Adding hsic funtionality to USB2 instance.
Add the changes required for hsic functionality and
power management.
BUG 756184
Change-Id: Ife8a1fc6ea95b15f66d840b1565d858ee25d5ded
Reviewed-on: http://git-master/r/15192
Tested-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Reviewed-by: Michael Hsu <mhsu@nvidia.com>
Tested-by: Michael Hsu <mhsu@nvidia.com>
Reviewed-by: Shail Dave <sdave@nvidia.com>
drivers/video/tegra/dc/hdmi.c
Change-Id: Ia65c693bf49160e3906df68403129ba1e5545912
alarm_irq_enable can enable/disable irqs and the same irq will
be enabled/disabled in set_alarm.
Bug 770380
Change-Id: Ibd006e83028cea5cd251d789d258a5549bfa34ce
Reviewed-on: http://git-master/r/18661
Change-Id: I9d9a9a301f23398a13fa7d865058f384288f6c92
Reviewed-on: http://git-master/r/18537
Reviewed-by: Nathan Lord <nlord@nvidia.com>
Tested-by: Nathan Lord <nlord@nvidia.com>
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Reviewed-by: Pritesh Raithatha <praithatha@nvidia.com>
Bug 770380
Change-Id: I8950a3ef2259b233b1711b266fa7d29270d95bfd
Reviewed-on: http://git-master/r/18565
tps6586 does not support burst writes. i2c writes have to be
1 byte at a time.
Change-Id: Iaf4fd9a3c1b983a3bb9a1ef680e03b14a69d736b
Reviewed-on: http://git-master/r/18561
Change-Id: I6fcdbcd0eb7103ac580deb94faf79959a5818ba1
Change-Id: I94c5c83c25a8aa1de344339f5759953074488720
Signed-off-by: Erik Gilling <konkers@android.com>
Looks for ieee registration numver 0x000c03 as per HDMI spec.
Change-Id: I6875b24c66e8754510edabcb4f9ba682a50d6ac1
Initial checkin for Maxim max8907c RTC driver
Change-Id: I764440cc1b0410e54f480a6e0ce424103052df14
Reviewed-on: http://git-master/r/16615
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Bug 782956
Change-Id: I0949eb5b40e75c7e9697787aba3d645dbe695cee
Reviewed-on: http://git-master/r/18167
Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
max8907c Charger Driver from maxim plus nvidia modifications
Integration from http://git-master/r/#change,15043
Change-Id: I8143fee9c99b43ad1089613236410dc8ad5bbca0
Reviewed-on: http://git-master/r/16134
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Bug 782954
Change-Id: I142e9b3684830e5a10b506d320dbddb71efa57d3
Reviewed-on: http://git-master/r/18018
Add support for atmel's maxtouch to enter/exit sleep mode
BUG 788286
Change-Id: I4d043d4a19147dd11c426b13ac5ef6eea77fe820
Reviewed-on: http://git-master/r/18336
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-by: Robert R Collins <rcollins@nvidia.com>
arch/arm/mach-tegra/include/mach/dc.h
drivers/video/tegra/host/nvhost_acm.c
Change-Id: Iddf74984cc02f08dca3738967c0580ba7c375337
Change-Id: Iceb3ef8b11d4ce18fd3cb0947268744775b81758
Reviewed-on: http://git-master/r/17525
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
added new entry for PORT_TEGRA in serial8250 driver and updated
flags and type of debug uart.
Bug : 782543
Change-Id: I3e6c59f7a24731e92bd48197c6b1b22acdba8a8f
Reviewed-on: http://git-master/r/17995
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Change-Id: I65d011f4a13d99ffc617a807d551d5869b739662
Change-Id: I22c280928079af04263375fce63a87776588a457
Change-Id: I870875673113113940a47d30010683e51b12a27b
Change-Id: I4be0eb963c3779b9313ef94476b1589059d4aa3c
Change-Id: Ida82a70efaeadc9d5b11d8703e688063680b72a8
Change-Id: I0e988d1724461ff2d5bd1009f2fdc379bd154703
Recently wake_peer op was added to uart_ops. Add this op for
tegra_hsuart allowing a platform to implement peer specific wakeup.
BUG 781303
Change-Id: Icfbac324815d7737c0e0820e57a2e8d844855ba0
Reviewed-on: http://git-master/r/17993
instead of clearing the irq for alarm enable/disable,
the proper bit in RTC_CONFIG has to be set/cleared.
tps6586 does not support 1/sec update counter so
remove support for update_irq_enable. replace it with
alarm_irq_enable.
Change-Id: Iee66a6625e810169253a750faf3f12d20d65d7d9
Reviewed-on: http://git-master/r/17990
Modify the max8907c regulator to use the new i2c api in the mfd driver
Change-Id: Ib919e97069459a9deb595b1fa0d3142763205de1
Reviewed-on: http://git-master/r/16614
Clean up portions of max8907c.c driver
Add capability for bulk i2c read and write
Add capability for second i2c bus for rtc
Add capability for irq handling for rtc and battery charger
Change-Id: I6c2c2c42591aee766635a2e32a7404bb2591f4a7
Reviewed-on: http://git-master/r/16613
Bug 785837
Change-Id: I008a37b17205d058d6ba12a7a34a5cdc747435d7
Reviewed-on: http://git-master/r/17893
Tested-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Victor Ryabukhin <vryabukhin@nvidia.com>
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
The new overlay code had this change commented out, because I hadn't
figured out how to get the resolution of the display outside of the fb
driver. This change now grabs it from the h_active and v_active of the
current mode.
Old Change:
video: tegra: Fixed the HDMI corruption issue.
If internal panel has different resolution compared
to HDMI panel, then window attributes are calculated
differently, this causes HDMI panel to show corruption.
This is fixed by checking actual display resolution
while computing window attributes.
Bug 784995
Change-Id: I1ba2a85355ae02ed8914fbc32ea695f53ff9a947
Reviewed-on: http://git-master/r/17139
Ensures that cpufreq_stats_free_table is called before
__cpufreq_remove_dev on cpu hotplug (which also occurs during
suspend on SMP systems) to make sure that sysfs_remove_group
can get called before the cpufreq kobj is freed. Otherwise,
the sysfs file structures are leaked.
Change-Id: I87e55277272f5cfad47e9e7c92630e990bb90069
Signed-off-by: Colin Cross <ccross@android.com>
Need cache maintenance on rw_handle to remove
display garbage issue which happens randomly.
Bug 778138
Change-Id: I227913d1e49d7c28a1a776e2b946cfa0cc7e9803
Reviewed-on: http://git-master/r/17236
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
For NVMAP_IOC_GET_ID, if the requested handle isn't found in the
client-private list, check the device-wide handles if allowed (global
handles or superuser).
The proper way to share memory between clients is to first call
IOC_GET_ID from the client who owns the memory, pass the resulting ID to
the new client, and then use IOC_FROM_ID in the new client to get a
handle. However, some (broken) legacy applications did both IOC_GET_ID
and IOC_FROM_ID steps in the new client. To support those applications
but hopefully prevent new applications from growing the same behavior,
the NVMAP_SEARCH_GLOBAL_HANDLES config option was added that restores
the old behavior (default N).
Note that even with this option enabled, the client issuing the
IOC_GET_ID call must be privileged to access the handle provided. In
practice, this means the global list search only works for clients who
have opened the /dev/knvmap super device node.
Change-Id: I6a4490de922864d9119b24e610cfa127ec64bdc7
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Reviewed-on: http://git-master/r/14431
During resume, gpio-keys does not get updated state of gpios which
fails to report wakeup key event. Update resume routine to report
key event based on wakeup source.
BUG 745149
Change-Id: Iff7a9b431f9da8d226c8d3cd522725c3049fef07
Reviewed-on: http://git-master/r/17455
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Sometimes unexpected status like I2C busy status, Tx FIFO interrupted
and wait on Rx data etc is seen. Add a code to detect such conditions
and return -EAGAIN from driver. This will cause the i2c-core to retry
the transmission as per the retry count and time-out specified by the
platform data of the adapter.
Bug ID: 777455
Change-Id: Iac5971bca4d760d93cd2ed147f78fc2807315b4e
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/16212
arch/arm/mach-tegra/tegra2_dvfs.c
Change-Id: I3853d668107c191c94f731256a8d0b63149e8279
This fixes a regression where hubs cannot detect new devices once they
have been auto-suspended.
Change-Id: I4b3efcaa9634b9a912060e438527000bbc83dc32
Signed-off-by: Benoit Goby <benoit@android.com>
Reviewed-on: http://git-master/r/16710
Change-Id: I9576853bbe0fae52c5c2cfab26ce8f2017077d4e
Reviewed-on: http://git-master/r/16709
Change-Id: I69731fcd50933ccea73542d046c3c5d86d03fcd9
Reviewed-on: http://git-master/r/16707
Exclude from the watchdog the time spent waiting for children that
are resumed asynchronously and time every devices, whether or not they
resumed synchronously.
Change-Id: I84209dfd5df72842e045096c906fd61e20e6d183
When tegra_dc_hdmi_detect is triggered with high HPD Interrupt,
but there's no previous trigger of low HPD interrupt,
by some specific HW design,
then, there's no switch change, no hotplug_handling is getting
called because 1=>1 change do nothing in switch_set_state.
Add this change for safe operation.
Bug 779317
Change-Id: I79f9ad24616388a9eb5156d53b12676b96665c38
Reviewed-on: http://git-master/r/16285
Support dither settings in display control structure by writing color
control registers.
Change-Id: I57ceb22a4b96bc507e15ad97893ec19a5be44ec7
Reviewed-on: http://git-master/r/15906
Add support for extra actions that have to be done after power on the
panel.
fixes bug 767252
Change-Id: I68b0c4d03818c2722149fcba38b6eb222157d209
Reviewed-on: http://git-master/r/15766
To match with its idc file. idc file is located in /device folder.
idc file adds more information about touch panel.
Change-Id: If99b7a9784a015d990447c843ba9b0defd3751a1
Reviewed-on: http://git-master/r/17200
Reviewed-by: Gaurav Sarode <gsarode@nvidia.com>
Tested-by: Gaurav Sarode <gsarode@nvidia.com>
Regulator has to be enabled for ISL29018.
Bug 782958
Change-Id: Ic8d86107d905c9b8e1d4a858c9028b0a13d3d188
Reviewed-on: http://git-master/r/17201
This reverts commit 0f04e9f691396f4d1e4288fff91ae8f5862dbba3.
Enable rtc alarm suspend/resume handlers which were disabled
as WAR.
BUG 773133
Change-Id: I666fdf92cb716b247eea1933d837f4c2439cd6fd
Reviewed-on: http://git-master/r/17179
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
This reverts commit 0ddc54a60b12fb13fec7c5d8f9ff3f162c96818f.
It leads to suspend-resume cycle as mentioned in the below bug.
BUG 773133
Change-Id: I51e2a48a000752d4aba02bd3f8e7e8ab18316371
Reviewed-on: http://git-master/r/17178
bug 783966
Change-Id: Ic454eba8675596cf77856e0ec3da8df7d56d82ee
Reviewed-on: http://git-master/r/17005
Tested-by: Joseph Lehrer <jlehrer@nvidia.com>
This creates a new device node per head - /dev/tegra_dc%u. There are a
number of ioctls in linux/tegra_overlay.h to open, close, and flip
overlays.
This is a replacement for the extensions in the tegra fb interface, but
does not remove that functionality for compatibility reasons. Once
everyone has moved, we can remove the tegra fb extensions.
Change-Id: Id78a94482637a7ce229ec64eb5feaf2dec2b7804
Reviewed-on: http://git-master/r/16700
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
