commit 3587c856675c45809010c2cee5b21096f6e8e938 upstream.
I've found that by just turning the chip on and off via the
POWER_DOWN register, I end up getting i2c_transfer errors on
HiKey.
Investigating further, it turns out that some of the register
state in hardware is getting lost, as the device registers are
reset when the chip is powered down.
Thus this patch simply re-writes the i2c address to the
ADV7511_REG_EDID_I2C_ADDR register to ensure its properly set
before we try to read the EDID data.
Cc: David Airlie <airlied@linux.ie>
Cc: Archit Taneja <architt@codeaurora.org>
Cc: Wolfram Sang <wsa+renesas@sang-engineering.com>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: dri-devel@lists.freedesktop.org
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Tested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Signed-off-by: Archit Taneja <architt@codeaurora.org>
Link: http://patchwork.freedesktop.org/patch/msgid/1484614372-15342-7-git-send-email-john.stultz@linaro.org
Signed-off-by: Thong Ho <thong.ho.px@rvc.renesas.com>
Signed-off-by: Nhan Nguyen <nhan.nguyen.yb@renesas.com>
commit 6d5104c5a6b56385426e15047050584794bb6254 upstream.
In chasing down a previous issue with EDID probing from calling
drm_helper_hpd_irq_event() from irq context, Laurent noticed
that the DRM documentation suggests that
drm_kms_helper_hotplug_event() should be used instead.
Thus this patch replaces drm_helper_hpd_irq_event() with
drm_kms_helper_hotplug_event(), which requires we update the
connector.status entry and only call _hotplug_event() when the
status changes.
Link: http://patchwork.freedesktop.org/patch/msgid/1484614372-15342-3-git-send-email-john.stultz@linaro.org
context
commit 518cb7057a59b9441336d2e88a396d52b6ab0cce upstream.
I was recently seeing issues with EDID probing, where
the logic to wait for the EDID read bit to be set by the
IRQ wasn't happening and the code would time out and fail.
Digging deeper, I found this was due to the fact that
IRQs were disabled as we were running in IRQ context from
the HPD signal.
Thus this patch changes the logic to handle the HPD signal
via a work_struct so we can be out of irq context.
With this patch, the EDID probing on hotplug does not time
out.
Link: http://patchwork.freedesktop.org/patch/msgid/1484614372-15342-2-git-send-email-john.stultz@linaro.org
commit f0bfcc22d9822947b0ad3095e8363eab5261864c upstream.
When the adv7511 i2c client doesn't have an interrupt line, we observe a
deadlock on caused by trying to lock drm device's mode_config.mutex twice
in the same context.
Here is the sequence that causes it:
ioctl DRM_IOCTL_MODE_GETCONNECTOR from userspace
drm_mode_getconnector (acquires mode_config mutex)
connector->fill_modes()
drm_helper_probe_single_connector_modes
connector_funcs->get_modes
adv7511_encoder_get_modes
adv7511_get_edid_block
adv7511_irq_process
drm_helper_hpd_irq_event (acquires mode_config mutex again)
In adv7511_irq_process, don't call drm_helper_hpd_irq_event when not
called from the interrupt handler. It doesn't serve any purpose there
anyway.
commit d0be8584b01160eb6f49e77f8e9c1da286bb4ffb upstream.
The interrupts for EDID_READY or DDC_ERROR were never enabled in this
driver, so reading EDID always timed out when chip was powered down and
interrupts were used. Fix this and also remove clearing the interrupt
flags, they are cleared in POWER_DOWN mode anyhow (unlike the interrupt
enable flags) according to docs and my tests.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Tested-by: Archit Taneja <architt@codeaurora.org>
commit 8d26f491116feaa0b16de370b6a7ba40a40fa0b4 upstream.
Commit 1bc0eb044615 ("scsi: sg: protect accesses to 'reserved' page
array") adds needed concurrency protection for the "reserve" buffer.
Some checks that are initially made outside the lock are replicated once
the lock is taken to ensure the checks and resulting decisions are made
using consistent state.
The check that a request with flag SG_FLAG_MMAP_IO set fits in the
reserve buffer also needs to be performed again under the lock to ensure
the reserve buffer length compared against matches the value in effect
when the request is linked to the reserve buffer. An -ENOMEM should be
returned in this case, instead of switching over to an indirect buffer
as for non-MMAP_IO requests.
Signed-off-by: Todd Poynor <toddpoynor@google.com>
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
commit 6a8dadcca81fceff9976e8828cceb072873b7bd5 upstream.
Take f_mutex around mmap() processing to protect against races with the
SG_SET_RESERVED_SIZE ioctl. Ensure the reserve buffer length remains
consistent during the mapping operation, and set the "mmap called" flag
to prevent further changes to the reserved buffer size as an atomic
operation with the mapping.
[mkp: fixed whitespace]
commit 591b6bb605785c12a21e8b07a08a277065b655a5 upstream.
Several legacy devices such as Geode-based Cisco ASA appliances
and DB800 development board do possess CS5536 IDE controller
with different PCI id than existing one. Using pata_generic is
not always feasible as at least DB800 requires MSR quirk from
pata_cs5536 to be used with vendor firmware.
Signed-off-by: Andrey Korolyov <andrey@xdel.ru>
commit bc60c90f472b6e762ea96ef384072145adc8d4af upstream.
It appears that MSI does not work on either G5 PPC nor on a E5500-based
platform, where other hardware is reported to work fine with MSI.
Both tests were conducted with NV4x hardware, so perhaps other (or even
this) hardware can be made to work. It's still possible to force-enable
with config=NvMSI=1 on load.
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit 4b5dde2d6234ff5bc68e97e6901d1f2a0a7f3749 upstream.
mwifiex records information about various channels as it receives scan
information. It does this by appending to a buffer that was sized
to the max number of supported channels on any band, but there are
numerous problems:
(a) scans can return info from more than one band (e.g., both 2.4 and 5
GHz), so the determined "max" is not large enough
(b) some firmware appears to return multiple results for a given
channel, so the max *really* isn't large enough
(c) there is no bounds checking when stashing these stats, so problems
(a) and (b) can easily lead to buffer overflows
Let's patch this by setting a slightly-more-correct max (that accounts
for a combination of both 2.4G and 5G bands) and adding a bounds check
when writing to our statistics buffer.
Due to problem (b), we still might not properly report all known survey
information (e.g., with "iw <dev> survey dump"), since duplicate results
(or otherwise "larger than expected" results) will cause some
truncation. But that's a problem for a future bugfix.
(And because of this known deficiency, only log the excess at the WARN
level, since that isn't visible by default in this driver and would
otherwise be a bit too noisy.)
Fixes: bf35443314ac ("mwifiex: channel statistics support for mwifiex")
Cc: Avinash Patil <patila@marvell.com>
Cc: Xinming Hu <huxm@marvell.com>
Signed-off-by: Brian Norris <briannorris@chromium.org>
Reviewed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Reviewed-by: Ganapathi Bhat <gbhat@marvell.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit a81d72d2002d6a932bd83022cbf8c442b1b97512 upstream.
T: Bus=02 Lev=01 Prnt=01 Port=03 Cnt=03 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 2.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=13d3 ProdID=3494 Rev= 2.00
S: Manufacturer=Realtek
S: Product=Bluetooth Radio
S: SerialNumber=00e04c000001
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
Signed-off-by: Dmitry Tunin <hanipouspilot@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit fc81bab5eeb103711925d7510157cf5cd2b153f4 upstream.
_rtl_pci_find_adapter fail path will jump to label fail3 for
unsupported adapter types.
However, on course for fail3 there will be call rtl_deinit_core
before rtl_init_core.
For the inclusion of checking pci_iounmap this fail can be moved to
fail2.
Fixes
[ 4.492963] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 4.493067] IP: rtl_deinit_core+0x31/0x90 [rtlwifi]
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
commit 293b915fd9bebf33cdc906516fb28d54649a25ac upstream.
Trackpoint buttons detection fails on ThinkPad 570 and 470 series,
this makes the middle button of the trackpoint to not being recogized.
As I don't believe there is any trackpoint with less than 3 buttons this
patch just assumes three buttons when the extended button information
read fails.
Signed-off-by: Oscar Campos <oscar.campos@member.fsf.org>
Acked-by: Peter Hutterer <peter.hutterer@who-t.net>
Signed-off-by: Aaron Ma <aaron.ma@canonical.com>
commit f35a7f91f66af528b3ee1921de16bea31d347ab0 upstream.
The rx ring buffers are added to a hash table if
firmware support full rx reorder. If the full rx
reorder support flag is not set before allocating
the rx ring buffers, none of the buffers are added
to the hash table.
There is a race condition between rx ring refill and
rx buffer replenish from napi poll. The interrupts are
enabled in hif start, before the rx ring is refilled during init.
We replenish buffers from napi poll due to the interrupts which
get enabled after hif start. Hence before the entire rx ring is
refilled during the init, the napi poll replenishes a few buffers
in steps of 100 buffers per attempt. During this rx ring replenish
from napi poll, the rx reorder flag has not been set due to which
the replenished buffers are not added to the hash table
Set the rx full reorder support flag before we allocate
the rx ring buffer to avoid the memory leak.
Signed-off-by: Rakesh Pillai <pillair@qti.qualcomm.com>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
Cc: Christian Lamparter <chunkeey@googlemail.com>
commit efb3669e14fe17d0ec4ecf57d0365039fe726f59 upstream.
This adds Intel(R) Trace Hub PCI ID for Cannon Lake PCH-LP.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
commit 84331e1390b6378a5129a3678c87a42c6f697d29 upstream.
This adds Intel(R) Trace Hub PCI ID for Cannon Lake PCH-H.
commit 0f9b011d3321ca1079c7a46c18cb1956fbdb7bcb upstream.
The .release function of driver_ktype is 'driver_release()'.
This function frees the container_of this kobject.
So, this memory must not be freed explicitly in the error handling path of
'bus_add_driver()'. Otherwise a double free will occur.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
commit 34ff1bf4920471cff66775dc39537b15c5f0feff upstream.
The mask of sns_key_info1 suggests the upper nybble is being extracted
however the following shift of 8 bits is too large and always results in
0. Fix this by shifting only by 4 bits to correctly get the upper nybble.
Detected by CoverityScan, CID#142891 ("Operands don't affect result")
Fixes: fa590c222fba ("staging: rts5208: add support for rts5208 and rts5288")
commit ed62ca2f4f51c17841ea39d98c0c409cb53a3e10 upstream.
While running reboot tests w/ a specific set of USB devices (and
slub_debug enabled), I found that once every few hours my device would
be crashed with a stack that looked like this:
[ 14.012445] BUG: spinlock bad magic on CPU#0, modprobe/2091
[ 14.012460] lock: 0xffffffc0cb055978, .magic: ffffffc0, .owner: cryption contexts: %lu/%lu
[ 14.012460] /1025536097, .owner_cpu: 0
[ 14.012466] CPU: 0 PID: 2091 Comm: modprobe Not tainted 4.4.79 #352
[ 14.012468] Hardware name: Google Kevin (DT)
[ 14.012471] Call trace:
[ 14.012483] [<....>] dump_backtrace+0x0/0x160
[ 14.012487] [<....>] show_stack+0x20/0x28
[ 14.012494] [<....>] dump_stack+0xb4/0xf0
[ 14.012500] [<....>] spin_dump+0x8c/0x98
[ 14.012504] [<....>] spin_bug+0x30/0x3c
[ 14.012508] [<....>] do_raw_spin_lock+0x40/0x164
[ 14.012515] [<....>] _raw_spin_lock_irqsave+0x64/0x74
[ 14.012521] [<....>] __wake_up+0x2c/0x60
[ 14.012528] [<....>] async_completed+0x2d0/0x300
[ 14.012534] [<....>] __usb_hcd_giveback_urb+0xc4/0x138
[ 14.012538] [<....>] usb_hcd_giveback_urb+0x54/0xf0
[ 14.012544] [<....>] xhci_irq+0x1314/0x1348
[ 14.012548] [<....>] usb_hcd_irq+0x40/0x50
[ 14.012553] [<....>] handle_irq_event_percpu+0x1b4/0x3f0
[ 14.012556] [<....>] handle_irq_event+0x4c/0x7c
[ 14.012561] [<....>] handle_fasteoi_irq+0x158/0x1c8
[ 14.012564] [<....>] generic_handle_irq+0x30/0x44
[ 14.012568] [<....>] __handle_domain_irq+0x90/0xbc
[ 14.012572] [<....>] gic_handle_irq+0xcc/0x18c
Investigation using kgdb() found that the wait queue that was passed
into wake_up() had been freed (it was filled with slub_debug poison).
I analyzed and instrumented the code and reproduced. My current
belief is that this is happening:
1. async_completed() is called (from IRQ). Moves "as" onto the
completed list.
2. On another CPU, proc_reapurbnonblock_compat() calls
async_getcompleted(). Blocks on spinlock.
3. async_completed() releases the lock; keeps running; gets blocked
midway through wake_up().
4. proc_reapurbnonblock_compat() => async_getcompleted() gets the
lock; removes "as" from completed list and frees it.
5. usbdev_release() is called. Frees "ps".
6. async_completed() finally continues running wake_up(). ...but
wake_up() has a pointer to the freed "ps".
The instrumentation that led me to believe this was based on adding
some trace_printk() calls in a select few functions and then using
kdb's "ftdump" at crash time. The trace follows (NOTE: in the trace
below I cheated a little bit and added a udelay(1000) in
async_completed() after releasing the spinlock because I wanted it to
trigger quicker):
<...>-2104 0d.h2 13759034us!: async_completed at start: as=ffffffc0cc638200
mtpd-2055 3.... 13759356us : async_getcompleted before spin_lock_irqsave
mtpd-2055 3d..1 13759362us : async_getcompleted after list_del_init: as=ffffffc0cc638200
mtpd-2055 3.... 13759371us+: proc_reapurbnonblock_compat: free_async(ffffffc0cc638200)
mtpd-2055 3.... 13759422us+: async_getcompleted before spin_lock_irqsave
mtpd-2055 3.... 13759479us : usbdev_release at start: ps=ffffffc0cc042080
mtpd-2055 3.... 13759487us : async_getcompleted before spin_lock_irqsave
mtpd-2055 3.... 13759497us!: usbdev_release after kfree(ps): ps=ffffffc0cc042080
<...>-2104 0d.h2 13760294us : async_completed before wake_up(): as=ffffffc0cc638200
To fix this problem we can just move the wake_up() under the ps->lock.
There should be no issues there that I'm aware of.
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit e6b422b88b46353cf596e0db6dc0e39d50d90d6e upstream.
The following commit cause a regression on ATI chipsets.
'commit e788787ef4f9 ("usb:xhci:Add quirk for Certain
failing HP keyboard on reset after resume")'
This causes pinfo->smbus_dev to be wrongly set to NULL on
systems with the ATI chipset that this function checks for first.
Added conditional check for AMD chipsets to avoid the overwriting
pinfo->smbus_dev.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Fixes: e788787ef4f9 ("usb:xhci:Add quirk for Certain
cc: Nehal Shah <Nehal-bakulchandra.Shah@amd.com>
Signed-off-by: Sandeep Singh <Sandeep.Singh@amd.com>
Signed-off-by: Shyam Sundar S K <Shyam-sundar.S-k@amd.com>
commit a1279ef74eeeb5f627f091c71d80dd7ac766c99d upstream.
Commit e0429362ab15
("usb: Add device quirk for Logitech HD Pro Webcams C920 and C930e")
introduced quirk to workaround an issue with some Logitech webcams.
Apparently model C920-C has the same issue so applying
the same quirk as well.
See aforementioned commit message for detailed explanation of the problem.
Signed-off-by: Dmitry Fleytman <dmitry@daynix.com>
commit 169e86546f5712179709de23cd64bbb15f199fab upstream.
This commit adds support (an ID, really) for D-Link DWM-157 hardware
version C1 USB modem to option driver.
According to manufacturer-provided Windows INF file the device has four
serial ports:
"D-Link HSPA+DataCard Diagnostics Interface" (interface 2; modem port),
"D-Link HSPA+DataCard NMEA Device" (interface 3),
"D-Link HSPA+DataCard Speech Port" (interface 4),
"D-Link HSPA+DataCard Debug Port" (interface 5).
usb-devices output:
T: Bus=05 Lev=01 Prnt=01 Port=04 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=2001 ProdID=7d0e Rev=03.00
S: Manufacturer=D-Link,Inc
S: Product=D-Link DWM-157
C: #Ifs= 7 Cfg#= 1 Atr=a0 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=0e Prot=00 Driver=cdc_mbim
I: If#= 1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim
I: If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=01 Driver=option
I: If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 6 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit de3af5bf259d7a0bfaac70441c8568ab5998d80c upstream.
Corsair Strafe RGB keyboard has trouble to initialize:
[ 1.679455] usb 3-6: new full-speed USB device number 4 using xhci_hcd
[ 6.871136] usb 3-6: unable to read config index 0 descriptor/all
[ 6.871138] usb 3-6: can't read configurations, error -110
[ 6.991019] usb 3-6: new full-speed USB device number 5 using xhci_hcd
[ 12.246642] usb 3-6: unable to read config index 0 descriptor/all
[ 12.246644] usb 3-6: can't read configurations, error -110
[ 12.366555] usb 3-6: new full-speed USB device number 6 using xhci_hcd
[ 17.622145] usb 3-6: unable to read config index 0 descriptor/all
[ 17.622147] usb 3-6: can't read configurations, error -110
[ 17.742093] usb 3-6: new full-speed USB device number 7 using xhci_hcd
[ 22.997715] usb 3-6: unable to read config index 0 descriptor/all
[ 22.997716] usb 3-6: can't read configurations, error -110
Although it may work after several times unpluging/pluging:
[ 68.195240] usb 3-6: new full-speed USB device number 11 using xhci_hcd
[ 68.337459] usb 3-6: New USB device found, idVendor=1b1c, idProduct=1b20
[ 68.337463] usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 68.337466] usb 3-6: Product: Corsair STRAFE RGB Gaming Keyboard
[ 68.337468] usb 3-6: Manufacturer: Corsair
[ 68.337470] usb 3-6: SerialNumber: 0F013021AEB8046755A93ED3F5001941
Tried three quirks: USB_QUIRK_DELAY_INIT, USB_QUIRK_NO_LPM and
USB_QUIRK_DEVICE_QUALIFIER, user confirmed that USB_QUIRK_DELAY_INIT alone
can workaround this issue. Hence add the quirk for Corsair Strafe RGB.
BugLink: https://bugs.launchpad.net/bugs/1678477
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
commit 9afae2719273fa1d406829bf3498f82dbdba71c7 upstream.
When fail to get needed page for pool, need to put allocated pages
into pool. But current code has a miscalculation of allocated pages,
correct it.
Signed-off-by: Xiangliang.Yu <Xiangliang.Yu@amd.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Monk Liu <monk.liu@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit f581a0dd744fe32b0a8805e279c59ec1ac676d60 upstream.
wl1251: add a missing spin_lock_init()
This fixes the following kernel warning:
[ 5668.771453] BUG: spinlock bad magic on CPU#0, kworker/u2:3/9745
[ 5668.771850] lock: 0xce63ef20, .magic: 00000000, .owner: <none>/-1,
.owner_cpu: 0
[ 5668.772277] CPU: 0 PID: 9745 Comm: kworker/u2:3 Tainted: G W
4.12.0-03002-gec979a4-dirty #40
[ 5668.772796] Hardware name: Nokia RX-51 board
[ 5668.773071] Workqueue: phy1 wl1251_irq_work
[ 5668.773345] [<c010c9e4>] (unwind_backtrace) from [<c010a274>]
(show_stack+0x10/0x14)
[ 5668.773803] [<c010a274>] (show_stack) from [<c01545a4>]
(do_raw_spin_lock+0x6c/0xa0)
[ 5668.774230] [<c01545a4>] (do_raw_spin_lock) from [<c06ca578>]
(_raw_spin_lock_irqsave+0x10/0x18)
[ 5668.774658] [<c06ca578>] (_raw_spin_lock_irqsave) from [<c048c010>]
(wl1251_op_tx+0x38/0x5c)
[ 5668.775115] [<c048c010>] (wl1251_op_tx) from [<c06a12e8>]
(ieee80211_tx_frags+0x188/0x1c0)
[ 5668.775543] [<c06a12e8>] (ieee80211_tx_frags) from [<c06a138c>]
(__ieee80211_tx+0x6c/0x130)
[ 5668.775970] [<c06a138c>] (__ieee80211_tx) from [<c06a3dbc>]
(ieee80211_tx+0xdc/0x104)
[ 5668.776367] [<c06a3dbc>] (ieee80211_tx) from [<c06a4af0>]
(__ieee80211_subif_start_xmit+0x454/0x8c8)
[ 5668.776824] [<c06a4af0>] (__ieee80211_subif_start_xmit) from
[<c06a4f94>] (ieee80211_subif_start_xmit+0x30/0x2fc)
[ 5668.777343] [<c06a4f94>] (ieee80211_subif_start_xmit) from
[<c0578848>] (dev_hard_start_xmit+0x80/0x118)
by adding the missing spin_lock_init().
Reported-by: Pavel Machek <pavel@ucw.cz>
Cc: Kalle Valo <kvalo@codeaurora.org>
Acked-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Pavel Machek <pavel@ucw.cz>
commit ba201c4f5ebe13d7819081756378777d8153f23e upstream.
Compare the number of bytes actually seen on the wire to the byte
count field returned by the slave device.
Previously we just overwrote the byte count returned by the slave
with the real byte count and let the caller figure out if the
message was sane.
Signed-off-by: Stephen Douthit <stephend@adiengineering.com>
Tested-by: Dan Priamo <danp@adiengineering.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit b6c159a9cb69c2cf0bf59d4e12c3a2da77e4d994 upstream.
According to Table 15-14 of the C2000 EDS (Intel doc #510524) the
rx data pointed to by the descriptor dptr contains the byte count.
desc->rxbytes reports all bytes read on the wire, including the
"byte count" byte. So if a device sends 4 bytes in response to a
block read, on the wire and in the DMA buffer we see:
count data1 data2 data3 data4
0x04 0xde 0xad 0xbe 0xef
That's what we want to return in data->block to the next level.
Instead we were actually prefixing that with desc->rxbytes:
bad
count count data1 data2 data3 data4
0x05 0x04 0xde 0xad 0xbe 0xef
This was discovered while developing a BMC solution relying on the
ipmi_ssif.c driver which was trying to interpret the bogus length
field as part of the IPMI response.
commit 2c0e8382386f618c85d20cb05e7cf7df8cdd382c upstream.
A SYNC is required between enabling the GIC region and actually trying
to use it, even if the first access is a read, otherwise its possible
depending on the timing (and in my case depending on the precise
alignment of certain kernel code) to hit CM bus errors on that first
access.
Add the SYNC straight after setting the GIC base.
[paul.burton@imgtec.com:
Changes later in this series increase our likelihood of hitting this
by reducing the amount of code that runs between enabling the GIC &
accessing it.]
Fixes: a7057270c280 ("irqchip: mips-gic: Add device-tree support")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/17019/
When building with gcc-7, the following warning happens:
drivers/gpu/drm/i915/intel_uncore.c: In function ‘hsw_unclaimed_reg_detect’:
drivers/gpu/drm/i915/intel_uncore.c:638:36: warning: decrement of a boolean expression [-Wbool-operation]
i915.mmio_debug = mmio_debug_once--;
As it's really not wise to -- on a boolean value.
Commit 7571494004d8 ("drm/i915: Do one shot unclaimed mmio detection
less frequently") which showed up in 4.6-rc1 does solve this issue, by
rewriting the mmio detection logic, but that isn't really good to
backport to 4.4-stable, so just fix up the obvious logic here to do the
right thing.
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Paulo Zanoni <przanoni@gmail.com>
Cc: Mika Kuoppala <mika.kuoppala@intel.com>
commit e791ce27c3f6a1d3c746fd6a8f8e36c9540ec6f9 upstream.
Once the reserved page array is unused we can reset the 'res_in_use'
state; here we can do a lazy update without holding the mutex as we only
need to check against concurrent access, not concurrent release.
[mkp: checkpatch]
Fixes: 1bc0eb044615 ("scsi: sg: protect accesses to 'reserved' page array")
Signed-off-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Cc: Todd Poynor <toddpoynor@google.com>
commit 1bc0eb0446158cc76562176b80623aa119afee5b upstream.
The 'reserved' page array is used as a short-cut for mapping data,
saving us to allocate pages per request. However, the 'reserved' array
is only capable of holding one request, so this patch introduces a mutex
for protect 'sg_fd' against concurrent accesses.
Tested-by: Johannes Thumshirn <jthumshirn@suse.de>
[toddpoynor@google.com: backport to 3.18-4.9, fixup for bad ioctl
SG_SET_FORCE_LOW_DMA code removed in later versions and not modified by
the original patch.]
commit 342b59caa66240b670285d519fdfe2c44289b516 upstream.
When the switch is rebooted, the lpfc driver fails to log
into the fabric, and Unexpected timeout message is seen.
Fix: Do not issue RegVFI if the FLOGI was internally aborted.
Signed-off-by: Dick Kennedy <dick.kennedy@avagotech.com>
Signed-off-by: James Smart <james.smart@avagotech.com>
Signed-off-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
commit 6f17581788206444cbbcdbc107498f85e9765e3d upstream.
gcc 7 complains:
drivers/net/wireless/intersil/p54/fwio.c: In function 'p54_scan':
drivers/net/wireless/intersil/p54/fwio.c:491:4: warning: 'memset' used with length equal to number of elements without multiplication by element size [-Wmemset-elt-size]
Fix that by passing the correct size to memset.
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
commit 27bfeb5a0619554d9734fb39e14f0e80fa7c342c upstream.
David reported that the length for memset was incorrect (element sizes
were not taken into account). Then I saw that we are clearing kzalloced
memory, so we can simply drop this code.
Reported-by: David Binderman <dcb314@hotmail.com>
Reviewed-by: Axel Lin <axel.lin@ingics.com>
commit 5cfa2a3c7342bd0b50716c8bb32ee491af43c785 upstream.
I'm getting a new warning with gcc-7:
isci/remote_node_context.c: In function 'sci_remote_node_context_destruct':
isci/remote_node_context.c:69:16: error: array subscript is above array bounds [-Werror=array-bounds]
This is odd, since we clearly cover all values for enum
scis_sds_remote_node_context_states here. Anyway, checking for an array
overflow can't harm and it makes the warning go away.
commit 7d64f82cceb21e6d95db312d284f5f195e120154 upstream.
When removing a GHES device notified by SCI, list_del_rcu() is used,
ghes_remove() should call synchronize_rcu() before it goes on to call
kfree(ghes), otherwise concurrent RCU readers may still hold this list
entry after it has been freed.
Signed-off-by: James Morse <james.morse@arm.com>
Reviewed-by: "Huang, Ying" <ying.huang@intel.com>
Fixes: 81e88fdc432a (ACPI, APEI, Generic Hardware Error Source POLL/IRQ/NMI notification type support)
commit e3d5092b6756b9e0b08f94bbeafcc7afe19f0996 upstream.
The on-stack resource-window 'win' in setup_res() is not
properly initialized. This causes the pointers in the
embedded 'struct resource' to contain stale addresses.
These pointers (in my case the ->child pointer) later get
propagated to the global iomem_resources list, causing a #GP
exception when the list is traversed in
iomem_map_sanity_check().
Fixes: c183619b63ec (x86/irq, ACPI: Implement ACPI driver to support IOAPIC hotplug)
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit 8e8496e0e9564b66165f5219a4e8ed20b0d3fc6b upstream.
A divide by zero error occurs if qp_count is less than mw_count because
num_qps_mw is calculated to be zero. The calculation appears to be
incorrect.
The requirement is for num_qps_mw to be set to qp_count / mw_count
with any remainder divided among the earlier mws.
For example, if mw_count is 5 and qp_count is 12 then mws 0 and 1
will have 3 qps per window and mws 2 through 4 will have 2 qps per window.
Thus, when mw_num < qp_count % mw_count, num_qps_mw is 1 higher
than when mw_num >= qp_count.
Signed-off-by: Logan Gunthorpe <logang@deltatee.com>
Fixes: e26a5843f7f5 ("NTB: Split ntb_hw_intel and ntb_transport drivers")
Acked-by: Allen Hubbe <Allen.Hubbe@dell.com>
Signed-off-by: Jon Mason <jdmason@kudzu.us>
commit cb827ee6ccc3e480f0d9c0e8e53eef55be5b0414 upstream.
In cases where there are more mw's than spads/2-2, the mw count gets
reduced to match the limitation. ntb_transport also tries to ensure that
there are fewer qps than mws but uses the full mw count instead of
the reduced one. When this happens, the math in
'ntb_transport_setup_qp_mw' will get confused and result in a kernel
paging request bug.
This patch fixes the bug by reducing qp_count to the reduced mw count
instead of the full mw count.
commit f299aec6ebd747298e35934cff7709c6b119ca52 upstream.
Add support for USB Device Rosewill RNX-N150NUB.
VendorID: 0x0bda, ProductID: 0xffef
Signed-off-by: Charles Milette <charles.milette@gmail.com>
commit f1664eaacec31035450132c46ed2915fd2b2049a upstream.
It has been reported for a while that with iio-sensor-proxy service the
rotation only works after one suspend/resume cycle. This required a wait
in the systemd unit file to avoid race. I found a Yoga 900 where I could
reproduce this.
The problem scenerio is:
- During sensor driver init, enable run time PM and also set a
auto-suspend for 3 seconds.
This result in one runtime resume. But there is a check to avoid
a powerup in this sequence, but rpm is active
- User space iio-sensor-proxy tries to power up the sensor. Since rpm is
active it will simply return. But sensors were not actually
powered up in the prior sequence, so actaully the sensors will not work
- After 3 seconds the auto suspend kicks
If we add a wait in systemd service file to fire iio-sensor-proxy after
3 seconds, then now everything will work as the runtime resume will
actually powerup the sensor as this is a user request.
To avoid this:
- Remove the check to match user requested state, this will cause a
brief powerup, but if the iio-sensor-proxy starts immediately it will
still work as the sensors are ON.
- Also move the autosuspend delay to place when user requested turn off
of sensors, like after user finished raw read or buffer disable
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Tested-by: Bastien Nocera <hadess@hadess.net>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit fdd0d32eb95f135041236a6885d9006315aa9a1d upstream.
According to the datasheet, the range of the acceleration is [-10 g, + 10 g],
so the scale factor should be 10 instead of 5.
Signed-off-by: Dragos Bogdan <dragos.bogdan@analog.com>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
commit b2a6d1b999a4c13e5997bb864694e77172d45250 upstream.
Commit c4ea41ba195d ("binder: use group leader instead of open thread")'
was incomplete and didn't update a check in binder_mmap(), causing all
mmap() calls into the binder driver to fail.
Signed-off-by: Martijn Coenen <maco@android.com>
Tested-by: John Stultz <john.stultz@linaro.org>
commit 00b40d613352c623aaae88a44e5ded7c912909d7 upstream.
Use wake_up_interruptible_sync() to hint to the scheduler binder
transactions are synchronous wakeups. Disable preemption while waking
to avoid ping-ponging on the binder lock.
Signed-off-by: Todd Kjos <tkjos@google.com>
Signed-off-by: Omprakash Dhyade <odhyade@codeaurora.org>
commit c4ea41ba195d01c9af66fb28711a16cc97caa9c5 upstream.
The binder allocator assumes that the thread that
called binder_open will never die for the lifetime of
that proc. That thread is normally the group_leader,
however it may not be. Use the group_leader instead
of current.
commit fd1adef3bff0663c5ac31b45bc4a05fafd43d19b upstream.
The VSL and HSL bits in the DSMR register set the corresponding
horizontal and vertical sync signal polarity to active high. The code
got it the wrong way around, fix it.
Signed-off-by: Koji Matsuoka <koji.matsuoka.xm@renesas.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
commit 9cdced8a39c04cf798ddb2a27cb5952f7d39f633 upstream.
There is a bug in the setting of the DES (Display Enable Signal)
register. This current setting occurs 1 dot left shift. The DES
register should be set minus one value about the specifying value
with H/W specification. This patch corrects it.
commit 05ee29e94acf0d4b3998c3f93374952de8f90176 upstream.
When an encoder fails to initialize the driver prints an error message
to the kernel log. The message contains the name of the encoder's DT
node, which is NULL for internal encoders. Use the of_node_full_name()
macro to avoid dereferencing a NULL pointer, print the output number to
add more context to the error, and make sure we still own a reference to
the encoder's DT node by delaying the of_node_put() call.
Reviewed-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit 82e7c5e4964545352accff4b44bbcaa2c38e7fc1 upstream.
The bit is named PLLON in the datasheet, rename it.
commit 5e1ac3bdc6bbb4f378251b87625b8acfbfc4ae82 upstream.
The frequency checks don't match the datasheet, fix them.
