path: root/drivers
2008-05-17Merge branch 'linus' into x86/garttip-x86-gart-2008-05-17-15-12-25Thomas Gleixner
2008-05-15Merge branch 'merge' of ↵tip-x86-urgent-2008-05-17-17-16-08tip-x86-setup-2008-05-30_12.10_Fritip-x86-mtrr-2008-05-16-12-09-30tip-x86-cleanups-2008-05-16-11-16-08tip-tip-2008-05-26_08_52_Montip-timers-hrtimers-2008-05-30_12.09_Fritip-timers-hpet-2008-05-30_12.09_Fritip-sched-2008-05-26_08_52_Montip-core-locking-2008-05-26_08_52_MonLinus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] macintosh: Replace deprecated __initcall with device_initcall [POWERPC] cell: Fix section mismatches in io-workarounds code [POWERPC] spufs: Fix compile error [POWERPC] Fix uninitialized variable bug in copy_{to|from}_user [POWERPC] Add null pointer check to of_find_property [POWERPC] vmemmap fixes to use smaller pages [POWERPC] spufs: Fix pointer reference in find_victim [POWERPC] 85xx: SBC8548 - Add flash support and HW Rev reporting [POWERPC] 85xx: Fix some sparse warnings for 85xx MDS [POWERPC] 83xx: Enable DMA engine on the MPC8377 MDS board. [POWERPC] 86xx: mpc8610_hpcd: fix second serial port [POWERPC] 86xx: mpc8610_hpcd: add support for NOR and NAND flashes [POWERPC] 85xx: Add 8568 PHY workarounds to board code [POWERPC] 86xx: mpc8610_hpcd: use ULI526X driver for on-board ethernet
2008-05-15Clean up 'print_fn_descriptor_symbol()' typesLinus Torvalds
Everybody wants to pass it a function pointer, and in fact, that is what you _must_ pass it for it to make sense (since it knows that ia64 and ppc64 use descriptors for function pointers and fetches the actual address from there). So don't make the argument be a 'unsigned long' and force everybody to add a cast. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-15tty: fix BKL related leak and crashIngo Molnar
Enabling the BKL to be lockdep tracked uncovered the following upstream kernel bug in the tty code, which caused a BKL reference leak: ================================================ [ BUG: lock held when returning to user space! ] ------------------------------------------------ dmesg/3121 is leaving the kernel with locks still held! 1 lock held by dmesg/3121: #0: (kernel_mutex){--..}, at: [<c02f34d9>] opost+0x24/0x194 this might explain some of the atomicity warnings and crashes that -tip tree testing has been experiencing since the BKL was converted back to a spinlock. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-15Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [S390] show_interrupts: prevent cpu hotplug when walking cpu_online_map. [S390] smp: __smp_call_function_map vs cpu_online_map fix. [S390] tape: Use ccw_dev_id to build cdev_id. [S390] dasd: fix timeout handling in interrupt handler [S390] s390dbf: Use const char * for dbf name. [S390] dasd: Use const in busid functions. [S390] blacklist.c: removed duplicated include [S390] vmlogrdr: module initialization function should return negative errors [S390] sparsemem vmemmap: initialize memmap. [S390] Remove last traces of cio_msg=. [S390] cio: Remove CCW_CMD_SUSPEND_RECONN in front of CCW_CMD_SET_PGID.
2008-05-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: arch/parisc/kernel/perf_asm.S: build fix parisc: remove -traditional from assembler flags parisc: use conditional macro for 64-bit wide ops parisc: Remove ioctl.h content picked up from <asm-generic/ioctl.h>. arch/parisc/kernel/unaligned.c: use time_* macros parisc: remove redundant display of free swap space in show_mem() drivers/parisc: replace remaining __FUNCTION__ occurrences parisc: replace remaining __FUNCTION__ occurrences parisc: new termios definitions parisc: fix trivial section name warnings
2008-05-15[S390] tape: Use ccw_dev_id to build cdev_id.Cornelia Huck
To construct the integer containing the information from the bus_id, it is easier to use the data from ccw_dev_id than to parse the bus_id. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-15[S390] dasd: fix timeout handling in interrupt handlerStefan Weinhuber
When the dasd_int_handler is called with an error code instead of an irb, the associated request should be restarted. This handling was missing from the -ETIMEDOUT case. In fact it should be done in any case. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-15[S390] dasd: Use const in busid functions.Cornelia Huck
We should use 'const char *' in the busid functions since the strings are not modified anyway. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-15[S390] blacklist.c: removed duplicated includeHuang Weiyi
Removed duplicated include <asm/cio.h> in drivers/s390/cio/blacklist.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-15[S390] vmlogrdr: module initialization function should return negative errorsMarcin Slusarz
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-15[S390] cio: Remove CCW_CMD_SUSPEND_RECONN in front of CCW_CMD_SET_PGID.Michael Ernst
CCW_CMD_SUSPEND_RECONN causes a system hang if the cable of a reserved DASD is disconnected and connected again. Signed-off-by: Michael Ernst <mernst@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-15drivers/parisc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-05-15[POWERPC] macintosh: Replace deprecated __initcall with device_initcallRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-15[POWERPC] Add null pointer check to of_find_propertyTimur Tabi
Update function of_find_property() to return NULL if the device_node passed to it is also NULL. Otherwise, passing NULL will cause a null pointer dereference. Without this, the legacy_serial driver will crash if there's no 'chosen' node in the device tree. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-14tty_check_change(): avoid taking tasklist_lock while holding tty->ctrl_lockAndrew Morton
May 11 09:42:27 [kernel] [ 1104.496819] rarian-sk-get-c[5630]: segfault at 0 ip 7f478556caf0 sp 7fff8e3fe338 error 4 in libc-2.6.1.so[7f47854f9000+136000] May 11 10:59:48 [kernel] [ 2494.165792] May 11 10:59:48 [kernel] [ 2494.165794] ======================================================= May 11 10:59:48 [kernel] [ 2494.165801] [ INFO: possible circular locking dependency detected ] May 11 10:59:48 [kernel] [ 2494.165805] 2.6.26-rc1-00007-g91b3a7a #217 May 11 10:59:48 [kernel] [ 2494.165807] ------------------------------------------------------- May 11 10:59:48 [kernel] [ 2494.165809] less/7053 is trying to acquire lock: May 11 10:59:48 [kernel] [ 2494.165812] (tasklist_lock){..??}, at: [<ffffffff80232e95>] is_current_pgrp_orphaned+0x15/0x50 May 11 10:59:48 [kernel] [ 2494.165821] May 11 10:59:48 [kernel] [ 2494.165822] but task is already holding lock: May 11 10:59:48 [kernel] [ 2494.165824] (&tty->ctrl_lock){....}, at: [<ffffffff803d5f31>] tty_check_change+0x61/0x110 May 11 10:59:48 [kernel] [ 2494.165831] May 11 10:59:48 [kernel] [ 2494.165832] which lock already depends on the new lock. May 11 10:59:48 [kernel] [ 2494.165833] May 11 10:59:48 [kernel] [ 2494.165835] May 11 10:59:48 [kernel] [ 2494.165836] the existing dependency chain (in reverse order) is: May 11 10:59:48 [kernel] [ 2494.165838] May 11 10:59:48 [kernel] [ 2494.165839] -> #2 (&tty->ctrl_lock){....}: May 11 10:59:48 [kernel] [ 2494.165843] [<ffffffff80253796>] __lock_acquire+0xf86/0x1080 May 11 10:59:48 [kernel] [ 2494.165851] [<ffffffff80253922>] lock_acquire+0x92/0xc0 May 11 10:59:48 [kernel] [ 2494.165858] [<ffffffff804deee0>] _spin_lock_irqsave+0x40/0x60 May 11 10:59:48 [kernel] [ 2494.165866] [<ffffffff803d31b5>] __proc_set_tty+0x35/0xe0 May 11 10:59:48 [kernel] [ 2494.165873] [<ffffffff803d76d4>] tty_ioctl+0xbf4/0xfe0 May 11 10:59:48 [kernel] [ 2494.165880] [<ffffffff802a05e1>] vfs_ioctl+0x31/0x90 May 11 10:59:48 [kernel] [ 2494.165888] [<ffffffff802a06b3>] do_vfs_ioctl+0x73/0x2d0 May 11 10:59:48 [kernel] [ 2494.165895] [<ffffffff802a095a>] sys_ioctl+0x4a/0x80 May 11 10:59:48 [kernel] [ 2494.165902] [<ffffffff8020b5ab>] system_call_after_swapgs+0x7b/0x80 May 11 10:59:48 [kernel] [ 2494.165910] [<ffffffffffffffff>] 0xffffffffffffffff May 11 10:59:48 [kernel] [ 2494.165924] May 11 10:59:48 [kernel] [ 2494.165925] -> #1 (&sighand->siglock){++..}: May 11 10:59:48 [kernel] [ 2494.165929] [<ffffffff80253796>] __lock_acquire+0xf86/0x1080 May 11 10:59:48 [kernel] [ 2494.165936] [<ffffffff80253922>] lock_acquire+0x92/0xc0 May 11 10:59:48 [kernel] [ 2494.165943] [<ffffffff804dec1f>] _spin_lock+0x2f/0x40 May 11 10:59:48 [kernel] [ 2494.165951] [<ffffffff8022d5a3>] copy_process+0x973/0x1210 May 11 10:59:48 [kernel] [ 2494.165959] [<ffffffff8022df12>] do_fork+0x82/0x2f0 May 11 10:59:48 [kernel] [ 2494.165967] [<ffffffff8020bfe1>] kernel_thread+0x81/0xde May 11 10:59:48 [kernel] [ 2494.165974] [<ffffffff8020c048>] child_rip+0xa/0x12 May 11 10:59:48 [kernel] [ 2494.165981] [<ffffffffffffffff>] 0xffffffffffffffff May 11 10:59:48 [kernel] [ 2494.166038] May 11 10:59:48 [kernel] [ 2494.166039] -> #0 (tasklist_lock){..??}: May 11 10:59:48 [kernel] [ 2494.166043] [<ffffffff802535ab>] __lock_acquire+0xd9b/0x1080 May 11 10:59:48 [kernel] [ 2494.166050] [<ffffffff80253922>] lock_acquire+0x92/0xc0 May 11 10:59:48 [kernel] [ 2494.166057] [<ffffffff804dede2>] _read_lock+0x32/0x50 May 11 10:59:48 [kernel] [ 2494.166063] [<ffffffff80232e95>] is_current_pgrp_orphaned+0x15/0x50 May 11 10:59:48 [kernel] [ 2494.166071] [<ffffffff803d5f80>] tty_check_change+0xb0/0x110 May 11 10:59:48 [kernel] [ 2494.166078] [<ffffffff803dac5f>] set_termios+0x1f/0x4c0 May 11 10:59:48 [kernel] [ 2494.166085] [<ffffffff803db379>] tty_mode_ioctl+0x279/0x3e0 May 11 10:59:48 [kernel] [ 2494.166092] [<ffffffff803db51d>] n_tty_ioctl+0x3d/0x260 May 11 10:59:48 [kernel] [ 2494.166100] [<ffffffff803d6c34>] tty_ioctl+0x154/0xfe0 May 11 10:59:48 [kernel] [ 2494.166107] [<ffffffff802a05e1>] vfs_ioctl+0x31/0x90 May 11 10:59:48 [kernel] [ 2494.166114] [<ffffffff802a06b3>] do_vfs_ioctl+0x73/0x2d0 May 11 10:59:48 [kernel] [ 2494.166121] [<ffffffff802a095a>] sys_ioctl+0x4a/0x80 May 11 10:59:48 [kernel] [ 2494.166128] [<ffffffff8020b5ab>] system_call_after_swapgs+0x7b/0x80 May 11 10:59:48 [kernel] [ 2494.166135] [<ffffffffffffffff>] 0xffffffffffffffff May 11 10:59:48 [kernel] [ 2494.166142] May 11 10:59:48 [kernel] [ 2494.166143] other info that might help us debug this: May 11 10:59:48 [kernel] [ 2494.166144] May 11 10:59:48 [kernel] [ 2494.166146] 1 lock held by less/7053: May 11 10:59:48 [kernel] [ 2494.166148] #0: (&tty->ctrl_lock){....}, at: [<ffffffff803d5f31>] tty_check_change+0x61/0x110 May 11 10:59:48 [kernel] [ 2494.166155] May 11 10:59:48 [kernel] [ 2494.166156] stack backtrace: May 11 10:59:48 [kernel] [ 2494.166159] Pid: 7053, comm: less Not tainted 2.6.26-rc1-00007-g91b3a7a #217 May 11 10:59:48 [kernel] [ 2494.166161] May 11 10:59:48 [kernel] [ 2494.166162] Call Trace: May 11 10:59:48 [kernel] [ 2494.166168] [<ffffffff80251223>] print_circular_bug_tail+0x83/0x90 May 11 10:59:48 [kernel] [ 2494.166172] [<ffffffff80250889>] ? print_circular_bug_entry+0x49/0x60 May 11 10:59:48 [kernel] [ 2494.166178] [<ffffffff802535ab>] __lock_acquire+0xd9b/0x1080 May 11 10:59:48 [kernel] [ 2494.166184] [<ffffffff80232e95>] ? is_current_pgrp_orphaned+0x15/0x50 May 11 10:59:48 [kernel] [ 2494.166189] [<ffffffff80253922>] lock_acquire+0x92/0xc0 May 11 10:59:48 [kernel] [ 2494.166206] [<ffffffff803d5f80>] tty_check_change+0xb0/0x110 May 11 10:59:48 [kernel] [ 2494.166211] [<ffffffff803dac5f>] set_termios+0x1f/0x4c0 May 11 10:59:48 [kernel] [ 2494.166216] [<ffffffff803d3423>] ? tty_ldisc_try+0x23/0x60 May 11 10:59:48 [kernel] [ 2494.166220] [<ffffffff803d3444>] ? tty_ldisc_try+0x44/0x60 May 11 10:59:48 [kernel] [ 2494.166224] [<ffffffff804df2c5>] ? _spin_unlock_irqrestore+0x65/0x80 May 11 10:59:48 [kernel] [ 2494.166230] [<ffffffff803db379>] tty_mode_ioctl+0x279/0x3e0 May 11 10:59:48 [kernel] [ 2494.166234] [<ffffffff803d3444>] ? tty_ldisc_try+0x44/0x60 May 11 10:59:48 [kernel] [ 2494.166239] [<ffffffff803db51d>] n_tty_ioctl+0x3d/0x260 May 11 10:59:48 [kernel] [ 2494.166244] [<ffffffff803d6c34>] tty_ioctl+0x154/0xfe0 May 11 10:59:48 [kernel] [ 2494.166249] [<ffffffff80252baa>] ? __lock_acquire+0x39a/0x1080 May 11 10:59:48 [kernel] [ 2494.166256] [<ffffffff80252baa>] ? __lock_acquire+0x39a/0x1080 May 11 10:59:48 [kernel] [ 2494.166263] [<ffffffff80252baa>] ? __lock_acquire+0x39a/0x1080 May 11 10:59:48 [kernel] [ 2494.166269] [<ffffffff802a05e1>] vfs_ioctl+0x31/0x90 May 11 10:59:48 [kernel] [ 2494.166274] [<ffffffff802a06b3>] do_vfs_ioctl+0x73/0x2d0 May 11 10:59:48 [kernel] [ 2494.166280] [<ffffffff802a095a>] sys_ioctl+0x4a/0x80 May 11 10:59:48 [kernel] [ 2494.166286] [<ffffffff8020b5ab>] system_call_after_swapgs+0x7b/0x80 May 11 10:59:48 [kernel] [ 2494.166292] Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14Remove blkdev warning triggered by using mdNeil Brown
As setting and clearing queue flags now requires that we hold a spinlock on the queue, and as blk_queue_stack_limits is called without that lock, get the lock inside blk_queue_stack_limits. For blk_queue_stack_limits to be able to find the right lock, each md personality needs to set q->queue_lock to point to the appropriate lock. Those personalities which didn't previously use a spin_lock, us q->__queue_lock. So always initialise that lock when allocated. With this in place, setting/clearing of the QUEUE_FLAG_PLUGGED bit will no longer cause warnings as it will be clear that the proper lock is held. Thanks to Dan Williams for review and fixing the silly bugs. Signed-off-by: NeilBrown <neilb@suse.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Alistair John Strachan <alistair@devzero.co.uk> Cc: Nick Piggin <npiggin@suse.de> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Jacek Luczak <difrost.kernel@gmail.com> Cc: Prakash Punnoor <prakash@punnoor.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14char: select fw_loader by moxaJiri Slaby
Select FW_LOADER since moxa needs it, otherwise we face link problems such as: drivers/built-in.o: In function moxa_pci_probe':moxa.c:(.devinit.text+0x76d8): undefined reference to request_firmware' :moxa.c:(.devinit.text+0x7e6e): undefined reference to release_firmware' make: *** [.tmp_vmlinux1] Error 1 Reported-by: Philippe Roussel <p.o.roussel@free.fr> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14lib: create common ascii hex arrayHarvey Harrison
Add a common hex array in hexdump.c so everyone can use it. Add a common hi/lo helper to avoid the shifting masking that is done to get the upper and lower nibbles of a byte value. Pull the pack_hex_byte helper from kgdb as it is opencoded many places in the tree that will be consolidated. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14video/logo: add support for Blackfin/Linux logo for framebuffer consoleRobin Getz
This art design is beautiful, isn't it? And you can watch our demo on YouTube: http://youtube.com/watch?v=fKyQOntPEFs Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14ipmi: support I/O resources in OF driverNate Case
The current OF probing assumes that the resource is IORESOURCE_MEM. This checks for the IORESOURCE_IO flag and behaves appropriately. An I/O resource can exist with an ipmi device node on a legacy ISA bus. Signed-off-by: Nate Case <ncase@xes-inc.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14pnp: add ISAPnP MPU option quirksRene Herman
The AD181x and AZT230 chips don't support an IRQ-less MPU401 option but work fine without one. This adds (priority functional) IRQ-less options for each port option to help systems with few available IRQs. The AD1815 quirk can't use pnp_register_irq_resource() due to doubly penalizing the IRQ. Also, while not a practical issue due to no IRQ option being present for the dependents, this needs to add in front, not back. Doesn't use pnp_register_port_resource() for symetry with above. This does not delete the AD1815 independent option even though it should be empty after the IRQ transfer due to AD1816 coming with an empty but still present independent option by default. Was tested on AD1815, AD1816 and AZT2320. The ALSA snd-ad1818a driver also support the AZT2002 ID for MPU401 but this doesn't as I was unable to test it. Signed-off-by: Rene Herman <rene.herman@gmail.com> Tested-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Len Brown <len.brown@intel.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14pnp: add pnp_build_option() to the APIRene Herman
The subsequent AD181x quirk patch would like this as part of the API. pnp_register_dependent_option() adds to the same dependent chain the quirk is walking which is fairly unclean. This enables a private option chain build which it can then just add onto the end when done. Signed-off-by: Rene Herman <rene.herman@gmail.com> Tested-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Len Brown <len.brown@intel.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14pnp: clean up pnp_fixup_device()Rene Herman
Make it look a bit more like pci_fixup_device/pci_do_fixups. Also print the PnP ID and delete the () from the "foo+0x0/0x1234()". Signed-off-by: Rene Herman <rene.herman@gmail.com> Tested-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Len Brown <len.brown@intel.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14fix "lxfb: extend PLL table to support dotclocks below 25 MHz"Jens Rottmann
The following patch caused a regression with OLPC panels: commit 3888d4639e78802c4ec1086127124e890461b9e4 lxfb: extend PLL table to support dotclocks below 25 MHz Extends the PLL frequency table of the AMD Geode-LX frame buffer driver to make use of the DIV4 bit, thus adding support for dotclocks between 6 and 25 MHz. These are needed for small LCDs (e.g. 320x240). Also inserts some intermediate steps between pre-existing frequencies. The problem was the insertion of intermediate steps into the frequency table; they would cause the wrong frequency to be matched. This patch drops those intermediate frequencies while keeping the sub-25MHz frequencies. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Jens Rottmann <JRottmann@LiPPERT-AT.de> Tested-by: Andres Salomon <dilinger@debian.org> Acked-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14oprofile: don't request cache line alignment for cpu_bufferEric Dumazet
Alignment was previously requested because cpu_buffer was an [NR_CPUS] array, to avoid cache line sharing between CPUS. After commit 608dfddd845da5ab6accef70154c8910529699f7 (oprofile: change cpu_buffer from array to per_cpu variable ), we dont need to force an alignement anymore since cpu_buffer sits in per_cpu zone. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Mike Travis <travis@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14m68knommu: add info about removing mcfserialSebastian Siewior
Schedule a removal for this driver. Alternative driver is available for a while now. Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14mpc5200_psc_spi: typo fix in header blockGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: cs5520: disable VDMA ide/Kconfig: couple of fixes alim15x3: remove WDC_ALI15X3 config option alim15x3: add "wdc_udma" module parameter alim15x3: remove stale warning about ATI RS100 northbridge alim15x3: trivial cleanup for ali_set_pio_mode() make ide-iops.c:SELECT_MASK() static SWARM IDE: Fix up following changes to ide_hwif_t
2008-05-14cs5520: disable VDMABartlomiej Zolnierkiewicz
Disable Virtual DMA support for now (it causes system hangs). Thanks to TAKADA Yoshihito for the help with debugging the problem. Reported-by: TAKADA Yoshihito <takada@mbf.nifty.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-05-14ide/Kconfig: couple of fixesBartlomiej Zolnierkiewicz
* Don't ask to enable no longer existing config options ("Use DMA by default when available" and "Special UDMA Feature"). * PIIX host driver doesn't support Victory66 chipset. * "ide0=cmd640_vlb" -> "cmd640.probe_vlb" * "ide=doubler" -> "gayle.doubler" * Amiga IDE doubler support is a feature for gayle host driver not a separate host driver. * Remove Andre's mail. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-05-14alim15x3: remove WDC_ALI15X3 config optionBartlomiej Zolnierkiewicz
There is "wdc_udma" module parameter now. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-05-14alim15x3: add "wdc_udma" module parameterBartlomiej Zolnierkiewicz
Add "wdc_udma" module parameter for allowing UDMA transfers on M1543C-E chipset for WDC disks. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-05-14alim15x3: remove stale warning about ATI RS100 northbridgeBartlomiej Zolnierkiewicz
2008-05-14alim15x3: trivial cleanup for ali_set_pio_mode()Bartlomiej Zolnierkiewicz
Remove commented out code and stale comment. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-05-14make ide-iops.c:SELECT_MASK() staticAdrian Bunk
SELECT_MASK() can now become static. [bart: remove space between function name and open parenthesis] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-05-14SWARM IDE: Fix up following changes to ide_hwif_tMaciej W. Rozycki
Following recent changes to ide_hwif_t update the SWARM IDE driver to use hw_regs_t to initialize port mapping. Plus minor layout adjustments along the lines of other drivers. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-05-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/cxgb3: Wrap the software send queue pointer as needed on flush IB/ipath: Change ipath_devdata.ipath_sdma_status to be unsigned long IB/ipath: Make ipath_portdata work with struct pid * not pid_t IB/ipath: Fix RDMA read response sequence checking IB/ipath: Fix many locking issues when switching to error state IB/ipath: Fix RC and UC error handling RDMA/nes: Fix up nes_lro_max_aggr module parameter
2008-05-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (70 commits) V4L/DVB (7900): pvrusb: Fix Kconfig if DVB=m V4L_core=y V4L/DVB (7899): Fixes a few remaining Kbuild issues at common/tuners V4L/DVB (7898): Fix VIDEO_MEDIA Kconfig logic V4L/DVB (7895): tveeprom: update Hauppauge analog audio and video decoders V4L/DVB (7893): xc5000: bug-fix: allow multiple devices in a single system V4L/DVB (7891): cx18/ivtv: fix open() kernel oops V4L/DVB (7890): cx18: removed bogus and confusing conditional V4L/DVB (7889): cx18: improve HVR-1600 detection. V4L/DVB (7888): cx18: minor card definition updates. V4L/DVB (7887): cx18: fix Compro H900 analog support. V4L/DVB (7881): saa7134: fixed a compile warning in saa7134-core.c V4L/DVB (7880): saa7134: remove explicit GPIO initialization V4L/DVB(7879): Adding cx18 Support for mxl5005s V4L/DVB(7878): mxl55005s: Makefile and Kconfig additions V4L/DVB(7877): mxl5005s: Ensure debug is off V4L/DVB(7876): mxl5005s: Remove incorrect copyright holders V4L/DVB(7875): mxl5005s: Remove redundant functions V4L/DVB(7874): mxl5005s: Fix function statics V4L/DVB(7873): mxl5005s: Fix header includes. V4L/DVB(7872): mxl5005s: checkpatch.pl compliance ...
2008-05-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: Driver core: struct class remove children list block: do_mounts - accept root=<non-existant partition>
2008-05-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (22 commits) USB: atmel_usba_udc fixes, mostly disconnect() USB: pxa27x_udc: minor fixes usbtest: comment on why this code "expects" negative and positive errnos USB: remove PICDEM FS USB demo (04d8:000c) device from ldusb USB: option: add new Dell 5520 HSDPA variant USB: unusual_devs: Add support for GI 0401 SD-Card interface USB: serial gadget: descriptor cleanup USB: serial gadget: simplify endpoint handling USB: serial gadget: remove needless data structure USB: serial gadget: cleanup/reorg usb: fix compile warning in isp1760 USB: do not handle device 1410:5010 in 'option' driver USB: Fix unusual_devs.h ordering USB: add Zoom Telephonics Model 3095F V.92 USB Mini External modem to cdc-acm USB: Support for the ET502HS HDSPA modem in option driver USB: Support for the ET502HS HDSPA modem usb: fix integer as NULL pointer warnings found by sparse USB: isp1760: fix printk format USB: add Telstra NextG CDMA id to option driver USB: add association.h ...
2008-05-14Driver core: struct class remove children listDave Young
because of the class_device was removed, now do the children list removing Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (73 commits) net: Fix typo in net/core/sock.c. ppp: Do not free not yet unregistered net device. netfilter: xt_iprange: module aliases for xt_iprange netfilter: ctnetlink: dump conntrack ID in event messages irda: Fix a misalign access issue. (v2) sctp: Fix use of uninitialized pointer cipso: Relax too much careful cipso hash function. tcp FRTO: work-around inorder receivers tcp FRTO: Fix fallback to conventional recovery New maintainer for Intel ethernet adapters DM9000: Use delayed work to update MII PHY state DM9000: Update and fix driver debugging messages DM9000: Add __devinit and __devexit attributes to probe and remove sky2: fix simple define thinko [netdrvr] sfc: sfc: Add self-test support [netdrvr] sfc: Increment rx_reset when reported as driver event [netdrvr] sfc: Remove unused macro EFX_XAUI_RETRAIN_MAX [netdrvr] sfc: Fix code formatting [netdrvr] sfc: Remove kernel-doc comments for removed members of struct efx_nic [netdrvr] sfc: Remove garbage from comment ...
2008-05-14USB: atmel_usba_udc fixes, mostly disconnect()David Brownell
Various fixes to Atmel's high speed UDC driver. * Issue some missing disconnect() calls. Currently they are only made when VBUS power goes away (on boards where the driver can sense such changes), but that's not enough for gadget drivers to clean out all the state that's needed. Missing calls were: - After USB reset, before starting enumeration. - When unregistering a gadget driver, before unbind(). * Don't assume gadget drivers provide disconnect callbacks; make sure to not call through a null pointer! * When the driver doesn't provide an unbind() callback, refuse to unregister it. Also remove two bogus "error" messages: * Related to mis-handling of disconnect() ... don't emit error messages for disconnect() handlers that disable endpoints. All of them should be doing that; the problem is (unfixed) oddness in atmel_usba_udc. * Don't emit a diagnostic for a curious and transient nonfatal error that shows up sometimes with EP0. Those messages spammed syslog, for no good reason. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14USB: pxa27x_udc: minor fixesRobert Jarzmik
Minor fixes to pxa27x udc driver : - don't clobber driver model bus_id field - wrong endianess fix (no functional change; cpu is little-endian) - double udc disable fix - resume/suspend fix (OTG hold bit) - make driver pxa27x dependant (check cpu at runtime) Signed-off-by: Robert Jarzmik <rjarzmik@free.fr> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14usbtest: comment on why this code "expects" negative and positive errnosMarcin Slusarz
On Mon, May 12, 2008 at 01:02:22AM -0700, David Brownell wrote: > On Sunday 11 May 2008, Marcin Slusarz wrote: > > > > test_ctrl_queue expects (?) positive and negative errnos. > > what is going on here? > > The sign is just a way to flag something: > > /* some faults are allowed, not required */ > > The negative ones are required. Positive codes are optional, > in the sense that, depending on how the peripheral happens > to be implemented, they won't necessarily be triggered. > > For example, the test to fetch a device qualifier desriptor > must succeed if the device is running at high speed. So that > test is marked as negative. But when it's full speed, it > could legitimately fail; marked as positive. And so on for > other tests. > > Look at how the codes are *interpreted* to see it work. Lets document it. Based on comment from David Brownell <david-b@pacbell.net>. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14USB: remove PICDEM FS USB demo (04d8:000c) device from ldusbXiaofan Chen
Microchip has changed the PICDEM FS USB demo device (0x04d8:000c) to use bulk transfer and not interrupt transfer. So I've updated the libusb based program here (Post #31). http://forum.microchip.com/tm.aspx?m=106426&mpage=2 So I believe that the in-kernel ldusb driver will no longer work with the demo firmware. It should be removed. Signed-off-by: Xiaofan Chen <xiaofanc@gmail.com> Cc: Michael Hund <MHund@LD-Didactic.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14USB: option: add new Dell 5520 HSDPA variantDan Williams
New variant of the 5520 found by Luke Sheldrick. Signed-off-by: Dan Williams <dcbw@redhat.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14USB: unusual_devs: Add support for GI 0401 SD-Card interfaceFilip Aben
Enables the SD-Card interface on the GI 0401 HSUPA card from Option. The unusual_devs.h entry is necessary because the device descriptor is vendor-specific. That prevents usb-storage from binding to it as an interface driver. This revised patch adds a small comment explaining why and reduces the rev range. T: Bus=02 Lev=01 Prnt=01 Port=06 Cnt=01 Dev#= 3 Spd=480 MxCh= 0 D: Ver= 2.00 Cls=ff(vend.) Sub=ff Prot=ff MxPS=64 #Cfgs= 1 P: Vendor=0af0 ProdID=7401 Rev= 0.00 S: Manufacturer=Option N.V. S: Product=Globetrotter HSUPA Modem C:* #Ifs=10 Cfg#= 1 Atr=80 MxPwr=500mA I:* If#= 0 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) I: If#= 0 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 1 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) I: If#= 1 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 2 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) I: If#= 2 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 3 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) I: If#= 3 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 4 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) I: If#= 4 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 5 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) I: If#= 5 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 6 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) I: If#= 6 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=07(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 7 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) I: If#= 7 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=88(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=08(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 8 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=89(I) Atr=03(Int.) MxPS= 64 Ivl=2ms E: Ad=8a(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=09(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 9 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage E: Ad=0a(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=8b(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms Signed-off-by: Filip Aben <f.aben@option.com> Signed-off-by: Phil Dibowitz <phil@ipom.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14USB: serial gadget: descriptor cleanupDavid Brownell
Bugfix some serial gadget descriptors: - Stop mangling the low bits (controller type ID) of bcdDevice; just use the high bits for a driver revision code. - Serial numbers that aren't specific to individual devices are useless; stop reporting "0" for this. - Since it's not part of a CDC-conformant function, the "bulk only" configuration shouldn't be using "CDC Data" as its interface class. Switch over to using CLASS_VENDOR_SPEC (different value, 0xff). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Al Borchers <alborchers@steinerpoint.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
