commit f418b88aad0c42b4caf4d79a0cf8d14a5d0a2284 upstream.
This register is needed for streamout to work properly.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
commit 860fe2f05fa2eacac84368e23547ec8cf3cc6652 upstream.
These regs were being wronly rejected leading to rendering
issues.
fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=56876
commit afcc87aa6a233e52df73552dc1dc9ae3881b7cc8 upstream.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Brian Paul <brianp@vmware.com>
Reviewed-by: Dmitry Torokhov <dtor@vmware.com>
Cc: linux-graphics-maintainer@vmware.com
commit 95e8f6a21996c4cc2c4574b231c6e858b749dce3 upstream.
The device would not reset properly when resuming from hibernation.
commit 14efd957209461bbdf285bf0d67e931955d04a4c upstream.
Commit 473b095a72a9 ("mmc: sdhci: fix incorrect command used in tuning")
introduced a NULL dereference at resume-time if an SD 3.0 host controller
raises the SDHCI_NEEDS_TUNING flag while no card is inserted. Seen on an
OLPC XO-4 with sdhci-pxav3, but presumably affects other controllers too.
Signed-off-by: Chris Ball <cjb@laptop.org>
commit a0d28ba01ebd048b4ba418142b37f5cf80e6d156 upstream.
A recent commit "mmc: sh_mmcif: fix clock management" has introduced a
use after free bug in sh_mmcif.c: in sh_mmcif_remove() the call to
mmc_free_host() frees private driver data, therefore using it afterwards
is a bug. Revert that hunk.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
[ Upstream commit 57c10b61c84bfed68b1b317d6f507a392724b9c4 ]
Based on commit b27393aecf66199f5ddad37c302d3e0cfadbe6c0
Calling mdiobus_free without calling mdiobus_unregister causes
BUG_ON(). This patch fixes the issue.
The semantic patch that found this issue(http://coccinelle.lip6.fr/):
// <smpl>
expression E;
... when != mdiobus_unregister(E);
+ mdiobus_unregister(E);
mdiobus_free(E);
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Tested-by: Roland Stigge <stigge@antcom.de>
Tested-by: Alexandre Pereira da Silva <aletes.xgr@gmail.com>
[ Upstream commit 39707c2a3ba5011038b363f84d37c8a98d2d9db1 ]
Driver anchors the tx urbs and defers the urb submission if
a transmit request comes when the interface is suspended.
Anchoring urb increments the urb reference count. These
deferred urbs are later accessed by calling usb_get_from_anchor()
for submission during interface resume. usb_get_from_anchor()
unanchors the urb but urb reference count remains same.
This causes the urb reference count to remain non-zero
after usb_free_urb() gets called and urb never gets freed.
Hence call usb_put_urb() after anchoring the urb to properly
balance the reference count for these deferred urbs. Also,
unanchor these deferred urbs during disconnect, to free them
up.
Signed-off-by: Hemant Kumar <hemantk@codeaurora.org>
Acked-by: Oliver Neukum <oneukum@suse.de>
commit 3300fb4f88688029fff8dfb9ec0734f6e4cba3e7 upstream.
Don't assume bank 0 is selected at device probe time. This may not be
the case. Force bank selection at first register access to guarantee
that we read the right registers upon driver loading.
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
commit fdb40a08ef7bc970899c3a1f471165f9c22763a1 upstream.
Some drivers (specifically vmwgfx) look at dev_mapping
in their open hook, so we have to set dev->dev_mapping
earlier in the process.
Reference:
http://lists.freedesktop.org/archives/dri-devel/2012-October/029420.html
Signed-off-by: Ilija Hadzic <ihadzic@research.bell-labs.com>
Reported-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
commit 0f1cb1bd94a9c967cd4ad3de51cfdabe61eb5dcc upstream.
If drm_setup (called at first open) fails, the whole
open call has failed, so we should not keep the
open_count incremented.
commit 1623392af9da983f3ad088a75076c9da05e5600d upstream.
Otherwise we may remove the only console for a nomodeset system.
We became more aggressive in our kicking with
commit e188719a2891f01b3100dca4ae3a055fb5a7ab52
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Tue Jun 12 11:28:17 2012 +0200
drm/i915: kick any firmware framebuffers before claiming the gtt
Reported-and-tested-by: monnier@iro.umontreal.ca
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=54615
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit a9193983f4f292a82a00c72971c17ec0ee8c6c15 upstream.
The overlay on the i830M has a peculiar failure mode: It works the
first time around after boot-up, but consistenly hangs the second time
it's used.
Chris Wilson has dug out a nice errata:
"1.5.12 Clock Gating Disable for Display Register
Address Offset: 06200h–06203h
"Bit 3
Ovrunit Clock Gating Disable.
0 = Clock gating controlled by unit enabling logic
1 = Disable clock gating function
DevALM Errata ALM049: Overlay Clock Gating Must be Disabled: Overlay
& L2 Cache clock gating must be disabled in order to prevent device
hangs when turning off overlay.SW must turn off Ovrunit clock gating
(6200h) and L2 Cache clock gating (C8h)."
Now I've nowhere found that 0xc8 register and hence couldn't apply the
l2 cache workaround. But I've remembered that part of the magic that
the OVERLAY_ON/OFF commands are supposed to do is to rearrange cache
allocations so that the overlay scaler has some scratch space.
And while pondering how that could explain the hang the 2nd time we
enable the overlay, I've remembered that the old ums overlay code did
_not_ issue the OVERLAY_OFF cmd.
And indeed, disabling the OFF cmd results in the overlay working
flawlessly, so I guess we can workaround the lack of the above
workaround by simply never disabling the overlay engine once it's
enabled.
Note that we have the first part of the above w/a already implemented
in i830_init_clock_gating - leave that as-is to avoid surprises.
v2: Add a comment in the code.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=47827
Tested-by: Rhys <rhyspuk@gmail.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
commit b6e0e543f75729f207b9c72b0162ae61170635b2 upstream.
Like in the case of native hdmi, which is fixed already in
commit adf00b26d18e1b3570451296e03bcb20e4798cdd
Author: Paulo Zanoni <paulo.r.zanoni@intel.com>
Date: Tue Sep 25 13:23:34 2012 -0300
drm/i915: make sure we write all the DIP data bytes
we need to clear the entire sdvo buffer to avoid upsetting the
display.
Since infoframe buffer writing is now a bit more elaborate, extract it
into it's own function. This will be useful if we ever get around to
properly update the ELD for sdvo. Also #define proper names for the
two buffer indexes with fixed usage.
v2: Cite the right commit above, spotted by Paulo Zanoni.
v3: I'm too stupid to paste the right commit.
v4: Ben Hutchings noticed that I've failed to handle an underflow in
my loop logic, breaking it for i >= length + 8. Since I've just lost C
programmer license, use his solution. Also, make the frustrated 0-base
buffer size a notch more clear.
Reported-and-tested-by: Jürg Billeter <j@bitron.ch>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=25732
Cc: Paulo Zanoni <przanoni@gmail.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Reviewed-by: Rodrigo Vivi <rodrigo.vivi@gmail.com>
commit 3916e1d71b62b120888aa50bcc8d9a6200fc19a7 upstream.
When buffer sharing with the i915 and using a 1680x1050 monitor,
the i915 gives is a 6912 buffer for the 6720 width, the code doesn't
render this properly as it uses one value to set the base address for
reading from the vmap and for where to start on the device.
This fixes it by calculating the values correctly for the device and
for the pixmap. No idea how I haven't seen this before now.
commit 83325d072185899b706de2956170b246585aaec9 upstream.
An uninitialized variable led to broken load detection.
Signed-off-by: Egbert Eich <eich@suse.de>
commit dea5f0998aa82bdeca260b87c653db11e91329b2 upstream.
This patch fixes a regression in spc_emulate_inquiry() code where the
local scope bounce buffer was no longer getting it's memory zeroed,
causing various problems with SCSI initiators that depend upon areas
of INQUIRY EVPD=0x83 payload having been zeroed.
This bug was introduced with the following v3.7-rc1 patch + CC'ed
stable commit:
commit ffe7b0e9326d9c68f5688bef691dd49f1e0d3651
Author: Paolo Bonzini <pbonzini@redhat.com>
Date: Fri Sep 7 17:30:38 2012 +0200
target: support zero allocation length in INQUIRY
Go ahead and re-add the missing memset of bounce buffer memory to be
copied into the outgoing se_cmd descriptor kmapped SGL payload.
Reported-by: Kelsey Prantis <kelsey.prantis@intel.com>
Cc: Kelsey Prantis <kelsey.prantis@intel.com>
Cc: Andy Grover <agrover@redhat.com>
commit ab74b3d62f05192bf8fb8f169e7999d1183b2e08 upstream.
This patch changes core_tmr_abort_task() to use spin_lock -> spin_unlock
around se_cmd->t_state_lock while spin_lock_irqsave is held via
se_sess->sess_cmd_lock.
Signed-off-by: Steve Hodgson <steve@purestorage.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit d5627acba9ae584cf4928af19f7ddf5f6837de32 upstream.
The sleeping code in iscsi_target_tx_thread() is susceptible to the classic
missed wakeup race:
- TX thread finishes handle_immediate_queue() and handle_response_queue(),
thinks both queues are empty.
- Another thread adds a queue entry and does wake_up_process(), which does
nothing because the TX thread is still awake.
- TX thread does schedule_timeout() and sleeps forever.
In practice this can kill an iSCSI connection if for example an initiator
does single-threaded writes and the target misses the wakeup window when
queueing an R2T; in this case the connection will be stuck until the
initiator loses patience and does some task management operation (or kills
the connection entirely).
Fix this by converting to wait_event_interruptible(), which does not
suffer from this sort of race.
Cc: Hannes Reinecke <hare@suse.de>
commit 3e03989b5868acf69a391a424dc71fcd6cc48167 upstream.
The expression (max_sectors * block_size) might overflow a u32
(indeed, since iblock sets max_hw_sectors to UINT_MAX, it is
guaranteed to overflow and end up with a much-too-small result in many
common cases). Fix this by doing an equivalent calculation that
doesn't require multiplication.
While we're touching this code, avoid splitting a printk format across
two lines and use pr_info(...) instead of printk(KERN_INFO ...).
commit 0d0f9dfb31e0a6c92063e235417b42df185b3275 upstream.
If the call to core_dev_release_virtual_lun0() fails, then nothing
sets ret to anything other than 0, so even though everything is
torn down and freed, target_core_init_configfs() will seem to succeed
and the module will be loaded. Fix this by passing the return value
on up the chain.
commit bf7e1abe434ba9e22e8dc04a4cba4ab504b788b8 upstream.
Some hardware has correct (!= 0xff) value of tssi_bounds[4] in the
EEPROM, but step is equal to 0xff. This results on ridiculous delta
calculations and completely broke TX power settings.
Reported-and-tested-by: Pavel Lucik <pavel.lucik@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
commit 6fe7cc71bbf3a0bc28c9cec3c00bc11e81344412 upstream.
The ath9k xmit functions for AMPDUs can send frames as non-aggregate in case
only one frame is currently available. The client will then answer using a
normal Ack instead of a BlockAck. This acknowledgement has no TID stored and
therefore the hardware is not able to provide us the corresponding TID.
The TID set by the hardware in the tx status descriptor has to be seen as
undefined and not as a valid TID value for normal acknowledgements. Doing
otherwise results in a massive amount of retransmissions and stalls of
connections.
Users may experience low bandwidth and complete connection stalls in
environments with transfers using multiple TIDs.
This regression was introduced in b11b160defc48e4daa283f785192ea3a23a51f8e
("ath9k: validate the TID in the tx status information").
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
Acked-by: Felix Fietkau <nbd@openwrt.org>
commit 8c6e30936a7893a85f6222084f0f26aceb81137a upstream.
bf->bf_next is only while buffers are chained as part of an A-MPDU
in the tx queue. When a tid queue is flushed (e.g. on tearing down
an aggregation session), frames can be enqueued again as normal
transmission, without bf_next being cleared. This can lead to the
old pointer being dereferenced again later.
This patch might fix crashes and "Failed to stop TX DMA!" messages.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit 32ed1911fc79908d704023317d4ddeb3883fd07e upstream.
The tsc40 driver announces it supports the pressure event, but will never
send one. The announcement will cause tslib to wait for such events and
sending all touch events with a pressure of 0. Removing the announcement
will make tslib fall back to emulating the pressure on touch events so
everything works as expected.
Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
commit 50f8d35de8ba4af311ea1176c534e8b73bb198e5 upstream.
This patch corrects the ethtool get_ts_info functon which did not state that
software timestamping was supported, even though it is.
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Tested-by: Stephen Ko <stephen.s.ko@intel.com>
commit a67baeb77375199bbd842fa308cb565164dd1f19 upstream.
map->kmap_ops allocated in gntdev_alloc_map() wasn't freed by
gntdev_put_map().
Add a gntdev_free_map() helper function to free everything allocated
by gntdev_alloc_map().
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
This is to prevent nouveau from taking over the console on headless boards
such as Tesla.
Backport of upstream commit: e412e95a268fa8544858ebfe066826b290430d51
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
Backport of fixes from upstream commit:
9430738d80223a1cd791a2baa74fa170d3df1262
commit cee59f15a60cc6269a25e3f6fbf1a577d6ab8115 upstream.
commit 3ccc60f9d8c39180c205dba1a020735bda1b2491 upstream.
Microsoft Digital Media Keyboard 3000 has two interfaces, and the
second one has a report descriptor with a bug. The second collection
says:
05 01 -- global; usage page -- 01 -- Generic Desktop Controls
09 80 -- local; usage -- 80 -- System Control
a1 01 -- main; collection -- 01 -- application
85 03 -- global; report ID -- 03
19 00 -- local; Usage Minimum -- 00
29 ff -- local; Usage Maximum -- ff
15 00 -- global; Logical Minimum -- 0
26 ff 00 -- global; Logical Maximum -- ff
81 00 -- main; input
c0 -- main; End Collection
I.e. it makes us think that there are all kinds of usages of system
control. That the keyboard is a not only a keyboard, but also a
joystick, mouse, gamepad, keypad, etc. The same as for the Wireless
Desktop Receiver, this should be Physical Min/Max. So fix that
appropriately.
References: https://bugzilla.novell.com/show_bug.cgi?id=776834
commit e13d5fef88c40b87c8430f8274c3a9ca32ef90bc upstream.
Fabric drivers currently expect to internally release se_cmd in the event
of a TMR failure during target_submit_tmr(), which means the immediate call
to transport_generic_free_cmd() after TFO->queue_tm_rsp() from within
target_complete_tmr_failure() workqueue context is wrong.
This is done as some fabrics expect TMR operations to be acknowledged
before releasing the descriptor, so the assumption that core is releasing
se_cmd associated TMR memory is incorrect. This fixes a OOPs where
transport_generic_free_cmd() was being called more than once.
This bug was originally observed with tcm_qla2xxx fabric ports.
Cc: Roland Dreier <roland@purestorage.com>
commit 1a1ff38c4cebf23be8bf0009a76b082a13bd25cb upstream.
With kernel 3.6 some obsolete SCSI-2 commands including SEEK_10 have
have been removed by commit 1fd032ee10d2816c947f5d5b9abda95e728f0a8f
"target: move code for CDB emulation".
There are still clients out there which use these old SCSI-2 commands.
This mainly happens when running VMs with legacy guest systems,
connected via SCSI command pass-through to iSCSI targets. Make them
happy and return status GOOD.
Many real SCSI disks or external iSCSI storage devices still support
these old commands. So let's make LIO backward compatible as well.
This patch adds support for the previously removed SEEK_10 and
additionally the SEEK_6 and REZERO_UNIT commands.
Signed-off-by: Bernhard Kohl <bernhard.kohl@nsn.com>
commit c8292d1da53fa60c7516ab03a9d83f7ea266d335 upstream.
It is possible for the target code to change the loop_id or s_id of a
target session in reaction to an FC fabric change. However, the
session structures are stored in tables that are indexed by these two
keys, and if we just change the session structure but leave the
pointers to it in the old places in the table, havoc can ensue. For
example, a new session might come along that should go in the old slot
in the table and overwrite the old session pointer.
To handle this, add a new tgt_ops->update_sess() method that also
updates the "by loop_id" and "by s_id" lookup tables when a session
changes, so that the keys where a session pointer is stored in these
tables always matches the keys in the session structure itself.
(nab: Drop unnecessary double inversion with FCF_CONF_COMP_SUPPORTED
usage)
Cc: Chad Dupuis <chad.dupuis@qlogic.com>
Cc: Arun Easi <arun.easi@qlogic.com>
Cc: Saurav Kashyap <saurav.kashyap@qlogic.com>
The stable commit 12ddc74e8e25107eda81aceb74e3311c1480b381
("USB: io_edgeport: fix port-data memory leak") left one variable
unused:
drivers/usb/serial/io_edgeport.c: In function 'edge_release':
drivers/usb/serial/io_edgeport.c:3155:6: warning: unused variable 'i' [-Wunused-variable]
Remove this unused variable.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Fix two memory leaks involving dbgbuf that were introduced in port-probe
error paths when backporting the following port-data fixes from v3.7
(which doesn't have dbgbuf):
0978c94 USB: iuu_phoenix: fix sysfs-attribute creation
5363655 USB: iuu_phoenix: fix port-data memory leak
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 80c00750f0c9867a65b30a17880939b6bc660a77 upstream.
Fix port-data memory leak by moving port data allocation and
deallocation to port_probe and port_remove.
Since commit 0998d0631001288 (device-core: Ensure drvdata = NULL when no
driver is bound) the port private data is no longer freed at release as
it is no longer accessible.
Note that the indentation was kept intact using a do-while(0) in order
to facilitate review. A follow-up patch will remove it.
Compile-only tested.
commit d60e7ec18c3fb2cbf90969ccd42889eb2d03aef9 upstream.
On floppy initialization, if something failed inside the loop we call
add_disk, there was no cleanup of previous iterations in the error
handling.
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
commit 238ab78469c6ab7845b43d5061cd3c92331b2452 upstream.
If blk_init_queue fails, we do not call put_disk on the current dr
(dr is decremented first in the error handling loop).
Reviewed-by: Ben Hutchings <ben@decadent.org.uk>
commit b54e1f88897bcacc2cd359f48ea3b39eaf55f084 upstream.
Since commit 070ad7e ("floppy: convert to delayed work and single-thread
wq"), we end up calling alloc_ordered_workqueue multiple times inside
the loop, which shouldn't be intended. Besides the leak, other side
effect in the current code is if blk_init_queue fails, we would end up
calling unregister_blkdev even if we didn't call yet register_blkdev.
Just moved the allocation of floppy_wq before the loop, and adjusted the
code accordingly.
Acked-by: Vivek Goyal <vgoyal@redhat.com>
commit 02b898f2f04e418094f0093a3ad0b415bcdbe8eb upstream.
setup_conf in raid1.c uses conf->raid_disks before assigning
a value. It is used when including 'Replacement' devices.
The consequence is that assembling an array which contains a
replacement will misbehave and either not include the replacement, or
not include the device being replaced.
Though this doesn't lead directly to data corruption, it could lead to
reduced data safety.
So use mddev->raid_disks, which is initialised, instead.
Bug was introduced by commit c19d57980b38a5bb613a898937a1cf85f422fb9b
md/raid1: recognise replacements when assembling arrays.
in 3.3, so fix is suitable for 3.3.y thru 3.6.y.
Signed-off-by: NeilBrown <neilb@suse.de>
commit ad2fab36d7922401c4576fb7ea9b21a47a29a17f upstream.
gpios requested with invalid numbers, or gpios requested from userspace via sysfs
should not try to be deferred on failure.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit d79550a7bc35c16476ebdc27c78378d8093390ec upstream.
->last_ier is an unsigned long but the high bits can't be used int the
original code because the shift wraps.
commit 73b26df5fa1a6245d6fc982362518b620bc7c2fe upstream.
This reverts commit a240dc7b3c7463bd60cf0a9b2a90f52f78aae0fd.
This commit is reducing tx power by at least 10 db on some devices,
e.g. the Buffalo WZR-HP-G450H.
Cc: rmanohar@qca.qualcomm.com
commit e4df1cbcc1f329e53a1fff7450b2229e0addff20 upstream.
Commit 6889125b8b4e09c5e53e6ecab3433bed1ce198c9
(cpufreq/powernow-k8: workqueue user shouldn't migrate the kworker to another CPU)
causes powernow-k8 to trigger a preempt warning, e.g.:
BUG: using smp_processor_id() in preemptible [00000000] code: cpufreq/3776
caller is powernowk8_target+0x20/0x49
Pid: 3776, comm: cpufreq Not tainted 3.6.0 #9
Call Trace:
[<ffffffff8125b447>] debug_smp_processor_id+0xc7/0xe0
[<ffffffff814877e7>] powernowk8_target+0x20/0x49
[<ffffffff81482b02>] __cpufreq_driver_target+0x82/0x8a
[<ffffffff81484fc6>] cpufreq_governor_performance+0x4e/0x54
[<ffffffff81482c50>] __cpufreq_governor+0x8c/0xc9
[<ffffffff81482e6f>] __cpufreq_set_policy+0x1a9/0x21e
[<ffffffff814839af>] store_scaling_governor+0x16f/0x19b
[<ffffffff81484f16>] ? cpufreq_update_policy+0x124/0x124
[<ffffffff8162b4a5>] ? _raw_spin_unlock_irqrestore+0x2c/0x49
[<ffffffff81483640>] store+0x60/0x88
[<ffffffff811708c0>] sysfs_write_file+0xf4/0x130
[<ffffffff8111243b>] vfs_write+0xb5/0x151
[<ffffffff811126e0>] sys_write+0x4a/0x71
[<ffffffff816319a9>] system_call_fastpath+0x16/0x1b
Fix this by by always using work_on_cpu().
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
commit bf11315eeda510ea4fc1a2bf972d8155d31d89b4 upstream.
The driver does not count space of radiotap fields when allocating skb for
radiotap packet. This leads to kernel panic with the following call trace:
[67607.676067] [<c152f90f>] error_code+0x67/0x6c
[67607.676067] [<c142f831>] ? skb_put+0x91/0xa0
[67607.676067] [<f8cf5e5b>] ? ipw_handle_promiscuous_tx+0x16b/0x2d0 [ipw2200]
[67607.676067] [<f8cf5e5b>] ipw_handle_promiscuous_tx+0x16b/0x2d0 [ipw2200]
[67607.676067] [<f8cf899b>] ipw_net_hard_start_xmit+0x8b/0x90 [ipw2200]
[67607.676067] [<f8741c5a>] libipw_xmit+0x55a/0x980 [libipw]
[67607.676067] [<c143d3e8>] dev_hard_start_xmit+0x218/0x4d0
This bug was found by VittGam.
https://bugzilla.kernel.org/show_bug.cgi?id=43255
Signed-off-by: Stanislav Yakovlev <stas.yakovlev@gmail.com>
commit 1fffa905adffbf0d3767fc978ef09afb830275eb upstream.
When cores are unregistered, entries
need to be removed from cores list in a safe manner.
Reported-by: Stanislaw Gruszka <sgruszka@redhat.com>
Reviewed-by: Arend Van Spriel <arend@broadcom.com>
Signed-off-by: Piotr Haber <phaber@broadcom.com>
commit 8f7b8db6e0557c8437adf9371e020cd89a7e85dc upstream.
The channel switch command for 6000 series devices
is larger than the maximum inline command size of
320 bytes. The command is therefore refused with a
warning. Fix this by allocating the command and
using the NOCOPY mechanism.
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit 720dfd250e48a8c7fd1b2b8645955413989c4ee0 upstream.
Add the missing unlock on the error handling path in function
imxdma_xfer_desc().
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
commit 26fd12209c08fe947be1828896ef4ffc5bd0e6df upstream.
list_move_tail(&schan->queued, &schan->active) makes the list_empty(schan->queued)
undefined, we either should change it to:
list_move_tail(schan->queued.next, &schan->active)
or
list_move_tail(&sdesc->node, &schan->active)
Signed-off-by: Barry Song <Baohua.Song@csr.com>
