path: root/drivers
2012-03-19i2c-algo-bit: Fix spurious SCL timeouts under heavy loadVille Syrjala
commit 8ee161ce5e0cfc689eb677f227a6248191165fac upstream. When the system is under heavy load, there can be a significant delay between the getscl() and time_after() calls inside sclhi(). That delay may cause the time_after() check to trigger after SCL has gone high, causing sclhi() to return -ETIMEDOUT. To fix the problem, double check that SCL is still low after the timeout has been reached, before deciding to return -ETIMEDOUT. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19hwmon: (w83627ehf) Fix memory leak in probe functionGuenter Roeck
commit 32260d94408c553dca4ce54104edf79941a27536 upstream. The driver probe function leaked memory if creating the cpu0_vid attribute file failed. Fix by converting the driver to use devm_kzalloc. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19hwmon: (w83627ehf) Fix writing into fan_stop_time for NCT6775F/NCT6776FGuenter Roeck
commit 33fa9b620409edfc71aa6cf01a51f990fbe46ab8 upstream. NCT6775F and NCT6776F have their own set of registers for FAN_STOP_TIME. The correct registers were used to read FAN_STOP_TIME, but writes used the wrong registers. Fix it. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19compat: Re-add missing asm/compat.h include to fix compile breakage on s390Jiri Slaby
For 3.0 stable kernel the backport of 048cd4e51d24ebf7f3552226d03c769d6ad91658 "compat: fix compile breakage on s390" breaks compilation... Re-add a single #include <asm/compat.h> in order to fix this. This patch is _not_ necessary for upstream, only for stable kernels which include the "build fix" mentioned above. One fix for arch/s390/kernel/setup.c was already sent and applied. But we need a similar patch for drivers/s390/char/fs3270.c. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19sfc: Fix assignment of ip_summed for pre-allocated skbsBen Hutchings
commit ff3bc1e7527504a93710535611b2f812f3bb89bf upstream. When pre-allocating skbs for received packets, we set ip_summed = CHECKSUM_UNNCESSARY. We used to change it back to CHECKSUM_NONE when the received packet had an incorrect checksum or unhandled protocol. Commit bc8acf2c8c3e43fcc192762a9f964b3e9a17748b ('drivers/net: avoid some skb->ip_summed initializations') mistakenly replaced the latter assignment with a DEBUG-only assertion that ip_summed == CHECKSUM_NONE. This assertion is always false, but it seems no-one has exercised this code path in a DEBUG build. Fix this by moving our assignment of CHECKSUM_UNNECESSARY into efx_rx_packet_gro(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19block, sx8: fix pointer math issue getting fw versionDan Carpenter
commit ea5f4db8ece896c2ab9eafa0924148a2596c52e4 upstream. "mem" is type u8. We need parenthesis here or it screws up the pointer math probably leading to an oops. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19regulator: Fix setting selector in tps6524x set_voltage functionAxel Lin
commit f03570cf1709397ebe656608266b44ec772960c2 upstream. Don't assign the voltage to selector. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19usb: asix: Patch for Sitecom LN-031Joerg Neikes
commit 4e50391968849860dff1aacde358b4eb14aa5127 upstream. This patch adds support for the Sitecom LN-031 USB adapter with a AX88178 chip. Added USB id to find correct driver for AX88178 1000 Ethernet adapter. Signed-off-by: Joerg Neikes <j.neikes@midlandgate.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19atl1c: dont use highprio tx queueEric Dumazet
[ Upstream commit 11aad99af6ef629ff3b05d1c9f0936589b204316 ] This driver attempts to use two TX rings but lacks proper support : 1) IRQ handler only takes care of TX completion on first TX ring 2) the stop/start logic uses the legacy functions (for non multiqueue drivers) This means all packets witk skb mark set to 1 are sent through high queue but are never cleaned and queue eventualy fills and block the device, triggering the infamous "NETDEV WATCHDOG" message. Lets use a single TX ring to fix the problem, this driver is not a real multiqueue one yet. Minimal fix for stable kernels. Reported-by: Thomas Meyer <thomas@m3y3r.de> Tested-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Jay Cliburn <jcliburn@gmail.com> Cc: Chris Snook <chris.snook@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19vmxnet3: Fix transport header sizeShreyas Bhatewara
[ Upstream commit efead8710aad9e384730ecf25eae0287878840d7 ] Fix transport header size Fix the transpoert header size for UDP packets. Signed-off-by: Shreyas N Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19ppp: fix 'ppp_mp_reconstruct bad seq' errorsBen McKeegan
[ Upstream commit 8a49ad6e89feb5015e77ce6efeb2678947117e20 ] This patch fixes a (mostly cosmetic) bug introduced by the patch 'ppp: Use SKB queue abstraction interfaces in fragment processing' found here: http://www.spinics.net/lists/netdev/msg153312.html The above patch rewrote and moved the code responsible for cleaning up discarded fragments but the new code does not catch every case where this is necessary. This results in some discarded fragments remaining in the queue, and triggering a 'bad seq' error on the subsequent call to ppp_mp_reconstruct. Fragments are discarded whenever other fragments of the same frame have been lost. This can generate a lot of unwanted and misleading log messages. This patch also adds additional detail to the debug logging to make it clearer which fragments were lost and which other fragments were discarded as a result of losses. (Run pppd with 'kdebug 1' option to enable debug logging.) Signed-off-by: Ben McKeegan <ben@netservers.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19acer-wmi: No wifi rfkill on Lenovo machinesIke Panhc
commit 461e74377cfcfc2c0d6bbdfa8fc5fbc21b052c2a upstream. We have several reports which says acer-wmi is loaded on ideapads and register rfkill for wifi which can not be unblocked. Since ideapad-laptop also register rfkill for wifi and it works reliably, it will be fine acer-wmi is not going to register rfkill for wifi once VPC2004 is found. Also put IBM0068/LEN0068 in the list. Though thinkpad_acpi has no wifi rfkill capability, there are reports which says acer-wmi also block wireless on Thinkpad E520/E420. Signed-off-by: Ike Panhc <ike.pan@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19acer-wmi: check wireless capability flag before register rfkillLee, Chun-Yi
commit 1709adab0773616da7a8190f2762e599afb0a295 upstream. There will be better to check the wireless capability flag (ACER_CAP_WIRELESS) before register wireless rfkill because maybe the machine doesn't have wifi module or the module removed by user. Tested on Acer Travelmate 8572 Tested on Acer Aspire 4739Z Tested-by: AceLan Kao <acelan.kao@canonical.com> Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Matthew Garrett <mjg@redhat.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19acer-wmi: Add wireless quirk for Lenovo 3000 N200Seth Forshee
commit be3128b107e36271f7973ef213ccde603a494fe8 upstream. This quirk fixes the wlan rfkill status on this machine. Without it, wlan is permanently soft blocked whenever acer-wmi is loaded. BugLink: https://bugs.launchpad.net/bugs/857297 Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Reviewed-by: Lee, Chun-Yi <jlee@novell.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19acer-wmi: support Lenovo ideapad S205 wifi switchLee, Chun-Yi
commit 15b956a0b5651bbb1217ec374fdd67291dabb2af upstream. The AMW0 function in acer-wmi works on Lenovo ideapad S205 for control the wifi hardware state. We also found there have a 0x78 EC register exposes the state of wifi hardware switch on the machine. So, add this patch to support Lenovo ideapad S205 wifi hardware switch in acer-wmi driver. Reference: bko#37892 https://bugzilla.kernel.org/show_bug.cgi?id=37892 Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Matthew Garrett <mjg@redhat.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Thomas Renninger <trenn@suse.de> Tested-by: Florian Heyer <heyho@flanto.de> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19rt2x00: fix random stallsStanislaw Gruszka
commit 3780d038fdf4b5ef26ead10b0604ab1f46dd9510 upstream. Is possible that we stop queue and then do not wake up it again, especially when packets are transmitted fast. That can be easily reproduced with modified tx queue entry_num to some small value e.g. 16. If mac80211 already hold local->queue_stop_reason_lock, then we can wait on that lock in both rt2x00queue_pause_queue() and rt2x00queue_unpause_queue(). After drooping ->queue_stop_reason_lock is possible that __ieee80211_wake_queue() will be performed before __ieee80211_stop_queue(), hence we stop queue and newer wake up it again. Another race condition is possible when between rt2x00queue_threshold() check and rt2x00queue_pause_queue() we will process all pending tx buffers on different cpu. This might happen if for example interrupt will be triggered on cpu performing rt2x00mac_tx(). To prevent race conditions serialize pause/unpause by queue->tx_lock. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19PM / Driver core: leave runtime PM enabled during system shutdownAlan Stern
commit fe6b91f47080eb17d21cbf2a39311877d57f6938 upstream. Disabling all runtime PM during system shutdown turns out not to be a good idea, because some devices may need to be woken up from a low-power state at that time. The whole point of disabling runtime PM for system shutdown was to prevent untimely runtime-suspend method calls. This patch (as1504) accomplishes the same result by incrementing the usage count for each device and waiting for ongoing runtime-PM callbacks to finish. This is what we already do during system suspend and hibernation, which makes sense since the shutdown method is pretty much a legacy analog of the pm->poweroff method. This fixes a recent regression on some OMAP systems introduced by commit af8db1508f2c9f3b6e633e2d2d906c6557c617f9 (PM / driver core: disable device's runtime PM during shutdown). Reported-and-tested-by: NeilBrown <neilb@suse.de> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Kostyantyn Shlyakhovoy <x0155534@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19firewire: core: handle ack_busy when fetching the Config ROMStefan Richter
commit aaff12039ffd812d0c8bbff50b87b6f1f09bec3e upstream. Some older Panasonic made camcorders (Panasonic AG-EZ30 and NV-DX110, Grundig Scenos DLC 2000) reject requests with ack_busy_X if a request is sent immediately after they sent a response to a prior transaction. This causes firewire-core to fail probing of the camcorder with "giving up on config rom for node id ...". Consequently, programs like kino or dvgrab are unaware of the presence of a camcorder. Such transaction failures happen also with the ieee1394 driver stack (of the 2.4...2.6 kernel series until 2.6.36 inclusive) but with a lower likelihood, such that kino or dvgrab are generally able to use these camcorders via the older driver stack. The cause for firewire-ohci's or firewire-core's worse behavior is not yet known. Gap count optimization in firewire-core is not the cause. Perhaps the slightly higher latency of transaction completion in the older stack plays a role. (ieee1394: AR-resp DMA context tasklet -> packet completion ktread -> user process; firewire-core: tasklet -> user process.) This change introduces retries and delays after ack_busy_X into firewire-core's Config ROM reader, such that at least firewire-core's probing and /dev/fw* creation are successful. This still leaves the problem that userland processes are facing transaction failures. gscanbus's built-in retry routines deal with them successfully, but neither kino's nor dvgrab's do ever succeed. But at least DV capture with "dvgrab -noavc -card 0" works now. Live video preview in kino works too, but not actual capture. One way to prevent Configuration ROM reading failures in application programs is to modify libraw1394 to synthesize read responses by means of firewire-core's Configuration ROM cache. This would only leave CMP and FCP transaction failures as a potential problem source for applications. Reported-and-tested-by: Thomas Seilund <tps@netmaster.dk> Reported-and-tested-by: René Fritz <rene@colorcube.de> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19firewire: cdev: fix 32 bit userland on 64 bit kernel compat corner casesStefan Richter
commit 9c1176b6a28850703ea6e3a0f0c703f6d6c61cd3 upstream. Clemens points out that we need to use compat_ptr() in order to safely cast from u64 to addresses of a 32-bit usermode client. Before, our conversion went wrong - in practice if the client cast from pointer to integer such that sign-extension happened, (libraw1394 and libdc1394 at least were not doing that, IOW were not affected) or - in theory on s390 (which doesn't have FireWire though) and on the tile architecture, regardless of what the client does. The bug would usually be observed as the initial get_info ioctl failing with "Bad address" (EFAULT). Reported-by: Carl Karsten <carl@personnelware.com> Reported-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19PCI: ignore pre-1.1 ASPM quirking when ASPM is disabledMatthew Garrett
commit 4949be16822e92a18ea0cc1616319926628092ee upstream. Right now we won't touch ASPM state if ASPM is disabled, except in the case where we find a device that appears to be too old to reliably support ASPM. Right now we'll clear it in that case, which is almost certainly the wrong thing to do. The easiest way around this is just to disable the blacklisting when ASPM is disabled. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12mfd: Fix cs5535 section mismatchChristian Gmeiner
commit 97e43c983c721a47546e6db3b7711dcd912a6481 upstream. Silence following warnings: WARNING: drivers/mfd/cs5535-mfd.o(.data+0x20): Section mismatch in reference from the variable cs5535_mfd_drv to the function .devinit.text:cs5535_mfd_probe() The variable cs5535_mfd_drv references the function __devinit cs5535_mfd_probe() If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console WARNING: drivers/mfd/cs5535-mfd.o(.data+0x28): Section mismatch in reference from the variable cs5535_mfd_drv to the function .devexit.text:cs5535_mfd_remove() The variable cs5535_mfd_drv references the function __devexit cs5535_mfd_remove() If the reference is valid then annotate the variable with __exit* (see linux/init.h) or name the variable: *driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console Rename the variable from *_drv to *_driver so modpost ignore the OK references to __devinit/__devexit functions. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12cs5535-mfgpt: don't call __init function from __devinitDanny Kukawka
commit 474de3bbadd9cb75ffc32cc759c40d868343d46c upstream. Fix scan_timers() to be __devinit and not __init since the function get called from cs5535_mfgpt_probe which is __devinit. Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12dm raid: fix flush supportJonathan E Brassow
commit 0ca93de9b789e0eb05e103f0c04de72df13da73a upstream. Fix dm-raid flush support. Both md and dm have support for flush, but the dm-raid target forgot to set the flag to indicate that flushes should be passed on. (Important for data integrity e.g. with writeback cache enabled.) Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12dm io: fix discard supportMilan Broz
commit 0c535e0d6f463365c29623350dbd91642363c39b upstream. This patch fixes a crash by recognising discards in dm_io. Currently dm_mirror can send REQ_DISCARD bios if running over a discard-enabled device and without support in dm_io the system crashes badly. BUG: unable to handle kernel paging request at 00800000 IP: __bio_add_page.part.17+0xf5/0x1e0 ... bio_add_page+0x56/0x70 dispatch_io+0x1cf/0x240 [dm_mod] ? km_get_page+0x50/0x50 [dm_mod] ? vm_next_page+0x20/0x20 [dm_mod] ? mirror_flush+0x130/0x130 [dm_mirror] dm_io+0xdc/0x2b0 [dm_mod] ... Introduced in 2.6.38-rc1 by commit 5fc2ffeabb9ee0fc0e71ff16b49f34f0ed3d05b4 (dm raid1: support discard). Signed-off-by: Milan Broz <mbroz@redhat.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12net/usbnet: avoid recursive locking in usbnet_stop()Sebastian Siewior
commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d upstream. |kernel BUG at kernel/rtmutex.c:724! |[<c029599c>] (rt_spin_lock_slowlock+0x108/0x2bc) from [<c01c2330>] (defer_bh+0x1c/0xb4) |[<c01c2330>] (defer_bh+0x1c/0xb4) from [<c01c3afc>] (rx_complete+0x14c/0x194) |[<c01c3afc>] (rx_complete+0x14c/0x194) from [<c01cac88>] (usb_hcd_giveback_urb+0xa0/0xf0) |[<c01cac88>] (usb_hcd_giveback_urb+0xa0/0xf0) from [<c01e1ff4>] (musb_giveback+0x34/0x40) |[<c01e1ff4>] (musb_giveback+0x34/0x40) from [<c01e2b1c>] (musb_advance_schedule+0xb4/0x1c0) |[<c01e2b1c>] (musb_advance_schedule+0xb4/0x1c0) from [<c01e2ca8>] (musb_cleanup_urb.isra.9+0x80/0x8c) |[<c01e2ca8>] (musb_cleanup_urb.isra.9+0x80/0x8c) from [<c01e2ed0>] (musb_urb_dequeue+0xec/0x108) |[<c01e2ed0>] (musb_urb_dequeue+0xec/0x108) from [<c01cbb90>] (unlink1+0xbc/0xcc) |[<c01cbb90>] (unlink1+0xbc/0xcc) from [<c01cc2ec>] (usb_hcd_unlink_urb+0x54/0xa8) |[<c01cc2ec>] (usb_hcd_unlink_urb+0x54/0xa8) from [<c01c2a84>] (unlink_urbs.isra.17+0x2c/0x58) |[<c01c2a84>] (unlink_urbs.isra.17+0x2c/0x58) from [<c01c2b44>] (usbnet_terminate_urbs+0x94/0x10c) |[<c01c2b44>] (usbnet_terminate_urbs+0x94/0x10c) from [<c01c2d68>] (usbnet_stop+0x100/0x15c) |[<c01c2d68>] (usbnet_stop+0x100/0x15c) from [<c020f718>] (__dev_close_many+0x94/0xc8) defer_bh() takes the lock which is hold during unlink_urbs(). The safe walk suggest that the skb will be removed from the list and this is done by defer_bh() so it seems to be okay to drop the lock here. Reported-by: Aníbal Almeida Pinto <anibal.pinto@efacec.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Acked-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12drm/radeon/kms: set SX_MISC in the r6xx blit code (v2)Marek Olšák
commit cf00790dea6f210ddd01a6656da58c7c9a4ea0e4 upstream. Mesa may set it to 1, causing all primitives to be killed. v2: also update the r7xx code Signed-off-by: Marek Olšák <maraeo@gmail.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12carl9170: Fix memory accounting when sta is in power-save mode.Nicolas Cavallari
commit 992d52529d7840236d3059b51c15d5eb9e81a869 upstream. On Access Point mode, when transmitting a packet, if the destination station is in powersave mode, we abort transmitting the packet to the device queue, but we do not reclaim the allocated memory. Given enough packets, we can go in a state where there is no packet on the device queue, but we think the device has no memory left, so no packet gets transmitted, connections breaks and the AP stops working. This undo the allocation done in the TX path when the station is in power-save mode. Signed-off-by: Nicolas Cavallari <cavallar@lri.fr> Acked-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12hwmon: (jc42) Add support for AT30TS00, TS3000GB2, TSE2002GB2, and MCP9804Guenter Roeck
commit 1bd612a25855f4cc9345052b53d7da697dba6358 upstream. Also update IDT datasheet locations. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12hwmon: (jc42) Add support for ST Microelectronics STTS2002 and STTS3000Jean Delvare
commit 4de86126a712ba83fa038d277c8282f7ed466a4b upstream. These are fully compatible with Jedec JC 42.4 as far as I can see. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12hwmon: (pmbus_core) Fix maximum number of POUT alarm attributesGuenter Roeck
commit 7cb3c44fb1f7999e4c53b6a52de6bc25da6de079 upstream. There are up to three POUT alarm attributes, not two, since cap_alarm was added. Reported-by: Michele Petracca <mi.petracca@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12Input: ALPS - fix touchpad detection when buttons are pressedAkio Idehara
commit 99c90ab31fad855b9da9dee3a5aa6c27f263e9d6 upstream. ALPS touchpad detection fails if some buttons of ALPS are pressed. The reason is that the "E6" query response byte is different from what is expected. This was tested on a Toshiba Portege R500. Signed-off-by: Akio Idehara <zbe64533@gmail.com> Tested-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12media: staging: lirc_serial: Do not assume error codes returned by request_irq()Ben Hutchings
commit affc9a0d59ac49bd304e2137bd5e4ffdd6fdfa52 upstream. lirc_serial_probe() must fail if request_irq() returns an error, even if it isn't EBUSY or EINVAL, Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12media: staging: lirc_serial: Fix deadlock on resume failureBen Hutchings
commit 1ff1d88e862948ae5bfe490248c023ff8ac2855d upstream. A resume function cannot remove the device it is resuming! Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12media: staging: lirc_serial: Free resources on failure paths of ↵Ben Hutchings
lirc_serial_probe() commit c8e57e1b766c2321aa76ee5e6878c69bd2313d62 upstream. Failure to allocate the I/O region leaves the IRQ allocated. A later failure leaves them both allocated. Reported-by: Torsten Crass <torsten.crass@eBiology.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12media: staging: lirc_serial: Fix init/exit orderBen Hutchings
commit 9105b8b200410383d0854bbe237ee385d7d33ba6 upstream. Currently the module init function registers a platform_device and only then allocates its IRQ and I/O region. This allows allocation to race with the device's suspend() function. Instead, allocate resources in the platform driver's probe() function and free them in the remove() function. The module exit function removes the platform device before the character device that provides access to it. Change it to reverse the order of initialisation. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12OMAPDSS: HDMI: PHY burnout fixTomi Valkeinen
commit c49d005b6cc8491fad5b24f82805be2d6bcbd3dd upstream. A hardware bug in the OMAP4 HDMI PHY causes physical damage to the board if the HDMI PHY is kept powered on when the cable is not connected. This patch solves the problem by adding hot-plug-detection into the HDMI IP driver. This is not a real HPD support in the sense that nobody else than the IP driver gets to know about the HPD events, but is only meant to fix the HW bug. The strategy is simple: If the display device is turned off by the user, the PHY power is set to OFF. When the display device is turned on by the user, the PHY power is set either to LDOON or TXON, depending on whether the HDMI cable is connected. The reason to avoid PHY OFF when the display device is on, but the cable is disconnected, is that when the PHY is turned OFF, the HDMI IP is not "ticking" and thus the DISPC does not receive pixel clock from the HDMI IP. This would, for example, prevent any VSYNCs from happening, and would thus affect the users of omapdss. By using LDOON when the cable is disconnected we'll avoid the HW bug, but keep the HDMI working as usual from the user's point of view. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12OMAP: DSS2: HDMI: use default dividersTomi Valkeinen
commit 8d88767a4377171752c22ac39bcb2b505eb751da upstream. Use default regn and regm2 dividers in the hdmi driver if the board file does not define them. Cc: Mythri P K <mythripk@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12drm/i915: gen7: Disable the RHWO optimization as it can cause GPU hangs.Kenneth Graunke
commit d71de14ddf423ccc9a2e3f7e37553c99ead20d7c upstream. The BSpec Workarounds page states that bits 10 and 26 must be set to avoid 3D ring hangs. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41353 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=44610 Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Kenneth Graunke <kenneth@whitecape.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12drm/i915: gen7: work around a system hang on IVBEugeni Dodonov
commit db099c8f963fe656108e0a068274c5580a17f69b upstream. This adds the workaround for WaCatErrorRejectionIssue which could result in a system hang. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41353 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=44610 Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Kenneth Graunke <kenneth@whitecape.org> Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12drm/i915: gen7: Implement an L3 caching workaround.Eugeni Dodonov
commit e4e0c058a19c41150d12ad2d3023b3cf09c5de67 upstream. This adds two cache-related workarounds for Ivy Bridge which can lead to 3D ring hangs and corruptions. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41353 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=44610 Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Kenneth Graunke <kenneth@whitecape.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12drm/i915: gen7: implement rczunit workaroundEugeni Dodonov
commit eae66b50c760233fad526edf4a0d327be17a055d upstream. This is yet another workaround related to clock gating which we need on Ivy Bridge. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41353 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=44610 Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Kenneth Graunke <kenneth@whitecape.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12ACPI / PM: Do not save/restore NVS on Asus K54C/K54HRKeng-Yu Lin
commit 5a50a7c32d630d6cdb13d69afabb0cc81b2f379c upstream. The models do not resume correctly without acpi_sleep=nonvs. Signed-off-by: Keng-Yu Lin <kengyu@canonical.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12osd_uld: Bump MAX_OSD_DEVICES from 64 to 1,048,576Boaz Harrosh
commit 41f8ad76362e7aefe3a03949c43e23102dae6e0b upstream. It used to be that minors where 8 bit. But now they are actually 20 bit. So the fix is simplicity itself. I've tested with 300 devices and all user-mode utils work just fine. I have also mechanically added 10,000 to the ida (so devices are /dev/osd10000, /dev/osd10001 ...) and was able to mkfs an exofs filesystem and access osds from user-mode. All the open-osd user-mode code uses the same library to access devices through their symbolic names in /dev/osdX so I'd say it's pretty safe. (Well tested) This patch is very important because some of the systems that will be deploying the 3.2 pnfs-objects code are larger than 64 OSDs and will stop to work properly when reaching that number. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12crypto: mv_cesa - fix final callback not ignoring input dataPhil Sutter
commit f8f54e190ddb4ed697036b60f5e2ae6dd45b801c upstream. Broken by commit 6ef84509f3d439ed2d43ea40080643efec37f54f for users passing a request with non-zero 'nbytes' field, like e.g. testmgr. Signed-off-by: Phil Sutter <phil.sutter@viprinet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12HID: usbhid: Add NOGET quirk for the AIREN Slim+ keyboardAlan Stern
commit 37891abc8464637964a26ae4b61d307fef831f80 upstream. This patch (as1531) adds a NOGET quirk for the Slim+ keyboard marketed by AIREN. This keyboard seems to have a lot of bugs; NOGET works around only one of them. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: okias <d.okias@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12ath9k_hw: prevent writes to const data on AR9160Felix Fietkau
commit 9bbb8168ed3d8b946f9c1901a63a675012de88f2 upstream. Duplicate the data for iniAddac early on, to avoid having to do redundant memcpy calls later. While we're at it, make AR5416 < v2.2 use the same codepath. Fixes a reported crash on x86. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Reported-by: Magnus Määttä <magnus.maatta@logica.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12mmc: sdhci-esdhc-imx: fix for mmc cards on i.MX5Sascha Hauer
commit 5b6b0ad6e572b32a641116aaa5f897ffebe31e44 upstream. On i.MX53 we have to write a special SDHCI_CMD_ABORTCMD to the SDHCI_TRANSFER_MODE register during a MMC_STOP_TRANSMISSION command. This works for SD cards. However, with MMC cards the MMC_SET_BLOCK_COUNT command is used instead, but this needs the same handling. Fix MMC cards by testing for the MMC_SET_BLOCK_COUNT command aswell. Tested on a custom i.MX53 board with a Transcend MMC+ card and eMMC. The kernel started used MMC_SET_BLOCK_COUNT in 3.0, so this is a regression for these boards introduced in 3.0; it should go to 3.0/3.1/3.2-stable. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12Move Logitech Harmony 900 from cdc_ether to zaurusScott Talbert
commit ee932bf9acb2e2c6a309e808000f24856330e3f9 upstream. In the current kernel implementation, the Logitech Harmony 900 remote control is matched to the cdc_ether driver through the generic USB_CDC_SUBCLASS_MDLM entry. However, this device appears to be of the pseudo-MDLM (Belcarra) type, rather than the standard one. This patch blacklists the Harmony 900 from the cdc_ether driver and whitelists it for the pseudo-MDLM driver in zaurus. Signed-off-by: Scott Talbert <talbert@techie.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12mfd: Fix ACPI conflict checkJean Delvare
commit 81b5482c32769abb6dfb979560dab2f952ba86fa upstream. The code is currently always checking the first resource of every device only (several times.) This has been broken since the ACPI check was added in February 2010 in commit 91fedede0338eb6203cdd618d8ece873fdb7c22c. Fix the check to run on each resource individually, once. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12regulator: fix the ldo configure according to 88pm860x specJett.Zhou
commit 3380643b0eaa7ecf99c4f095bdfcb6e5df471616 upstream. Signed-off-by: Jett.Zhou <jtzhou@marvell.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
