path: root/drivers
2013-06-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix RTNL locking in batman-adv, from Matthias Schiffer. 2) Don't allow non-passthrough macvlan devices to set NOPROMISC via netlink, otherwise we can end up with corrupted promisc counter values on the device. From Michael S Tsirkin. 3) Fix stmmac driver build with debugging defines enabled, from Dinh Nguyen. 4) Make sure name string we give in socket address in AF_PACKET is NULL terminated, from Daniel Borkmann. 5) Fix leaking of two uninitialized bytes of memory to userspace in l2tp, from Guillaume Nault. 6) Clear IPCB(skb) before tunneling otherwise we touch dangling IP options state and crash. From Saurabh Mohan. 7) Fix suspend/resume for davinci_mdio by using suspend_late and resume_early. From Mugunthan V N. 8) Don't tag ip_tunnel_init_net and ip_tunnel_delete_net with __net_{init,exit}, they can be called outside of those contexts. From Eric Dumazet. 9) Fix RX length error in sh_eth driver, from Yoshihiro Shimoda. 10) Fix missing sctp_outq initialization in some code paths of SCTP stack, from Neil Horman. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (21 commits) sctp: fully initialize sctp_outq in sctp_outq_init netiucv: Hold rtnl between name allocation and device registration. tulip: Properly check dma mapping result net: sh_eth: fix incorrect RX length error if R8A7740 ip_tunnel: remove __net_init/exit from exported functions drivers: net: davinci_mdio: restore mdio clk divider in mdio resume drivers: net: davinci_mdio: moving mdio resume earlier than cpsw ethernet driver net/ipv4: ip_vti clear skb cb before tunneling. tg3: Wait for boot code to finish after power on l2tp: Fix sendmsg() return value l2tp: Fix PPP header erasure and memory leak bonding: fix igmp_retrans type and two related races bonding: reset master mac on first enslave failure packet: packet_getname_spkt: make sure string is always 0-terminated net: ethernet: stmicro: stmmac: Fix compile error when STMMAC_XMIT_DEBUG used be2net: Fix 32-bit DMA Mask handling xen-netback: don't de-reference vif pointer after having called xenvif_put() macvlan: don't touch promisc without passthrough batman-adv: Don't handle address updates when bla is disabled batman-adv: forward late OGMs from best next hop ...
2013-06-14Merge tag 'char-misc-3.10-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char / misc fixes from Greg Kroah-Hartman: "Here are some small mei driver fixes for 3.10-rc6 that fix some reported problems" * tag 'char-misc-3.10-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: mei: me: clear interrupts on the resume path mei: nfc: fix nfc device freeing mei: init: Flush scheduled work before resetting the device
2013-06-14Merge tag 'usb-3.10-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg Kroah-Hartman: "Here are some small USB driver fixes that resolve some reported problems for 3.10-rc6 Nothing major, just 3 USB serial driver fixes, and two chipidea fixes" * tag 'usb-3.10-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: usb: chipidea: fix id change handling usb: chipidea: fix no transceiver case USB: pl2303: fix device initialisation at open USB: spcp8x5: fix device initialisation at open USB: f81232: fix device initialisation at open
2013-06-13mei: me: clear interrupts on the resume pathTomas Winkler
We need to clear pending interrupts on the resume path. This brings the device into defined state before starting the reset flow This should solve suspend/resume issues: mei_me : wait hw ready failed. status = 0x0 mei_me : version message write failed Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13mei: nfc: fix nfc device freeingTomas Winkler
The nfc_dev is a static variable and is not cleaned properly upon reset mainly ndev->cl and ndev->cl_info are not set to NULL after freeing which mei_stop:198: mei_me 0000:00:16.0: stopping the device. [ 404.253427] general protection fault: 0000 [#2] SMP [ 404.253437] Modules linked in: mei_me(-) binfmt_misc snd_pcm_oss snd_mixer_oss snd_seq snd_seq_device edd af_packet cpufreq_conservative cpufreq_userspace cpufreq_powersave fuse loop dm_mod hid_generic usbhid hid coretemp acpi_cpufreq mperf kvm_intel kvm crc32c_intel ghash_clmulni_intel aesni_intel ablk_helper cryptd lrw gf128mul snd_hda_codec_hdmi glue_helper aes_x86_64 e1000e snd_hda_intel snd_hda_codec ehci_pci iTCO_wdt iTCO_vendor_support ehci_hcd snd_hwdep xhci_hcd snd_pcm usbcore ptp mei sg microcode snd_timer pps_core i2c_i801 snd pcspkr battery rtc_cmos lpc_ich mfd_core soundcore usb_common snd_page_alloc ac ext3 jbd mbcache drm_kms_helper drm intel_agp i2c_algo_bit intel_gtt i2c_core sd_mod crc_t10dif thermal fan video button processor thermal_sys hwmon ahci libahci libata scsi_mod [last unloaded: mei_me] [ 404.253591] CPU: 0 PID: 5551 Comm: modprobe Tainted: G D W 3.10.0-rc3 #1 [ 404.253611] task: ffff880143cd8300 ti: ffff880144a2a000 task.ti: ffff880144a2a000 [ 404.253619] RIP: 0010:[<ffffffff81334e5d>] [<ffffffff81334e5d>] device_del+0x1d/0x1d0 [ 404.253638] RSP: 0018:ffff880144a2bcf8 EFLAGS: 00010206 [ 404.253645] RAX: 2020302e30202030 RBX: ffff880144fdb000 RCX: 0000000000000086 [ 404.253652] RDX: 0000000000000001 RSI: 0000000000000086 RDI: ffff880144fdb000 [ 404.253659] RBP: ffff880144a2bd18 R08: 0000000000000651 R09: 0000000000000006 [ 404.253666] R10: 0000000000000651 R11: 0000000000000006 R12: ffff880144fdb000 [ 404.253673] R13: ffff880149371098 R14: ffff880144482c00 R15: ffffffffa04710e0 [ 404.253681] FS: 00007f251c59a700(0000) GS:ffff88014e200000(0000) knlGS:0000000000000000 [ 404.253689] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 404.253696] CR2: ffffffffff600400 CR3: 0000000145319000 CR4: 00000000001407f0 [ 404.253703] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 404.253710] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 [ 404.253716] Stack: [ 404.253720] ffff880144fdb000 ffff880143ffe000 ffff880149371098 ffffffffa0471000 [ 404.253732] ffff880144a2bd38 ffffffff8133502d ffff88014e20cf48 ffff880143ffe1d8 [ 404.253744] ffff880144a2bd48 ffffffffa02a4749 ffff880144a2bd58 ffffffffa02a4ba1 [ 404.253755] Call Trace: [ 404.253766] [<ffffffff8133502d>] device_unregister+0x1d/0x60 [ 404.253787] [<ffffffffa02a4749>] mei_cl_remove_device+0x9/0x10 [mei] [ 404.253804] [<ffffffffa02a4ba1>] mei_nfc_host_exit+0x21/0x30 [mei] [ 404.253819] [<ffffffffa029c2dd>] mei_stop+0x3d/0x90 [mei] [ 404.253830] [<ffffffffa046e220>] mei_me_remove+0x60/0xe0 [mei_me] [ 404.253843] [<ffffffff81278f37>] pci_device_remove+0x37/0xb0 [ 404.253855] [<ffffffff81337c68>] __device_release_driver+0x98/0x100 [ 404.253865] [<ffffffff81337d80>] driver_detach+0xb0/0xc0 [ 404.253876] [<ffffffff81336b4f>] bus_remove_driver+0x8f/0x120 [ 404.253891] [<ffffffff81075990>] ? try_to_wake_up+0x2b0/0x2b0 [ 404.253903] [<ffffffff81338a48>] driver_unregister+0x58/0x90 [ 404.253913] [<ffffffff8127906b>] pci_unregister_driver+0x2b/0xb0 [ 404.253924] [<ffffffffa046f244>] mei_me_driver_exit+0x10/0xdcc [mei_me] [ 404.253936] [<ffffffff810a50d8>] SyS_delete_module+0x198/0x2b0 [ 404.253949] [<ffffffff814850d9>] ? do_page_fault+0x9/0x10 [ 404.253961] [<ffffffff81489692>] system_call_fastpath+0x16/0x1b [ 404.253967] Code: 41 5c 41 5d 41 5e 41 5f c9 c3 0f 1f 40 00 55 48 89 e5 41 56 41 55 41 54 49 89 fc 53 48 8b 87 88 00 00 00 4c 8b 37 48 85 c0 74 18 <48> 8b 78 78 4c 89 e2 be 02 00 00 00 48 81 c7 f8 00 00 00 e8 3b [ 404.254048] RIP [<ffffffff81334e5d>] device_del+0x1d/0x1d0 Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13mei: init: Flush scheduled work before resetting the deviceSamuel Ortiz
Flushing pending work items before resetting the device makes more sense than doing so afterwards. Some of them, like e.g. the NFC initialization one, find themselves with client IDs changed after the reset, eventually leading to trigger a client.c:mei_me_cl_by_id() warning after a few modprobe/rmmod cycles. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13netiucv: Hold rtnl between name allocation and device registration.Benjamin Poirier
fixes a race condition between concurrent initializations of netiucv devices that try to use the same name. sysfs: cannot create duplicate filename '/devices/iucv/netiucv2' [...] Call Trace: ([<00000000002edea4>] sysfs_add_one+0xb0/0xdc) [<00000000002eecd4>] create_dir+0x80/0xfc [<00000000002eee38>] sysfs_create_dir+0xe8/0x118 [<00000000003835a8>] kobject_add_internal+0x120/0x2d0 [<00000000003839d6>] kobject_add+0x62/0x9c [<00000000003d9564>] device_add+0xcc/0x510 [<000003e00212c7b4>] netiucv_register_device+0xc0/0x1ec [netiucv] Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Tested-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13tulip: Properly check dma mapping resultNeil Horman
Tulip throws an error when dma debugging is enabled, as it doesn't properly check dma mapping results with dma_mapping_error() durring tx ring refills. Easy fix, just add it in, and drop the frame if the mapping is bad Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Grant Grundler <grundler@parisc-linux.org> CC: "David S. Miller" <davem@davemloft.net> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull device tree bug fixes from Grant Likely: "This branch contains the following bug fixes: - Fix locking vs. interrupts. Bug caught by lockdep checks - Fix parsing of cpp #line directive output by dtc - Fix 'make clean' for dtc temporary files. There is also a commit that regenerates the dtc lexer and parser files with Bison 2.5. The only purpose of this commit is to separate the functional change in the dtc bug fix from the code generation change caused by a different Bison version" * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux: dtc: ensure #line directives don't consume data from the next line dtc: Update generated files to output from Bison 2.5 of: Fix locking vs. interrupts kbuild: make sure we clean up DTB temporary files
2013-06-13of: Fix locking vs. interruptsBenjamin Herrenschmidt
The OF code uses irqsafe locks everywhere except in a handful of functions for no obvious reasons. Since the conversion from the old rwlocks, this now triggers lockdep warnings when used at interrupt time. At least one driver (ibmvscsi) seems to be doing that from softirq context. This converts the few non-irqsafe locks into irqsafe ones, making them consistent with the rest of the code. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-13Merge tag 'acpi-3.10-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI fix from Rafael Wysocki: "This is an alternative fix for the regression introduced in 3.9 whose previous fix had to be reverted right before 3.10-rc5, because it broke one of the Tony's machines. In this one the check is confined to the ACPI video driver (which is the only one causing the problem to happen in the first place) and the Tony's box shouldn't even notice it. - ACPI fix for an issue causing ACPI video driver to attempt to bind to devices it shouldn't touch from Rafael J Wysocki." * tag 'acpi-3.10-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / video: Do not bind to device objects with a scan handler
2013-06-13Merge tag 'md-3.10-fixes' of git://neil.brown.name/mdLinus Torvalds
Pull md bugfixes from Neil Brown: "A few bugfixes for md Some tagged for -stable" * tag 'md-3.10-fixes' of git://neil.brown.name/md: md/raid1,5,10: Disable WRITE SAME until a recovery strategy is in place md/raid1,raid10: use freeze_array in place of raise_barrier in various places. md/raid1: consider WRITE as successful only if at least one non-Faulty and non-rebuilding drive completed it. md: md_stop_writes() should always freeze recovery.
2013-06-13net: sh_eth: fix incorrect RX length error if R8A7740Yoshihiro Shimoda
This patch fixes an issue that the driver increments the "RX length error" on every buffer in sh_eth_rx() if the R8A7740. This patch also adds a description about the Receive Frame Status bits. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13drivers: net: davinci_mdio: restore mdio clk divider in mdio resumeMugunthan V N
During suspend resume cycle all the register data is lost, so MDIO clock divier value gets reset. This patch restores the clock divider value. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13drivers: net: davinci_mdio: moving mdio resume earlier than cpsw ethernet driverMugunthan V N
MDIO driver should resume before CPSW ethernet driver so that CPSW connect to the phy and start tx/rx ethernet packets, changing the suspend/resume apis with suspend_late/resume_early. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13tg3: Wait for boot code to finish after power onNithin Sujir
Some systems that don't need wake-on-lan may choose to power down the chip on system standby. Upon resume, the power on causes the boot code to startup and initialize the hardware. On one new platform, this is causing the device to go into a bad state due to a race between the driver and boot code, once every several hundred resumes. The same race exists on open since we come up from a power on. This patch adds a wait for boot code signature at the beginning of tg3_init_hw() which is common to both cases. If there has not been a power-off or the boot code has already completed, the signature will be present and poll_fw() returns immediately. Also return immediately if the device does not have firmware. Cc: stable@vger.kernel.org Signed-off-by: Nithin Nayak Sujir <nsujir@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13bonding: fix igmp_retrans type and two related racesNikolay Aleksandrov
First the type of igmp_retrans (which is the actual counter of igmp_resend parameter) is changed to u8 to be able to store values up to 255 (as per documentation). There are two races that were hidden there and which are easy to trigger after the previous fix, the first is between bond_resend_igmp_join_requests and bond_change_active_slave where igmp_retrans is set and can be altered by the periodic. The second race condition is between multiple running instances of the periodic (upon execution it can be scheduled again for immediate execution which can cause the counter to go < 0 which in the unsigned case leads to unnecessary igmp retransmissions). Since in bond_change_active_slave bond->lock is held for reading and curr_slave_lock for writing, we use curr_slave_lock for mutual exclusion. We can't drop them as there're cases where RTNL is not held when bond_change_active_slave is called. RCU is unlocked in bond_resend_igmp_join_requests before getting curr_slave_lock since we don't need it there and it's pointless to delay. The decrement is moved inside the "if" block because if we decrement unconditionally there's still a possibility for a race condition although it is much more difficult to hit (many changes have to happen in a very short period in order to trigger) which in the case of 3 parallel running instances of this function and igmp_retrans == 1 (with check bond->igmp_retrans-- > 1) is: f1 passes, doesn't re-schedule, but decrements - igmp_retrans = 0 f2 then passes, doesn't re-schedule, but decrements - igmp_retrans = 255 f3 does the unnecessary retransmissions. Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13bonding: reset master mac on first enslave failureNikolay Aleksandrov
If the bond device is supposed to get the first slave's MAC address and the first enslavement fails then we need to reset the master's MAC otherwise it will stay the same as the failed slave device. We do it after err_undo_flags since that is the first place where the MAC can be changed and we check if it should've been the first slave and if the bond's MAC was set to it because that err place is used by multiple locations prior to changing the master's MAC address. Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13net: ethernet: stmicro: stmmac: Fix compile error when STMMAC_XMIT_DEBUG usedDinh Nguyen
drivers/net/ethernet/stmicro/stmmac/stmmac_main.c: In function: stmmac_xmit drivers/net/ethernet/stmicro/stmmac/stmmac_main.c:1902:74: error: expected ) before __func__ Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Cc: Giuseppe Cavallaro <peppe.cavallaro@st.com> CC: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13be2net: Fix 32-bit DMA Mask handlingSomnath Kotur
Fix to set the coherent DMA mask only if dma_set_mask() succeeded, and to error out if either fails. Signed-off-by: Somnath Kotur <somnath.kotur@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13xen-netback: don't de-reference vif pointer after having called xenvif_put()Jan Beulich
When putting vif-s on the rx notify list, calling xenvif_put() must be deferred until after the removal from the list and the issuing of the notification, as both operations dereference the pointer. Changing this got me to notice that the "irq" variable was effectively unused (and was of too narrow type anyway). Signed-off-by: Jan Beulich <jbeulich@suse.com> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13macvlan: don't touch promisc without passthroughMichael S. Tsirkin
commit df8ef8f3aaa6692970a436204c4429210addb23a "macvlan: add FDB bridge ops and macvlan flags" added a way to control NOPROMISC macvlan flag through netlink. However, with a non passthrough device we never set promisc on open, even if NOPROMISC is off. As a result: If userspace clears NOPROMISC on open, then does not clear it on a netlink command, promisc counter is not decremented on stop and there will be no way to clear it once macvlan is detached. If userspace does not clear NOPROMISC on open, then sets NOPROMISC on a netlink command, promisc counter will be decremented from 0 and overflow to fffffffff with no way to clear promisc. To fix, simply ignore NOPROMISC flag in a netlink command for non-passthrough devices, same as we do at open/close. Since we touch this code anyway - check dev_set_promiscuity return code and pass it to users (though an error here is unlikely). Cc: "David S. Miller" <davem@davemloft.net> Reviewed-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13md/raid1,5,10: Disable WRITE SAME until a recovery strategy is in placeH. Peter Anvin
There are cases where the kernel will believe that the WRITE SAME command is supported by a block device which does not, in fact, support WRITE SAME. This currently happens for SATA drivers behind a SAS controller, but there are probably a hundred other ways that can happen, including drive firmware bugs. After receiving an error for WRITE SAME the block layer will retry the request as a plain write of zeroes, but mdraid will consider the failure as fatal and consider the drive failed. This has the effect that all the mirrors containing a specific set of data are each offlined in very rapid succession resulting in data loss. However, just bouncing the request back up to the block layer isn't ideal either, because the whole initial request-retry sequence should be inside the write bitmap fence, which probably means that md needs to do its own conversion of WRITE SAME to write zero. Until the failure scenario has been sorted out, disable WRITE SAME for raid1, raid5, and raid10. [neilb: added raid5] This patch is appropriate for any -stable since 3.7 when write_same support was added. Cc: stable@vger.kernel.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-06-13md/raid1,raid10: use freeze_array in place of raise_barrier in various places.NeilBrown
Various places in raid1 and raid10 are calling raise_barrier when they really should call freeze_array. The former is only intended to be called from "make_request". The later has extra checks for 'nr_queued' and makes a call to flush_pending_writes(), so it is safe to call it from within the management thread. Using raise_barrier will sometimes deadlock. Using freeze_array should not. As 'freeze_array' currently expects one request to be pending (in handle_read_error - the only previous caller), we need to pass it the number of pending requests (extra) to ignore. The deadlock was made particularly noticeable by commits 050b66152f87c7 (raid10) and 6b740b8d79252f13 (raid1) which appeared in 3.4, so the fix is appropriate for any -stable kernel since then. This patch probably won't apply directly to some early kernels and will need to be applied by hand. Cc: stable@vger.kernel.org Reported-by: Alexander Lyakas <alex.bolshoy@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-06-13md/raid1: consider WRITE as successful only if at least one non-Faulty and ↵Alex Lyakas
non-rebuilding drive completed it. Without that fix, the following scenario could happen: - RAID1 with drives A and B; drive B was freshly-added and is rebuilding - Drive A fails - WRITE request arrives to the array. It is failed by drive A, so r1_bio is marked as R1BIO_WriteError, but the rebuilding drive B succeeds in writing it, so the same r1_bio is marked as R1BIO_Uptodate. - r1_bio arrives to handle_write_finished, badblocks are disabled, md_error()->error() does nothing because we don't fail the last drive of raid1 - raid_end_bio_io() calls call_bio_endio() - As a result, in call_bio_endio(): if (!test_bit(R1BIO_Uptodate, &r1_bio->state)) clear_bit(BIO_UPTODATE, &bio->bi_flags); this code doesn't clear the BIO_UPTODATE flag, and the whole master WRITE succeeds, back to the upper layer. So we returned success to the upper layer, even though we had written the data onto the rebuilding drive only. But when we want to read the data back, we would not read from the rebuilding drive, so this data is lost. [neilb - applied identical change to raid10 as well] This bug can result in lost data, so it is suitable for any -stable kernel. Cc: stable@vger.kernel.org Signed-off-by: Alex Lyakas <alex@zadarastorage.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-06-13md: md_stop_writes() should always freeze recovery.NeilBrown
__md_stop_writes() will currently sometimes freeze recovery. So any caller must be ready for that to happen, and indeed they are. However if __md_stop_writes() doesn't freeze_recovery, then a recovery could start before mddev_suspend() is called, which could be awkward. This can particularly cause problems or dm-raid. So change __md_stop_writes() to always freeze recovery. This is safe and more predicatable. Reported-by: Brassow Jonathan <jbrassow@redhat.com> Tested-by: Brassow Jonathan <jbrassow@redhat.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking update from David Miller: 1) Fix dump iterator in nfnl_acct_dump() and ctnl_timeout_dump() to dump all objects properly, from Pablo Neira Ayuso. 2) xt_TCPMSS must use the default MSS of 536 when no MSS TCP option is present. Fix from Phil Oester. 3) qdisc_get_rtab() looks for an existing matching rate table and uses that instead of creating a new one. However, it's key matching is incomplete, it fails to check to make sure the ->data[] array is identical too. Fix from Eric Dumazet. 4) ip_vs_dest_entry isn't fully initialized before copying back to userspace, fix from Dan Carpenter. 5) Fix ubuf reference counting regression in vhost_net, from Jason Wang. 6) When sock_diag dumps a socket filter back to userspace, we have to translate it out of the kernel's internal representation first. From Nicolas Dichtel. 7) davinci_mdio holds a spinlock while calling pm_runtime, which sleeps. Fix from Sebastian Siewior. 8) Timeout check in sh_eth_check_reset is off by one, from Sergei Shtylyov. 9) If sctp socket init fails, we can NULL deref during cleanup. Fix from Daniel Borkmann. 10) netlink_mmap() does not propagate errors properly, from Patrick McHardy. 11) Disable powersave and use minstrel by default in ath9k. From Sujith Manoharan. 12) Fix a regression in that SOCK_ZEROCOPY is not set on tuntap sockets which prevents vhost from being able to use zerocopy. From Jason Wang. 13) Fix race between port lookup and TX path in team driver, from Jiri Pirko. 14) Missing length checks in bluetooth L2CAP packet parsing, from Johan Hedberg. 15) rtlwifi fails to connect to networking using any encryption method other than WPA2. Fix from Larry Finger. 16) Fix iwlegacy build due to incorrect CONFIG_* ifdeffing for power management stuff. From Yijing Wang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (35 commits) b43: stop format string leaking into error msgs ath9k: Use minstrel rate control by default Revert "ath9k_hw: Update rx gain initval to improve rx sensitivity" ath9k: Disable PowerSave by default net: wireless: iwlegacy: fix build error for il_pm_ops rtlwifi: Fix a false leak indication for PCI devices wl12xx/wl18xx: scan all 5ghz channels wl12xx: increase minimum singlerole firmware version required wl12xx: fix minimum required firmware version for wl127x multirole rtlwifi: rtl8192cu: Fix problem in connecting to WEP or WPA(1) networks mwifiex: debugfs: Fix out of bounds array access Bluetooth: Fix mgmt handling of power on failures Bluetooth: Fix missing length checks for L2CAP signalling PDUs Bluetooth: btmrvl: support Marvell Bluetooth device SD8897 Bluetooth: Fix checks for LE support on LE-only controllers team: fix checks in team_get_first_port_txable_rcu() team: move add to port list before port enablement team: check return value of team_get_port_by_index_rcu() for NULL tuntap: set SOCK_ZEROCOPY flag during open netlink: fix error propagation in netlink_mmap() ...
2013-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull input layer bugfix from Jiri Kosina: "Memory leak regression fix from Benjamin Tissoires" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: multitouch: prevent memleak with the allocated name
2013-06-12Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "Outside of bcache (which really isn't super big), these are all few-liners. There are a few important fixes in here: - Fix blk pm sleeping when holding the queue lock - A small collection of bcache fixes that have been done and tested since bcache was included in this merge window. - A fix for a raid5 regression introduced with the bio changes. - Two important fixes for mtip32xx, fixing an oops and potential data corruption (or hang) due to wrong bio iteration on stacked devices." * 'for-linus' of git://git.kernel.dk/linux-block: scatterlist: sg_set_buf() argument must be in linear mapping raid5: Initialize bi_vcnt pktcdvd: silence static checker warning block: remove refs to XD disks from documentation blkpm: avoid sleep when holding queue lock mtip32xx: Correctly handle bio->bi_idx != 0 conditions mtip32xx: Fix NULL pointer dereference during module unload bcache: Fix error handling in init code bcache: clarify free/available/unused space bcache: drop "select CLOSURES" bcache: Fix incompatible pointer type warning
2013-06-12Merge branch 'akpm' (updates from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton: "Bunch of fixes and one little addition to math64.h" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (27 commits) include/linux/math64.h: add div64_ul() mm: memcontrol: fix lockless reclaim hierarchy iterator frontswap: fix incorrect zeroing and allocation size for frontswap_map kernel/audit_tree.c:audit_add_tree_rule(): protect `rule' from kill_rules() mm: migration: add migrate_entry_wait_huge() ocfs2: add missing lockres put in dlm_mig_lockres_handler mm/page_alloc.c: fix watermark check in __zone_watermark_ok() drivers/misc/sgi-gru/grufile.c: fix info leak in gru_get_config_info() aio: fix io_destroy() regression by using call_rcu() rtc-at91rm9200: use shadow IMR on at91sam9x5 rtc-at91rm9200: add shadow interrupt mask rtc-at91rm9200: refactor interrupt-register handling rtc-at91rm9200: add configuration support rtc-at91rm9200: add match-table compile guard fs/ocfs2/namei.c: remove unecessary ERROR when removing non-empty directory swap: avoid read_swap_cache_async() race to deadlock while waiting on discard I/O completion drivers/rtc/rtc-twl.c: fix missing device_init_wakeup() when booted with device tree cciss: fix broken mutex usage in ioctl audit: wait_for_auditd() should use TASK_UNINTERRUPTIBLE drivers/rtc/rtc-cmos.c: fix accidentally enabling rtc channel ...
2013-06-12drivers/misc/sgi-gru/grufile.c: fix info leak in gru_get_config_info()Dan Carpenter
The "info.fill" array isn't initialized so it can leak uninitialized stack information to user space. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Robin Holt <holt@sgi.com> Acked-by: Dimitri Sivanich <sivanich@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12rtc-at91rm9200: use shadow IMR on at91sam9x5Johan Hovold
Add support for the at91sam9x5-family which must use the shadow interrupt mask due to a hardware issue (causing RTC_IMR to always be zero). Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Douglas Gilbert <dgilbert@interlog.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: Robert Nelson <Robert.Nelson@digikey.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12rtc-at91rm9200: add shadow interrupt maskJohan Hovold
Add shadow interrupt-mask register which can be used on SoCs where the actual hardware register is broken. Note that some care needs to be taken to make sure the shadow mask corresponds to the actual hardware state. The added overhead is not an issue for the non-broken SoCs due to the relatively infrequent interrupt-mask updates. We do, however, only use the shadow mask value as a fall-back when it actually needed as there is still a theoretical possibility that the mask is incorrect (see the code for details). Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Douglas Gilbert <dgilbert@interlog.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: Robert Nelson <Robert.Nelson@digikey.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12rtc-at91rm9200: refactor interrupt-register handlingJohan Hovold
Add accessors for the interrupt register. This will allow us to easily add a shadow interrupt-mask register to use on SoCs where the interrupt-mask register cannot be used. Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Douglas Gilbert <dgilbert@interlog.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: Robert Nelson <Robert.Nelson@digikey.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12rtc-at91rm9200: add configuration supportJohan Hovold
Add configuration support which can be used to implement SoC-specific workarounds for broken hardware. Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Douglas Gilbert <dgilbert@interlog.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: Robert Nelson <Robert.Nelson@digikey.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12rtc-at91rm9200: add match-table compile guardJohan Hovold
The members of Atmel's at91sam9x5 family (9x5) have a broken RTC interrupt mask register (AT91_RTC_IMR). It does not reflect enabled interrupts but instead always returns zero. The kernel's rtc-at91rm9200 driver handles the RTC for the 9x5 family. Currently when the date/time is set, an interrupt is generated and this driver neglects to handle the interrupt. The kernel complains about the un-handled interrupt and disables it henceforth. This not only breaks the RTC function, but since that interrupt is shared (Atmel's SYS interrupt) then other things break as well (e.g. the debug port no longer accepts characters). Tested on the at91sam9g25. Bug confirmed by Atmel. This patch (of 5): Add missing match-table compile guard. Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Douglas Gilbert <dgilbert@interlog.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: Robert Nelson <Robert.Nelson@digikey.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12drivers/rtc/rtc-twl.c: fix missing device_init_wakeup() when booted with ↵Tony Lindgren
device tree When booted in legacy mode device_init_wakeup() gets called by drivers/mfd/twl-core.c when the children are initialized. However, when booted using device tree, the children are created with of_platform_populate() instead add_children(). This means that the RTC driver will not have device_init_wakeup() set, and we need to call it from the driver probe like RTC drivers typically do. Without this we cannot test PM wake-up events on omaps for cases where there may not be any physical wake-up event. Signed-off-by: Tony Lindgren <tony@atomide.com> Reported-by: Kevin Hilman <khilman@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Jingoo Han <jg1.han@samsung.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12cciss: fix broken mutex usage in ioctlStephen M. Cameron
If a new logical drive is added and the CCISS_REGNEWD ioctl is invoked (as is normal with the Array Configuration Utility) the process will hang as below. It attempts to acquire the same mutex twice, once in do_ioctl() and once in cciss_unlocked_open(). The BKL was recursive, the mutex isn't. Linux version 3.10.0-rc2 (scameron@localhost.localdomain) (gcc version 4.4.7 20120313 (Red Hat 4.4.7-3) (GCC) ) #1 SMP Fri May 24 14:32:12 CDT 2013 [...] acu D 0000000000000001 0 3246 3191 0x00000080 Call Trace: schedule+0x29/0x70 schedule_preempt_disabled+0xe/0x10 __mutex_lock_slowpath+0x17b/0x220 mutex_lock+0x2b/0x50 cciss_unlocked_open+0x2f/0x110 [cciss] __blkdev_get+0xd3/0x470 blkdev_get+0x5c/0x1e0 register_disk+0x182/0x1a0 add_disk+0x17c/0x310 cciss_add_disk+0x13a/0x170 [cciss] cciss_update_drive_info+0x39b/0x480 [cciss] rebuild_lun_table+0x258/0x370 [cciss] cciss_ioctl+0x34f/0x470 [cciss] do_ioctl+0x49/0x70 [cciss] __blkdev_driver_ioctl+0x28/0x30 blkdev_ioctl+0x200/0x7b0 block_ioctl+0x3c/0x40 do_vfs_ioctl+0x89/0x350 SyS_ioctl+0xa1/0xb0 system_call_fastpath+0x16/0x1b This mutex usage was added into the ioctl path when the big kernel lock was removed. As it turns out, these paths are all thread safe anyway (or can easily be made so) and we don't want ioctl() to be single threaded in any case. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mike Miller <mike.miller@hp.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12drivers/rtc/rtc-cmos.c: fix accidentally enabling rtc channelDerek Basehore
During resume, we call hpet_rtc_timer_init after masking an irq bit in hpet. This will cause the call to hpet_disable_rtc_channel to be undone if RTC_AIE is the only bit not masked. Allowing the cmos interrupt handler to run before resuming caused some issues where the timer for the alarm was not removed. This would cause other, later timers to not be cleared, so utilities such as hwclock would time out when waiting for the update interrupt. [akpm@linux-foundation.org: coding-style tweak] Signed-off-by: Derek Basehore <dbasehore@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12drivers/rtc/rtc-tps6586x.c: device wakeup flags correctionDmitry Osipenko
Use device_init_wakeup() instead of device_set_wakeup_capable() and move it before rtc dev registering. This fixes alarmtimer not registered when tps6586x rtc is the only wakeup compatible rtc in the system. Signed-off-by: Dmitry Osipenko <digetx@gmail.com> Cc: Laxman Dewangan <ldewangan@nvidia.com> Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Just some GMA500 memory leaks and i915 regression fix due to a regression fix" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/i915: prefer VBT modes for SVDO-LVDS over EDID drm/i915: Enable hotplug interrupts after querying hw capabilities. drm/i915: Fix hotplug interrupt enabling for SDVOC drm/gma500/cdv: Fix cursor gem obj referencing on cdv drm/gma500/psb: Fix cursor gem obj referencing on psb drm/gma500/cdv: Unpin framebuffer on crtc disable drm/gma500/psb: Unpin framebuffer on crtc disable drm/gma500: Add fb gtt offset to fb base
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull ceph fixes from Sage Weil: "There is a pair of fixes for double-frees in the recent bundle for 3.10, a couple of fixes for long-standing bugs (sleep while atomic and an endianness fix), and a locking fix that can be triggered when osds are going down" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: rbd: fix cleanup in rbd_add() rbd: don't destroy ceph_opts in rbd_add() ceph: ceph_pagelist_append might sleep while atomic ceph: add cpu_to_le32() calls when encoding a reconnect capability libceph: must hold mutex for reset_changed_osds()
2013-06-12Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2013-06-12b43: stop format string leaking into error msgsKees Cook
The module parameter "fwpostfix" is userspace controllable, unfiltered, and is used to define the firmware filename. b43_do_request_fw() populates ctx->errors[] on error, containing the firmware filename. b43err() parses its arguments as a format string. For systems with b43 hardware, this could lead to a uid-0 to ring-0 escalation. CVE-2013-2852 Signed-off-by: Kees Cook <keescook@chromium.org> Cc: stable@vger.kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-06-12ath9k: Use minstrel rate control by defaultSujith Manoharan
The ath9k rate control algorithm has various architectural issues that make it a poor fit in scenarios like congested environments etc. An example: https://bugzilla.redhat.com/show_bug.cgi?id=927191 Change the default to minstrel which is more robust in such cases. The ath9k RC code is left in the driver for now, maybe it can be removed altogether later on. Cc: stable@vger.kernel.org Cc: Jouni Malinen <jouni@qca.qualcomm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-06-12Revert "ath9k_hw: Update rx gain initval to improve rx sensitivity"Felix Fietkau
This reverts commit 68d9e1fa24d9c7c2e527f49df8d18fb8cf0ec943 This change reduces rx sensitivity with no apparent extra benefit. It looks like it was meant for testing in a specific scenario, but it was never properly validated. Cc: rmanohar@qca.qualcomm.com Cc: stable@vger.kernel.org Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-06-12ath9k: Disable PowerSave by defaultSujith Manoharan
Almost all the DMA issues which have plagued ath9k (in station mode) for years are related to PS. Disabling PS usually "fixes" the user's connection stablility. Reports of DMA problems are still trickling in and are sitting in the kernel bugzilla. Until the PS code in ath9k is given a thorough review, disbale it by default. The slight increase in chip power consumption is a small price to pay for improved link stability. Cc: stable@vger.kernel.org Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-06-12net: wireless: iwlegacy: fix build error for il_pm_opsYijing Wang
Fix build error for il_pm_ops if CONFIG_PM is set but CONFIG_PM_SLEEP is not set. ERROR: "il_pm_ops" [drivers/net/wireless/iwlegacy/iwl4965.ko] undefined! ERROR: "il_pm_ops" [drivers/net/wireless/iwlegacy/iwl3945.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 Signed-off-by: Yijing Wang <wangyijing@huawei.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: netdev@vger.kernel.org Cc: linux-wireless@vger.kernel.org Cc: Jingoo Han <jg1.han@samsung.com> Acked-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-06-12rtlwifi: Fix a false leak indication for PCI devicesLarry Finger
This false leak indication is avoided with a no-leak annotation to kmemleak. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-06-12wl12xx/wl18xx: scan all 5ghz channelsEliad Peller
Due to a typo, the current code copies only sizeof(cmd->channels_2) bytes, which is smaller than the correct sizeof(cmd->channels_5) size, resulting in a partial scan (some channels are skipped). Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
