path: root/drivers
2007-02-03[libata] use kmap_atomic(KM_IRQ0) in SCSI simulatorJeff Garzik
We are inside spin_lock_irqsave(). quoth akpm's debug facility: [ 231.948000] SCSI device sda: 195371568 512-byte hdwr sectors (100030 MB) [ 232.232000] ata1.00: configured for UDMA/33 [ 232.404000] WARNING (1) at arch/i386/mm/highmem.c:47 kmap_atomic() [ 232.404000] [<c01162e6>] kmap_atomic+0xa9/0x1ab [ 232.404000] [<c0242c81>] ata_scsi_rbuf_get+0x1c/0x30 [ 232.404000] [<c0242caf>] ata_scsi_rbuf_fill+0x1a/0x87 [ 232.404000] [<c0243ab2>] ata_scsiop_mode_sense+0x0/0x309 [ 232.404000] [<c01729d5>] end_bio_bh_io_sync+0x0/0x37 [ 232.404000] [<c02311c6>] scsi_done+0x0/0x16 [ 232.404000] [<c02311c6>] scsi_done+0x0/0x16 [ 232.404000] [<c0242dcc>] ata_scsi_simulate+0xb0/0x13f [...] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03hwmon: Update Rudolf Marek's e-mail addressRudolf Marek
The Silicon Hill club is not what it used to be. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03k8temp: Documentation updateRudolf Marek
Update the documentation for the k8temp driver. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03Make 'repair' actually work for raid1.Neil Brown
When 'repair' finds a block that is different one the various parts of the mirror. it is meant to write a chosen good version to the others. However it currently writes out the original data to each. The memcpy to make all the data the same is missing. Also correct a test so that 'repair' causes a repair, rather than anything other then 'repair'. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-30hwmon: New driver k8tempRudolf Marek
Add support for the temperature sensor(s) found in AMD K8 CPUs. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-30[SCSI] arcmsr: fix up sysfs valuesJames Bottomley
The sysfs files in arcmsr are non-standard in that they aren't simple filename value pairs, the values actually contain preceeding text which would have to be parsed. The idea of sysfs files is that the file name is the description and the contents is a simple value. Fix up arcmsr to conform to this standard. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-30[SCSI] areca sysfs fixAndrew Morton
Remove sysfs_remove_bin_file() return-value checking from the areca driver. There's nothing a driver can do if sysfs file removal fails, so we'll soon be changing sysfs_remove_bin_file() to internally print a diagnostic and to return void. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-30[SCSI] arcmsr: initial driver, version 1.20.00.13Erich Chen
arcmsr is a driver for the Areca Raid controller, a host based RAID subsystem that speaks SCSI at the firmware level. This patch is quite a clean up over the initial submission with contributions from: Randy Dunlap <rdunlap@xenotime.net> Christoph Hellwig <hch@lst.de> Matthew Wilcox <matthew@wil.cx> Adrian Bunk <bunk@stusta.de> Signed-off-by: Erich Chen <erich@areca.com.tw> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-25V4L/DVB: Missing statement in drivers/media/dvb/frontends/cx22700.cEric Sesterhenn
Stumbled over this because of coverity (id #492), seems like we are missing a return statement here and fail to do proper bounds checking. If this assumption is false we should at least change the identation to make it clear Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-24V4L/DVB: Flexcop-usb: fix debug printkAlexey Dobriyan
.. fix debug printk. Why, oh why, one would want to do (u16 & 0xff) << 8 and print it with %02x format? Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-24V4L/DVB: Fix uninitialised variable in dvb_frontend_swzigzagAndrew de Quincey
Spotted by coverity/Adrian Bunk. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-23read_zero_pagealigned() locking fixHugh Dickins
Ramiro Voicu hits the BUG_ON(!pte_none(*pte)) in zeromap_pte_range: kernel bugzilla 7645. Right: read_zero_pagealigned uses down_read of mmap_sem, but another thread's racing read of /dev/zero, or a normal fault, can easily set that pte again, in between zap_page_range and zeromap_page_range getting there. It's been wrong ever since 2.4.3. The simple fix is to use down_write instead, but that would serialize reads of /dev/zero more than at present: perhaps some app would be badly affected. So instead let zeromap_page_range return the error instead of BUG_ON, and read_zero_pagealigned break to the slower clear_user loop in that case - there's no need to optimize for it. Use -EEXIST for when a pte is found: BUG_ON in mmap_zero (the other user of zeromap_page_range), though it really isn't interesting there. And since mmap_zero wants -EAGAIN for out-of-memory, the zeromaps better return that than -ENOMEM. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-22atiixp: hang fixAlan Cox
When the old IDE layer calls into methods in the driver during error handling it is essentially random whether ide_lock is already held. This causes a deadlock in the atiixp driver which also uses ide_lock internally for locking. Switch to a private lock instead. [akpm@osl.org: cleanup] Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-22cdrom: set default timeout to 7 secondsJens Axboe
It's a known fact that Windows times out commands after 7 seconds, so drives generally try and respond if they can before that happens. We default to 5 seconds, which sometimes is a bit too short. Jeremy Higdon reported here: http://lkml.org/lkml/2007/1/1/145 that his drive takes longer than 5 seconds for a "read track information" command, later confirming that it is about 6.7 seconds. So just do the sane thing and change the default command timeout to 7 seconds to avoid other surprises. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-22[SCSI] qla1280 bus reset typoJes Sorensen
Fix typo in check of return value of qla1280_bus_reset() which would result in an adapter reset in addition to the bus reset. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-22[SCSI] qla1280 command timeoutJes Sorensen
Original patch from Ian Dall in bugzilla. Set command timeout as specified by the SCSI layer rather than hardcode it to 30 seconds. I have received a couple of reports of people hitting this one with various tape configurations and the patch looks obviously correct. From http://bugzilla.kernel.org/show_bug.cgi?id=6275 Ian Dall <ian@beware.dropbear.id.au>: The command sent to the card was using a 30second timeout regardless of the timeout requested in the scsi command passed down from higher levels. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09rtc: lockdep fix/workaroundPeter Zijlstra
BUG: warning at kernel/lockdep.c:1816/trace_hardirqs_on() (Not tainted) [<c04051ee>] show_trace_log_lvl+0x58/0x171 [<c0405802>] show_trace+0xd/0x10 [<c040591b>] dump_stack+0x19/0x1b [<c043abee>] trace_hardirqs_on+0xa2/0x11e [<c06143c3>] _spin_unlock_irq+0x22/0x26 [<c0541540>] rtc_get_rtc_time+0x32/0x176 [<c0419ba4>] hpet_rtc_interrupt+0x92/0x14d [<c0450f94>] handle_IRQ_event+0x20/0x4d [<c0451055>] __do_IRQ+0x94/0xef [<c040678d>] do_IRQ+0x9e/0xbd [<c0404a49>] common_interrupt+0x25/0x2c DWARF2 unwinder stuck at common_interrupt+0x25/0x2c Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09i2c-mv64xxx: Fix random oops at bootMaxime Bizon
I have a Marvell board which has the same i2c hw block than mv64xxx, so I'm trying to use i2c-mv64xxx driver. But I get the following random oops at boot: Unable to handle kernel NULL pointer dereference at virtual address 00000002 Backtrace: [<c0397e4c>] (mv64xxx_i2c_intr+0x0/0x2b8) from [<c02879c4>] (__do_irq+0x4c/0x8c) [<c0287978>] (__do_irq+0x0/0x8c) from [<c0287c0c>] (do_level_IRQ+0x68/0xc0) r8 = C0501E08 r7 = 00000005 r6 = C0501E08 r5 = 00000005 r4 = C048BB78 [<c0287ba4>] (do_level_IRQ+0x0/0xc0) from [<c02885f8>] (asm_do_IRQ+0x50/0x134) r6 = C0449C78 r5 = F1020000 r4 = FFFFFFFF [<c02885a8>] (asm_do_IRQ+0x0/0x134) from [<c02869c4>] (__irq_svc+0x24/0x100) r8 = C1CAC400 r7 = 00000005 r6 = 00000002 r5 = F1020000 r4 = FFFFFFFF [<c0287efc>] (setup_irq+0x0/0x124) from [<c02880d0>] (request_irq+0xb0/0xd0) r7 = C041B2AC r6 = C0397E4C r5 = 00000000 r4 = 00000005 [<c0288020>] (request_irq+0x0/0xd0) from [<c03985f4>] (mv64xxx_i2c_probe+0x148/0x244) [<c03984ac>] (mv64xxx_i2c_probe+0x0/0x244) from [<c038bedc>] (platform_drv_probe+0x20/0x24) The oops is caused by a spurious interrupt that occurs when request_irq is called. mv64xxx_i2c_fsm() tries to read drv_data->msg, which is NULL. I noticed that hardware init is done after requesting irq. Thus any pending irq from previous hardware usage may cause this. Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09V4L: cx88: Fix leadtek_eeprom taggingJean Delvare
reference to .init.text: from .text between 'cx88_card_setup' (at offset 0x68c) and 'cx88_risc_field' Caused by leadtek_eeprom() being declared __devinit and called from a non-devinit context. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-01-09USB_RTL8150 must select MII to avoid link errors.Adrian Bunk
Stolen from a patch by Randy Dunlap. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09rio: typo in bitwise AND expression.Willy Tarreau
The line: hp->Mode &= !RIO_PCI_INT_ENABLE; is obviously wrong as RIO_PCI_INT_ENABLE=0x04 and is used as a bitmask 2 lines before. Getting no IRQ would not disable RIO_PCI_INT_ENABLE but rather RIO_PCI_BOOT_FROM_RAM which equals 0x01. Obvious fix is to change ! for ~. Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09drm: allow detection of new VIA chipsetsChuck Short
Update pci ids. Signed-off-by: Chuck Short <zulcss@gmail.com> Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09drm: Add the P4VM800PRO PCI ID.Dave Airlie
Signed-off-by: Dave Airlie <airlied@linux.ie> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09i2c-i801: SMBus patch for Intel ICH9Jason Gaston
This updated patch adds the Intel ICH9 LPC and SMBus Controller DID's. Signed-off-by: Jason Gaston <jason.d.gaston@intel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09i2c-viapro: Add support for the VT8237A and VT8251Rudolf Marek
Documentation update included. Compile tested. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09SPI/MTD: mtd_dataflash oops preventionDavid Brownell
Return a fault code if the Dataflash driver runs into a "no device present" error when the MISO line has a pulldown (it currently expects a pullup), so that rmmod won't oops. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09USB: Fix alignment of buffer passed down to ->hub_control()Mikael Pettersson
Implementations assume the buffer is at least 4 byte aligned. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09[SUNKBD]: Fix sunkbd_enable(sunkbd, 0); obvious.Fabrice Knevez
"sunkbd_enable(sunkbd, 0);" has no effect. Adding "sunkbd->enabled = enable" in sunkbd_enable (obvious) Signed-off-by: Fabrice Knevez <nuxdoors@cegetel.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09ibmtr section fixesAndrew Morton
WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_mem_base from .text between 'ibmtr_probe1' (at offset 0x6e6) and 'ibmtr_probe_card' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_mem_base from .text between 'ibmtr_probe1' (at offset 0x74a) and 'ibmtr_probe_card' WARNING: drivers/net/tokenring/ibmtr.o - Section mismatch: reference to .init.data:ibmtr_mem_base from .text between 'ibmtr_probe1' (at offset 0x7fd) and 'ibmtr_probe_card' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-04Call init_timer() for ISDN PPP CCP reset state timer (CVE-2006-5749)Marcel Holtmann
The function isdn_ppp_ccp_reset_alloc_state() sets ->timer.function and ->timer.data and later on calls add_timer() with no init_timer() ever done. Noted by Al Viro. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-04i2c: fix broken ds1337 initializationDirk Eibach
On a custom board with ds1337 RTC I found that upgrade from 2.6.15 to 2.6.18 broke RTC support. The main problem are changes to ds1337_init_client(). When a ds1337 recognizes a problem (e.g. power or clock failure) bit 7 in status register is set. This has to be reset by writing 0 to status register. But since there are only 16 byte written to the chip and the first byte is interpreted as an address, the status register (which is the 16th) is never written. The other problem is, that initializing all registers to zero is not valid for day, date and month register. Funny enough this is checked by ds1337_detect(), which depends on this values not being zero. So then treated by ds1337_init_client() the ds1337 is not detected anymore, whereas the failure bit in the status register is still set. Broken by commit f9e8957937ebf60d22732a5ca9130f48a7603f60 (2.6.16-rc1, 2006-01-06). This fix is in Linus' tree since 2.6.20-rc1 (commit 763d9c046a2e511ec090a8986d3f85edf7448e7e). Signed-off-by: Dirk Stieler <stieler@gdsys.de> Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-18[SCSI] DAC960: PCI id table fixupBrian King
The PCI ID table in the DAC960 driver conflicts with some devices that use the ipr driver. All ipr adapters that use this chip have an IBM subvendor ID and all DAC960 adapters that use this chip have a Mylex subvendor id. Signed-off-by: Brian King <brking@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-18hvc_console suspend fixAndrew Morton
Fix http://bugzilla.kernel.org/show_bug.cgi?id=7152 Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-18[WATCHDOG] sc1200wdt.c pnp unregister fix.Akinobu Mita
If no devices found or invalid parameter is specified, scl200wdt_pnp_driver is left unregistered. It breaks global list of pnp drivers. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-18[WATCHDOG] sc1200wdt.c printk fixDave Jones
Fix printk output. sc1200wdt: build 20020303<3>sc1200wdt: io parameter must be specified Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-18ISDN: fix drivers, by handling errors thrown by ->readstat()Jeff Garzik
This is a particularly ugly on-failure bug, possibly security, since the lack of error handling here is covering up another class of bug: failure to handle copy_to_user() return values. The I4L API function ->readstat() returns an integer, and by looking at several existing driver implementations, it is clear that a negative return value was meant to indicate an error. Given that several drivers already return a negative value indicating an errno-style error, the current code would blindly accept that [negative] value as a valid amount of bytes read. Obvious damage ensues. Correcting ->readstat() handling to properly notice errors fixes the existing code to work correctly on error, and enables future patches to more easily indicate errors during operation. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-17r8169: tweak the PCI data parity error recoveryFrancois Romieu
The 8110SB based n2100 board signals a lot of what ought to be PCI data parity errors durint operation of the 8169 as target. Experiment proved that the driver can ignore the error and process the packet as if nothing had happened. Let's add an ad-hoc knob to enable users to fix their system while avoiding the risks of a wholesale change. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-17r8169: fix infinite loop during hotplugArnaud Patard
Bug reported for PCMCIA. Signed-off-by: Arnaud Patard <apatard@mandriva.com> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-17r8169: RX fifo overflow recoveryFrancois Romieu
2006-12-17scsi: clear garbage after CDBs on SG_IOTejun Heo
ATAPI devices transfer fixed number of bytes for CDBs (12 or 16). Some ATAPI devices choke when shorter CDB is used and the left bytes contain garbage. Block SG_IO cleared left bytes but SCSI SG_IO didn't. This patch makes SCSI SG_IO clear it and simplify CDB clearing in block SG_IO. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-15AGP: Allocate AGP pages with GFP_DMA32 by defaultLinus Torvalds
Not all graphic page remappers support physical addresses over the 4GB mark for remapping, so while some do (the AMD64 GART always did, and I just fixed the i965 to do so properly), we're safest off just forcing GFP_DMA32 allocations to make sure graphics pages get allocated in the low 32-bit address space by default. AGP sub-drivers that really care, and can do better, could just choose to implement their own allocator (or we could add another "64-bit safe" default allocator for their use), but quite frankly, you're not likely to care in practice. So for now, this trivial change means that we won't be allocating pages that we can't map correctly by mistake on x86-64. [ On traditional 32-bit x86, this could never happen, because GFP_KERNEL would never allocate any highmem memory anyway ] Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-15md: Fix md grow/size code to correctly find the maximum available spaceNeil Brown
An md array can be asked to change the amount of each device that it is using, and in particular can be asked to use the maximum available space. This currently only works if the first device is not larger than the rest. As 'size' gets changed and so 'fit' becomes wrong. So check if a 'fit' is required early and don't corrupt it. Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-15dm crypt: Fix data corruption with dm-crypt over RAID5Christophe Saout
Fix corruption issue with dm-crypt on top of software raid5. Cancelled readahead bio's that report no error, just have BIO_UPTODATE cleared were reported as successful reads to the higher layers (and leaving random content in the buffer cache). Already fixed in 2.6.19. Signed-off-by: Christophe Saout <christophe@saout.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-14IDE: Add the support of nvidia PATA controllers of MCP67 to amd74xx.cPeer Chen
Add support for PATA controllers of MCP67 to amd74xx.c. Signed-off-by: Peer Chen <pchen@nvidia.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-14amd74xx.c: add some NVIDIA chipset IDsRandy Dunlap
Add some nVidia chipset ID's support. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-14sata_nv/amd74xx: Add MCP61 supportAndrew Chew
Added MCP61 support to sata_nv and amd74xx. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-14[libata] sata_nv: add PCI IDsJeff Garzik
Based on a patch contributed by Andrew Chew @ NVIDIA. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-14dm snapshot: fix metadata writing when suspendingMark McLoughlin
When suspending a device-mapper device, dm_suspend() sleeps until all necessary I/O is completed. This state is triggered by a callback from persistent_commit(). But some I/O can still be issued *after* the callback (to prepare the next metadata area for use if the current one is full). This patch delays the callback until after that I/O is complete. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-14dm: Fix deadlock under high i/o load in raid1 setup.Daniel Kobras
On an nForce4-equipped machine with two SATA disk in raid1 setup using dmraid, we experienced frequent deadlock of the system under high i/o load. 'cat /dev/zero > ~/zero' was the most reliable way to reproduce them: Randomly after a few GB, 'cp' would be left in 'D' state along with kjournald and kmirrord. The functions cp and kjournald were blocked in did vary, but kmirrord's wchan always pointed to 'mempool_alloc()'. We've seen this pattern on 2.6.15 and 2.6.17 kernels. http://lkml.org/lkml/2005/4/20/142 indicates that this problem has been around even before. So much for the facts, here's my interpretation: mempool_alloc() first tries to atomically allocate the requested memory, or falls back to hand out preallocated chunks from the mempool. If both fail, it puts the calling process (kmirrord in this case) on a private waitqueue until somebody refills the pool. Where the only 'somebody' is kmirrord itself, so we have a deadlock. I worked around this problem by falling back to a (blocking) kmalloc when before kmirrord would have ended up on the waitqueue. This defeats part of the benefits of using the mempool, but at least keeps the system running. And it could be done with a two-line change. Note that mempool_alloc() clears the GFP_NOIO flag internally, and only uses it to decide whether to wait or return an error if immediate allocation fails, so the attached patch doesn't change behaviour in the non-deadlocking case. Path is against current git (2.6.18-rc4), but should apply to earlier versions as well. I've tested on 2.6.15, where this patch makes the difference between random lockup and a stable system. Signed-off-by: Daniel Kobras <kobras@linux.de> Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-14dm: mirror sector offset fixNeil Brown
The device-mapper core does not perform any remapping of bios before passing them to the targets. If a particular mapping begins part-way into a device, targets obtain the sector relative to the start of the mapping by subtracting ti->begin. The dm-raid1 target didn't do this everywhere: this patch fixes it, taking care to subtract ti->begin exactly once for each bio. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
