commit 308aa2b8f7b7db3332a7d41099fd37851fb793b2 upstream.
Once the qp has been flushed, it cannot be flushed again. The user qp
flush logic wasn't enforcing it however. The bug can cause
touch-after-free crashes like:
Unable to handle kernel paging request for data at address 0x000001ec
Faulting instruction address: 0xc008000016069100
Oops: Kernel access of bad area, sig: 11 [#1]
NIP [c008000016069100] flush_qp+0x80/0x480 [iw_cxgb4]
LR [c00800001606cd6c] c4iw_modify_qp+0x71c/0x11d0 [iw_cxgb4]
Call Trace:
[c00800001606e868] c4iw_ib_modify_qp+0x118/0x200 [iw_cxgb4]
[c0080000119eae80] ib_security_modify_qp+0xd0/0x3d0 [ib_core]
[c0080000119c4e24] ib_modify_qp+0xc4/0x2c0 [ib_core]
[c008000011df0284] iwcm_modify_qp_err+0x44/0x70 [iw_cm]
[c008000011df0fec] destroy_cm_id+0xcc/0x370 [iw_cm]
[c008000011ed4358] rdma_destroy_id+0x3c8/0x520 [rdma_cm]
[c0080000134b0540] ucma_close+0x90/0x1b0 [rdma_ucm]
[c000000000444da4] __fput+0xe4/0x2f0
So fix flush_qp() to only flush the wq once.
Cc: stable@vger.kernel.org
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
commit de66a1a04c25f2560a8dca7a95e2a150b0d5e17e upstream.
Add support for USB based DS4 dongle device, which allows connecting
a DS4 through Bluetooth, but hides Bluetooth from the host system.
Signed-off-by: Roderick Colenbrander <roderick.colenbrander@sony.com>
commit cf1015d65d7c8a5504a4c03afb60fb86bff0f032 upstream.
Support additional DS4 model.
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit e97267cb4d1ee01ca0929638ec0fcbb0904f903d upstream.
vsa.console is indirectly controlled by user-space, hence leading to
a potential exploitation of the Spectre variant 1 vulnerability.
This issue was detected with the help of Smatch:
drivers/tty/vt/vt_ioctl.c:711 vt_ioctl() warn: potential spectre issue
'vc_cons' [r]
Fix this by sanitizing vsa.console before using it to index vc_cons
Notice that given that speculation windows are large, the policy is
to kill the speculation on the first load and not worry if it can be
completed with a dependent load/store [1].
[1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Reviewed-by: Alan Cox <alan@linux.intel.com>
commit 6833fb1ec120bf078e1a527c573a09d4de286224 upstream.
It's true we can't resume the device from poll workers in
nouveau_connector_detect(). We can however, prevent the autosuspend
timer from elapsing immediately if it hasn't already without risking any
sort of deadlock with the runtime suspend/resume operations. So do that
instead of entirely avoiding grabbing a power reference.
Signed-off-by: Lyude Paul <lyude@redhat.com>
Reviewed-by: Karol Herbst <kherbst@redhat.com>
Acked-by: Daniel Vetter <daniel@ffwll.ch>
Cc: Lukas Wunner <lukas@wunner.de>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit 1816494330a83f2a064499d8ed2797045641f92c upstream.
This change has the following effects, in order of descreasing importance:
1) Prevent a stack buffer overflow
2) Do not append an unnecessary NULL to an anyway binary buffer, which
is writing one byte past client_digest when caller is:
chap_string_to_hex(client_digest, chap_r, strlen(chap_r));
The latter was found by KASAN (see below) when input value hes expected size
(32 hex chars), and further analysis revealed a stack buffer overflow can
happen when network-received value is longer, allowing an unauthenticated
remote attacker to smash up to 17 bytes after destination buffer (16 bytes
attacker-controlled and one null). As switching to hex2bin requires
specifying destination buffer length, and does not internally append any null,
it solves both issues.
This addresses CVE-2018-14633.
Beyond this:
- Validate received value length and check hex2bin accepted the input, to log
this rejection reason instead of just failing authentication.
- Only log received CHAP_R and CHAP_C values once they passed sanity checks.
BUG: KASAN: stack-out-of-bounds in chap_string_to_hex+0x32/0x60 [iscsi_target_mod]
Write of size 1 at addr ffff8801090ef7c8 by task kworker/0:0/1021
CPU: 0 PID: 1021 Comm: kworker/0:0 Tainted: G O 4.17.8kasan.sess.connops+ #2
Hardware name: To be filled by O.E.M. To be filled by O.E.M./Aptio CRB, BIOS 5.6.5 05/19/2014
Workqueue: events iscsi_target_do_login_rx [iscsi_target_mod]
Call Trace:
dump_stack+0x71/0xac
print_address_description+0x65/0x22e
? chap_string_to_hex+0x32/0x60 [iscsi_target_mod]
kasan_report.cold.6+0x241/0x2fd
chap_server_compute_md5.isra.2+0x2cb/0x860 [iscsi_target_mod]
? chap_binaryhex_to_asciihex.constprop.5+0x50/0x50 [iscsi_target_mod]
? ftrace_caller_op_ptr+0xe/0xe
? __orc_find+0x6f/0xc0
? unwind_next_frame+0x231/0x850
? kthread+0x1a0/0x1c0
? ret_from_fork+0x35/0x40
? iscsi_target_do_login_rx+0x3bc/0x4c0 [iscsi_target_mod]
? deref_stack_reg+0xd0/0xd0
? is_module_text_address+0xa/0x11
? kernel_text_address+0x4c/0x110
? __save_stack_trace+0x82/0x100
? save_stack+0x8c/0xb0
? 0xffffffffc1660000
? iscsi_target_do_login+0x155/0x8d0 [iscsi_target_mod]
? process_one_work+0x35c/0x640
? worker_thread+0x66/0x5d0
? iscsi_update_param_value+0x80/0x80 [iscsi_target_mod]
? iscsit_release_cmd+0x170/0x170 [iscsi_target_mod]
chap_main_loop+0x172/0x570 [iscsi_target_mod]
? chap_server_compute_md5.isra.2+0x860/0x860 [iscsi_target_mod]
? rx_data+0xd6/0x120 [iscsi_target_mod]
? iscsit_print_session_params+0xd0/0xd0 [iscsi_target_mod]
? cyc2ns_read_begin.part.2+0x90/0x90
? _raw_spin_lock_irqsave+0x25/0x50
? memcmp+0x45/0x70
iscsi_target_do_login+0x875/0x8d0 [iscsi_target_mod]
? iscsi_target_check_first_request.isra.5+0x1a0/0x1a0 [iscsi_target_mod]
? del_timer+0xe0/0xe0
? memset+0x1f/0x40
? flush_sigqueue+0x29/0xd0
? iscsi_target_nego_release+0x80/0x80 [iscsi_target_mod]
? iscsi_target_restore_sock_callbacks+0x130/0x130 [iscsi_target_mod]
? flush_rcu_work+0x40/0x40
kthread+0x1a0/0x1c0
? kthread_bind+0x30/0x30
The buggy address belongs to the page:
page:ffffea0004243bc0 count:0 mapcount:0 mapping:0000000000000000 index:0x0
flags: 0x17fffc000000000()
raw: 017fffc000000000 0000000000000000 0000000000000000 00000000ffffffff
raw: ffffea0004243c20 ffffea0004243ba0 0000000000000000 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8801090ef680: f2 f2 f2 f2 f2 f2 f2 01 f2 f2 f2 f2 f2 f2 f2 00
ffff8801090ef700: f2 f2 f2 f2 f2 f2 f2 00 02 f2 f2 f2 f2 f2 f2 00
>ffff8801090ef780: 00 f2 f2 f2 f2 f2 f2 00 00 f2 f2 f2 f2 f2 f2 00
ffff8801090ef800: 00 f2 f2 f2 f2 f2 f2 00 00 00 00 02 f2 f2 f2 f2
ffff8801090ef880: f2 f2 f2 00 00 00 00 00 00 00 00 f2 f2 f2 f2 00
Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com>
Reviewed-by: Mike Christie <mchristi@redhat.com>
[ Upstream commit a7f38002fb69b44f8fc622ecb838665d0b8666af ]
The operation ~(p100_inb(VG_LAN_CFG_1) & HP100_LINK_UP) returns a value
that is always non-zero and hence the wait for the link to drop always
terminates prematurely. Fix this by using a logical not operator instead
of a bitwise complement. This issue has been in the driver since
pre-2.6.12-rc2.
Detected by CoverityScan, CID#114157 ("Logical vs. bitwise operator")
[ Upstream commit 9824dfae5741275473a23a7ed5756c7b6efacc9d ]
Fields ->dev and ->next of struct ipddp_route may be copied to
userspace on the SIOCFINDIPDDPRT ioctl. This is only accessible
to CAP_NET_ADMIN though. Let's manually copy the relevant fields
instead of using memcpy().
BugLink: http://blog.infosectcbr.com.au/2018/09/linux-kernel-infoleaks.html
Cc: Jann Horn <jannh@google.com>
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit ad4f15dc2c70b1de5e0a64d27335962fbc9cf71c upstream.
Commit 57f230ab04d291 ("xen/netfront: raise max number of slots in
xennet_get_responses()") raised the max number of allowed slots by one.
This seems to be problematic in some configurations with netback using
a larger MAX_SKB_FRAGS value (e.g. old Linux kernel with MAX_SKB_FRAGS
defined as 18 instead of nowadays 17).
Instead of BUG_ON() in this case just fall back to retransmission.
Fixes: 57f230ab04d291 ("xen/netfront: raise max number of slots in xennet_get_responses()")
Signed-off-by: Juergen Gross <jgross@suse.com>
commit ff0e9f26288d2daee4950f42b37a3d3d30d36ec1 upstream.
An ACPI buffer that was allocated was not being freed after use.
Signed-off-by: Mario Limonciello <mario.limonciello@dell.com>
Signed-off-by: Darren Hart (VMware) <dvhart@infradead.org>
commit d733f7542ad47cf73e033c90cf55158587e1d060 upstream.
If an emac node has a phy-handle property that points to something
which is not a phy, then a segmentation fault will occur when the
interface is brought up. This is because while phy_connect() will
return ERR_PTR() on failure, of_phy_connect() will return NULL.
The common error check uses IS_ERR(), and so missed when
of_phy_connect() fails. The NULL pointer is then dereferenced.
Also, the common error message referenced slave->data->phy_id,
which would be empty in the case of phy-handle. Instead, use the
name of the device_node as a useful identifier. And in the phy_id
case add the error code for completeness.
Fixes: 9e42f715264f ("drivers: net: cpsw: add phy-handle parsing")
Signed-off-by: David Rivshin <drivshin@allworx.com>
[SZ Lin (林上智): Tweak the patch to use original print function of dev_info()]
Signed-off-by: SZ Lin (林上智) <sz.lin@moxa.com>
commit b40b3e9358fbafff6a4ba0f4b9658f6617146f9c upstream.
We accidentally removed the check for negative returns
without considering the issue of type promotion.
The "if_version_length" variable is type size_t so if __mei_cl_recv()
returns a negative then "bytes_recv" is type promoted
to a high positive value and treated as success.
Cc: <stable@vger.kernel.org>
Fixes: 582ab27a063a ("mei: bus: fix received data size check in NFC fixup")
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
commit 5dfdd24eb3d39d815bc952ae98128e967c9bba49 upstream.
Similarly to a recently reported bug in io_ti, a malicious USB device
could set port_number to a negative value and we would underflow the
port array in the interrupt completion handler.
As these devices only have one or two ports, fix this by making sure we
only consider the seventh bit when determining the port number (and
ignore bits 0xb0 which are typically set to 0x30).
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Johan Hovold <johan@kernel.org>
[ Upstream commit 1cf86bc21257a330e3af51f2a4e885f1a705f6a5 ]
If you do this on an sdm845 board:
grep "" /sys/kernel/debug/pinctrl/*spmi:pmic*/pinconf-groups
...it looks like nonsense. For every pin you see listed:
input bias disabled, input bias high impedance, input bias pull down, input bias pull up, ...
That's because pmic_gpio_config_get() isn't complying with the rules
that pinconf_generic_dump_one() expects. Specifically for boolean
parameters (anything with a "struct pin_config_item" where has_arg is
false) the function expects that the function should return its value
not through the "config" parameter but should return "0" if the value
is set and "-EINVAL" if the value isn't set.
Let's fix this.
>From a quick sample of other pinctrl drivers, it appears to be
tradition to also return 1 through the config parameter for these
boolean parameters when they exist. I'm not one to knock tradition,
so I'll follow tradition and return 1 in these cases. While I'm at
it, I'll also continue searching for four leaf clovers, kocking on
wood three times, and trying not to break mirrors.
NOTE: This also fixes an apparent typo for reading
PIN_CONFIG_BIAS_DISABLE where the old driver was accidentally
using "=" instead of "==" and thus was setting some internal
state when you tried to query PIN_CONFIG_BIAS_DISABLE. Oops.
Fixes: eadff3024472 ("pinctrl: Qualcomm SPMI PMIC GPIO pin controller driver")
Signed-off-by: Douglas Anderson <dianders@chromium.org>
[ Upstream commit cd0e0ca69109d025b1a1b6609f70682db62138b0 ]
The ARRAY_SIZE() macro is type size_t. If s6e8aa0_dcs_read() returns a
negative error code, then "ret < ARRAY_SIZE(id)" is false because the
negative error code is type promoted to a high positive value.
Fixes: 02051ca06371 ("drm/panel: add S6E8AA0 driver")
Reviewed-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180704093807.s3lqsb2v6dg2k43d@kili.mountain
[ Upstream commit 7874b919866ba91bac253fa219d3d4c82bb944df ]
When devm_ioremap fails, the lack of error-handling code may
cause unexpected results.
This patch adds error-handling code after calling devm_ioremap.
Signed-off-by: Zhouyang Jia <jiazhouyang09@gmail.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
[ Upstream commit e47cb828eb3fca3e8999a0b9aa053dda18552071 ]
Return ERR_PTR(-EINVAL) if kfd_get_process fails to find the process.
This fixes kernel oopses when a child process calls KFD ioctls with
a file descriptor inherited from the parent process.
Signed-off-by: Wei Lu <wei.lu2@amd.com>
Reviewed-by: Felix Kuehling <Felix.Kuehling@amd.com>
Signed-off-by: Felix Kuehling <Felix.Kuehling@amd.com>
Acked-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Oded Gabbay <oded.gabbay@gmail.com>
[ Upstream commit b23ec59926faf05b0c43680d05671c484e810ac4 ]
Since we put static variable to a header file it's copied to each module
that includes the header. But not all of them are actually used it.
Mark gpio_suffixes array with __maybe_unused to hide a compiler warning:
In file included from
drivers/gpio/gpiolib-legacy.c:6:0:
drivers/gpio/gpiolib.h:95:27: warning: ‘gpio_suffixes’ defined but not used [-Wunused-const-variable=]
static const char * const gpio_suffixes[] = { "gpios", "gpio" };
In file included from drivers/gpio/gpiolib-devprop.c:17:0:
[ Upstream commit ccff2dfaceaca4517432f5c149594215fe9098cc ]
Probing the TPIU driver under UBSan triggers an out-of-bounds shift
warning in coresight_timeout():
[ 5.677530] UBSAN: Undefined behaviour in drivers/hwtracing/coresight/coresight.c:929:16
[ 5.685542] shift exponent 64 is too large for 64-bit type 'long unsigned int'
On closer inspection things are exponentially out of whack because we're
passing a bitmask where a bit number should be. Amusingly, it seems that
both calls will find their expected values by sheer luck and appear to
succeed: 1 << FFCR_FON_MAN ends up at bit 64 which whilst undefined
evaluates as zero in practice, while 1 << FFSR_FT_STOPPED finds bit 2
(TCPresent) which apparently is usually tied high.
Following the examples of other drivers, define separate FOO and FOO_BIT
macros for masks vs. indices, and put things right.
CC: Robert Walker <robert.walker@arm.com>
CC: Mike Leach <mike.leach@linaro.org>
CC: Mathieu Poirier <mathieu.poirier@linaro.org>
Fixes: 11595db8e17f ("coresight: Fix disabling of CoreSight TPIU")
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
[ Upstream commit fe470f5f7f684ed15bc49b6183a64237547910ff ]
If we fail to find the input / output port for a LINK component
while enabling a path, we should fail gracefully rather than
assuming port "0".
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
[ Upstream commit faa1a47388b33623e4d504c23569188907b039a0 ]
Return an error code on failure. Change leading spaces to tab on the
first if.
Problem found using Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
[ Upstream commit b59fb482b52269977ee5de205308e5b236a03917 ]
Depending on the kernel configuration, early ARM architecture setup code
may have attached the GPU to a DMA/IOMMU mapping that transparently uses
the IOMMU to back the DMA API. Tegra requires special handling for IOMMU
backed buffers (a special bit in the GPU's MMU page tables indicates the
memory path to take: via the SMMU or directly to the memory controller).
Transparently backing DMA memory with an IOMMU prevents Nouveau from
properly handling such memory accesses and causes memory access faults.
As a side-note: buffers other than those allocated in instance memory
don't need to be physically contiguous from the GPU's perspective since
the GPU can map them into contiguous buffers using its own MMU. Mapping
these buffers through the IOMMU is unnecessary and will even lead to
performance degradation because of the additional translation. One
exception to this are compressible buffers which need large pages. In
order to enable these large pages, multiple small pages will have to be
combined into one large (I/O virtually contiguous) mapping via the
IOMMU. However, that is a topic outside the scope of this fix and isn't
currently supported. An implementation will want to explicitly create
these large pages in the Nouveau driver, so detaching from a DMA/IOMMU
mapping would still be required.
Acked-by: Christoph Hellwig <hch@lst.de>
Reviewed-by: Robin Murphy <robin.murphy@arm.com>
Tested-by: Nicolas Chauvet <kwizart@gmail.com>
[ Upstream commit 6c6bc9ea84d0008024606bf5ba10519e20d851bf ]
The first checks in mtdchar_read() and mtdchar_write() attempt to limit
`count` such that `*ppos + count <= mtd->size`. However, they ignore the
possibility of `*ppos > mtd->size`, allowing the calculation of `count` to
wrap around. `mtdchar_lseek()` prevents seeking beyond mtd->size, but the
pread/pwrite syscalls bypass this.
I haven't found any codepath on which this actually causes dangerous
behavior, but it seems like a sensible change anyway.
Signed-off-by: Jann Horn <jannh@google.com>
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
service_outstanding_interrupt()
commit 6e22e3af7bb3a7b9dc53cb4687659f6e63fca427 upstream.
wdm_in_callback() is a completion handler function for the USB driver.
So it should not sleep. But it calls service_outstanding_interrupt(),
which calls usb_submit_urb() with GFP_KERNEL.
To fix this bug, GFP_KERNEL is replaced with GFP_ATOMIC.
This bug is found by my static analysis tool DSAC.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
commit 7e10f14ebface44a48275c8d6dc1caae3668d5a9 upstream.
If the written data starts with a digit, yurex_write() tries to parse
it as an integer using simple_strtoull(). This requires a null-
terminator, and currently there's no guarantee that there is one.
(The sample program at
https://github.com/NeoCat/YUREX-driver-for-Linux/blob/master/sample/yurex_clock.pl
writes an integer without a null terminator. It seems like it must
have worked by chance!)
Always add a null byte after the written data. Enlarge the buffer
to allow for this.
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit bc8acc214d3f1cafebcbcd101a695bbac716595d upstream.
async_complete() in uss720.c is a completion handler function for the
USB driver. So it should not sleep, but it is can sleep according to the
function call paths (from bottom to top) in Linux-4.16.
[FUNC] set_1284_register(GFP_KERNEL)
drivers/usb/misc/uss720.c, 372:
set_1284_register in parport_uss720_frob_control
drivers/parport/ieee1284.c, 560:
[FUNC_PTR]parport_uss720_frob_control in parport_ieee1284_ack_data_avail
drivers/parport/ieee1284.c, 577:
parport_ieee1284_ack_data_avail in parport_ieee1284_interrupt
./include/linux/parport.h, 474:
parport_ieee1284_interrupt in parport_generic_irq
drivers/usb/misc/uss720.c, 116:
parport_generic_irq in async_complete
[FUNC] get_1284_register(GFP_KERNEL)
drivers/usb/misc/uss720.c, 382:
get_1284_register in parport_uss720_read_status
drivers/parport/ieee1284.c, 555:
[FUNC_PTR]parport_uss720_read_status in parport_ieee1284_ack_data_avail
Note that [FUNC_PTR] means a function pointer call is used.
To fix these bugs, GFP_KERNEL is replaced with GFP_ATOMIC.
These bugs are found by my static analysis tool DSAC.
commit 691a03cfe8ca483f9c48153b869d354e4ae3abef upstream.
As reported by Dan Carpenter, a malicious USB device could set
port_number to a negative value and we would underflow the port array in
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
commit dec3c23c9aa1815f07d98ae0375b4cbc10971e13 upstream.
Commit f16443a034c7 ("USB: gadgetfs, dummy-hcd, net2280: fix locking
for callbacks") was based on a serious misunderstanding. It
introduced regressions into both the dummy-hcd and net2280 drivers.
The problem in dummy-hcd was fixed by commit 7dbd8f4cabd9 ("USB:
dummy-hcd: Fix erroneous synchronization change"), but the problem in
net2280 remains. Namely: the ->disconnect(), ->suspend(), ->resume(),
and ->reset() callbacks must be invoked without the private lock held;
otherwise a deadlock will occur when the callback routine tries to
interact with the UDC driver.
This patch largely is a reversion of the relevant parts of
f16443a034c7. It also drops the private lock around the calls to
->suspend() and ->resume() (something the earlier patch forgot to do).
This is safe from races with device interrupts because it occurs
within the interrupt handler.
Finally, the patch changes where the ->disconnect() callback is
invoked when net2280_pullup() turns the pullup off. Rather than
making the callback from within stop_activity() at a time when dropping
the private lock could be unsafe, the callback is moved to a point
after the lock has already been dropped.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Fixes: f16443a034c7 ("USB: gadgetfs, dummy-hcd, net2280: fix locking for callbacks")
Reported-by: D. Ziesche <dziesche@zes.com>
Tested-by: D. Ziesche <dziesche@zes.com>
CC: <stable@vger.kernel.org>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit 9b83a1c301ad6d24988a128c69b42cbaaf537d82 upstream.
WORLDE Controller KS49 or Prodipe MIDI 49C USB controller
cause a -EPROTO error, a communication restart and loop again.
This issue has already been fixed for KS25.
https://lore.kernel.org/patchwork/patch/753077/
I just add device 201 for KS49 in quirks.c to get it works.
Signed-off-by: Laurent Roux <xpros64@hotmail.fr>
commit 6d4f268fa132742fe96dad22307c68d237356d88 upstream.
i_usX2Y_subs_startup in usbusx2yaudio.c is a completion handler function
for the USB driver. So it should not sleep, but it is can sleep
according to the function call paths (from bottom to top) in Linux-4.16.
[FUNC] msleep
drivers/usb/host/u132-hcd.c, 2558:
msleep in u132_get_frame
drivers/usb/core/hcd.c, 2231:
[FUNC_PTR]u132_get_frame in usb_hcd_get_frame_number
drivers/usb/core/usb.c, 822:
usb_hcd_get_frame_number in usb_get_current_frame_number
sound/usb/usx2y/usbusx2yaudio.c, 303:
usb_get_current_frame_number in i_usX2Y_urb_complete
sound/usb/usx2y/usbusx2yaudio.c, 366:
i_usX2Y_urb_complete in i_usX2Y_subs_startup
To fix this bug, msleep() is replaced with mdelay().
commit f9a5b4f58b280c1d26255376713c132f93837621 upstream.
The steps taken by usb core to set a new interface is very different from
what is done on the xHC host side.
xHC hardware will do everything in one go. One command is used to set up
new endpoints, free old endpoints, check bandwidth, and run the new
endpoints.
All this is done by xHC when usb core asks the hcd to check for
available bandwidth. At this point usb core has not yet flushed the old
endpoints, which will cause use-after-free issues in xhci driver as
queued URBs are cancelled on a re-allocated endpoint.
To resolve this add a call to usb_disable_interface() which will flush
the endpoints before calling usb_hcd_alloc_bandwidth()
Additional checks in xhci driver will also be implemented to gracefully
handle stale URB cancel on freed and re-allocated endpoints
Reported-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit f45681f9becaa65111ed0a691ccf080a0cd5feb8 upstream.
This device does not correctly handle the LPM operations.
Also, the device cannot handle ATA pass-through commands
and locks up when attempted while running in super speed.
This patch adds the equivalent quirk logic as found in uas.
Signed-off-by: Tim Anderson <tsa@biglakesoftware.com>
commit f3dc41c5d22b2ca14a0802a65d8cdc33a3882d4e upstream.
usb_hc_died() should only be called once, and with the primary HCD
as parameter. It will mark both primary and secondary hcd's dead.
Remove the extra call to usb_cd_died with the shared hcd as parameter.
Fixes: ff9d78b36f76 ("USB: Set usb_hcd->state and flags for shared roothubs")
commit de916736aaaadddbd6061472969f667b14204aa9 upstream.
val is indirectly controlled by user-space, hence leading to a
drivers/misc/hmc6352.c:54 compass_store() warn: potential spectre issue
'map' [r]
Fix this by sanitizing val before using it to index map
commit 816e846c2eb9129a3e0afa5f920c8bbc71efecaa upstream.
Inside of start_xmit() the call to check if the connection is up and the
queueing of the packets for later transmission is not atomic which leaves
a window where cm_rep_handler can run, set the connection up, dequeue
pending packets and leave the subsequently queued packets by start_xmit()
sitting on neigh->queue until they're dropped when the connection is torn
down. This only applies to connected mode. These dropped packets can
really upset TCP, for example, and cause multi-minute delays in
transmission for open connections.
Here's the code in start_xmit where we check to see if the connection is
up:
if (ipoib_cm_get(neigh)) {
if (ipoib_cm_up(neigh)) {
ipoib_cm_send(dev, skb, ipoib_cm_get(neigh));
goto unref;
The race occurs if cm_rep_handler execution occurs after the above
connection check (specifically if it gets to the point where it acquires
priv->lock to dequeue pending skb's) but before the below code snippet in
start_xmit where packets are queued.
if (skb_queue_len(&neigh->queue) < IPOIB_MAX_PATH_REC_QUEUE) {
push_pseudo_header(skb, phdr->hwaddr);
spin_lock_irqsave(&priv->lock, flags);
__skb_queue_tail(&neigh->queue, skb);
spin_unlock_irqrestore(&priv->lock, flags);
} else {
++dev->stats.tx_dropped;
dev_kfree_skb_any(skb);
The patch acquires the netif tx lock in cm_rep_handler for the section
where it sets the connection up and dequeues and retransmits deferred
skb's.
Fixes: 839fcaba355a ("IPoIB: Connected mode experimental support")
Signed-off-by: Aaron Knister <aaron.s.knister@nasa.gov>
Tested-by: Ira Weiny <ira.weiny@intel.com>
Reviewed-by: Ira Weiny <ira.weiny@intel.com>
commit 8edfe2e992b75aee3da9316e9697c531194c2f53 upstream.
Commit 822fb18a82aba ("xen-netfront: wait xenbus state change when load
module manually") added a new wait queue to wait on for a state change
when the module is loaded manually. Unfortunately there is no wakeup
anywhere to stop that waiting.
Instead of introducing a new wait queue rename the existing
module_unload_q to module_wq and use it for both purposes (loading and
unloading).
As any state change of the backend might be intended to stop waiting
do the wake_up_all() in any case when netback_changed() is called.
Fixes: 822fb18a82aba ("xen-netfront: wait xenbus state change when load module manually")
Cc: <stable@vger.kernel.org> #4.18
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
commit 954a8e3aea87e896e320cf648c1a5bbe47de443e upstream.
When AF_IB addresses are used during rdma_resolve_addr() a lock is not
held. A cma device can get removed while list traversal is in progress
which may lead to crash. ie
CPU0 CPU1
rdma_resolve_addr()
cma_resolve_ib_dev()
list_for_each() cma_remove_one()
cur_dev->device mutex_lock(&lock)
list_del();
mutex_unlock(&lock);
cma_process_remove();
Therefore, hold a lock while traversing the list which avoids such
situation.
Cc: <stable@vger.kernel.org> # 3.10
Fixes: f17df3b0dede ("RDMA/cma: Add support for AF_IB to rdma_resolve_addr()")
Signed-off-by: Parav Pandit <parav@mellanox.com>
Reviewed-by: Daniel Jurgens <danielj@mellanox.com>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
[ Upstream commit 21f2706b20100bb3db378461ab9b8e2035309b5b ]
There is a call trace generated after commit 2d408c0d4574b01b9ed45e02516888bf925e11a9(
xen-netfront: fix queue name setting). There is no 'device/vif/xx-q0-tx' file found
under /proc/irq/xx/.
This patch only picks up device type and id as its name.
With the patch, now /proc/interrupts looks like below and the warning message gone:
70: 21 0 0 0 xen-dyn -event vif0-q0-tx
71: 15 0 0 0 xen-dyn -event vif0-q0-rx
72: 14 0 0 0 xen-dyn -event vif0-q1-tx
73: 33 0 0 0 xen-dyn -event vif0-q1-rx
74: 12 0 0 0 xen-dyn -event vif0-q2-tx
75: 24 0 0 0 xen-dyn -event vif0-q2-rx
76: 19 0 0 0 xen-dyn -event vif0-q3-tx
77: 21 0 0 0 xen-dyn -event vif0-q3-rx
Below is call trace information without this patch:
name 'device/vif/0-q0-tx'
WARNING: CPU: 2 PID: 37 at fs/proc/generic.c:174 __xlate_proc_name+0x85/0xa0
RIP: 0010:__xlate_proc_name+0x85/0xa0
RSP: 0018:ffffb85c40473c18 EFLAGS: 00010286
RAX: 0000000000000000 RBX: 0000000000000006 RCX: 0000000000000006
RDX: 0000000000000007 RSI: 0000000000000096 RDI: ffff984c7f516930
RBP: ffffb85c40473cb8 R08: 000000000000002c R09: 0000000000000229
R10: 0000000000000000 R11: 0000000000000001 R12: ffffb85c40473c98
R13: ffffb85c40473cb8 R14: ffffb85c40473c50 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff984c7f500000(0000) knlGS:0000000000000000
CR2: 00007f69b6899038 CR3: 000000001c20a006 CR4: 00000000001606e0
Call Trace:
__proc_create+0x45/0x230
? snprintf+0x49/0x60
proc_mkdir_data+0x35/0x90
register_handler_proc+0xef/0x110
? proc_register+0xfc/0x110
? proc_create_data+0x70/0xb0
__setup_irq+0x39b/0x660
? request_threaded_irq+0xad/0x160
request_threaded_irq+0xf5/0x160
? xennet_tx_buf_gc+0x1d0/0x1d0 [xen_netfront]
bind_evtchn_to_irqhandler+0x3d/0x70
? xenbus_alloc_evtchn+0x41/0xa0
netback_changed+0xa46/0xcda [xen_netfront]
? find_watch+0x40/0x40
xenwatch_thread+0xc5/0x160
? finish_wait+0x80/0x80
kthread+0x112/0x130
? kthread_create_worker_on_cpu+0x70/0x70
Code: 81 5c 00 48 85 c0 75 cc 5b 49 89 2e 31 c0 5d 4d 89 3c 24 41 5c 41 5d 41 5e 41 5f c3 4c 89 ee 48 c7 c7 40 4f 0e b4 e8 65 ea d8 ff <0f> 0b b8 fe ff ff ff 5b 5d 41 5c 41 5d 41 5e 41 5f c3 66 0f 1f
---[ end trace 650e5561b0caab3a ]---
Signed-off-by: Xiao Liang <xiliang@redhat.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
[ Upstream commit 0e7d4d932ffc23f75efb31a8c2ac2396c1b81c55 ]
This patch fixes two typos related to unregistering algorithms supported by
SAHARAH 3. In sahara_register_algs the wrong algorithms are unregistered
in case of an error. In sahara_unregister_algs the wrong array is used to
determine the iteration count.
Signed-off-by: Michael Müller <michael@fds-team.de>
[ Upstream commit c2e2a618eb7104e18fdcf739d4d911563812a81c ]
Fix a build warning in toshiba_acpi.c when CONFIG_PROC_FS is not enabled
by marking the unused function as __maybe_unused.
../drivers/platform/x86/toshiba_acpi.c:1685:12: warning: 'version_proc_show' defined but not used [-Wunused-function]
Cc: Azael Avalos <coproscefalo@gmail.com>
Cc: platform-driver-x86@vger.kernel.org
Cc: Andy Shevchenko <andy@infradead.org>
[ Upstream commit 70551dc46ffa3555a0b5f3545b0cd87ab67fd002 ]
After the subdriver's remove() routine has completed, the card's layer
mode is undetermined again. Reflect this in the layer2 field.
If qeth_dev_layer2_store() hits an error after remove() was called, the
card _always_ requires a setup(), even if the previous layer mode is
requested again.
But qeth_dev_layer2_store() bails out early if the requested layer mode
still matches the current one. So unless we reset the layer2 field,
re-probing the card back to its previous mode is currently not possible.
Signed-off-by: Julian Wiedmann <jwi@linux.ibm.com>
[ Upstream commit a702349a4099cd5a7bab0904689d8e0bf8dcd622 ]
By updating q->used_buffers only _after_ do_QDIO() has completed, there
is a potential race against the buffer's TX completion. In the unlikely
case that the TX completion path wins, qeth_qdio_output_handler() would
decrement the counter before qeth_flush_buffers() even incremented it.
[ Upstream commit 2d408c0d4574b01b9ed45e02516888bf925e11a9 ]
Commit f599c64fdf7d ("xen-netfront: Fix race between device setup and
open") changed the initialization order: xennet_create_queues() now
happens before we do register_netdev() so using netdev->name in
xennet_init_queue() is incorrect, we end up with the following in
/proc/interrupts:
60: 139 0 xen-dyn -event eth%d-q0-tx
61: 265 0 xen-dyn -event eth%d-q0-rx
62: 234 0 xen-dyn -event eth%d-q1-tx
63: 1 0 xen-dyn -event eth%d-q1-rx
and this looks ugly. Actually, using early netdev name (even when it's
already set) is also not ideal: nowadays we tend to rename eth devices
and queue name may end up not corresponding to the netdev name.
Use nodename from xenbus device for queue naming: this can't change in VM's
lifetime. Now /proc/interrupts looks like
62: 202 0 xen-dyn -event device/vif/0-q0-tx
63: 317 0 xen-dyn -event device/vif/0-q0-rx
64: 262 0 xen-dyn -event device/vif/0-q1-tx
65: 17 0 xen-dyn -event device/vif/0-q1-rx
Fixes: f599c64fdf7d ("xen-netfront: Fix race between device setup and open")
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Reviewed-by: Ross Lagerwall <ross.lagerwall@citrix.com>
[ Upstream commit 1ba0a59cea41ea05fda92daaf2a2958a2246b9cf ]
I discovered the problem when developing a frame buffer driver for the
PlayStation 2 (not yet merged), using the following video modes for the
PlayStation 3 in drivers/video/fbdev/ps3fb.c:
/* 1080if */
"1080if", 50, 1920, 1080, 13468, 148, 484, 36, 4, 88, 5,
FB_SYNC_BROADCAST, FB_VMODE_INTERLACED
/* 1080pf */
"1080pf", 50, 1920, 1080, 6734, 148, 484, 36, 4, 88, 5,
FB_SYNC_BROADCAST, FB_VMODE_NONINTERLACED
In ps3fb_probe, the mode_option module parameter is used with fb_find_mode
but it can only select the interlaced variant of 1920x1080 since the loop
matching the modes does not take the difference between interlaced and
progressive modes into account.
In short, without the patch, progressive 1920x1080 cannot be chosen as a
mode_option parameter since fb_find_mode (falsely) thinks interlace is a
perfect match.
Signed-off-by: Fredrik Noring <noring@nocrew.org>
Cc: "Maciej W. Rozycki" <macro@linux-mips.org>
[b.zolnierkie: updated patch description]
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
[ Upstream commit b6566b47a67e07fdca44cf51abb14e2fbe17d3eb ]
Fix a build warning in viafbdev.c when CONFIG_PROC_FS is not enabled
../drivers/video/fbdev/via/viafbdev.c:1471:12: warning: 'viafb_sup_odev_proc_show' defined but not used [-Wunused-function]
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
[ Upstream commit 5958fde72d04e7b8c6de3669d1f794a90997e3eb ]
goldfish_fb_probe() allocates memory for fb, but goldfish_fb_remove() does
not have deallocation of fb, which leads to memory leak on probe/remove.
The patch adds deallocation into goldfish_fb_remove().
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Anton Vasilyev <vasilyev@ispras.ru>
Cc: Aleksandar Markovic <aleksandar.markovic@mips.com>
Cc: Miodrag Dinic <miodrag.dinic@mips.com>
Cc: Goran Ferenc <goran.ferenc@mips.com>
[ Upstream commit 5ec1ec35b2979b59d0b33381e7c9aac17e159d16 ]
The omapfb_register_client[] array has OMAPFB_PLANE_NUM elements so the
> should be >= or we are one element beyond the end of the array.
Fixes: 8b08cf2b64f5 ("OMAP: add TI OMAP framebuffer driver")
Cc: Imre Deak <imre.deak@solidboot.com>
[ Upstream commit 1d25e3eeed1d987404e2d2e451eebac8c15cecc1 ]
Fix 2 printk format warnings (this driver is currently only used by
arch/sh/) by using "%pap" instead of "%lx".
Fixes these build warnings:
../drivers/mtd/maps/solutionengine.c: In function 'init_soleng_maps':
../include/linux/kern_levels.h:5:18: warning: format '%lx' expects argument of type 'long unsigned int', but argument 2 has type 'resource_size_t' {aka 'unsigned int'} [-Wformat=]
../drivers/mtd/maps/solutionengine.c:62:54: note: format string is defined here
printk(KERN_NOTICE "Solution Engine: Flash at 0x%08lx, EPROM at 0x%08lx\n",
%08x
../include/linux/kern_levels.h:5:18: warning: format '%lx' expects argument of type 'long unsigned int', but argument 3 has type 'resource_size_t' {aka 'unsigned int'} [-Wformat=]
../drivers/mtd/maps/solutionengine.c:62:72: note: format string is defined here
%08x
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Boris Brezillon <boris.brezillon@bootlin.com>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: linux-mtd@lists.infradead.org
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Rich Felker <dalias@libc.org>
Cc: linux-sh@vger.kernel.org
Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit b509d733d337417bcb7fa4a35be3b9a49332b724 ]
The vb2_core_qbuf() function didn't check if q->error was set. It is
checked in __buf_prepare(), but that function isn't called if the buffer
was already prepared before with VIDIOC_PREPARE_BUF.
So check it at the start of vb2_core_qbuf() as well.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
[ Upstream commit e49756544a21f5625b379b3871d27d8500764670 ]
In pl330_update() when checking if a channel has been aborted, the
channel's lock is not taken, only the overall pl330_dmac lock. But in
pl330_terminate_all() the aborted flag (req_running==-1) is set under
the channel lock and not the pl330_dmac lock.
With threaded interrupts, this leads to a potential race:
pl330_terminate_all pl330_update
lock channel
entry
lock pl330
_stop channel
unlock pl330
lock pl330
check req_running != -1
req_running = -1
_start channel
Signed-off-by: John Keeping <john@metanate.com>
Signed-off-by: Vinod Koul <vkoul@kernel.org>
