commit bf47b4fd8f9f81cd5ce40e1945c6334d088226d1 upstream.
clk_change_rate() is accessing parent's rate without checking
if the parent exists at all. In case of root clocks this will
cause NULL pointer dereference.
This patch follows what clk_calc_new_rates() does in such
situation.
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
commit b2e6ad7dfe26aac5bf136962d0b11d180b820d44 upstream.
Add support for the 15'' MacBook Pro Retina. The keyboard is
the same as recent models.
The patch needs to be synchronized with the bcm5974 patch for
the trackpad - as usual.
Patch originally written by clipcarl (forums.opensuse.org).
[rydberg@euromail.se: Amended mouse ignore lines]
Signed-off-by: Ryan Bourgeois <bluedragonx@gmail.com>
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit e76b8ee25e034ab601b525abb95cea14aa167ed3 upstream.
I couldn't find the vendor ID in any of the online databases, but this
mat has a Pump It Up logo on the top side of the controller compartment,
and a disclaimer stating that Andamiro will not be liable on the bottom.
Signed-off-by: Yuri Khan <yurivkhan@gmail.com>
commit cc71a7e899cc6b2ff41e1be48756782ed004d802 upstream.
Signed-off-by: Ilia Katsnelson <k0009000@gmail.com>
commit 3ffb62cb9ac2430c2504c6ff9727d0f2476ef0bd upstream.
The device should be handled by xpad driver instead of generic HID driver.
commit 3dde22a98e94eb18527f0ff0068fb2fb945e58d4 upstream.
Add support for the 15'' MacBook Pro Retina model (MacBookPro10,1).
commit a64d49c3dd504b685f9742a2f3dcb11fb8e4345f upstream.
It was recently reported that moving a bonding device between network
namespaces causes warnings from /proc. It turns out after the move we
were trying to add and to remove the /proc/net/bonding entries from the
wrong network namespace.
Move the bonding /proc registration code into the NETDEV_REGISTER and
NETDEV_UNREGISTER events where the proc registration and unregistration
will always happen at the right time.
commit 96ca7ffe748bf91f851e6aa4479aa11c8b1122ba upstream.
The bonding debugfs support has been broken in the presence of network
namespaces since it has been added. The debugfs support does not handle
multiple bonding devices with the same name in different network
namespaces.
I haven't had any bug reports, and I'm not interested in getting any.
Disable the debugfs support when network namespaces are enabled.
commit 8e83989106562326bfd6aaf92174fe138efd026b upstream.
It was observed that during multiple reboots nfs hangs. The status of
receive descriptors shows that all the descriptors were in control of
CPU, and none were assigned to DMA.
Also the DMA status register confirmed that the Rx buffer is
unavailable.
This patch adds the fix for the same by adding the memory barriers to
ascertain that the all instructions before enabling the Rx or Tx DMA are
completed which involves the proper setting of the ownership bit in DMA
descriptors.
Signed-off-by: Deepak Sikri <deepak.sikri@st.com>
commit 9634252617441991b01dacaf4040866feecaf36f upstream.
When rpmsg drivers are built into the kernel, they must not initialize
before the rpmsg bus does, otherwise they'd trigger a BUG() in
drivers/base/driver.c line 169 (driver_register()).
To fix that, and to stop depending on arbitrary linkage ordering of
those built-in rpmsg drivers, we make the rpmsg bus initialize at
subsys_initcall.
Signed-off-by: Federico Fuga <fuga@studiofuga.com>
[ohad: rewrite the commit log]
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
commit b48d96652626b315229b1b82c6270eead6a77a6d upstream.
When we remove a key, we put a key index which was supposed
to tell the fw that we are actually removing the key. But
instead the fw took that index as a valid index and messed
up the SRAM of the device.
This memory corruption on the device mangled the data of
the SCD. The impact on the user is that SCD queue 2 got
stuck after having removed keys.
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit c2ca7d92ed4bbd779516beb6eb226e19f7f7ab0f upstream.
This is iwlegacy version of:
commit 342bbf3fee2fa9a18147e74b2e3c4229a4564912
Author: Johannes Berg <johannes.berg@intel.com>
Date: Sun Mar 4 08:50:46 2012 -0800
iwlwifi: always monitor for stuck queues
If we only monitor while associated, the following
can happen:
- we're associated, and the queue stuck check
runs, setting the queue "touch" time to X
- we disassociate, stopping the monitoring,
which leaves the time set to X
- almost 2s later, we associate, and enqueue
a frame
- before the frame is transmitted, we monitor
for stuck queues, and find the time set to
X, although it is now later than X + 2000ms,
so we decide that the queue is stuck and
erroneously restart the device
commit d0efa8f23a644f7cb7d1f8e78dd9a223efa412a3 upstream.
SYNCH bit and IV bit of RXCW register are sticky. Before examining these bits,
RXCW should be read twice to filter out one-time false events and have correct
values for these bits. Incorrect values of these bits in link check logic can
cause weird link stability issues if auto-negotiation fails.
Reported-by: Dean Nelson <dnelson@redhat.com>
Signed-off-by: Tushar Dave <tushar.n.dave@intel.com>
Reviewed-by: Bruce Allan <bruce.w.allan@intel.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
commit efd821182cec8c92babef6e00a95066d3252fda4 upstream.
On rt2x00_dmastart() we increase index specified by Q_INDEX and on
rt2x00_dmadone() we increase index specified by Q_INDEX_DONE. So entries
between Q_INDEX_DONE and Q_INDEX are those we currently process in the
hardware. Entries between Q_INDEX and Q_INDEX_DONE are those we can
submit to the hardware.
According to that fix rt2x00usb_kick_queue(), as we need to submit RX
entries that are not processed by the hardware. It worked before only
for empty queue, otherwise was broken.
Note that for TX queues indexes ordering are ok. We need to kick entries
that have filled skb, but was not submitted to the hardware, i.e.
started from Q_INDEX_DONE and have ENTRY_DATA_PENDING bit set.
From practical standpoint this fixes RX queue stall, usually reproducible
in AP mode, like for example reported here:
https://bugzilla.redhat.com/show_bug.cgi?id=828824
Reported-and-tested-by: Franco Miceli <fmiceli@plan.ceibal.edu.uy>
Reported-and-tested-by: Tom Horsley <horsley1953@gmail.com>
commit 88ca518b0bb4161e5f20f8a1d9cc477cae294e54 upstream.
intel_ips driver spews the warning message
"ME failed to update for more than 1s, likely hung"
at each second endlessly on HP ProBook laptops with IronLake.
As this has never worked, better to blacklist the driver for now.
commit c4686c71a9183f76e3ef59098da5c098748672f6 upstream.
Commit d640113fe80e45ebd4a5b420b introduced a regression on SMP
systems where the processor core with ACPI id zero is disabled
(typically should be the case because of hyperthreading).
The regression got spread through stable kernels.
On 3.0.X it got introduced via 3.0.18.
Such platforms may be rare, but do exist.
Look out for a disabled processor with acpi_id 0 in dmesg:
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x10] disabled)
This problem has been observed on a:
HP Proliant BL280c G6 blade
This patch restricts the introduced workaround to platforms
with nr_cpu_ids <= 1.
Signed-off-by: Thomas Renninger <trenn@suse.de>
commit 46befd6b38d802dfc5998e7d7938854578b45d9d upstream.
Fixes a problem that can occur when a lone package object is
wrapped with an outer package object in order to conform to
the ACPI specification. Can affect these predefined names:
_ALR,_MLS,_PSS,_TRT,_TSS,_PRT,_HPX,_DLM,_CSD,_PSD,_TSD
https://bugzilla.kernel.org/show_bug.cgi?id=44171
This problem was introduced in 3.4-rc1 by commit
6a99b1c94d053b3420eaa4a4bc8b2883dd90a2f9
(ACPICA: Object repair code: Support to add Package wrappers)
Reported-by: Vlastimil Babka <caster@gentoo.org>
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
commit 2d4f4f3384d4ef4f7c571448e803a1ce721113d5 upstream.
This bug has been present ever since data-check was introduce
in 2.6.16. However it would only fire if a data-check were
done on a degraded array, which was only possible if the array
has 3 or more devices. This is certainly possible, but is quite
uncommon.
Since hot-replace was added in 3.3 it can happen more often as
the same condition can arise if not all possible replacements are
present.
The problem is that as soon as we submit the last read request, the
'r1_bio' structure could be freed at any time, so we really should
stop looking at it. If the last device is being read from we will
stop looking at it. However if the last device is not due to be read
from, we will still check the bio pointer in the r1_bio, but the
r1_bio might already be free.
So use the read_targets counter to make sure we stop looking for bios
to submit as soon as we have submitted them all.
This fix is suitable for any -stable kernel since 2.6.16.
Reported-by: Arnold Schulz <arnysch@gmx.net>
Signed-off-by: NeilBrown <neilb@suse.de>
commit 596fd46268634082314b3af1ded4612e1b7f3f03 upstream.
We don't need to open code the divide function, just use div_u64 that
already exists and do the same job. While this is a straightforward
clean up, there is more to that, the real motivation for this.
While building on a cross compiling environment in armel, using gcc
4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5), I was getting the following build
error:
ERROR: "__aeabi_uldivmod" [drivers/mtd/nand/nandsim.ko] undefined!
After investigating with objdump and hand built assembly version
generated with the compiler, I narrowed __aeabi_uldivmod as being
generated from the divide function. When nandsim.c is built with
-fno-inline-functions-called-once, that happens when
CONFIG_DEBUG_SECTION_MISMATCH is enabled, the do_div optimization in
arch/arm/include/asm/div64.h doesn't work as expected with the open
coded divide function: even if the do_div we are using doesn't have a
constant divisor, the compiler still includes the else parts of the
optimized do_div macro, and translates the divisions there to use
__aeabi_uldivmod, instead of only calling __do_div_asm -> __do_div64 and
optimizing/removing everything else out.
So to reproduce, gcc 4.6 plus CONFIG_DEBUG_SECTION_MISMATCH=y and
CONFIG_MTD_NAND_NANDSIM=m should do it, building on armel.
After this change, the compiler does the intended thing even with
-fno-inline-functions-called-once, and optimizes out as expected the
constant handling in the optimized do_div on arm. As this also avoids a
build issue, I'm marking for Stable, as I think is applicable for this
case.
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit 82163edcdfa4eb3d74516cc8e9f38dd3d039b67d upstream.
There is a missing "up_write()" here. Semaphore should be released
before returning error value.
Signed-off-by: Santosh Nayak <santoshprasadnayak@gmail.com>
commit 41002f8dd5938d5ad1d008ce5bfdbfe47fa7b4e8 upstream.
We were accidentally losing one bit in the configuration register on
device initialization. It was reported to freeze one specific system
right away. Properly preserve all bits we don't explicitly want to
change in order to prevent that.
Reported-by: Stevie Trujillo <stevie.trujillo@gmail.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
commit a7deca6fa79d5c65575532e780f3c93f6bf8ddad upstream.
Commit 7a6f6c29d264cdd2fe0eb3d923217eed5f0ad134 (cx231xx: use
URB_NO_TRANSFER_DMA_MAP) was intended to avoid mapping the DMA buffer
for URB twice. This works for the URBs allocated with usb_alloc_urb(),
as those are allocated from cohernent DMA pools, but the flag was also
added for the VBI and audio URBs, which have a manually allocated area.
This leaves the random trash in the structure after allocation as the
DMA address, corrupting memory and preventing VBI and audio from
working. Letting the USB core map the buffers solves the problem.
Signed-off-by: David Dillow <dave@thedillows.org>
Cc: Sri Deevi <srinivasa.deevi@conexant.com>
commit b59f6d1febd6cbe9fae4589bf72da0ed32bc69e0 upstream.
Fixes
WARNING: at irq/handle.c:146 handle_irq_event_percpu+0x19c/0x1b8()
irq 25 handler mxc_rtc_interrupt+0x0/0xac enabled interrupts
Modules linked in:
(unwind_backtrace+0x0/0xf0) from (warn_slowpath_common+0x4c/0x64)
(warn_slowpath_common+0x4c/0x64) from (warn_slowpath_fmt+0x30/0x40)
(warn_slowpath_fmt+0x30/0x40) from (handle_irq_event_percpu+0x19c/0x1b8)
(handle_irq_event_percpu+0x19c/0x1b8) from (handle_irq_event+0x28/0x38)
(handle_irq_event+0x28/0x38) from (handle_level_irq+0x80/0xc4)
(handle_level_irq+0x80/0xc4) from (generic_handle_irq+0x24/0x38)
(generic_handle_irq+0x24/0x38) from (handle_IRQ+0x30/0x84)
(handle_IRQ+0x30/0x84) from (avic_handle_irq+0x2c/0x4c)
(avic_handle_irq+0x2c/0x4c) from (__irq_svc+0x40/0x60)
Exception stack(0xc050bf60 to 0xc050bfa8)
bf60: 00000001 00000000 003c4208 c0018e20 c050a000 c050a000 c054a4c8 c050a000
bf80: c05157a8 4117b363 80503bb4 00000000 01000000 c050bfa8 c0018e2c c000e808
bfa0: 60000013 ffffffff
(__irq_svc+0x40/0x60) from (default_idle+0x1c/0x30)
(default_idle+0x1c/0x30) from (cpu_idle+0x68/0xa8)
(cpu_idle+0x68/0xa8) from (start_kernel+0x22c/0x26c)
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Sascha Hauer <kernel@pengutronix.de>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
commit 3cfd16a551dc0c188160e1765168a04baf2d3198 upstream.
This driver's IRQ registration is failing because the kernel now forces
IRQs to be ONESHOT if no IRQ handler is passed.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
commit 2a643893e50fde71d7ba84b5592ec61b467b9ab6 upstream.
`config' is freed and is then used in the rtc_device_unregister() call,
causing a kernel panic.
Signed-off-by: Devendra Naga <devendra.aaru@gmail.com>
Reviewed-by: Viresh Kumar <viresh.linux@gmail.com>
commit 279bf2e57c30c9a4482b2b6ede11b31c41e35e78 upstream.
Commit 50ac23be ("staging:iio:adc:ad7606 add local define for chan_spec
structures.") accidentally removed the scale info_mask flag. This patch
adds it back again.
Acked-by: Jonathan Cameron <jic23@kernel.org>
[herton: Backported to 3.4: info_mask was not used yet with another flag]
Signed-off-by: Herton R. Krzesinski <herton@canonical.com>
commit 6c0544e255dd6582a9899572e120fb55d9f672a4 upstream.
In chunk_aligned_read() we are adding data_offset before calling
is_badblock. But is_badblock also adds data_offset, so that is bad.
So move the addition of data_offset to after the call to
is_badblock.
This bug was introduced by commit 31c176ecdf3563140e639
md/raid5: avoid reading from known bad blocks.
which first appeared in 3.0. So that patch is suitable for any
-stable kernel from 3.0.y onwards. However it will need minor
revision for most of those (as the comment didn't appear until
recently).
Signed-off-by: majianpeng <majianpeng@gmail.com>
[bwh: Backported to 3.2: ignored missing comment]
commit 58bf8062d0b293b8e1028e5b0342082002886bd4 upstream.
After banging my head against this for the past few months, I still
don't see how this could possible race under the premise that once an
irq bit is masked in PM_IMR and reset in PM_IIR it won't show up again
until we unmask it in PM_IMR.
Still, we have reports of this being seen in the wild. Now Bspec has
this little bit of lovely language in the PMIIR register:
Public SNB Docs, Vol3Part2, 2.5.14 "PMIIR":
"For each bit, the IIR can store a second pending interrupt if two or
more of the same interrupt conditions occur before the first condition
is cleared. Upon clearing the interrupt, the IIR bit will momentarily
go low, then return high to indicate there is another interrupt
pending."
Now if we presume that PMIMR only prevent new interrupts from being
queued, we could easily end up masking an interrupt and clearing it,
but the 2nd pending interrupt setting the bit in PMIIR right away
again. Which leads, the next time the irq handler runs, to hitting the
WARN.
Also, no bad side effects of this have ever been reported. And we've
tracked down our issues with the gpu turbo getting stuck to bogus
interrupt generation limits in th RPLIMIT register.
So let's just rip out this WARN as bogus and call it a day. The only
shallow thing here is that this 2-deep irq queue in the hw makes you
wonder how racy the windows irq handler is ...
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42907
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit fc6826d1dcd65f3d1e9a5377678882e4e08f02be upstream.
This function, along with the registers and deferred work hander, are
all shared with SandyBridge, IvyBridge and their variants. So remove the
duplicate code into a single function.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Ben Widawsky <ben@bwidawsk.net>
[bwh: Backported to 3.2: adjust context; drop changes for Valley View]
commit a141e6a0097118bb35024485f1faffc0d9042f5c upstream.
Driver doesn't report its supported cipher suites through cfg80211
interface. It still uses wext interface and probably will not work
through nl80211, but will at least correctly advertise supported
features.
Bug was reported by Omar Siam.
https://bugzilla.kernel.org/show_bug.cgi?id=43049
Signed-off-by: Stanislav Yakovlev <stas.yakovlev@gmail.com>
Cc: Josh Boyer <jwboyer@redhat.com>
commit b92946e2919134ebe2a4083e4302236295ea2a73 upstream.
There're several reasons that the vectors need to be validated:
- Return error when caller provides vectors whose num is greater than UIO_MAXIOV.
- Linearize part of skb when userspace provides vectors grater than MAX_SKB_FRAGS.
- Return error when userspace provides vectors whose total length may exceed
- MAX_SKB_FRAGS * PAGE_SIZE.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit 0fde0a8cfd0ede7f310d6a681c8e5a7cb3e32406 upstream.
Fix:
BUG: sleeping function called from invalid context at kernel/workqueue.c:2547
in_atomic(): 1, irqs_disabled(): 0, pid: 629, name: wpa_supplicant
2 locks held by wpa_supplicant/629:
#0: (rtnl_mutex){+.+.+.}, at: [<c08b2b84>] rtnl_lock+0x14/0x20
#1: (&trigger->leddev_list_lock){.+.?..}, at: [<c0867f41>] led_trigger_event+0x21/0x80
Pid: 629, comm: wpa_supplicant Not tainted 3.3.0-0.rc3.git5.1.fc17.i686
Call Trace:
[<c046a9f6>] __might_sleep+0x126/0x1d0
[<c0457d6c>] wait_on_work+0x2c/0x1d0
[<c045a09a>] __cancel_work_timer+0x6a/0x120
[<c045a160>] cancel_delayed_work_sync+0x10/0x20
[<f7dd3c22>] rtl8187_led_brightness_set+0x82/0xf0 [rtl8187]
[<c0867f7c>] led_trigger_event+0x5c/0x80
[<f7ff5e6d>] ieee80211_led_radio+0x1d/0x40 [mac80211]
[<f7ff3583>] ieee80211_stop_device+0x13/0x230 [mac80211]
Removing _sync is ok, because if led_on work is currently running
it will be finished before led_off work start to perform, since
they are always queued on the same mac80211 local->workqueue.
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=795176
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Acked-by: Hin-Tak Leung <htl10@users.sourceforge.net>
commit 6bb51c70cabaadddc54a6454844eceba91a56083 upstream.
Commit 3a2923e83c introduced a bug when a corrupt descriptor
is encountered - although the following descriptor is discarded
and returned to the queue for reuse the associated frame is
also returned for processing. This leads to a panic:
BUG: unable to handle kernel NULL pointer dereference at 000000000000003a
IP: [<ffffffffa02599a5>] ath_rx_tasklet+0x165/0x1b00 [ath9k]
Call Trace:
<IRQ>
[<ffffffff812d7fa0>] ? map_single+0x60/0x60
[<ffffffffa028f044>] ? ath9k_ioread32+0x34/0x90 [ath9k]
[<ffffffffa0292eec>] athk9k_tasklet+0xdc/0x160 [ath9k]
[<ffffffff8105e133>] tasklet_action+0x63/0xd0
[<ffffffff8105dbc0>] __do_softirq+0xc0/0x1e0
[<ffffffff8101a873>] ? native_sched_clock+0x13/0x80
[<ffffffff815f9d5c>] call_softirq+0x1c/0x30
[<ffffffff810151f5>] do_softirq+0x75/0xb0
[<ffffffff8105df95>] irq_exit+0xb5/0xc0
[<ffffffff815fa5b3>] do_IRQ+0x63/0xe0
[<ffffffff815f0cea>] common_interrupt+0x6a/0x6a
<EOI>
[<ffffffff8131840a>] ? intel_idle+0xea/0x150
[<ffffffff813183eb>] ? intel_idle+0xcb/0x150
[<ffffffff814a1db9>] cpuidle_enter+0x19/0x20
[<ffffffff814a23d9>] cpuidle_idle_call+0xa9/0x240
[<ffffffff8101c4bf>] cpu_idle+0xaf/0x120
[<ffffffff815cda8e>] rest_init+0x72/0x74
[<ffffffff81cf4c1a>] start_kernel+0x3b7/0x3c4
[<ffffffff81cf4662>] ? repair_env_string+0x5e/0x5e
[<ffffffff81cf4346>] x86_64_start_reservations+0x131/0x135
[<ffffffff81cf444a>] x86_64_start_kernel+0x100/0x10f
Making sure bf is cleared to NULL in this case restores the
old behaviour.
Signed-off-by: Tom Hughes <tom@compton.nu>
commit b7abee6ef888117f92db370620ebf116a38e3f4d upstream.
5906 devices also need the short DMA fragment workaround. This patch
makes the necessary change.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
Tested-by: Christian Kujau <lists@nerdbynature.de>
commit fab363b5ff502d1b39ddcfec04271f5858d9f26e upstream.
There isn't locking setting STRIPE_DELAYED and STRIPE_PREREAD_ACTIVE bits, but
the two bits have relationship. A delayed stripe can be moved to hold list only
when preread active stripe count is below IO_THRESHOLD. If a stripe has both
the bits set, such stripe will be in delayed list and preread count not 0,
which will make such stripe never leave delayed list.
Signed-off-by: Shaohua Li <shli@fusionio.com>
commit af05ef01e9cde84620c6855a8d8ab9c8a1db9009 upstream.
[Backport to linux-stable by Antonio Ospite <ospite@studenti.unina.it>]
This fixes a regression introduced by commit f7059ea and should be
backported to all supported stable kernels which have this commit.
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
Tested-by: Antonio Ospite <ospite@studenti.unina.it>
commit 858faa57dd9e2b91f3f870fbb1185982e42f5a2b upstream
add_virtual_intf() needs to return an ERR_PTR(), instead of NULL,
on errors, otherwise cfg80211 will crash.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
commit 882b7b7d11d65e8eccce738f1ce97cdfdb998f9f upstream.
When debugging is disabled, the event log functions aren't
functional in the way that the debugfs file expects. This
leads to the debugfs access crashing. Since the event log
functions aren't functional then, remove the debugfs file
when CONFIG_IWLWIFI_DEBUG is not set.
Reported-by: Lekensteyn <lekensteyn@gmail.com>
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
[bwh: Backported to 3.2: adjust filename, context]
commit 6de0298ec9c1edaf330b71b57346241ece8f3346 upstream.
This adds support for the iPad to the ipheth driver.
(product id = 0x129a)
Signed-off-by: Davide Gerhard <rainbow@irh.it>
commit dbf0e4c7257f8d684ec1a3c919853464293de66e upstream.
Quite a few ASUS computers experience a nasty problem, related to the
EHCI controllers, when going into system suspend. It was observed
that the problem didn't occur if the controllers were not put into the
D3 power state before starting the suspend, and commit
151b61284776be2d6f02d48c23c3625678960b97 (USB: EHCI: fix crash during
suspend on ASUS computers) was created to do this.
It turned out this approach messed up other computers that didn't have
the problem -- it prevented USB wakeup from working. Consequently
commit c2fb8a3fa25513de8fedb38509b1f15a5bbee47b (USB: add
NO_D3_DURING_SLEEP flag and revert 151b61284776be2) was merged; it
reverted the earlier commit and added a whitelist of known good board
names.
Now we know the actual cause of the problem. Thanks to AceLan Kao for
tracking it down.
According to him, an engineer at ASUS explained that some of their
BIOSes contain a bug that was added in an attempt to work around a
problem in early versions of Windows. When the computer goes into S3
suspend, the BIOS tries to verify that the EHCI controllers were first
quiesced by the OS. Nothing's wrong with this, but the BIOS does it
by checking that the PCI COMMAND registers contain 0 without checking
the controllers' power state. If the register isn't 0, the BIOS
assumes the controller needs to be quiesced and tries to do so. This
involves making various MMIO accesses to the controller, which don't
work very well if the controller is already in D3. The end result is
a system hang or memory corruption.
Since the value in the PCI COMMAND register doesn't matter once the
controller has been suspended, and since the value will be restored
anyway when the controller is resumed, we can work around the BIOS bug
simply by setting the register to 0 during system suspend. This patch
(as1590) does so and also reverts the second commit mentioned above,
which is now unnecessary.
In theory we could do this for every PCI device. However to avoid
introducing new problems, the patch restricts itself to EHCI host
controllers.
Finally the affected systems can suspend with USB wakeup working
properly.
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=37632
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=42728
Based-on-patch-by: AceLan Kao <acelan.kao@canonical.com>
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Dâniel Fraga <fragabr@gmail.com>
Tested-by: Javier Marcet <jmarcet@gmail.com>
Tested-by: Andrey Rahmatullin <wrar@wrar.name>
Tested-by: Oleksij Rempel <bug-track@fisher-privat.net>
Tested-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
commit 0d9f78a92ef5e97d9fe51d9215ebe22f6f0d289d upstream.
The Microsoft LifeChat 3000 USB headset was causing a very reproducible
hang whenever it was plugged in. At first, I thought the host
controller was producing bad transfer events, because the log was filled
with errors like:
xhci_hcd 0000:00:14.0: ERROR Transfer event TRB DMA ptr not part of current TD
However, it turned out to be an xHCI driver bug in the ring expansion
patches. The bug is triggered When there are two ring segments, and a
TD that ends just before a link TRB, like so:
______________ _____________
| | ---> | setup TRB B |
______________ | _____________
| | | | data TRB B |
| setup TRB A | <-- deq | | data TRB B |
| data TRB A | | | | <-- enq, deq''
| status TRB A | | | |
| link TRB |--------------- | link TRB |
_____________ <--- deq' _____________
TD A (the first control transfer) stalls on the data phase. That halts
the ring. The xHCI driver moves the hardware dequeue pointer to the
first TRB after the stalled transfer, which happens to be the link TRB.
Once the Set TR dequeue pointer command completes, the function
update_ring_for_set_deq_completion runs. That function is supposed to
update the xHCI driver's dequeue pointer to match the internal hardware
dequeue pointer. On the first call this would work fine, and the
software dequeue pointer would move to deq'.
However, if the transfer immediately after that stalled (TD B in this
case), another Set TR Dequeue command would be issued. That would move
the hardware dequeue pointer to deq''. Once that command completed,
update_ring_for_set_deq_completion would run again.
The original code would unconditionally increment the software dequeue
pointer, which moved the pointer off the ring segment into la-la-land.
The while loop would happy increment the dequeue pointer (possibly
wrapping it) until it matched the hardware pointer value.
The while loop would also access all the memory in between the first
ring segment and the second ring segment to determine if it was a link
TRB. This could cause general protection faults, although it was
unlikely because the ring segments came from a DMA pool, and would often
have consecutive memory addresses.
If nothing in that space looked like a link TRB, the deq_seg pointer for
the ring would remain on the first segment. Thus, the deq_seg and the
software dequeue pointer would get out of sync.
When the next transfer event came in after the stalled transfer, the
xHCI driver code would attempt to convert the software dequeue pointer
into a DMA address in order to compare the DMA address for the completed
transfer. Since the deq_seg and the dequeue pointer were out of sync,
xhci_trb_virt_to_dma would return NULL.
The transfer event would get ignored, the transfer would eventually
timeout, and we would mistakenly convert the finished transfer to no-op
TRBs. Some kernel driver (maybe xHCI?) would then get stuck in an
infinite loop in interrupt context, and the whole machine would hang.
This patch should be backported to kernels as old as 3.4, that contain
the commit b008df60c6369ba0290fa7daa177375407a12e07 "xHCI: count free
TRBs on transfer ring"
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Andiry Xu <andiry.xu@amd.com>
commit 8bea2bd37df08aaa599aa361a9f8b836ba98e554 upstream.
The host controller port status register supports CAS (Cold Attach
Status) bit. This bit could be set when USB3.0 device is connected
when system is in Sx state. When the system wakes to S0 this port
status with CAS bit is reported and this port can't be used by any
device.
When CAS bit is set the port should be reset by warm reset. This
was not supported by xhci driver.
The issue was found when pendrive was connected to suspended
platform. The link state of "Compliance Mode" was reported together
with CAS bit. This link state was also not supported by xhci and
core/hub.c.
The CAS bit is defined only for xhci root hub port and it is
not supported on regular hubs. The link status is used to force
warm reset on port. Make the USB core issue a warm reset when port
is in ether the 'inactive' or 'compliance mode'. Change the xHCI driver
to report 'compliance mode' when the CAS is set. This force warm reset
on the root hub port.
This patch should be backported to stable kernels as old as 3.2, that
contain the commit 10d674a82e553cb8a1f41027bb3c3e309b3f6804 "USB: When
hot reset for USB3 fails, try warm reset."
Signed-off-by: Stanislaw Ledwon <staszek.ledwon@linux.intel.com>
Acked-by: Andiry Xu <andiry.xu@amd.com>
commit aacef9c561a693341566a6850c451ce3df68cb9a upstream.
Signed-off-by: Gaosen Zhang <gaosen.zhang@mediatek.com>
commit 8e16e33c168a6efd0c9f7fa9dd4c1e1db9a74553 upstream.
Switches into a composite device by ejecting the initial
driver CD. The four interfaces are: QCDM, AT, QMI/wwan
and mass storage. Let this driver manage the two serial
interfaces:
T: Bus=02 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 28 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=19d2 ProdID=1402 Rev= 0.00
S: Manufacturer=ZTE,Incorporated
S: Product=ZTE WCDMA Technologies MSM
S: SerialNumber=xxxxx
C:* #Ifs= 4 Cfg#= 1 Atr=c0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
E: Ad=83(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit b086b6b10d9f182cd8d2f0dcfd7fd11edba93fc9 upstream.
Clear the WDM_READ flag on empty reads to avoid running
forever in an infinite tight loop, causing lockups:
Jul 1 21:58:11 nemi kernel: [ 3658.898647] qmi_wwan 2-1:1.2: Unexpected error -71
Jul 1 21:58:36 nemi kernel: [ 3684.072021] BUG: soft lockup - CPU#0 stuck for 23s! [qmi.pl:12235]
Jul 1 21:58:36 nemi kernel: [ 3684.072212] CPU 0
Jul 1 21:58:36 nemi kernel: [ 3684.072355]
Jul 1 21:58:36 nemi kernel: [ 3684.072367] Pid: 12235, comm: qmi.pl Tainted: P O 3.5.0-rc2+ #13 LENOVO 2776LEG/2776LEG
Jul 1 21:58:36 nemi kernel: [ 3684.072383] RIP: 0010:[<ffffffffa0635008>] [<ffffffffa0635008>] spin_unlock_irq+0x8/0xc [cdc_wdm]
Jul 1 21:58:36 nemi kernel: [ 3684.072388] RSP: 0018:ffff88022dca1e70 EFLAGS: 00000282
Jul 1 21:58:36 nemi kernel: [ 3684.072393] RAX: ffff88022fc3f650 RBX: ffffffff811c56f7 RCX: 00000001000ce8c1
Jul 1 21:58:36 nemi kernel: [ 3684.072398] RDX: 0000000000000010 RSI: 000000000267d810 RDI: ffff88022fc3f650
Jul 1 21:58:36 nemi kernel: [ 3684.072403] RBP: ffff88022dca1eb0 R08: ffffffffa063578e R09: 0000000000000000
Jul 1 21:58:36 nemi kernel: [ 3684.072407] R10: 0000000000000008 R11: 0000000000000246 R12: 0000000000000002
Jul 1 21:58:36 nemi kernel: [ 3684.072412] R13: 0000000000000246 R14: ffffffff00000002 R15: ffff8802281d8c88
Jul 1 21:58:36 nemi kernel: [ 3684.072418] FS: 00007f666a260700(0000) GS:ffff88023bc00000(0000) knlGS:0000000000000000
Jul 1 21:58:36 nemi kernel: [ 3684.072423] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jul 1 21:58:36 nemi kernel: [ 3684.072428] CR2: 000000000270d9d8 CR3: 000000022e865000 CR4: 00000000000007f0
Jul 1 21:58:36 nemi kernel: [ 3684.072433] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
Jul 1 21:58:36 nemi kernel: [ 3684.072438] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
Jul 1 21:58:36 nemi kernel: [ 3684.072444] Process qmi.pl (pid: 12235, threadinfo ffff88022dca0000, task ffff88022ff76380)
Jul 1 21:58:36 nemi kernel: [ 3684.072448] Stack:
Jul 1 21:58:36 nemi kernel: [ 3684.072458] ffffffffa063592e 0000000100020000 ffff88022fc3f650 ffff88022fc3f6a8
Jul 1 21:58:36 nemi kernel: [ 3684.072466] 0000000000000200 0000000100000000 000000000267d810 0000000000000000
Jul 1 21:58:36 nemi kernel: [ 3684.072475] 0000000000000000 ffff880212cfb6d0 0000000000000200 ffff880212cfb6c0
Jul 1 21:58:36 nemi kernel: [ 3684.072479] Call Trace:
Jul 1 21:58:36 nemi kernel: [ 3684.072489] [<ffffffffa063592e>] ? wdm_read+0x1a0/0x263 [cdc_wdm]
Jul 1 21:58:36 nemi kernel: [ 3684.072500] [<ffffffff8110adb7>] ? vfs_read+0xa1/0xfb
Jul 1 21:58:36 nemi kernel: [ 3684.072509] [<ffffffff81040589>] ? alarm_setitimer+0x35/0x64
Jul 1 21:58:36 nemi kernel: [ 3684.072517] [<ffffffff8110aec7>] ? sys_read+0x45/0x6e
Jul 1 21:58:36 nemi kernel: [ 3684.072525] [<ffffffff813725f9>] ? system_call_fastpath+0x16/0x1b
Jul 1 21:58:36 nemi kernel: [ 3684.072557] Code: <66> 66 90 c3 83 ff ed 89 f8 74 16 7f 06 83 ff a1 75 0a c3 83 ff f4
The WDM_READ flag is normally cleared by wdm_int_callback
before resubmitting the read urb, and set by wdm_in_callback
when this urb returns with data or an error. But a crashing
device may cause both a read error and cancelling all urbs.
Make sure that the flag is cleared by wdm_read if the buffer
is empty.
We don't clear the flag on errors, as there may be pending
data in the buffer which should be processed. The flag will
instead be cleared on the next wdm_read call.
Acked-by: Oliver Neukum <oneukum@suse.de>
commit b7d28e32c93801d60c1a7a817f774a02b7bdde43 upstream.
Do not set low_latency flag at open as tty_flip_buffer_push must not be
called in IRQ context with low_latency set.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit dc332fdf9f373a87b1e2f423b5b004b2a3c37e1a upstream.
This is an old suspend/resume lockup fix:
commit 2780cc4660e1
Author: Len Brown <len.brown@intel.com>
Date: Thu Dec 23 13:43:30 2004 -0500
[ACPI] Fix suspend/resume lockup issue
by leaving Bus Master Arbitration enabled.
The ACPI spec mandates it be disabled only for C3.
http://bugzilla.kernel.org/show_bug.cgi?id=3599
Signed-off-by: David Shaohua Li <shaohua.li@intel.com>
The bug snuck back in in commit 2feec47d4c5f (ACPICA: ACPI 5: Support
for new FADT SleepStatus, SleepControl registers, 2012-02-14),
presumably by copy/pasting a copy of the code without that fix for the
legacy case.
On affected machines, after that commit, the machine locks up hard on
resume from suspend. The same fix as seven years ago still works.
Addresses <https://bugzilla.kernel.org/show_bug.cgi?id=43641>.
Reported-bisected-and-tested-by: Octavio Alvarez <alvarezp@alvarezp.com>
Reported-by: Adrian Knoth <adi@drcomp.erfurt.thur.de>
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
commit 6ef1b512f4e6f936d89aa20be3d97a7ec7c290ac upstream.
fill_result_tf() grabs the taskfile flags from the originating qc which
sas_ata_qc_fill_rtf() promptly overwrites. The presence of an
ata_taskfile in the sata_device makes it tempting to just copy the full
contents in sas_ata_qc_fill_rtf(). However, libata really only wants
the fis contents and expects the other portions of the taskfile to not
be touched by ->qc_fill_rtf. To that end store a fis buffer in the
sata_device and use ata_tf_from_fis() like every other ->qc_fill_rtf()
implementation.
Reported-by: Praveen Murali <pmurali@logicube.com>
Tested-by: Praveen Murali <pmurali@logicube.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit dbe9a2edd17d843d80faf2b99f20a691c1853418 upstream.
The comparison between the system sleep state being entered
and the lowest system sleep state the given device may wake up
from in acpi_pm_device_sleep_state() is reversed, because the
specification (ACPI 5.0) says that for wakeup to work:
"The sleeping state being entered must be less than or equal to the
power state declared in element 1 of the _PRW object."
In other words, the state returned by _PRW is the deepest
(lowest-power) system sleep state the device is capable of waking up
the system from.
Moreover, acpi_pm_device_sleep_state() also should check if the
wakeup capability is supported through ACPI, because in principle it
may be done via native PCIe PME, for example, in which case _SxW
should not be evaluated.
commit 3ac36d15557d1bedfb1151d9911b9587b2d40759 upstream.
The previous implementation introduced a randomness in the splitting
of the different touches reported by the device. This version is more
robust as we don't rely on hi->input->absbit, but on our own structure.
This also prepares hid-multitouch to better support Win8 devices.
[Jiri Kosina <jkosina@suse.cz>: fix build]
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr>
Acked-by: Henrik Rydberg <rydberg@euromail.se>
