commit a9c3f68f3cd8d55f809fbdb0c138ed061ea1bd25 upstream.
The user-settable knob, low_latency, has been the source of
several BUG reports which stem from flush_to_ldisc() running
in interrupt context. Since 3.12, which added several sleeping
locks (termios_rwsem and buf->lock) to the input processing path,
the frequency of these BUG reports has increased.
Note that changes in 3.12 did not introduce this regression;
sleeping locks were first added to the input processing path
with the removal of the BKL from N_TTY in commit
a88a69c91256418c5907c2f1f8a0ec0a36f9e6cc,
'n_tty: Fix loss of echoed characters and remove bkl from n_tty'
and later in commit 38db89799bdf11625a831c5af33938dcb11908b6,
'tty: throttling race fix'. Since those changes, executing
flush_to_ldisc() in interrupt_context (ie, low_latency set), is unsafe.
However, since most devices do not validate if the low_latency
setting is appropriate for the context (process or interrupt) in
which they receive data, some reports are due to misconfiguration.
Further, serial dma devices for which dma fails, resort to
interrupt receiving as a backup without resetting low_latency.
Historically, low_latency was used to force wake-up the reading
process rather than wait for the next scheduler tick. The
effect was to trim multiple milliseconds of latency from
when the process would receive new data.
Recent tests [1] have shown that the reading process now receives
data with only 10's of microseconds latency without low_latency set.
Remove the low_latency rx steering from tty_flip_buffer_push();
however, leave the knob as an optional hint to drivers that can
tune their rx fifos and such like. Cleanup stale code comments
regarding low_latency.
[1] https://lkml.org/lkml/2014/2/20/434
"Yay.. thats an annoying historical pain in the butt gone."
-- Alan Cox
Reported-by: Beat Bolli <bbolli@ewanet.ch>
Reported-by: Pavel Roskin <proski@gnu.org>
Acked-by: David Sterba <dsterba@suse.cz>
Cc: Grant Edwards <grant.b.edwards@gmail.com>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: Hal Murray <murray+fedora@ip-64-139-1-69.sjc.megapath.net>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit 723abd87f6e536f1353c8f64f621520bc29523a3 upstream.
The 'active' sysfs attribute should refer to the currently active tty
devices the console is running on, not the currently active console. The
console structure doesn't refer to any device in sysfs, only the tty the
console is running on has. So we need to print out the tty names in
'active', not the console names.
There is one special-case, which is tty0. If the console is directed to
it, we want 'tty0' to show up in the file, so user-space knows that the
messages get forwarded to the active VT. The ->device() callback would
resolve tty0, though. Hence, treat it special and don't call into the VT
layer to resolve it (plymouth is known to depend on it).
Cc: Lennart Poettering <lennart@poettering.net>
Cc: Kay Sievers <kay@vrfy.org>
Cc: Jiri Slaby <jslaby@suse.cz>
Signed-off-by: Werner Fink <werner@suse.de>
Signed-off-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
commit 268d1e799663b795cba15c64f5d29407786a9dd4 upstream.
According to National Instruments' PCI-DIO-96/PXI-6508/PCI-6503 User
Manual, the physical address in PCI BAR1 needs to be OR'ed with 0x80 and
written to register offset 0xC0 in the "MITE" registers (BAR0). Do so
during initialization of the National Instruments boards handled by the
"8255_pci" driver. The boards were previously handled by the
"ni_pcidio" driver, where the initialization was done by `mite_setup()`
in the "mite" module. The "mite" module comes with too much extra
baggage for the "8255_pci" driver to deal with so use a local, simpler
initialization function.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit 0bf6368ee8f25826d0645c0f7a4f17c8845356a4 upstream.
Commit 1696d9d (ACPI: Remove the old /proc/acpi/event interface)
removed ACPI Button event which originally was sent to userspace via
/proc/acpi/event. This caused ACPI shutdown regression on gentoo
in VirtualBox. Now ACPI events are sent to userspace via netlink,
so add ACPI Button event back via netlink routine.
References: https://bugzilla.kernel.org/show_bug.cgi?id=71721
Reported-and-tested-by: Richard Musil <richard.musil@gmail.com>
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
commit 017fcdc30cdae18c0946eef1ece1f14b4c7897ba upstream.
This patch corrects iATU programming for cfg1, io and mem viewport. Enable
ATU only after configuring it.
Signed-off-by: Mohit Kumar <mohit.kumar@st.com>
Signed-off-by: Ajay Khandelwal <ajay.khandelwal@st.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Jingoo Han <jg1.han@samsung.com>
commit dbffdd6862e67d60703f2df66c558bf448f81d6e upstream.
The Synopsys PCIe core provides one pair of 32-bit BARs (BAR 0 and BAR 1).
The BARs can be configured as follows:
- One 64-bit BAR: BARs 0 and 1 are combined to form a single 64-bit BAR
- Two 32-bit BARs: BARs 0 and 1 are two independent 32-bit BARs
This patch corrects 64-bit, non-prefetchable memory BAR configuration
implemented in dw driver.
Cc: Pratyush Anand <pratyush.anand@st.com>
Cc: Jingoo Han <jg1.han@samsung.com>
commit 5c551e624abba6782034edd5b9eb58ac6f146b38 upstream.
Some BIOSes change hardware based on the state of
a laptop's lid. If the lid is closed, the touchpad is
disabled and the checksum changes. Windows 8 no longer
aborts resume if the checksum has changed.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
[rjw: Use pr_crit() for the message and don't break the string]
commit 48e8ac2979920ffa39117e2d725afa3a749bfe8d upstream.
With recent changes it is possible for the timer handler to detect an
idle interface and not start the timer, but the thread to start an
operation at the same time. The thread will not start the timer in that
instance, resulting in the timer not running.
Instead, move all timer operations under the lock and start the timer in
the thread if it detect non-idle and the timer is not already running.
Moving under locks allows the last timeout to be set in both the thread
and the timer. 'Timer is not running' means that the timer is not
pending and smi_timeout() is not running. So we need a flag to detect
this correctly.
Also fix a few other timeout bugs: setting the last timeout when the
interrupt has to be disabled and the timer started, and setting the last
timeout in check_start_timer_thread possibly racing with the timer
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Signed-off-by: Bodo Stroesser <bstroesser@ts.fujitsu.com>
commit 1f74ef0f2d7d692fcd615621e0e734c3e7771413 upstream.
When adding or removing 100G from a balloon:
BUG: soft lockup - CPU#0 stuck for 22s! [vballoon:367]
We have a wait_event_interruptible(), but the condition is always true
(more ballooning to do) so we don't ever sleep. We also have a
wait_event() for the host to ack, but that is also always true as QEMU
is synchronous for balloon operations.
Reported-by: Gopesh Kumar Chaudhary <gopchaud@in.ibm.com>
Cc: stable@kernel.org
commit 9d0e8d8348d54d60005c6c938b87b94648005d1c upstream.
Update current channel selection logic to include F15h, M30h memory
controllers.
Refer F15 M30h BKDG D18F2x110[7:6] (DRAM Controller Select Low)
(Link:http://support.amd.com/TechDocs/49125_15h_Models_30h-3Fh_BKDG.pdf)
Signed-off-by: Aravind Gopalakrishnan <Aravind.Gopalakrishnan@amd.com>
Link: http://lkml.kernel.org/r/1390338216-3873-1-git-send-email-Aravind.Gopalakrishnan@amd.com
commit 3eba563e280101209bad27d40bfc83ddf1489234 upstream.
Address a regression caused by commit ad332c8a4533:
(ACPI / EC: Clear stale EC events on Samsung systems)
After the earlier patch, there was found to be a race condition on some
earlier Samsung systems (N150/N210/N220). The function acpi_ec_clear was
sometimes discarding a new EC event before its GPE was triggered by the
system. In the case of these systems, this meant that the "lid open"
event was not registered on resume if that was the cause of the wake,
leading to problems when attempting to close the lid to suspend again.
After testing on a number of Samsung systems, both those affected by the
previous EC bug and those affected by the race condition, it seemed that
the best course of action was to process rather than discard the events.
On Samsung systems which accumulate stale EC events, there does not seem
to be any adverse side-effects of running the associated _Q methods.
This patch adds an argument to the static function acpi_ec_sync_query so
that it may be used within the acpi_ec_clear loop in place of
acpi_ec_query_unlocked which was used previously.
With thanks to Stefan Biereigel for reporting the issue, and for all the
people who helped test the new patch on affected systems.
Fixes: ad332c8a4533 (ACPI / EC: Clear stale EC events on Samsung systems)
References: https://lkml.kernel.org/r/532FE3B2.9060808@biereigel-wb.de
References: https://bugzilla.kernel.org/show_bug.cgi?id=44161#c173
Reported-by: Stefan Biereigel <stefan@biereigel.de>
Signed-off-by: Kieran Clancy <clancy.kieran@gmail.com>
Tested-by: Stefan Biereigel <stefan@biereigel.de>
Tested-by: Dennis Jansen <dennis.jansen@web.de>
Tested-by: Nicolas Porcel <nicolasporcel06@gmail.com>
Tested-by: Maurizio D'Addona <mauritiusdadd@gmail.com>
Tested-by: Juan Manuel Cabo <juanmanuel.cabo@gmail.com>
Tested-by: Giannis Koutsou <giannis.koutsou@gmail.com>
Tested-by: Kieran Clancy <clancy.kieran@gmail.com>
Cc: 3.14+ <stable@vger.kernel.org> # 3.14+
commit b20a774495671f037e7160ea2ce8789af6b61533 upstream.
In commit da1e2046e5, the flow for enabling/disabling an Si errata
workaround (e1000_lv_jumbo_workaround_ich8lan) was changed to fix a problem
with iAMT connections dropping on interface down with jumbo frames set.
Part of this change was to move the function call disabling the workaround
to e1000e_down() from the e1000_setup_rctl() function. The mechanic for
disabling of this workaround involves writing several MAC and PHY registers
back to hardware defaults.
After this commit, when the driver is loaded with the cable out, the PHY
registers are not programmed with the correct default values. This causes
the device to be capable of transmitting packets, but is unable to recieve
them until this workaround is called.
The flow of e1000e's open code relies upon calling the above workaround to
expicitly program these registers either with jumbo frame appropriate settings
or h/w defaults on 82579 and newer hardware.
Fix this issue by adding logic to e1000_setup_rctl() that not only calls
e1000_lv_jumbo_workaround_ich8lan() when jumbo frames are set, to enable the
workaround, but also calls this function to explicitly disable the workaround
in the case that jumbo frames are not set.
Signed-off-by: Dave Ertman <davidx.m.ertman@intel.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
commit 1b31e9b76ef8c62291e698dfdb973499986a7f68 upstream.
Add Device ID of Intel BayTrail SMBus Controller.
Signed-off-by: Chew, Kean ho <kean.ho.chew@intel.com>
Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit 32e24930fb71c47a1366325b6f139e039cacaca4 upstream.
Fix atm_dbg to use normal pr_debug not dynamic_pr_debug
because dynamic_pr_debug may not be compiled in at all.
Tested-by: Krzysztof Mazur <krzysiek@podlesie.net>
commit e8d2d82d4a73f37b3270e4fd19ba83e48b589656 upstream.
This patch corrects the PASID format in the INVALIDATE_IOTLB_PAGES
command, which was caused by incorrect information in
the AMD IOMMU Architectural Specification v2.01 document.
Incorrect format:
cmd->data[0][16:23] = PASID[7:0]
cmd->data[1][16:27] = PASID[19:8]
Correct format:
cmd->data[0][16:23] = PASID[15:8]
cmd->data[1][16:23] = PASID[7:0]
However, this does not affect the IOMMUv2 hardware implementation,
and has been corrected since version 2.02 of the specification
(available through AMD NDA).
Signed-off-by: Jay Cornwall <jay.cornwall@amd.com>
Reviewed-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Signed-off-by: Joerg Roedel <joro@8bytes.org>
commit ef4e5e4a756ff077dbdbdb8481d0e3788a07c005 upstream.
This patch adds support for new Intel Bluetooth device.
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 2.01 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=8087 ProdID=0a2a Rev= 0.01
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 64 Ivl=1ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
Signed-off-by: Tedd Ho-Jeong An <tedd.an@intel.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit c321f7d7c87cdc623c87845f6378620573e57512 upstream.
Otherwise the device is not completely shut down.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit 08d2d00b291ed4eb91530050274e67a761c1901d upstream.
The loff_t type may be wider than phys_addr_t (e.g. on 32-bit systems).
Consequently, the file offset may be truncated in the assignment.
Currently, /dev/mem wraps around, which may cause applications to read
or write incorrect regions of memory by accident.
Let's follow POSIX file semantics here and return 0 when reading from
and -EFBIG when writing to an offset that cannot be represented by a
phys_addr_t.
Note that the conditional is optimized out by the compiler if loff_t
has the same size as phys_addr_t.
Signed-off-by: Petr Tesarik <ptesarik@suse.cz>
commit 8fc1e8c240aab968db658b2d8d079b4391207a36 upstream.
When brcm80211 firmware is not installed networking hangs.
A deadlock happens because we call ieee80211_unregister_hw()
from the .start callback of struct ieee80211_ops. When .start
is called we are under rtnl lock and ieee80211_unregister_hw()
tries to take it again.
Function call stack:
dev_change_flags()
__dev_change_flags()
__dev_open()
ASSERT_RTNL() <-- Assert rtnl lock
ops->ndo_open()
.ndo_open = ieee80211_open,
ieee80211_open()
ieee80211_do_open()
drv_start()
local->ops->start()
.start = brcms_ops_start,
brcms_ops_start()
brcms_remove()
rtnl_lock() <-- Here we deadlock
Introduced by:
commit 25b5632fb35ca61b8ae3eee235edcdc2883f7a5e
("brcmsmac: request firmware in .start() callback")
This patch fixes the bug by removing the call to brcms_remove()
and moves the brcms_request_fw() call to the top of the .start
callback to not initiate anything unless firmware is installed.
Signed-off-by: Emil Goode <emilgoode@gmail.com>
[ Upstream commit 7563487cbf865284dcd35e9ef5a95380da046737 ]
There are three buffer overflows addressed in this patch.
1) In isdnloop_fake_err() we add an 'E' to a 60 character string and
then copy it into a 60 character buffer. I have made the destination
buffer 64 characters and I'm changed the sprintf() to a snprintf().
2) In isdnloop_parse_cmd(), p points to a 6 characters into a 60
character buffer so we have 54 characters. The ->eazlist[] is 11
characters long. I have modified the code to return if the source
buffer is too long.
3) In isdnloop_command() the cbuf[] array was 60 characters long but the
max length of the string then can be up to 79 characters. I made the
cbuf array 80 characters long and changed the sprintf() to snprintf().
I also removed the temporary "dial" buffer and changed it to use "p"
directly.
Unfortunately, we pass the "cbuf" string from isdnloop_command() to
isdnloop_writecmd() which truncates anything over 60 characters to make
it fit in card->omsg[]. (It can accept values up to 255 characters so
long as there is a '\n' character every 60 characters). For now I have
just fixed the memory corruption bug and left the other problems in this
driver alone.
[ Upstream commit 77bc6bed7121936bb2e019a8c336075f4c8eef62 ]
Return -EINVAL unless all of user-given strings are correctly
NUL-terminated.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit 5933a7bbb5de66482ea8aa874a7ebaf8e67603c4 ]
If the vxlan interface is created without explicit group definition,
there are corner cases which may cause kernel panic.
For instance, in the following scenario:
node A:
$ ip link add dev vxlan42 address 2c:c2:60:00:10:20 type vxlan id 42
$ ip addr add dev vxlan42 10.0.0.1/24
$ ip link set up dev vxlan42
$ arp -i vxlan42 -s 10.0.0.2 2c:c2:60:00:01:02
$ bridge fdb add dev vxlan42 to 2c:c2:60:00:01:02 dst <IPv4 address>
$ ping 10.0.0.2
node B:
$ ip link add dev vxlan42 address 2c:c2:60:00:01:02 type vxlan id 42
$ ip addr add dev vxlan42 10.0.0.2/24
$ arp -i vxlan42 -s 10.0.0.1 2c:c2:60:00:10:20
node B crashes:
vxlan42: 2c:c2:60:00:10:20 migrated from 4011:eca4:c0a8:6466:c0a8:6415:8e09:2118 to (invalid address)
BUG: unable to handle kernel NULL pointer dereference at 0000000000000046
IP: [<ffffffff8143c459>] ip6_route_output+0x58/0x82
PGD 7bd89067 PUD 7bd4e067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in:
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.14.0-rc8-hvx-xen-00019-g97a5221-dirty #154
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
task: ffff88007c774f50 ti: ffff88007c79c000 task.ti: ffff88007c79c000
RIP: 0010:[<ffffffff8143c459>] [<ffffffff8143c459>] ip6_route_output+0x58/0x82
RSP: 0018:ffff88007fd03668 EFLAGS: 00010282
RAX: 0000000000000000 RBX: ffffffff8186a000 RCX: 0000000000000040
RDX: 0000000000000000 RSI: ffff88007b0e4a80 RDI: ffff88007fd03754
RBP: ffff88007fd03688 R08: ffff88007b0e4a80 R09: 0000000000000000
R10: 0200000a0100000a R11: 0001002200000000 R12: ffff88007fd03740
R13: ffff88007b0e4a80 R14: ffff88007b0e4a80 R15: ffff88007bba0c50
FS: 0000000000000000(0000) GS:ffff88007fd00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000046 CR3: 000000007bb60000 CR4: 00000000000006e0
Stack:
0000000000000000 ffff88007fd037a0 ffffffff8186a000 ffff88007fd03740
ffff88007fd036c8 ffffffff814320bb 0000000000006e49 ffff88007b8b7360
ffff88007bdbf200 ffff88007bcbc000 ffff88007b8b7000 ffff88007b8b7360
Call Trace:
<IRQ>
[<ffffffff814320bb>] ip6_dst_lookup_tail+0x2d/0xa4
[<ffffffff814322a5>] ip6_dst_lookup+0x10/0x12
[<ffffffff81323b4e>] vxlan_xmit_one+0x32a/0x68c
[<ffffffff814a325a>] ? _raw_spin_unlock_irqrestore+0x12/0x14
[<ffffffff8104c551>] ? lock_timer_base.isra.23+0x26/0x4b
[<ffffffff8132451a>] vxlan_xmit+0x66a/0x6a8
[<ffffffff8141a365>] ? ipt_do_table+0x35f/0x37e
[<ffffffff81204ba2>] ? selinux_ip_postroute+0x41/0x26e
[<ffffffff8139d0c1>] dev_hard_start_xmit+0x2ce/0x3ce
[<ffffffff8139d491>] __dev_queue_xmit+0x2d0/0x392
[<ffffffff813b380f>] ? eth_header+0x28/0xb5
[<ffffffff8139d569>] dev_queue_xmit+0xb/0xd
[<ffffffff813a5aa6>] neigh_resolve_output+0x134/0x152
[<ffffffff813db741>] ip_finish_output2+0x236/0x299
[<ffffffff813dc074>] ip_finish_output+0x98/0x9d
[<ffffffff813dc749>] ip_output+0x62/0x67
[<ffffffff813da9f2>] dst_output+0xf/0x11
[<ffffffff813dc11c>] ip_local_out+0x1b/0x1f
[<ffffffff813dcf1b>] ip_send_skb+0x11/0x37
[<ffffffff813dcf70>] ip_push_pending_frames+0x2f/0x33
[<ffffffff813ff732>] icmp_push_reply+0x106/0x115
[<ffffffff813ff9e4>] icmp_reply+0x142/0x164
[<ffffffff813ffb3b>] icmp_echo.part.16+0x46/0x48
[<ffffffff813c1d30>] ? nf_iterate+0x43/0x80
[<ffffffff813d8037>] ? xfrm4_policy_check.constprop.11+0x52/0x52
[<ffffffff813ffb62>] icmp_echo+0x25/0x27
[<ffffffff814005f7>] icmp_rcv+0x1d2/0x20a
[<ffffffff813d810d>] ip_local_deliver_finish+0xd6/0x14f
[<ffffffff813d7fde>] NF_HOOK.constprop.10+0x4c/0x53
[<ffffffff813d82bf>] ip_local_deliver+0x4a/0x4f
[<ffffffff813d7f7b>] ip_rcv_finish+0x253/0x26a
[<ffffffff813d7d28>] ? inet_add_protocol+0x3e/0x3e
[<ffffffff813d856a>] ip_rcv+0x2a6/0x2ec
[<ffffffff8139a9a0>] __netif_receive_skb_core+0x43e/0x478
[<ffffffff812a346f>] ? virtqueue_poll+0x16/0x27
[<ffffffff8139aa2f>] __netif_receive_skb+0x55/0x5a
[<ffffffff8139aaaa>] process_backlog+0x76/0x12f
[<ffffffff8139add8>] net_rx_action+0xa2/0x1ab
[<ffffffff81047847>] __do_softirq+0xca/0x1d1
[<ffffffff81047ace>] irq_exit+0x3e/0x85
[<ffffffff8100b98b>] do_IRQ+0xa9/0xc4
[<ffffffff814a37ad>] common_interrupt+0x6d/0x6d
<EOI>
[<ffffffff810378db>] ? native_safe_halt+0x6/0x8
[<ffffffff810110c7>] default_idle+0x9/0xd
[<ffffffff81011694>] arch_cpu_idle+0x13/0x1c
[<ffffffff8107480d>] cpu_startup_entry+0xbc/0x137
[<ffffffff8102e741>] start_secondary+0x1a0/0x1a5
Code: 24 14 e8 f1 e5 01 00 31 d2 a8 32 0f 95 c2 49 8b 44 24 2c 49 0b 44 24 24 74 05 83 ca 04 eb 1c 4d 85 ed 74 17 49 8b 85 a8 02 00 00 <66> 8b 40 46 66 c1 e8 07 83 e0 07 c1 e0 03 09 c2 4c 89 e6 48 89
RIP [<ffffffff8143c459>] ip6_route_output+0x58/0x82
RSP <ffff88007fd03668>
---[ end trace 4612329caab37efd ]---
When vxlan interface is created without explicit group definition, the
default_dst protocol family is initialiazed to AF_UNSPEC and the driver
assumes IPv4 configuration. On the other side, the default_dst protocol
family is used to differentiate between IPv4 and IPv6 cases and, since,
AF_UNSPEC != AF_INET, the processing takes the IPv6 path.
Making the IPv4 assumption explicit by settting default_dst protocol
family to AF_INET4 and preventing mixing of IPv4 and IPv6 addresses in
snooped fdb entries fixes the corner case crashes.
Signed-off-by: Mike Rapoport <mike.rapoport@ravellosystems.com>
[ Upstream commit e9d8b2c2968499c1f96563e6522c56958d5a1d0d ]
When netback discovers frontend is sending malformed packet it will
disables the interface which serves that frontend.
However disabling a network interface involving taking a mutex which
cannot be done in softirq context, so we need to defer this process to
kthread context.
This patch does the following:
1. introduce a flag to indicate the interface is disabled.
2. check that flag in TX path, don't do any work if it's true.
3. check that flag in RX path, turn off that interface if it's true.
The reason to disable it in RX path is because RX uses kthread. After
this change the behavior of netback is still consistent -- it won't do
any TX work for a rogue frontend, and the interface will be eventually
turned off.
Also change a "continue" to "break" after xenvif_fatal_tx_err, as it
doesn't make sense to continue processing packets if frontend is rogue.
This is a fix for XSA-90.
Reported-by: Török Edwin <edwin@etorok.net>
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Cc: Ian Campbell <ian.campbell@citrix.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
[ Upstream commit 0576eddf24df716d8570ef8ca11452a9f98eaab2 ]
This patch removes a test in start_new_rx_buffer() that checks whether
a copy operation is less than MAX_BUFFER_OFFSET in length, since
MAX_BUFFER_OFFSET is defined to be PAGE_SIZE and the only caller of
start_new_rx_buffer() already limits copy operations to PAGE_SIZE or less.
Signed-off-by: Paul Durrant <paul.durrant@citrix.com>
Cc: Wei Liu <wei.liu2@citrix.com>
Cc: Sander Eikelenboom <linux@eikelenboom.it>
Reported-By: Sander Eikelenboom <linux@eikelenboom.it>
Tested-By: Sander Eikelenboom <linux@eikelenboom.it>
[ Upstream commit a39ee449f96a2cd44ce056d8a0a112211a9b1a1f ]
vhost fails to validate negative error code
from vhost_get_vq_desc causing
a crash: we are using -EFAULT which is 0xfffffff2
as vector size, which exceeds the allocated size.
The code in question was introduced in commit
8dd014adfea6f173c1ef6378f7e5e7924866c923
vhost-net: mergeable buffers support
CVE-2014-0055
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit d8316f3991d207fe32881a9ac20241be8fa2bad0 ]
When mergeable buffers are disabled, and the
incoming packet is too large for the rx buffer,
get_rx_bufs returns success.
This was intentional in order for make recvmsg
truncate the packet and then handle_rx would
detect err != sock_len and drop it.
Unfortunately we pass the original sock_len to
recvmsg - which means we use parts of iov not fully
validated.
Fix this up by detecting this overrun and doing packet drop
immediately.
CVE-2014-0077
[ Upstream commit 14a0d635d18d0fb552dcc979d6d25106e6541f2e ]
This fixes a race which happens by freeing an object on the stack.
Quoting Julius:
> The issue is
> that it calls usbnet_terminate_urbs() before that, which temporarily
> installs a waitqueue in dev->wait in order to be able to wait on the
> tasklet to run and finish up some queues. The waiting itself looks
> okay, but the access to 'dev->wait' is totally unprotected and can
> race arbitrarily. I think in this case usbnet_bh() managed to succeed
> it's dev->wait check just before usbnet_terminate_urbs() sets it back
> to NULL. The latter then finishes and the waitqueue_t structure on its
> stack gets overwritten by other functions halfway through the
> wake_up() call in usbnet_bh().
The fix is to just not allocate the data structure on the stack.
As dev->wait is abused as a flag it also takes a runtime PM change
to fix this bug.
Reported-by: Grant Grundler <grundler@google.com>
Tested-by: Grant Grundler <grundler@google.com>
[ Upstream commit 51dfe7b944998eaeb2b34d314f3a6b16a5fd621b ]
Including hardware acceleration features in vlan_features breaks
stacked vlans (Q-in-Q) by marking the bottom vlan interface as
capable of acceleration. This causes one of the tags to be lost
and the packets are sent with a sing vlan header.
CC: Nithin Nayak Sujir <nsujir@broadcom.com>
CC: Michael Chan <mchan@broadcom.com>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit ebf4ad955d3e26d4d2a33709624fc7b5b9d3b969 ]
Few platforms use external regulator to keep the ethernet MAC supplied.
So, request and enable the regulator for driver functionality.
Fixes: 66fda75f47dc (regulator: core: Replace direct ops->disable usage)
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Suggested-by: Markus Pargmann <mpa@pengutronix.de>
Signed-off-by: Nishanth Menon <nm@ti.com>
[ Upstream commit 4b29dba9c085a4fb79058fb1c45a2f6257ca3dfa ]
The VXLAN neigh_reduce() code is completely non-functional since
check-in. Specific errors:
1) The original code drops all packets with a multicast destination address,
even though neighbor solicitations are sent to the solicited-node
address, a multicast address. The code after this check was never run.
2) The neighbor table lookup used the IPv6 header destination, which is the
solicited node address, rather than the target address from the
neighbor solicitation. So neighbor lookups would always fail if it
got this far. Also for L3MISSes.
3) The code calls ndisc_send_na(), which does a send on the tunnel device.
The context for neigh_reduce() is the transmit path, vxlan_xmit(),
where the host or a bridge-attached neighbor is trying to transmit
a neighbor solicitation. To respond to it, the tunnel endpoint needs
to do a *receive* of the appropriate neighbor advertisement. Doing a
send, would only try to send the advertisement, encapsulated, to the
remote destinations in the fdb -- hosts that definitely did not do the
corresponding solicitation.
4) The code uses the tunnel endpoint IPv6 forwarding flag to determine the
isrouter flag in the advertisement. This has nothing to do with whether
or not the target is a router, and generally won't be set since the
tunnel endpoint is bridging, not routing, traffic.
The patch below creates a proxy neighbor advertisement to respond to
neighbor solicitions as intended, providing proper IPv6 support for neighbor
reduction.
Signed-off-by: David L Stevens <dlstevens@us.ibm.com>
[ Upstream commit 7346135dcd3f9b57f30a5512094848c678d7143e ]
This patch fixes a NULL pointer dereference in the event of an
skb allocation failure in arp_reduce().
Signed-Off-By: David L Stevens <dlstevens@us.ibm.com>
Acked-by: Cong Wang <cwang@twopensource.com>
[ Upstream commit 84fe61821e4ebab6322eeae3f3c27f77f0031978 ]
If the Freescale fec is in promiscuous mode and network cable is
reconnected then the promiscuous mode get lost. The problem is caused
by a too soon call of set_multicast_list to re-enable promisc mode.
The FEC_R_CNTRL register changes are overwritten by fec_restart.
This patch fixes this by moving the call behind the init of FEC_R_CNTRL
register in fec_restart.
Successful tested on a i.MX28 board.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
[ Upstream commit fb00bc2e6cd2046282ba4b03f4fe682aee70b2f8 ]
The commit d3ab3ffd1d728d7ee77340e7e7e2c7cfe6a4013e
(bonding: use rlb_client_info->vlan_id instead of ->tag)
remove the rlb_client_info->tag, but occur some issues,
The vlan_get_tag() will return 0 for success and -EINVAL for
error, so the client_info->vlan_id always be set to 0 if the
vlan_get_tag return 0 for success, so the client_info would
never get a correct vlan id.
We should only set the vlan id to 0 when the vlan_get_tag return error.
Fixes: d3ab3ffd1d7 (bonding: use rlb_client_info->vlan_id instead of ->tag)
CC: Ding Tianhong <dingtianhong@huawei.com>
CC: Jay Vosburgh <fubar@us.ibm.com>
CC: Andy Gospodarek <andy@greyhouse.net>
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
Acked-by: Veaceslav Falico <vfalico@redhat.com>
[ Upstream commit a8d9bc2e9f5d1c5a25e33cec096d2a1652d3fd52 ]
The pci shutdown handler added in:
bnx2: Add pci shutdown handler
commit 25bfb1dd4ba3b2d9a49ce9d9b0cd7be1840e15ed
created a shutdown down sequence without chip reset if the device was
never brought up. This can cause the firmware to shutdown the PHY
prematurely and cause MMIO read cycles to be unresponsive. On some
systems, it may generate NMI in the bnx2's pci shutdown handler.
The fix is to tell the firmware not to shutdown the PHY if there was
no prior chip reset.
Signed-off-by: Michael Chan <mchan@broadcom.com>
commit 121a6a17439b000b9699c3fa876636db20fa4107 upstream.
Explicitly set 1024x768 as default mode, so the display doesn't come up
with the largest supported mode.
While being at it drop first three drm_add_modes_noedid calls. As
drm_add_modes_noedid fills the mode list with modes from the database
*up to* the specified size it is pretty pointless to call it multiple
times with different sizes.
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
commit 3cf70dafd7bbbc91df0a9ecb081d46f9f3d867f6 upstream.
New helper function to set the preferred video mode. Can be called
after drm_add_modes_noedid if you don't want the largest supported
video mode be used by default.
commit 13ba0ad4490c3dd08b15c430a7a01c6fb45d5bce upstream.
Calling this "conflicting" just makes people think there's a problem
when there's not.
Signed-off-by: Adam Jackson <ajax@redhat.com>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
commit 46eeb2c144956e88197439b5ee5cf221a91b0a81 upstream.
If we fail to remove a conflicting fb driver, we need to abort the
loading of the second driver to avoid likely kernel panics.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: linux-fbdev@vger.kernel.org
Cc: dri-devel@lists.freedesktop.org
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
commit 3a41c5dbe8bc396a7fb16ca8739e945bb003342e upstream.
Following commits:
50e244cc79 fb: rework locking to fix lock ordering on takeover
e93a9a8687 fb: Yet another band-aid for fixing lockdep mess
054430e773 fbcon: fix locking harder
reworked locking to fix related lock ordering on takeover, and introduced console_lock
into fbmem, but it seems that the new lock sequence(fb_info->lock ---> console_lock)
is against with the one in console_callback(console_lock ---> fb_info->lock), and leads to
a potential dead lock as following:
[ 601.079000] ======================================================
[ 601.079000] [ INFO: possible circular locking dependency detected ]
[ 601.079000] 3.11.0 #189 Not tainted
[ 601.079000] -------------------------------------------------------
[ 601.079000] kworker/0:3/619 is trying to acquire lock:
[ 601.079000] (&fb_info->lock){+.+.+.}, at: [<ffffffff81397566>] lock_fb_info+0x26/0x60
[ 601.079000]
but task is already holding lock:
[ 601.079000] (console_lock){+.+.+.}, at: [<ffffffff8141aae3>] console_callback+0x13/0x160
[ 601.079000]
which lock already depends on the new lock.
[ 601.079000]
the existing dependency chain (in reverse order) is:
[ 601.079000]
-> #1 (console_lock){+.+.+.}:
[ 601.079000] [<ffffffff810dc971>] lock_acquire+0xa1/0x140
[ 601.079000] [<ffffffff810c6267>] console_lock+0x77/0x80
[ 601.079000] [<ffffffff81399448>] register_framebuffer+0x1d8/0x320
[ 601.079000] [<ffffffff81cfb4c8>] efifb_probe+0x408/0x48f
[ 601.079000] [<ffffffff8144a963>] platform_drv_probe+0x43/0x80
[ 601.079000] [<ffffffff8144853b>] driver_probe_device+0x8b/0x390
[ 601.079000] [<ffffffff814488eb>] __driver_attach+0xab/0xb0
[ 601.079000] [<ffffffff814463bd>] bus_for_each_dev+0x5d/0xa0
[ 601.079000] [<ffffffff81447e6e>] driver_attach+0x1e/0x20
[ 601.079000] [<ffffffff81447a07>] bus_add_driver+0x117/0x290
[ 601.079000] [<ffffffff81448fea>] driver_register+0x7a/0x170
[ 601.079000] [<ffffffff8144a10a>] __platform_driver_register+0x4a/0x50
[ 601.079000] [<ffffffff8144a12d>] platform_driver_probe+0x1d/0xb0
[ 601.079000] [<ffffffff81cfb0a1>] efifb_init+0x273/0x292
[ 601.079000] [<ffffffff81002132>] do_one_initcall+0x102/0x1c0
[ 601.079000] [<ffffffff81cb80a6>] kernel_init_freeable+0x15d/0x1ef
[ 601.079000] [<ffffffff8166d2de>] kernel_init+0xe/0xf0
[ 601.079000] [<ffffffff816914ec>] ret_from_fork+0x7c/0xb0
[ 601.079000]
-> #0 (&fb_info->lock){+.+.+.}:
[ 601.079000] [<ffffffff810dc1d8>] __lock_acquire+0x1e18/0x1f10
[ 601.079000] [<ffffffff816835ca>] mutex_lock_nested+0x7a/0x3b0
[ 601.079000] [<ffffffff81397566>] lock_fb_info+0x26/0x60
[ 601.079000] [<ffffffff813a4aeb>] fbcon_blank+0x29b/0x2e0
[ 601.079000] [<ffffffff81418658>] do_blank_screen+0x1d8/0x280
[ 601.079000] [<ffffffff8141ab34>] console_callback+0x64/0x160
[ 601.079000] [<ffffffff8108d855>] process_one_work+0x1f5/0x540
[ 601.079000] [<ffffffff8108e04c>] worker_thread+0x11c/0x370
[ 601.079000] [<ffffffff81095fbd>] kthread+0xed/0x100
[ 601.079000]
[ 601.079000] Possible unsafe locking scenario:
[ 601.079000] CPU0 CPU1
[ 601.079000] ---- ----
[ 601.079000] lock(console_lock);
[ 601.079000] lock(&fb_info->lock);
[ 601.079000]
*** DEADLOCK ***
so we reorder the lock sequence the same as it in console_callback() to
avoid this issue. And following Tomi's suggestion, fix these similar
issues all in fb subsystem.
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
commit c683f427bdc43525f61e26609d34e799e7ea4c12 upstream.
Currently drm_pick_cmdline_mode() doesn't care about the interlace
when the given mode line has no "i" suffix. That is, when there are
multiple entries for the same resolution, an interlace mode might be
picked up just depending on the assigned order, and there is no way to
exclude it.
This patch changes the logic for the mode selection, to prefer the
noninterlace mode unless the interlace mode is explicitly given.
When no matching mode is found, it still tries the interlace mode as
fallback.
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 3803c8e5b50946dd6bc18972d9190757d05648f0 upstream.
Now that we disable audio while setting up the audio
hw, we should be able to set this up without hangs.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
commit 832eafaf34ff7d0348fe701e417900c6cf1f5656 upstream.
Disable audio around audio hw setup. This may avoid
hangs on certain asics.
commit 99d4a8ae93ead27b5a88cdbd09dc556fe96ac3a8 upstream.
Xorg fbdev driver requires smem_start/smem_len, otherwise
it tries to map 0 bytes as video memory.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=856760
Signed-off-by: Martin Koegler <martin.koegler@chello.at>
commit a4945f9522d27e1e6d64a02ad055e83768cb0896 upstream.
The PIPEA quirk is specifically for the issue with the PIPEB PLL on
830gm being slaved to the PIPEA PLL, and so to use PIPEB requires PIPEA
running. i845 doesn't even have the second PLL or pipe, and enabling
the quirk results in a blank DVO LVDS.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 7b7b68bba5ef23734c35ffb0d8d82079ed604d33 upstream.
In case reading of block 0 during open() fails, it is not the right thing
to let open() succeed.
Fix this by introducing FD_OPEN_SHOULD_FAIL_BIT flag, and setting it in
case the bio callback encounters an error while trying to read block 0.
As a bonus, this works around certain broken userspace (blkid), which is
not able to properly handle read()s returning IO errors. Hence be nice to
those, and bail out during open() already; if block 0 is not readable,
read()s are not going to provide any meaningful data anyway.
commit a94cdd1f4d30f12904ab528152731fb13a812a16 upstream.
In read_all_bytes, we do
unsigned char i;
bt->read_data[0] = BMC2HOST;
bt->read_count = bt->read_data[0];
for (i = 1; i <= bt->read_count; i++)
bt->read_data[i] = BMC2HOST;
If bt->read_data[0] == bt->read_count == 255, we loop infinitely in the
'for' loop. Make 'i' an 'int' instead of 'char' to get rid of the
overflow and finish the loop after 255 iterations every time.
Reported-and-debugged-by: Rui Hui Dian <rhdian@novell.com>
Cc: Tomas Cech <tcech@suse.cz>
Cc: Corey Minyard <minyard@acm.org>
Cc: <openipmi-developer@lists.sourceforge.net>
commit b42285f66f871a9898a0e79e2d74bc7e7a101995 upstream.
The clock passed to PCI controller found on MVEBU SoCs may come from a
clock gate. This requires the clock to be enabled before any registers
are accessed. Therefore, move the clock enable before register iomap to
ensure it is enabled.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit 22c73795b101597051924556dce019385a1e2fa0 upstream.
This patch reorders reported frequencies from the highest to the lowest,
just like in other frequency drivers.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
commit d82b922a4acc1781d368aceac2f9da43b038cab2 upstream.
The powernow-k6 driver used to read the initial multiplier from the
powernow register. However, there is a problem with this:
* If there was a frequency transition before, the multiplier read from the
register corresponds to the current multiplier.
* If there was no frequency transition since reset, the field in the
register always reads as zero, regardless of the current multiplier that
is set using switches on the mainboard and that the CPU is running at.
The zero value corresponds to multiplier 4.5, so as a consequence, the
powernow-k6 driver always assumes multiplier 4.5.
For example, if we have 550MHz CPU with bus frequency 100MHz and
multiplier 5.5, the powernow-k6 driver thinks that the multiplier is 4.5
and bus frequency is 122MHz. The powernow-k6 driver then sets the
multiplier to 4.5, underclocking the CPU to 450MHz, but reports the
current frequency as 550MHz.
There is no reliable way how to read the initial multiplier. I modified
the driver so that it contains a table of known frequencies (based on
parameters of existing CPUs and some common overclocking schemes) and sets
the multiplier according to the frequency. If the frequency is unknown
(because of unusual overclocking or underclocking), the user must supply
the bus speed and maximum multiplier as module parameters.
This patch should be backported to all stable kernels. If it doesn't
apply cleanly, change it, or ask me to change it.
commit e20e1d0ac02308e2211306fc67abcd0b2668fb8b upstream.
I found out that a system with k6-3+ processor is unstable during network
server load. The system locks up or the network card stops receiving. The
reason for the instability is the CPU frequency scaling.
During frequency transition the processor is in "EPM Stop Grant" state.
The documentation says that the processor doesn't respond to inquiry
requests in this state. Consequently, coherency of processor caches and
bus master devices is not maintained, causing the system instability.
This patch flushes the cache during frequency transition. It fixes the
instability.
Other minor changes:
* u64 invalue changed to unsigned long because the variable is 32-bit
* move the logic to set the multiplier to a separate function
powernow_k6_set_cpu_multiplier
* preserve lower 5 bits of the powernow port instead of 4 (the voltage
field has 5 bits)
* mask interrupts when reading the multiplier, so that the port is not
open during other activity (running other kernel code with the port open
shouldn't cause any misbehavior, but we should better be safe and keep
the port closed)
