path: root/drivers
2016-11-10HID: usbhid: add ATEN CS962 to list of quirky devicesOliver Neukum
commit cf0ea4da4c7df11f7a508b2f37518e0f117f3791 upstream. Like many similar devices it needs a quirk to work. Issuing the request gets the device into an irrecoverable state. Signed-off-by: Oliver Neukum <oneukum@suse.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ubi: fastmap: Fix add_vol() return value test in ubi_attach_fastmap()Boris Brezillon
commit 40b6e61ac72e99672e47cdb99c8d7d226004169b upstream. Commit e96a8a3bb671 ("UBI: Fastmap: Do not add vol if it already exists") introduced a bug by changing the possible error codes returned by add_vol(): - this function no longer returns NULL in case of allocation failure but return ERR_PTR(-ENOMEM) - when a duplicate entry in the volume RB tree is found it returns ERR_PTR(-EEXIST) instead of ERR_PTR(-EINVAL) Fix the tests done on add_vol() return val to match this new behavior. Fixes: e96a8a3bb671 ("UBI: Fastmap: Do not add vol if it already exists") Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Sheng Yong <shengyong1@huawei.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10tty: vt, fix bogus division in csi_JJiri Slaby
commit 42acfc6615f47e465731c263bee0c799edb098f2 upstream. In csi_J(3), the third parameter of scr_memsetw (vc_screenbuf_size) is divided by 2 inappropriatelly. But scr_memsetw expects size, not count, because it divides the size by 2 on its own before doing actual memset-by-words. So remove the bogus division. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Petr Písař <ppisar@redhat.com> Fixes: f8df13e0a9 (tty: Clean console safely) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10usb: dwc3: Fix size used in dma_free_coherent()Christophe JAILLET
commit 51fbc7c06c8900370c6da5fc4a4685add8fa4fb0 upstream. In commit 2abd9d5fa60f9 ("usb: dwc3: ep0: Add chained TRB support"), the size of the memory allocated with 'dma_alloc_coherent()' has been modified but the corresponding calls to 'dma_free_coherent()' have not been updated accordingly. This has been spotted with coccinelle, using the following script: //////////////////// @r@ expression x0, x1, y0, y1, z0, z1, t0, t1, ret; @@ * ret = dma_alloc_coherent(x0, y0, z0, t0); ... * dma_free_coherent(x1, y1, ret, t1); @script:python@ y0 << r.y0; y1 << r.y1; @@ if y1.find(y0) == -1: print "WARNING: sizes look different: '%s' vs '%s'" % (y0, y1) //////////////////// Fixes: 2abd9d5fa60f9 ("usb: dwc3: ep0: Add chained TRB support") Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10pwm: Unexport children before chip removalDavid Hsu
commit 0733424c9ba9f42242409d1ece780777272f7ea1 upstream. Exported pwm channels aren't removed before the pwmchip and are leaked. This results in invalid sysfs files. This fix removes all exported pwm channels before chip removal. Signed-off-by: David Hsu <davidhsu@google.com> Fixes: 76abbdde2d95 ("pwm: Add sysfs interface") Signed-off-by: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10UBI: fastmap: scrub PEB when bitflips are detected in a free PEB EC headerBoris Brezillon
commit ecbfa8eabae9cd73522d1d3d15869703c263d859 upstream. scan_pool() does not mark the PEB for scrubing when bitflips are detected in the EC header of a free PEB (VID header region left to 0xff). Make sure we scrub the PEB in this case. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Fixes: dbb7d2a88d2a ("UBI: Add fastmap core") Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10smc91x: avoid self-comparison warningArnd Bergmann
commit e3ebd894f084255fde19116955ba7054858ff5d6 upstream. The smc91x driver defines a macro that compares its argument to itself, apparently to get a true result while using its argument to avoid a warning about unused local variables. Unfortunately, this triggers a warning with gcc-6, as the comparison is obviously useless: drivers/net/ethernet/smsc/smc91x.c: In function 'smc_hardware_send_pkt': drivers/net/ethernet/smsc/smc91x.c:563:14: error: self-comparison always evaluates to true [-Werror=tautological-compare] if (!smc_special_trylock(&lp->lock, flags)) { This replaces the macro with another one that behaves similarly, with a cast to (void) to ensure the argument is used, and using a literal 'true' as its value. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10drm/exynos: fix error handling in exynos_drm_subdrv_openArnd Bergmann
commit 55c4b906aa2aec3fa66310ec03c6842e34a04b2a upstream. gcc-6 warns about a pointless loop in exynos_drm_subdrv_open: drivers/gpu/drm/exynos/exynos_drm_core.c: In function 'exynos_drm_subdrv_open': drivers/gpu/drm/exynos/exynos_drm_core.c:104:199: error: self-comparison always evaluates to false [-Werror=tautological-compare] list_for_each_entry_reverse(subdrv, &subdrv->list, list) { Here, the list_for_each_entry_reverse immediately terminates because the subdrv pointer is compared to itself as the loop end condition. If we were to take the current subdrv pointer as the start of the list (as we would do if list_for_each_entry_reverse() was not a macro), we would iterate backwards over the &exynos_drm_subdrv_list anchor, which would be even worse. Instead, we need to use list_for_each_entry_continue_reverse() to go back over each subdrv that was successfully opened until the first entry. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10drm/dp/mst: Check peer device type before attempting EDID readVille Syrjälä
commit 4da5caa6a6f82cda3193bca855235b87debf78bd upstream. Only certain types of pdts have the DDC bus registered, so check for that before we attempt the EDID read. Othwewise we risk playing around with an i2c adapter that doesn't actually exist. Cc: Carlos Santa <carlos.santa@intel.com> Cc: Kirill A. Shutemov <kirill@shutemov.name> Tested-by: Carlos Santa <carlos.santa@intel.com> Tested-by: Kirill A. Shutemov <kirill@shutemov.name> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=97666 Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/1477472755-15288-5-git-send-email-ville.syrjala@linux.intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10drm/radeon: drop register readback in cayman_cp_int_cntl_setupLucas Stach
commit 537b4b462caa8bfb9726d9695b8e56e2d5e6b41e upstream. The read is taking a considerable amount of time (about 50us on this machine). The register does not ever hold anything other than the ring ID that is updated in this exact function, so there is no need for the read modify write cycle. This chops off a big chunk of the time spent in hardirq disabled context, as this function is called multiple times in the interrupt handler. With this change applied radeon won't show up in the list of the worst IRQ latency offenders anymore, where it was a regular before. Reviewed-by: Christian König <christian.koenig@amd.com> Signed-off-by: Lucas Stach <dev@lynxeye.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10drm/radeon/si_dpm: workaround for SI kickersAlex Deucher
commit 7dc86ef5ac91642dfc3eb93ee0f0458e702a343e upstream. Consolidate existing quirks. Fixes stability issues on some kickers. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10drm/radeon/si_dpm: Limit clocks on HD86xx partTom St Denis
commit fb9a5b0c1c9893db2e0d18544fd49e19d784a87d upstream. Limit clocks on a specific HD86xx part to avoid crashes (while awaiting an appropriate PP fix). Signed-off-by: Tom St Denis <tom.stdenis@amd.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10Revert "drm/radeon: fix DP link training issue with second 4K monitor"Michel Dänzer
commit 9dc79965b21967caebde575f5f5d8bf1aa2c23ab upstream. This reverts commit 1a738347df2ee4977459a8776fe2c62196bdcb1b. It caused at least some Kaveri laptops to incorrectly report DisplayPort connectors as connected. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=97857 Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10mmc: dw_mmc-pltfm: fix the potential NULL pointer dereferenceJaehoon Chung
commit 45c7a4908a307a023e237a64a3eadcafc4836493 upstream. platform_get_resource can be returned the NULL pointer. Then regs->start should be referred to NULL Pointer. devm_ioremap_resource() checks whether res is NULL or not. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Shawn Lin <shawn.lin@rock-chips.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10scsi: arcmsr: Send SYNCHRONIZE_CACHE command to firmwareChing Huang
commit 2bf7dc8443e113844d078fd6541b7f4aa544f92f upstream. The arcmsr driver failed to pass SYNCHRONIZE CACHE to controller firmware. Depending on how drive caches are handled internally by controller firmware this could potentially lead to data integrity problems. Ensure that cache flushes are passed to the controller. [mkp: applied by hand and removed unused vars] Signed-off-by: Ching Huang <ching2048@areca.com.tw> Reported-by: Tomas Henzl <thenzl@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10scsi: scsi_debug: Fix memory leak if LBP enabled and module is unloadedEwan D. Milne
commit 4d2b496f19f3c2cfaca1e8fa0710688b5ff3811d upstream. map_storep was not being vfree()'d in the module_exit call. Signed-off-by: Ewan D. Milne <emilne@redhat.com> Reviewed-by: Laurence Oberman <loberman@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10scsi: megaraid_sas: Fix data integrity failure for JBOD (passthrough) devicesKashyap Desai
commit 1e793f6fc0db920400574211c48f9157a37e3945 upstream. Commit 02b01e010afe ("megaraid_sas: return sync cache call with success") modified the driver to successfully complete SYNCHRONIZE_CACHE commands without passing them to the controller. Disk drive caches are only explicitly managed by controller firmware when operating in RAID mode. So this commit effectively disabled writeback cache flushing for any drives used in JBOD mode, leading to data integrity failures. [mkp: clarified patch description] Fixes: 02b01e010afeeb49328d35650d70721d2ca3fd59 Signed-off-by: Kashyap Desai <kashyap.desai@broadcom.com> Signed-off-by: Sumit Saxena <sumit.saxena@broadcom.com> Reviewed-by: Tomas Henzl <thenzl@redhat.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Ewan D. Milne <emilne@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10firewire: net: fix fragmented datagram_size off-by-oneStefan Richter
commit e9300a4b7bbae83af1f7703938c94cf6dc6d308f upstream. RFC 2734 defines the datagram_size field in fragment encapsulation headers thus: datagram_size: The encoded size of the entire IP datagram. The value of datagram_size [...] SHALL be one less than the value of Total Length in the datagram's IP header (see STD 5, RFC 791). Accordingly, the eth1394 driver of Linux 2.6.36 and older set and got this field with a -/+1 offset: ether1394_tx() /* transmit */ ether1394_encapsulate_prep() hdr->ff.dg_size = dg_size - 1; ether1394_data_handler() /* receive */ if (hdr->common.lf == ETH1394_HDR_LF_FF) dg_size = hdr->ff.dg_size + 1; else dg_size = hdr->sf.dg_size + 1; Likewise, I observe OS X 10.4 and Windows XP Pro SP3 to transmit 1500 byte sized datagrams in fragments with datagram_size=1499 if link fragmentation is required. Only firewire-net sets and gets datagram_size without this offset. The result is lacking interoperability of firewire-net with OS X, Windows XP, and presumably Linux' eth1394. (I did not test with the latter.) For example, FTP data transfers to a Linux firewire-net box with max_rec smaller than the 1500 bytes MTU - from OS X fail entirely, - from Win XP start out with a bunch of fragmented datagrams which time out, then continue with unfragmented datagrams because Win XP temporarily reduces the MTU to 576 bytes. So let's fix firewire-net's datagram_size accessors. Note that firewire-net thereby loses interoperability with unpatched firewire-net, but only if link fragmentation is employed. (This happens with large broadcast datagrams, and with large datagrams on several FireWire CardBus cards with smaller max_rec than equivalent PCI cards, and it can be worked around by setting a small enough MTU.) Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10firewire: net: guard against rx buffer overflowsStefan Richter
commit 667121ace9dbafb368618dbabcf07901c962ddac upstream. The IP-over-1394 driver firewire-net lacked input validation when handling incoming fragmented datagrams. A maliciously formed fragment with a respectively large datagram_offset would cause a memcpy past the datagram buffer. So, drop any packets carrying a fragment with offset + length larger than datagram_size. In addition, ensure that - GASP header, unfragmented encapsulation header, or fragment encapsulation header actually exists before we access it, - the encapsulated datagram or fragment is of nonzero size. Reported-by: Eyal Itkin <eyal.itkin@gmail.com> Reviewed-by: Eyal Itkin <eyal.itkin@gmail.com> Fixes: CVE 2016-8633 Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10Input: i8042 - add XMG C504 to keyboard reset tablePatrick Scheuring
commit da25311c7ca8b0254a686fc0d597075b9aa3b683 upstream. The Schenker XMG C504 is a rebranded Gigabyte P35 v2 laptop. Therefore it also needs a keyboard reset to detect the Elantech touchpad. Otherwise the touchpad appears to be dead. With this patch the touchpad is detected: $ dmesg | grep -E "(i8042|Elantech|elantech)" [ 2.675399] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12 [ 2.680372] i8042: Attempting to reset device connected to KBD port [ 2.789037] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 2.791586] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 2.813840] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4 [ 3.811431] psmouse serio1: elantech: assuming hardware version 4 (with firmware version 0x361f0e) [ 3.825424] psmouse serio1: elantech: Synaptics capabilities query result 0x00, 0x15, 0x0f. [ 3.839424] psmouse serio1: elantech: Elan sample query result 03, 58, 74 [ 3.911349] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input6 Signed-off-by: Patrick Scheuring <patrick.scheuring.dev@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10dm mirror: fix read error on recovery after default leg failureHeinz Mauelshagen
commit dcb2ff56417362c31f6b430c3c531a84581e8721 upstream. If a default leg has failed, any read will cause a new operational default leg to be selected and the read is resubmitted. But until now the read will return failure even though it was successful due to resubmission. The reason for this is bio->bi_error was not being cleared before resubmitting the bio. Fix by clearing bio->bi_error before resubmission. Fixes: 4246a0b63bd8 ("block: add a bi_error field to struct bio") Signed-off-by: Heinz Mauelshagen <heinzm@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10virtio: console: Unlock vqs while freeing buffersMatt Redfearn
commit 34563769e438d2881f62cf4d9badc4e589ac0ec0 upstream. Commit c6017e793b93 ("virtio: console: add locks around buffer removal in port unplug path") added locking around the freeing of buffers in the vq. However, when free_buf() is called with can_sleep = true and rproc is enabled, it calls dma_free_coherent() directly, requiring interrupts to be enabled. Currently a WARNING is triggered due to the spin locking around free_buf, with a call stack like this: WARNING: CPU: 3 PID: 121 at ./include/linux/dma-mapping.h:433 free_buf+0x1a8/0x288 Call Trace: [<8040c538>] show_stack+0x74/0xc0 [<80757240>] dump_stack+0xd0/0x110 [<80430d98>] __warn+0xfc/0x130 [<80430ee0>] warn_slowpath_null+0x2c/0x3c [<807e7c6c>] free_buf+0x1a8/0x288 [<807ea590>] remove_port_data+0x50/0xac [<807ea6a0>] unplug_port+0xb4/0x1bc [<807ea858>] virtcons_remove+0xb0/0xfc [<807b6734>] virtio_dev_remove+0x58/0xc0 [<807f918c>] __device_release_driver+0xac/0x134 [<807f924c>] device_release_driver+0x38/0x50 [<807f7edc>] bus_remove_device+0xfc/0x130 [<807f4b74>] device_del+0x17c/0x21c [<807f4c38>] device_unregister+0x24/0x38 [<807b6b50>] unregister_virtio_device+0x28/0x44 Fix this by restructuring the loops to allow the locks to only be taken where it is necessary to protect the vqs, and release it while the buffer is being freed. Fixes: c6017e793b93 ("virtio: console: add locks around buffer removal in port unplug path") Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10virtio_ring: Make interrupt suppression spec compliantLadi Prosek
commit 0ea1e4a6d9b62cf29e210d2b4ba9fd43917522e3 upstream. According to the spec, if the VIRTIO_RING_F_EVENT_IDX feature bit is negotiated the driver MUST set flags to 0. Not dirtying the available ring in virtqueue_disable_cb also has a minor positive performance impact, improving L1 dcache load missed by ~0.5% in vring_bench. Writes to the used event field (vring_used_event) are still unconditional. Cc: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Ladi Prosek <lprosek@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10dm: free io_barrier after blk_cleanup_queue callTahsin Erdogan
commit d09960b0032174eb493c4c13be5b9c9ef36dc9a7 upstream. dm_old_request_fn() has paths that access md->io_barrier. The party destroying io_barrier should ensure that no future execution of dm_old_request_fn() is possible. Move io_barrier destruction to below blk_cleanup_queue() to ensure this and avoid a NULL pointer crash during request-based DM device shutdown. Signed-off-by: Tahsin Erdogan <tahsin@google.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10USB: serial: cp210x: fix tiocmget error handlingJohan Hovold
commit de24e0a108bc48062e1c7acaa97014bce32a919f upstream. The current tiocmget implementation would fail to report errors up the stack and instead leaked a few bits from the stack as a mask of modem-status flags. Fixes: 39a66b8d22a3 ("[PATCH] USB: CP2101 Add support for flow control") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10tty: limit terminal size to 4M charsDmitry Vyukov
commit 32b2921e6a7461fe63b71217067a6cf4bddb132f upstream. Size of kmalloc() in vc_do_resize() is controlled by user. Too large kmalloc() size triggers WARNING message on console. Put a reasonable upper bound on terminal size to prevent WARNINGs. Signed-off-by: Dmitry Vyukov <dvyukov@google.com> CC: David Rientjes <rientjes@google.com> Cc: One Thousand Gnomes <gnomes@lxorguk.ukuu.org.uk> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jiri Slaby <jslaby@suse.com> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: linux-kernel@vger.kernel.org Cc: syzkaller@googlegroups.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10xhci: add restart quirk for Intel Wildcatpoint PCHMathias Nyman
commit 4c39135aa412d2f1381e43802523da110ca7855c upstream. xHC in Wildcatpoint-LP PCH is similar to LynxPoint-LP and need the same quirks to prevent machines from spurious restart while shutting them down. Reported-by: Hasan Mahmood <hasan.mahm@gmail.com> Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10hv: do not lose pending heartbeat vmbus packetsLong Li
commit 407a3aee6ee2d2cb46d9ba3fc380bc29f35d020c upstream. The host keeps sending heartbeat packets independent of the guest responding to them. Even though we respond to the heartbeat messages at interrupt level, we can have situations where there maybe multiple heartbeat messages pending that have not been responded to. For instance this occurs when the VM is paused and the host continues to send the heartbeat messages. Address this issue by draining and responding to all the heartbeat messages that maybe pending. Signed-off-by: Long Li <longli@microsoft.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10vt: clear selection before resizingScot Doyle
commit 009e39ae44f4191188aeb6dfbf661b771dbbe515 upstream. When resizing a vt its selection may exceed the new size, resulting in an invalid memory access [1]. Clear the selection before resizing. [1] http://lkml.kernel.org/r/CACT4Y+acDTwy4umEvf5ROBGiRJNrxHN4Cn5szCXE5Jw-d1B=Xw@mail.gmail.com Reported-and-tested-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Scot Doyle <lkml14@scotdoyle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10GenWQE: Fix bad page access during abort of resource allocationGerald Schaefer
commit a7a7aeefbca2982586ba2c9fd7739b96416a6d1d upstream. When interrupting an application which was allocating DMAable memory, it was possible, that the DMA memory was deallocated twice, leading to the error symptoms below. Thanks to Gerald, who analyzed the problem and provided this patch. I agree with his analysis of the problem: ddcb_cmd_fixups() -> genwqe_alloc_sync_sgl() (fails in f/lpage, but sgl->sgl != NULL and f/lpage maybe also != NULL) -> ddcb_cmd_cleanup() -> genwqe_free_sync_sgl() (double free, because sgl->sgl != NULL and f/lpage maybe also != NULL) In this scenario we would have exactly the kind of double free that would explain the WARNING / Bad page state, and as expected it is caused by broken error handling (cleanup). Using the Ubuntu git source, tag Ubuntu-4.4.0-33.52, he was able to reproduce the "Bad page state" issue, and with the patch on top he could not reproduce it any more. ------------[ cut here ]------------ WARNING: at /build/linux-o03cxz/linux-4.4.0/arch/s390/include/asm/pci_dma.h:141 Modules linked in: qeth_l2 ghash_s390 prng aes_s390 des_s390 des_generic sha512_s390 sha256_s390 sha1_s390 sha_common genwqe_card qeth crc_itu_t qdio ccwgroup vmur dm_multipath dasd_eckd_mod dasd_mod CPU: 2 PID: 3293 Comm: genwqe_gunzip Not tainted 4.4.0-33-generic #52-Ubuntu task: 0000000032c7e270 ti: 00000000324e4000 task.ti: 00000000324e4000 Krnl PSW : 0404c00180000000 0000000000156346 (dma_update_cpu_trans+0x9e/0xa8) R:0 T:1 IO:0 EX:0 Key:0 M:1 W:0 P:0 AS:3 CC:0 PM:0 EA:3 Krnl GPRS: 00000000324e7bcd 0000000000c3c34a 0000000027628298 000000003215b400 0000000000000400 0000000000001fff 0000000000000400 0000000116853000 07000000324e7b1e 0000000000000001 0000000000000001 0000000000000001 0000000000001000 0000000116854000 0000000000156402 00000000324e7a38 Krnl Code: 000000000015633a: 95001000 cli 0(%r1),0 000000000015633e: a774ffc3 brc 7,1562c4 #0000000000156342: a7f40001 brc 15,156344 >0000000000156346: 92011000 mvi 0(%r1),1 000000000015634a: a7f4ffbd brc 15,1562c4 000000000015634e: 0707 bcr 0,%r7 0000000000156350: c00400000000 brcl 0,156350 0000000000156356: eb7ff0500024 stmg %r7,%r15,80(%r15) Call Trace: ([<00000000001563e0>] dma_update_trans+0x90/0x228) [<00000000001565dc>] s390_dma_unmap_pages+0x64/0x160 [<00000000001567c2>] s390_dma_free+0x62/0x98 [<000003ff801310ce>] __genwqe_free_consistent+0x56/0x70 [genwqe_card] [<000003ff801316d0>] genwqe_free_sync_sgl+0xf8/0x160 [genwqe_card] [<000003ff8012bd6e>] ddcb_cmd_cleanup+0x86/0xa8 [genwqe_card] [<000003ff8012c1c0>] do_execute_ddcb+0x110/0x348 [genwqe_card] [<000003ff8012c914>] genwqe_ioctl+0x51c/0xc20 [genwqe_card] [<000000000032513a>] do_vfs_ioctl+0x3b2/0x518 [<0000000000325344>] SyS_ioctl+0xa4/0xb8 [<00000000007b86c6>] system_call+0xd6/0x264 [<000003ff9e8e520a>] 0x3ff9e8e520a Last Breaking-Event-Address: [<0000000000156342>] dma_update_cpu_trans+0x9a/0xa8 ---[ end trace 35996336235145c8 ]--- BUG: Bad page state in process jbd2/dasdb1-8 pfn:3215b page:000003d100c856c0 count:-1 mapcount:0 mapping: (null) index:0x0 flags: 0x3fffc0000000000() page dumped because: nonzero _count Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Frank Haverkamp <haver@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10usb: increase ohci watchdog delay to 275 msecBryan Paluch
commit ed6d6f8f42d7302f6f9b6245f34927ec20d26c12 upstream. Increase ohci watchout delay to 275 ms. Previous delay was 250 ms with 20 ms of slack, after removing slack time some ohci controllers don't respond in time. Logs from systems with controllers that have the issue would show "HcDoneHead not written back; disabled" Signed-off-by: Bryan Paluch <bryanpaluch@gmail.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10xhci: use default USB_RESUME_TIMEOUT when resuming ports.Mathias Nyman
commit 7d3b016a6f5a0fa610dfd02b05654c08fa4ae514 upstream. USB2 host inititated resume, and system suspend bus resume need to use the same USB_RESUME_TIMEOUT as elsewhere. This resolves a device disconnect issue at system resume seen on Intel Braswell and Apollolake, but is in no way limited to those platforms. Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10USB: serial: ftdi_sio: add support for Infineon TriBoard TC2X7Stefan Tauner
commit ca006f785fbfd7a5c901900bd3fe2b26e946a1ee upstream. This adds support to ftdi_sio for the Infineon TriBoard TC2X7 engineering board for first-generation Aurix SoCs with Tricore CPUs. Mere addition of the device IDs does the job. Signed-off-by: Stefan Tauner <stefan.tauner@technikum-wien.at> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10USB: serial: fix potential NULL-dereference at probeJohan Hovold
commit 126d26f66d9890a69158812a6caa248c05359daa upstream. Make sure we have at least one port before attempting to register a console. Currently, at least one driver binds to a "dummy" interface and requests zero ports for it. Should such an interface also lack endpoints, we get a NULL-deref during probe. Fixes: e5b1e2062e05 ("USB: serial: make minor allocation dynamic") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10usb: gadget: function: u_ether: don't starve tx request queueFelipe Balbi
commit 6c83f77278f17a7679001027e9231291c20f0d8a upstream. If we don't guarantee that we will always get an interrupt at least when we're queueing our very last request, we could fall into situation where we queue every request with 'no_interrupt' set. This will cause the link to get stuck. The behavior above has been triggered with g_ether and dwc3. Reported-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10mei: txe: don't clean an unprocessed interrupt cause.Alexander Usyskin
commit 43605e293eb13c07acb546c14f407a271837af17 upstream. SEC registers are not accessible when the TXE device is in low power state, hence the SEC interrupt cannot be processed if device is not awake. In some rare cases entrance to low power state (aliveness off) and input ready bits can be signaled at the same time, resulting in communication stall as input ready won't be signaled again after waking up. To resolve this IPC_HHIER_SEC bit in HHISR_REG should not be cleaned if the interrupt is not processed. Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ANDROID: binder: Clear binder and cookie when setting handle in flat binder ↵Arve Hjønnevåg
struct commit 4afb604e2d14d429ac9e1fd84b952602853b2df5 upstream. Prevents leaking pointers between processes Signed-off-by: Arve Hjønnevåg <arve@android.com> Signed-off-by: Martijn Coenen <maco@android.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ANDROID: binder: Add strong ref checksArve Hjønnevåg
commit 0a3ffab93fe52530602fe47cd74802cffdb19c05 upstream. Prevent using a binder_ref with only weak references where a strong reference is required. Signed-off-by: Arve Hjønnevåg <arve@android.com> Signed-off-by: Martijn Coenen <maco@android.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10drm/dp/mst: Clear port->pdt when tearing down the i2c adapterVille Syrjälä
commit 36e3fa6a38e135e9478a2f75dec9bf6ff1e6480e upstream. The i2c adapter is only relevant for some peer device types, so let's clear the pdt if it's still the same as the old_pdt when we tear down the i2c adapter. I don't really like this design pattern of updating port->whatever before doing the accompanying changes and passing around old_whatever to figure stuff out. Would make much more sense to me to the pass the new value around and only update the port->whatever when things are consistent. But let's try to work with what we have right now. Quoting a follow-up from Ville: "And naturally I forgot to amend the commit message w.r.t. this guy [the change in drm_dp_destroy_port]. We don't really need to do this here, but I figured I'd try to be a bit more consistent by having it, just to avoid accidental mistakes if/when someone changes this stuff again later." v2: Clear port->pdt in the caller, if needed (Daniel) Cc: Daniel Vetter <daniel@ffwll.ch> Cc: Carlos Santa <carlos.santa@intel.com> Cc: Kirill A. Shutemov <kirill@shutemov.name> Tested-by: Carlos Santa <carlos.santa@intel.com> Tested-by: Kirill A. Shutemov <kirill@shutemov.name> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=97666 Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/1477488633-16544-1-git-send-email-ville.syrjala@linux.intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10i2c: core: fix NULL pointer dereference under race conditionVladimir Zapolskiy
commit 147b36d5b70c083cc76770c47d60b347e8eaf231 upstream. Race condition between registering an I2C device driver and deregistering an I2C adapter device which is assumed to manage that I2C device may lead to a NULL pointer dereference due to the uninitialized list head of driver clients. The root cause of the issue is that the I2C bus may know about the registered device driver and thus it is matched by bus_for_each_drv(), but the list of clients is not initialized and commonly it is NULL, because I2C device drivers define struct i2c_driver as static and clients field is expected to be initialized by I2C core: i2c_register_driver() i2c_del_adapter() driver_register() ... bus_add_driver() ... ... bus_for_each_drv(..., __process_removed_adapter) ... i2c_do_del_adapter() ... list_for_each_entry_safe(..., &driver->clients, ...) INIT_LIST_HEAD(&driver->clients); To solve the problem it is sufficient to do clients list head initialization before calling driver_register(). The problem was found while using an I2C device driver with a sluggish registration routine on a bus provided by a physically detachable I2C master controller, but practically the oops may be reproduced under the race between arbitraty I2C device driver registration and managing I2C bus device removal e.g. by unbinding the latter over sysfs: % echo 21a4000.i2c > /sys/bus/platform/drivers/imx-i2c/unbind Unable to handle kernel NULL pointer dereference at virtual address 00000000 Internal error: Oops: 17 [#1] SMP ARM CPU: 2 PID: 533 Comm: sh Not tainted 4.9.0-rc3+ #61 Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree) task: e5ada400 task.stack: e4936000 PC is at i2c_do_del_adapter+0x20/0xcc LR is at __process_removed_adapter+0x14/0x1c Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none Control: 10c5387d Table: 35bd004a DAC: 00000051 Process sh (pid: 533, stack limit = 0xe4936210) Stack: (0xe4937d28 to 0xe4938000) Backtrace: [<c0667be0>] (i2c_do_del_adapter) from [<c0667cc0>] (__process_removed_adapter+0x14/0x1c) [<c0667cac>] (__process_removed_adapter) from [<c0516998>] (bus_for_each_drv+0x6c/0xa0) [<c051692c>] (bus_for_each_drv) from [<c06685ec>] (i2c_del_adapter+0xbc/0x284) [<c0668530>] (i2c_del_adapter) from [<bf0110ec>] (i2c_imx_remove+0x44/0x164 [i2c_imx]) [<bf0110a8>] (i2c_imx_remove [i2c_imx]) from [<c051a838>] (platform_drv_remove+0x2c/0x44) [<c051a80c>] (platform_drv_remove) from [<c05183d8>] (__device_release_driver+0x90/0x12c) [<c0518348>] (__device_release_driver) from [<c051849c>] (device_release_driver+0x28/0x34) [<c0518474>] (device_release_driver) from [<c0517150>] (unbind_store+0x80/0x104) [<c05170d0>] (unbind_store) from [<c0516520>] (drv_attr_store+0x28/0x34) [<c05164f8>] (drv_attr_store) from [<c0298acc>] (sysfs_kf_write+0x50/0x54) [<c0298a7c>] (sysfs_kf_write) from [<c029801c>] (kernfs_fop_write+0x100/0x214) [<c0297f1c>] (kernfs_fop_write) from [<c0220130>] (__vfs_write+0x34/0x120) [<c02200fc>] (__vfs_write) from [<c0221088>] (vfs_write+0xa8/0x170) [<c0220fe0>] (vfs_write) from [<c0221e74>] (SyS_write+0x4c/0xa8) [<c0221e28>] (SyS_write) from [<c0108a20>] (ret_fast_syscall+0x0/0x1c) Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10i2c: xgene: Avoid dma_buffer overrunHoan Tran
commit 603616017c35f4d0fbdbcace72adf9bf949c4a65 upstream. SMBus block command uses the first byte of buffer for the data length. The dma_buffer should be increased by 1 to avoid the overrun issue. Reported-by: Phil Endecott <phil_gjouf_endecott@chezphil.org> Signed-off-by: Hoan Tran <hotran@apm.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31mpt3sas: Don't spam logs if logging level is 0Johannes Thumshirn
commit 0d667f72b2a20bbac72bec0ab11467fc70bb0f1f upstream. In _scsih_io_done() we test if the ioc->logging_level does _not_ have the MPT_DEBUG_REPLY bit set and if it hasn't we print the debug messages. This unfortunately is the wrong way around. Note, the actual bug is older than af0094115 but this commit removed the CONFIG_SCSI_MPT3SAS_LOGGING Kconfig option which hid the bug. Fixes: af0094115 'mpt2sas, mpt3sas: Remove SCSI_MPTXSAS_LOGGING entry from Kconfig' Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Acked-by: Chaitra P B <chaitra.basappa@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31clk: divider: Fix clk_divider_round_rate() to use clk_readl()Geert Uytterhoeven
commit 2cf9a57811bddb6fa6b0f8d7376da164d5534813 upstream. clk-divider uses clk_readl()/clk_writel() everywhere, except in clk_divider_round_rate(), where plain readl() is used. Change this to clk_readl(), as it makes a difference on powerpc. Fixes: e6d5e7d90be92cee ("clk-divider: Fix READ_ONLY when divider > 1") Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31clk: qoriq: fix a register offset errorTang Yuantian
commit 8964193f6bfda5c4cf14eedb7e94892c1f1c34f0 upstream. The offset of Core Cluster clock control/status register on cluster group V3 version is different from others, and should be plus 0x70000. Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com> Reviewed-by: Scott Wood <oss@buserror.net> Fixes: 9e19ca2f627e ("clk: qoriq: Add ls2080a support.") Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31s390/con3270: fix insufficient space paddingSascha Silbe
commit 6cd997db911f28f2510b771691270c52b63ed2e6 upstream. con3270 contains an optimisation that reduces the amount of data to be transmitted to the 3270 terminal by putting a Repeat to Address (RA) order into the data stream. The RA order itself takes up space, so con3270 only uses it if there's enough space left in the line buffer. Otherwise it just pads out the line manually. For lines that were _just_ short enough that the RA order still fit in the line buffer, the line was instead padded with an insufficient amount of spaces. This was caused by examining the size of the allocated line buffer rather than the length of the string to be displayed. For con3270_cline_end(), we just compare against the line length. For con3270_update_string() however that isn't available anymore, so we check whether the Repeat to Address order is present. Fixes: f51320a5 ("[PATCH] s390: new 3270 driver.") (tglx/history.git) Tested-by: Jing Liu <liujbjl@linux.vnet.ibm.com> Tested-by: Yang Chen <bjcyang@linux.vnet.ibm.com> Signed-off-by: Sascha Silbe <silbe@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31s390/con3270: fix use of uninitialised dataSascha Silbe
commit c14f2aac7aa147861793eed9f41f91dd530f0be1 upstream. con3270 contains an optimisation that reduces the amount of data to be transmitted to the 3270 terminal by putting a Repeat to Address (RA) order into the data stream. The RA order itself takes up space, so con3270 only uses it if there's enough space left in the line buffer. Otherwise it just pads out the line manually. For lines too long to include the RA order, one byte was left uninitialised. This was caused by an off-by-one bug in the loop that pads out the line. Since the buffer is allocated from a common pool, the single byte left uninitialised contained some previous buffer content. Usually this was just a space or some character (which can result in clutter but is otherwise harmless). Sometimes, however, it was a Repeat to Address order, messing up the entire screen layout and causing the display to send the entire buffer content on every keystroke. Fixes: f51320a5 ("[PATCH] s390: new 3270 driver.") (tglx/history.git) Reported-by: Liu Jing <liujbjl@linux.vnet.ibm.com> Tested-by: Jing Liu <liujbjl@linux.vnet.ibm.com> Tested-by: Yang Chen <bjcyang@linux.vnet.ibm.com> Signed-off-by: Sascha Silbe <silbe@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31s390/cio: fix accidental interrupt enabling during resumeSebastian Ott
commit d53c51f26145657aa7c55fa396f93677e613548d upstream. Since commit 9f3d6d7 chsc_get_channel_measurement_chars is called with interrupts disabled during resume from hibernate. Since this function used spin_unlock_irq, interrupts have been enabled accidentally. Fix this by using the irqsave variant. Since we can't guarantee the IRQ-enablement state for all (future/ external) callers, change the locking in related functions to prevent similar bugs in the future. Fixes: 9f3d6d7 ("s390/cio: update measurement characteristics") Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31dmaengine: ipu: remove bogus NO_IRQ referenceArnd Bergmann
commit 86c7e6836479c4045a9a81ed5ea76c51d719f9c1 upstream. A workaround for a warning introduced a use of the NO_IRQ macro that should have been gone for a long time. It is clear from the code that the value cannot actually be used, but apparently there was a configuration at some point that caused a warning, so instead of just reverting that patch, this rearranges the code in a way that the warning cannot reappear. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: 6ef41cf6f721 ("dmaengine :ipu: change ipu_irq_handler() to remove compile warning") Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31power: bq24257: Fix use of uninitialized pointer bq->chargerGeorges Savoundararadj
commit 0610735928ee47870e083d5901caa371089216f1 upstream. bq->charger is initialized in bq24257_power_supply_init. Therefore, bq24257_power_supply_init should be called before the registration of the IRQ handler bq24257_irq_handler_thread that calls power_supply_changed(bq->charger). Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Cc: Aurelien Chanot <chanot.a@gmail.com> Cc: Andreas Dannenberg <dannenberg@ti.com> Cc: Sebastian Reichel <sre@kernel.org> Cc: David Woodhouse <dwmw2@infradead.org> Fixes: 2219a935963e ("power_supply: Add TI BQ24257 charger driver") Signed-off-by: Sebastian Reichel <sre@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31staging: r8188eu: Fix scheduling while atomic splatLarry Finger
commit 1335a9516d3d52f157ad87456efdd8dc9ae1747b upstream. Commit fadbe0cd5292851608e2e01b91d9295fa287b9fe ("staging: rtl8188eu: Remove rtw_zmalloc(), wrapper for kzalloc()") changed all allocation calls to be GFP_KERNEL even though the original wrapper was testing to determine if the caller was in atomic mode. Most of the mistakes were corrected with commit 33dc85c3c667209c930b2dac5ccbc2a365e06b7a ("staging: r8188eu: Fix scheduling while atomic error introduced in commit fadbe0cd"); however, two kzalloc calls were missed as the call only happens when the driver is shutting down. Fixes: fadbe0cd5292851608e2e01b91d9295fa287b9fe ("staging: rtl8188eu: Remove rtw_zmalloc(), wrapper for kzalloc()") Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: navin patidar <navin.patidar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
