commit 822bfa51ce44f2c63c300fdb76dc99c4d5a5ca9f upstream.
"nframes" comes from the user and "nframes * CD_FRAMESIZE_RAW" can wrap
on 32 bit systems. That would have been ok if we used the same wrapped
value for the copy, but we use a shifted value. We should just use the
checked version of copy_to_user() because it's not going to make a
difference to the speed.
commit c1c1a3d012fe5e82a9a025fb4b5a4f8ee67a53f6 upstream.
By hwmon sysfs interface convention, setting pwm_enable to zero sets a fan
to full speed. In the f75375s driver, this need be done by enabling
manual fan control, plus duty mode for the F875387 chip, and then setting
the maximum duty cycle. Fix a bug where the two necessary register writes
were swapped, effectively discarding the setting to full-speed.
Signed-off-by: Nikolaus Schulz <mail@microschulz.de>
Cc: Riku Voipio <riku.voipio@iki.fi>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit afa159538af61f1a65d48927f4e949fe514fb4fc upstream.
status has to be set to STREAMING before the streaming worker is
queued. hdpvr_transmit_buffers() will exit immediately otherwise.
Reported-by: Joerg Desch <vvd.joede@googlemail.com>
commit 5d69703263d588dbb03f4e57091afd8942d96e6d upstream.
This patch fixes a regression that was introduced by
commit 0a5f38467765ee15478db90d81e40c269c8dda20
davinci_emac: Add Carrier Link OK check in Davinci RX Handler
Said commit adds a check whether the carrier link is ok. If the link is
not ok, the skb is freed and no new dma descriptor added to the rx dma
channel. This causes trouble during initialization when the carrier
status has not yet been updated. If a lot of packets are received while
netif_carrier_ok returns false, all dma descriptors are freed and the
rx dma transfer is stopped.
The bug occurs when the board is connected to a network with lots of
traffic and the ifconfig down/up is done, e.g., when reconfiguring
the interface with DHCP.
The bug can be reproduced by flood pinging the davinci board while doing
ifconfig eth0 down
ifconfig eth0 up
on the board.
After that, the rx path stops working and the overrun value reported
by ifconfig is counting up.
This patch reverts commit 0a5f38467765ee15478db90d81e40c269c8dda20
and instead issues warnings only if cpdma_chan_submit returns -ENOMEM.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: <stable@vger.kernel.org>
Cc: Cyril Chemparathy <cyril@ti.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Tested-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com>
commit ba9adbe67e288823ac1deb7f11576ab5653f833e upstream.
Set the RX FIFO flush watermark lower.
According to Federico and JMicron's reply,
setting it to 16QW would be stable on most platforms.
Otherwise, user might experience packet drop issue.
Reported-by: Federico Quagliata <federico@quagliata.org>
Fixed-by: Federico Quagliata <federico@quagliata.org>
Signed-off-by: Guo-Fu Tseng <cooldavid@cooldavid.org>
commit fea6d607e154cf96ab22254ccb48addfd43d4cb5 upstream.
This patch (as1520) fixes a bug in the SCSI layer's power management
implementation.
LUN scanning can be carried out asynchronously in do_scan_async(), and
sd uses an asynchronous thread for the time-consuming parts of disk
probing in sd_probe_async(). Currently nothing coordinates these
async threads with system sleep transitions; they can and do attempt
to continue scanning/probing SCSI devices even after the host adapter
has been suspended. As one might expect, the outcome is not ideal.
This is what the "prepare" stage of system suspend was created for.
After the prepare callback has been called for a host, target, or
device, drivers are not allowed to register any children underneath
them. Currently the SCSI prepare callback is not implemented; this
patch rectifies that omission.
For SCSI hosts, the prepare routine calls scsi_complete_async_scans()
to wait until async scanning is finished. It might be slightly more
efficient to wait only until the host in question has been scanned,
but there's currently no way to do that. Besides, during a sleep
transition we will ultimately have to wait until all the host scanning
has finished anyway.
For SCSI devices, the prepare routine calls async_synchronize_full()
to wait until sd probing is finished. The routine does nothing for
SCSI targets, because asynchronous target scanning is done only as
part of host scanning.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 267a6ad4aefaafbde607804c60945bcf97f91c1b upstream.
In do_scan_async(), calling scsi_autopm_put_host(shost) may reference
freed shost, and cause Posison overwitten warning.
Yes, this case can happen, for example, an USB is disconnected just
when do_scan_async() thread starts to run, then scsi_host_put() called
in scsi_finish_async_scan() will lead to shost be freed(because the
refcount of shost->shost_gendev decreases to 1 after USB disconnects),
at this point, if references shost again, system will show following
warning msg.
To make scsi_autopm_put_host(shost) always reference a valid shost,
put it just before scsi_host_put() in function
scsi_finish_async_scan().
[ 299.281565] =============================================================================
[ 299.281634] BUG kmalloc-4096 (Tainted: G I ): Poison overwritten
[ 299.281682] -----------------------------------------------------------------------------
[ 299.281684]
[ 299.281752] INFO: 0xffff880056c305d0-0xffff880056c305d0. First byte
0x6a instead of 0x6b
[ 299.281816] INFO: Allocated in scsi_host_alloc+0x4a/0x490 age=1688
cpu=1 pid=2004
[ 299.281870] __slab_alloc+0x617/0x6c1
[ 299.281901] __kmalloc+0x28c/0x2e0
[ 299.281931] scsi_host_alloc+0x4a/0x490
[ 299.281966] usb_stor_probe1+0x5b/0xc40 [usb_storage]
[ 299.282010] storage_probe+0xa4/0xe0 [usb_storage]
[ 299.282062] usb_probe_interface+0x172/0x330 [usbcore]
[ 299.282105] driver_probe_device+0x257/0x3b0
[ 299.282138] __driver_attach+0x103/0x110
[ 299.282171] bus_for_each_dev+0x8e/0xe0
[ 299.282201] driver_attach+0x26/0x30
[ 299.282230] bus_add_driver+0x1c4/0x430
[ 299.282260] driver_register+0xb6/0x230
[ 299.282298] usb_register_driver+0xe5/0x270 [usbcore]
[ 299.282337] 0xffffffffa04ab03d
[ 299.282364] do_one_initcall+0x47/0x230
[ 299.282396] sys_init_module+0xa0f/0x1fe0
[ 299.282429] INFO: Freed in scsi_host_dev_release+0x18a/0x1d0 age=85
cpu=0 pid=2008
[ 299.282482] __slab_free+0x3c/0x2a1
[ 299.282510] kfree+0x296/0x310
[ 299.282536] scsi_host_dev_release+0x18a/0x1d0
[ 299.282574] device_release+0x74/0x100
[ 299.282606] kobject_release+0xc7/0x2a0
[ 299.282637] kobject_put+0x54/0xa0
[ 299.282668] put_device+0x27/0x40
[ 299.282694] scsi_host_put+0x1d/0x30
[ 299.282723] do_scan_async+0x1fc/0x2b0
[ 299.282753] kthread+0xdf/0xf0
[ 299.282782] kernel_thread_helper+0x4/0x10
[ 299.282817] INFO: Slab 0xffffea00015b0c00 objects=7 used=7 fp=0x
(null) flags=0x100000000004080
[ 299.282882] INFO: Object 0xffff880056c30000 @offset=0 fp=0x (null)
[ 299.282884]
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 2504a6423b9ab4c36df78227055995644de19edb upstream.
Rate control algorithms are supposed to stop processing when they
encounter a rate with the index -1. Checking for rate->count not being
zero is not enough.
Allowing a rate with negative index leads to memory corruption in
ath_debug_stat_rc().
One consequence of the bug is discussed at
https://bugzilla.redhat.com/show_bug.cgi?id=768639
Signed-off-by: Pavel Roskin <proski@gnu.org>
commit 68d07f64b8a11a852d48d1b05b724c3e20c0d94b upstream
Intel has a PCI USB xhci host controller on a new platform. It doesn't
have a line IRQ definition in BIOS. The Linux driver refuses to
initialize this controller, but Windows works well because it only depends
on MSI.
Actually, Linux also can work for MSI. This patch avoids the line IRQ
checking for USB3 HCDs in usb core PCI probe. It allows the xHCI driver
to try to enable MSI or MSI-X first. It will fail the probe if MSI
enabling failed and there's no legacy PCI IRQ.
This patch should be backported to kernels as old as 2.6.32.
[Maintainer note: This patch is a backport of commit
68d07f64b8a11a852d48d1b05b724c3e20c0d94b "USB: Don't fail USB3 probe on
missing legacy PCI IRQ." to the 3.0 kernel. Note, the original patch
description was wrong. We should not back port this to kernels older
than 2.6.36, since that was the first kernel to support MSI and MSI-X
for xHCI hosts. These systems will just not work without MSI support,
so the probe should fail on kernels older than 2.6.36.]
Signed-off-by: Alex Shi <alex.shi@intel.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit bb94a406682770a35305daaa241ccdb7cab399de upstream.
This patch (as1521b) fixes the interaction between usb-storage's
scanning thread and the freezer. The current implementation has a
race: If the device is unplugged shortly after being plugged in and
just as a system sleep begins, the scanning thread may get frozen
before the khubd task. Khubd won't be able to freeze until the
disconnect processing is complete, and the disconnect processing can't
proceed until the scanning thread finishes, so the sleep transition
will fail.
The implementation in the 3.2 kernel suffers from an additional
problem. There the scanning thread calls set_freezable_with_signal(),
and the signals sent by the freezer will mess up the thread's I/O
delays, which are all interruptible.
The solution to both problems is the same: Replace the kernel thread
used for scanning with a delayed-work routine on the system freezable
work queue. Freezable work queues have the nice property that you can
cancel a work item even while the work queue is frozen, and no signals
are needed.
The 3.2 version of this patch solves the problem in Bugzilla #42730.
Acked-by: Seth Forshee <seth.forshee@canonical.com>
commit a45aa3b30583e7d54e7cf4fbcd0aa699348a6e5c upstream.
The superspeed device attached to a USB 3.0 hub(such as VIA's)
doesn't respond the address device command after resume. The
root cause is the superspeed hub will miss the Hub Depth value
that is used as an offset into the route string to locate the
bits it uses to determine the downstream port number after
reset, and all packets can't be routed to the device attached
to the superspeed hub.
Hub driver sends a Set Hub Depth request to the superspeed hub
except for USB 3.0 root hub when the hub is initialized and
doesn't send the request again after reset due to the resume
process. So moving the code that sends the Set Hub Depth request
to the superspeed hub from hub_configure() to hub_activate()
is to cover those situations include initialization and reset.
The patch should be backported to kernels as old as 2.6.39.
Signed-off-by: Elric Fu <elricfu1@gmail.com>
commit 340a3504fd39dad753ba908fb6f894ee81fc3ae2 upstream.
The xHCI 0.96 spec says that HS bulk and control endpoint NAK rate must
be encoded as an exponent of two number of microframes. The endpoint
descriptor has the NAK rate encoded in number of microframes. We were
just copying the value from the endpoint descriptor into the endpoint
context interval field, which was not correct. This lead to the VIA
host rejecting the add of a bulk OUT endpoint from any USB 2.0 mass
storage device.
The fix is to use the correct encoding. Refactor the code to convert
number of frames to an exponential number of microframes, and make sure
we convert the number of microframes in HS bulk and control endpoints to
an exponent.
This should be back ported to kernels as old as 2.6.31, that contain the
commit dfa49c4ad120a784ef1ff0717168aa79f55a483a "USB: xhci - fix math
in xhci_get_endpoint_interval"
Tested-by: Felipe Contreras <felipe.contreras@gmail.com>
Suggested-by: Andiry Xu <andiry.xu@amd.com>
commit 3278a55a1aebe2bbd47fbb5196209e5326a88b56 upstream.
The code to set the device removable bits in the USB 2.0 roothub
descriptor was accidentally looking at the USB 3.0 port registers
instead of the USB 2.0 registers. This can cause an oops if there are
more USB 2.0 registers than USB 3.0 registers.
This should be backported to kernels as old as 2.6.39, that contain the
commit 4bbb0ace9a3de8392527e3c87926309d541d3b00 "xhci: Return a USB 3.0
hub descriptor for USB3 roothub."
commit cab928ee1f221c9cc48d6615070fefe2e444384a upstream.
On some systems with an Intel Panther Point xHCI host controller, the
BIOS disables the xHCI PCI device during boot, and switches the xHCI
ports over to EHCI. This allows the BIOS to access USB devices without
having xHCI support.
The downside is that the xHCI BIOS handoff mechanism will fail because
memory mapped I/O is not enabled for the disabled PCI device.
Jesse Barnes says this is expected behavior. The PCI core will enable
BARs before quirks run, but it will leave it in an undefined state, and
it may not have memory mapped I/O enabled.
Make the generic USB quirk handler call pci_enable_device() to re-enable
MMIO, and call pci_disable_device() once the host-specific BIOS handoff
is finished. This will balance the ref counts in the PCI core. When
the PCI probe function is called, usb_hcd_pci_probe() will call
pci_enable_device() again.
This should be back ported to kernels as old as 2.6.31. That was the
first kernel with xHCI support, and no one has complained about BIOS
handoffs failing due to memory mapped I/O being disabled on other hosts
(EHCI, UHCI, or OHCI).
Acked-by: Oliver Neukum <oneukum@suse.de>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 7fd25702ba616d9ba56e2a625472f29e5aff25ee upstream.
This USB-serial cable with mini stereo jack enumerates as:
Bus 001 Device 004: ID 1a61:3410 Abbott Diabetes Care
It is a TI3410 inside.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
commit b9e44fe5ecda4158c22bc1ea4bffa378a4f83f65 upstream.
1. Remove all old mass-storage ids's pid:
0x0026,0x0053,0x0098,0x0099,0x0149,0x0150,0x0160;
2. As the pid from 0x1401 to 0x1510 which have not surely assigned to
use for serial-port or mass-storage port,so i think it should be
removed now, and will re-add after it have assigned in future;
3. sort the pid to WCDMA and CDMA.
Signed-off-by: Rui li <li.rui27@zte.com.cn>
commit c6c1e4491dc8d1ed2509fa6aacffa7f34614fc38 upstream.
Signed-off-by: Bruno Thomsen <bruno.thomsen@gmail.com>
[ Upstream commit b530b1930bbd9d005345133f0ff0c556d2a52b19 ]
Initially diagnosed on Ubuntu 11.04 with kernel 2.6.38.
velocity_close is not called during a suspend / resume cycle in this
driver and it has no business playing directly with power states.
Signed-off-by: David Lv <DavidLv@viatech.com.cn>
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
[ Upstream commit 3013dc0cceb9baaf25d5624034eeaa259bf99004 ]
Jean Delvare reported bonding on top of 3c59x adapters was not detecting
network cable removal fast enough.
3c59x indeed uses a 60 seconds timer to check link status if carrier is
on, and 5 seconds if carrier is off.
This patch reduces timer period to 5 seconds if device is a bonding
slave.
Reported-by: Jean Delvare <jdelvare@suse.de>
Acked-by: Jean Delvare <jdelvare@suse.de>
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 237114384ab22c174ec4641e809f8e6cbcfce774 ]
VETH_INFO_PEER carries struct ifinfomsg plus optional IFLA
attributes. A minimal size of sizeof(struct ifinfomsg) must be
enforced or we may risk accessing that struct beyond the limits
of the netlink message.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
[ Upstream commit 936d7de3d736e0737542641269436f4b5968e9ef ]
Commit a0417fa3a18a ("net: Make qdisc_skb_cb upper size bound
explicit.") made it possible for a netdev driver to use skb->cb
between its header_ops.create method and its .ndo_start_xmit
method. Use this in ipoib_hard_header() to stash away the LL address
(GID + QPN), instead of the "ipoib_pseudoheader" hack. This allows
IPoIB to stop lying about its hard_header_len, which will let us fix
the L2 check for GRO.
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 4d6144de8ba263eb3691a737c547e5b2fdc45287 upstream.
If the read or write buffer size associated with the command sent
through the mmc_blk_ioctl is zero, do not prepare data buffer.
This enables a ioctl(2) call to for instance send a MMC_SWITCH to set
a byte in the ext_csd.
Signed-off-by: Johan Rudholm <johan.rudholm@stericsson.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
commit 72ba009b8a159e995e40d3b4e5d7d265acead983 upstream.
BugLink: http://bugs.launchpad.net/bugs/900802
Signed-off-by: Till Kamppeter <till.kamppeter@gmail.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit 71f6bd4a23130cd2f4b036010c5790b1295290b9 upstream.
Fixes PCI device detection on IBM xSeries IBM 3850 M2 / x3950 M2
when using ACPI resources (_CRS).
This is default, a manual workaround (without this patch)
would be pci=nocrs boot param.
V2: Add dev_warn if the workaround is hit. This should reveal
how common such setups are (via google) and point to possible
problems if things are still not working as expected.
-> Suggested by Jan Beulich.
Tested-by: garyhade@us.ibm.com
Signed-off-by: Yinghai Lu <yinghai.lu@oracle.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit b7f5b7dec3d539a84734f2bcb7e53fbb1532a40b upstream.
MSI_REARM_EN register is a write only trigger register.
There is no need RMW when re-arming.
May fix:
https://bugs.freedesktop.org/show_bug.cgi?id=41668
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 363434b5dc352464ac7601547891e5fc9105f124 upstream.
An error while creating sysfs attribute files in the driver's probe function
results in an error abort, but already created files are not removed. This patch
fixes the problem.
Cc: Dirk Eibach <eibach@gdsys.de>
Acked-by: Jean Delvare <khali@linux-fr.org>
commit 2f2da1ac0ba5b6cc6e1957c4da5ff20e67d8442b upstream.
Initialize PPR register for both channels, and set correct PPR register bits.
Also remove unnecessary variable initializations.
Signed-off-by: Chris D Schimp <silverchris@gmail.com>
[guenter.roeck@ericsson.com: Merged two patches into one]
Acked-by: Roland Stigge <stigge@antcom.de>
commit b63d97a36edb1aecf8c13e5f5783feff4d64c24b upstream.
RPM calculation from tachometer value does not depend on PPR.
Also, do not report negative RPM values.
[guenter.roeck@ericsson.com: do not report negative RPM values]
commit 09e87e5c4f9af656af2a8a3afc03487c5d9287c3 upstream.
In order to enable temperature mode aka automatic mode for the F75373 and
F75375 chips, the two FANx_MODE bits in the fan configuration register
need be set to 01, not 10.
commit 6dd599f8af0166805951f4421a78ba716d78321a upstream.
When using nested threaded irqs, use handle_nested_irq(). This function
does not call the chip handler, so no handler is set.
Signed-off-by: David Jander <david@protonic.nl>
Cc: Yong Zhang <yong.zhang0@gmail.com>
Cc: Manfred Gruber <m.gruber@unverspurt.at>
commit eb2f255b2d360df3f500042a2258dcf2fcbe89a2 upstream.
In order to extract the high byte of the 16-bit word, shift the word to
the right, not to the left.
commit e57b6886f555ab57f40a01713304e2053efe51ec upstream.
According to a bug report, it doesn't have one.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=44263
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Keith Packard <keithp@keithp.com>
[ Upstream commit d3aaeb38c40e5a6c08dd31a1b64da65c4352be36, along
with dependent backports of commits:
69cce1d1404968f78b177a0314f5822d5afdbbfb
9de79c127cccecb11ae6a21ab1499e87aa222880
218fa90f072e4aeff9003d57e390857f4f35513e
580da35a31f91a594f3090b7a2c39b85cb051a12
f7e57044eeb1841847c24aa06766c8290c202583
e049f28883126c689cf95859480d9ee4ab23b7fa ]
Gergely Kalman reported crashes in check_peer_redir().
It appears commit f39925dbde778 (ipv4: Cache learned redirect
information in inetpeer.) added a race, leading to possible NULL ptr
dereference.
Since we can now change dst neighbour, we should make sure a reader can
safely use a neighbour.
Add RCU protection to dst neighbour, and make sure check_peer_redir()
can be called safely by different cpus in parallel.
As neighbours are already freed after one RCU grace period, this patch
should not add typical RCU penalty (cache cold effects)
Many thanks to Gergely for providing a pretty report pointing to the
bug.
Reported-by: Gergely Kalman <synapse@hippy.csoma.elte.hu>
commit a8eb28480e9b637cc78b9aa5e08612ba97e1317a upstream.
The driver uses the pstate number from the status register as index in
its table of ACPI pstates (powernow_table). This is wrong as this is
not a 1-to-1 mapping.
For example we can have _PSS information to just utilize Pstate 0 and
Pstate 4, ie.
powernow-k8: Core Performance Boosting: on.
powernow-k8: 0 : pstate 0 (2200 MHz)
powernow-k8: 1 : pstate 4 (1400 MHz)
In this example the driver's powernow_table has just 2 entries. Using
the pstate number (4) as index into this table is just plain wrong.
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Signed-off-by: Dave Jones <davej@redhat.com>
commit 201bf0f129e1715a33568d1563d9a75b840ab4d3 upstream.
Due to CPB we can't directly map SW Pstates to Pstate MSRs. Get rid of
the paranoia check. (assuming that the ACPI Pstate information is
correct.)
commit b5266ea675c5a041e2852c7ccec4cf2d4f5e0cf4 upstream.
Acked-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
commit 1608ea5f4b5d6262cd6e808839491cfb2a67405a upstream.
As ZTE have and will use more pid for new products this year,
so we need to add some new zte 3g-dongle's pid on option.c ,
and delete one pid 0x0154 because it use for mass-storage port.
commit 90451e6973a5da155c6f315a409ca0a8d3ce6b76 upstream.
Signed-off-by: Milan Kocian <milon@wq.cz>
commit e4436a7c17ac2b5e138f93f83a541cba9b311685 upstream.
The Netlogic XLP SoC's on-chip USB controller appears as a PCI
USB device, but does not need the EHCI/OHCI handoff done in
usb/host/pci-quirks.c.
The pci-quirks.c is enabled for all vendors and devices, and is
enabled if USB and PCI are configured.
If we do not skip the qurik handling on XLP, the readb() call in
ehci_bios_handoff() will cause a crash since byte access is not
supported for EHCI registers in XLP.
Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com>
commit 683da59d7b8ae04891636d4b59893cd4e9b0b7e5 upstream.
ab943a2e125b (USB: gadget: gadget zero uses new suspend/resume hooks)
introduced a copy-paste error where f_loopback.c writes to a variable
declared in f_sourcesink.c. This prevents one from creating gadgets
that only have a loopback function.
Signed-off-by: Timo Juhani Lindfors <timo.lindfors@iki.fi>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 1793bf1deddc8ce25dc41925d5dbe64536c841b6 upstream.
Add USB ID for SITECOM WLA-1000 V1 001 WLAN
Reported-and-tested-by: Roland Gruber <post@rolandgruber.de>
Reported-and-tested-by: Dario Lucia <dario.lucia@gmail.com>
commit 3589e74595a4332ebf77b5ed006f3c6686071ecd upstream.
Asus_oled triggers the following bug on module unloading:
usbcore: deregistering interface driver asus-oled
BUG: unable to handle kernel NULL pointer dereference at 0000000000000038
IP: [<ffffffff8111292b>] sysfs_delete_link+0x30/0x66
Call Trace:
[<ffffffff81225373>] device_remove_class_symlinks+0x6b/0x70
[<ffffffff812256a8>] device_del+0x9f/0x1ab
[<ffffffff812257c5>] device_unregister+0x11/0x1e
[<ffffffffa000cb82>] asus_oled_disconnect+0x4f/0x9e [asus_oled]
[<ffffffff81277430>] usb_unbind_interface+0x54/0x103
[<ffffffff812276c4>] __device_release_driver+0xa2/0xeb
[<ffffffff81227794>] driver_detach+0x87/0xad
[<ffffffff812269e9>] bus_remove_driver+0x91/0xc1
[<ffffffff81227fb4>] driver_unregister+0x66/0x6e
[<ffffffff812771ed>] usb_deregister+0xbb/0xc4
[<ffffffffa000ce87>] asus_oled_exit+0x2f/0x31 [asus_oled]
[<ffffffff81068365>] sys_delete_module+0x1b8/0x21b
[<ffffffff810ae3de>] ? do_munmap+0x2ef/0x313
[<ffffffff813699bb>] system_call_fastpath+0x16/0x1b
This is due to an incorrect destruction sequence in asus_oled_exit().
Fix the order, fixes the bug. Tested on an Asus G50V laptop only.
Cc: Jakub Schmidtke <sjakub@gmail.com>
Signed-off-by: Pekka Paalanen <pq@iki.fi>
commit 635032cb397b396241372fa0ff36ae758e658b23 upstream.
Programming an image was broken, because odev->buf_offs was not advanced
for val == 0 in append_values(). This regression was introduced in:
commit 1ff12a4aa354bed093a0240d5e6347b1e27601bc
Author: Kevin A. Granade <kevin.granade@gmail.com>
Date: Sat Sep 5 01:03:39 2009 -0500
Staging: asus_oled: Cleaned up checkpatch issues.
Fix the image processing by special-casing val == 0.
I have tested this change on an Asus G50V laptop only.
Cc: Kevin A. Granade <kevin.granade@gmail.com>
commit 9fbc8909876a2160044e71d376848973b9bfdc3f upstream.
According to SPC-4, the sense key for commands that are failed with
INVALID FIELD IN PARAMETER LIST and INVALID FIELD IN CDB should be
ILLEGAL REQUEST (5h) rather than ABORTED COMMAND (Bh). Without this
patch, a tcm_loop LUN incorrectly gives:
# sg_raw -r 1 -v /dev/sda 3 1 0 0 ff 0
Sense Information:
Fixed format, current; Sense key: Aborted Command
Additional sense: Invalid field in cdb
Raw sense data (in hex):
70 00 0b 00 00 00 00 0a 00 00 00 00 24 00 00 00
00 00
While a real SCSI disk gives:
Sense Information:
Fixed format, current; Sense key: Illegal Request
70 00 05 00 00 00 00 18 00 00 00 00 24 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
with the main point being that the real disk gives a sense key of
ILLEGAL REQUEST (5h).
commit 6816966a8418b980481b4dced7eddd1796b145e8 upstream.
Initiators that aren't the active reservation holder should be able to
do a PERSISTENT RESERVE IN command in all cases, so add it to the list
of allowed CDBs in core_scsi3_pr_seq_non_holder().
Signed-off-by: Marco Sanvido <marco@purestorage.com>
commit 9e08e34e3735ae057eb3834da3570995811b7eb9 upstream.
The comments quote the right parts of the spec:
* d) Establish a unit attention condition for the
* initiator port associated with every I_T nexus
* that lost its registration other than the I_T
* nexus on which the PERSISTENT RESERVE OUT command
* was received, with the additional sense code set
* to REGISTRATIONS PREEMPTED.
and
* e) Establish a unit attention condition for the initiator
* port associated with every I_T nexus that lost its
* persistent reservation and/or registration, with the
* additional sense code set to REGISTRATIONS PREEMPTED;
but the actual code accidentally uses ASCQ_2AH_RESERVATIONS_PREEMPTED
instead of ASCQ_2AH_REGISTRATIONS_PREEMPTED. Fix this.
commit 025e4ab3db07fcbf62c01e4f30d1012234beb980 upstream.
This fixes a memory-corrupting bug: not only does it cause the warning,
but as a result of dropping the refcount to zero, it causes the
pcmcia_socket0 device structure to be freed while it still has
references, causing slab caches corruption. A fatal oops quickly
follows this warning - often even just a 'dmesg' following the warning
causes the kernel to oops.
While testing suspend/resume on an ARM device with PCMCIA support, and a
CF card inserted, I found that after five suspend and resumes, the
kernel would complain, and shortly die after with slab corruption.
WARNING: at include/linux/kref.h:41 kobject_get+0x28/0x50()
As the message doesn't give a clue about which kobject, and the built-in
debugging in drivers/base/power/main.c happens too late, this was added
right before each get_device():
printk("%s: %p [%s] %u\n", __func__, dev, kobject_name(&dev->kobj), atomic_read(&dev->kobj.kref.refcount));
and on the 3rd s2ram cycle, the following behaviour observed:
On the 3rd suspend/resume cycle:
dpm_prepare: c1a0d998 [pcmcia_socket0] 3
dpm_suspend: c1a0d998 [pcmcia_socket0] 3
dpm_suspend_noirq: c1a0d998 [pcmcia_socket0] 3
dpm_resume_noirq: c1a0d998 [pcmcia_socket0] 3
dpm_resume: c1a0d998 [pcmcia_socket0] 3
dpm_complete: c1a0d998 [pcmcia_socket0] 2
4th:
dpm_prepare: c1a0d998 [pcmcia_socket0] 2
dpm_suspend: c1a0d998 [pcmcia_socket0] 2
dpm_suspend_noirq: c1a0d998 [pcmcia_socket0] 2
dpm_resume_noirq: c1a0d998 [pcmcia_socket0] 2
dpm_resume: c1a0d998 [pcmcia_socket0] 2
dpm_complete: c1a0d998 [pcmcia_socket0] 1
5th:
dpm_prepare: c1a0d998 [pcmcia_socket0] 1
dpm_suspend: c1a0d998 [pcmcia_socket0] 1
dpm_suspend_noirq: c1a0d998 [pcmcia_socket0] 1
dpm_resume_noirq: c1a0d998 [pcmcia_socket0] 1
dpm_resume: c1a0d998 [pcmcia_socket0] 1
dpm_complete: c1a0d998 [pcmcia_socket0] 0
Modules linked in: ucb1x00_core
Backtrace:
[<c0212090>] (dump_backtrace+0x0/0x110) from [<c04799dc>] (dump_stack+0x18/0x1c)
[<c04799c4>] (dump_stack+0x0/0x1c) from [<c021cba0>] (warn_slowpath_common+0x50/0x68)
[<c021cb50>] (warn_slowpath_common+0x0/0x68) from [<c021cbdc>] (warn_slowpath_null+0x24/0x28)
[<c021cbb8>] (warn_slowpath_null+0x0/0x28) from [<c0335374>] (kobject_get+0x28/0x50)
[<c033534c>] (kobject_get+0x0/0x50) from [<c03804f4>] (get_device+0x1c/0x24)
[<c0388c90>] (dpm_complete+0x0/0x1a0) from [<c0389cc0>] (dpm_resume_end+0x1c/0x20)
Looking at commit 7b24e7988263 ("pcmcia: split up central event handler"),
the following change was made to cs.c:
return 0;
#endif
- send_event(skt, CS_EVENT_PM_RESUME, CS_EVENT_PRI_LOW);
+ if (!(skt->state & SOCKET_CARDBUS) && (skt->callback))
+ skt->callback->early_resume(skt);
return 0;
And the corresponding change in ds.c is from:
-static int ds_event(struct pcmcia_socket *skt, event_t event, int priority)
- struct pcmcia_socket *s = pcmcia_get_socket(skt);
- switch (event) {
- case CS_EVENT_PM_RESUME:
- if (verify_cis_cache(skt) != 0) {
- dev_dbg(&skt->dev, "cis mismatch - different card\n");
- /* first, remove the card */
- ds_event(skt, CS_EVENT_CARD_REMOVAL, CS_EVENT_PRI_HIGH);
- mutex_lock(&s->ops_mutex);
- destroy_cis_cache(skt);
- kfree(skt->fake_cis);
- skt->fake_cis = NULL;
- s->functions = 0;
- mutex_unlock(&s->ops_mutex);
- /* now, add the new card */
- ds_event(skt, CS_EVENT_CARD_INSERTION,
- CS_EVENT_PRI_LOW);
- break;
- pcmcia_put_socket(s);
- return 0;
-} /* ds_event */
to:
+static int pcmcia_bus_early_resume(struct pcmcia_socket *skt)
+ if (!verify_cis_cache(skt)) {
+ pcmcia_put_socket(skt);
+ return 0;
+ dev_dbg(&skt->dev, "cis mismatch - different card\n");
+ /* first, remove the card */
+ pcmcia_bus_remove(skt);
+ mutex_lock(&skt->ops_mutex);
+ destroy_cis_cache(skt);
+ kfree(skt->fake_cis);
+ skt->fake_cis = NULL;
+ skt->functions = 0;
+ mutex_unlock(&skt->ops_mutex);
+ /* now, add the new card */
+ pcmcia_bus_add(skt);
+ return 0;
As can be seen, the original function called pcmcia_get_socket() and
pcmcia_put_socket() around the guts, whereas the replacement code
calls pcmcia_put_socket() only in one path. This creates an imbalance
in the refcounting.
Testing with pcmcia_put_socket() put removed shows that the bug is gone:
dpm_suspend: c1a10998 [pcmcia_socket0] 5
dpm_suspend_noirq: c1a10998 [pcmcia_socket0] 5
dpm_resume_noirq: c1a10998 [pcmcia_socket0] 5
dpm_resume: c1a10998 [pcmcia_socket0] 5
dpm_complete: c1a10998 [pcmcia_socket0] 5
Tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
commit 585c0fd8216e0c9f98e2434092af7ec0f999522d upstream.
NCT6776F can select fan input pins for fans 3 to 5 with a secondary set of
chip register bits. Check that second set of bits in addition to the first set
to detect if fans 3..5 are monitored.
commit 9f1065032ceb7e86c7c9f16bb86518857e88a172 upstream.
An error was existing in the saving of CONTRAST_CTR register
across suspend/resume.
Signed-off-by: Hubert Feurstein <h.feurstein@gmail.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
commit 07c1e8c1462fa7324de4c36ae9e55da2abd79cee upstream.
We don't need to check 3rd pipe specifically, as it shares PLL with some
other one.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41977
Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
