path: root/drivers
2008-08-20qla2xxx: Set an rport's dev_loss_tmo value in a consistent manner.Andrew Vasquez
[ Upstream commit 85821c906cf3563a00a3d98fa380a2581a7a5ff1 ] As there's no point in adding a fixed-fudge value (originally 5 seconds), honor the user settings only. We also remove the driver's dead-callback get_rport_dev_loss_tmo function (qla2x00_get_rport_loss_tmo()). Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20qla2xxx: Add dev_loss_tmo_callbk/terminate_rport_io callback support.Seokmann Ju
[ Upstream commit 5f3a9a207f1fccde476dd31b4c63ead2967d934f ] Signed-off-by: Seokmann Ju <seokmann.ju@qlogic.com> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20i2c: Fix NULL pointer dereference in i2c_new_probed_deviceHans Verkuil
Already in Linus' tree: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=b25b791b13aaa336b56c4f9bd417ff126363f80b Fix a NULL pointer dereference that happened when calling i2c_new_probed_device on one of the addresses for which we use byte reads instead of quick write for detection purpose (that is: 0x30-0x37 and 0x50-0x5f). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20r8169: avoid thrashing PCI conf space above RTL_GIGA_MAC_VER_06Marcus Sundberg
commit 77332894c21165404496c56763d7df6c15c4bb09 upstream The magic write to register 0x82 will often cause PCI config space on my 8168 (PCI ID 10ec:8168, revision 2. mounted in an LG P300 laptop) to be filled with ones during driver load, and thus breaking NIC operation until reboot. If it does not happen on first driver load it can easily be reproduced by unloading and loading the driver a few times. The magic write was added long ago by this commit: Author: François Romieu <romieu@fr.zoreil.com> Date: Sat Jan 10 06:00:46 2004 -0500 [netdrvr r8169] Merge of changes done by Realtek to rtl8169_init_one(): - phy capability settings allows lower or equal capability as suggested in Realtek's changes; - I/O voodoo; - no need to s/mdio_write/RTL8169_WRITE_GMII_REG/; - s/rtl8169_hw_PHY_config/rtl8169_hw_phy_config/; - rtl8169_hw_phy_config(): ad-hoc struct "phy_magic" to limit duplication of code (yep, the u16 -> int conversions should work as expected); - variable renames and whitepace changes ignored. As the 8168 wasn't supported by that version this patch simply removes the bogus write from mac versions <= RTL_GIGA_MAC_VER_06. [The change above makes sense for the 8101/8102 too -- Ueimor] Signed-off-by: Marcus Sundberg <marcus@ingate.com> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20radeon: misc correctionsDavid Miller
Commit efc491814308f89d5ef6c4fe19ae4552a67d4132 upstream radeon: misc corrections I have a new PCI-E radeon RV380 series card (PCI device ID 5b64) that hangs in my sparc64 boxes when the init scripts set the font. The problem goes away if I disable acceleration. I haven't figured out that bug yet, but along the way I found some corrections to make based upon some auditing. 1) The RB2D_DC_FLUSH_ALL value used by the kernel fb driver and the XORG video driver differ. I've made the kernel match what XORG is using. 2) In radeonfb_engine_reset() we have top-level code structure that roughly looks like: if (family is 300, 350, or V350) do this; else do that; ... if (family is NOT 300, OR family is NOT 350, OR family is NOT V350) do another thing; this last conditional makes no sense, is always true, and obviously was likely meant to be "family is NOT 300, 350, or V350". So I've made the code match the intent. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20acer-wmi: Fix wireless and bluetooth on early AMW0 v2 laptopsCarlos Corbacho
commit 5c742b45dd5fbbb6cf74d3378341704f4b23c5e8 upstream In the old acer_acpi, I discovered that on some of the newer AMW0 laptops that supported the WMID methods, they don't work properly for setting the wireless and bluetooth values. So for the AMW0 V2 laptops, we want to use both the 'old' AMW0 and the 'new' WMID methods for setting wireless & bluetooth to guarantee we always enable it. This was fixed in acer_acpi some time ago, but I forgot to port the patch over to acer-wmi when it was merged. (Without this patch, early AMW0 V2 laptops such as the Aspire 5040 won't work with acer-wmi, where-as they did with the old acer_acpi). AK: fix compilation Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20ide-cd: fix endianity for the error message in cdrom_read_capacityPetr Tesarik
commit 938bb03d188a1e688fb0bcae49788f540193e80a uptream Aesthetic regards aside, commit e8e7b9eb11c34ee18bde8b7011af41938d1ad667 still leaves a bug in the error message, because it uses the unconverted big-endian value for printk. Fix this by using a local variable in machine byte order. The result is correct, more readable, and also produces slightly shorter code on i386. Signed-off-by: Petr Tesarik <ptesarik@suse.cz> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Jan Kara <jack@suse.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: <stable@kernel.org> Acked-by: Borislav Petkov <petkovbb@gmail.com> [bart: __u32 -> u32] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20matrox maven: fix a broken error pathJean Delvare
commit 5ede40f87957c6ededf9284c8339722a97b9dfb6 upstream I broke an error path with d03c21ec0be7787ff6b75dcf56c0e96209ccbfbd, sorry about that. The machine will crash if the i2c_attach_client() or maven_init_client() calls fail, although nobody has yet reported this happening. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Petr Vandrovec <VANDROVE@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20radeonfb: fix accel engine hangsDavid Miller
commit 969830b2fedf8336c41d6195f49d250b1e166ff8 upstream Some chips appear to have the 2D engine hang during screen redraw, typically in a sequence of copyarea operations. This appear to be solved by adding a flush of the engine destination pixel cache and waiting for the engine to be idle before issuing the accel operation. The performance impact seems to be fairly small. Here is a trace on an RV370 (PCI device ID 0x5b64), it records the RBBM_STATUS register, then the source x/y, destination x/y, and width/height used for the copy: ---------------------------------------- radeonfb_prim_copyarea: STATUS[00000140] src[210:70] dst[210:60] wh[a0:10] radeonfb_prim_copyarea: STATUS[00000140] src[2b8:70] dst[2b8:60] wh[88:10] radeonfb_prim_copyarea: STATUS[00000140] src[348:70] dst[348:60] wh[40:10] radeonfb_prim_copyarea: STATUS[80020140] src[390:70] dst[390:60] wh[88:10] radeonfb_prim_copyarea: STATUS[8002613f] src[40:80] dst[40:70] wh[28:10] radeonfb_prim_copyarea: STATUS[80026139] src[a8:80] dst[a8:70] wh[38:10] radeonfb_prim_copyarea: STATUS[80026133] src[e8:80] dst[e8:70] wh[80:10] radeonfb_prim_copyarea: STATUS[8002612d] src[170:80] dst[170:70] wh[30:10] radeonfb_prim_copyarea: STATUS[80026127] src[1a8:80] dst[1a8:70] wh[8:10] radeonfb_prim_copyarea: STATUS[80026121] src[1b8:80] dst[1b8:70] wh[88:10] radeonfb_prim_copyarea: STATUS[8002611b] src[248:80] dst[248:70] wh[68:10] ---------------------------------------- When things are going fine the copies complete before the next ROP is even issued, but all of a sudden the 2D unit becomes active (bit 17 in RBBM_STATUS) and the FIFO retry (bit 13) and FIFO pipeline busy (bit 14) are set as well. The FIFO begins to backup until it becomes full. What happens next is the radeon_fifo_wait() times out, and we access the chip illegally leading to a bus error which usually wedges the box. None of this makes it to the console screen, of course :-) radeon_fifo_wait() should be modified to reset the accelerator when this timeout happens instead of programming the chip anyways. ---------------------------------------- radeonfb: FIFO Timeout ! ERROR(0): Cheetah error trap taken afsr[0010080005000000] afar[000007f900800e40] TL1(0) ERROR(0): TPC[595114] TNPC[595118] O7[459788] TSTATE[11009601] ERROR(0): TPC<radeonfb_copyarea+0xfc/0x248> ERROR(0): M_SYND(0), E_SYND(0), Privileged ERROR(0): Highest priority error (0000080000000000) "Bus error response from system bus" ERROR(0): D-cache idx[0] tag[0000000000000000] utag[0000000000000000] stag[0000000000000000] ERROR(0): D-cache data0[0000000000000000] data1[0000000000000000] data2[0000000000000000] data3[0000000000000000] ERROR(0): I-cache idx[0] tag[0000000000000000] utag[0000000000000000] stag[0000000000000000] u[0000000000000000] l[00\ ERROR(0): I-cache INSN0[0000000000000000] INSN1[0000000000000000] INSN2[0000000000000000] INSN3[0000000000000000] ERROR(0): I-cache INSN4[0000000000000000] INSN5[0000000000000000] INSN6[0000000000000000] INSN7[0000000000000000] ERROR(0): E-cache idx[800e40] tag[000000000e049f4c] ERROR(0): E-cache data0[fffff8127d300180] data1[00000000004b5384] data2[0000000000000000] data3[0000000000000000] Ker:xnel panic - not syncing: Irrecoverable deferred error trap. ---------------------------------------- Another quirk is that these copyarea calls will not happen until the first drivers/char/vt.c:redraw_screen() occurs. This will only happen if you 1) VC switch or 2) run "consolechars" or 3) unblank the screen. This seems to happen because until a redraw_screen() the screen scrolling method used by fbcon is not finalized yet. I've seen this with other fb drivers too. So if all you do is boot straight into X you will never see this bug on the relevant chips. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20SCSI: hptiop: add more PCI device IDsHighPoint Linux Team
commit dd07428b44944b42f699408fe31af47977f1e733 upstream Add PCI device ID for new adapter models. Signed-off-by: HighPoint Linux Team <linux@highpoint-tech.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20SCSI: scsi_transport_spi: fix oops in revalidateJames Bottomley
commit e8bac9e0647dd04c83fd0bfe7cdfe2f6dfb100d0 upstream The class_device->device conversion is causing an oops in revalidate because it's assuming that the device_for_each_child iterator will only return struct scsi_device children. The conversion made all former class_devices children of the device as well, so this assumption is broken. Fix it. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20SCSI: ses: fix VPD inquiry overrunJames Bottomley
commit 671a99c8eb2f1dde08ac5538d8cd912047c61ddf upstream There are a few kerneloops.org reports like this one: http://www.kerneloops.org/search.php?search=ses_match_to_enclosure That seem to imply we're running off the end of the VPD inquiry data (although at 512 bytes, it should be long enough for just about anything). we should be using correctly sized buffers anyway, so put those in and hope this oops goes away. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20USB: ftdi_sio: add support for Luminance Stellaris Evaluation/Development KitsFrederik Kriewitz
commit a00c3cadc2bf50b3c925acdb3d0e5789b1650498 upstream The Patch adds support for Luminance Stellaris Evaluation/Development Kits (FTDI 2232C based). The PIDs were missing. Successfully tested with a Stellaris LM3S8962 Evaluation kit. Signed-off-by: Frederik Kriewitz <frederik@kriewitz.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20USB: ftdi_sio: Add USB Product Id for ELV HS485Andre Schenk
commit b5894a500127fce1db1309db5f9ca8b77a2ac266 upstream USB product id registration for the ELV HS485 USB adapter (www.elv.de) to their home automation bus system. Applies to 2.6.26. Signed-off-by: Andre Schenk <andre@melior.s.bawue.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20USB: pl2023: Remove USB id (4348:5523) handled by ch341Tollef Fog Heen
commit 8c809681ba0289afd0ed7bbb63679a0568dd441d upstream USB ID 4348:5523 is handled by the ch341 driver. Remove it from the pl2023 driver. Reverts 002e8f2c80c6be76bb312940bc278fc10b2b2487. Signed-off-by: Tollef Fog Heen <tfheen@err.no> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20usb-serial: don't release unregistered minorsAlan Stern
commit 0282b7f2a874e72c18fcd5a112ccf67f71ba7f5c upstream This patch (as1121) fixes a bug in the USB serial core. When a device is unregistered, the core will give back its minors -- even if the device hasn't been assigned any! The patch reserves the highest minor value (255) to mean that no minor was assigned. It also removes some dead code and does a small style fixup. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20usb-storage: unusual_devs entries for iRiver T10 and Datafab CF+SM readerAlan Stern
commit 368ee6469c327364ea10082a348f91c1f5ba47f7 upstream This patch (as1115) adds unusual_devs entries with the IGNORE_RESIDE flag for the iRiver T10 and the Simple Tech/Datafab CF+SM card reader. Apparently these devices provide reasonable residue values for READ and WRITE operations, but not for others like INQUIRY or READ CAPACITY. This fixes the iRiver T10 problem reported in Bugzilla #11125. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20USB: usb-storage: quirk around v1.11 firmware on Nikon D4Dave Jones
commit b9a097f26e55968cbc52e30a4a2e73d32d7604ce upstream usb-storage: quirk around v1.11 firmware on Nikon D40 https://bugzilla.redhat.com/show_bug.cgi?id=454028 Just as in earlier firmware versions, we need to perform this quirk for the latest version too. Speculatively do the entry for the D80 too, as they seem to have the same firmware problems historically. Signed-off-by: Dave Jones <davej@redhat.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06pci: VT3336 can't do MSI eitherTejun Heo
commit 66d715c95a39e84cd25204a665915621457d9691 upstream It seems VT3336 can't do msi either as with its bro 3351. Disable it. Reported in the following SUSE bug. https://bugzilla.novell.com/show_bug.cgi?id=300001 Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06USB: EHCI: fix remote-wakeup regressionAlan Stern
commit d1f114d12bb4db3147e1b1342ae31083c5a79c84 upstream This patch (as1097) fixes a bug in the remote-wakeup handling in ehci-hcd. The driver currently does not keep track of whether the change-suspend feature is enabled for each port; the feature is automatically reset the first time it is read. But recent changes to the hub driver require that the feature be read at least twice in order to work properly. A bit-vector is added for storing the change-suspend feature values. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06Input: appletouch - implement reset-resume logicOliver Neukum
commit 90d95ef617a535a8832bdcb8dee07bf591e5dd82 upstream On some boxes the touchpad needs to be reinitialized after resume to make it function again. This fixes bugzilla #10825. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06ACPI: update thermal temperatureZhang, Rui
commit 76ecb4f2d7ea5c3aac8970b9529775316507c6d2 upstream Fix the problem that thermal_get_temp returns the cached value, which causes the temperature in generic thermal never updates. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06ACPI: Reject below-freezing temperatures as invalid critical temperaturesArjan van de Ven
commit a39a2d7c72b358c6253a2ec28e17b023b7f6f41c upstream My laptop thinks that it's a good idea to give -73C as the critical CPU temperature.... which isn't the best thing since it causes a shutdown right at bootup. Temperatures below freezing are clearly invalid critical thresholds so just reject these as such. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06ath5k: Use software encryption for nowLuis R. Rodriguez
Commit 6844e63a9458d15b4437aa467c99128d994b0f6c Hardware encryption doesn't work yet so lets use software encryption for now. Changes-licensed-under: 3-Clause-BSD Signed-off-by: Luis R. Rodriguez <mcgrof@winlab.rutgers.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com> Cc: Jiri Benc <jbenc@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06bay: exit if notify handler cannot be installedHolger Macht
commit 7efd52a407bed6a2b02015b8ebbff7beba155392 upstream If acpi_install_notify_handler() for a bay device fails, the bay driver is superfluous. Most likely, another driver (like libata) is already caring about this device anyway. Furthermore, register_hotplug_dock_device(acpi_handle) from the dock driver must not be called twice with the same handler. This would result in an endless loop consuming 100% of CPU. So clean up and exit. Signed-off-by: Holger Macht <hmacht@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06Input: i8042 - add Acer Aspire 1360 to nomux blacklistJiri Kosina
commit 0376bce7b0659fe1e80d045860087072583ab93f upstream. Acer Aspire 1360 needs to be added to nomux blacklist, otherwise its touchpad misbehaves. Reported-by: Clark Tompsett <clarkt@cnsp.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06Input: i8042 - add Fujitsu-Siemens Amilo Pro 2010 to nomux listJiri Kosina
commit 3f79b1e94002791a42837a46b5817e87a0ac0873 upstream Reported-by: Hans Aschauer <Hans.Aschauer@web.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06Input: i8042 - add Fujitsu-Siemens Amilo Pro V2030 to nomux tableJiri Kosina
Commit efd5184646d5d400fc538d093e9a0bec22a75551 upstream Fujitsu Siemens Amilo Pro V2030 needs nomux table entry, in addition to already existing entry for V2010 model (note that Fujitsu-Siemens changed the capitalization in the DMI data for product). Tested-by: Jiri Mleziva <jmleziva@tiscali.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06Input: i8042 - add Gericom Bellagio to nomux blacklistJiri Kosina
commit 5b5b43d0b32ea586036638288c31179f00de5443 upstream Gericom Bellagio needs to be added to nomux blacklist, otherwise its touchpad misbehaves. Reported-by: Roland Kletzing <roland.kletzing@materna.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06Input: i8042 - add Intel D845PESV to nopnp listJiri Kosina
commit c3a34f4390396a4bede3f8b7bcc5153f50b974bb upstream This patch introduces i8042_dmi_nopnp_table to make it possible to perform DMI matches for systems that need 'i8042.nopnp' to work correctly, and introduces such an entry for Intel D845PESV -- this system doesn't detect PS2 mouse reliably without this option, as reported by Robert Lewis. [dtor@mail.ru - make it compile if CONFIG_PNP is off - reported by Randy Dunlap] Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06Input: i8042 - retry failed CTR writes when resumingJiri Kosina
commit 2f6a77d56523c14651236bc401a99b0e2aca2fdd upstream There are systems that fail in i8042_resume() with i8042: Can't write CTR to resume as i8042_command(&i8042_ctr, I8042_CMD_CTL_WCTR) fails even though the controller claimed itself to be ready before. One retry after failing write fixes the problems on the failing systems. Reported-by: Helmut Schaa <hschaa@novell.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06POWERPC: PS3: Add time include to lpmFUJITA Tomonori
commit 483d8876f75aa5707a646442377051f1b90db206 upstream Add an include <asm/time.h> statement for get_tb(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06SCSI: megaraid_mbox: fix Dell CERC firmware problemHannes Reinecke
commit 69cd39e94669e2994277a29249b6ef93b088ddbb upstream Newer Dell CERC firmware (>= 6.62) implement a random deletion handling compatible with the legacy megaraid driver. The legacy handling shifted the target ID by 0x80 only for I/O commands (READ/WRITE/etc), whereas megaraid_mbox shifts the target ID always if random deletion is supported. The resulted in megaraid_mbox sending an INQUIRY to the wrong channel, and not finding any devices, obviously. So we disable the random deletion support if the offending firmware is found. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=6695 Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Bo Yang <Bo.Yang@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-01ath5k: don't enable MSI, we cannot handle it yetPavel Roskin
commit 256b152b005e319f985f50f2a910a75ba0def74f upstream MSI is a nice thing, but we cannot enable it without changing the interrupt handler. If we do it, we break MSI capable hardware, specifically AR5006 chipset. Signed-off-by: Pavel Roskin <proski@gnu.org> Acked-by: Nick Kossifidis <mickflemm@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-01b43legacy: Release mutex in error handling codeJulia Lawall
commit 4104863fb4a724723d1d5f3cba9d3c5084087e45 upstream The mutex is released on a successful return, so it would seem that it should be released on an error return as well. The semantic patch finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression l; @@ mutex_lock(l); .. when != mutex_unlock(l) when any when strict ( if (...) { ... when != mutex_unlock(l) + mutex_unlock(l); return ...; } | mutex_unlock(l); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-01cpufreq acpi: only call _PPC after cpufreq ACPI init funcs got called alreadyThomas Renninger
commit a1531acd43310a7e4571d52e8846640667f4c74b upstream Ingo Molnar provided a fix to not call _PPC at processor driver initialization time in "[PATCH] ACPI: fix cpufreq regression" (git commit e4233dec749a3519069d9390561b5636a75c7579) But it can still happen that _PPC is called at processor driver initialization time. This patch should make sure that this is not possible anymore. Signed-off-by: Thomas Renninger <trenn@suse.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: Len Brown <lenb@kernel.org> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-01ixgbe: remove device ID for unsupported deviceJesse Brandeburg
commit bb5d10ac8cc315d53306963001fe650d88a1cbb2 upstream The ixgbe driver was untested with device ID 8086:10c8 but still advertises support. Currently if this device is present in the system when the driver is loaded, the system will panic. Remove this device ID until full support can be tested with available hardware. This patch is necessary for 2.6.24, 2.6.25 and 2.6.26 Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-01mpc52xx_psc_spi: fix block transferLuotao Fu
commit 9a7867e1b34c3575e7e76a05c0c54c6edbdae2a4 upstream The block transfer routine in the mpc52xx psc spi driver misinterpret the datasheet. According to the processor datasheet the chipselect is held as long as the EOF is not written. Theoretically blocks of any sizes can be transferred in this way. The old routine however writes an EOF after every word, which has the size of size_of_word. This makes the transfer slow. Also fixed some duplicate code. Signed-off-by: Luotao Fu <l.fu@pengutronix.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-01ahci: retry enabling AHCI a few times before spitting out WARN_ON()Tejun Heo
commit 15fe982e429e0e6b7466719acb6cfd9dbfe47f0c upstream ahci: retry enabling AHCI a few times before spitting out WARN_ON() Some chips need AHCI_EN set more than once to actually set it. Try a few times before giving up and spitting out WARN_ON(). Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Peer Chen <pchen@nvidia.com> Cc: Volker Armin Hemmann <volker.armin.hemmann@tu-clausthal.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-01ide-cd: fix oops when using growisofsJens Axboe
commit e8e7b9eb11c34ee18bde8b7011af41938d1ad667 upstream cdrom_read_capacity() will blindly return the capacity from the device without sanity-checking it. This later causes code in fs/buffer.c to oops. Fix this by checking that the device is telling us sensible things. From: Jens Axboe <jens.axboe@oracle.com> Cc: Michael Buesch <mb@bu3sch.de> Cc: Jan Kara <jack@suse.cz> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <petkovbb@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [bart: print device name instead of driver name] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> [harvey: blocklen is a big-endian value] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-01pata_atiixp: Don't disableAlan Cox
Commit 05177f178efe1459d2d0ac05430027ba201889a4 upstream pata_atiixp: Don't disable A couple of distributions (Fedora, Ubuntu) were having weird problems with the ATI IXP series PATA controllers being reported as simplex. At the heart of the problem is that both distros ignored the recommendations to load pata_acpi and ata_generic *AFTER* specific host drivers. The underlying cause however is that if you D3 and then D0 an ATI IXP it helpfully throws away some configuration and won't let you rewrite it. Add checks to ata_generic and pata_acpi to pin ATIIXP devices. Possibly the real answer here is to quirk them and pin them, but right now we can't do that before they've been pcim_enable()'d by a driver. I'm indebted to David Gero for this. His bug report not only reported the problem but identified the cause correctly and he had tested the right values to prove what was going on [If you backport this for 2.6.24 you will need to pull in the 2.6.25 removal of the bogus WARN_ON() in pcim_enagle] Signed-off-by: Alan Cox <alan@redhat.com> Tested-by: David Gero <davidg@havidave.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-28pppoe: Unshare skb before anything elseHerbert Xu
[ Upstream commit bc6cffd177f9266af38dba96a2cea06c1e7ff932 ] We need to unshare the skb first as otherwise pskb_may_pull may write to a shared skb which could be bad. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-28net pppoe: Check packet length on all receive pathsHerbert Xu
[ Upstream commit 392fdb0e35055b96faa9c1cd6ab537805337cdce ] The length field in the PPPOE header wasn't checked completely. This patch causes all packets shorter than the declared length to be dropped. It also changes the memcpy_toiovec call to skb_copy_datagram_iovec so that paged packets (rare for PPPOE) are handled properly. Thanks to Ilja of the Netric Security Team for discovering and reporting this bug, and Chris Wright for the total_len check. [ Incorporate warning fix from Stephen Hemminger. -DaveM ] Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-28l2tp: Fix potential memory corruption in pppol2tp_recvmsg()James Chapman
[ Upstream commit 6b6707a50c7598a83820077393f8823ab791abf8 ] This patch fixes a potential memory corruption in pppol2tp_recvmsg(). If skb->len is bigger than the caller's buffer length, memcpy_toiovec() will go into unintialized data on the kernel heap, interpret it as an iovec and start modifying memory. The fix is to change the memcpy_toiovec() call to skb_copy_datagram_iovec() so that paged packets (rare for PPPOL2TP) are handled properly. Also check that the caller's buffer is big enough for the data and set the MSG_TRUNC flag if it is not so. Reported-by: Ilja <ilja@netric.org> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-28hdlcdrv: Fix CRC calculation.Micah Dowty
[ Upstream commit ae6134bdf3197206fba95563d755d2fa50d90ddd ] This is a trivial patch against the hdlcdrv module that fixes its CRC calculation. The finished CRC was overwriting the first two bytes of each packet rather than being appended to the end. I've tested this with 2.6.8 and 2.6.10-rc1, but hdlcdrv hasn't changed much recently so it should work with many other kernel versions. Signed-off-by: Micah Dowty <micah@navi.cx> Acked-by: Thomas Sailer <t.sailer@alumni.ethz.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-24V4L/DVB (7475): Added support for Terratec Cinergy T USB XXSAlexander Simon
commit dc88807ed61ed0fc0d57bd80a92508b9de638f5d upstream. Alexander Simon found out that the Terratec Cinergy T USB XXS is just a clone of another DiB7070P-based device. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Ludwig Nussel <lnussel@novell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-24mmc: don't use DMA on newer ENE controllersPierre Ossman
commit bf5b1935d8e42b36a34645788eb261461fe07f2e upstream. Even the newer ENE controllers have bugs in their DMA engine that make it too dangerous to use. Disable it until someone has figured out under which conditions it corrupts data. This has caused problems at least once, and can be found as bug report 10925 in the kernel bugzilla. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-24pxamci: trivial fix of DMA alignment register bit clearingKarl Beldan
commit 4fe16897c59882420d66f2d503106653d026ed6c upstream Signed-off-by: Karl Beldan <karl.beldan@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-24pxamci: fix byte aligned DMA transfersPhilipp Zabel
commit 97f8571e663c808ad2d01a396627235167291556 upstream The pxa27x DMA controller defaults to 64-bit alignment. This caused the SCR reads to fail (and, depending on card type, error out) when card->raw_scr was not aligned on a 8-byte boundary. For performance reasons all scatter-gather addresses passed to pxamci_request should be aligned on 8-byte boundaries, but if this can't be guaranteed, byte aligned DMA transfers in the have to be enabled in the controller to get correct behaviour. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-24SCSI: mptspi: fix oops in mptspi_dv_renegotiate_work()James Bottomley
commit 081a5bcb39b455405d58f79bb3c9398a9d4477ed upstream The problem here is that if the ioc faults too early in the bring up sequence (as it usually does for an irq routing problem), ioc_reset gets called before the scsi host is even allocated. This causes an oops when it later schedules a renegotiation. Fix this by checking ioc->sh before trying to renegotiate. Cc: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
