Set USB interface data to null at disconnect.
Bug 200018305
Bug 200024051
Change-Id: I65aec8c97f674faef0ebd9ed5916f28e22604da6
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/449265
Tested-by: Yunfan Zhang <yunfanz@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Anshul Jain (SW) <anshulj@nvidia.com>
HDMI needs to set DC to stop when closing, otherwise there is a flicker
upon shutdown
Bug 1448296
Change-Id: I93d14517e2b2ec77b0a6730a5c40930cd71f4327
Signed-off-by: David Dastous <ddastoussthi@nvidia.com>
Reviewed-on: http://git-master/r/447733
Tested-by: Anshuman Kar <anshumank@nvidia.com>
Currently oz_timer_add sets the new expiry time before calling
hrtimer_start_expires where the timer is actually updated in the
timerqueue.
However, this update to expiry time is racy because the the
hrtimer_set_expires call is being performed from a softirq or a thread's
context. The CPU could recieve a hrtimer_interrupt before the
hrtimer_start_expires call but after hrtimer_set_expires.
This would leave the hrtimer with a new expiry value but with the same
position in the rbtree which a subsequent hrtimer_interrupt could use
to perform its timerqueue add/del operations with. Leaving the rbtree
in this stale/bad state causes some timers to never get serviced.
Fix this by first removing the timer from the timerqueue by calling
hrtimer_cancel and then updating the expiry time.
Bug 200016188
Change-Id: Ib8acb9f2977580e077bbe968a32c6deba992d000
Signed-off-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Reviewed-on: http://git-master/r/439729
Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
Reviewed-by: Mitch Luban <mluban@nvidia.com>
Reviewed-by: Vinayak Pane <vpane@nvidia.com>
(cherry picked from commit bad282f7a9bf0cdbef32a6353e1a0154277eaaa7)
Reviewed-on: http://git-master/r/440902
Tested-by: Anshul Jain (SW) <anshulj@nvidia.com>
(cherry picked from commit aa4e6917c9a17ddfed3f14d1128f47d373e85097)
Reviewed-on: http://git-master/r/441373
If __cpufreq_remove_dev is called right after handle_update is
scheduled, it will cause kernel crashes at process_one_work.
Bug 200018349
Bug 200020039
Change-Id: I7521163977881493f79f83664b3dd7db4f81f257
Signed-off-by: Louis Li <louli@nvidia.com>
Reviewed-on: http://git-master/r/437036
Reviewed-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
In case of device role undetermined, we should return error instread of
going ahead to set IEs to FW, which could potentially cause a NULL poiter
issue.
Bug 200015171
Change-Id: I2dd1828d6ad87845d3b0ed5bfeaffad6fe728a1f
Signed-off-by: Allen Yu <alleny@nvidia.com>
Reviewed-on: http://git-master/r/434900
(cherry picked from commit 79936ac3b2a0069af2b55ec84ed44c86fc8fce17)
Reviewed-on: http://git-master/r/435737
In oz_pd_put(), PD may be already freed after calling oz_pd_destroy().
So we need to move WARN_ON() to the entry of oz_pd_put() instead to
avoid dangling pointer.
Bug 200017893
Change-Id: Ie12af2adcacab6dce0ce58a21a27c0497a540382
Reviewed-on: http://git-master/r/434837
(cherry picked from commit 42a76c8f61b33c73244f5114126e8f9e6bf72934)
Reviewed-on: http://git-master/r/435736
uevent workqueue needs to be flushed before pd free.
destroy workqueue should not have been rescheduled.
Don't make work struct NULL again.
Bug 200016744
Change-Id: Ief24aad7d787ca3ce6f0c5b4f41656aa50bf2bf4
Reviewed-on: http://git-master/r/432633
(cherry picked from commit 0011da3e0ed4b8c73992ff630ee8a2972ef8ba33)
Reviewed-on: http://git-master/r/435735
Bug 200015171
Change-Id: Ib8471805a37310692e69a02715c44cc5eb329d92
Signed-off-by: bibhayr <bibhayr@nvidia.com>
Signed-off-by: Aly Hirani <ahirani@nvidia.com>
Reviewed-on: http://git-master/r/434569
(cherry picked from commit 3f569103bd34a449afc45ded980292bfb412fdd8)
Reviewed-on: http://git-master/r/435734
Acquire spin_lock before checking disconnect flag of hid.
Also add USB interface null check at get_raw_report.
Bug 200018305
Change-Id: I7255fa641cabf0866dd0d1f2fdab460ec82eca70
Reviewed-on: http://git-master/r/434584
(cherry picked from commit df6b2b50b8e0f4db0609bd5c3388225243038778)
Reviewed-on: http://git-master/r/435733
Bug 200015171
Change-Id: I7c74fcbe5bb567051b356227596b49fedb8eac57
Signed-off-by: Eric Chuang <echuang@nvidia.com>
Reviewed-on: http://git-master/r/433942
(cherry picked from commit 74c2b52d3c248246942e5590d88398d95870bf8c)
Reviewed-on: http://git-master/r/435732
Increase all audio packet priority over network.
This will likely avoid audio glitches.
Change-Id: I5238da5060cb8d5990d4b4a7df8b856de7e46bd8
Reviewed-on: http://git-master/r/433901
(cherry picked from commit b4e4f79a1894b5716fc234ccf1c7224e7bdb6d42)
Reviewed-on: http://git-master/r/435731
Remove HID_CONNECT_FF bit from hid_connect.
Device has it's own forced feedback enabled.
Bug 200016744
Change-Id: I98f072c5a61809891264acbe7a498d51acef266f
Reviewed-on: http://git-master/r/433807
(cherry picked from commit 9d13c29fd07d8b15b9a5439f4a2057be8704a63d)
Signed-off-by: martin gao <marting@nvidia.com>
Reviewed-on: http://git-master/r/435730
The broadcom firmware sends a flowcontrol status in the rx packet
indicating that it is running short on tx buffers. This bit is used to
tell the driver to stop sending packets (based on their priority).
However, there seems to be a significantly large delay (~100ms) in the
fw updating the driver with the new flowcontrol bits.
Ozmo's audio traffic is marked as 0x106 priority which translates to
priority=0x40.
This change overrides the flowcontrol bits sent by the fw
and makes it so that the 0x40 priority traffic is never blocked from
flowcontrol. The DATAOK(bus) check on the bus ensures that we always
have enough tx buffers on the chip (despite the flowcontrol being set)
and that we don't end up clobbering packets on the fw.
Change-Id: I26c2d6f3b66d2e2f23c4c5327ed2577025bc089c
Reviewed-on: http://git-master/r/433463
(cherry picked from commit 98ab3dfb5c46e48a140d0888540d48b8770c9f4d)
Reviewed-on: http://git-master/r/435729
When PD is stopping, cancel hrtimers associated with it
instead of waiting for pd_destroy to cancel them.
Bug 200013781
Change-Id: Id6628e21b766a2f80ecfbe982cde2b82409c6637
Reviewed-on: http://git-master/r/432985
(cherry picked from commit b61d6a4da28f9b54d542e396a4a251d4ec4d9a0b)
Reviewed-on: http://git-master/r/435728
Force feedback should be enabled at hid-probe.
This has been caused by bad merge http://git-master/r/#/c/409169/
Change-Id: I5a9e97f2b489cfd0c1a988abd3c0a599ed226dd1
Reviewed-on: http://git-master/r/432986
(cherry picked from commit b8970d8083860a0a3b83c872bc4c2de255b74b9b)
Reviewed-on: http://git-master/r/435727
move the null pointer check before using it.
Bug 200015171
Change-Id: I669b62f2448cc515f67401df046a1d57638d8144
Reviewed-on: http://git-master/r/432834
(cherry picked from commit b33e2518db4411a7d1e89b9b116ae038ef4ed55e)
Reviewed-on: http://git-master/r/435726
Bug 200015171
Change-Id: I341dd59845ae981ba1aeb7a6229cc83c37322443
Signed-off-by: Mitch Luban <mluban@nvidia.com>
Reviewed-on: http://git-master/r/432559
(cherry picked from commit 99ef142403e3c7203febd174f0c533f9d72c245b)
Reviewed-on: http://git-master/r/435725
oz_pd_find() can return 0 if it fails to find any pd in g_pd_list
that matches the mac_addr. This could happen if oz_pd_stop() has been
called on the pd so that it's deleted from g_pd_list.
Change-Id: I6bedf242676d6cd316eae41dacd8a515dac296b8
Reviewed-on: http://git-master/r/432534
(cherry picked from commit d6e48d6e4b3a5b378502137f2eda68009333e144)
Reviewed-on: http://git-master/r/435724
If two routines A and B call oz_pd_destroy() in parallel, there could be
a race condition they are both able to get through to the point of increasing
pd_destroy_scheduled. For example, routine A reads pd_destroy_scheduled
and its value is zero, right after that routine B reads pd_destroy_scheduled
as well and its value is still zero. Then routine A and B will both be able
to go ahead to increase pd_destroy_scheduled and then schedule the oz_pd_free
workitem, causing the reduplicate oz_pd_free.
To fix that, using spinlock instead of atomic operation. Also do some cleanup
of the redundant code and fix a potential NULL pointer error in oz_pd_alloc().
Bug 200014887
Bug 1522180
Change-Id: I777c39298600c273b6f55bbaf524edd597c80c57
Reviewed-on: http://git-master/r/432519
(cherry picked from commit 8e7516dd2b71ded03e9a3556da32979d1ddba92c)
Reviewed-on: http://git-master/r/435723
some of the callbacks does not have the NULL
pointer check for wl. So, add wl NULL check for
every function. If net device gets unregistered
and there is another call on wl, kernel crash
happens. This will avoid all the crashes.
Bug 200015171
Change-Id: I15a7de6ba36caf7037c7a37a530f1829e2f94cf0
Reviewed-on: http://git-master/r/432450
(cherry picked from commit dbdc9e41eed97b0e9f29651f0f2c70c056165338)
Reviewed-on: http://git-master/r/435722
Set port changed flag at every hub disconnect control message.
USB hub status should know correct port status always.
Also contains ugly WAR to recover from network failure cases.
After 3 port reset retries reset the net interface.
Bug 1522708
Change-Id: I1aa5baa837f60668cfb4a23dd7fa820be27151e7
Reviewed-on: http://git-master/r/431926
(cherry picked from commit bf3790755af42b0d6d2497061b7880078829e9c7)
Reviewed-on: http://git-master/r/435721
decrease the pd reference count if workitem
scheduling fails.
Bug 200013781
Change-Id: I6452477df02b538c04e5424a18a35524343ec1f6
Reviewed-on: http://git-master/r/429292
(cherry picked from commit de30fcd8dd58c6cf046e9b95cc3f022085890ba1)
Reviewed-on: http://git-master/r/435720
To prevent blake disconnection on 2.4Ghz channels, set miracast mode 5
to disable interference mitigation and set miracast mode 6 to enable
auto interference mitigation.
Bug 1527717
Change-Id: I48447215051be1bf6983ccec8eb4d2f07c4b1f2a
Signed-off-by: Srinivas Ramachandran <srinivasra@nvidia.com>
Reviewed-on: http://git-master/r/428009
(cherry picked from commit c608170b0603d55bb703db1f08d07925d9bc0a3f)
Reviewed-on: http://git-master/r/435719
problem:
during p2p interface add/remove stress, race condition is happening
for rtnl_lock between cfg80211_event_work and dhd driver. due to
which system's net stack is going in to deadlock state.
solution:
to register p2p interface make use of register_netdevice instead
of register_netdev which doesn't require rtnl_lock and remove
rtnl_unlock/lock that was added to make sure register_netdev doesn't
block on rtnl_lock.
Bug 1515721
Change-Id: Iceba835b986561fce9e707ef9cc92e3265689abb
Signed-off-by: Om Prakash Singh <omp@nvidia.com>
Reviewed-on: http://git-master/r/426983
(cherry picked from commit 29ff3759b1352d1c7c8278b6b123c3b3317917b8)
Reviewed-on: http://git-master/r/435718
oz_pd_destroy() is called mulitple times when network
down notifier gets triggered. Destroy workqueue is scheduled
from tasklet and also from oz_binding_remov function.
Protecting it by strictly scheduling workqueue only once.
Bug 1522180
Bug 1522708
Change-Id: I47c92a5e7ef1067d5dc4cdf67653a785eff34bca
Reviewed-on: http://git-master/r/426904
(cherry picked from commit 2115acceab535b3b493519c23cb076045618482b)
Reviewed-on: http://git-master/r/435717
Call kobject_uevent_env() always from process context.
Bug 1523226
Reviewed-on: http://git-master/r/425002
(cherry picked from commit a7168d798724a3049f6dc53cd0f35d2c34163e48)
Change-Id: I65e52eda1349b2a807c323d3f8768e1bda516a45
Signed-off-by: S Tateno <shigekatsu.tateno@atmel.com>
Reviewed-on: http://git-master/r/426903
(cherry picked from commit aa608de59a483a9e868bb77b0e9460ec0eb551d6)
Reviewed-on: http://git-master/r/435716
This reverts commit 3e6733bb4f62148b38af8ccbe56dc0e62a052138.
An improvised fix for this is provided by Atmel with patch
"staging: ozwpan: kobject_uevent_env() from process context"
which is submitted separately.
Reviewed-on: http://git-master/r/425001
(cherry picked from commit 2b0b08d23de2a59275c276df87f2b11237f833e9)
Change-Id: I91ded7b515dea4a9fd75a04fd98b66f67f789504
Reviewed-on: http://git-master/r/426902
(cherry picked from commit 4cfff60103501540866dde35bd90e20fd721418f)
Reviewed-on: http://git-master/r/435715
update the status of the firmware to connected after
AP association when the WLC_E_SET_SSID event happens.
Currently it updates the status before WLC_E_SET_SSID.
Bug 200013819
Change-Id: Ic126661373e75ecaf561831396d3c23990314444
Reviewed-on: http://git-master/r/425086
(cherry picked from commit d956e21d55b1c3f1d5ae832ab3e3bf8368138ea5)
Reviewed-on: http://git-master/r/435714
Do not allow virtual p2p interface creation while the AP
drviver status is CONNECTING
Bug 200009241
Bug 200009346
Bug 200009344
Bug 200009328
Change-Id: I8bfba473110067b550473e32295ad523a5515023
Reviewed-on: http://git-master/r/417330
(cherry picked from commit 7436ab5ebc68e08e0c54f6ddfcaf1b078ebb532c)
Reviewed-on: http://git-master/r/425081
(cherry picked from commit d4e1b14483dda59bccddb1fc65535b9dc8487269)
Reviewed-on: http://git-master/r/435713
If kmemdup() in hidraw_report_event() fails, we are not propagating
this fact properly.
Let hidraw_report_event() and hid_report_raw_event() return an error
value to the caller.
Reported-by: Oliver Neukum <oneukum@suse.de>
(cherry picked from commit b6787242f32700377d3da3b8d788ab3928bab849)
Change-Id: I4594eedebe423f1f8d6ff5272ab7b5bc4c924593
Signed-off-by: Jean Huang <jeanh@nvidia.com>
Reviewed-on: http://git-master/r/427998
Exporting the function allows us to calculate the resolution in third
party drivers like hid-multitouch.
This patch also complete the function with additional valid axes.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
(cherry picked from commit 37cf6e6fc34e2fca4e7c565697e7cd5c317bc316)
Change-Id: I526e9fad8ee4369b4a52f6325234a6ef22fb2bb7
Reviewed-on: http://git-master/r/427996
Reviewed-by: Jean Huang <jeanh@nvidia.com>
Tested-by: Jean Huang <jeanh@nvidia.com>
Add digitizer X Tilt and Y Tilt usage support along with resolution calculation.
Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com>
(cherry picked from commit b73b2da0353d15b712b27b1aed3c50856bdfc341)
Change-Id: I50d34fb9dceccad05d534898396e260ff223020c
Reviewed-on: http://git-master/r/427994
Some drivers send reports directly to underlying device, creating an
unwanted dependency on the underlying transport layer. This patch adds
hid_hw_request() to the interface, thereby removing usbhid from the
lion share of the drivers.
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
(cherry picked from commit e90a6df80dc45ab53d2f4f4db297434e48c0208e)
Change-Id: Ib042c9600a56d092e1548e7c12a1fddf28a0ac5b
Reviewed-on: http://git-master/r/427991
Call kobject_uevent_env() from process context.
Bug 1523226
Change-Id: I6b5569f986b179f8b804642dc3702f3a3f10d180
Reviewed-on: http://git-master/r/422536
(cherry picked from commit 3e6733bb4f62148b38af8ccbe56dc0e62a052138)
Reviewed-on: http://git-master/r/427952
add notifier function to remove p2p netdevice binding on
NETDEV_DOWN or NETDEV_UNREGISTER events
Bug 1478118
Bug 1470921
Change-Id: I6a18c65ee45affeaa6f459b656888c1c52d2fd3b
Reviewed-on: http://git-master/r/368141
(cherry picked from commit 28d61853e7f35e80ba11784eceb83acd1a870fac)
Reviewed-on: http://git-master/r/383615
(cherry picked from commit c67c144624703bc7d927c6822c24ecbc9a6b04f9)
Reviewed-on: http://git-master/r/427951
Make sure we remove node from list while we still
hold lock.
Bug 1474422
Change-Id: I7e23f6432f347937b1883ea086e55f5c324fc985
Reviewed-on: http://git-master/r/380497
(cherry picked from commit 466f6ed30787d16fff3f74e9412416de5b1eb0f6)
Reviewed-on: http://git-master/r/427950
Update to driver version 10.00.01.02.05
Bug 1459299
Change-Id: I73dcbb97093179c4a69b9e5cbfc4d10a16e228ec
Reviewed-on: http://git-master/r/368040
(cherry picked from commit aaa4d5c3e5e21b3a220b3103b72eee6fda0203b3)
Reviewed-on: http://git-master/r/427949
hidinput_disconnect() function frees hid drv data
internally, remove unnecessary kfree from driver.
Change-Id: Idd60a597d607d5a68eedb7dd51daeca867d31125
Reviewed-on: http://git-master/r/412819
(cherry picked from commit c7b31ae80b2364903095a98a32b31a37f98900b1)
Reviewed-on: http://git-master/r/427948
Add device disconnect check in usbhid_get_raw_report()
Bug 200000762
Change-Id: Ia56a5ba746ee197a0be967f4cb09e38e44be8a8f
Reviewed-on: http://git-master/r/404650
(cherry picked from dd289fb0c9cb7f3b2f3ad37509d08591180aa60d)
Reviewed-on: http://git-master/r/427947
Adding remove function to remove sysfs attribute nodes
when blake is disconnected.
Bug 200003632
Change-Id: I5bf571176d2653b9f74f548775da904ef93007c8
Reviewed-on: http://git-master/r/410596
(cherry picked from commit 9904c21f42b14f3675c27ef2646eae669440bd07)
Reviewed-on: http://git-master/r/409169
(cherry picked from commit 3d1e96872a5769ff66678c0235654ade43c9ea3c)
Reviewed-on: http://git-master/r/427946
Make changes to the blake driver to support new features that were
enabled with new FW. This includes:
- Force feedback enablement
- Touchpad tweaking to improve UX
- New hid report support
Bug 1456586
Bug 1481171
Bug 1504937
Bug 1514012
Change-Id: I8e35c9206a88a7a4911457ba500ed5be2070867f
Reviewed-on: http://git-master/r/411089
(cherry picked from commit 88ed3da9d1d5566165dd634a2e532ad1e9521b29)
Reviewed-on: http://git-master/r/427945
-Mouse Mode(Default on KK): trackpad is functioning as
a mouse.
-Gesture Mode(Default on KKWT): trackpad is functioning
as a D-pad.
-Absolute Mode: trackpad is sending absolute coordinates
as ABS_X and ABS_Y.
-Disabled Mode: trackpad will not send anything to host.
Bug 1503137
Change-Id: Ifd007af18cafc0e1c34ba335cae9ee59e34e9e9f
Reviewed-on: http://git-master/r/399867
(cherry picked from commit 21e8fe3450c7429362dbeddca2df65893bbae575)
Reviewed-on: http://git-master/r/427944
-Converted absolute coordinates to REL events.
-Adjusted blake joystick parameters to increase
granularity.
Bug 1487225
Change-Id: I3f90e79e5519a74d46947ef851b126cca4070719
Reviewed-on: http://git-master/r/394924
(cherry picked from commit ed1bc9b9e6f5d38476ba97f10102b602c9b92aac)
Reviewed-on: http://git-master/r/427943
This is to support recovery kernel, where we
don't have Android keymapping but totally relying
on "real" KEY_HOME/KEY_BACK.
Bug 1431870
Change-Id: Ib3185bc230b65b5e25094caf3a61fa45ed2b835b
Reviewed-on: http://git-master/r/350820
(cherry picked from commit e8c64f6f7cf8280b903a6f29116b79abb1538f05)
Reviewed-on: http://git-master/r/427942
In order to customize the flat and fuzz of the
joystick, create an separate hid driver for
Shield joystick. It does the same hid mapping
with hid-input.c but only changes the flat and
fuzz configurations.
Bug 1352488
Change-Id: Ide6d37eeeffac9a7150fb257d30f348599794c4c
Reviewed-on: http://git-master/r/335198
(cherry picked from commit e0e74a97241af85468858cdd79fd4ba994804007)
Reviewed-on: http://git-master/r/381015
choose appropriate netdev to issue scan command depending on netdev
interface type.
Bug 1472982
Change-Id: I1bdf15760119f98e4b55432aef6e397b16bed1e4
Signed-off-by: Dhruvaraja Kunjar <dkunjar@broadcom.com>
Reviewed-on: http://git-master/r/383635
(cherry picked from commit 359142ef5a6def496a588d2c6b48f1acbe65e8b4)
Reviewed-on: http://git-master/r/417396
Reviewed-by: Mandar Padmawar <mpadmawar@nvidia.com>
Tested-by: Mandar Padmawar <mpadmawar@nvidia.com>
dhd_idx2net can return NULL. ndev_to_wdev needs valid input
Bug 1507452
Change-Id: I2291f0a1a71b90dc799f93169ccf7eec63479f18
Reviewed-on: http://git-master/r/401796
(cherry picked from commit 8263b665ebb294ae5e51078a20a5ab94b9100fd9)
Reviewed-on: http://git-master/r/417395
Reviewed-by: Narayan Reddy <narayanr@nvidia.com>
Tested-by: Narayan Reddy <narayanr@nvidia.com>
Reviewed-by: Mohan Thadikamalla <mohant@nvidia.com>
On concurrent P2P and STA connection stress tests observe
NULL pointer issue in wl_cfgp2p_generate_bss_mac function.
So add NULL checks for input parameters.
Bug 1455328
Change-Id: I884d1612b1df16c5acd038b8cd0f51129e5d9130
Signed-off-by: Mohan T <mohant@nvidia.com>
Reviewed-on: http://git-master/r/385779
(cherry picked from commit 21a162bc3f9eb7ec0153ff87cdbf28433fe34a6f)
Reviewed-on: http://git-master/r/417394
modify DHD_SCAN_UNASSOC_ACTIVE_TIME and
DHD_SCAN_ASSOC_ACTIVE_TIME to 65 and 35 msec to save
300 msec of active scan time in non associated state and
100 msec in case of associated state.
Bug 1512114
Change-Id: I902400763d0e64ee020ff4650253e4934527c0e3
Signed-off-by: Narayan Reddy <narayanr@nvidia.com>
Reviewed-on: http://git-master/r/407443
(cherry picked from commit aa34b71e8b235eb2d05e4d2b099bcae36c7d0a02)
Reviewed-on: http://git-master/r/417380
Ensure system time is read from rtc i.e. PMIC RTC
in case of tegra after system resume.
- Change is applicable to all PMIC RTC drivers.
bug 1510843
Change-Id: I8194f9f4be581216d662e6a6e0d7e98a9495159c
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/413365
