path: root/drivers
2014-11-30Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Two i915 regressions and one dual-gpu laptop radeon fix" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/radeon: report disconnected for LVDS/eDP with PX if ddc fails drm/i915: Cancel vdd off work before suspend drm/i915: Ignore SURFLIVE and flip counter when the GPU gets reset
2014-11-29Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: "Three fixlets from the ARM SoC camp: - correct irqdomain initialization for atmel-aic - correct error handling for device tree parsing in bcm controllers" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip: brcmstb-l2: Fix error handling of irq_of_parse_and_map irqchip: bcm7120-l2: Fix error handling of irq_of_parse_and_map irqchip: atmel-aic: Fix irqdomain initialization
2014-11-29Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "This is a set of ten fixes: 8 for UFS including four static checker warnings, a potential null deref in the voltage regulator code, a race on module unload, a ref counting fix on the well known LUNs which made it impossible to remove the ufs module and fix to correct the information in pwr_info. In addition to UFS, there's a blacklist for the Intel Multi-Flex array which chokes on report supported operation codes and a fix to an oops in bnx2fc caused by shared skbs" [ For us non-SCSI people: "UFS" here is "Universal Flash Storage" not the filesystem. - Linus ] * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: ufs: fix NULL dereference when no regulators are defined ufs: ensure clk gating work is finished before module unloading scsi: ufs: fix static checker warning in ufshcd_parse_clock_info scsi: ufs: fix static checker warning in __ufshcd_setup_clocks scsi: ufs: fix static checker warning in ufshcd_populate_vreg scsi: ufs: fix static checker errors in ufshcd_system_suspend ufs: fix power info after link start-up ufs: fix reference counting of W-LUs scsi: add Intel Multi-Flex to scsi scan blacklist bnx2fc: do not add shared skbs to the fcoe_rx_list
2014-11-28Merge tag 'staging-3.18-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging/IIO driver fixes from Greg KH: "Here are some staging and IIO driver fixes for 3.18-rc7 that resolve a number of reported issues, and a new device id for a staging wireless driver. All of these have been in linux-next" * tag 'staging-3.18-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: r8188eu: Add new device ID for DLink GO-USB-N150 staging: r8188eu: Fix scheduling while atomic error introduced in commit fadbe0cd iio: accel: bmc150: set low default thresholds iio: accel: bmc150: Fix iio_event_spec direction iio: accel: bmc150: Send x, y and z motion separately iio: accel: bmc150: Error handling when mode set fails iio: gyro: bmg160: Fix iio_event_spec direction iio: gyro: bmg160: Send x, y and z motion separately iio: gyro: bmg160: Don't let interrupt mode to be open drain iio: gyro: bmg160: Error handling when mode set fails iio: adc: men_z188_adc: Add terminating entry for men_z188_ids iio: accel: kxcjk-1013: Fix kxcjk10013_set_range iio: Fix IIO_EVENT_CODE_EXTRACT_DIR bit mask
2014-11-28Merge tag 'tty-3.18-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fix from Greg KH: "Here is a single revert for the of-serial driver that resolves a reported issue. This revert has been in linux-next for a while" * tag 'tty-3.18-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: Revert "serial: of-serial: add PM suspend/resume support"
2014-11-28Merge tag 'usb-3.18-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here are some USB driver fixes and new device ids for 3.18-rc7. Full details are in the shortlog, and all of these have been in the linux-next tree for a while" * tag 'usb-3.18-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: usb-quirks: Add reset-resume quirk for MS Wireless Laser Mouse 6000 usb: xhci: rework root port wake bits if controller isn't allowed to wakeup USB: xhci: Reset a halted endpoint immediately when we encounter a stall. Revert "xhci: clear root port wake on bits if controller isn't wake-up capable" USB: xhci: don't start a halted endpoint before its new dequeue is set USB: uas: Add no-uas quirk for Hitachi usb-3 enclosures 4971:1012 USB: ssu100: fix overrun-error reporting USB: keyspan: fix overrun-error reporting USB: keyspan: fix tty line-status reporting usb: serial: ftdi_sio: add PIDs for Matrix Orbital products usb: dwc3: ep0: fix for dead code USB: serial: cp210x: add IDs for CEL MeshConnect USB Stick
2014-11-28Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal Pull thermal fixes from Eduardo Valentin: "In this -rc still very minor changes: - Lee Jones fixes compilation warning in sti thermal driver - Marjus Elfring removes unnecessary checks in exynos thermal driver (as per coccinelle) - Now we always update cpufreq policies, and thus get (hopefully) always in sync with cpufreq, thanks to Yadwinder" * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal: thermal: Exynos: Deletion of unnecessary checks before two function calls thermal: sti: Ignore suspend/resume functions when !PM_SLEEP thermal: cpu_cooling: Update always cpufreq policy with thermal constraints
2014-11-28Merge tag 'drm-intel-fixes-2014-11-27' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-fixes Two regression fixes from Ville. * tag 'drm-intel-fixes-2014-11-27' of git://anongit.freedesktop.org/drm-intel: drm/i915: Cancel vdd off work before suspend drm/i915: Ignore SURFLIVE and flip counter when the GPU gets reset
2014-11-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Several small fixes here: 1) Don't crash in tg3 driver when the number of tx queues has been configured to be different from the number of rx queues. From Thadeu Lima de Souza Cascardo. 2) VLAN filter not disabled properly in promisc mode in ixgbe driver, from Vlad Yasevich. 3) Fix OOPS on dellink op in VTI tunnel driver, from Xin Long. 4) IPV6 GRE driver WCCP code checks skb->protocol for ETH_P_IP instead of ETH_P_IPV6, whoops. From Yuri Chislov. 5) Socket matching in ping driver is buggy when packet AF does not match socket's AF. Fix from Jane Zhou. 6) Fix checksum calculation errors in VXLAN due to where the udp_tunnel6_xmit_skb() helper gets it's saddr/daddr from. From Alexander Duyck. 7) Fix 5G detection problem in rtlwifi driver, from Larry Finger. 8) Fix NULL deref in tcp_v{4,6}_send_reset, from Eric Dumazet. 9) Various missing netlink attribute verifications in bridging code, from Thomas Graf. 10) tcp_recvmsg() unconditionally calls ipv4 ip_recv_error even for ipv6 sockets, whoops. Fix from Willem de Bruijn" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (29 commits) net-timestamp: make tcp_recvmsg call ipv6_recv_error for AF_INET6 socks bridge: Sanitize IFLA_EXT_MASK for AF_BRIDGE:RTM_GETLINK bridge: Add missing policy entry for IFLA_BRPORT_FAST_LEAVE net: Check for presence of IFLA_AF_SPEC net: Validate IFLA_BRIDGE_MODE attribute length bridge: Validate IFLA_BRIDGE_FLAGS attribute length stmmac: platform: fix default values of the filter bins setting net/mlx4_core: Limit count field to 24 bits in qp_alloc_res net: dsa: bcm_sf2: reset switch prior to initialization net: dsa: bcm_sf2: fix unmapping registers in case of errors tg3: fix ring init when there are more TX than RX channels tcp: fix possible NULL dereference in tcp_vX_send_reset() rtlwifi: Change order in device startup rtlwifi: rtl8821ae: Fix 5G detection problem Revert "netfilter: conntrack: fix race in __nf_conntrack_confirm against get_next_corpse" vxlan: Fix boolean flip in VXLAN_F_UDP_ZERO_CSUM6_[TX|RX] ip6_udp_tunnel: Fix checksum calculation net-timestamp: Fix a documentation typo net/ping: handle protocol mismatching scenario af_packet: fix sparse warning ...
2014-11-27Merge tag 'spi-v3.18-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi fixes from Mark Brown: "There's a couple of driver fixes here, plus one core fix for the DMA mapping which wasn't doing the right thing for vmalloc()ed addresses that hadn't been through kmap(). It's fairly rare to use vmalloc() with SPI and it's a subset of those users who might fail so it's unsurprising that this wasn't noticed sooner" * tag 'spi-v3.18-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: spi: sirf: fix word width configuration spi: Fix mapping from vmalloc-ed buffer to scatter list spi: dw: Fix dynamic speed change.
2014-11-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input layer fixes from Dmitry Torokhov: "The main change is to fix breakage in Elantech driver introduced by the recent commit adding trackpoint reporting to protocol v4. Now we are trusting the hardware to advertise the trackpoint properly and do not try to decode the data as trackpoint if firmware told us it is not present" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: xpad - use proper endpoint type Input: elantech - trust firmware about trackpoint presence Input: synaptics - adjust min/max on Thinkpad E540
2014-11-27staging: r8188eu: Add new device ID for DLink GO-USB-N150Larry Finger
The DLink GO-USB-N150 with revision B1 uses this driver. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-27Merge branch 'drm-fixes-3.18' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-fixes one fix for PX laptops. * 'drm-fixes-3.18' of git://people.freedesktop.org/~agd5f/linux: drm/radeon: report disconnected for LVDS/eDP with PX if ddc fails
2014-11-26drm/radeon: report disconnected for LVDS/eDP with PX if ddc failsAlex Deucher
If ddc fails, presumably the i2c mux (and hopefully the signal mux) are switched to the other GPU so don't fetch the edid from the vbios so that the connector reports disconnected. bug: https://bugzilla.opensuse.org/show_bug.cgi?id=904417 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2014-11-26staging: r8188eu: Fix scheduling while atomic error introduced in commit ↵Larry Finger
fadbe0cd In commit fadbe0cd5292851608e2e01b91d9295fa287b9fe entitled "staging: rtl8188eu:Remove rtw_zmalloc(), wrapper for kzalloc()", the author failed to note that the original code in the wrapper tested whether the caller could sleep, and set the flags argument to kzalloc() appropriately. After the patch, GFP_KERNEL is used unconditionally. Unfortunately, several of the routines may be entered from an interrupt routine and generate a BUG splat for every such call. Routine rtw_sitesurvey_cmd() is used in the example below: BUG: sleeping function called from invalid context at mm/slub.c:1240 in_atomic(): 1, irqs_disabled(): 0, pid: 756, name: wpa_supplicant INFO: lockdep is turned off. CPU: 2 PID: 756 Comm: wpa_supplicant Tainted: G WC O 3.18.0-rc4+ #34 Hardware name: TOSHIBA TECRA A50-A/TECRA A50-A, BIOS Version 4.20 04/17/2014 ffffc90005557000 ffff880216fafaa8 ffffffff816b0bbf 0000000000000000 ffff8800c3b58000 ffff880216fafac8 ffffffff8107af77 0000000000000001 0000000000000010 ffff880216fafb18 ffffffff811b06ce 0000000000000000 Call Trace: [<ffffffff816b0bbf>] dump_stack+0x4e/0x71 [<ffffffff8107af77>] __might_sleep+0xf7/0x120 [<ffffffff811b06ce>] kmem_cache_alloc_trace+0x4e/0x1f0 [<ffffffffa0888226>] ? rtw_sitesurvey_cmd+0x56/0x2a0 [r8188eu] [<ffffffffa0888226>] rtw_sitesurvey_cmd+0x56/0x2a0 [r8188eu] [<ffffffffa088f00d>] rtw_do_join+0x22d/0x370 [r8188eu] [<ffffffffa088f6e8>] rtw_set_802_11_ssid+0x218/0x3d0 [r8188eu] [<ffffffffa08c3ca5>] rtw_wx_set_essid+0x1e5/0x410 [r8188eu] [<ffffffffa08c3ac0>] ? rtw_wx_get_rate+0x50/0x50 [r8188eu] [<ffffffff816938f1>] ioctl_standard_iw_point+0x151/0x3f0 [<ffffffff81693d52>] ioctl_standard_call+0xb2/0xe0 [<ffffffff81597df7>] ? rtnl_lock+0x17/0x20 [<ffffffff816945a0>] ? iw_handler_get_private+0x70/0x70 [<ffffffff81693ca0>] ? call_commit_handler+0x40/0x40 [<ffffffff81693256>] wireless_process_ioctl+0x176/0x1c0 [<ffffffff81693e79>] wext_handle_ioctl+0x69/0xc0 [<ffffffff8159fe79>] dev_ioctl+0x309/0x5e0 [<ffffffff810be9c7>] ? call_rcu+0x17/0x20 [<ffffffff8156a472>] sock_ioctl+0x142/0x2e0 [<ffffffff811e0c70>] do_vfs_ioctl+0x300/0x520 [<ffffffff81101514>] ? __audit_syscall_entry+0xb4/0x110 [<ffffffff81101514>] ? __audit_syscall_entry+0xb4/0x110 [<ffffffff810102bc>] ? do_audit_syscall_entry+0x6c/0x70 [<ffffffff811e0f11>] SyS_ioctl+0x81/0xa0 [<ffffffff816ba1d2>] system_call_fastpath+0x12/0x17 Additional routines that generate this BUG are rtw_joinbss_cmd(), rtw_dynamic_chk_wk_cmd(), rtw_lps_ctrl_wk_cmd(), rtw_rpt_timer_cfg_cmd(), rtw_ps_cmd(), report_survey_event(), report_join_res(), survey_timer_hdl(), and rtw_check_bcn_info(). Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: navin patidar <navin.patidar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-26Merge tag 'master-2014-11-25' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== pull request: wireless 2014-11-26 Please pull this little batch of fixes intended for the 3.18 stream... For the iwlwifi one, Emmanuel says: "Not all the firmware know how to handle the HOT_SPOT_CMD. Make sure that the firmware will know this command before sending it. This avoids a firmware crash." Along with that, Larry sends a pair of rtlwifi fixes to address some discrepancies from moving drivers out of staging. Larry says: "These two patches are needed to fix a regression introduced when driver rtl8821ae was moved from staging to the regular wireless tree." Please let me know if there are problems! ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-26net: Check for presence of IFLA_AF_SPECThomas Graf
ndo_bridge_setlink() is currently only called on the slave if IFLA_AF_SPEC is set but this is a very fragile assumption and may change in the future. Cc: Ajit Khaparde <ajit.khaparde@emulex.com> Cc: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-26net: Validate IFLA_BRIDGE_MODE attribute lengthThomas Graf
Payload is currently accessed blindly and may exceed valid message boundaries. Fixes: a77dcb8c8 ("be2net: set and query VEB/VEPA mode of the PF interface") Fixes: 815cccbf1 ("ixgbe: add setlink, getlink support to ixgbe and ixgbevf") Cc: Ajit Khaparde <ajit.khaparde@emulex.com> Cc: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-26Merge tag 'iio-fixes-for-3.18c' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus Jonathan writes: Third set of IIO fixes for the 3.18 cycle. Most of these are fairly standard little fixes, a bmc150 and bmg160 patch is to make an ABI change to indicated a specific axis in an event rather than the generic option in the original drivers. As both of these drivers are new in this cycle it would be ideal to push this minor change through even though it isn't strictly a fix. A couple of other 'fixes' change defaults for some settings on these new drivers to more intuitive calues. Looks like some useful feedback has been coming in for this driver since it was applied. * IIO_EVENT_CODE_EXTRACT_DIR bit mask was wrong and has been for a while 0xCF clearly doesn't give a contiguous bitmask. * kxcjk-1013 range setting was failing to mask out the previous value in the register and hence was 'enable only'. * men_z188 device id table wasn't null terminated. * bmg160 and bmc150 both failed to correctly handling an error in mode setting. * bmg160 and bmc150 both had a bug in setting the event direction in the event spec (leads to an attribute name being incorrect) * bmg160 defaulted to an open drain output for the interrupt - as a default this obviously only works with some interrupt chips - hence change the default to push-pull (note this is a new driver so we aren't going to cause any regressions with this change). * bmc150 had an unintuitive default for the rate of change (motion detector) so change it to 0 (new driver so change of default won't cause any regressions).
2014-11-26Merge remote-tracking branches 'spi/fix/dw' and 'spi/fix/sirf' into spi-linusMark Brown
2014-11-26Merge remote-tracking branch 'spi/fix/dma' into spi-linusMark Brown
2014-11-26stmmac: platform: fix default values of the filter bins settingHuacai Chen
The commit 3b57de958e2a brought the support for a different amount of the filter bins, but didn't update the platform driver that without CONFIG_OF. Fixes: 3b57de958e2a (net: stmmac: Support devicetree configs for mcast and ucast filter entries) Signed-off-by: Huacai Chen <chenhc@lemote.com> Acked-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-26net/mlx4_core: Limit count field to 24 bits in qp_alloc_resJack Morgenstein
Some VF drivers use the upper byte of "param1" (the qp count field) in mlx4_qp_reserve_range() to pass flags which are used to optimize the range allocation. Under the current code, if any of these flags are set, the 32-bit count field yields a count greater than 2^24, which is out of range, and this VF fails. As these flags represent a "best-effort" allocation hint anyway, they may safely be ignored. Therefore, the PF driver may simply mask out the bits. Fixes: c82e9aa0a8 "mlx4_core: resource tracking for HCA resources used by guests" Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-26net: dsa: bcm_sf2: reset switch prior to initializationFlorian Fainelli
Our boot agent may have left the switch in an certain configuration state, make sure we issue a software reset prior to configuring the switch in order to ensure the HW is in a consistent state, in particular transmit queues and internal buffers. Fixes: 246d7f773c13 ("net: dsa: add Broadcom SF2 switch driver") Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-26net: dsa: bcm_sf2: fix unmapping registers in case of errorsFlorian Fainelli
In case we fail to ioremap() one of our registers, we would be leaking existing mappings, unwind those accordingly on errors. Fixes: 246d7f773c13 ("net: dsa: add Broadcom SF2 switch driver") Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-26drm/i915: Cancel vdd off work before suspendVille Syrjälä
Currently we just make sure vdd is off before suspending, but we don't cancel the vdd off work. The work wil not touch vdd if want_panel_vdd==false so in theory this is fine. In the past that was perfectly fine since the vdd off work didn't do anything when want_panel_vdd==false, so even if the work would have been run during system resume before i915 has resumed, nothing would happen. However since pps_lock() will now grab the power domain references before it can check want_panel_vdd, we may end up toggling the power wells on/off already before the driver has resumed. That is not really acceptable, so cancel the vdd off work when suspending the encoder. The problem appeared when pps_lock() was introduced in: commit 773538e86081d146e0020435d614f4b96996c1f9 Author: Ville Syrjälä <ville.syrjala@linux.intel.com> Date: Thu Sep 4 14:54:56 2014 +0300 drm/i915: Reset power sequencer pipe tracking when disp2d is off Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Imre Deak <imre.deak@intel.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com>
2014-11-26ufs: fix NULL dereference when no regulators are definedAkinobu Mita
If no voltage supply regulators are defined for the UFS devices (assumed they are always-on), ufshcd_config_vreg_load() can be called on suspend/resume paths with vreg == NULL as hba->vreg_info.vcc* equal to NULL, and it causes NULL pointer dereference. This fixes it by making ufshcd_config_vreg_{h,l}pm noop when no regulators are defined. Signed-off-by: Akinobu Mita <mita@fixstars.com> Reviewed-by: Subhash Jadavani <subhashj@codeaurora.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-26ufs: ensure clk gating work is finished before module unloadingAkinobu Mita
When dynamic clk gating feature is enabled, delayed workqueue machanism is used in order to detect certain period of inactivity. But there is no guarantee that scheduled gating work is completed before module unloading. So it can cause kernel crash by accessing memory after it was freed. Fix it by cancelling clk gating and ungating works and ensure that its execution is finished before module unloading. Signed-off-by: Akinobu Mita <mita@fixstars.com> Reviewed-by: Subhash Jadavani <subhashj@codeaurora.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-26irqchip: brcmstb-l2: Fix error handling of irq_of_parse_and_mapDmitry Torokhov
Return value of irq_of_parse_and_map() is unsigned int, with 0 indicating failure, so testing for negative result never works. Signed-off-by: Dmitry Torokhov <dtor@chromium.org> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Kevin Cernekee <cernekee@gmail.com> Link: https://lkml.kernel.org/r/20141114221642.GA37468@dtor-ws Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-11-26irqchip: bcm7120-l2: Fix error handling of irq_of_parse_and_mapDmitry Torokhov
Return value of irq_of_parse_and_map() is unsigned int, with 0 indicating failure, so testing for negative result never works. Signed-off-by: Dmitry Torokhov <dtor@chromium.org> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Kevin Cernekee <cernekee@gmail.com> Link: https://lkml.kernel.org/r/20141114221614.GA37395@dtor-ws Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-11-25Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc fixes from Ben Herrenschmidt: "This series fix a nasty issue with radeon adapters on powerpc servers, it's all CC'ed stable and has the relevant maintainers ack's/reviews. Basically, some (radeon) adapters have issues with MSI addresses above 1T (only support 40-bits). We had powerpc specific quirk but it only listed a specific revision of an adapter that we shipped with our machines and didn't properly handle the audio function which some distros enable nowadays. So we made the quirk generic and fixed both the graphic and audio drivers properly to use it. Without that, ppc64 server machines will crash at boot with a radeon adapter. Note: This has been brewing for a while, it just needed a last respin which got delayed due to us moving ozlabs to a new location in town and other such things taking priority" * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/pci: Remove unused force_32bit_msi quirk powerpc/pseries: Honor the generic "no_64bit_msi" flag powerpc/powernv: Honor the generic "no_64bit_msi" flag sound/radeon: Move 64-bit MSI quirk from arch to driver gpu/radeon: Set flag to indicate broken 64-bit MSI PCI/MSI: Add device flag indicating that 64-bit MSIs don't work ALSA: hda - Limit 40bit DMA for AMD HDMI controllers
2014-11-25Merge tag 'hwmon-for-linus-v3.18-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull a hwmon fix from Guenter Roeck: "Fix hwmon registration problem in g762 driver" * tag 'hwmon-for-linus-v3.18-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (g762) fix call to devm_hwmon_device_register_with_groups()
2014-11-25Merge tag 'clk-fixes-for-linus' of ↵Linus Torvalds
https://git.linaro.org/people/mike.turquette/linux Pull clock fixes from Mike Turquette: "The fixes for the clock framework are all regressions in drivers, plus a single fix in one of the basic clock templates. No fixes to the core this time around. As with most clock driver fixes these run the gamut from fixing a build warning to fixing wrecked memory timings, with a little USB tossed in for fun" * tag 'clk-fixes-for-linus' of https://git.linaro.org/people/mike.turquette/linux: clk: pxa: fix pxa27x CCCR bit usage clk-divider: Fix READ_ONLY when divider > 1 clk: qcom: Fix duplicate rbcpr clock name clk: at91: usb: fix at91sam9x5 recalc, round and set rate clk: at91: usb: fix at91rm9200 round and set rate
2014-11-25Revert "serial: of-serial: add PM suspend/resume support"Greg Kroah-Hartman
This reverts commit 2dea53bf57783f243c892e99c10c6921e956aa7e. Turns out to be broken :( Cc: Jingchang Lu <jingchang.lu@freescale.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-25tg3: fix ring init when there are more TX than RX channelsThadeu Lima de Souza Cascardo
If TX channels are set to 4 and RX channels are set to less than 4, using ethtool -L, the driver will try to initialize more RX channels than it has allocated, causing an oops. This fix only initializes the RX ring if it has been allocated. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-25rtlwifi: Change order in device startupLarry Finger
The existing order of steps when starting the PCI devices works for 2.4G devices, but fails to initialize the 5G section of the RTL8821AE hardware. This patch is needed to fix the regression reported in Bug #88811 (https://bugzilla.kernel.org/show_bug.cgi?id=88811). Reported-by: Valerio Passini <valerio.passini@unicam.it> Tested-by: Valerio Passini <valerio.passini@unicam.it> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Valerio Passini <valerio.passini@unicam.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-11-25rtlwifi: rtl8821ae: Fix 5G detection problemLarry Finger
The changes associated with moving this driver from staging to the regular tree missed one section setting the allowable rates for the 5GHz band. This patch is needed to fix the regression reported in Bug #88811 (https://bugzilla.kernel.org/show_bug.cgi?id=88811). Reported-by: Valerio Passini <valerio.passini@unicam.it> Tested-by: Valerio Passini <valerio.passini@unicam.it> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Valerio Passini <valerio.passini@unicam.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-11-25vxlan: Fix boolean flip in VXLAN_F_UDP_ZERO_CSUM6_[TX|RX]Alexander Duyck
In "vxlan: Call udp_sock_create" there was a logic error that resulted in the default for IPv6 VXLAN tunnels going from using checksums to not using checksums. Since there is currently no support in iproute2 for setting these values it means that a kernel after the change cannot talk over a IPv6 VXLAN tunnel to a kernel prior the change. Fixes: 3ee64f3 ("vxlan: Call udp_sock_create") Cc: Tom Herbert <therbert@google.com> Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com> Acked-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-25Input: xpad - use proper endpoint typeGreg Kroah-Hartman
The xpad wireless endpoint is not a bulk endpoint on my devices, but rather an interrupt one, so the USB core complains when it is submitted. I'm guessing that the author really did mean that this should be an interrupt urb, but as there are a zillion different xpad devices out there, let's cover out bases and handle both bulk and interrupt endpoints just as easily. Signed-off-by: "Pierre-Loup A. Griffais" <pgriffais@valvesoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-11-25Input: elantech - trust firmware about trackpoint presenceDmitry Torokhov
Only try to parse data as coming from trackpoint if firmware told us that trackpoint is present. Fixes commit caeb0d37fa3e387eb0dd22e5d497523c002033d1 Reported-and-tested-by: Marcus Overhagen <marcus.overhagen@gmail.com> Reported-and-tested-by: Anders Kaseorg <andersk@mit.edu> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-11-24usb-quirks: Add reset-resume quirk for MS Wireless Laser Mouse 6000Hans de Goede
This wireless mouse receiver needs a reset-resume quirk to properly come out of reset. BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1165206 Signed-off-by: Hans de Goede <hdegoede@redhat.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-24xen-netback: do not report success if backend_create_xenvif() failsAlexey Khoroshilov
If xenvif_alloc() or xenbus_scanf() fail in backend_create_xenvif(), xenbus is left in offline mode but netback_probe() reports success. The patch implements propagation of error code for backend_create_xenvif(). Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Acked-by: Wei Liu <wei.liu2@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-24Merge tag 'iwlwifi-for-john-2014-11-23' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/iwlwifi-fixes Emmanuel Grumbach <egrumbach@gmail.com> says: "Not all the firmware know how to handle the HOT_SPOT_CMD. Make sure that the firmware will know this command before sending it. This avoids a firmware crash." Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-11-24drm/i915: Ignore SURFLIVE and flip counter when the GPU gets resetVille Syrjälä
During a GPU reset we need to get pending page flip cleared out since the ring contents are gone and flip will never complete on its own. This used to work until the mmio vs. CS flip race detection came about. That piece of code is looking for a specific surface address in the SURFLIVE register, but as a flip to that address may never happen the check may never pass. So we should just skip the SURFLIVE and flip counter checks when the GPU gets reset. intel_display_handle_reset() tries to effectively complete the flip anyway by calling .update_primary_plane(). But that may not satisfy the conditions of the mmio vs. CS race detection since there's no guarantee that a modeset didn't sneak in between the GPU reset and intel_display_handle_reset(). Such a modeset will not wait for pending flips due to the ongoing GPU reset, and then the primary plane updates performed by intel_display_handle_reset() will already use the new surface address, and thus the surface address the flip is waiting for might never appear in SURFLIVE. The result is that the flip will never complete and attempts to perform further page flips will fail with -EBUSY. During the GPU reset intel_crtc_has_pending_flip() will return false regardless, so the deadlock with a modeset vs. the error work acquiring crtc->mutex was avoided. And the reset_counter check in intel_crtc_has_pending_flip() actually made this bug even less severe since it allowed normal modesets to go through even though there's a pending flip. This is a regression introduced by me here: commit 75f7f3ec600524c9544cc31695155f1a9ddbe1d9 Author: Ville Syrjälä <ville.syrjala@linux.intel.com> Date: Tue Apr 15 21:41:34 2014 +0300 drm/i915: Fix mmio vs. CS flip race on ILK+ Testcase: igt/kms_flip/flip-vs-panning-vs-hang Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: stable@vger.kernel.org Signed-off-by: Jani Nikula <jani.nikula@intel.com>
2014-11-24gpu/radeon: Set flag to indicate broken 64-bit MSIBenjamin Herrenschmidt
Some radeon ASICs don't support all 64 address bits of MSIs despite advertising support for 64-bit MSIs in their configuration space. This breaks on systems such as IBM POWER7/8, where 64-bit MSIs can be assigned with some of the high address bits set. This makes use of the newly introduced "no_64bit_msi" flag in structure pci_dev to allow the MSI allocation code to fallback to 32-bit MSIs on those adapters. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> CC: <stable@vger.kernel.org> --- Adding Alex's review tag. Patch to the driver is identical to the reviewed one, I dropped the arch/powerpc hunk rewrote the subject and cset comment.
2014-11-24PCI/MSI: Add device flag indicating that 64-bit MSIs don't workBenjamin Herrenschmidt
This can be set by quirks/drivers to be used by the architecture code that assigns the MSI addresses. We additionally add verification in the core MSI code that the values assigned by the architecture do satisfy the limitation in order to fail gracefully if they don't (ie. the arch hasn't been updated to deal with that quirk yet). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: <stable@vger.kernel.org> Acked-by: Bjorn Helgaas <bhelgaas@google.com>
2014-11-23iwlwifi: mvm: check TLV flag before trying to use hotspot firmware commandsLuciano Coelho
Older firmwares do not provide support for the HOT_SPOT_CMD command. Check for the appropriate TLV flag that declares hotspot support in the firmware to prevent a firmware assertion failure that can be triggered from the userspace, Cc: stable@vger.kernel.org [3.17+] Signed-off-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-11-23solos-pci: fix error return codeJulia Lawall
Return a negative error code on failure. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier ret; expression e1,e2; @@ ( if (\(ret < 0\|ret != 0\)) { ... return ret; } | ret = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-23igb: Fixes needed for surprise removal supportCarolyn Wyborny
This patch adds some checks in order to prevent panic's on surprise removal of devices during S0, S3, S4. Without this patch, Thunderbolt type device removal will panic the system. Signed-off-by: Yanir Lubetkin <yanirx.lubetkin@intel.com> Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-23ixgbe: fix use after free adapter->state test in ixgbe_remove/ixgbe_probeDaniel Borkmann
While working on a different issue, I noticed an annoying use after free bug on my machine when unloading the ixgbe driver: [ 8642.318797] ixgbe 0000:02:00.1: removed PHC on p2p2 [ 8642.742716] ixgbe 0000:02:00.1: complete [ 8642.743784] BUG: unable to handle kernel paging request at ffff8807d3740a90 [ 8642.744828] IP: [<ffffffffa01c77dc>] ixgbe_remove+0xfc/0x1b0 [ixgbe] [ 8642.745886] PGD 20c6067 PUD 81c1f6067 PMD 81c15a067 PTE 80000007d3740060 [ 8642.746956] Oops: 0002 [#1] SMP DEBUG_PAGEALLOC [ 8642.748039] Modules linked in: [...] [ 8642.752929] CPU: 1 PID: 1225 Comm: rmmod Not tainted 3.18.0-rc2+ #49 [ 8642.754203] Hardware name: Supermicro X10SLM-F/X10SLM-F, BIOS 1.1b 11/01/2013 [ 8642.755505] task: ffff8807e34d3fe0 ti: ffff8807b7204000 task.ti: ffff8807b7204000 [ 8642.756831] RIP: 0010:[<ffffffffa01c77dc>] [<ffffffffa01c77dc>] ixgbe_remove+0xfc/0x1b0 [ixgbe] [...] [ 8642.774335] Stack: [ 8642.775805] ffff8807ee824098 ffff8807ee824098 ffffffffa01f3000 ffff8807ee824000 [ 8642.777326] ffff8807b7207e18 ffffffff8137720f ffff8807ee824098 ffff8807ee824098 [ 8642.778848] ffffffffa01f3068 ffff8807ee8240f8 ffff8807b7207e38 ffffffff8144180f [ 8642.780365] Call Trace: [ 8642.781869] [<ffffffff8137720f>] pci_device_remove+0x3f/0xc0 [ 8642.783395] [<ffffffff8144180f>] __device_release_driver+0x7f/0xf0 [ 8642.784876] [<ffffffff814421f8>] driver_detach+0xb8/0xc0 [ 8642.786352] [<ffffffff814414a9>] bus_remove_driver+0x59/0xe0 [ 8642.787783] [<ffffffff814429d0>] driver_unregister+0x30/0x70 [ 8642.789202] [<ffffffff81375c65>] pci_unregister_driver+0x25/0xa0 [ 8642.790657] [<ffffffffa01eb38e>] ixgbe_exit_module+0x1c/0xc8e [ixgbe] [ 8642.792064] [<ffffffff810f93a2>] SyS_delete_module+0x132/0x1c0 [ 8642.793450] [<ffffffff81012c61>] ? do_notify_resume+0x61/0xa0 [ 8642.794837] [<ffffffff816d2029>] system_call_fastpath+0x12/0x17 The issue is that test_and_set_bit() done on adapter->state is being performed *after* the netdevice has been freed via free_netdev(). When netdev is being allocated on initialization time, it allocates a private area, here struct ixgbe_adapter, that resides after the net_device structure. In ixgbe_probe(), the device init routine, we set up the adapter after alloc_etherdev_mq() on the private area and add a reference for the pci_dev as well via pci_set_drvdata(). Both in the error path of ixgbe_probe(), but also on module unload when ixgbe_remove() is being called, commit 41c62843eb6a ("ixgbe: Fix rcu warnings induced by LER") accesses adapter after free_netdev(). The patch stores the result in a bool and thus fixes above oops on my side. Fixes: 41c62843eb6a ("ixgbe: Fix rcu warnings induced by LER") Cc: stable <stable@vger.kernel.org> Cc: Mark Rustad <mark.d.rustad@intel.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
