commit 6d69bb536bac0d403d83db1ca841444981b280cd upstream.
Mapping an image with a long parent chain (e.g. image foo, whose parent
is bar, whose parent is baz, etc) currently leads to a kernel stack
overflow, due to the following recursion in the reply path:
rbd_osd_req_callback()
rbd_obj_request_complete()
rbd_img_obj_callback()
rbd_img_parent_read_callback()
Limit the parent chain to 16 images, which is ~5K worth of stack. When
the above recursion is eliminated, this limit can be lifted.
Fixes: http://tracker.ceph.com/issues/12538
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Josh Durgin <jdurgin@redhat.com>
[idryomov@gmail.com: backport to 3.10: rbd_dev->opts, context]
commit 1f2c6651f69c14d0d3a9cfbda44ea101b02160ba upstream.
Currently we leak parent_spec and trigger a "parent reference
underflow" warning if rbd_dev_create() in rbd_dev_probe_parent() fails.
The problem is we take the !parent out_err branch and that only drops
refcounts; parent_spec that would've been freed had we called
rbd_dev_unparent() remains and triggers rbd_warn() in
rbd_dev_parent_put() - at that point we have parent_spec != NULL and
parent_ref == 0, so counter ends up being -1 after the decrement.
Redo rbd_dev_probe_parent() to fix this.
[idryomov@gmail.com: backport to < 4.2: rbd_dev->opts]
Reviewed-by: Alex Elder <elder@linaro.org>
commit 7fd6f640f2dd17dac6ddd6702c378cb0bb9cfa11 upstream.
Trying to write console output from within the serial console driver
while the port->lock is held causes recursive deadlock:
CPU 0
spin_lock_irqsave(&port->lock)
printk()
console_unlock()
call_console_drivers()
serial8250_console_write()
** DEADLOCK **
The 8250_dw i/o accessors try to write a console error message if the
LCR workaround was unsuccessful. When the port->lock is already held
(eg., when called from serial8250_set_termios()), this deadlocks.
Make the error message a FIXME until a general solution is devised.
Cc: Tim Kryger <tim.kryger@gmail.com>
Reported-by: Zhang Zhen <zhenzhang.zhang@huawei.com>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
commit b51ecea852b712618796d9eab8428a7d5f1f106f upstream.
For RTL8411, RTL8111G, RTL8402, RTL8105, and RTL8106, disable the feature
of entering the L2/L3 link state of the PCIe. When the nic starts the process
of entering the L2/L3 link state and the PCI reset occurs before the work
is finished, the work would be queued and continue after the next the PCI
reset occurs. This causes the device stays in L2/L3 link state, and the system
couldn't find the device.
Signed-off-by: Hayes Wang <hayeswang@realtek.com>
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
commit f75761b6b5bf6277296505941d2dd8e11f9b5c35 upstream.
The tx descriptor version of RTL8111B belong to RTL_TD_0.
commit 06a2feb9e3bd0d2d555ccb19607ff5583cfa03e8 upstream.
Add missing platform_set_drvdata() in mace_probe(), otherwise
calling platform_get_drvdata() in mac_mace_device_remove() may
returns NULL.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
commit 2670cc699a66c4cf268cb3e3f6dfc325ec14f224 upstream.
Upon reception of a new frame, the emac driver checks for a number
of error conditions, and flag the packet as "bad" if any of these
are present. It then allocates a skb unconditionally, but only uses
it if the packet is "good". On the error path, the skb is just forgotten,
and the system leaks memory.
The piece of junk I have on my desk seems to encounter such error
frequently enough so that the box goes OOM after a couple of days,
which makes me grumpy.
Fix this by moving the allocation on the "good_packet" path (and
convert it to netdev_alloc_skb while we're at it).
Tested on a random Allwinner A20 board.
Cc: Stefan Roese <sr@denx.de>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
[ Upstream commit 48900cb6af4282fa0fb6ff4d72a81aa3dadb5c39 ]
virtio declares support for NETIF_F_FRAGLIST, but assumes
that there are at most MAX_SKB_FRAGS + 2 fragments which isn't
always true with a fraglist.
A longer fraglist in the skb will make the call to skb_to_sgvec overflow
the sg array, leading to memory corruption.
Drop NETIF_F_FRAGLIST so we only get what we can handle.
Cc: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Jason Wang <jasowang@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit 70910791731b5956171e1bfcad707766b8e18fee ]
The lt4112 is a HP branded Huawei me906e modem. Like other Huawei
modems, it does not have a fixed interface to function mapping.
Instead it uses a Huawei specific scheme: functions are mapped by
subclass and protocol.
However, the HP vendor ID is used for modems from many different
manufacturers using different schemes, so we cannot apply a generic
vendor rule like we do for the Huawei vendor ID.
Replace the previous lt4112 entry pointing to an arbitrary interface
number with a device specific subclass + protocol match.
Reported-and-tested-by: Muri Nicanor <muri+libqmi@immerda.ch>
Tested-by: Martin Hauke <mardnh@gmx.de>
Fixes: bb2bdeb83fb1 ("qmi_wwan: Add support for HP lt4112 LTE/HSPA+ Gobi 4G Modem")
Signed-off-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit e6dbe1eb2db0d7a14991c06278dd3030c45fb825 ]
priv->hwts_*_en indicate if timestamping is enabled/disabled at run
time. But priv->dma_cap.time_stamp and priv->dma_cap.atime_stamp
indicates HW is support for PTPv1/PTPv2.
Signed-off-by: Phil Reid <preid@electromag.com.au>
Acked-by: Richard Cochran <richardcochran@gmail.com>
[ Upstream commit c02b05011fadf8e409e41910217ca689f2fc9d91 ]
When doing memcpy/memset of EQEs, we should use sizeof struct
mlx4_eqe as the base size and not caps.eqe_size which could be bigger.
If caps.eqe_size is bigger than the struct mlx4_eqe then we corrupt
data in the master context.
When using a 64 byte stride, the memcpy copied over 63 bytes to the
slave_eq structure. This resulted in copying over the entire eqe of
interest, including its ownership bit -- and also 31 bytes of garbage
into the next WQE in the slave EQ -- which did NOT include the ownership
bit (and therefore had no impact).
However, once the stride is increased to 128, we are overwriting the
ownership bits of *three* eqes in the slave_eq struct. This results
in an incorrect ownership bit for those eqes, which causes the eq to
seem to be full. The issue therefore surfaced only once 128-byte EQEs
started being used in SRIOV and (overarchitectures that have 128/256
byte cache-lines such as PPC) - e.g after commit 77507aa249ae
"net/mlx4_core: Enable CQE/EQE stride support".
Fixes: 08ff32352d6f ('mlx4: 64-byte CQE/EQE support')
Signed-off-by: Carol L Soto <clsoto@linux.vnet.ibm.com>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
[ Upstream commit 1acea4f6ce1b1c0941438aca75dd2e5c6b09db60 ]
We can't rely on PPPOX_ZOMBIE to decide whether to clear po->pppoe_dev.
PPPOX_ZOMBIE can be set by pppoe_disc_rcv() even when po->pppoe_dev is
NULL. So we have no guarantee that (sk->sk_state & PPPOX_ZOMBIE) implies
(po->pppoe_dev != NULL).
Since we're releasing a PPPoE socket, we want to release the pppoe_dev
if it exists and reset sk_state to PPPOX_DEAD, no matter the previous
value of sk_state. So we can just check for po->pppoe_dev and avoid any
assumption on sk->sk_state.
Fixes: 2b018d57ff18 ("pppoe: drop PPPOX_ZOMBIEs in pppoe_release")
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit f23d538bc24a83c16127c2eb82c9cf1adc2b5149 ]
We don't have fraglist support in TAP_FEATURES. This will lead
software segmentation of gro skb with frag list. Fixes by having
frag list support in TAP_FEATURES.
With this patch single session of netperf receiving were restored from
about 5Gb/s to about 12Gb/s on mlx4.
Fixes a567dd6252 ("macvtap: simplify usage of tap_features")
Cc: Vlad Yasevich <vyasevic@redhat.com>
commit dbfe8ef5599a5370abc441fcdbb382b656563eb4 upstream.
Avoton AHCI occasionally sees drive probe timeouts at driver load time.
When this happens SCR_STATUS indicates device detected, but no D2H FIS
reception. Reset the internal link state machines by bouncing
port-enable in the PCS register when this occurs.
Cc: <stable@vger.kernel.org>
commit 039ece38da45f5e6a94be3aa7611cf3634bc2461 upstream.
Allwinner A10 and A20 ARM SoCs have an AHCI sata controller which needs a
special register to be poked before starting the DMA engine.
This register gets reset on an ahci_stop_engine call, so there is no other
place then ahci_start_engine where this poking can be done.
This commit allows drivers to override ahci_start_engine behavior for use by
the Allwinner AHCI driver (and potentially other drivers in the future).
commit e819cdb198319cccf4af4fc12ac4d796109d8c23 upstream.
These are signed values the come from the user, we put a cap on the
upper bounds but not on the lower bounds.
We use "karg.dataSgeOffset" to calculate "sz". We verify "sz" and
proceed as if that means that "karg.dataSgeOffset" is correct but this
fails to consider that the "sz" calculations can have integer overflows.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Cc: Oliver Neukum <ONeukum@suse.com>
commit 81207880cef207cd89db863f9aa1d65f22b4f2a2 upstream.
Add a register patch for rev E and above that configures the location of
some write sequences to assist with the headphone enables.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 02915661dbb91b25b621ab3f387ab55311bded7f upstream.
Evaluation of revision D of WM5110 suggests updates to the register
patch for optimal performance. For the sake of clarity rev C of the chip
does not require a register patch.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
commit be32c0cf0462c36f482b5ddcff1d8371be1e183c upstream.
The Exar XR17V358 can also be combined with a XR17V354 chip to act as a
single 12 port chip. This works the same way as the combining two XR17V358
chips. But the reported device id then is 0x4358.
Signed-off-by: Soeren Grunewald <soeren.grunewald@desy.de>
commit 96a5d18bc1338786fecac73599f1681f59a59a8e upstream.
The Exar XR17V358 chip usually provides only 8 ports. But two chips can be
combined to act as a single 16 port chip. Therefor one chip is configured
as master the second as slave by connecting the mode pin to VCC (master)
or GND (slave).
Then the master chip is reporting a different device-id depending on
whether a slave is detected or not. The UARTs 8-15 are addressed from
0x2000-0x3fff. So the offset of 0x400 from UART to UART can be used to
address all 16 ports as before.
See: https://www.exar.com/common/content/document.ashx?id=1587 page 11
commit 0ca81a2840f77855bbad1b9f172c545c4dc9e6a4 upstream.
ib_send_cm_sidr_rep could sometimes erase the node from the sidr
(depending on errors in the process). Since ib_send_cm_sidr_rep is
called both from cm_sidr_req_handler and cm_destroy_id, cm_id_priv
could be either erased from the rb_tree twice or not erased at all.
Fixing that by making sure it's erased only once before freeing
cm_id_priv.
Fixes: a977049dacde ('[PATCH] IB: Add the kernel CM implementation')
Signed-off-by: Doron Tsur <doront@mellanox.com>
Signed-off-by: Matan Barak <matanb@mellanox.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit 2280521719e81919283b82902ac24058f87dfc1b upstream.
When pci_pool_alloc fails in mvs_task_prep then task->lldd_task stays
NULL but it's later used in mvs_abort_task as slot which is passed
to mvs_slot_task_free causing NULL pointer dereference.
Just return from mvs_slot_task_free when passed with NULL slot.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=101891
Signed-off-by: Dāvis Mosāns <davispuh@gmail.com>
Reviewed-by: Tomas Henzl <thenzl@redhat.com>
commit 681ab4696062f5aa939c9e04d058732306a97176 upstream.
This was introduced with 9e882242c6193ae6f416f2d8d8db0d9126bd996b
which changed the return value of submit_bio_wait() to return != 0 on
error, but didn't update the caller accordingly.
Fixes: 9e882242c6 ("block: Add submit_bio_wait(), remove from md")
Reported-by: Bill Kuzeja <William.Kuzeja@stratus.com>
Signed-off-by: Jes Sorensen <Jes.Sorensen@redhat.com>
Signed-off-by: NeilBrown <neilb@suse.com>
commit 203d27b0226a05202438ddb39ef0ef1acb14a759 upstream.
commit a54c8f0f2d7df525ff997e2afe71866a1a013064 upstream.
xen-blkfront will crash if the check to talk_to_blkback()
in blkback_changed()(XenbusStateInitWait) returns an error.
The driver data is freed and info is set to NULL. Later during
the close process via talk_to_blkback's call to xenbus_dev_fatal()
the null pointer is passed to and dereference in blkfront_closing.
Signed-off-by: Cathy Avery <cathy.avery@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit fd7cd061adcf5f7503515ba52b6a724642a839c8 upstream.
We received several reports of systems rebooting and powering on
after an attempted shutdown. Testing showed that setting
XHCI_SPURIOUS_WAKEUP quirk in addition to the XHCI_SPURIOUS_REBOOT
quirk allowed the system to shutdown as expected for LynxPoint-LP
xHCI controllers. Set the quirk back.
Note that the quirk was originally introduced for LynxPoint and
LynxPoint-LP just for this same reason. See:
commit 638298dc66ea ("xhci: Fix spurious wakeups after S5 on Haswell")
It was later limited to only concern HP machines as it caused
regression on some machines, see both bug and commit:
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=66171
commit 6962d914f317 ("xhci: Limit the spurious wakeup fix only to HP machines")
Later it was discovered that the powering on after shutdown
was limited to LynxPoint-LP (Haswell-ULT) and that some non-LP HP
machine suffered from spontaneous resume from S3 (which should
not be related to the SPURIOUS_WAKEUP quirk at all). An attempt
to fix this then removed the SPURIOUS_WAKEUP flag usage completely.
commit b45abacde3d5 ("xhci: no switching back on non-ULT Haswell")
Current understanding is that LynxPoint-LP (Haswell ULT) machines
need the SPURIOUS_WAKEUP quirk, otherwise they will restart, and
plain Lynxpoint (Haswell) machines may _not_ have the quirk
set otherwise they again will restart.
Signed-off-by: Laura Abbott <labbott@fedoraproject.org>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Oliver Neukum <oneukum@suse.com>
[Added more history to commit message -Mathias]
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 3b4739b8951d650becbcd855d7d6f18ac98a9a85 upstream.
If a host fails to wake up a isochronous SuperSpeed device from U1/U2
in time for a isoch transfer it will generate a "No ping response error"
Host will then move to the next transfer descriptor.
Handle this case in the same way as missed service errors, tag the
current TD as skipped and handle it on the next transfer event.
commit 4dcb8b57df3593dcb20481d9d6cf79d1dc1534be upstream.
btree_split_beneath()'s error path had an outstanding FIXME that speaks
directly to the potential for _not_ cleaning up a previously allocated
bufio-backed block.
Fix this by releasing the previously allocated bufio block using
unlock_block().
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Joe Thornber <thornber@redhat.com>
commit bae818ee1577c27356093901a0ea48f672eda514 upstream.
rbd requires stable pages, as it performs a crc of the page data before
they are send to the OSDs.
But since kernel 3.9 (patch 1d1d1a767206fbe5d4c69493b7e6d2a8d08cc0a0
"mm: only enforce stable page writes if the backing device requires
it") it is not assumed anymore that block devices require stable pages.
This patch sets the necessary flag to get stable pages back for rbd.
In a ceph installation that provides multiple ext4 formatted rbd
devices "bad crc" messages appeared regularly (ca 1 message every 1-2
minutes on every OSD that provided the data for the rbd) in the
OSD-logs before this patch. After this patch this messages are pretty
much gone (only ca 1-2 / month / OSD).
Signed-off-by: Ronny Hegewald <Ronny.Hegewald@online.de>
[idryomov@gmail.com: require stable pages only in crc case, changelog]
[idryomov@gmail.com: backport to 3.9-3.17: context]
commit 2a6c521bb41ce862e43db46f52e7681d33e8d771 upstream.
On nv50+, we restrict the valid domains to just the one where the buffer
was originally created. However after the buffer is evicted to system
memory, we might move it back to a different domain that was not
originally valid. When sharing the buffer and retrieving its GEM_INFO
data, we still want the domain that will be valid for this buffer in a
pushbuf, not the one where it currently happens to be.
This resolves fdo#92504 and several others. These are due to suspend
evicting all buffers, making it more likely that they temporarily end up
in the wrong place.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=92504
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit e1bde3b11fedace5042f0232339da90bc85666af upstream.
Fix the pointer-integer size mismatch warning below:
drivers/spi/spi-gpio.c: In function ‘spi_gpio_setup’:
drivers/spi/spi-gpio.c:252:8: warning: cast from pointer to integer of
different size [-Wpointer-to-int-cast]
cs = (unsigned int) spi->controller_data;
Signed-off-by: SeongJae Park <sj38.park@gmail.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
commit 31f50e48e3e4ea9d503285a389d6a1b5349d66c0 upstream.
This patch fixes following build warning:
In file included from include/linux/printk.h:261:0,
from include/linux/kernel.h:13,
from include/linux/list.h:8,
from include/linux/module.h:9,
from drivers/power/bq24190_charger.c:11:
drivers/power/bq24190_charger.c: In function ‘bq24190_irq_handler_thread’:
include/linux/dynamic_debug.h:86:20: warning: ‘ss_reg’ may be used uninitialized in this function [-Wmaybe-uninitialized]
__dynamic_dev_dbg(&descriptor, dev, fmt, \
drivers/power/bq24190_charger.c:1211:5: note: ‘ss_reg’ was declared here
u8 ss_reg, f_reg;
include/linux/dynamic_debug.h:86:20: warning: ‘f_reg’ may be used uninitialized in this function [-Wmaybe-uninitialized]
drivers/power/bq24190_charger.c:1211:13: note: ‘f_reg’ was declared here
u8 ss_reg, f_reg;
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Signed-off-by: Sebastian Reichel <sre@kernel.org>
commit 1d20a16062e771b6e26b843c0cde3b17c1146e00 upstream.
drivers/net/ethernet/sfc/selftest.c: In function ‘efx_iterate_state’:
drivers/net/ethernet/sfc/selftest.c:388:9: warning: passing argument 1 of ‘memcpy’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-array-qualifiers]
This is because the msg[] member of struct efx_loopback_payload
is marked as 'const'. Remove that.
commit cbf3ccd09d683abf1cacd36e3640872ee912d99b upstream.
During device assignment/deassignment the flags in the DTE
get lost, which might cause spurious faults, for example
when the device tries to access the system management range.
Fix this by not clearing the flags with the rest of the DTE.
Reported-by: G. Richard Bellamy <rbellamy@pteradigm.com>
Tested-by: G. Richard Bellamy <rbellamy@pteradigm.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit 2cf5eb3ab7bb7f2e3a70edcef236cd62c87db030 upstream.
The code to send the RX PN data (for each TID) to the firmware
has a devastating bug: it overwrites the data for TID 0 with
all the TID data, leaving the remaining TIDs zeroed. This will
allow replays to actually be accepted by the firmware, which
could allow waking up the system.
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
commit b5a48134f8af08f5243328f8a0b05fc5ae7cf343 upstream.
The MODULE_FIRMWARE() for 3160 should be using the 7260 version as
it's done in the device configuration struct instead of referencing
IWL3160_UCODE_API_OK which doesn't even exist.
Reported-by: Hauke Mehrtens <hauke@hauke-m.de>
commit 5bd166872d8f99f156fac191299d24f828bb2348 upstream.
commit 2871c69e025e8bc507651d5a9cf81a8a7da9d24b upstream.
Commit 4c7e309340ff ("dm btree remove: fix bug in redistribute3") wasn't
a complete fix for redistribute3().
The redistribute3 function takes 3 btree nodes and shares out the entries
evenly between them. If the three nodes in total contained
(MAX_ENTRIES * 3) - 1 entries between them then this was erroneously getting
rebalanced as (MAX_ENTRIES - 1) on the left and right, and (MAX_ENTRIES + 1) in
the center.
Fix this issue by being more careful about calculating the target number
of entries for the left and right nodes.
Unit tested in userspace using this program:
https://github.com/jthornber/redistribute3-test/blob/master/redistribute3_t.c
Signed-off-by: Joe Thornber <ejt@redhat.com>
commit 2c2b24d9c3e96d5cf974be4559a936e7f3b50225 upstream.
The dbx500_cpuidle_probe is tagged as an __init section but the variable
dbx500_cpuidle_plat_driver is not.
The dbx500_cpuidle_probe could not be declared as __init because of macro
module_platform_driver builds the exit function, tags as __exit and this one
refers to the dbx500_cpuidle_plat_driver which is an __initdata.
That leads to a section mismatch.
Fix it by removing the __init tag for the probe function.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
commit 029cd0370241641eb70235d205aa0b90c84dce44 upstream.
ath9k inserts padding between the 802.11 header and the data area (to
align it). Since it didn't declare this extra required headroom, this
led to some nasty issues like randomly dropped packets in some setups.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
This reverts commit e25ecd21ffdbf1f8287103ccf97205fc30088344 in 3.12,
upstream commit ddbe1fca0bcb87ca8c199ea873a456ca8a948567 (USB: Add
device quirk for ASUS T100 Base Station keyboard).
It was applied twice to 3.12 and one backport is bogus.
Cc: Lu Baolu <baolu.lu@linux.intel.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
commit e5dff0e80463cc3fa236e898ef1491b40be70b19 upstream.
OTG device shall support this device for allowing compliance automated testing.
The modification is derived from Pavankumar and Vijayavardhans' previous work.
Signed-off-by: Macpaul Lin <macpaul@gmail.com>
Cc: Pavankumar Kondeti <pkondeti@codeaurora.org>
Cc: Vijayavardhan Vennapusa <vvreddy@codeaurora.org>
Cc: stable <stable@vger.kernel.org>
commit e0e6a356a0b41375b729c511caa99d3ec019640e upstream.
This reverts commit 614ced91fc6fbb5a1cdd12f0f1b6c9197d9f1350.
The units on this was seen were prototypes and the issue is
not seen on younger units.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit 7868943db1668fba898cf71bed1506c19d6958aa upstream.
The following patch is required to resolve remote wake issues with
certain devices.
Issue description:
If the remote wake is issued from the device in a specific timing
condition while the system is entering sleep state then it may cause
system to auto wake on subsequent sleep cycle.
Root cause:
Host controller rebroadcasts the Resume signal > 100 µseconds after
receiving the original resume event from the device. For proper
function, some devices may require the rebroadcast of resume event
within the USB spec of 100µS.
Workaroud:
1. Filter the AMD platforms with Yangtze chipset, then judge of all the usb
devices are mouse or not. And get out the port id which attached a mouse
with Pixart controller.
2. Then reset the port which attached issue device during system resume
from S3.
[Q] Why the special devices are only mice? Would high speed devices
such as 3G modem or USB Bluetooth adapter trigger this issue?
- Current this sensitivity is only confined to devices that use Pixart
controllers. This controller is designed for use with LS mouse
devices only. We have not observed any other devices failing. There
may be a small risk for other devices also but this patch (reset
device in resume phase) will cover the cases if required.
[Q] Shouldn’t the resume signal be sent within 100 us for every
device?
- The Host controller may not send the resume signal within 100us,
this our host controller specification change. This is why we
require the patch to prevent side effects on certain known devices.
[Q] Why would clicking mouse INTENSELY to wake the system up trigger
this issue?
- This behavior is specific to the devices that use Pixart controller.
It is timing dependent on when the resume event is triggered during
the sleep state.
[Q] Is it a host controller issue or mouse?
- It is the host controller behavior during resume that triggers the
device incorrect behavior on the next resume.
This patch sets USB_QUIRK_RESET_RESUME flag for these Pixart-based mice
when they attached to platforms with AMD Yangtze chipset.
Signed-off-by: Huang Rui <ray.huang@amd.com>
Suggested-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 63f2f417526fc54191f2b813f72dc1d5322bede8 upstream.
API compliance scanning with coccinelle flagged:
./drivers/media/usb/gspca/m5602/m5602_s5k83a.c:180:9-25:
WARNING: timeout (100) seems HZ dependent
Numeric constants passed to schedule_timeout() make the effective
timeout HZ dependent which makes little sense in a polling loop for
the cameras rotation state.
Fixed up by converting the constant to jiffies with msecs_to_jiffies()
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit 03b36e4dcf422a10da8b67bce2ed00b34ec58aac upstream.
Clipping size bit of VI6_WPFn _HSZCLIP and VI6_WPFn _VSZCLIP register are from
0 bit to 11 bit. But VI6_WPF_SZCLIP_SIZE_MASK is set to 0x1FFF, this will mask
until the reserve bits. This fixes size for VI6_WPF_SZCLIP_SIZE_MASK.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
commit 1aa7890324b497f96f07c20673fae58f26fabfe7 upstream.
FP bit of VI6_DPR_mod_ROUTE register is 6bit. But VI6_DPR_ROUTE_FP_MASK is set
to 0xFF, this will mask until the reserve bit.
This fixes size for VI6_DPR_ROUTE_FP_MASK.
commit 45008ee9295b3ae96d7413ab91871907a671ca82 upstream.
FXA bit of VI6_DPR_mod_ROUTE register starts from 16bit. But VI6_DPR_ROUTE_FXA_MASK
is set to become start from 8bit. This fixes shift size for VI6_DPR_ROUTE_FXA_MASK.
commit e2c84ccb0fbe5e524d15bb09c042a6ca634adaed upstream.
If remove_pending is non-zero, then the v4l2_lock is never unlocked.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
commit d3b367bc26ea2e07a83fe73f0ccbddd729cb1f9a upstream.
It uses bitrev8(), so it must ensure that lib/bitrev.o gets included in
vmlinux.
