This patch adds support for a new PHY to the sis900 driver.
See also Bugzilla 6919.
Signed-off-by: Daniele Venzano <venza@brownhat.org>
this patch is required to get a SIS964 based motherboard ethernet working
(FSC D1875) (picking the #1 transceiver, instead of the last one, in case
no known ones were found might be a better default, and would have worked
in this case too)
Signed-off-by: Artur Skawina <art_k@o2.pl>
This patch is identical to that introduced in
1a1276e7b6cba549553285f74e87f702bfff6fac to the Linus' 2.6 development tree
by Alan Cox.
'This is based on the proposed patches flying around but also checks that
the device in question is new enough to have word 93 rather thanb blindly
assuming word 93 == 0 means SATA (see ATA-5, ATA-7)' -- Alan Cox
Required for my SATA drive on an Asus Pundit-R to operate above 33MBps.
Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk>
Two different exports with the same name are not a good idea:
$ grep -r EXPORT_SYMBOL\(dmasound_init\) *
drivers/media/video/saa7134/saa7134-core.c:EXPORT_SYMBOL(dmasound_init);
sound/oss/dmasound/dmasound_core.c:EXPORT_SYMBOL(dmasound_init);
This patch renames the saa7134 dmasound_{init,exit} to
saa7134_dmasound_{init,exit}.
This patch fixes an array overrun spotted by the Coverity checker.
Use proper upper limits for the loops and check for all error
conditions.
The problem was noticed by Adrian Bunk.
Signed-off-by: Michael Chan <mchan@broadcom.com>
Fix receive tty error handling in synclink_gt driver.
Adrian reported compiler warning for incorrect bit test
against char variable. I determined these and other
device specific error bits were incorrectly defined.
Signed-off-by: Paul Fulghum <paulkf@microgate.com>
This patch adds support for the Promise FastTrak TX4300/TX4310 4-port PCI SATA
controllers based on the PDC40719 chip.
Signed-off-by: Daniel Drake <dsd@gentoo.org>
As detailed at http://bugs.gentoo.org/131534 :
2.6.16 converted many ACPI debug messages into error or warning
messages. One extraneous message was incorrectly converted, resulting in
logs being flooded by "Handle is NULL and Pathname is relative" messages
on some systems.
This patch (part of a larger ACPICA commit) converts the message back to
debug level.
Add a new PCI ID for SiI 3124. Reported by Silicon Image.
Signed-off-by: Tejun Heo <htejun@gmail.com>
xmon writes garbage on the screen because the nvidia console driver has
changed the line pitch from what the firmware set it to. Fix it by making
the nvidia driver inform the btext engine (which xmon uses if the screen is
its output device) about changes to display resolution.
The scx200_acb i2c bus driver pretends to support SMBus block
transactions, but in fact it implements the more simple I2C block
transactions. Additionally, it lacks sanity checks on the length
of the block transactions, which could lead to a buffer overrun.
This fixes an oops reported by Alexander Atanasov:
http://marc.theaimsgroup.com/?l=linux-kernel&m=114970382125094
Thanks to Ben Gardner for fixing my bugs :)
* Nack was sent one byte too late on reads >= 2 bytes.
* Stop bit was set one byte too late on reads.
Quadro NVS280 is a dual-head PCIe card with PCI ID 10de:00fd and subsystem I
10de:0215.
Signed-off-by: Pavel Roskin <proski@gnu.org>
Signed-off-by: Antonino Daplas <adaplas@pol.net>
This patch removes an unused variable.
Signed-off-by: Dave Jones <davej@redhat.com>
Based on a patch from the Ubuntu kernel.
Signed-off-by: Ben Collins <bcollins@ubuntu.com>
The Coverity checker noted that in
drivers/telephony/ixj.c:ixj_build_filter_cadence(), filter_en[4] or
filter_en[5] could be written to.
Add support for Geforce 6100 and related chipsets (PCI device id 0x024x)
START_ARRAY will not be removed in 2.6.16, therefore replace the date
reference with a kernel version reference.
Address http://bugzilla.kernel.org/show_bug.cgi?id=7189
It should check `clen', not `len'.
PPPoE must advertise the underlying device's MTU via the ppp channel
descriptor structure, as multilink functionality depends on it.
Signed-off-by: Michal Ostrowski <mostrows@earthlink.net>
Add a modeline for the Philips 200W display. aty128fb does not do DDC, it
picks 1920x1440 or similar. It works ok with nvidiafb because it can ask
for DDC data.
mode "1680x1050-60"
# D: 146.028 MHz, H: 65.191 kHz, V: 59.863 Hz
geometry 1680 1050 1680 1050 16
timings 6848 280 104 30 3 176 6
hsync high
vsync high
rgba 5/11,6/5,5/0,0/0
endmode
hwinfo --monitor
20: None 00.0: 10000 Monitor
[Created at monitor.206]
Unique ID: rdCR.pzUFTofo1S4
Parent ID: 002j.bJRsY88eNSC
Hardware Class: monitor
Model: "PHILIPS Philips 200W"
Vendor: PHL "PHILIPS"
Device: eisa 0x0832 "Philips 200W"
Serial ID: "VN 016596"
Resolution: 720x400@70Hz
Resolution: 640x480@60Hz
Resolution: 640x480@67Hz
Resolution: 640x480@72Hz
Resolution: 640x480@75Hz
Resolution: 800x600@56Hz
Resolution: 800x600@60Hz
Resolution: 800x600@72Hz
Resolution: 800x600@75Hz
Resolution: 832x624@75Hz
Resolution: 1024x768@60Hz
Resolution: 1024x768@70Hz
Resolution: 1024x768@75Hz
Resolution: 1280x1024@75Hz
Resolution: 1152x864@70Hz
Resolution: 1152x864@75Hz
Resolution: 1280x960@60Hz
Resolution: 1280x1024@60Hz
Resolution: 1680x1050@60Hz
Driver Info #0:
Max. Resolution: 1680x1050
Vert. Sync Range: 56-85 Hz
Hor. Sync Range: 30-93 kHz
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #5 (VGA compatible controller)
Signed-off-by: Olaf Hering <olh@suse.de>
Don't program the GMAC to reject flow control packets.
This maybe the cause of some of the transmit hangs.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
Fix support for fiber based devices. Needed to keep track of PMD type to
add workaround in setup. Add support for gigabit half duplex fiber.
Several code paths assume an additional 16 bytes of header padding
on the receive path. Use dev_alloc_skb to get that padding.
Backport the budget driver DISEQC instability fix.
Signed-off-by: Oliver Endriss <o.endriss@gmx.de>
Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Backport fix to artec USB DVB devices
The budget-av needs this GPIO set low for most cards to work.
ULE (Unidirectional Lightweight Encapsulation RFC 4326) decapsulation
code has a bug that allows an attacker to send a malformed ULE packet
with SNDU length of 0 and bring down the receiving machine. This patch
fix the bug and has been tested on version 2.6.17.11. This bug is 100%
reproducible and the modified source code (GPL) used to produce this bug
will be posted on http://nrg.cs.usm.my/downloads.htm shortly. The
kernel will produce a dump during CRC32 checking on faulty ULE packet.
Signed-off-by: Ang Way Chuang <wcang@nrg.cs.usm.my>
Keys on Yealink based phones will not function properly when using the
generic HID driver. This patch prevents the generic HID code from
grabbing the device before the regular yealink driver can get a grip on
it.
Signed-off-by: Henk Vergonet <Henk.Vergonet@gmail.com>
Signed-off-by: Vojtech Pavlik <vojtech@suse.cz>
This patch fixes a memory leak and a kernel oops when trying to unload
the driver, due to an unbalanced cleanup.
Thanks Ivar Jensen for spotting my mistake.
Signed-off-by: Henk Vergonet <henk.vergonet@gmail.com>
This patch fixes a bug in the handling of 'ignore' module parameters of I2C
client drivers.
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
This patch
- works around a bug in the I2C bridge that makes the initialization
of the TDA10046 fail on recent LifeView cards
- puts the AGC output to tristate in sleep mode. This is necessary for
recent hybrid cards that switch the AGC via tristateing.
Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Acked-by: Michael Krufky <mkrufky@linuxtv.org>
The via-velocity driver reports incorrect speed and link detected status
as viewed by ethtool (and probably other tools). This patch fixes those
incorrect reports and prettifies a long line.
Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net>
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
The patch fixes http://bugzilla.kernel.org/show_bug.cgi?id=6711
Signed-off-by: Roy Marples <uberlord@gentoo.org>
This patch enables agpgart on a Via "PT880 Ultra" based motherboard
(Asus P4V800D-X). The PCI ID of the PT880 Ultra is 0x0308 instead of
0x0258 of the PT880.
The patched via-agp passes testgart.
Signed-off-by: Magnus Kessler <Magnus.Kessler@gmx.net>
- Set outputs to tristate in sleep mode
- Reduce dangerously high firmware download speed with 16MHz xtal
- added tda827x configuration with GPIOs low
- added comments to stupid looking IIC reads that work around bugs in
the tda10046.
- some minor updates
based on drivers/media/common/ir-keymaps.c:ir_codes_flydvb
in Linus' tree.
There seem to be many variants of this cards with different
feature sets. This entry supports
analog TV, CVBS and s-video input, FM radio and DVB-T
if they are supported by the hardware.
The .vmux entry needs to be 1 instead of 0
Added ID entries for the Genius VideoWonder DVB-T
and the LifeView FlyTV Platinum Gold
The saa7134 drivers uses request_firmware()
and thus needs to select FW_LOADER.
Signed-off-by: maximilian attems <maks@sternwelten.at>
The device, Medion 7134, has two saa7134 chips on it, but only one of them
is functional in the current saa7134 driver.
This patch adds autodetection for the second, unsupported saa7134 chip,
as SAA7134_BOARD_MD7134_BRIDGE_2, and displays a message to the user
(in dmesg) indicating that the second chip isn't yet functional.
This is useful for users, since two instances of the saa7134 driver
will spawn. This patch will prevent confusion by warning the user that
only one of the chips on the board are functional.
There are other versions of the SAA7134_BOARD_MD7134 with only a single
saa7134 bridge/decoder -- those devices will not be affected by this patch.
Only devices containing the second chip will display the warning.
There are already some supported devices that contain two
saa713x chips on-board, where only one of these chips is
currently functional in the driver.
We are already printing a warning message for the second
saa7134 decoder in SAA7134_BOARD_AVERMEDIA_A169_B. This
patch alters that case to make it generic, so that other
cards in the same situation can use it.
- Added support for AVerMedia A169 Dual Analog tuner card
(dual saa7134 decoders - only 1 working right now)
- Added autodetection for both parts of the card.
It shows up like 2 cards, B1 and B
- Enabled tuner B1, SVIDEO on B1 and composite1 through SVIDEO,
FIXME: B is more or less dead at this point and I suspect the
FM-radio is on the B part of the board
Adrian Bunk:
slightly adapted to 2.6.16
Signed-off-by: Rickard Osser <ricky@osser.se>
I have the same card with the same PCI id, but from KWorld.
The patch documents that this is the same card.
- Corrected autodetection for saa7130 card:
subsystem: 1048:226c, board: ELSA EX-VISION 700TV
Signed-off-by: TAMUKI Shoichi <tamuki@linet.gr.jp>
- Enable the tuv1236 tuner on the Kworld-ATSC110 card so that the
tuner can be identified when tuners.ko loads.
- With this change it is no longer necessary to remove and reload
the tuner module in order to get the tuv1236 identified.
- This code was copied from the ATI HDTV Wonder init routine (in cx88-cards.c)
which also uses the TUV1236D.
Signed-off-by: Curt Meyers <cmeyers@boilerbots.com>
