commit 61a3855bb726cbb062ef02a31a832dea455456e0 upstream.
For RoCE ports, we set the u32 PMA values based on u64 HCA counters. In case of
overflow, according to the IB spec, we have to saturate a counter to its
max value, do that.
Fixes: c37791349cc7 ('IB/mlx4: Support PMA counters for IBoE')
Signed-off-by: Majd Dibbiny <majd@mellanox.com>
Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com>
Signed-off-by: Hadar Hen Zion <hadarh@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
commit 05b676ab42f624425d5f6519276e506b812fa058 upstream.
TASK_SIZE is depends on the systems architecture (32 or 64 bits) and it
should not be used for defining offset boundary for mmaping buffers for
CAPTURE and OUTPUT queues. This patch fixes support for MMAP calls on
the CAPTURE queue on 64bit architectures (like ARM64).
Signed-off-by: Kamil Debski <k.debski@samsung.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit ab3120300be067a2d41a027c41db0b2c662ab200 upstream.
The v4l2_dev field of struct video_device must be set correctly.
This was never done for this driver, so no video nodes were created
anymore.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
commit b815fc12d4dd2b5586184fb4f867caff05a810d4 upstream.
This fixes a oops due to a double list add when adding a reject PDU for
iscsit_allocate_iovecs allocation failures. The cmd has already been
added to the conn_cmd_list in iscsit_setup_scsi_cmd, so this has us call
iscsit_reject_cmd.
Note that for ERL0 the reject PDU is not actually sent, so this patch
is not completely tested. Just verified we do not oops. The problem is the
add reject functions return -1 which is returned all the way up to
iscsi_target_rx_thread which for ERL0 will drop the connection.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
commit 2e7cee027b26cbe7e6685a7a14bd2850bfe55d33 upstream.
Kernel panic was happening as iscsi_host_remove() was called on
a host which was not yet added.
Signed-off-by: John Soni Jose <sony.john-n@emulex.com>
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
commit fb5ef9e7da39968fec6d6f37f20a23d23740c75e upstream.
In canon mode, the read buffer head will advance over the buffer tail
if the input > 4095 bytes without receiving a line termination char.
Discard additional input until a line termination is received.
Before evaluating for overflow, the 'room' value is normalized for
I_PARMRK and 1 byte is reserved for line termination (even in !icanon
mode, in case the mode is switched). The following table shows the
transform:
actual buffer | 'room' value before overflow calc
space avail | !I_PARMRK | I_PARMRK
0 | -1 | -1
1 | 0 | 0
2 | 1 | 0
3 | 2 | 0
4+ | 3 | 1
When !icanon or when icanon and the read buffer contains newlines,
normalized 'room' values of -1 and 0 are clamped to 0, and
'overflow' is 0, so read_head is not adjusted and the input i/o loop
exits (setting no_room if called from flush_to_ldisc()). No input
is discarded since the reader does have input available to read
which ensures forward progress.
When icanon and the read buffer does not contain newlines and the
normalized 'room' value is 0, then overflow and room are reset to 1,
so that the i/o loop will process the next input char normally
(except for parity errors which are ignored). Thus, erasures, signalling
chars, 7-bit mode, etc. will continue to be handled properly.
If the input char processed was not a line termination char, then
the canon_head index will not have advanced, so the normalized 'room'
value will now be -1 and 'overflow' will be set, which indicates the
read_head can safely be reset, effectively erasing the last char
processed.
If the input char processed was a line termination, then the
canon_head index will have advanced, so 'overflow' is cleared to 0,
the read_head is not reset, and 'room' is cleared to 0, which exits
the i/o loop (because the reader now have input available to read
which ensures forward progress).
Note that it is possible for a line termination to be received, and
for the reader to copy the line to the user buffer before the
input i/o loop is ready to process the next input char. This is
why the i/o loop recomputes the room/overflow state with every
input char while handling overflow.
Finally, if the input data was processed without receiving
a line termination (so that overflow is still set), the pty
driver must receive a write wakeup. A pty writer may be waiting
to write more data in n_tty_write() but without unthrottling
here that wakeup will not arrive, and forward progress will halt.
(Normally, the pty writer is woken when the reader reads data out
of the buffer and more space become available).
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
(backported from commit fb5ef9e7da39968fec6d6f37f20a23d23740c75e)
Signed-off-by: Joseph Salisbury <joseph.salisbury@canonical.com>
commit 8e4934c6d6c659e22b1b746af4196683e77ce6ca upstream.
When the receiver was enabled during startup, a character could
have been in the FIFO when the UART get initially used. The
driver configures the (receive) watermark level, and flushes the
FIFO. However, the receive flag (RDRF) could still be set at that
stage (as mentioned in the register description of UARTx_RWFIFO).
This leads to an interrupt which won't be handled properly in
interrupt mode: The receive interrupt function lpuart_rxint checks
the FIFO count, which is 0 at that point (due to the flush
during initialization). The problem does not manifest when using
DMA to receive characters.
Fix this situation by explicitly read the status register, which
leads to clearing of the RDRF flag. Due to the flush just after
the status flag read, a explicit data read is not to required.
Signed-off-by: Stefan Agner <stefan@agner.ch>
commit 227a4fd801c8a9fa2c4700ab98ec1aec06e3b44d upstream.
When a device with an isochronous endpoint is plugged into the Intel
xHCI host controller, and the driver submits multiple frames per URB,
the xHCI driver will set the Block Event Interrupt (BEI) flag on all
but the last TD for the URB. This causes the host controller to place
an event on the event ring, but not send an interrupt. When the last
TD for the URB completes, BEI is cleared, and we get an interrupt for
the whole URB.
However, under Intel xHCI host controllers, if the event ring is full
of events from transfers with BEI set, an "Event Ring is Full" event
will be posted to the last entry of the event ring, but no interrupt
is generated. Host will cease all transfer and command executions and
wait until software completes handling the pending events in the event
ring. That means xHC stops, but event of "event ring is full" is not
notified. As the result, the xHC looks like dead to user.
This patch is to apply XHCI_AVOID_BEI quirk to Intel xHC devices. And
it should be backported to kernels as old as 3.0, that contains the
commit 69e848c2090a ("Intel xhci: Support EHCI/xHCI port switching.").
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Tested-by: Alistair Grant <akgrant0710@gmail.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 9425183d177aa4a2f09d01a74925124f0778b595 upstream.
Linux xHCI driver doesn't report and handle port cofig error change.
If Port Configure Error for root hub port occurs, CEC bit in PORTSC
would be set by xHC and remains 1. This happends when the root port
fails to configure its link partner, e.g. the port fails to exchange
port capabilities information using Port Capability LMPs.
Then the Port Status Change Events will be blocked until all status
change bits(CEC is one of the change bits) are cleared('0') (refer to
xHCI spec 4.19.2). Otherwise, the port status change event for this
root port will not be generated anymore, then root port would look
like dead for user and can't be recovered until a Host Controller
Reset(HCRST).
This patch is to check CEC bit in PORTSC in xhci_get_port_status()
and set a Config Error in the return status if CEC is set. This will
cause a ClearPortFeature request, where CEC bit is cleared in
xhci_clear_port_change_bit().
[The commit log is based on initial Marvell patch posted at
http://marc.info/?l=linux-kernel&m=142323612321434&w=2]
Reported-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit c7e8bdf5872c5a8f5a6494e16fe839c38a0d3d3d upstream.
Fix a bug that leads to showing the name and description of C-state C0
as "<null>" in sysfs after the ACPI C-states changed (e.g. after AC->DC
or DC->AC
transition).
The function poll_idle_init() in drivers/cpuidle/driver.c initializes the
state 0 during cpuidle_register_driver(), so we better do not overwrite it
again with '\0' during acpi_processor_cst_has_changed().
Signed-off-by: Thomas Schlichter <thomas.schlichter@web.de>
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
commit d75e4af14e228bbe3f86e29bcecb8e6be98d4e04 upstream.
Thomas Schlichter reports the following issue on his Samsung NC20:
"The C-states C1 and C2 to the OS when connected to AC, and additionally
provides the C3 C-state when disconnected from AC. However, the number
of C-states shown in sysfs is fixed to the number of C-states present
at boot.
If I boot with AC connected, I always only see the C-states up to C2
even if I disconnect AC.
The reason is commit 130a5f692425 (ACPI / cpuidle: remove dev->state_count
setting). It removes the update of dev->state_count, but sysfs uses
exactly this variable to show the C-states.
The fix is to use drv->state_count in sysfs. As this is currently the
last user of dev->state_count, this variable can be completely removed."
Remove dev->state_count as per the above.
Reported-by: Thomas Schlichter <thomas.schlichter@web.de>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
[ rjw: Changelog ]
commit 555828ef45f825d6ee06559f0304163550eed380 upstream.
Return EPROBE_DEFER if Regulator returns EPROBE_DEFER
If the Flexcan driver is built into kernel and a regulator is used to
enable the CAN transceiver, the Flexcan driver may not use the regulator.
When initializing the Flexcan device with a regulator defined in the device
tree, but not initialized, the regulator subsystem returns EPROBE_DEFER, hence
the Flexcan init fails.
The solution for this is to return EPROBE_DEFER if regulator is not initialized
and wait until the regulator is initialized.
Signed-off-by: Andreas Werner <kernel@andy89.org>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 02d88b735f5a60f04dbf6d051b76e1877a0d0844 upstream.
In omap_dma_start_desc the vdesc->node is removed from the virt-dma
framework managed lists (to be precise from the desc_issued list).
If a terminate_all comes before the transfer finishes the omap_desc will
not be freed up because it is not in any of the lists and we stopped the
DMA channel so the transfer will not going to complete.
There is no special sequence for leaking memory when using cyclic (audio)
transfer: with every start and stop of a cyclic transfer the driver leaks
struct omap_desc worth of memory.
Free up the allocated memory directly in omap_dma_terminate_all() since the
framework will not going to do that for us.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
CC: <linux-omap@vger.kernel.org>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 4ce7ca89d6e8eae9e201cd0e972ba323f33e2fb4 upstream.
This patch uses iio_trigger_get to increment the reference
count of trigger device, to avoid incorrect assignment.
Can result in a null pointer dereference during removal if the
trigger has been changed before removal.
This patch refers to a similar situation encountered through the
following discussion:
http://www.spinics.net/lists/linux-iio/msg13669.html
Signed-off-by: Darshana Padmadas <darshanapadmadas@gmail.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit 4dac0a8eefd55bb1f157d1a5a084531334a2d74c upstream.
A hardware fifo reset always imply an invalidation of the
existing timestamps, so we'll clear timestamps fifo on
successfull hardware fifo reset.
Signed-off-by: Viorel Suman <viorel.suman@gmail.com>
commit bba0bdd7ad4713d82338bcd9b72d57e9335a664b upstream.
SCSI transport drivers and SCSI LLDs block a SCSI device if the
transport layer is not operational. This means that in this state
no requests should be processed, even if the REQ_PREEMPT flag has
been set. This patch avoids that a rescan shortly after a cable
pull sporadically triggers the following kernel oops:
BUG: unable to handle kernel paging request at ffffc9001a6bc084
IP: [<ffffffffa04e08f2>] mlx4_ib_post_send+0xd2/0xb30 [mlx4_ib]
Process rescan-scsi-bus (pid: 9241, threadinfo ffff88053484a000, task ffff880534aae100)
Call Trace:
[<ffffffffa0718135>] srp_post_send+0x65/0x70 [ib_srp]
[<ffffffffa071b9df>] srp_queuecommand+0x1cf/0x3e0 [ib_srp]
[<ffffffffa0001ff1>] scsi_dispatch_cmd+0x101/0x280 [scsi_mod]
[<ffffffffa0009ad1>] scsi_request_fn+0x411/0x4d0 [scsi_mod]
[<ffffffff81223b37>] __blk_run_queue+0x27/0x30
[<ffffffff8122a8d2>] blk_execute_rq_nowait+0x82/0x110
[<ffffffff8122a9c2>] blk_execute_rq+0x62/0xf0
[<ffffffffa000b0e8>] scsi_execute+0xe8/0x190 [scsi_mod]
[<ffffffffa000b2f3>] scsi_execute_req+0xa3/0x130 [scsi_mod]
[<ffffffffa000c1aa>] scsi_probe_lun+0x17a/0x450 [scsi_mod]
[<ffffffffa000ce86>] scsi_probe_and_add_lun+0x156/0x480 [scsi_mod]
[<ffffffffa000dc2f>] __scsi_scan_target+0xdf/0x1f0 [scsi_mod]
[<ffffffffa000dfa3>] scsi_scan_host_selected+0x183/0x1c0 [scsi_mod]
[<ffffffffa000edfb>] scsi_scan+0xdb/0xe0 [scsi_mod]
[<ffffffffa000ee13>] store_scan+0x13/0x20 [scsi_mod]
[<ffffffff811c8d9b>] sysfs_write_file+0xcb/0x160
[<ffffffff811589de>] vfs_write+0xce/0x140
[<ffffffff81158b53>] sys_write+0x53/0xa0
[<ffffffff81464592>] system_call_fastpath+0x16/0x1b
[<00007f611c9d9300>] 0x7f611c9d92ff
Reported-by: Max Gurtuvoy <maxg@mellanox.com>
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
commit b229a0f840f774d29d8fedbf5deb344ca36b7f1a upstream.
This patch uses the existing CALAO Systems ftdi_8u2232c_probe in order
to avoid attaching a TTY to the JTAG port as this board is based on the
CALAO Systems reference design and needs the same fix up.
Signed-off-by: Doug Goldstein <cardoe@cardoe.com>
[johan: clean up probe logic ]
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 4899c054a90439477b24da8977db8d738376fe90 upstream.
Synapse Wireless uses the FTDI VID with a custom PID of 0x9090 for their
SNAP Stick 200 product.
commit f2c9e560b406f2f6b14b345c7da33467dee9cdf2 upstream.
Use readb() and memcpy_fromio() accessors instead.
Reviewed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit ff6b8090e26ef7649ef0cc6b42389141ef48b0cf upstream.
we have already allocated memory for nbd_dev, but we were not
releasing that memory and just returning the error value.
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
Acked-by: Paul Clements <Paul.Clements@SteelEye.com>
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
commit 9c8928f5176766bec79f272bd47b7124e11cccbd upstream.
The assumption before this patch was that we don't need to
run again the INIT firmware after the system booted. The
INIT firmware runs calibrations which impact the physical
layer's behavior.
Users reported that it may be helpful to run these
calibrations again every time the interface is brought up.
The penatly is minimal, since the calibrations run fast.
This fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=94341
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit 8494057ab5e40df590ef6ef7d66324d3ae33356b upstream.
Properly verify that the resulting page aligned end address is larger
than both the start address and the length of the memory area requested.
Both the start and length arguments for ib_umem_get are controlled by
the user. A misbehaving user can provide values which will cause an
integer overflow when calculating the page aligned end address.
This overflow can cause also miscalculation of the number of pages
mapped, and additional logic issues.
Addresses: CVE-2014-8159
Signed-off-by: Shachar Raindel <raindel@mellanox.com>
Signed-off-by: Jack Morgenstein <jackm@mellanox.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 377b513485fd885dea1083a9a5430df65b35e048 upstream.
Clear the reserved field of struct ib_uverbs_async_event_desc which is
copied to user space.
Signed-off-by: Eli Cohen <eli@mellanox.com>
Reviewed-by: Yann Droneaud <ydroneaud@opteya.com>
commit a1b7f2f6367944d445c6853035830a35c6343939 upstream.
Commit fab4c256a58b ("PCI/AER: Add a TLP header print helper") introduced
the helper function __print_tlp_header(), but contrary to the intention,
the behaviour did change: Since we're taking the address of the parameter
t, the first 4 or 8 bytes printed will be the value of the pointer t
itself, and the remaining 12 or 8 bytes will be who-knows-what (something
from the stack).
We want to show the values of the four members of the struct
aer_header_log_regs; that can be done without ugly and error-prone casts.
On little-endian this should produce the same output as originally
intended, and since no-one has complained about getting garbage output so
far, I think big-endian should be ok too.
Fixes: fab4c256a58b ("PCI/AER: Add a TLP header print helper")
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Borislav Petkov <bp@suse.de>
commit c8648508ebfc597058d2cd00b6c539110264a167 upstream.
On success, callback function returns 0. So invert the if condition
check so that we can break out of loop.
Signed-off-by: Ameya Palande <2ameya@gmail.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
commit 87f966d97b89774162df04d2106c6350c8fe4cb3 upstream.
On a MIPS Malta board, tons of fifo underflow errors have been observed
when using u-boot as bootloader instead of YAMON. The reason for that
is that YAMON used to set the pcnet device to SRAM mode but u-boot does
not. As a result, the default Tx threshold (64 bytes) is now too small to
keep the fifo relatively used and it can result to Tx fifo underflow errors.
As a result of which, it's best to setup the SRAM on supported controllers
so we can always use the NOUFLO bit.
Cc: <netdev@vger.kernel.org>
Cc: <linux-kernel@vger.kernel.org>
Cc: Don Fry <pcnet32@frontier.com>
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
commit 391949b6f02121371e3d7d9082c6d17fd9853034 upstream.
With spidev the mesg->complete callback points to spidev_complete.
Calling this unblocks spidev_sync and so spidev_sync_write finishes. As
the struct spi_message just read is a local variable in
spidev_sync_write and recording the trace event accesses this message
the recording is better done first. The same can happen for
spidev_sync_read.
This fixes an oops observed on a 3.14-rt system with spidev activity
after
echo 1 > /sys/kernel/debug/tracing/events/spi/enable
Signed-off-by: Mark Brown <broonie@kernel.org>
REQ_WRITE_SAME
commit e5db29806b99ce2b2640d2e4d4fcb983cea115c5 upstream.
Since it's possible for the discard and write same queue limits to
change while the upper level command is being sliced and diced, fix up
both of them (a) to reject IO if the special command is unsupported at
the start of the function and (b) read the limits once and let the
commands error out on their own if the status happens to change.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit ab7c7bb6f4ab95dbca96fcfc4463cd69843e3e24 upstream.
__dm_destroy() must take the suspend_lock so that its presuspend and
postsuspend calls do not race with an internal suspend.
commit a104a45ba7a51b5b4c5e8437020d9d48edf22f89 upstream.
The commit 9cade1a46c77 (dma: dw: split driver to library part and platform
code) introduced a separate platform driver but missed to add a
MODULE_ALIAS("platform:dw_dmac"); to that module.
The patch adds this to get driver loaded automatically if platform device is
registered.
Reported-by: "Blin, Jerome" <jerome.blin@intel.com>
Fixes: 9cade1a46c77 (dma: dw: split driver to library part and platform code)
commit 40c8790bcb7ac74f3038153cd09310e220c6a1df upstream.
When the driver sets this rate a power of zero value is set causing
data flow stoppage until another rate is tried.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
commit 163fe301b9f78b6de57d0014eafe504fd20c0cd4 upstream.
commit d7c146053dd195b90c79b9b8131431f44541d015 upstream.
The error code paths that require cleanup use a goto to jump to the
cleanup code and return an error code. However, the error code variable
res, which is initialized to -EINVAL when declared, is then overwritten
with the return value of of_parse_phandle_with_args(), and reused as the
return code from of_irq_parse_one(). This leads to an undetermined error
being returned instead of the expected -EINVAL value. Fix it.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Rob Herring <robh@kernel.org>
commit 2f1bce487cd0a02623cff3d877940f9a2026341c upstream.
devm_phy_create() stores the pointer to the new PHY at the address
returned by devres_alloc(). The res parameter passed to devm_phy_match()
is therefore the location where the pointer to the PHY is stored, hence
it needs to be dereferenced before comparing to the match data in order
to find the correct match.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
This reverts commit 5ac97a1b97e50ef197b64b72c1cd71779e4ecbbe
It was incorrectly applied, as it merged with fuzz.
Reported-by: Jiri Slaby <jslaby@suse.cz>
Signed-off-by: Greg Kroah-Hartman gregkh@linuxfoundation.org
commit 75c3d0bf9caebb502e96683b2bc37f9692437e68 upstream.
This patch fixes the incorrect use of __transport_register_session()
in tcm_qla2xxx_check_initiator_node_acl() code, that does not perform
explicit se_tpg->session_lock when accessing se_tpg->tpg_sess_list
to add new se_sess nodes.
Given that tcm_qla2xxx_check_initiator_node_acl() is not called with
qla_hw->hardware_lock held for all accesses of ->tpg_sess_list, the
code should be using transport_register_session() instead.
Cc: Giridhar Malavali <giridhar.malavali@qlogic.com>
Cc: Quinn Tran <quinn.tran@qlogic.com>
commit d556546e7ecd9fca199df4698943024d40044f8e upstream.
This patch adds a missing set of conditional check braces in
ft_invl_hw_context() originally introduced by commit dcd998ccd
when handling DDP failures in ft_recv_write_data() code.
commit dcd998ccdbf74a7d8fe0f0a44e85da1ed5975946
Author: Kiran Patil <kiran.patil@intel.com>
Date: Wed Aug 3 09:20:01 2011 +0000
tcm_fc: Handle DDP/SW fc_frame_payload_get failures in ft_recv_write_data
Cc: Kiran Patil <kiran.patil@intel.com>
commit 7b8f10da3bf1056546133c9f54f49ce389fd95ab upstream.
The initialisation of the efm32 clocksource first sets up the irq and only
after that initialises the data needed for irq handling. In case this
initialisation is delayed the irq handler would dereference a NULL pointer.
I'm not aware of anything that could delay the process in such a way, but it's
better to be safe than sorry, so setup the irq only when the clock event device
is ready.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Signed-off-by: Yongbae Park <yongbae2@gmail.com>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
commit 328f494d95aac8bd4896aea2328bc281053bcb71 upstream.
When inserting a new register into a block at the lower end the present
bitmap is currently shifted into the wrong direction. The effect of this is
that the bitmap becomes corrupted and registers which are present might be
reported as not present and vice versa.
Fix this by shifting left rather than right.
Fixes: 472fdec7380c("regmap: rbtree: Reduce number of nodes, take 2")
Reported-by: Daniel Baluta <daniel.baluta@gmail.com>
commit 1096be084ac59927158ce80ff1d31c33eed0e565 upstream.
The interrupt is enabled before the handler is set. Even this bug
did not appear, it is potentially dangerous as it can lead to a
NULL pointer dereference.
Fix the error by enabling the interrupt after
clockevents_config_and_register() is called.
commit 1ecc7586922662e3ca2f3f0c3f17fec8749fc621 upstream.
For PGR reservation of type Write Exclusive Access, allow all non
reservation holding I_T nexuses with active registrations to READ
from the device.
This addresses a bug where active registrations that attempted
to READ would result in an reservation conflict.
Signed-off-by: Lee Duncan <lduncan@suse.com>
commit ae450e246e8540300699480a3780a420a028b73f upstream.
This patch changes core_scsi3_pro_release() logic to allow an
existing AllRegistrants type reservation to be re-reserved by
any registered I_T nexus.
This addresses a issue where AllRegistrants type RESERVE was
receiving RESERVATION_CONFLICT status if dev_pr_res_holder did
not match the same I_T nexus, instead of just returning GOOD
status following spc4r34 Section 5.9.9:
"If the device server receives a PERSISTENT RESERVE OUT command
with RESERVE service action where the TYPE field and the SCOPE
field contain the same values as the existing type and scope
from a persistent reservation holder, it shall not make any
change to the existing persistent reservation and shall complete
the command with GOOD status."
Reported-by: Ilias Tsitsimpis <i.tsitsimpis@gmail.com>
Cc: Ilias Tsitsimpis <i.tsitsimpis@gmail.com>
Cc: Lee Duncan <lduncan@suse.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
commit 6c3c9baa0debeb4bcc52a78c4463a0a97518de10 upstream.
This patch fixes an issue with AllRegistrants reservations where
an unregister operation by the I_T nexus reservation holder would
incorrectly drop the reservation, instead of waiting until the
last active I_T nexus is unregistered as per SPC-4.
This includes updating __core_scsi3_complete_pro_release() to reset
dev->dev_pr_res_holder with another pr_reg for this special case,
as well as a new 'unreg' parameter to determine when the release
is occuring from an implicit unregister, vs. explicit RELEASE.
It also adds special handling in core_scsi3_free_pr_reg_from_nacl()
to release the left-over pr_res_holder, now that pr_reg is deleted
from pr_reg_list within __core_scsi3_complete_pro_release().
commit d16ca7c5198fd668db10d2c7b048ed3359c12c54 upstream.
This patch fixes the usage of R_HOLDER bit for an All Registrants
reservation in READ_FULL_STATUS, where only the registration who
issued RESERVE was being reported as having an active reservation.
It changes core_scsi3_pri_read_full_status() to check ahead of the
list walk of active registrations to see if All Registrants is active,
and if so set R_HOLDER bit and scope/type fields for all active
registrations.
commit 215a8fe4198f607f34ecdbc9969dae783d8b5a61 upstream.
This patch fixes a NULL pointer dereference OOPs with pSCSI backends
within target_core_stat.c code. The bug is caused by a configfs attr
read if no pscsi_dev_virt->pdv_sd has been configured.
Reported-by: Olaf Hering <olaf@aepfle.de>
commit f068fbc82e7696d67b1bb8189306865bedf368b6 upstream.
This patch fixes a iser specific logout bug where early complete()
of conn->conn_logout_comp in iscsit_close_connection() was causing
isert_wait4logout() to complete too soon, triggering a use after
free NULL pointer dereference of iscsi_conn memory.
The complete() was originally added for traditional iscsi-target
when a ISCSI_LOGOUT_OP failed in iscsi_target_rx_opcode(), but given
iser-target does not wait in logout failure, this special case needs
to be avoided.
Reported-by: Sagi Grimberg <sagig@mellanox.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Slava Shwartsman <valyushash@gmail.com>
commit 5f7da044f8bc1cfb21c962edf34bd5699a76e7ae upstream.
This patch fixes a NULL pointer dereference triggered by a late
target_configure_device() -> alloc_workqueue() failure that results
in target_free_device() being called with DF_CONFIGURED already set,
which subsequently OOPses in destroy_workqueue() code.
Currently this only happens at modprobe target_core_mod time when
core_dev_setup_virtual_lun0() -> target_configure_device() fails,
and the explicit target_free_device() gets called.
To address this bug originally introduced by commit 0fd97ccf45, go
ahead and move DF_CONFIGURED to end of target_configure_device()
code to handle this special failure case.
Reported-by: Claudio Fleiner <cmf@daterainc.com>
Cc: Claudio Fleiner <cmf@daterainc.com>
commit 7544e597343e2166daba3f32e4708533aa53c233 upstream.
This patch fixes a se_cmd->cmd_kref leak buf when se_sess->sess_tearing_down
is true within target_get_sess_cmd() submission path code.
This se_cmd reference leak can occur during active session shutdown when
ack_kref=1 is passed by target_submit_cmd_[map_sgls,tmr]() callers.
commit 6302ce4d80aa82b3fdb5c5cd68e7268037091b47 upstream.
This crash was reported:
[ 366.947370] sd 3:0:1:0: [sdb] Spinning up disk....
[ 368.804046] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 368.804072] IP: [<ffffffff81358457>] __mutex_lock_common.isra.7+0x9c/0x15b
[ 368.804098] PGD 0
[ 368.804114] Oops: 0002 [#1] SMP
[ 368.804143] CPU 1
[ 368.804151] Modules linked in: sg netconsole s3g(PO) uinput joydev hid_multitouch usbhid hid snd_hda_codec_via cpufreq_userspace cpufreq_powersave cpufreq_stats uhci_hcd cpufreq_conservative snd_hda_intel snd_hda_codec snd_hwdep snd_pcm sdhci_pci snd_page_alloc sdhci snd_timer snd psmouse evdev serio_raw pcspkr soundcore xhci_hcd shpchp s3g_drm(O) mvsas mmc_core ahci libahci drm i2c_core acpi_cpufreq mperf video processor button thermal_sys dm_dmirror exfat_fs exfat_core dm_zcache dm_mod padlock_aes aes_generic padlock_sha iscsi_target_mod target_core_mod configfs sswipe libsas libata scsi_transport_sas picdev via_cputemp hwmon_vid fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 sd_mod crc_t10dif usb_storage scsi_mod ehci_hcd usbcore usb_common
[ 368.804749]
[ 368.804764] Pid: 392, comm: kworker/u:3 Tainted: P W O 3.4.87-logicube-ng.22 #1 To be filled by O.E.M. To be filled by O.E.M./EPIA-M920
[ 368.804802] RIP: 0010:[<ffffffff81358457>] [<ffffffff81358457>] __mutex_lock_common.isra.7+0x9c/0x15b
[ 368.804827] RSP: 0018:ffff880117001cc0 EFLAGS: 00010246
[ 368.804842] RAX: 0000000000000000 RBX: ffff8801185030d0 RCX: ffff88008edcb420
[ 368.804857] RDX: 0000000000000000 RSI: 0000000000000002 RDI: ffff8801185030d4
[ 368.804873] RBP: ffff8801181531c0 R08: 0000000000000020 R09: 00000000fffffffe
[ 368.804885] R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801185030d4
[ 368.804899] R13: 0000000000000002 R14: ffff880117001fd8 R15: ffff8801185030d8
[ 368.804916] FS: 0000000000000000(0000) GS:ffff88011fc80000(0000) knlGS:0000000000000000
[ 368.804931] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 368.804946] CR2: 0000000000000000 CR3: 000000000160b000 CR4: 00000000000006e0
[ 368.804962] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 368.804978] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 368.804995] Process kworker/u:3 (pid: 392, threadinfo ffff880117000000, task ffff8801181531c0)
[ 368.805009] Stack:
[ 368.805017] ffff8801185030d8 0000000000000000 ffffffff8161ddf0 ffffffff81056f7c
[ 368.805062] 000000000000b503 ffff8801185030d0 ffff880118503000 0000000000000000
[ 368.805100] ffff8801185030d0 ffff8801188b8000 ffff88008edcb420 ffffffff813583ac
[ 368.805135] Call Trace:
[ 368.805153] [<ffffffff81056f7c>] ? up+0xb/0x33
[ 368.805168] [<ffffffff813583ac>] ? mutex_lock+0x16/0x25
[ 368.805194] [<ffffffffa018c414>] ? smp_execute_task+0x4e/0x222 [libsas]
[ 368.805217] [<ffffffffa018ce1c>] ? sas_find_bcast_dev+0x3c/0x15d [libsas]
[ 368.805240] [<ffffffffa018ce4f>] ? sas_find_bcast_dev+0x6f/0x15d [libsas]
[ 368.805264] [<ffffffffa018e989>] ? sas_ex_revalidate_domain+0x37/0x2ec [libsas]
[ 368.805280] [<ffffffff81355a2a>] ? printk+0x43/0x48
[ 368.805296] [<ffffffff81359a65>] ? _raw_spin_unlock_irqrestore+0xc/0xd
[ 368.805318] [<ffffffffa018b767>] ? sas_revalidate_domain+0x85/0xb6 [libsas]
[ 368.805336] [<ffffffff8104e5d9>] ? process_one_work+0x151/0x27c
[ 368.805351] [<ffffffff8104f6cd>] ? worker_thread+0xbb/0x152
[ 368.805366] [<ffffffff8104f612>] ? manage_workers.isra.29+0x163/0x163
[ 368.805382] [<ffffffff81052c4e>] ? kthread+0x79/0x81
[ 368.805399] [<ffffffff8135fea4>] ? kernel_thread_helper+0x4/0x10
[ 368.805416] [<ffffffff81052bd5>] ? kthread_flush_work_fn+0x9/0x9
[ 368.805431] [<ffffffff8135fea0>] ? gs_change+0x13/0x13
[ 368.805442] Code: 83 7d 30 63 7e 04 f3 90 eb ab 4c 8d 63 04 4c 8d 7b 08 4c 89 e7 e8 fa 15 00 00 48 8b 43 10 4c 89 3c 24 48 89 63 10 48 89 44 24 08 <48> 89 20 83 c8 ff 48 89 6c 24 10 87 03 ff c8 74 35 4d 89 ee 41
[ 368.805851] RIP [<ffffffff81358457>] __mutex_lock_common.isra.7+0x9c/0x15b
[ 368.805877] RSP <ffff880117001cc0>
[ 368.805886] CR2: 0000000000000000
[ 368.805899] ---[ end trace b720682065d8f4cc ]---
It's directly caused by 89d3cf6 [SCSI] libsas: add mutex for SMP task
execution, but shows a deeper cause: expander functions expect to be able to
cast to and treat domain devices as expanders. The correct fix is to only do
expander discover when we know we've got an expander device to avoid wrongly
casting a non-expander device.
Reported-by: Praveen Murali <pmurali@logicube.com>
Tested-by: Praveen Murali <pmurali@logicube.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit af6fc858a35b90e89ea7a7ee58e66628c55c776b upstream.
Otherwise the guest can abuse that control to cause e.g. PCIe
Unsupported Request responses by disabling memory and/or I/O decoding
and subsequently causing (CPU side) accesses to the respective address
ranges, which (depending on system configuration) may be fatal to the
host.
Note that to alter any of the bits collected together as
PCI_COMMAND_GUEST permissive mode is now required to be enabled
globally or on the specific device.
This is CVE-2015-2150 / XSA-120.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
