commit 5ba2f67afb02c5302b2898949ed6fc3b3d37dcf1 upstream
NULL function pointers are very bad security wise. This one got caught by
kerneloops.org quite a few times, so it's happening in the field....
Fix is simple, check the function pointer for NULL, like 6 other places
in the same function are already doing.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
(cherry picked from commit a636da6bab3307fc8c6e6a22a63b0b25ba0687be)
DVB: au0828: add support for another USB id for Hauppauge HVR950Q
Add autodetection support for a new revision of the Hauppauge HVR950Q (2040:721e)
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
commit 4b40893918203ee1a1f6a114316c2a19c072e9bd upstream
Olaf Kirch noticed that the i915_set_status_page() function of the i915
kernel driver calls ioremap with an address offset that is supplied by
userspace via ioctl. The function zeroes the mapped memory via memset
and tells the hardware about the address. Turns out that access to that
ioctl is not restricted to root so users could probably exploit that to
do nasty things. We haven't tried to write actual exploit code though.
It only affects the Intel G33 series and newer.
upstream commmit: c2c789057f075022658b38b498755c29c1ba8055
According to acpi spec , the objectes of _BCL and _BCM are required if
integrated LCD is present and supports brightness level and the _BQC is
the optional object. So the _BQC object will be ignored when the backlight
device is registered.
At the same time when there is no _BQC object, the current brightness will be
set to the maximum.
http://bugzilla.kernel.org/show_bug.cgi?id=10206
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Cc: Len Brown <lenb@kernel.org>
based on commit 98dd22c3e086d76058083432d4d8fb85f04bab90 upstream
On the Shuttle SN68PT, FAN_CTL2 is apparently not connected to a fan,
but to something else. One user has reported instant system power-off
when changing the PWM2 duty cycle, so we disable it.
I use the board name string as the trigger in case the same board is
ever used in other systems.
This closes lm-sensors ticket #2349:
pwmconfig causes a hard poweroff
http://www.lm-sensors.org/ticket/2349
commit b5ff7df3df9efab511244d5a299fce706c71af48 upstream
Check mapped ranges on sysfs resource files
This is loosely based on a patch by Jesse Barnes to check the user-space
PCI mappings though the sysfs interfaces. Quoting Jesse's original
explanation:
It's fairly common for applications to map PCI resources through sysfs.
However, with the current implementation, it's possible for an application
to map far more than the range corresponding to the resourceN file it
opened. This patch plugs that hole by checking the range at mmap time,
similar to what is done on platforms like sparc64 in their lower level
PCI remapping routines.
It was initially put together to help debug the e1000e NVRAM corruption
problem, since we initially thought an X driver might be walking past the
end of one of its mappings and clobbering the NVRAM. It now looks like
that's not the case, but doing the check is still important for obvious
reasons.
and this version of the patch differs in that it uses a helper function
to clarify the code, and does all the checks in pages (instead of bytes)
in order to avoid overflows when doing "<< PAGE_SHIFT" etc.
[cebbert@redhat.com: backport, changing WARN() to printk()]
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Chuck Ebbert <cebbert@redhat.com>
commit 149e16372a2066c5474d8a8db9b252afd57eb427 upstream
Disable ASPM on pre-1.1 PCIe devices, as many of them don't implement it
correctly.
Tested-by: Jack Howarth <howarth@bromo.msbb.uc.edu>
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 5fde244d39b88625ac578d83e6625138714de031 upstream
The ACPI FADT table includes an ASPM control bit. If the bit is set, do
not enable ASPM since it may indicate that the platform doesn't actually
support the feature.
Commit fe6c700ff34e68e1eb7991e9c5d18986d0005ac1 upstream
V4L/DVB (9053): fix buffer overflow in uvc-video
There is a buffer overflow in drivers/media/video/uvc/uvc_ctrl.c:
INFO: 0xf2c5ce08-0xf2c5ce0b. First byte 0xa1 instead of 0xcc
INFO: Allocated in uvc_query_v4l2_ctrl+0x3c/0x239 [uvcvideo] age=13 cpu=1 pid=4975
A fixed size 8-byte buffer is allocated, and a variable size field is read
into it; there is no particular bound on the size of the field (it is
dependent on hardware and configuration) and it can overflow [also
verified by inserting printk's.]
The patch attempts to size the buffer to the correctly.
Acked-by: Laurent Pinchart <laurent.pinchart@skynet.be>
commit 04793dd041bbb88a39b768b714c725de2c339b51 upstream
Data buffers on the stack are not allowed for USB I/O. Use dynamically
allocated buffers instead.
Signed-off-by: Bruce Schmid <duck@freescale.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@skynet.be>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
boolean control.
commit 54812c77bc830e2dbcb62b4c6d8a9c7f97cfdd1b upstream
[required to get the following two patches to apply]
Although the V4L2 spec states that the minimum and maximum fields may not be
valid for control types other than V4L2_CTRL_TYPE_INTEGER, it makes sense
to set the bounds to 0 and 1 for boolean controls instead of returning
uninitialized values.
cherry picked from commit a30ee3c747728f9151664118ffcbdeefd202c332
The zr36067 driver is improperly declaring pixel format RGBP twice,
once as "16-bit RGB LE" and once as "16-bit RGB BE". The latter is
actually RGBR. Fix the code to properly map both pixel formats.
Acked-by: Trent Piepho <xyzzy@speakeasy.org>
(cherry picked from commit c37396c19403e249f12626187d51e92c915f2bc9)
Fix the following crash in the bttv driver:
BUG: unable to handle kernel NULL pointer dereference at 000000000000036c
IP: [<ffffffffa037860a>] radio_open+0x3a/0x170 [bttv]
This happens because radio_open assumes that all present bttv devices
have a radio function. If a bttv device without radio and one with
radio are installed on the same system, and the one without radio is
registered first, then radio_open checks for the radio device number
of a bttv device that has no radio function, and this breaks. All we
have to do to fix it is to skip bttv devices without a radio function.
Commit a674050e068a2919908730279f0b731ae6d2e005 upstream
ehc->i.action got accidentally overwritten to ATA_EH_HARD/SOFTRESET in
ata_eh_reset(). The original intention was to clear reset action
which wasn't selected. This can cause unexpected behavior when other
EH actions are scheduled together with reset. Fix it.
commit 5dbfc9cb59d4ad75199949d7dd8a8c6d7bc518df upstream
As an optimization, follow-up SRST used to be skipped if
classification wasn't requested even when hardreset requested it via
-EAGAIN. However, some hardresets can't wait for device readiness and
skipping SRST can cause timeout or other failures during revalidation.
Always perform follow-up SRST if hardreset returns -EAGAIN. This
makes reset paths more predictable and thus less error-prone.
While at it, move hardreset error checking such that it's done right
after hardreset is finished. This simplifies followup SRST condition
check a bit and makes the reset path easier to modify.
commit 232fb69a53a5ec3f22a8104d447abe4806848a8f upstream
echo 3 >> /sys/class/graphics/fbcon/rotate_all, then switch to another
console. Result:
BUG: unable to handle kernel paging request at ffffc20005d00000
IP: [bitfill_aligned+149/265] bitfill_aligned+0x95/0x109
PGD 7e228067 PUD 7e229067 PMD 7bc1f067 PTE 0
Oops: 0002 [1] SMP
CPU 1
Modules linked in: [...a lot...]
Pid: 10, comm: events/1 Not tainted 2.6.26.5-45.fc9.x86_64 #1
RIP: 0010:[bitfill_aligned+149/265] [bitfill_aligned+149/265] bitfill_aligned+0x95/0x109
RSP: 0018:ffff81007d811bc8 EFLAGS: 00010216
RAX: ffffc20005d00000 RBX: 0000000000000000 RCX: 0000000000000400
RDX: 0000000000000000 RSI: ffffc20005d00000 RDI: ffffffffffffffff
RBP: ffff81007d811be0 R08: 0000000000000400 R09: 0000000000000040
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000010000
R13: ffffffff811632f0 R14: 0000000000000006 R15: ffff81007cb85400
FS: 0000000000000000(0000) GS:ffff81007e004780(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: ffffc20005d00000 CR3: 0000000000201000 CR4: 00000000000006e0
Process events/1 (pid: 10, threadinfo ffff81007d810000, task ffff81007d808000)
Stack: ffff81007c9d75a0 0000000000000000 0000000000000000 ffff81007d811c80
ffffffff81163a61 ffff810000000000 ffffffff8115f9c8 0000001000000000
0000000100aaaaaa 000000007cd0d4a0 fffffd8a00000800 0001000000000000
Call Trace:
[cfb_fillrect+523/798] cfb_fillrect+0x20b/0x31e
[soft_cursor+416/436] ? soft_cursor+0x1a0/0x1b4
[ccw_clear_margins+205/263] ccw_clear_margins+0xcd/0x107
[fbcon_clear_margins+59/61] fbcon_clear_margins+0x3b/0x3d
[fbcon_switch+1291/1466] fbcon_switch+0x50b/0x5ba
[redraw_screen+261/481] redraw_screen+0x105/0x1e1
[ccw_cursor+0/1869] ? ccw_cursor+0x0/0x74d
[complete_change_console+48/190] complete_change_console+0x30/0xbe
[change_console+115/120] change_console+0x73/0x78
[console_callback+0/292] ? console_callback+0x0/0x124
[console_callback+97/292] console_callback+0x61/0x124
[schedule_delayed_work+25/30] ? schedule_delayed_work+0x19/0x1e
[run_workqueue+139/282] run_workqueue+0x8b/0x11a
[worker_thread+221/238] worker_thread+0xdd/0xee
[autoremove_wake_function+0/56] ? autoremove_wake_function+0x0/0x38
[worker_thread+0/238] ? worker_thread+0x0/0xee
[kthread+73/118] kthread+0x49/0x76
[child_rip+10/18] child_rip+0xa/0x12
[kthread+0/118] ? kthread+0x0/0x76
[child_rip+0/18] ? child_rip+0x0/0x12
Because fbcon_set_all_vcs()->FBCON_SWAP() uses display->rotate == 0 instead
of fbcon_ops->rotate, and vc_resize() has no effect because it is called with
new_cols/rows == ->vc_cols/rows.
Tested on 2.6.26.5-45.fc9.x86_64, but
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git seems to
have the same problem.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
commit c6a2afdacccd56cc0be8e9a7977f0ed1509069f6 upstream
Date: Sat, 6 Sep 2008 16:51:22 -0500
Subject: b43legacy: Fix failure in rate-adjustment mechanism
A coding error present since b43legacy was incorporated into the
kernel has prevented the driver from using the rate-setting mechanism
of mac80211. The driver has been forced to remain at a 1 Mb/s rate.
commit 8f520021837d45c47d0ab57e7271f8d88bf7f3a4 upstream
(only the tty_io.c portion of this commit)
This moves us towards sanity and should mean our termios locking is now
complete and comprehensive.
Signed-off-by: Alan Cox <alan@redhat.com>
commit 2e4a75cdcb89ff53bb182dda3a6dcdc14befe007 upstream
When userspace uses SIGIO notification and forgets to disable it before
closing file descriptor, rtc->async_queue contains stale pointer to struct
file. When user space enables again SIGIO notification in different
process, kernel dereferences this (poisoned) pointer and crashes.
So disable SIGIO notification on close.
Kernel panic:
(second run of qemu (requires echo 1024 > /sys/class/rtc/rtc0/max_user_freq))
general protection fault: 0000 [1] PREEMPT
CPU 0
Modules linked in: af_packet snd_pcm_oss snd_mixer_oss snd_seq_oss snd_seq_midi_event snd_seq usbhid tuner tea5767 tda8290 tuner_xc2028 xc5000 tda9887 tuner_simple tuner_types mt20xx tea5761 tda9875 uhci_hcd ehci_hcd usbcore bttv snd_via82xx snd_ac97_codec ac97_bus snd_pcm snd_timer ir_common compat_ioctl32 snd_page_alloc videodev v4l1_compat snd_mpu401_uart snd_rawmidi v4l2_common videobuf_dma_sg videobuf_core snd_seq_device snd btcx_risc soundcore tveeprom i2c_viapro
Pid: 5781, comm: qemu-system-x86 Not tainted 2.6.27-rc6 #363
RIP: 0010:[<ffffffff8024f891>] [<ffffffff8024f891>] __lock_acquire+0x3db/0x73f
RSP: 0000:ffffffff80674cb8 EFLAGS: 00010002
RAX: ffff8800224c62f0 RBX: 0000000000000046 RCX: 0000000000000002
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff8800224c62f0
RBP: ffffffff80674d08 R08: 0000000000000002 R09: 0000000000000001
R10: ffffffff80238941 R11: 0000000000000001 R12: 0000000000000000
R13: 6b6b6b6b6b6b6b6b R14: ffff88003a450080 R15: 0000000000000000
FS: 00007f98b69516f0(0000) GS:ffffffff80623200(0000) knlGS:00000000f7cc86d0
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000a87000 CR3: 0000000022598000 CR4: 00000000000006e0
Process qemu-system-x86 (pid: 5781, threadinfo ffff880028812000, task ffff88003a450080)
Stack: ffffffff80674cf8 0000000180238440 0000000200000002 0000000000000000
ffff8800224c62f0 0000000000000046 0000000000000000 0000000000000002
0000000000000002 0000000000000000 ffffffff80674d68 ffffffff8024fc7a
Call Trace:
<IRQ> [<ffffffff8024fc7a>] lock_acquire+0x85/0xa9
[<ffffffff8029cb62>] ? send_sigio+0x2a/0x184
[<ffffffff80491d1f>] _read_lock+0x3e/0x4a
[<ffffffff8029cb62>] send_sigio+0x2a/0x184
[<ffffffff8024fb97>] ? __lock_acquire+0x6e1/0x73f
[<ffffffff8029cd4d>] ? kill_fasync+0x2c/0x4e
[<ffffffff8029cd10>] __kill_fasync+0x54/0x65
[<ffffffff8029cd5b>] kill_fasync+0x3a/0x4e
[<ffffffff80402896>] rtc_update_irq+0x9c/0xa5
[<ffffffff80404640>] cmos_interrupt+0xae/0xc0
[<ffffffff8025d1c1>] handle_IRQ_event+0x25/0x5a
[<ffffffff8025e5e4>] handle_edge_irq+0xdd/0x123
[<ffffffff8020da34>] do_IRQ+0xe4/0x144
[<ffffffff8020bad6>] ret_from_intr+0x0/0xf
<EOI> [<ffffffff8026fdc2>] ? __alloc_pages_internal+0xe7/0x3ad
[<ffffffff8033fe67>] ? clear_page_c+0x7/0x10
[<ffffffff8026fc10>] ? get_page_from_freelist+0x385/0x450
[<ffffffff80280aac>] ? anon_vma_prepare+0x2e/0xf6
[<ffffffff80279400>] ? handle_mm_fault+0x227/0x6a5
[<ffffffff80494716>] ? do_page_fault+0x494/0x83f
[<ffffffff8049251d>] ? error_exit+0x0/0xa9
Code: cc 41 39 45 28 74 24 e8 5e 1d 0f 00 85 c0 0f 84 6a 03 00 00 83 3d 8f a9 aa 00 00 be 47 03 00 00 0f 84 6a 02 00 00 e9 53 03 00 00 <41> ff 85 38 01 00 00 45 8b be 90 06 00 00 41 83 ff 2f 76 24 e8
RIP [<ffffffff8024f891>] __lock_acquire+0x3db/0x73f
RSP <ffffffff80674cb8>
---[ end trace 431877d860448760 ]---
Kernel panic - not syncing: Aiee, killing interrupt handler!
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
commit 08650869e0ec581f8d88cfdb563d37f5383abfe2 upstream
Commit 22af89aa0c0b4012a7431114a340efd3665a7617 ("fbcon: replace mono_col
macro with static inline") changed the order of operations for computing
monochrome color values. This generates 0xffff000f instead of 0x0000000f
for a 4 bit monochrome color, leading to image corruption if it is passed
to cfb_imageblit or other similar functions. Fix it up.
Cc: Harvey Harrison <harvey.harrison@gmail.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
commit c0c9209ddd96bc4f1d70a8b9958710671e076080 upstream
Only register the braille driver VT and keyboard notifiers when the
braille console is used. Avoids eating insert or backspace keys.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=11242
Signed-off-by: Pascal Terjan <pterjan@mandriva.com>
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: <stable@kernel.org>
Cc: Moritz Muehlenhoff <jmm@inutil.org>
[ Upstream commit cff502a38394fd33693f6233e03fca363dfa956d ]
The reset_task function in the niu driver does not reset the tx and rx
buffers properly. This leads to panic on reset. This patch is a
modified implementation of the previously posted fix.
Signed-off-by: Santwona Behera <santwona.behera@sun.com>
[ Upstream commit: cec5eb7be3a104fffd27ca967ee8e15a123050e2 ]
PCMCIA abuses dev->private_data in the probe methods. Unfortunately it
continues to abuse it after calling drv->probe() which leads to crashes and
other nasties (such as bogus probes of multifunction devices) giving errors like
pcmcia: registering new device pcmcia0.1
kernel: 0.1: GetNextTuple: No more items
Extract the passed data before calling the driver probe function that way
we don't blow up when the driver reuses dev->private_data as its right.
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
commit 9d699ed92a459cb408e2577e8bbeabc8ec3989e1 upstream
When EC is in Polling mode, OS will check the EC status continually by using
the following source code:
clear_bit(EC_FLAGS_WAIT_GPE, &ec->flags);
while (time_before(jiffies, delay)) {
if (acpi_ec_check_status(ec, event))
return 0;
msleep(1);
But msleep is realized by the function of schedule_timeout. At the same time
although one process is already waken up by some events, it won't be scheduled
immediately. So maybe there exists the following phenomena:
a. The current jiffies is already after the predefined jiffies.
But before timeout happens, OS has no chance to check the EC
status again.
b. If preemptible schedule is enabled, maybe preempt schedule will happen
before checking loop. When the process is resumed again, maybe
timeout already happens, which means that OS has no chance to check
the EC status.
In such case maybe EC status is already what OS expects when timeout happens.
But OS has no chance to check the EC status and regards it as AE_TIME.
So it will be more appropriate that OS will try to check the EC status again
when timeout happens. If the EC status is what we expect, it won't be regarded
as timeout. Only when the EC status is not what we expect, it will be regarded
as timeout, which means that EC controller can't give a response in time.
http://bugzilla.kernel.org/show_bug.cgi?id=9823
http://bugzilla.kernel.org/show_bug.cgi?id=11141
commit 8e260c22238dd8b57aefb1f5e4bd114486a9c17d upstream
Remove the rt2x00 singlethreaded workqueue and move
the link tuner and packet filter scheduled work to
the ieee80211_hw->workqueue again.
The only exception is the interface scheduled work
handler which uses the mac80211 interface iterator
under the RTNL lock. This work needs to be handled
on the kernel workqueue to prevent lockdep issues.
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
completes.
commit 048feec5548c0582ee96148c61b87cccbcb5f9be upstream
Josip Rodin noted
(http://article.gmane.org/gmane.linux.ports.sparc/10152) the
driver oopsing during registration of an rport to the
FC-transport layer with a backtrace indicating a dereferencing of
an shost->shost_data equal to NULL. David Miller identified a
small window in driver logic where this could happen:
> Look at how the driver registers the IRQ handler before the host has
> been registered with the SCSI layer.
> That leads to a window of time where the shost hasn't been setup
> fully, yet ISRs can come in and trigger DPC thread events, such as
> loop resyncs, which expect the transport area to be setup.
> But it won't be setup, because scsi_add_host() hasn't finished yet.
> Note that in Josip's crash log, we don't even see the
> qla_printk(KERN_INFO, ha, "\n"
> " QLogic Fibre Channel HBA Driver: %s\n"
> " QLogic %s - %s\n"
> " ISP%04X: %s @ %s hdma%c, host#=%ld, fw=%s\n",
> message yet.
> Which means that the crash occurs between qla2x00_request_irqs()
> and printing that message.
Close this window by enabling RISC interrupts after the host has
been registered with the SCSI midlayer.
Reported-by: Josip Rodin <joy@entuzijast.net>
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
commit 83a798207361cc26385187b2e71efa2b5d75de7f upstream
Commit de85422b94ddb23c021126815ea49414047c13dc, 'USB: fix interrupt
disabling for HCDs with shared interrupt handlers' changed usb_add_hcd()
to strip IRQF_DISABLED from irqflags prior to calling request_irq()
with the justification that such a removal was necessary for shared
interrupts to work properly. Unfortunately, the change in that commit
unconditionally removes the IRQF_DISABLED flag, causing problems on
platforms that don't use a shared interrupt but require IRQF_DISABLED.
This change adds a check for IRQF_SHARED prior to removing the
IRQF_DISABLED flag.
Fixes the PS3 system startup hang reported with recent Fedora and
OpenSUSE kernels.
Note that this problem is hidden when CONFIG_LOCKDEP=y (ps3_defconfig),
as local_irq_enable_in_hardirq() is defined as a null statement for
that config.
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Stefan Becker <Stefan.Becker@nokia.com>
commit 20b918dc77b383e9779dafceee3f2198a6f7b0e5 upstream
This patch fixes a build error in the pxa2xx-spi driver,
introduced by commit 7e96445533ac3f4f7964646a202ff3620602fab4
("pxa2xx_spi: dma bugfixes")
CC drivers/spi/pxa2xx_spi.o
drivers/spi/pxa2xx_spi.c: In function 'map_dma_buffers':
drivers/spi/pxa2xx_spi.c:331: error: invalid operands to binary &
drivers/spi/pxa2xx_spi.c: In function 'pump_transfers':
drivers/spi/pxa2xx_spi.c:897: warning: format '%lu' expects type 'long unsigned int', but argument 4 has type 'unsigned int'
[dbrownell@users.sourceforge.net: fix warning too ]
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: Eric Miao <eric.miao@marvell.com>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
commit 8423597d676615f3dd2d9ab36f59f147086b90b8 upstream
Fixes several chipselect bugs in the pxa2xx_spi driver. These bugs are in
all versions of this driver and prevent using it with chips like m25p16
flash.
1. The spi_transfer.cs_change flag is handled too early:
before spi_transfer.delay_usecs applies, thus making the
delay ineffective at holding chip select.
2. spi_transfer.delay_usecs is ignored on the last transfer
of a message (likewise not holding chipselect long enough).
3. If spi_transfer.cs_change is set on the last transfer, the
chip select is always disabled, instead of the intended
meaning: optionally holding chip select enabled for the
next message.
Those first three bugs were fixed with a relocation of delays
and chip select de-assertions.
4. If a message has the cs_change flag set on the last transfer,
and had the chip select stayed enabled as requested (see 3,
above), it would not have been disabled if the next message is
for a different chip. Fixed by dropping chip select regardless
of cs_change at end of a message, if there is no next message
or if the next message is for a different chip.
This patch should apply to all kernels back to and including 2.6.20;
it was test patched against 2.6.20. An additional patch would be
required for older kernels, but those versions are very buggy anyway.
Signed-off-by: Ned Forrester <nforrester@whoi.edu>
Cc: Vernon Sauder <vernoninhand@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
commit 7e96445533ac3f4f7964646a202ff3620602fab4 upstream
Fixes two DMA bugs in the pxa2xx_spi driver. The first bug is in all
versions of this driver; the second was introduced in the 2.6.20 kernel,
and prevents using the driver with chips like m25p16 flash (which can
issue large DMA reads).
1. Zero length transfers are permitted for use to insert timing,
but pxa2xx_spi.c will fail if this is requested in DMA mode.
Fixed by using programmed I/O (PIO) mode for such transfers.
2. Transfers larger than 8191 are not permitted in DMA mode. A
test for length rejects all large transfers regardless of DMA
or PIO mode. Worked around by rejecting only large transfers
with DMA mapped buffers, and forcing all other transfers
larger than 8191 to use PIO mode. A rate limited warning is
issued for DMA transfers forced to PIO mode.
commit 70bb08962ea9bd50797ae9f16b2493f5f7c65053 upstream
mmc_block_open() increments md->usage although it returns with -EROFS when
default mounting a MMC/SD card with write protect switch on. This
reference counting bug prevents /dev/mmcblkX from being released on card
removal, and situation worsen with reinsertion until the minor number
range runs out.
Reported-by: <sasin@solomon-systech.com>
Acked-by: Pierre Ossman <drzeus-list@drzeus.cx>
commit 15e79f24b60c4b0bf8019423bda4e03a576b02f2 upstream
This commit dropped the setting of the default interrupt throttle rate.
commit 021230d40ae0e6508d6c717b6e0d6d81cd77ac25
Author: Ayyappan Veeraiyan <ayyappan.veeraiyan@intel.com>
Date: Mon Mar 3 15:03:45 2008 -0800
ixgbe: Introduce MSI-X queue vector code
The following patch adds it back. Without this the default value of 0
causes the performance of this card to be awful. Restoring these to the
default values yields much better performance.
This regression has been around since 2.6.25.
Signed-off-by: Andy Gospodarek <andy@greyhouse.net>
Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
In Linus' tree:
http://git.kernel.org/?p=linux%2Fkernel%2Fgit%2Ftorvalds%2Flinux-2.6.git;a=commit;h=e74783ec3cb981211689bd2cfd3248f8dc48ec01
We need to convert the error pointer from class_create(), else we'll return the
successful return code from register_chrdev() on failure.
Signed-off-by: Sven Wegener <sven.wegener@stealer.net>
commit 9f497bcc695fb828da023d74ad3c966b1e58ad21 upstream
ACPI: Fix thermal shutdowns
Do not use unsigned int if there is test for negative number...
See drivers/acpi/processor_perflib.c
static unsigned int ignore_ppc = -1;
if (event == CPUFREQ_START && ignore_ppc <= 0) {
ignore_ppc = 0;
Signed-off-by: Milan Broz <mbroz@redhat.com>
commit 4bdee6c5103696a2729d3db2f235d202191788e4 upstream
sata_mv allowed issuing two DMA commands concurrently which the
hardware allows. Unfortunately, libata core layer isn't ready for
this yet and spews ugly warning message and malfunctions on this.
Don't allow concurrent DMA commands for now.
Cc: Martin Michlmayr <tbm@cyrius.com>
Cc: Mark Lord <liml@rtr.ca>
Cc: Artem Bokhan <aptem@ngs.ru>
commit a866bbf6aacf95f849810079442a20be118ce905 upstream
The leak hurts with swiotlb and jumbo frames.
Fix http://bugzilla.kernel.org/show_bug.cgi?id=9468.
Heavily hinted by Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Tested-by: Alistair John Strachan <alistair@devzero.co.uk>
Tested-by: Timothy J Fontaine <tjfontaine@atxconsulting.com>
Cc: Edward Hsu <edward_hsu@realtek.com.tw>
patch 4ba526ced990f4d61ee8d65fe8a6f0745e8e455c upstream
The git commit 7c5026aa9b81dd45df8d3f4e0be73e485976a8b6 ("tg3: Add
link state reporting to UMP firmware") introduced code that waits for
previous firmware events to be serviced before attempting to submit a
new event. Unfortunately that patch contained a bug that cause the
driver to wait 2.5 seconds, rather than 2.5 milliseconds as intended.
This patch fixes that bug.
This bug revealed that not all firmware versions service driver events
though. Since we do not know which versions of the firmware do and don't
service these events, the driver needs some way to minimize the effects
of the delay. This patch solves the problem by recording a jiffies
timestamp when it submits an event to the hardware. If the jiffies
counter shows that 2.5 milliseconds have already passed, a wait is not
needed and the driver can proceed to submit a new event.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
commit 363f66fe06c75270b669c88e321e6b354ba0201e upstream
Recent changes to tighten the check for UARTs that don't correctly
re-assert THRE (01c194d9278efc15d4785ff205643e9c0bdcef53: "serial 8250:
tighten test for using backup timer") caused problems when such a UART was
opened for the second time - the bug could only successfully be detected
at first initialization. For users of this version of this particular
UART IP it is fatal.
This patch stores the information about the bug in the bugs field of the
port structure when the port is first started up so subsequent opens can
check this bit even if the test for the bug fails.
David Brownell: "My own exposure to this is that the UART on DaVinci
hardware, which TI allegedly derived from its original 16550 logic, has
periodically gone from working to unusable with the mainline 8250.c ...
and back and forth a bunch. Currently it's "unusable", a regression from
some previous versions. With this patch from Will, it's usable."
Signed-off-by: Will Newton <will.newton@gmail.com>
Acked-by: Alex Williamson <alex.williamson@hp.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: David Brownell <david-b@pacbell.net>
commit 73442daf2ea85e2a779396b76b1a39b10188ecb5 upstream
commit 945185a69daa457c4c5e46e47f4afad7dcea734f ("rtc: rtc_time_to_tm: use
unsigned arithmetic") changed the some types in rtc_time_to_tm() to
unsigned:
void rtc_time_to_tm(unsigned long time, struct rtc_time *tm)
- register int days, month, year;
+ unsigned int days, month, year;
This doesn't work for all cases, because days is checked for < 0 later
on:
if (days < 0) {
year -= 1;
days += 365 + LEAP_YEAR(year);
I think the correct fix would be to keep days signed and do an appropriate
cast later on.
Signed-off-by: Jan Altenberg <jan.altenberg@linutronix.de>
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Dmitri Vorobiev <dmitri.vorobiev@gmail.com>
commit 8b76f46a2db29407fed66cf4aca19d61b3dcb3e1 upstream
Fix a bug reported by and diagnosed by Aaron Straus.
This is a regression intruduced into 2.6.26 by
commit adc782dae6c4c0f6fb679a48a544cfbcd79ae3dc
Author: Matt Mackall <mpm@selenic.com>
Date: Tue Apr 29 01:03:07 2008 -0700
random: simplify and rename credit_entropy_store
credit_entropy_bits() does:
spin_lock_irqsave(&r->lock, flags);
if (r->entropy_count > r->poolinfo->POOLBITS)
r->entropy_count = r->poolinfo->POOLBITS;
so there is a time window in which this BUG_ON():
static size_t account(struct entropy_store *r, size_t nbytes, int min,
int reserved)
unsigned long flags;
BUG_ON(r->entropy_count > r->poolinfo->POOLBITS);
/* Hold lock while accounting */
can trigger.
We could fix this by moving the assertion inside the lock, but it seems
safer and saner to revert to the old behaviour wherein
entropy_store.entropy_count at no time exceeds
entropy_store.poolinfo->POOLBITS.
Reported-by: Aaron Straus <aaron@merfinllc.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Theodore Ts'o <tytso@mit.edu>
commit 82c26a9d117f0178b8c1b33429014b6d99c470f6 upstream
The atl1 driver is causing stalled connections and file corruption
whenever TSO is enabled. Two examples are here:
http://lkml.org/lkml/2008/7/15/325
http://lkml.org/lkml/2008/8/18/543
Disable TSO by default until we can determine the source of the
problem.
Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net>
commit edcfe5f7e307846e578fb88d69fa27051fded0ab upstream
Fix the checksum feature advertised in device flags. The hardware support
TCP/UDP over IPv4 and TCP/UDP over IPv6 (without IPv6 extension headers).
However, the kernel feature flags do not distinguish IPv6 with/without
extension headers.
Therefore, the driver needs to use NETIF_F_IP_CSUM instead of
NETIF_F_HW_CSUM since the latter includes all IPv6 packets.
A future patch can be created to check for extension headers and perform
software checksum calculation.
Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
commit 49fd38bdaa96f093fcad3176a781a4d0de8f8602 upstream
The Perform Subsystem Function/Prepare for Read Subsystem Data
command requires 12 bytes of parameter data, but the respective data
structure dasd_psf_prssd_data has a length of 16 bytes.
Current storage servers ignore the obsolete bytes, but older models
fail to execute the command and report an incorrect length error.
This causes the device initilization for these devices to fail.
To fix this problem we need to correct the dasd_psf_prssd_data
structure and shorten it to the correct length.
Reported-by: Ivan Warren <ivan@vmfacility.fr>
Reviewed-by: Ivan Warren <ivan@vmfacility.fr>
Tested-by: Ivan Warren <ivan@vmfacility.fr>
Signed-off-by: Stefan Weinhuber <wein@de.ibm.com>
commit 74573ee7096a4ffc2f098108d21c85801b9c7434 upstream
On Wed, Jul 23, 2008 at 03:52:36PM +0300, Andrei Popa wrote:
> I installed gnokii-0.6.22-r2 and gave the command "gnokii --identify"
> and the kernel oopsed:
> BUG: unable to handle kernel NULL pointer dereference at 00000458
> IP: [<c0444b52>] mutex_unlock+0x0/0xb
> [<c03830ae>] acm_tty_open+0x4c/0x214
Tested-by: Andrei Popa <andrei.popa@i-neo.ro>
commit d847471d063663b9f36927d265c66a270c0cfaab upstream
Fixes kernel BUG at lib/radix-tree.c:473.
Previously the handler was incidentally provided by tmpfs but this was
removed with:
commit 14fcc23fdc78e9d32372553ccf21758a9bd56fa1
Author: Hugh Dickins <hugh@veritas.com>
Date: Mon Jul 28 15:46:19 2008 -0700
tmpfs: fix kernel BUG in shmem_delete_inode
relying on this behaviour was incorrect in any case and the BUG also
appeared when the device node was on an ext3 filesystem.
v2: override a_ops at open() time rather than mmap() time to minimise
races per AKPM's concerns.
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Cc: Jaya Kumar <jayakumar.lkml@gmail.com>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Johannes Weiner <hannes@saeurebad.de>
Cc: Kel Modderman <kel@otaku42.de>
Cc: Markus Armbruster <armbru@redhat.com>
commit f14413184b1de4dcbd5ec3e7c129c3ce2079f543 upstream
Date: Wed, 20 Aug 2008 14:08:57 -0700
Subject: eeepc-laptop: fix use after free
eeepc-laptop uses the hwmon struct after unregistering the device, causing
an oops on module unload. Flip the ordering to fix.
Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Cc: Corentin Chary <corentincj@iksaif.net>
Cc: Karol Kozimor <sziwan@users.sourceforge.net>
commit ebca4f1bce1eb7b91a63c515db66316db9391221 upstream
Alex Chiang and Matthew Wilcox pointed out that pci_get_dev_by_id() does
not properly decrement the reference on the from pointer if it is
present, like the documentation for the function states it will.
It fixes a pretty bad leak in the hotplug core (we were leaking an
entire struct pci_dev for each function of each offlined card, the first
time around; subsequent onlines/offlines were ok).
Cc: Matthew Wilcox <matthew@wil.cx>
Tested-by: Alex Chiang <achiang@hp.com>
Acked-by: Alex Chiang <achiang@hp.com>
crypto: padlock - fix VIA PadLock instruction usage with irq_ts_save/restore()
[ Upstream commit: e49140120c88eb99db1a9172d9ac224c0f2bbdd2 ]
Wolfgang Walter reported this oops on his via C3 using padlock for
AES-encryption:
BUG: unable to handle kernel NULL pointer dereference at 000001f0
IP: [<c01028c5>] __switch_to+0x30/0x117
*pde = 00000000
Oops: 0002 [#1] PREEMPT
Modules linked in:
Pid: 2071, comm: sleep Not tainted (2.6.26 #11)
EIP: 0060:[<c01028c5>] EFLAGS: 00010002 CPU: 0
EIP is at __switch_to+0x30/0x117
EAX: 00000000 EBX: c0493300 ECX: dc48dd00 EDX: c0493300
ESI: dc48dd00 EDI: c0493530 EBP: c04cff8c ESP: c04cff7c
DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068
Process sleep (pid: 2071, ti=c04ce000 task=dc48dd00 task.ti=d2fe6000)
Stack: dc48df30 c0493300 00000000 00000000 d2fe7f44 c03b5b43 c04cffc8 00000046
c0131856 0000005a dc472d3c c0493300 c0493470 d983ae00 00002696 00000000
c0239f54 00000000 c04c4000 c04cffd8 c01025fe c04f3740 00049800 c04cffe0
Call Trace:
[<c03b5b43>] ? schedule+0x285/0x2ff
[<c0131856>] ? pm_qos_requirement+0x3c/0x53
[<c0239f54>] ? acpi_processor_idle+0x0/0x434
[<c01025fe>] ? cpu_idle+0x73/0x7f
[<c03a4dcd>] ? rest_init+0x61/0x63
Wolfgang also found out that adding kernel_fpu_begin() and kernel_fpu_end()
around the padlock instructions fix the oops.
Suresh wrote:
These padlock instructions though don't use/touch SSE registers, but it behaves
similar to other SSE instructions. For example, it might cause DNA faults
when cr0.ts is set. While this is a spurious DNA trap, it might cause
oops with the recent fpu code changes.
This is the code sequence that is probably causing this problem:
a) new app is getting exec'd and it is somewhere in between
start_thread() and flush_old_exec() in the load_xyz_binary()
b) At pont "a", task's fpu state (like TS_USEDFPU, used_math() etc) is
cleared.
c) Now we get an interrupt/softirq which starts using these encrypt/decrypt
routines in the network stack. This generates a math fault (as
cr0.ts is '1') which sets TS_USEDFPU and restores the math that is
in the task's xstate.
d) Return to exec code path, which does start_thread() which does
free_thread_xstate() and sets xstate pointer to NULL while
the TS_USEDFPU is still set.
e) At the next context switch from the new exec'd task to another task,
we have a scenarios where TS_USEDFPU is set but xstate pointer is null.
This can cause an oops during unlazy_fpu() in __switch_to()
Now:
1) This should happen with or with out pre-emption. Viro also encountered
similar problem with out CONFIG_PREEMPT.
2) kernel_fpu_begin() and kernel_fpu_end() will fix this problem, because
kernel_fpu_begin() will manually do a clts() and won't run in to the
situation of setting TS_USEDFPU in step "c" above.
3) This was working before the fpu changes, because its a spurious
math fault which doesn't corrupt any fpu/sse registers and the task's
math state was always in an allocated state.
With out the recent lazy fpu allocation changes, while we don't see oops,
there is a possible race still present in older kernels(for example,
while kernel is using kernel_fpu_begin() in some optimized clear/copy
page and an interrupt/softirq happens which uses these padlock
instructions generating DNA fault).
This is the failing scenario that existed even before the lazy fpu allocation
changes:
0. CPU's TS flag is set
1. kernel using FPU in some optimized copy routine and while doing
kernel_fpu_begin() takes an interrupt just before doing clts()
2. Takes an interrupt and ipsec uses padlock instruction. And we
take a DNA fault as TS flag is still set.
3. We handle the DNA fault and set TS_USEDFPU and clear cr0.ts
4. We complete the padlock routine
5. Go back to step-1, which resumes clts() in kernel_fpu_begin(), finishes
the optimized copy routine and does kernel_fpu_end(). At this point,
we have cr0.ts again set to '1' but the task's TS_USEFPU is stilll
set and not cleared.
6. Now kernel resumes its user operation. And at the next context
switch, kernel sees it has do a FP save as TS_USEDFPU is still set
and then will do a unlazy_fpu() in __switch_to(). unlazy_fpu()
will take a DNA fault, as cr0.ts is '1' and now, because we are
in __switch_to(), math_state_restore() will get confused and will
restore the next task's FP state and will save it in prev tasks's FP state.
Remember, in __switch_to() we are already on the stack of the next task
but take a DNA fault for the prev task.
This causes the fpu leakage.
Fix the padlock instruction usage by calling them inside the
context of new routines irq_ts_save/restore(), which clear/restore cr0.ts
manually in the interrupt context. This will not generate spurious DNA
in the context of the interrupt which will fix the oops encountered and
the possible FPU leakage issue.
Reported-and-bisected-by: Wolfgang Walter <wolfgang.walter@stwm.de>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
commit 35405f256de924be56ea5edaca4cdc627f1bb0f8 upstream
BCM5706S wont work correctly unless VPD length truncated to 128
Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com>
commit 59f4ff2ecff4cef36378928cec891785b402e80c upstream
This patch (as1119b) will help to reduce the clutter of usb-storage's
unusual_devs file by automatically detecting some devices that need
the IGNORE_RESIDUE flag. The idea is that devices should never return
a non-zero residue for an INQUIRY or a READ CAPACITY command unless
they failed to transfer all the requested data. So if one of these
commands transfers a standard amount of data but there is a positive
residue, we know that the residue is bogus and we can set the flag.
This fixes the problems reported in Bugzilla #11125.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Matthew Frost <artusemrys@sbcglobal.net>
