path: root/drivers
2014-09-03hpsa: fix bad -ENOMEM return value in hpsa_big_passthru_ioctlStephen M. Cameron
commit 0758f4f732b08b6ef07f2e5f735655cf69fea477 upstream. When copy_from_user fails, return -EFAULT, not -ENOMEM Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Reported-by: Robert Elliott <elliott@hp.com> Reviewed-by: Joe Handzik <joseph.t.handzik@hp.com> Reviewed-by: Scott Teel <scott.teel@hp.com> Reviewed by: Mike MIller <michael.miller@canonical.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03PCI: Configure ASPM when enabling deviceVidya Sagar
commit 1f6ae47ecff7f23da73417e068018b311f3b5583 upstream. We can't do ASPM configuration at enumeration-time because enabling it makes some defective hardware unresponsive, even if ASPM is disabled later (see 41cd766b0659 ("PCI: Don't enable aspm before drivers have had a chance to veto it"). Therefore, we have to do it after a driver claims the device. We previously configured ASPM in pci_set_power_state(), but that's not a very good place because it's not really related to setting the PCI device power state, and doing it there means: - We incorrectly skipped ASPM config when setting a device that's already in D0 to D0. - We unnecessarily configured ASPM when setting a device to a low-power state (the ASPM feature only applies when the device is in D0). - We unnecessarily configured ASPM when called from a .resume() method (ASPM configuration needs to be restored during resume, but pci_restore_pcie_state() should already do this). Move ASPM configuration from pci_set_power_state() to do_pci_enable_device() so we do it when a driver enables a device. [bhelgaas: changelog] Link: https://bugzilla.kernel.org/show_bug.cgi?id=79621 Fixes: db288c9c5f9d ("PCI / PM: restore the original behavior of pci_set_power_state()") Suggested-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Vidya Sagar <sagar.tv@gmail.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03drm/radeon: add new KV pci idAlex Deucher
commit 6dc14baf4ced769017c7a7045019c7a19f373865 upstream. bug: https://bugs.freedesktop.org/show_bug.cgi?id=82912 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03crypto: ux500 - make interrupt mode plausibleArnd Bergmann
commit e1f8859ee265fc89bd21b4dca79e8e983a044892 upstream. The interrupt handler in the ux500 crypto driver has an obviously incorrect way to access the data buffer, which for a while has caused this build warning: ../ux500/cryp/cryp_core.c: In function 'cryp_interrupt_handler': ../ux500/cryp/cryp_core.c:234:5: warning: passing argument 1 of '__fswab32' makes integer from pointer without a cast [enabled by default] writel_relaxed(ctx->indata, ^ In file included from ../include/linux/swab.h:4:0, from ../include/uapi/linux/byteorder/big_endian.h:12, from ../include/linux/byteorder/big_endian.h:4, from ../arch/arm/include/uapi/asm/byteorder.h:19, from ../include/asm-generic/bitops/le.h:5, from ../arch/arm/include/asm/bitops.h:340, from ../include/linux/bitops.h:33, from ../include/linux/kernel.h:10, from ../include/linux/clk.h:16, from ../drivers/crypto/ux500/cryp/cryp_core.c:12: ../include/uapi/linux/swab.h:57:119: note: expected '__u32' but argument is of type 'const u8 *' static inline __attribute_const__ __u32 __fswab32(__u32 val) There are at least two, possibly three problems here: a) when writing into the FIFO, we copy the pointer rather than the actual data we want to give to the hardware b) the data pointer is an array of 8-bit values, while the FIFO is 32-bit wide, so both the read and write access fail to do a proper type conversion c) This seems incorrect for big-endian kernels, on which we need to byte-swap any register access, but not normally FIFO accesses, at least the DMA case doesn't do it either. This converts the bogus loop to use the same readsl/writesl pair that we use for the two other modes (DMA and polling). This is more efficient and consistent, and probably correct for endianess. The bug has existed since the driver was first merged, and was probably never detected because nobody tried to use interrupt mode. It might make sense to backport this fix to stable kernels, depending on how the crypto maintainers feel about that. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: linux-crypto@vger.kernel.org Cc: Fabio Baltieri <fabio.baltieri@linaro.org> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03serial: core: Preserve termios c_cflag for console resumePeter Hurley
commit ae84db9661cafc63d179e1d985a2c5b841ff0ac4 upstream. When a tty is opened for the serial console, the termios c_cflag settings are inherited from the console line settings. However, if the tty is subsequently closed, the termios settings are lost. This results in a garbled console if the console is later suspended and resumed. Preserve the termios c_cflag for the serial console when the tty is shutdown; this reflects the most recent line settings. Fixes: Bugzilla #69751, 'serial console does not wake from S3' Reported-by: Valerio Vanni <valerio.vanni@inwind.it> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03drivers/i2c/busses: use correct type for dma_map/unmapWolfram Sang
commit 28772ac8711e4d7268c06e765887dd8cb6924f98 upstream. dma_{un}map_* uses 'enum dma_data_direction' not 'enum dma_transfer_direction'. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03tpm: Add missing tpm_do_selftest to ST33 I2C driverJason Gunthorpe
commit f07a5e9a331045e976a3d317ba43d14859d9407c upstream. Most device drivers do call 'tpm_do_selftest' which executes a TPM_ContinueSelfTest. tpm_i2c_stm_st33 is just pointlessly different, I think it is bug. These days we have the general assumption that the TPM is usable by the kernel immediately after the driver is finished, so we can no longer defer the mandatory self test to userspace. Reported-by: Richard Marciel <rmaciel@linux.vnet.ibm.com> Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03hwmon: (dme1737) Prevent overflow problem when writing large limitsAxel Lin
commit d58e47d787c09fe5c61af3c6ce7d784762f29c3d upstream. On platforms with sizeof(int) < sizeof(long), writing a temperature limit larger than MAXINT will result in unpredictable limit values written to the chip. Avoid auto-conversion from long to int to fix the problem. Voltage limits, fan minimum speed, pwm frequency, pwm ramp rate, and other attributes have the same problem, fix them as well. Zone temperature limits are signed, but were cached as u8, causing unepected values to be reported for negative temperatures. Cache as s8 to fix the problem. vrm is an u8, so the written value needs to be limited to [0, 255]. Signed-off-by: Axel Lin <axel.lin@ingics.com> [Guenter Roeck: Fix zone temperature cache] Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03hwmon: (ads1015) Fix out-of-bounds array accessAxel Lin
commit e981429557cbe10c780fab1c1a237cb832757652 upstream. Current code uses data_rate as array index in ads1015_read_adc() and uses pga as array index in ads1015_reg_to_mv, so we must make sure both data_rate and pga settings are in valid value range. Return -EINVAL if the setting is out-of-range. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03hwmon: (lm85) Fix various errors on attribute writesGuenter Roeck
commit 3248c3b771ddd9d31695da17ba350eb6e1b80a53 upstream. Temperature limit register writes did not account for negative numbers. As a result, writing -127000 resulted in -126000 written into the temperature limit register. This problem affected temp[1-3]_min, temp[1-3]_max, temp[1-3]_auto_temp_crit, and temp[1-3]_auto_temp_min. When writing pwm[1-3]_freq, a long variable was auto-converted into an int without range check. Wiring values larger than MAXINT resulted in unexpected register values. When writing temp[1-3]_auto_temp_max, an unsigned long variable was auto-converted into an int without range check. Writing values larger than MAXINT resulted in unexpected register values. vrm is an u8, so the written value needs to be limited to [0, 255]. Cc: Axel Lin <axel.lin@ingics.com> Reviewed-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03hwmon: (ads1015) Fix off-by-one for valid channel index checkingAxel Lin
commit 56de1377ad92f72ee4e5cb0faf7a9b6048fdf0bf upstream. Current code uses channel as array index, so the valid channel value is 0 .. ADS1015_CHANNELS - 1. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03hwmon: (gpio-fan) Prevent overflow problem when writing large limitsAxel Lin
commit 2565fb05d1e9fc0831f7b1c083bcfcb1cba1f020 upstream. On platforms with sizeof(int) < sizeof(unsigned long), writing a rpm value larger than MAXINT will result in unpredictable limit values written to the chip. Avoid auto-conversion from unsigned long to int to fix the problem. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03hwmon: (lm78) Fix overflow problems seen when writing large temperature limitsGuenter Roeck
commit 1074d683a51f1aded3562add9ef313e75d557327 upstream. On platforms with sizeof(int) < sizeof(long), writing a temperature limit larger than MAXINT will result in unpredictable limit values written to the chip. Avoid auto-conversion from long to int to fix the problem. Cc: Axel Lin <axel.lin@ingics.com> Reviewed-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03hwmon: (amc6821) Fix possible race condition bugAxel Lin
commit cf44819c98db11163f58f08b822d626c7a8f5188 upstream. Ensure mutex lock protects the read-modify-write period to prevent possible race condition bug. In additional, update data->valid should also be protected by the mutex lock. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03hwmon: (sis5595) Prevent overflow problem when writing large limitsAxel Lin
commit cc336546ddca8c22de83720632431c16a5f9fe9a upstream. On platforms with sizeof(int) < sizeof(long), writing a temperature limit larger than MAXINT will result in unpredictable limit values written to the chip. Avoid auto-conversion from long to int to fix the problem. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03drm: omapdrm: fix compiler errorsRussell King
commit 2d31ca3ad7d5d44c8adc7f253c96ce33f3a2e931 upstream. Regular randconfig nightly testing has detected problems with omapdrm. omapdrm fails to build when the kernel is built to support 64-bit DMA addresses and/or 64-bit physical addresses due to an assumption about the width of these types. Use %pad to print DMA addresses, rather than %x or %Zx (which is even more wrong than %x). Avoid passing a uint32_t pointer into a function which expects dma_addr_t pointer. drivers/gpu/drm/omapdrm/omap_plane.c: In function 'omap_plane_pre_apply': drivers/gpu/drm/omapdrm/omap_plane.c:145:2: error: format '%x' expects argument of type 'unsigned int', but argument 5 has type 'dma_addr_t' [-Werror=format] drivers/gpu/drm/omapdrm/omap_plane.c:145:2: error: format '%x' expects argument of type 'unsigned int', but argument 6 has type 'dma_addr_t' [-Werror=format] make[5]: *** [drivers/gpu/drm/omapdrm/omap_plane.o] Error 1 drivers/gpu/drm/omapdrm/omap_gem.c: In function 'omap_gem_get_paddr': drivers/gpu/drm/omapdrm/omap_gem.c:794:4: error: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'dma_addr_t' [-Werror=format] drivers/gpu/drm/omapdrm/omap_gem.c: In function 'omap_gem_describe': drivers/gpu/drm/omapdrm/omap_gem.c:991:4: error: format '%Zx' expects argument of type 'size_t', but argument 7 has type 'dma_addr_t' [-Werror=format] drivers/gpu/drm/omapdrm/omap_gem.c: In function 'omap_gem_init': drivers/gpu/drm/omapdrm/omap_gem.c:1470:4: error: format '%x' expects argument of type 'unsigned int', but argument 7 has type 'dma_addr_t' [-Werror=format] make[5]: *** [drivers/gpu/drm/omapdrm/omap_gem.o] Error 1 drivers/gpu/drm/omapdrm/omap_dmm_tiler.c: In function 'dmm_txn_append': drivers/gpu/drm/omapdrm/omap_dmm_tiler.c:226:2: error: passing argument 3 of 'alloc_dma' from incompatible pointer type [-Werror] make[5]: *** [drivers/gpu/drm/omapdrm/omap_dmm_tiler.o] Error 1 make[5]: Target `__build' not remade because of errors. make[4]: *** [drivers/gpu/drm/omapdrm] Error 2 Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03mei: start disconnect request timer consistentlyAlexander Usyskin
commit 22b987a325701223f9a37db700c6eb20b9924c6f upstream. Link must be reset in case the fw doesn't respond to client disconnect request. We did charge the timer only in irq path from mei_cl_irq_close and not in mei_cl_disconnect Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03USB: Fix persist resume of some SS USB devicesPratyush Anand
commit a40178b2fa6ad87670fb1e5fa4024db00c149629 upstream. Problem Summary: Problem has been observed generally with PM states where VBUS goes off during suspend. There are some SS USB devices which take longer time for link training compared to many others. Such devices fail to reconnect with same old address which was associated with it before suspend. When system resumes, at some point of time (dpm_run_callback-> usb_dev_resume->usb_resume->usb_resume_both->usb_resume_device-> usb_port_resume) SW reads hub status. If device is present, then it finishes port resume and re-enumerates device with same address. If device is not present then, SW thinks that device was removed during suspend and therefore does logical disconnection and removes all the resource allocated for this device. Now, if I put sufficient delay just before root hub status read in usb_resume_device then, SW sees always that device is present. In normal course(without any delay) SW sees that no device is present and then SW removes all resource associated with the device at this port. In the latter case, after sometime, device says that hey I am here, now host enumerates it, but with new address. Problem had been reproduced when I connect verbatim USB3.0 hard disc with my STiH407 XHCI host running with 3.10 kernel. I see that similar problem has been reported here. https://bugzilla.kernel.org/show_bug.cgi?id=53211 Reading above it seems that bug was not in 3.6.6 and was present in 3.8 and again it was not present for some in 3.12.6, while it was present for few others. I tested with 3.13-FC19 running at i686 desktop, problem was still there. However, I was failed to reproduce it with 3.16-RC4 running at same i686 machine. I would say it is just a random observation. Problem for few devices is always there, as I am unable to find a proper fix for the issue. So, now question is what should be the amount of delay so that host is always able to recognize suspended device after resume. XHCI specs 4.19.4 says that when Link training is successful, port sets CSC bit to 1. So if SW reads port status before successful link training, then it will not find device to be present. USB Analyzer log with such buggy devices show that in some cases device switch on the RX termination after long delay of host enabling the VBUS. In few other cases it has been seen that device fails to negotiate link training in first attempt. It has been reported till now that few devices take as long as 2000 ms to train the link after host enabling its VBUS and RX termination. This patch implements a 2000 ms timeout for CSC bit to set ie for link training. If in a case link trains before timeout, loop will exit earlier. This patch implements above delay, but only for SS device and when persist is enabled. So, for the good device overhead is almost none. While for the bad devices penalty could be the time which it take for link training. But, If a device was connected before suspend, and was removed while system was asleep, then the penalty would be the timeout ie 2000 ms. Results: Verbatim USB SS hard disk connected with STiH407 USB host running 3.10 Kernel resumes in 461 msecs without this patch, but hard disk is assigned a new device address. Same system resumes in 790 msecs with this patch, but with old device address. Signed-off-by: Pratyush Anand <pratyush.anand@st.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03USB: ehci-pci: USB host controller support for Intel Quark X1000Bryan O'Donoghue
commit 6e693739e9b603b3ca9ce0d4f4178f0633458465 upstream. The EHCI packet buffer in/out threshold is programmable for Intel Quark X1000 USB host controller, and the default value is 0x20 dwords. The in/out threshold can be programmed to 0x80 dwords (512 Bytes) to maximize the perfomrance, but only when isochronous/interrupt transactions are not initiated by the USB host controller. This patch is to reconfigure the packet buffer in/out threshold as maximal as possible to maximize the performance, and 0x7F dwords (508 Bytes) should be used because the USB host controller initiates isochronous/interrupt transactions. Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@intel.com> Signed-off-by: Alvin (Weike) Chen <alvin.chen@intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Reviewed-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03USB: serial: ftdi_sio: Add support for new Xsens devicesPatrick Riphagen
commit 4bdcde358b4bda74e356841d351945ca3f2245dd upstream. This adds support for new Xsens devices, using Xsens' own Vendor ID. Signed-off-by: Patrick Riphagen <patrick.riphagen@xsens.com> Signed-off-by: Frans Klaver <frans.klaver@xsens.com> Cc: Johan Hovold <johan@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03USB: serial: ftdi_sio: Annotate the current Xsens PID assignmentsPatrick Riphagen
commit 9273b8a270878906540349422ab24558b9d65716 upstream. The converters are used in specific products. It can be useful to know which they are exactly. Signed-off-by: Patrick Riphagen <patrick.riphagen@xsens.com> Signed-off-by: Frans Klaver <frans.klaver@xsens.com> Cc: Johan Hovold <johan@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03USB: devio: fix issue with log floodingOliver Neukum
commit d310d05f1225d1f6f2bf505255fdf593bfbb3051 upstream. usbfs allows user space to pass down an URB which sets URB_SHORT_NOT_OK for output URBs. That causes usbcore to log messages without limit for a nonsensical disallowed combination. The fix is to silently drop the attribute in usbfs. The problem is reported to exist since 3.14 https://www.virtualbox.org/ticket/13085 Signed-off-by: Oliver Neukum <oneukum@suse.de> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03USB: OHCI: don't lose track of EDs when a controller diesAlan Stern
commit 977dcfdc60311e7aa571cabf6f39c36dde13339e upstream. This patch fixes a bug in ohci-hcd. When an URB is unlinked, the corresponding Endpoint Descriptor is added to the ed_rm_list and taken off the hardware schedule. Once the ED is no longer visible to the hardware, finish_unlinks() handles the URBs that were unlinked or have completed. If any URBs remain attached to the ED, the ED is added back to the hardware schedule -- but only if the controller is running. This fails when a controller dies. A non-empty ED does not get added back to the hardware schedule and does not remain on the ed_rm_list; ohci-hcd loses track of it. The remaining URBs cannot be unlinked, which causes the USB stack to hang. The patch changes finish_unlinks() so that non-empty EDs remain on the ed_rm_list if the controller isn't running. This requires moving some of the existing code around, to avoid modifying the ED's hardware fields more than once. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03USB: OHCI: fix bugs in debug routinesAlan Stern
commit 256dbcd80f1ccf8abf421c1d72ba79a4e29941dd upstream. The debug routine fill_async_buffer() in ohci-hcd is buggy: It never produces any output because it forgets to initialize the output buffer size. Also, the debug routine ohci_dump() has an unused argument. This patch adds the correct initialization and removes the unused argument. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03HID: fix a couple of off-by-onesJiri Kosina
commit 4ab25786c87eb20857bbb715c3ae34ec8fd6a214 upstream. There are a few very theoretical off-by-one bugs in report descriptor size checking when performing a pre-parsing fixup. Fix those. Reported-by: Ben Hawkes <hawkes@google.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-03HID: logitech: perform bounds checking on device_id early enoughJiri Kosina
commit ad3e14d7c5268c2e24477c6ef54bbdf88add5d36 upstream. device_index is a char type and the size of paired_dj_deivces is 7 elements, therefore proper bounds checking has to be applied to device_index before it is used. We are currently performing the bounds checking in logi_dj_recv_add_djhid_device(), which is too late, as malicious device could send REPORT_TYPE_NOTIF_DEVICE_UNPAIRED early enough and trigger the problem in one of the report forwarding functions called from logi_dj_raw_event(). Fix this by performing the check at the earliest possible ocasion in logi_dj_raw_event(). Reported-by: Ben Hawkes <hawkes@google.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-02HID: add quirk for 0x04d9:0xa096 deviceWangzhao Cai
commit 30c6fd4277ebab2a32ae5635d34283354b1bc8f2 upstream. I am using a USB keyborad that give me "usb_submit_urb(ctrl) failed: -1" error when I plugin it. and I need to wait for 10s for this device to be ready. By adding this quirks, the usb keyborad is usable right after plugin Signed-off-by: Wangzhao Cai <microcaicai@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-02USB: core: hcd-pci: free IRQ before disabling PCI device when shutting downJiang Liu
commit c5946f9d286ad368329c79107fdf4d825d2091bd upstream. The assigned IRQ should be freed before calling pci_disable_device() when shutting down system, otherwise it will cause following warning. [ 568.879482] ------------[ cut here ]------------ [ 568.884236] WARNING: CPU: 1 PID: 3300 at /home/konrad/ssd/konrad/xtt-i386/bootstrap/linux-usb/fs/proc/generic.c:521 remove_proc_entry+0x165/0x170() [ 568.897846] remove_proc_entry: removing non-empty directory 'irq/16', leaking at least 'ohci_hcd:usb4' [ 568.907430] Modules linked in: dm_multipath dm_mod iscsi_boot_sysfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi libcrc32c crc32c_generic sg sd_mod crct10dif_generic crc_t10dif crct10dif_common radeon fbcon tileblit ttm font bitblit softcursor ata_generic ahci libahci drm_kms_helper skge r8169 libata mii scsi_mod wmi acpi_cpufreq [ 568.938539] CPU: 1 PID: 3300 Comm: init Tainted: G W 3.16.0-rc5upstream-01651-g03b9189 #1 [ 568.947946] Hardware name: ECS A780GM-A Ultra/A780GM-A Ultra, BIOS 080015 04/01/2010 [ 568.956008] 00000209 ed0f1cd0 c1617946 c175403c ed0f1d00 c1090c3f c1754084 ed0f1d2c [ 568.964068] 00000ce4 c175403c 00000209 c11f22a5 c11f22a5 f755e8c0 ed0f1d78 f755e90d [ 568.972128] ed0f1d18 c1090cde 00000009 ed0f1d10 c1754084 ed0f1d2c ed0f1d60 c11f22a5 [ 568.980194] Call Trace: [ 568.982715] [<c1617946>] dump_stack+0x48/0x60 [ 568.987294] [<c1090c3f>] warn_slowpath_common+0x7f/0xa0 [ 569.003887] [<c1090cde>] warn_slowpath_fmt+0x2e/0x30 [ 569.009092] [<c11f22a5>] remove_proc_entry+0x165/0x170 [ 569.014476] [<c10da6ca>] unregister_irq_proc+0xaa/0xc0 [ 569.019858] [<c10d582f>] free_desc+0x1f/0x60 [ 569.024346] [<c10d58aa>] irq_free_descs+0x3a/0x80 [ 569.029283] [<c10d9e9d>] irq_dispose_mapping+0x2d/0x50 [ 569.034666] [<c1078fd3>] mp_unmap_irq+0x73/0xa0 [ 569.039423] [<c107196b>] acpi_unregister_gsi_ioapic+0x2b/0x40 [ 569.045431] [<c107180f>] acpi_unregister_gsi+0xf/0x20 [ 569.050725] [<c1339cad>] acpi_pci_irq_disable+0x4b/0x50 [ 569.056196] [<c14daa38>] pcibios_disable_device+0x18/0x20 [ 569.061848] [<c130123d>] do_pci_disable_device+0x4d/0x60 [ 569.067410] [<c13012b7>] pci_disable_device+0x47/0xb0 [ 569.077814] [<c14800b1>] usb_hcd_pci_shutdown+0x31/0x40 [ 569.083285] [<c1304b19>] pci_device_shutdown+0x19/0x50 [ 569.088667] [<c13fda64>] device_shutdown+0x14/0x120 [ 569.093777] [<c10ac29d>] kernel_restart_prepare+0x2d/0x30 [ 569.099429] [<c10ac41e>] kernel_restart+0xe/0x60 [ 569.109028] [<c10ac611>] SYSC_reboot+0x191/0x220 [ 569.159269] [<c10ac6ba>] SyS_reboot+0x1a/0x20 [ 569.163843] [<c161c718>] sysenter_do_call+0x12/0x16 [ 569.168951] ---[ end trace ccc1ec4471c289c9 ]--- Tested-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Reviewed-by: Huang Rui <ray.huang@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-02usb-core bInterval quirkJames P Michels III
commit cd83ce9e6195aa3ea15ab4db92892802c20df5d0 upstream. This patch adds a usb quirk to support devices with interupt endpoints and bInterval values expressed as microframes. The quirk causes the parse endpoint function to modify the reported bInterval to a standards conforming value. There is currently code in the endpoint parser that checks for bIntervals that are outside of the valid range (1-16 for USB 2+ high speed and super speed interupt endpoints). In this case, the code assumes the bInterval is being reported in 1ms frames. As well, the correction is only applied if the original bInterval value is out of the 1-16 range. With this quirk applied to the device, the bInterval will be accurately adjusted from microframes to an exponent. Signed-off-by: James P Michels III <james.p.michels@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-02USB: add reset resume quirk for usb3503Joonyoung Shim
commit 526a4045c60fbaede88ec95a69a73059dff02160 upstream. The usb device will autoresume from choose_wakeup() if it is autosuspended with the wrong wakeup setting, but below errors occur because usb3503 misc driver will switch to standby mode when suspended. As add USB_QUIRK_RESET_RESUME, it can stop setting wrong wakeup from autosuspend_check(). [ 7.734717] usb 1-3: reset high-speed USB device number 3 using exynos-ehci [ 7.854658] usb 1-3: device descriptor read/64, error -71 [ 8.079657] usb 1-3: device descriptor read/64, error -71 [ 8.294664] usb 1-3: reset high-speed USB device number 3 using exynos-ehci [ 8.414658] usb 1-3: device descriptor read/64, error -71 [ 8.639657] usb 1-3: device descriptor read/64, error -71 [ 8.854667] usb 1-3: reset high-speed USB device number 3 using exynos-ehci [ 9.264598] usb 1-3: device not accepting address 3, error -71 [ 9.374655] usb 1-3: reset high-speed USB device number 3 using exynos-ehci [ 9.784601] usb 1-3: device not accepting address 3, error -71 [ 9.784838] usb usb1-port3: device 1-3 not suspended yet Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-02USB: serial: cp210x: Removing unncessary `usb_reset_device` on startupPreston Fick
commit 934ef5aca9daea10507eebcbd0fb8f6d57d55359 upstream. This `usb_reset_device` command has been around since the driver was originally reverse engineered. It doesn't cause much issue on single interface CP210x devices, but on the CP2105 and CP2108 with 2 and 4 interfaces respectively it will cause instability on enumeration and delays enumeration noticably. There should be no reason to reset a device at startup, per the CP210x AN571 spec. Signed-off-by: Preston Fick <preston.fick@silabs.com> Cc: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-02usb: musb: cppi41: fire hrtimer according to programmed channel lengthDaniel Mack
commit 50aea6fca771d6daf3ec24f771da866f7fd836e4 upstream. The musb/cppi41 code installs a hrtimer to work around DMA completion interrupts that have fired too early on AM335x hardware. This timer is currently programmed to first fire 140 microseconds after the DMA completion callback. According to the commit which introduced it (a655f481d83, "usb: musb: musb_cppi41: handle pre-mature TX complete interrupt"), that value is is considered a 'rule of thumb' that worked well with the test case described in the commit log. Test show, however, that for USB audio devices and much smaller packet sizes, the timer has to fire earlier in order to correctly handle the audio stream. The original test case had output transfer sizes of 1514 bytes, and a delay of 140 microseconds. For audio devices with 24 bytes channel size, 3 microseconds seem to work well. Hence, let's assume that the time it takes to clear the bit correlates with the number of bytes transferred. The referenced commit log mentions such a suspicion as well. Let the timer fire in cppi41_channel->total_len/10 microseconds to correctly handle both cases. Also, shorten the interval in which the timer fires again in case of a non-empty early_tx list. With these changes in place, both FS and HS audio devices appear to work well on AM335x hardware. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-by: Sebastian Reimers <sebastian.reimers@googlemail.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-02bcache: Minor journal fixKent Overstreet
commit b3fa7e77e67e647db3db2166b65083a427d84ed3 upstream. The real fix is where we check the bytes we need against how much is remaining - we also need to check for a journal entry bigger than our buffer, we'll never write those and it would be bad if we tried to read one. Also improve the diagnostic messages. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26drivers/rtc/interface.c: fix infinite loop in initializing the alarmAles Novak
commit ee1d90146815fdc8d653c558b327fff2acba041d upstream. In __rtc_read_alarm(), if the alarm time retrieved by rtc_read_alarm_internal() from the device contains invalid values (e.g. month=2,mday=31) and the year not set (=-1), the initialization will loop infinitely because the year-fixing loop expects the time being invalid due to leap year. Fix reduces the loop to the leap years and adds final validity check. Signed-off-by: Ales Novak <alnovak@suse.cz> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Reported-by: Jiri Bohac <jbohac@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26drivers/rtc/rtc-efi.c: check for invalid data coming back from UEFIJan Beulich
commit 6e85bab6bc1019f9b87c53b32da3ad7791e7ddf9 upstream. In particular seeing zero in eft->month is problematic, as it results in -1 (converted to unsigned int, i.e. yielding 0xffffffff) getting passed to rtc_year_days(), where the value gets used as an array index (normally resulting in a crash). This was observed with the driver enabled on x86 on some Fujitsu system (with possibly not up to date firmware, but anyway). Perhaps efi_read_alarm() should not fail if neither enabled nor pending are set, but the returned time is invalid? Signed-off-by: Jan Beulich <jbeulich@suse.com> Reported-by: Raymund Will <rw@suse.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Jingoo Han <jg1.han@samsung.com> Acked-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26drivers/rtc/rtc-efi.c: avoid subtracting day twice when computing year daysLee, Chun-Yi
commit 809d9627087e1db63b8672c1f264af73b13116fb upstream. Compared source code of rtc-lib.c::rtc_year_days() with efirtc.c::rtc_year_days(), found the code in rtc-efi decreases value of day twice when it computing year days. rtc-lib.c::rtc_year_days() has already decrease days and return the year days from 0 to 365. Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26HID: logitech-dj: Fix USB 3.0 issueBenjamin Tisssoires
commit 42c22dbf81ebd1146960875ddfe71630cb2b3ae6 upstream. This fix (not very clean though) should fix the long time USB3 issue that was spotted last year. The rational has been given by Hans de Goede: ---- I think the most likely cause for this is a firmware bug in the unifying receiver, likely a race condition. The most prominent difference between having a USB-2 device plugged into an EHCI (so USB-2 only) port versus an XHCI port will be inter packet timing. Specifically if you send packets (ie hid reports) one at a time, then with the EHCI controller their will be a significant pause between them, where with XHCI they will be very close together in time. The reason for this is the difference in EHCI / XHCI controller OS <-> driver interfaces. For non periodic endpoints (control, bulk) the EHCI uses a circular linked-list of commands in dma-memory, which it follows to execute commands, if the list is empty, it will go into an idle state and re-check periodically. The XHCI uses a ring of commands per endpoint, and if the OS places anything new on the ring it will do an ioport write, waking up the XHCI making it send the new packet immediately. For periodic transfers (isoc, interrupt) the delay between packets when sending one at a time (rather then queuing them up) will be even larger, because they need to be inserted into the EHCI schedule 2 ms in the future so the OS driver can be sure that the EHCI driver does not try to start executing the time slot in question before the insertion has completed. So a possible fix may be to insert a delay between packets being send to the receiver. ---- I tested this on a buggy Haswell USB 3.0 motherboard, and I always get the notification after adding the msleep. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26Input: i8042 - add Acer Aspire 5710 to nomux blacklistJiri Kosina
commit 8c947e20cb1f442c704852b2ca24b81981b09493 upstream. Acer Aspire needs to be added to nomux blacklist, otherwise the touchpad misbehaves rather randomly. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26PCI: rphahp: Fix endianess issuesLaurent Dufour
commit 761ce53330a4f02c58768631027d1c1dd0d538f7 upstream. Numerical values stored in the device tree are encoded in Big Endian and should be byte swapped when running in Little Endian. The RPA hotplug module should convert those values as well. Note that in rpaphp_get_drc_props(), the comparison between indexes[i+1] and *index is done using the BE values (whatever is the current endianess). This doesn't matter since we are checking for equality here. This way only the returned value is byte swapped. RPA also made RTAS calls which implies BE values to be used. According to the patch done in RTAS (http://patchwork.ozlabs.org/patch/336865), no additional conversion is required in RPA. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26tg3: Add support for new 577xx device idsNithin Sujir
commit 68273712a19e9107a498a371532b3b3eb6dbb14c upstream. This patch adds support for 57764, 57765, 57787, 57782 and 57786 devices. Signed-off-by: Nithin Nayak Sujir <nsujir@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26bnx2fc: fix memory leak in bnx2fc_allocate_hash_table()Maurizio Lombardi
commit fdbcbcab0eae6773430546697ace0b3fe48e7fbc upstream. In case of error, the bnx2fc_allocate_hash_table() didn't free all the memory it allocated. Signed-off-by: Maurizio Lombardi <mlombard@redhat.com> Acked-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26bnx2x: Test nvram when interface is downYuval Mintz
commit bd8e012b5d369933f50842294372ed580f5d9605 upstream. Since commit 3fb43eb ("bnx2x: Change to D3hot only on removal") nvram is accessible whenever the driver is loaded - Thus it is possible to test it during self-test even if the interface is down Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Ariel Elior <ariele@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26RDMA/cxgb3: Fix information leak in send_abort()Dan Carpenter
commit e4514cbd972786af67dd6c442c072685387e22a2 upstream. The cpl_abort_req struct has several reserved members which need to be cleared to avoid disclosing kernel information. I have added a memset() so now it matches the cxgb4 version of this function. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26netxen: Correct off-by-one errors in bounds checksDavid Gibson
commit 4710b2ba873692194c636811ceda398f95e02db2 upstream. netxen_process_lro() contains two bounds checks. One for the ring number against the number of rings, and one for the Rx buffer ID against the array of receive buffers. Both of these have off-by-one errors, using > instead of >=. The correct versions are used in netxen_process_rcv(), they're just wrong in netxen_process_lro(). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26DMA-API: net: brocade/bna/bnad.c: fix 32-bit DMA mask handlingRussell King
commit 3e5480791e3b0e239d2cd4e5ecd43a7d2585484b upstream. The fallback to 32-bit DMA mask is rather odd: if (!dma_set_mask(&pdev->dev, DMA_BIT_MASK(64)) && !dma_set_coherent_mask(&pdev->dev, DMA_BIT_MASK(64))) { *using_dac = true; } else { err = dma_set_mask(&pdev->dev, DMA_BIT_MASK(32)); if (err) { err = dma_set_coherent_mask(&pdev->dev, DMA_BIT_MASK(32)); if (err) goto release_regions; } This means we only try and set the coherent DMA mask if we failed to set a 32-bit DMA mask, and only if both fail do we fail the driver. Adjust this so that if either setting fails, we fail the driver - and thereby end up properly setting both the DMA mask and the coherent DMA mask in the fallback case. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26igbvf: add missing iounmap() on error in igbvf_probe()Wei Yongjun
commit de524681f88ff4ed293aa239f83c8cb04d59b47d upstream. Add the missing iounmap() before return from igbvf_probe() in the error handling case. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Tested-by: Sibai Li <Sibai.li@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26igbvf: integer wrapping bug setting the mtuDan Carpenter
commit 3de9e65f011b95235a789b12abc4730570cdb737 upstream. If new_mtu is very large then "new_mtu + ETH_HLEN + ETH_FCS_LEN" can wrap and the check on the next line can underflow. This is one of those bugs which can be triggered by the user if you have namespaces configured. Also since this is something the user can trigger then we don't want to have dev_err() message. This is a static checker fix and I'm not sure what the impact is. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Tested-by: Sibai Li Sibai.li@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26DMA-API: net: intel/igbvf: fix 32-bit DMA mask handlingRussell King
commit c21b8ebc2f1613fd0a9d5aa0d0d1083aee8ca306 upstream. The fallback to 32-bit DMA mask is rather odd: err = dma_set_mask(&pdev->dev, DMA_BIT_MASK(64)); if (!err) { err = dma_set_coherent_mask(&pdev->dev, DMA_BIT_MASK(64)); if (!err) pci_using_dac = 1; } else { err = dma_set_mask(&pdev->dev, DMA_BIT_MASK(32)); if (err) { err = dma_set_coherent_mask(&pdev->dev, DMA_BIT_MASK(32)); if (err) { dev_err(&pdev->dev, "No usable DMA " "configuration, aborting\n"); goto err_dma; } } } This means we only set the coherent DMA mask in the fallback path if the DMA mask set failed, which is silly. This fixes it to set the coherent DMA mask only if dma_set_mask() succeeded, and to error out if either fails. Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26igb: Fixed Wake On LAN supportAkeem G Abodunrin
commit 42ce4126d8bc2e128e1f207cf79bb0623fac498f upstream. This patch fixes Wake on LAN being reported as supported on some Ethernet ports, in contrary to Hardware capability. Signed-off-by: Akeem G Abodunrin <akeem.g.abodunrin@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-08-26igb: Don't let ethtool try to write to iNVM in i210/i211Fujinaka, Todd
commit a71fc313c4f569be5788caff07ef1fe346842c5b upstream. Don't let ethtool try to write to iNVM in i210/i211. This fixes an issue seen by Marek Vasut. Reported-by: Marek Vasut <marex@denx.de> Signed-off-by: Todd Fujinaka <todd.fujinaka@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
