commit ab48b03ec9ae1840a1e427e2375bd0d9d554b4ed upstream.
If the restart timer is running due to BUS-OFF and the device is
disconnected an dev_put will decrease the usage counter to -1 thus
blocking the interface removal, resulting in the following dmesg
lines repeating every 10s:
can: notifier: receive list not found for dev can0
unregister_netdevice: waiting for can0 to become free. Usage count = -1
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit f9af7b9edccb87d4d80b58687ab63e58f3b64c4c upstream.
Commit 0a97e1e9f9a6 ('HID: apple: Add Apple wireless keyboard 2011 ANSI PID')
did not update the special driver list in hid-core.c, so hid-generic may
still bind to this device.
Reported-by: Ari Pollak <ari@scvngr.com>
References: http://bugs.debian.org/694546
commit 2f90b68309683f2c5765a1b04ca23d71e51f1494 upstream.
tm_mon is 0..11, whereas vt8500 expects 1..12 for the month field,
causing invalid date errors for January, and causing the day field to
roll over incorrectly.
The century flag is only handled in vt8500_rtc_read_time, but not set in
vt8500_rtc_set_time. This patch corrects the behaviour of the century
flag.
Signed-off-by: Edgar Toernig <froese@gmx.de>
Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
commit 532db570e5181abc8f4f7bfa6c77c69ec2240198 upstream.
Control register bitfield for 12H/24H mode is handled incorrectly.
Setting CR_24H actually enables 12H mode. This patch renames the define
and changes the initialization code to correctly set 24H mode.
Cc: Edgar Toernig <froese@gmx.de>
commit 5abe257af8b95857b95fa0ba694530b446ae32d8 upstream.
Revert commit 2830a6d20139df2198d63235df7957712adb28e5.
We already perform the ida_simple_remove() in rtc_device_release(),
which is an appropriate place. Commit 2830a6d20 ("rtc: recycle id when
unloading a rtc driver") caused the kernel to emit
ida_remove called for id=0 which is not allocated.
warnings when rtc_device_release() tries to release an alread-released
ID.
Let's restore things to their previous state and then work out why
Vincent's kernel wasn't calling rtc_device_release() - presumably a bug
in a specific sub-driver.
Reported-by: Lothar Waßmann <LW@KARO-electronics.de>
Acked-by: Alexander Holler <holler@ahsoftware.de>
Cc: Vincent Palatin <vpalatin@chromium.org>
commit 1ee3ff6110c16acfc915a79b1e3feb5013c41e75 upstream.
Vendor-specific ID for BCM20702A0.
Support for bluetooth over Asus Wi-Fi GO!, included with Asus P8Z77-V
Deluxe.
T: Bus=07 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0b05 ProdID=17b5 Rev=01.12
S: Manufacturer=Broadcom Corp
S: Product=BCM20702A0
S: SerialNumber=94DBC98AC113
C: #Ifs= 4 Cfg#= 1 Atr=e0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=01 Driver=(none)
I: If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=01 Prot=01 Driver=(none)
I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 3 Alt= 0 #EPs= 0 Cls=fe(app. ) Sub=01 Prot=01 Driver=(none)
Signed-off-by: Jeff Cook <jeff@deserettechnology.com>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit c733b77475707cc3980542c86ee0ad5c841d544c upstream.
Ulrich reported that his USB3 cardreader does not work reliably when
connected to the USB3 port. It turns out that USB3 controller failed to
awaken when plugging in the USB3 cardreader. Further experiments found
that the USB3 host controller can only be awakened via polling, not via PME
interrupt. But if the PCIe port to which the USB3 host controller is
connected is suspended, we cannot poll the controller because its config
space is not accessible when the PCIe port is in a low power state.
To solve the issue, the PCIe port will not be suspended if any subordinate
device needs PME polling.
[bhelgaas: use bool consistently rather than mixing int/bool]
Reference: http://lkml.kernel.org/r/50841CCC.9030809@uli-eckhardt.de
Reported-by: Ulrich Eckhardt <usb@uli-eckhardt.de>
Tested-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Signed-off-by: Huang Ying <ying.huang@intel.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
commit 812089e01b9f65f90fc8fc670d8cce72a0e01fbb upstream.
Otherwise it fails like this on cards like the Transcend 16GB SDHC card:
mmc0: new SDHC card at address b368
mmcblk0: mmc0:b368 SDC 15.0 GiB
mmcblk0: error -110 sending status command, retrying
mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb0
Tested on my Lenovo x200 laptop.
[bhelgaas: changelog]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Chris Ball <cjb@laptop.org>
CC: Manoj Iyer <manoj.iyer@canonical.com>
commit 967577b062417b4e4b8e27b711220f4124f5153a upstream.
For unbound PCI devices, what we need is:
- Always in D0 state, because some devices do not work again after
being put into D3 by the PCI bus.
- In SUSPENDED state if allowed, so that the parent devices can still
be put into low power state.
To satisfy these requirements, the runtime PM for the unbound PCI
devices are disabled and set to SUSPENDED state. One issue of this
solution is that the PCI devices will be put into SUSPENDED state even
if the SUSPENDED state is forbidden via the sysfs interface
(.../power/control) of the device. This is not an issue for most
devices, because most PCI devices are not used at all if unbound.
But there are exceptions. For example, unbound VGA card can be used
for display, but suspending its parents makes it stop working.
To fix the issue, we keep the runtime PM enabled when the PCI devices
are unbound. But the runtime PM callbacks will do nothing if the PCI
devices are unbound. This way, we can put the PCI devices into
SUSPENDED state without putting the PCI devices into D3 state.
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=48201
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit cae49ede00ec3d0cda290b03fee55b72b49efc11 upstream.
We weren't clearing card->tx_skb[port] when processing the TX done interrupt.
If there wasn't another skb ready to transmit immediately, this led to a
double-free because we'd free it *again* next time we did have a packet to
send.
commit b9ed9f0ecf1b5675c64d069e9b53effe276b6f01 upstream.
Fixed include error for drm_mode.h
Signed-off-by: Andy Gross <andy.gross@ti.com>
commit bb1e5dd7113d2fd178d3af9aca8f480ae0468edf upstream.
Like Lynx Point, Lynx Point LP is also switchable. See
1c12443ab8eba71a658fae4572147e56d1f84f66 for more details.
This patch should be backported to stable kernels as old as 3.0,
that contain commit 69e848c2090aebba5698a1620604c7dccb448684
"Intel xhci: Support EHCI/xHCI port switching."
Signed-off-by: Russell Webb <russell.webb@linux.intel.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Mode Patch
commit b0e4e606ff6ff26da0f60826e75577b56ba4e463 upstream.
This minor patch creates a more stricter conditional for the Z1 sytems for applying
the Compliance Mode Patch, this to avoid the quirk to be applied to models that
contain a "Z1" in their dmi product string but are different from Z1 systems.
This patch should be backported to stable kernels as old as 3.2, that
contain the commit 71c731a296f1b08a3724bd1b514b64f1bda87a23 "usb: host:
xhci: Fix Compliance Mode on SN65LVPE502CP Hardware"
Signed-off-by: Alexis R. Cortes <alexis.cortes@ti.com>
commit 36caff5d795429c572443894e8789c2150dd796b upstream.
This patch (as1631) fixes a bug that shows up when a config change
fails for a device under an xHCI controller. The controller needs to
be told to disable the endpoints that have been enabled for the new
config. The existing code does this, but before storing the
information about which endpoints were enabled! As a result, any
second attempt to install the new config is doomed to fail because
xhci-hcd will refuse to enable an endpoint that is already enabled.
The patch optimistically initializes the new endpoints' device
structures before asking the device to switch to the new config. If
the request fails then the endpoint information is already stored, so
we can use usb_hcd_alloc_bandwidth() to disable the endpoints with no
trouble. The rest of the error path is slightly more complex now; we
have to disable the new interfaces and call put_device() rather than
simply deallocating them.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: Matthias Schniedermeyer <ms@citd.de>
CC: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 68e5254adb88bede68285f11fb442a4d34fb550c upstream.
xhci_alloc_segments_for_ring() builds a list of xhci_segments and links
the tail to head at the end (forming a ring). When it bails out for OOM
reasons half-way through, it tries to destroy its half-built list with
xhci_free_segments_for_ring(), even though it is not a ring yet. This
causes a null-pointer dereference upon hitting the last element.
Furthermore, one of its callers (xhci_ring_alloc()) mistakenly believes
the output parameters to be valid upon this kind of OOM failure, and
calls xhci_ring_free() on them. Since the (incomplete) list/ring should
already be destroyed in that case, this would lead to a use after free.
This patch fixes those issues by having xhci_alloc_segments_for_ring()
destroy its half-built, non-circular list manually and destroying the
invalid struct xhci_ring in xhci_ring_alloc() with a plain kfree().
This patch should be backported to kernels as old as 2.6.31, that
contains the commit 0ebbab37422315a5d0cb29792271085bafdf38c0 "USB: xhci:
Ring allocation and initialization."
A separate patch will need to be developed for kernels older than 3.4,
since the ring allocation code was refactored in that kernel.
Signed-off-by: Julius Werner <jwerner@chromium.org>
commit 4525c0a10dff7ad3669763c28016c7daffc3900e upstream.
The xHCI 1.0 specification made a change to the TD Size field in TRBs.
The value is now the number of packets that remain to be sent in the TD,
not including this TRB. The TD Size value for the last TRB in a TD must
always be zero.
The xHCI function xhci_v1_0_td_remainder() attempts to calculate this,
but it gets it wrong. First, it erroneously reuses the old
xhci_td_remainder function, which will right shift the value by 10. The
xHCI 1.0 spec as of June 2011 says nothing about right shifting by 10.
Second, it does not set the TD size for the last TRB in a TD to zero.
Third, it uses roundup instead of DIV_ROUND_UP. The total packet count
is supposed to be the total number of bytes in this TD, divided by the
max packet size, rounded up. DIV_ROUND_UP is the right function to use
in that case.
With the old code, a TD on an endpoint with max packet size 1024 would
be set up like so:
TRB 1, TRB length = 600 bytes, TD size = 0
TRB 1, TRB length = 200 bytes, TD size = 0
TRB 1, TRB length = 100 bytes, TD size = 0
With the new code, the TD would be set up like this:
TRB 1, TRB length = 600 bytes, TD size = 1
TRB 1, TRB length = 200 bytes, TD size = 1
This commit should be backported to kernels as old as 3.0, that contain
the commit 4da6e6f247a2601ab9f1e63424e4d944ed4124f3 "xhci 1.0: Update TD
size field format."
Reported-by: Chintan Mehta <chintan.mehta@sibridgetech.com>
Reported-by: Shimmer Huang <shimmering.h@gmail.com>
Tested-by: Bhavik Kothari <bhavik.kothari@sibridgetech.com>
Tested-by: Shimmer Huang <shimmering.h@gmail.com>
commit 392a07ae3316f2b90b39ce41e66d6f6b5c95de90 upstream.
David reports that at drivers/usb/host/xhci.c:2257:
static bool xhci_is_sync_in_ep(unsigned int ep_type)
return (ep_type == ISOC_IN_EP || ep_type != INT_IN_EP);
The static analyser cppcheck says
[linux-3.7-rc2/drivers/usb/host/xhci.c:2257]: (style) Redundant condition: If ep_type == 5, the comparison ep_type != 7 is always true.
Maybe the original programmer intention was something like
return (ep_type == ISOC_IN_EP || ep_type == INT_IN_EP);
Fix this.
contain the commit 2b69899934c63b7b9432568584fb4c4a2924f40c "xhci: USB
3.0 BW checking."
Reported-by: David Binderman <dcb314@hotmail.com>
commit d75542263a0b005876d112bbf9ffb23180cc3149 upstream.
This reverts commit d8c3ef256f88b7c6ecd673d03073b5645be9c5e4.
Above mentioned change was made along with multi usb phy change and
adding DT support for nop transceiver. But other two changes did not
make it to mainline. This in effect makes dsps musb wrapper unusable
even for single instance.
Hence revert it so that at least single instance can be supported.
Signed-off-by: Afzal Mohammed <afzal@ti.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 8b416b0b25d5d8ddb3a91c1d20e1373582c50405 upstream.
Now that DaVinci glue layer can be modular, we must export cppi_interrupt()
that it may call...
commit e324ce61ef483dd26d03502d35666ad48a2e1b33 upstream.
If of_get_gpio_flags() returns an error (as in case when GPIO probe is
deferred) the driver would attempt to claim invalid GPIO. It should
propagate the error code up the stack instead so that the probe either
fails or will be retried later (in case of -EPROBE_DEFER).
Reported-by: Gabor Juhos <juhosg@openwrt.org>
commit d46329a708c1a3301e272a029266b69339c0877f upstream.
If GPIO probing is deferred, the driver tries to claim an invalid GPIO line
which leads to an error message like this:
gpio-keys-polled buttons.2: unable to claim gpio 4294966779, err=-22
gpio-keys-polled: probe of buttons.2 failed with error -22
We should make sure that error code returned by of_get_gpio_flags (including
-EPROBE_DEFER) is propagated up the stack.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
commit a25461659050b913e114d282bf58823682eb56b6 upstream.
Report only the position of the first finger as absolute non-MT coordinates,
instead of reporting both fingers alternatively. Actual MT events are
unaffected.
This fixes horizontal and improves vertical scrolling with the touchpad.
Signed-off-by: Christophe TORDEUX <christophe@tordeux.net>
commit e12b3cecf221644ccab64d7c30a6df58b7630cb0 upstream.
Commit f393ee2b814e3291c12565000210b3cf10aa5c1d forgot to add the
touch_max property for Wacom Bamboo Fun CTH-461/S, ID 056a:00d2.
This broke the touch functionality for that device. This patch,
(done with help of Ping Cheng), adds the correct value and makes
touch work again.
Signed-off-by: Diego Calleja <diegocg@gmail.com>
Reviewed-by: Ping Cheng <pinglinux@gmail.com>
commit a455e2985f57e2a71566bb8850094af38b2c932d upstream.
The driver's timer must be set up before enabling IRQ handler, otherwise
bad things may happen.
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Peter Popovec <popovec@fei.tuke.sk>
commit 4f5f64cf0cc916220aaa055992e31195470cfe37 upstream.
At one point acpi_device_set_id() checks if acpi_device_hid(device)
returns NULL, but that never happens, so system bus devices with an
empty list of PNP IDs are given the dummy HID ("device") instead of
the "system bus HID" ("LNXSYBUS"). Fix the code to use the right
check.
commit 0d0cdb028f9d9771e2b346038707734121f906e3 upstream.
Commit 66fa7f215 "libata-acpi: improve ACPI disabling" introdcued the
behaviour of disabling ATA ACPI if ata_acpi_on_devcfg failed the 2nd
time, but commit 30dcf76ac dropped this behaviour and this caused
problem for Dimitris Damigos, where his laptop can not resume correctly.
The bugzilla page for it is:
https://bugzilla.kernel.org/show_bug.cgi?id=49331
The problem is, ata_dev_push_id will fail the 2nd time it is invoked,
and due to disabling ACPI code is dropped, ata_acpi_on_devcfg which
calls ata_dev_push_id will keep failing and eventually made the device
disabled.
This patch restores the original behaviour, if acpi failed the 2nd time,
disable acpi functionality for the device(and we do not event need to
add a debug message for this as it is still there ;-).
Reported-by: Dimitris Damigos <damigos@freemail.gr>
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
commit 0ac1b1d7b7424cd6f129b5454b504b3cae746f0e upstream.
The current acpisleep DMI checks only run when CONFIG_SUSPEND is set.
And this may break hibernation on some platforms when CONFIG_SUSPEND
is cleared.
Move acpisleep DMI check into #ifdef CONFIG_ACPI_SLEEP instead.
[rjw: Added acpi_sleep_dmi_check() and rebased on top of earlier
patches adding entries to acpisleep_dmi_table[].]
References: https://bugzilla.kernel.org/show_bug.cgi?id=45921
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
commit e79cc615a9bb44da72c499ccfa2c9c4bbea3aa84 upstream.
I think this is wrong since 72c973dd ("usb: gadget: add
usb_endpoint_descriptor to struct usb_ep"). If we fail to allocate an ep
or bail out early we shouldn't check for the descriptor which is
assigned at ep_enable() time.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Tatyana Brokhman <tlinder@codeaurora.org>
commit 0f9df939385527049c8062a099fbfa1479fe7ce0 upstream.
The "video->minor = -1" assigment is done in V4L2 by
video_register_device() so it is removed here.
Now. uvc_function_bind() calls in error case uvc_function_unbind() for
cleanup. The problem is that uvc_function_unbind() frees the uvc struct
and uvc_bind_config() does as well in error case of usb_add_function().
Removing kfree() in usb_add_function() would make the patch smaller but
it would look odd because the new allocated memory is not cleaned up.
However it is not guaranteed that if we call usb_add_function() we also
get to the bind function.
Therefore the patch extracts the conditional cleanup from
uvc_function_unbind() applies to uvc_function_bind().
uvc_function_unbind() now contains only the complete cleanup which is
required once everything has been registrated.
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Bhupesh Sharma <bhupesh.sharma@st.com>
commit fad8deb274edcef1c8ca38946338f5f4f8126fe2 upstream.
The descriptor list for FS speed was not NULL terminated. This patch
fixes this.
While here one of the twe two bAlternateSetting assignments for the BOT
interface. Both assign 0, one is enough.
commit d0eca719dd11ad0619e8dd6a1f3eceb95b0216dd upstream.
commit d185039f7982eb82cf8d03b6fb6689587ca5af24 upstream.
The HS descriptors are only created if HS is supported by the UDC but we
never free them.
commit 98c35534420d3147553bd3071a5fc63cd56de5b1 upstream.
The pointer to a platform_device struct must not be dereferenced after
the device has been unregistered.
This bug produces a crash when unloading the ci13xxx kernel module
compiled with CONFIG_PAGE_POISONING enabled.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Acked-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
commit 4010fe21a315b4223c25376714c6a2b61b722e5c upstream.
This patch adds USBIDs for:
- DrayTek Vigor 530
- Zoom 4410a
It also adds a note about Gemtek WUBI-100GW
and SparkLAN WL-682 USBID conflict [WUBI-100GW
is a ISL3886+NET2280 (LM86 firmare) solution,
whereas WL-682 is a ISL3887 (LM87 firmware)]
device.
Source: <http://www.wikidevi.com/wiki/Intersil/p54/usb/windows>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
commit 3194b7fcdf6caea338b5d2c72d76fed80437649c upstream.
Added USB ID for T-Com Sinus 154 data II.
Signed-off-by: Tomasz Guszkowski <tsg@o2.pl>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
commit 4c3de5920c486b8eefa6187ee6a181864c161100 upstream.
Incorrect use of usb_alloc_coherent memory as input buffer to usb_control_msg
can cause problems in arch DMA code, for example kernel BUG at
'arch/arm/include/asm/dma-mapping.h:321' on ARM (linux-3.4).
Change _usb_writeN_sync use kmalloc'd buffer instead.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
commit 0370acd4d4d2595a11b0b0a793acb506e19b9d4c upstream.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Acked-by: Bjørn Mork <bjorn@mork.no>
commit b92b1b89a33c172c075edccf6afb0edc41d851fd upstream.
Virtio devices may attempt to add descriptors to a virtqueue from atomic
context using GFP_ATOMIC allocation. This is problematic because such
allocations can fall outside of the lowmem mapping, causing virt_to_phys
to report bogus physical addresses which are subsequently passed to
userspace via the buffers for the virtual device.
This patch masks out __GFP_HIGH and __GFP_HIGHMEM from the requested
flags when allocating descriptors for a virtqueue. If an atomic
allocation is requested and later fails, we will return -ENOSPC which
will be handled by the driver.
Cc: Sasha Levin <levinsasha928@gmail.com>
commit ad68652412276f68ad4fe3e1ecf5ee6880876783 upstream.
Some MSI laptop BIOSes are broken - INT 15h code uses port 92h to enable A20
line but resume code assumes that KBC was used.
The laptop will not resume from S3 otherwise but powers off after a while
and then powers on again stuck with a blank screen.
Fix it by enabling A20 using KBC in i8042_platform_init for x86.
Fixes https://bugzilla.kernel.org/show_bug.cgi?id=12878
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Link: http://lkml.kernel.org/r/201212112218.06551.linux@rainbow-software.org
commit 891348ca0f66206f1dc0e30d63757e3df1ae2d15 upstream.
We found a user code which was raising a divide-by-zero trap. That trap
would lead to XPC connections between system-partitions being torn down
due to the die_chain notifier callouts it received.
This also revealed a different issue where multiple callers into
xpc_die_deactivate() would all attempt to do the disconnect in parallel
which would sometimes lock up but often overwhelm the console on very
large machines as each would print at least one line of output at the
end of the deactivate.
I reviewed all the users of the die_chain notifier and changed the code
to ignore the notifier callouts for reasons which will not actually lead
to a system to continue on to call die().
[akpm@linux-foundation.org: fix ia64]
Signed-off-by: Robin Holt <holt@sgi.com>
commit cdc87c5a30f407ed1ce43d8a22261116873d5ef1 upstream.
TEST_ALPHA() is broken and always returns 0.
[akpm@linux-foundation.org: return false for '@' as well, per Bjorn]
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
commit 78f18df4b323d2ac14d6c82e2fc3c8dc4556bccc upstream.
ieee80211_free_txskb() needs to be used instead of dev_kfree_skb_any for
tx packets passed to the driver from mac80211
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit 576d28a7c73013717311cfcb514dbcae27c82eeb upstream.
Recent versions of udev cause synchronous firmware loading from the
probe routine to fail because the request to user space times out.
The original fix for b43legacy (commit a3ea2c7) moved the firmware
load from the probe routine to a work queue, but it still used synchronous
firmware loading. This method is OK when b43legacy is built as a module;
however, it fails when the driver is compiled into the kernel.
This version changes the code to load the initial firmware file
using request_firmware_nowait(). A completion event is used to
hold the work queue until that file is available. The remaining
firmware files are read synchronously.
commit bd9eb7fbe69111ea0ff1f999ef4a5f26d223d1d5 upstream.
There is one race that both request_firmware() with the same
firmware name.
The race scenerio is as below:
CPU1 CPU2
request_firmware() -->
_request_firmware_load() return err another request_firmware() is coming -->
_request_firmware_cleanup is called --> _request_firmware_prepare -->
release_firmware ---> fw_lookup_and_allocate_buf -->
spin_lock(&fwc->lock)
... __fw_lookup_buf() return true
fw_free_buf() will be called --> ...
kref_put -->
decrease the refcount to 0
kref_get(&tmp->ref) ==> it will trigger warning
due to refcount == 0
__fw_free_buf() -->
... spin_unlock(&fwc->lock)
list_del(&buf->list)
kfree(buf)
After that, the freed buf will be used.
The key race is decreasing refcount to 0 and list_del is not protected together by
fwc->lock, and it is possible another thread try to get it between refcount==0
and list_del.
Fix it here to protect it together.
Acked-by: Ming Lei <ming.lei@canonical.com>
Signed-off-by: liu chuansheng <chuansheng.liu@intel.com>
commit ce2fcbd99cef580623116bb33531dbc3e6f690b0 upstream.
There is a race as below when calling request_firmware():
CPU1 CPU2
write 0 > loading
mutex_lock(&fw_lock)
set_bit FW_STATUS_DONE class_timeout is coming
set_bit FW_STATUS_ABORT
complete_all &completion
mutex_unlock(&fw_lock)
In this time, the bit FW_STATUS_DONE and FW_STATUS_ABORT are set,
and request_firmware() will return failure due to condition in
_request_firmware_load():
if (!buf->size || test_bit(FW_STATUS_ABORT, &buf->status))
retval = -ENOENT;
But from the above scenerio, it should be a successful requesting.
So we need judge if the bit FW_STATUS_DONE is already set before
calling fw_load_abort() in timeout function.
As Ming's proposal, we need change the timer into sched_work to
benefit from using &fw_lock mutex also.
commit 4f29ef050848245f7c180b95ccf67dfcd76b1fd8 upstream.
This patch adds two new products and modifies
the device id table to include them. In addition,
product of 0xbccd - BCM_USB_PRODUCT_ID_SM250 is
removed because Beceem, ZTE, Sprint use this id
for block devices.
Reported-by: Muhammad Minhazul Haque <mdminhazulhaque@gmail.com>
Signed-off-by: Kevin McKinney <klmckinney1@gmail.com>
commit 2656a9abcf1ec8dd5fee6a75d6997a0f2fa0094e upstream.
This patch (as1632b) fixes a bug in ehci-hcd. The USB core uses
urb->hcpriv to determine whether or not an URB is active; host
controller drivers are supposed to set this pointer to a non-NULL
value when an URB is queued. However ehci-hcd sets it to NULL for
isochronous URBs, which defeats the check in usbcore.
In itself this isn't a big deal. But people have recently found that
certain sequences of actions will cause the snd-usb-audio driver to
reuse URBs without waiting for them to complete. In the absence of
proper checking by usbcore, the URBs get added to their endpoint list
twice. This leads to list corruption and a system freeze.
The patch makes ehci-hcd assign a meaningful value to urb->hcpriv for
isochronous URBs. Improving robustness always helps.
Reported-by: Artem S. Tashkinov <t.artem@lycos.com>
Reported-by: Christof Meerwald <cmeerw@cmeerw.org>
commit ba2d8ce9db0a61505362bb17b8899df3d3326146 upstream.
Some devices (ex Nokia C7) simply don't respond at all when data is sent
to some of their USB interfaces. The data gets stuck in the TTYs queue
and sits there until close(2), which them blocks because closing_wait
defaults to 30 seconds (even though the fd is O_NONBLOCK). This is
rarely desired. Implement the standard mechanism to adjust closing_wait
and let applications handle it how they want to.
See also 02303f73373aa1da19dbec510ec5a4e2576f9610 for usb_wwan.c.
Acked-by: Oliver Neukum <oneukum@suse.de>
Tested-by: Aleksander Morgado <aleksander@gnu.org>
commit bba18e33f25072ebf70fd8f7f0cdbf8cdb59a746 upstream.
Ali reports that plugging a device into the Fresco Logic xHCI host with
PCI device ID 1400 produces an IRQ error:
do_IRQ: 3.176 No irq handler for vector (irq -1)
Other early Fresco Logic host revisions don't support MSI, even though
their PCI config space claims they do. Extend the quirk to disabling
MSI to this chipset revision. Also enable the short transfer quirk,
since it's likely this revision also has that quirk, and it should be
harmless to enable.
04:00.0 0c03: 1b73:1400 (rev 01) (prog-if 30 [XHCI])
Subsystem: 1d5c:1000
Physical Slot: 3
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 51
Region 0: Memory at d4600000 (32-bit, non-prefetchable) [size=64K]
Capabilities: [50] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000feeff00c Data: 41b1
Capabilities: [80] Express (v1) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <2us, L1 <32us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 unlimited, L1 unlimited
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Kernel driver in use: xhci_hcd
This patch should be backported to stable kernels as old as 2.6.36, that
contain the commit f5182b4155b9d686c5540a6822486400e34ddd98 "xhci:
Disable MSI for some Fresco Logic hosts."
Reported-by: A Sh <smr.ash1991@gmail.com>
Tested-by: A Sh <smr.ash1991@gmail.com>
commit 50ce5c0683aa83eb161624ea89daa5a9eee0c2ce upstream.
This patch (as1636) is a partial workaround for a hardware bug
affecting OHCI controllers by NVIDIA at least, maybe others too. When
the controller retires a Transfer Descriptor, it is supposed to add
the TD onto the Done Queue. But sometimes this doesn't happen, with
the result that ohci-hcd never realizes the corresponding transfer has
finished. Symptoms can vary; a typical result is that USB audio stops
working after a while.
The patch works around the problem by recognizing that TDs are always
processed in order. Therefore, if a later TD is found on the Done
Queue than all the earlier TDs for the same endpoint must be finished
as well.
Unfortunately this won't solve the problem in cases where the missing
TD is the last one in the endpoint's queue. A complete fix would
require a signficant amount of change to the driver.
Tested-by: Oliver Neukum <oneukum@suse.de>
