commit cd0a2bfb77a3edeecd652081e0b1a163d3b0696b upstream.
Otherwise we get this link failure for frv's defconfig:
LD .tmp_vmlinux1
drivers/built-in.o: In function `pci_assign_resource':
(.text+0xbf0c): undefined reference to `pci_cardbus_resource_alignment'
drivers/built-in.o: In function `pci_setup':
pci.c:(.init.text+0x174): undefined reference to `pci_realloc_get_opt'
pci.c:(.init.text+0x1a0): undefined reference to `pci_realloc_get_opt'
make[1]: *** [.tmp_vmlinux1] Error 1
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 650275dbfb2f4c12bc91420ad5a99f955eabec98 upstream.
drivers/parisc/iommu-helpers.h:62: error: implicit declaration of function 'prefetchw'
make[3]: *** [drivers/parisc/sba_iommu.o] Error 1
drivers/parisc/iommu-helpers.h needs to #include <linux/prefetch.h>
where prefetchw is declared.
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
[ Upstream commit 15718ea0d844e4816dbd95d57a8a0e3e264ba90e ]
The recent fix d9bf5f1309 "tun: compare with 0 instead of total_len" is
not totally correct. Because "len" and "sizeof()" are size_t type, that
means they are never less than zero.
Acked-by: Michael S. Tsirkin <mst@redhat.com>
commit ee60bddba5a5f23e39598195d944aa0eb2d455e5 upstream.
This patch fixes spc_emulate_inquiry_std() to add trailing ASCII
spaces for INQUIRY vendor + model fields following SPC-4 text:
"ASCII data fields described as being left-aligned shall have any
unused bytes at the end of the field (i.e., highest offset) and
the unused bytes shall be filled with ASCII space characters (20h)."
This addresses a problem with Falconstor NSS multipathing.
Reported-by: Tomas Molota <tomas.molota@lightstorm.sk>
commit 524f42fab787a9510be826ce3d736b56d454ac6d upstream.
The ECDT of ASUSTEK L4R doesn't provide correct command and data
I/O ports. The DSDT provides the correct information instead.
For this reason, add this machine to quirk list for ECDT validation
and use the EC information from the DSDT.
[rjw: Changelog]
References: https://bugzilla.kernel.org/show_bug.cgi?id=60765
Reported-and-tested-by: Daniele Esposti <expo@expobrain.net>
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
commit d2e9fc141e2aa21f4b35ee27072d84e9aa6e2ba0 upstream.
ath9k_htc adds padding between the 802.11 header and the payload during
TX by moving the header. When handing the frame back to mac80211 for TX
status handling the header is not moved back into its original position.
This can result in a too small skb headroom when entering ath9k_htc
again (due to a soft retransmission for example) causing an
skb_under_panic oops.
Fix this by moving the 802.11 header back into its original position
before returning the frame to mac80211 as other drivers like rt2x00
or ath5k do.
Reported-by: Marc Kleine-Budde <mkl@blackshift.org>
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
Tested-by: Marc Kleine-Budde <mkl@blackshift.org>
Signed-off-by: Marc Kleine-Budde <mkl@blackshift.org>
commit 21ea9f5ace3a7317cc3ba1fbc749758021a83136 upstream.
"cat /sys/devices/system/memory/memory*/removable" crashed the system.
The problem is that show_mem_removable() is passing a
bad pfn to is_mem_section_removable(), which causes
if (!node_online(page_to_nid(page)))
to blow up. Why is it passing in a bad pfn?
The reason is that show_mem_removable() will loop sections_per_block
times. sections_per_block is 16, but mem->section_count is 8,
indicating holes in this memory block. Checking that the memory section
is present before checking to see if the memory section is removable
fixes the problem.
harp5-sys:~ # cat /sys/devices/system/memory/memory*/removable
0
1
1
1
1
1
1
1
1
1
1
1
1
1
BUG: unable to handle kernel paging request at ffffea00c3200000
IP: [<ffffffff81117ed1>] is_pageblock_removable_nolock+0x1/0x90
PGD 83ffd4067 PUD 37bdfce067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: autofs4 binfmt_misc rdma_ucm rdma_cm iw_cm ib_addr ib_srp scsi_transport_srp scsi_tgt ib_ipoib ib_cm ib_uverbs ib_umad iw_cxgb3 cxgb3 mdio mlx4_en mlx4_ib ib_sa mlx4_core ib_mthca ib_mad ib_core fuse nls_iso8859_1 nls_cp437 vfat fat joydev loop hid_generic usbhid hid hwperf(O) numatools(O) dm_mod iTCO_wdt ipv6 iTCO_vendor_support igb i2c_i801 ioatdma i2c_algo_bit ehci_pci pcspkr lpc_ich i2c_core ehci_hcd ptp sg mfd_core dca rtc_cmos pps_core mperf button xhci_hcd sd_mod crc_t10dif usbcore usb_common scsi_dh_emc scsi_dh_hp_sw scsi_dh_alua scsi_dh_rdac scsi_dh gru(O) xvma(O) xfs crc32c libcrc32c thermal sata_nv processor piix mptsas mptscsih scsi_transport_sas mptbase megaraid_sas fan thermal_sys hwmon ext3 jbd ata_piix ahci libahci libata scsi_mod
CPU: 4 PID: 5991 Comm: cat Tainted: G O 3.11.0-rc5-rja-uv+ #10
Hardware name: SGI UV2000/ROMLEY, BIOS SGI UV 2000/3000 series BIOS 01/15/2013
task: ffff88081f034580 ti: ffff880820022000 task.ti: ffff880820022000
RIP: 0010:[<ffffffff81117ed1>] [<ffffffff81117ed1>] is_pageblock_removable_nolock+0x1/0x90
RSP: 0018:ffff880820023df8 EFLAGS: 00010287
RAX: 0000000000040000 RBX: ffffea00c3200000 RCX: 0000000000000004
RDX: ffffea00c30b0000 RSI: 00000000001c0000 RDI: ffffea00c3200000
RBP: ffff880820023e38 R08: 0000000000000000 R09: 0000000000000001
R10: 0000000000000000 R11: 0000000000000001 R12: ffffea00c33c0000
R13: 0000160000000000 R14: 6db6db6db6db6db7 R15: 0000000000000001
FS: 00007ffff7fb2700(0000) GS:ffff88083fc80000(0000) knlGS:0000000000000000
CR2: ffffea00c3200000 CR3: 000000081b954000 CR4: 00000000000407e0
Call Trace:
show_mem_removable+0x41/0x70
dev_attr_show+0x2a/0x60
sysfs_read_file+0xf7/0x1c0
vfs_read+0xc8/0x130
SyS_read+0x5d/0xa0
system_call_fastpath+0x16/0x1b
Signed-off-by: Russ Anderson <rja@sgi.com>
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
commit 924dd584b198a58aa7cb3efefd8a03326550ce8f upstream.
BUG: sleeping function called from invalid context at kernel/workqueue.c:2752
in_atomic(): 1, irqs_disabled(): 1, pid: 360, name: zfcperp0.0.1700
CPU: 1 Not tainted 3.9.3+ #69
Process zfcperp0.0.1700 (pid: 360, task: 0000000075b7e080, ksp: 000000007476bc30)
<snip>
Call Trace:
([<00000000001165de>] show_trace+0x106/0x154)
[<00000000001166a0>] show_stack+0x74/0xf4
[<00000000006ff646>] dump_stack+0xc6/0xd4
[<000000000017f3a0>] __might_sleep+0x128/0x148
[<000000000015ece8>] flush_work+0x54/0x1f8
[<00000000001630de>] __cancel_work_timer+0xc6/0x128
[<00000000005067ac>] scsi_device_dev_release_usercontext+0x164/0x23c
[<0000000000161816>] execute_in_process_context+0x96/0xa8
[<00000000004d33d8>] device_release+0x60/0xc0
[<000000000048af48>] kobject_release+0xa8/0x1c4
[<00000000004f4bf2>] __scsi_iterate_devices+0xfa/0x130
[<000003ff801b307a>] zfcp_erp_strategy+0x4da/0x1014 [zfcp]
[<000003ff801b3caa>] zfcp_erp_thread+0xf6/0x2b0 [zfcp]
[<000000000016b75a>] kthread+0xf2/0xfc
[<000000000070c9de>] kernel_thread_starter+0x6/0xc
[<000000000070c9d8>] kernel_thread_starter+0x0/0xc
Apparently, the ref_count for some scsi_device drops down to zero,
triggering device removal through execute_in_process_context(), while
the lldd error recovery thread iterates through a scsi device list.
Unfortunately, execute_in_process_context() decides to immediately
execute that device removal function, instead of scheduling asynchronous
execution, since it detects process context and thinks it is safe to do
so. But almost all calls to shost_for_each_device() in our lldd are
inside spin_lock_irq, even in thread context. Obviously, schedule()
inside spin_lock_irq sections is a bad idea.
Change the lldd to use the proper iterator function,
__shost_for_each_device(), in combination with required locking.
Occurences that need to be changed include all calls in zfcp_erp.c,
since those might be executed in zfcp error recovery thread context
with a lock held.
Other occurences of shost_for_each_device() in zfcp_fsf.c do not
need to be changed (no process context, no surrounding locking).
The problem was introduced in Linux 2.6.37 by commit
b62a8d9b45b971a67a0f8413338c230e3117dff5
"[SCSI] zfcp: Use SCSI device data zfcp_scsi_dev instead of zfcp_unit".
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com>
Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com>
commit d79ff142624e1be080ad8d09101f7004d79c36e1 upstream.
This patch adds wait_event_interruptible_lock_irq_timeout(), which is a
straight-forward descendant of wait_event_interruptible_timeout() and
wait_event_interruptible_lock_irq().
The zfcp driver used to call wait_event_interruptible_timeout()
in combination with some intricate and error-prone locking. Using
wait_event_interruptible_lock_irq_timeout() as a replacement
nicely cleans up that locking.
This rework removes a situation that resulted in a locking imbalance
in zfcp_qdio_sbal_get():
BUG: workqueue leaked lock or atomic: events/1/0xffffff00/10
last function: zfcp_fc_wka_port_offline+0x0/0xa0 [zfcp]
It was introduced by commit c2af7545aaff3495d9bf9a7608c52f0af86fb194
"[SCSI] zfcp: Do not wait for SBALs on stopped queue", which had a new
code path related to ZFCP_STATUS_ADAPTER_QDIOUP that took an early exit
without a required lock being held. The problem occured when a
special, non-SCSI I/O request was being submitted in process context,
when the adapter's queues had been torn down. In this case the bug
surfaced when the Fibre Channel port connection for a well-known address
was closed during a concurrent adapter shut-down procedure, which is a
rare constellation.
This patch also fixes these warnings from the sparse tool (make C=1):
drivers/s390/scsi/zfcp_qdio.c:224:12: warning: context imbalance in
'zfcp_qdio_sbal_check' - wrong count at exit
drivers/s390/scsi/zfcp_qdio.c:244:5: warning: context imbalance in
'zfcp_qdio_sbal_get' - unexpected unlock
Last but not least, we get rid of that crappy lock-unlock-lock
sequence at the beginning of the critical section.
It is okay to call zfcp_erp_adapter_reopen() with req_q_lock held.
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
commit 8ffff94d20b7eb446e848e0046107d51b17a20a8 upstream.
Fixing support for the Silicon Image 3826 port multiplier, by applying
to it the same quirks applied to the Silicon Image 3726. Specifically
fixes the repeated timeout/reset process which previously afflicted
the 3726, as described from line 290. Slightly based on notes from:
https://bugzilla.redhat.com/show_bug.cgi?id=890237
Signed-off-by: Terry Suereth <terry.suereth@gmail.com>
commit 909bd5926d474e275599094acad986af79671ac9 upstream.
We want the data stored in "addr" and "qual", but the extra ampersands
mean we are copying stack data instead.
commit 9e40127526e857fa3f29d51e83277204fbdfc6ba upstream.
Already existing property flags are filled wrong for properties created from
initial FDT. This could cause problems if this DYNAMIC device-tree functions
are used later, i.e. properties are attached/detached/replaced. Simply dumping
flags from the running system show, that some initial static (not allocated via
kzmalloc()) nodes are marked as dynamic.
I putted some debug extensions to property_proc_show(..) :
+ if (OF_IS_DYNAMIC(pp))
+ pr_err("DEBUG: xxx : OF_IS_DYNAMIC\n");
+ if (OF_IS_DETACHED(pp))
+ pr_err("DEBUG: xxx : OF_IS_DETACHED\n");
when you operate on the nodes (e.g.: ~$ cat /proc/device-tree/*some_node*) you
will see that those flags are filled wrong, basically in most cases it will dump
a DYNAMIC or DETACHED status, which is in not true.
(BTW. this OF_IS_DETACHED is a own define for debug purposes which which just
make a test_bit(OF_DETACHED, &x->_flags)
If nodes are dynamic kernel is allowed to kfree() them. But it will crash
attempting to do so on the nodes from FDT -- they are not allocated via
kzmalloc().
Signed-off-by: Wladislav Wiebe <wladislav.kw@gmail.com>
Acked-by: Alexander Sverdlin <alexander.sverdlin@nsn.com>
commit 84ca7a8e45dafb49cd5ca90a343ba033e2885c17 upstream.
The sizeof() argument in init_evtchn_cpu_bindings() is incorrect
resulting in only the first 64 (or 32 in 32-bit guests) ports having
their bindings being initialized to VCPU 0.
In most cases this does not cause a problem as request_irq() will set
the irq affinity which will set the correct local per-cpu mask.
However, if the request_irq() is called on a VCPU other than 0, there
is a window between the unmasking of the event and the affinity being
set were an event may be lost because it is not locally unmasked on
any VCPU. If request_irq() is called on VCPU 0 then local irqs are
disabled during the window and the race does not occur.
Fix this by initializing all NR_EVENT_CHANNEL bits in the local
per-cpu masks.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 1206ff4ff9d2ef7468a355328bc58ac6ebf5be44 upstream.
Patch fixes zd1201 not to use stack as URB transfer_buffer. URB buffers need
to be DMA-able, which stack is not.
Patch is only compile tested.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
commit ef6c8c1d733e244f0499035be0dabe1f4ed98c6f upstream.
The parallel-port code of the drivers used a stack allocated
control-request buffer for asynchronous (and possibly deferred) control
requests. This not only violates the no-DMA-from-stack requirement but
could also lead to corrupt control requests being submitted.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 304ab4ab079a8ed03ce39f1d274964a532db036b upstream.
These devices tend to become unresponsive after S3
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit b497ceb964a80ebada3b9b3cea4261409039e25a upstream.
ARM cannot handle udelay for more than 2 miliseconds, so we
should use mdelay instead for those.
Acked-by: GOTO Masanori <gotom@debian.or.jp>
Cc: YOKOTA Hiroshi <yokota@netlab.is.tsukuba.ac.jp>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
commit 96f97a83910cdb9d89d127c5ee523f8fc040a804 upstream.
If a port gets unplugged while a user is blocked on read(), -ENODEV is
returned. However, subsequent read()s returned 0, indicating there's no
host-side connection (but not indicating the device went away).
This also happened when a port was unplugged and the user didn't have
any blocking operation pending. If the user didn't monitor the SIGIO
signal, they won't have a chance to find out if the port went away.
Fix by returning -ENODEV on all read()s after the port gets unplugged.
write() already behaves this way.
Signed-off-by: Amit Shah <amit.shah@redhat.com>
commit 92d3453815fbe74d539c86b60dab39ecdf01bb99 upstream.
SIGIO should be sent when a port gets unplugged. It should only be sent
to prcesses that have the port opened, and have asked for SIGIO to be
delivered. We were clearing out guest_connected before calling
send_sigio_to_port(), resulting in a sigio not getting sent to
processes.
Fix by setting guest_connected to false after invoking the sigio
function.
commit ea3768b4386a8d1790f4cc9a35de4f55b92d6442 upstream.
We used to keep the port's char device structs and the /sys entries
around till the last reference to the port was dropped. This is
actually unnecessary, and resulted in buggy behaviour:
1. Open port in guest
2. Hot-unplug port
3. Hot-plug a port with the same 'name' property as the unplugged one
This resulted in hot-plug being unsuccessful, as a port with the same
name already exists (even though it was unplugged).
This behaviour resulted in a warning message like this one:
-------------------8<---------------------------------------
WARNING: at fs/sysfs/dir.c:512 sysfs_add_one+0xc9/0x130() (Not tainted)
Hardware name: KVM
sysfs: cannot create duplicate filename
'/devices/pci0000:00/0000:00:04.0/virtio0/virtio-ports/vport0p1'
Call Trace:
[<ffffffff8106b607>] ? warn_slowpath_common+0x87/0xc0
[<ffffffff8106b6f6>] ? warn_slowpath_fmt+0x46/0x50
[<ffffffff811f2319>] ? sysfs_add_one+0xc9/0x130
[<ffffffff811f23e8>] ? create_dir+0x68/0xb0
[<ffffffff811f2469>] ? sysfs_create_dir+0x39/0x50
[<ffffffff81273129>] ? kobject_add_internal+0xb9/0x260
[<ffffffff812733d8>] ? kobject_add_varg+0x38/0x60
[<ffffffff812734b4>] ? kobject_add+0x44/0x70
[<ffffffff81349de4>] ? get_device_parent+0xf4/0x1d0
[<ffffffff8134b389>] ? device_add+0xc9/0x650
Instead of relying on guest applications to release all references to
the ports, we should go ahead and unregister the port from all the core
layers. Any open/read calls on the port will then just return errors,
and an unplug/plug operation on the host will succeed as expected.
This also caused buggy behaviour in case of the device removal (not just
a port): when the device was removed (which means all ports on that
device are removed automatically as well), the ports with active
users would clean up only when the last references were dropped -- and
it would be too late then to be referencing char device pointers,
resulting in oopses:
PID: 6162 TASK: ffff8801147ad500 CPU: 0 COMMAND: "cat"
#0 [ffff88011b9d5a90] machine_kexec at ffffffff8103232b
#1 [ffff88011b9d5af0] crash_kexec at ffffffff810b9322
#2 [ffff88011b9d5bc0] oops_end at ffffffff814f4a50
#3 [ffff88011b9d5bf0] die at ffffffff8100f26b
#4 [ffff88011b9d5c20] do_general_protection at ffffffff814f45e2
#5 [ffff88011b9d5c50] general_protection at ffffffff814f3db5
[exception RIP: strlen+2]
RIP: ffffffff81272ae2 RSP: ffff88011b9d5d00 RFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff880118901c18 RCX: 0000000000000000
RDX: ffff88011799982c RSI: 00000000000000d0 RDI: 3a303030302f3030
RBP: ffff88011b9d5d38 R8: 0000000000000006 R9: ffffffffa0134500
R10: 0000000000001000 R11: 0000000000001000 R12: ffff880117a1cc10
R13: 00000000000000d0 R14: 0000000000000017 R15: ffffffff81aff700
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
#6 [ffff88011b9d5d00] kobject_get_path at ffffffff8126dc5d
#7 [ffff88011b9d5d40] kobject_uevent_env at ffffffff8126e551
#8 [ffff88011b9d5dd0] kobject_uevent at ffffffff8126e9eb
#9 [ffff88011b9d5de0] device_del at ffffffff813440c7
So clean up when we have all the context, and all that's left to do when
the references to the port have dropped is to free up the port struct
itself.
Reported-by: chayang <chayang@redhat.com>
Reported-by: YOGANANTH SUBRAMANIAN <anantyog@in.ibm.com>
Reported-by: FuXiangChun <xfu@redhat.com>
Reported-by: Qunfang Zhang <qzhang@redhat.com>
Reported-by: Sibiao Luo <sluo@redhat.com>
commit 671bdea2b9f210566610603ecbb6584c8a201c8c upstream.
Between open() being called and processed, the port can be unplugged.
Check if this happened, and bail out.
A simple test script to reproduce this is:
while true; do for i in $(seq 1 100); do echo $i > /dev/vport0p3; done; done;
This opens and closes the port a lot of times; unplugging the port while
this is happening triggers the bug.
commit 057b82be3ca3d066478e43b162fc082930a746c9 upstream.
There's a window between find_port_by_devt() returning a port and us
taking a kref on the port, where the port could get unplugged. Fix it
by taking the reference in find_port_by_devt() itself.
Problem reported and analyzed by Mateusz Guzik.
Reported-by: Mateusz Guzik <mguzik@redhat.com>
commit 93d783bcca69bfacc8dc739d8a050498402587b5 upstream.
In adt7470_write_word_data(), which writes two bytes using
i2c_smbus_write_byte_data(), the return codes are incorrectly AND-ed
together when they should be OR-ed together.
The return code of i2c_smbus_write_byte_data() is zero for success.
The upshot is only the first byte was ever written to the hardware.
The 2nd byte was never written out.
I noticed that trying to set the fan speed limits was not working
correctly on my system. Setting the fan speed limits is the only
code that uses adt7470_write_word_data(). After making the change
the limit settings work and the alarms work also.
Signed-off-by: Curt Brune <curt@cumulusnetworks.com>
[ Upstream commit 20f0170377264e8449b6987041f0bcc4d746d3ed ]
usbnet doesn't support yet SG, so drivers should not advertise SG or TSO
capabilities, as they allow TCP stack to build large TSO packets that
need to be linearized and might use order-5 pages.
This adds an extra copy overhead and possible allocation failures.
Current code ignore skb_linearize() return code so crashes are even
possible.
Best is to not pretend SG/TSO is supported, and add this again when/if
usbnet really supports SG for devices who could get a performance gain.
Based on a prior patch from Freddy Xin <freddy@asix.com.tw>
[ Upstream commit 087d273caf4f7d3f2159256f255f1f432bc84a5b ]
This patch doesn't change the compiled code because ARC_HDR_SIZE is 4
and sizeof(int) is 4, but the intent was to use the header size and not
the sizeof the header size.
commit 016d5baad04269e8559332df05f89bd95b52d6ad upstream.
The _BIX method returns extended battery info as a package.
According the ACPI spec (ACPI 5, Section 10.2.2.2), the first member
of that package should be "Revision". However, the current ACPI
battery driver treats the first member as "Power Unit" which should
be the second member. This causes the result of _BIX return data
parsing to be incorrect.
Fix this by adding a new member called 'revision' to struct
acpi_battery and adding the offsetof() information on it to
extended_info_offsets[] as the first row.
[rjw: Changelog]
Reported-and-tested-by: Jan Hoffmann <jan.christian.hoffmann@gmail.com>
References: http://bugzilla.kernel.org/show_bug.cgi?id=60519
commit 83e612f632c3897be29ef02e0472f6d63e258378 upstream.
Both type and pkt_len variables are in host endian and these should be in
Little Endian in the payload.
Signed-off-by: Tomasz Moń <desowin@gmail.com>
Acked-by: Bing Zhao <bzhao@marvell.com>
commit e2288b66fe7ff0288382b2af671b4da558b44472 upstream.
Since we clear QUEUE_STARTED in rt2x00queue_stop_queue(), following
call to rt2x00queue_pause_queue() reduce to noop, i.e we do not
stop queue in mac80211.
To fix that introduce rt2x00queue_pause_queue_nocheck() function,
which will stop queue in mac80211 directly.
Note that rt2x00_start_queue() explicitly set QUEUE_PAUSED bit.
Note also that reordering operations i.e. first call to
rt2x00queue_pause_queue() and then clear QUEUE_STARTED bit, will race
with rt2x00queue_unpause_queue(), so calling ieee80211_stop_queue()
directly is the only available solution to fix the problem without
major rework.
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
commit dc2a87f519a4d8cb376ab54f22b6b98a943b51ce upstream.
Currently we configure harwdare and clock, only after
interface start. In this case, if we reload module or
reboot PC without configuring adapter, firmware will freeze.
There is no software way to reset adpter.
This patch add initial configuration and set it in
disabled state, to avoid this freeze. Behaviour of this patch
should be similar to: ifconfig wlan0 up; ifconfig wlan0 down.
Bug: https://github.com/qca/open-ath9k-htc-firmware/issues/1
Tested-by: Bo Shi <cnshibo@gmail.com>
Signed-off-by: Oleksij Rempel <linux@rempel-privat.de>
commit 079a036f4283e2b0e5c26080b8c5112bc0cc1831 upstream.
Without this patch the driver waits ~1 ms for the UART to become idle. At
115200n8 this time is (theoretically) enough to transfer 11.5 characters
(= 115200 bits/s / (10 Bits/char) * 1ms). As the mxs-auart has a fifo size
of 16 characters the clock is gated too early. The problem is worse for
lower baud rates.
This only happens to really shut down the transmitter in the middle of a
transfer if /dev/ttyAPPx isn't opened in userspace (e.g. by a getty) but
was at least once (because the bootloader doesn't disable the transmitter).
So increase the timeout to 20 ms which should be enough for 9600n8, too.
Moreover skip gating the clock if the timeout is elapsed.
commit d970d7fe65adff5efe75b4a73c4ffc9be57089f7 upstream.
The handler needs to ack the pending events before actually handling them.
Otherwise a new event might come in after it it considered non-pending or
handled and is acked then without being handled. So this event is only
noticed when the next interrupt happens.
Without this patch an i.MX28 based machine running an rt-patched kernel
regularly hangs during boot.
commit e7a6121f4929c17215f0cdca3726f4bf3e4e9529 upstream.
The device report an error capacity when read_capacity_16().
Using read_capacity_10() can get the correct capacity.
Signed-off-by: Ren Bigcren <bigcren.ren@sonymobile.com>
Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
Signed-off-by: Oskar Andero <oskar.andero@sonymobile.com>
commit cbdadbbf0c790f79350a8f36029208944c5487d0 upstream
virtio net called virtqueue_enable_cq on RX path after napi_complete, so
with NAPI_STATE_SCHED clear - outside the implicit napi lock.
This violates the requirement to synchronize virtqueue_enable_cq wrt
virtqueue_add_buf. In particular, used event can move backwards,
causing us to lose interrupts.
In a debug build, this can trigger panic within START_USE.
Jason Wang reports that he can trigger the races artificially,
by adding udelay() in virtqueue_enable_cb() after virtio_mb().
However, we must call napi_complete to clear NAPI_STATE_SCHED before
polling the virtqueue for used buffers, otherwise napi_schedule_prep in
a callback will fail, causing us to lose RX events.
To fix, call virtqueue_enable_cb_prepare with NAPI_STATE_SCHED
set (under napi lock), later call virtqueue_poll with
NAPI_STATE_SCHED clear (outside the lock).
Reported-by: Jason Wang <jasowang@redhat.com>
Tested-by: Jason Wang <jasowang@redhat.com>
Acked-by: Jason Wang <jasowang@redhat.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
[wg: Backported to 3.2]
Signed-off-by: Wolfram Gloger <wmglo@dent.med.uni-muenchen.de>
commit cc229884d3f77ec3b1240e467e0236c3e0647c0c upstream.
This adds a way to check ring empty state after enable_cb outside any
locks. Will be used by virtio_net.
Note: there's room for more optimization: caller is likely to have a
memory barrier already, which means we might be able to get rid of a
barrier here. Deferring this optimization until we do some
benchmarking.
commit 179fbd5a45f0d4034cc6fd37b8d367a3b79663c4 upstream.
Unbinding an event channel (either with the ioctl or when the evtchn
device is closed) may deadlock because disable_irq() is called with
port_user_lock held which is also locked by the interrupt handler.
Think of the IOCTL_EVTCHN_UNBIND is being serviced, the routine has
just taken the lock, and an interrupt happens. The evtchn_interrupt
is invoked, tries to take the lock and spins forever.
A quick glance at the code shows that the spinlock is a local IRQ
variant. Unfortunately that does not help as "disable_irq() waits for
the interrupt handler on all CPUs to stop running. If the irq occurs
on another VCPU, it tries to take port_user_lock and can't because
the unbind ioctl is holding it." (from David). Hence we cannot
depend on the said spinlock to protect us. We could make it a system
wide IRQ disable spinlock but there is a better way.
We can piggyback on the fact that the existence of the spinlock is
to make get_port_user() checks be up-to-date. And we can alter those
checks to not depend on the spin lock (as it's protected by u->bind_mutex
in the ioctl) and can remove the unnecessary locking (this is
IOCTL_EVTCHN_UNBIND) path.
In the interrupt handler we cannot use the mutex, but we do not
need it.
"The unbind disables the irq before making the port user stale, so when
you clear it you are guaranteed that the interrupt handler that might
use that port cannot be running." (from David).
Hence this patch removes the spinlock usage on the teardown path
and piggybacks on disable_irq happening before we muck with the
get_port_user() data. This ensures that the interrupt handler will
never run on stale data.
[v1: Expanded the commit description a bit]
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
commit fed1f1ed90bce42ea010e2904cbc04e7b8304940 upstream.
RT Systems makes many usb serial cables based on the ftdi_sio driver for
programming various amateur radios. This patch is a full listing of
their current product offerings and should allow these cables to all
be recognized.
Signed-off-by: Rick Farina (Zero_Chaos) <zerochaos@gentoo.org>
commit 42a21826dc54583cdb79cc8477732e911ac9c376 upstream.
The ProcessAuxChannel table on some rv635 boards assumes
the divmul members are initialized to 0 otherwise we get
an invalid fb offset since it has a bad mask set when
setting the fb base. While here initialize all the
atom interpretor elements to 0.
Fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=60639
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 03ed8cf9b28d886c64c7e705c7bb1a365fd8fb95 upstream.
Hopefully avoid more quirks in the future due to bogus
vbios dac data.
commit cef1d00cd56f600121ad121875655ad410a001b8 upstream.
Noticed that my old Radeon 7500 hung after printing
drm: GPU not posted. posting now...
when it wasn't selected as the primary card the BIOS. Some digging
revealed that it was hanging in combios_parse_mmio_table() while
parsing the ASIC INIT 3 table. Looking at the BIOS ROM for the card,
it becomes obvious that there is no ASIC INIT 3 table in the BIOS.
The code is just processing random garbage. No surprise it hangs!
Why do I say that there is no ASIC INIT 3 table is the BIOS? This
table is found through the MISC INFO table. The MISC INFO table can
be found at offset 0x5e in the COMBIOS header. But the header is
smaller than that. The COMBIOS header starts at offset 0x126. The
standard PCI Data Structure (the bit that starts with 'PCIR') lives at
offset 0x180. That means that the COMBIOS header can not be larger
than 0x5a bytes and therefore cannot contain a MISC INFO table.
I looked at a dozen or so BIOS images, some my own, some downloaded from:
<http://www.techpowerup.com/vgabios/index.php?manufacturer=ATI&page=1>
It is fairly obvious that the size of the COMBIOS header can be found
at offset 0x6 of the header. Not sure if it is a 16-bit number or
just an 8-bit number, but that doesn't really matter since the tables
seems to be always smaller than 256 bytes.
So I think combios_get_table_offset() should check if the requested
table is present. This can be done by checking the offset against the
size of the header. See the diff below. The diff is against the WIP
OpenBSD codebase that roughly corresponds to Linux 3.8.13 at this
point. But I don't think this bit of the code changed much since
then.
For what it is worth:
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
commit d19f503e22316a84c39bc19445e0e4fdd49b3532 upstream.
device->driver_data needs to be cleared when releasing its data,
mem_device, in an error path of acpi_memory_device_add().
The function evaluates the _CRS of memory device objects, and fails
when it gets an unexpected resource or cannot allocate memory. A
kernel crash or data corruption may occur when the kernel accesses
the stale pointer.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
commit bb9696192826a7d9279caf872e95b41bc26c7eff upstream.
sata_inic162x never reached a state where it's reliable enough for
production use and data corruption is a relatively common occurrence.
Make the driver generate warning about the issues and mark the Kconfig
option as experimental.
If the situation doesn't improve, we'd be better off making it depend
on CONFIG_BROKEN. Let's wait for several cycles and see if the kernel
message draws any attention.
Reported-by: Martin Braure de Calignon <braurede@free.fr>
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Reported-by: risc4all@yahoo.com
commit 69acbaac303e8cb948801a9ddd0ac24e86cc4a1b upstream.
Comedi devices can do blocking read() or write() (or poll()) if an
asynchronous command has been set up, blocking for data (for read()) or
buffer space (for write()). Various events associated with the
asynchronous command will wake up the blocked reader or writer (or
poller). It is also possible to force the asynchronous command to
terminate by issuing a `COMEDI_CANCEL` ioctl. That shuts down the
asynchronous command, but does not currently wake up the blocked reader
or writer (or poller). If the blocked task could be woken up, it would
see that the command is no longer active and return. The caller of the
`COMEDI_CANCEL` ioctl could attempt to wake up the blocked task by
sending a signal, but that's a nasty workaround.
Change `do_cancel_ioctl()` to wake up the wait queue after it returns
from `do_cancel()`. `do_cancel()` can propagate an error return value
from the low-level comedi driver's cancel routine, but it always shuts
the command down regardless, so `do_cancel_ioctl()` can wake up he wait
queue regardless of the return value from `do_cancel()`.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit 2c7b871b9102c497ba8f972aa5d38532f05b654d upstream.
Control transfers have both IN and OUT (or SETUP) packets, so when
clearing TT buffers for a control transfer it's necessary to send
two HUB_CLEAR_TT_BUFFER requests to the hub.
Signed-off-by: William Gulland <wgulland@google.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 58fc90db8261b571c026bb8bf23aad48a7233118 upstream.
Signed-off-by: Jóhann B. Guðmundsson <johannbg@fedoraproject.org>
commit 1fad56424f5ad3ce4973505a357212b2e2282b3f upstream.
The driver failed to take the dynamic ids into account when determining
the device type and therefore all devices were detected as 2-port
devices when using the dynamic-id interface.
Match on the usb-serial-driver field instead of doing redundant id-table
searches.
Reported-by: Anders Hammarquist <iko@iko.pp.se>
commit 203a86613fb3bf2767335659513fa98563a3eb71 upstream.
When the host controller fails to respond to an Enable Slot command, and
the host fails to respond to the register write to abort the command
ring, the xHCI driver will assume the host is dead, and call
usb_hc_died().
The USB device's slot_id is still set to zero, and the pointer stored at
xhci->devs[0] will always be NULL. The call to xhci_check_args in
xhci_free_dev should have caught the NULL virt_dev pointer.
However, xhci_free_dev is designed to free the xhci_virt_device
structures, even if the host is dead, so that we don't leak kernel
memory. xhci_free_dev checks the return value from the generic
xhci_check_args function. If the return value is -ENODEV, it carries on
trying to free the virtual device.
The issue is that xhci_check_args looks at the host controller state
before it looks at the xhci_virt_device pointer. It will return -ENIVAL
because the host is dead, and xhci_free_dev will ignore the return
value, and happily dereference the NULL xhci_virt_device pointer.
The fix is to make sure that xhci_check_args checks the xhci_virt_device
pointer before it checks the host state.
See https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1203453 for
further details. This patch doesn't solve the underlying issue, but
will ensure we don't see any more NULL pointer dereferences because of
the issue.
This patch should be backported to kernels as old as 3.1, that
contain the commit 7bd89b4017f46a9b92853940fd9771319acb578a "xhci: Don't
submit commands or URBs to halted hosts."
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Reported-by: Vincent Thiele <vincentthiele@gmail.com>
commit d66eaf9f89502971fddcb0de550b01fa6f409d83 upstream.
in some cases where device is attched to xhci port and do not responding,
for example ath9k_htc with stalled firmware, kernel will
crash on ring_doorbell_for_active_rings.
This patch check if pointer exist before it is used.
This patch should be backported to kernels as old as 2.6.35, that
contain the commit e9df17eb1408cfafa3d1844bfc7f22c7237b31b8 "USB: xhci:
Correct assumptions about number of rings per endpoint"
commit c3ccb1d7cf4c4549151876dd37c0944a682fd9e1 upstream.
This fixes a regression where Xyratex controllers and disks were lost by the
driver:
https://bugzilla.kernel.org/show_bug.cgi?id=59601
Reported-by: Jack Hill <jackhill@jackhill.us>
Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
commit 085b513f97d8d799d28491239be4b451bcd8c2c5 upstream.
sd_prep_fn will allocate a larger CDB for the command via mempool_alloc
for devices using DIF type 2 protection. This CDB was being freed
in sd_done, which results in a kernel crash if the command is retried
due to a UNIT ATTENTION. This change moves the code to free the larger
CDB into sd_unprep_fn instead, which is invoked after the request is
complete.
It is no longer necessary to call scsi_print_command separately for
this case as the ->cmnd will no longer be NULL in the normal code path.
Also removed conditional test for DIF type 2 when freeing the larger
CDB because the protection_type could have been changed via sysfs while
the command was executing.
Signed-off-by: Ewan D. Milne <emilne@redhat.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
