path: root/drivers
2014-07-17ACPI / battery: Retry to get battery information if failed during probingLan Tianyu
commit 75646e758a0ecbed5024454507d5be5b9ea9dcbf upstream. Some machines (eg. Lenovo Z480) ECs are not stable during boot up and causes battery driver fails to be loaded due to failure of getting battery information from EC sometimes. After several retries, the operation will work. This patch is to retry to get battery information 5 times if the first try fails. [ backport to 3.14.5: removed second parameter in acpi_battery_update(), introduced by the commit 9e50bc14a7f58b5d8a55973b2d69355852ae2dae (ACPI / battery: Accelerate battery resume callback)] [naszar <naszar@ya.ru>: backport to 3.14.5] Link: https://bugzilla.kernel.org/show_bug.cgi?id=75581 Reported-and-tested-by: naszar <naszar@ya.ru> Cc: All applicable <stable@vger.kernel.org> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17drivers/rtc/rtc-puv3.c: use dev_dbg() instead of dev_debug() for typo issueChen Gang
commit c863810cefc7ffd782e5648a21bfb36a32c8b081 upstream. It is only a typo issue, the related commit: "1fbc4c4 drivers/rtc/rtc-puv3.c: use dev_dbg() instead of pr_debug()" The related error (unicore32 with allmodconfig): CC [M] drivers/rtc/rtc-puv3.o drivers/rtc/rtc-puv3.c: In function 'puv3_rtc_setpie': drivers/rtc/rtc-puv3.c:74: error: implicit declaration of function 'dev_debug' Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Acked-by: Xuetao Guan <gxt@mprc.pku.edu.cn> Signed-off-by: Xuetao Guan <gxt@mprc.pku.edu.cn> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17drivers/rtc/rtc-puv3.c: remove "&dev->" for typo issueChen Gang
commit 73fa540618d8b1f8c2266934f23bd84bb9e28d9e upstream. It is only a typo issue, the related commit: "1fbc4c4 drivers/rtc/rtc-puv3.c: use dev_dbg() instead of pr_debug()" The related error (for unicore32 with allmodconfig): CC [M] drivers/rtc/rtc-puv3.o drivers/rtc/rtc-puv3.c: In function 'puv3_rtc_setalarm': drivers/rtc/rtc-puv3.c:143: error: 'struct device' has no member named 'dev' Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Acked-by: Xuetao Guan <gxt@mprc.pku.edu.cn> Signed-off-by: Xuetao Guan <gxt@mprc.pku.edu.cn> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17DMA, CMA: fix possible memory leakJoonsoo Kim
commit fe8eea4f4a3f299ef83ed090d5354698ebe4fda8 upstream. We should free memory for bitmap when we find zone mismatch, otherwise this memory will leak. Additionally, I copy code comment from PPC KVM's CMA code to inform why we need to check zone mis-match. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Reviewed-by: Michal Nazarewicz <mina86@mina86.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Gleb Natapov <gleb@kernel.org> Cc: Alexander Graf <agraf@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17drm/i915: Don't clobber the GTT when it's within stolen memoryVille Syrjälä
commit f1e1c2129b79cfdaf07bca37c5a10569fe021abe upstream. On most gen2-4 platforms the GTT can be (or maybe always is?) inside the stolen memory region. If that's the case, reduce the size of the stolen memory appropriately to make make sure we don't clobber the GTT. v2: Deal with gen4 36 bit physical address Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=80151 Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17drm/radeon: stop poisoning the GART TLBChristian König
commit 0986c1a55ca64b44ee126a2f719a6e9f28cbe0ed upstream. When we set the valid bit on invalid GART entries they are loaded into the TLB when an adjacent entry is loaded. This poisons the TLB with invalid entries which are sometimes not correctly removed on TLB flush. For stable inclusion the patch probably needs to be modified a bit. Signed-off-by: Christian König <christian.koenig@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17drm/radeon: fix typo in golden register setup on evergreenAlex Deucher
commit 6abafb78f9881b4891baf74ab4e9f090ae45230e upstream. Fixes hangs on driver load on some cards. bug: https://bugs.freedesktop.org/show_bug.cgi?id=76998 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17drm/radeon: fix typo in ci_stop_dpm()Alex Deucher
commit ed96377132e564d797c48a5490fd46bed01c4273 upstream. Need to use the RREG32_SMC() accessor since the register is an smc indirect index. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17drm/radeon/dpm: Reenabling SS on CaymanAlexandre Demers
commit 41959341ac7e33dd360c7a881d13566f9eca37b2 upstream. It reverts commit c745fe611ca42295c9d91d8e305d27983e9132ef now that Cayman is stable since VDDCI fix. Spread spectrum was not the culprit. This depends on b0880e87c1fd038b84498944f52e52c3e86ebe59 (drm/radeon/dpm: fix vddci setup typo on cayman). Signed-off-by: Alexandre Demers <alexandre.f.demers@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17PCI: Fix unaligned access in AF transaction pending testAlex Williamson
commit d066c946a866268c14a120b33e7226e899981998 upstream. pci_wait_for_pending() uses word access, so we shouldn't be passing an offset that is only byte aligned. Use the control register offset instead, shifting the mask to match. Fixes: d0b4cc4e3270 ("PCI: Wrong register used to check pending traffic") Fixes: 157e876ffe0b ("PCI: Add pci_wait_for_pending() (refactor pci_wait_for_pending_transaction()) Reported-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17intel_pstate: Set CPU number before accessing MSRsVincent Minet
commit 179e8471673ce0249cd4ecda796008f7757e5bad upstream. Ensure that cpu->cpu is set before writing MSR_IA32_PERF_CTL during CPU initialization. Otherwise only cpu0 has its P-state set and all other cores are left with their values unchanged. In most cases, this is not too serious because the P-states will be set correctly when the timer function is run. But when the default governor is set to performance, the per-CPU current_pstate stays the same forever and no attempts are made to write the MSRs again. Signed-off-by: Vincent Minet <vincent@vincent-minet.net> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17intel_pstate: don't touch turbo bit if turbo disabled or unavailable.Dirk Brandewie
commit dd5fbf70f96dbfd7ee432096a1f979b2b3267856 upstream. If turbo is disabled in the BIOS bit 38 should be set in MSR_IA32_MISC_ENABLE register per section 14.3.2.1 of the SDM Vol 3 document 325384-050US Feb 2014. If this bit is set do *not* attempt to disable trubo via the MSR_IA32_PERF_CTL register. On some systems trying to disable turbo via MSR_IA32_PERF_CTL will cause subsequent writes to MSR_IA32_PERF_CTL not take affect, in fact reading MSR_IA32_PERF_CTL will not show the IDA/Turbo DISENGAGE bit(32) as set. A write of bit 32 to zero returns to normal operation. Also deal with the case where the processor does not support turbo and the BIOS does not report the fact in MSR_IA32_MISC_ENABLE but does report the max and turbo P states as the same value. Link: https://bugzilla.kernel.org/show_bug.cgi?id=64251 Signed-off-by: Dirk Brandewie <dirk.j.brandewie@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17intel_pstate: Fix setting VIDDirk Brandewie
commit c16ed06024a6e699c332831dd50d8276744e3de8 upstream. Commit 21855ff5 (intel_pstate: Set turbo VID for BayTrail) introduced setting the turbo VID which is required to prevent a machine check on some Baytrail SKUs under heavy graphics based workloads. The docmumentation update that brought the requirement to light also changed the bit mask used for enumerating P state and VID values from 0x7f to 0x3f. This change returns the mask value to 0x7f. Tested with the Intel NUC DN2820FYK, BIOS version FYBYT10H.86A.0034.2014.0513.1413 with v3.16-rc1 and v3.14.8 kernel versions. Fixes: 21855ff5 (intel_pstate: Set turbo VID for BayTrail) Link: https://bugzilla.kernel.org/show_bug.cgi?id=77951 Reported-and-tested-by: Rune Reterson <rune@megahurts.dk> Reported-and-tested-by: Eric Eickmeyer <erich@ericheickmeyer.com> Signed-off-by: Dirk Brandewie <dirk.j.brandewie@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17dm: allocate a special workqueue for deferred device removalMikulas Patocka
commit acfe0ad74d2e1bfc81d1d7bf5e15b043985d3650 upstream. The commit 2c140a246dc ("dm: allow remove to be deferred") introduced a deferred removal feature for the device mapper. When this feature is used (by passing a flag DM_DEFERRED_REMOVE to DM_DEV_REMOVE_CMD ioctl) and the user tries to remove a device that is currently in use, the device will be removed automatically in the future when the last user closes it. Device mapper used the system workqueue to perform deferred removals. However, some targets (dm-raid1, dm-mpath, dm-stripe) flush work items scheduled for the system workqueue from their destructor. If the destructor itself is called from the system workqueue during deferred removal, it introduces a possible deadlock - the workqueue tries to flush itself. Fix this possible deadlock by introducing a new workqueue for deferred removals. We allocate just one workqueue for all dm targets. The ability of dm targets to process IOs isn't dependent on deferred removal of unused targets, so a deadlock due to shared workqueue isn't possible. Also, cleanup local_init() to eliminate potential for returning success on failure. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17dm io: fix a race condition in the wake up code for sync_ioJoe Thornber
commit 10f1d5d111e8aed46a0f1179faf9a3cf422f689e upstream. There's a race condition between the atomic_dec_and_test(&io->count) in dec_count() and the waking of the sync_io() thread. If the thread is spuriously woken immediately after the decrement it may exit, making the on stack io struct invalid, yet the dec_count could still be using it. Fix this race by using a completion in sync_io() and dec_count(). Reported-by: Minfei Huang <huangminfei@ucloud.cn> Signed-off-by: Joe Thornber <thornber@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Acked-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17Drivers: hv: vmbus: Fix a bug in the channel callback dispatch codeK. Y. Srinivasan
commit affb1aff300ddee54df307812b38f166e8a865ef upstream. Starting with Win8, we have implemented several optimizations to improve the scalability and performance of the VMBUS transport between the Host and the Guest. Some of the non-performance critical services cannot leverage these optimization since they only read and process one message at a time. Make adjustments to the callback dispatch code to account for the way non-performance critical drivers handle reading of the channel. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17clk: qcom: HDMI source sel is 3 not 2Stephen Boyd
commit c556bcddc78096caeb46dbe3ad0314dd951f1665 upstream. The HDMI PLL input to the tv mux is supposed to be 3, not 2. Fix the code so that we can properly select the HDMI PLL. Fixes: 6d00b56fe "clk: qcom: Add support for MSM8960's multimedia clock controller (MMCC)" Reported-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17clk: s2mps11: Fix double free corruption during driver unbindKrzysztof Kozlowski
commit 2a96dfa49c83a2a7cbdb11382976aaa6b2636764 upstream. After unbinding the driver memory was corrupted by double free of clk_lookup structure. This lead to OOPS when re-binding the driver again. The driver allocated memory for 'clk_lookup' with devm_kzalloc. During driver removal this memory was freed twice: once by clkdev_drop() and second by devm code. Kernel panic log: [ 30.839284] Unable to handle kernel paging request at virtual address 5f343173 [ 30.846476] pgd = dee14000 [ 30.849165] [5f343173] *pgd=00000000 [ 30.852703] Internal error: Oops: 805 [#1] PREEMPT SMP ARM [ 30.858166] Modules linked in: [ 30.861208] CPU: 0 PID: 1 Comm: bash Not tainted 3.16.0-rc2-00239-g94bdf617b07e-dirty #40 [ 30.869364] task: df478000 ti: df480000 task.ti: df480000 [ 30.874752] PC is at clkdev_add+0x2c/0x38 [ 30.878738] LR is at clkdev_add+0x18/0x38 [ 30.882732] pc : [<c0350908>] lr : [<c03508f4>] psr: 60000013 [ 30.882732] sp : df481e78 ip : 00000001 fp : c0700ed8 [ 30.894187] r10: 0000000c r9 : 00000000 r8 : c07b0e3c [ 30.899396] r7 : 00000002 r6 : df45f9d0 r5 : df421390 r4 : c0700d6c [ 30.905906] r3 : 5f343173 r2 : c0700d84 r1 : 60000013 r0 : c0700d6c [ 30.912417] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 30.919534] Control: 10c53c7d Table: 5ee1406a DAC: 00000015 [ 30.925262] Process bash (pid: 1, stack limit = 0xdf480240) [ 30.930817] Stack: (0xdf481e78 to 0xdf482000) [ 30.935159] 1e60: 00001000 df6de610 [ 30.943321] 1e80: df7f4558 c0355650 c05ec6ec c0700eb0 df6de600 df7f4510 dec9d69c 00000014 [ 30.951480] 1ea0: 00167b48 df6de610 c0700e30 c0713518 00000000 c0700e30 dec9d69c 00000006 [ 30.959639] 1ec0: 00167b48 c02c1b7c c02c1b64 df6de610 c07aff48 c02c0420 c06fb150 c047cc20 [ 30.967798] 1ee0: df6de610 df6de610 c0700e30 df6de644 c06fb150 0000000c dec9d690 c02bef90 [ 30.975957] 1f00: dec9c6c0 dece4c00 df481f80 dece4c00 0000000c c02be73c 0000000c c016ca8c [ 30.984116] 1f20: c016ca48 00000000 00000000 c016c1f4 00000000 00000000 b6f18000 df481f80 [ 30.992276] 1f40: df7f66c0 0000000c df480000 df480000 b6f18000 c011094c df47839c 60000013 [ 31.000435] 1f60: 00000000 00000000 df7f66c0 df7f66c0 0000000c df480000 b6f18000 c0110dd4 [ 31.008594] 1f80: 00000000 00000000 0000000c b6ec05d8 0000000c b6f18000 00000004 c000f2a8 [ 31.016753] 1fa0: 00001000 c000f0e0 b6ec05d8 0000000c 00000001 b6f18000 0000000c 00000000 [ 31.024912] 1fc0: b6ec05d8 0000000c b6f18000 00000004 0000000c 00000001 00000000 00167b48 [ 31.033071] 1fe0: 00000000 bed83a80 b6e004f0 b6e5122c 60000010 00000001 ffffffff ffffffff [ 31.041248] [<c0350908>] (clkdev_add) from [<c0355650>] (s2mps11_clk_probe+0x2b4/0x3b4) [ 31.049223] [<c0355650>] (s2mps11_clk_probe) from [<c02c1b7c>] (platform_drv_probe+0x18/0x48) [ 31.057728] [<c02c1b7c>] (platform_drv_probe) from [<c02c0420>] (driver_probe_device+0x13c/0x384) [ 31.066579] [<c02c0420>] (driver_probe_device) from [<c02bef90>] (bind_store+0x88/0xd8) [ 31.074564] [<c02bef90>] (bind_store) from [<c02be73c>] (drv_attr_store+0x20/0x2c) [ 31.082118] [<c02be73c>] (drv_attr_store) from [<c016ca8c>] (sysfs_kf_write+0x44/0x48) [ 31.090016] [<c016ca8c>] (sysfs_kf_write) from [<c016c1f4>] (kernfs_fop_write+0xc0/0x17c) [ 31.098176] [<c016c1f4>] (kernfs_fop_write) from [<c011094c>] (vfs_write+0xa0/0x1c4) [ 31.105899] [<c011094c>] (vfs_write) from [<c0110dd4>] (SyS_write+0x40/0x8c) [ 31.112931] [<c0110dd4>] (SyS_write) from [<c000f0e0>] (ret_fast_syscall+0x0/0x3c) [ 31.120481] Code: e2842018 e584501c e1a00004 e885000c (e5835000) [ 31.126596] ---[ end trace efad45bfa3a61b05 ]--- [ 31.131181] Kernel panic - not syncing: Fatal exception [ 31.136368] CPU1: stopping [ 31.139054] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 3.16.0-rc2-00239-g94bdf617b07e-dirty #40 [ 31.148697] [<c0016480>] (unwind_backtrace) from [<c0012950>] (show_stack+0x10/0x14) [ 31.156419] [<c0012950>] (show_stack) from [<c0480db8>] (dump_stack+0x80/0xcc) [ 31.163622] [<c0480db8>] (dump_stack) from [<c001499c>] (handle_IPI+0x130/0x15c) [ 31.170998] [<c001499c>] (handle_IPI) from [<c000862c>] (gic_handle_irq+0x60/0x68) [ 31.178549] [<c000862c>] (gic_handle_irq) from [<c0013480>] (__irq_svc+0x40/0x70) [ 31.186009] Exception stack(0xdf4bdf88 to 0xdf4bdfd0) [ 31.191046] df80: ffffffed 00000000 00000000 00000000 df4bc000 c06d042c [ 31.199207] dfa0: 00000000 ffffffed c06d03c0 00000000 c070c288 00000000 00000000 df4bdfd0 [ 31.207363] dfc0: c0010324 c0010328 60000013 ffffffff [ 31.212402] [<c0013480>] (__irq_svc) from [<c0010328>] (arch_cpu_idle+0x28/0x30) [ 31.219783] [<c0010328>] (arch_cpu_idle) from [<c005f150>] (cpu_startup_entry+0x2c4/0x3f0) [ 31.228027] [<c005f150>] (cpu_startup_entry) from [<400086c4>] (0x400086c4) [ 31.234968] ---[ end Kernel panic - not syncing: Fatal exception Fixes: 7cc560dea415 ("clk: s2mps11: Add support for s2mps11") Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Yadwinder Singh Brar <yadi.brar@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17clk: spear3xx: Use proper control register offsetThomas Gleixner
commit 15ebb05248d025534773c9ef64915bd888f04e4b upstream. The control register is at offset 0x10, not 0x0. This is wreckaged since commit 5df33a62c (SPEAr: Switch to common clock framework). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17phy: core: Fix error path in phy_create()Roger Quadros
commit e73b49f1c4e75c44d62585cc3e5b9c7894b61c32 upstream. Prevent resources from being freed twice in case device_add() call fails within phy_create(). Also use ida_simple_remove() instead of ida_remove() as we had used ida_simple_get() to allocate the ida. Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17crypto: caam - fix memleak in caam_jr moduleCristian Stoica
commit 0378c9a855bfa395f595fbfb049707093e270f69 upstream. This patch fixes a memory leak that appears when caam_jr module is unloaded. Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17cpufreq: Makefile: fix compilation for davinci platformPrabhakar Lad
commit 5a90af67c2126fe1d04ebccc1f8177e6ca70d3a9 upstream. Since commtit 8a7b1227e303 (cpufreq: davinci: move cpufreq driver to drivers/cpufreq) this added dependancy only for CONFIG_ARCH_DAVINCI_DA850 where as davinci_cpufreq_init() call is used by all davinci platform. This patch fixes following build error: arch/arm/mach-davinci/built-in.o: In function `davinci_init_late': :(.init.text+0x928): undefined reference to `davinci_cpufreq_init' make: *** [vmlinux] Error 1 Fixes: 8a7b1227e303 (cpufreq: davinci: move cpufreq driver to drivers/cpufreq) Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17ACPI / EC: Fix race condition in ec_transaction_completed()Lv Zheng
commit c0d653412fc8450370167a3268b78fc772ff9c87 upstream. There is a race condition in ec_transaction_completed(). When ec_transaction_completed() is called in the GPE handler, it could return true because of (ec->curr == NULL). Then the wake_up() invocation could complete the next command unexpectedly since there is no lock between the 2 invocations. With the previous cleanup, the IBF=0 waiter race need not be handled any more. It's now safe to return a flag from advance_condition() to indicate the requirement of wakeup, the flag is returned from a locked context. The ec_transaction_completed() is now only invoked by the ec_poll() where the ec->curr is ensured to be different from NULL. After cleaning up, the EVT_SCI=1 check should be moved out of the wakeup condition so that an EVT_SCI raised with (ec->curr == NULL) can trigger a QR_SC command. Link: https://bugzilla.kernel.org/show_bug.cgi?id=70891 Link: https://bugzilla.kernel.org/show_bug.cgi?id=63931 Link: https://bugzilla.kernel.org/show_bug.cgi?id=59911 Reported-and-tested-by: Gareth Williams <gareth@garethwilliams.me.uk> Reported-and-tested-by: Hans de Goede <jwrdegoede@fedoraproject.org> Reported-by: Barton Xu <tank.xuhan@gmail.com> Tested-by: Steffen Weber <steffen.weber@gmail.com> Tested-by: Arthur Chen <axchen@nvidia.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17ACPI / EC: Remove duplicated ec_wait_ibf0() waiterLv Zheng
commit 9b80f0f73ae1583c22325ede341c74195847618c upstream. After we've added the first command byte write into advance_transaction(), the IBF=0 waiter is duplicated with the command completion waiter implemented in the ec_poll() because: If IBF=1 blocked the first command byte write invoked in the task context ec_poll(), it would be kicked off upon IBF=0 interrupt or timed out and retried again in the task context. Remove this seperate and duplicate IBF=0 waiter. By doing so we can reduce the overall number of times to access the EC_SC(R) status register. Link: https://bugzilla.kernel.org/show_bug.cgi?id=70891 Link: https://bugzilla.kernel.org/show_bug.cgi?id=63931 Link: https://bugzilla.kernel.org/show_bug.cgi?id=59911 Reported-and-tested-by: Gareth Williams <gareth@garethwilliams.me.uk> Reported-and-tested-by: Hans de Goede <jwrdegoede@fedoraproject.org> Reported-by: Barton Xu <tank.xuhan@gmail.com> Tested-by: Steffen Weber <steffen.weber@gmail.com> Tested-by: Arthur Chen <axchen@nvidia.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17ACPI / EC: Add asynchronous command byte write supportLv Zheng
commit f92fca0060fc4dc9227342d0072d75df98c1e5a5 upstream. Move the first command byte write into advance_transaction() so that all EC register accesses that can affect the command processing state machine can happen in this asynchronous state machine advancement function. The advance_transaction() function then can be a complete implementation of an asyncrhonous transaction for a single command so that: 1. The first command byte can be written in the interrupt context; 2. The command completion waiter can also be used to wait the first command byte's timeout; 3. In BURST mode, the follow-up command bytes can be written in the interrupt context directly, so that it doesn't need to return to the task context. Returning to the task context reduces the throughput of the BURST mode and in the worst cases where the system workload is very high, this leads to the hardware driven automatic BURST mode exit. In order not to increase memory consumption, convert 'done' into 'flags' to contain multiple indications: 1. ACPI_EC_COMMAND_COMPLETE: converting from original 'done' condition, indicating the completion of the command transaction. 2. ACPI_EC_COMMAND_POLL: indicating the availability of writing the first command byte. A new command can utilize this flag to compete for the right of accessing the underlying hardware. There is a follow-up bug fix that has utilized this new flag. The 2 flags are important because it also reflects a key concept of IO programs' design used in the system softwares. Normally an IO program running in the kernel should first be implemented in the asynchronous way. And the 2 flags are the most common way to implement its synchronous operations on top of the asynchronous operations: 1. POLL: This flag can be used to block until the asynchronous operations can happen. 2. COMPLETE: This flag can be used to block until the asynchronous operations have completed. By constructing code cleanly in this way, many difficult problems can be solved smoothly. Link: https://bugzilla.kernel.org/show_bug.cgi?id=70891 Link: https://bugzilla.kernel.org/show_bug.cgi?id=63931 Link: https://bugzilla.kernel.org/show_bug.cgi?id=59911 Reported-and-tested-by: Gareth Williams <gareth@garethwilliams.me.uk> Reported-and-tested-by: Hans de Goede <jwrdegoede@fedoraproject.org> Reported-by: Barton Xu <tank.xuhan@gmail.com> Tested-by: Steffen Weber <steffen.weber@gmail.com> Tested-by: Arthur Chen <axchen@nvidia.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17ACPI / EC: Avoid race condition related to advance_transaction()Lv Zheng
commit 66b42b78bc1e816f92b662e8888c89195e4199e1 upstream. The advance_transaction() will be invoked from the IRQ context GPE handler and the task context ec_poll(). The handling of this function is locked so that the EC state machine are ensured to be advanced sequentially. But there is a problem. Before invoking advance_transaction(), EC_SC(R) is read. Then for advance_transaction(), there could be race condition around the lock from both contexts. The first one reading the register could fail this race and when it passes the stale register value to the state machine advancement code, the hardware condition is totally different from when the register is read. And the hardware accesses determined from the wrong hardware status can break the EC state machine. And there could be cases that the functionalities of the platform firmware are seriously affected. For example: 1. When 2 EC_DATA(W) writes compete the IBF=0, the 2nd EC_DATA(W) write may be invalid due to IBF=1 after the 1st EC_DATA(W) write. Then the hardware will either refuse to respond a next EC_SC(W) write of the next command or discard the current WR_EC command when it receives a EC_SC(W) write of the next command. 2. When 1 EC_SC(W) write and 1 EC_DATA(W) write compete the IBF=0, the EC_DATA(W) write may be invalid due to IBF=1 after the EC_SC(W) write. The next EC_DATA(R) could never be responded by the hardware. This is the root cause of the reported issue. Fix this issue by moving the EC_SC(R) access into the lock so that we can ensure that the state machine is advanced consistently. Link: https://bugzilla.kernel.org/show_bug.cgi?id=70891 Link: https://bugzilla.kernel.org/show_bug.cgi?id=63931 Link: https://bugzilla.kernel.org/show_bug.cgi?id=59911 Reported-and-tested-by: Gareth Williams <gareth@garethwilliams.me.uk> Reported-and-tested-by: Hans de Goede <jwrdegoede@fedoraproject.org> Reported-by: Barton Xu <tank.xuhan@gmail.com> Tested-by: Steffen Weber <steffen.weber@gmail.com> Tested-by: Arthur Chen <axchen@nvidia.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17ACPI / resources: only reject zero length resources based at address zeroAndy Whitcroft
commit 867f9d463b82462793ea4610e748be0b04b37fc7 upstream. The recently merged change (in v3.14-rc6) to ACPI resource detection (below) causes all zero length ACPI resources to be elided from the table: commit b355cee88e3b1a193f0e9a81db810f6f83ad728b Author: Zhang Rui <rui.zhang@intel.com> Date: Thu Feb 27 11:37:15 2014 +0800 ACPI / resources: ignore invalid ACPI device resources This change has caused a regression in (at least) serial port detection for a number of machines (see LP#1313981 [1]). These seem to represent their IO regions (presumably incorrectly) as a zero length region. Reverting the above commit restores these serial devices. Only elide zero length resources which lie at address 0. Fixes: b355cee88e3b (ACPI / resources: ignore invalid ACPI device resources) Signed-off-by: Andy Whitcroft <apw@canonical.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17Revert "ACPI / AC: Remove AC's proc directory."Lan Tianyu
commit e63f6e28dda6de3de2392ddca321e211fd860925 upstream. Revert commit ab0fd674d6ce (ACPI / AC: Remove AC's proc directory.), because some old tools (e.g. kpowersave from kde 3.5.10) are still using /proc/acpi/ac_adapter. Fixes: ab0fd674d6ce (ACPI / AC: Remove AC's proc directory.) Reported-and-tested-by: Sorin Manolache <sorinm@gmail.com> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17hwmon: (adm1021) Fix cache problem when writing temperature limitsAxel Lin
commit c024044d4da2c9c3b32933b4235df1e409293b84 upstream. The module test script for the adm1021 driver exposes a cache problem when writing temperature limits. temp_min and temp_max are expected to be stored in milli-degrees C but are stored in degrees C. Reported-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17hwmon: (adm1029) Ensure the fan_div cache is updated in set_fan_divAxel Lin
commit 1035a9e3e9c76b64a860a774f5b867d28d34acc2 upstream. Writing to fanX_div does not clear the cache. As a result, reading from fanX_div may return the old value for up to two seconds after writing a new value. This patch ensures the fan_div cache is updated in set_fan_div(). Reported-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17hwmon: (adm1031) Fix writes to limit registersGuenter Roeck
commit 145e74a4e5022225adb84f4e5d4fff7938475c35 upstream. Upper limit for write operations to temperature limit registers was clamped to a fractional value. However, limit registers do not support fractional values. As a result, upper limits of 127.5 degrees C or higher resulted in a rounded limit of 128 degrees C. Since limit registers are signed, this was stored as -128 degrees C. Clamp limits to (-55, +127) degrees C to solve the problem. Value on writes to auto_temp[12]_min and auto_temp[12]_max were not clamped at all, but masked. As a result, out-of-range writes resulted in a more or less arbitrary limit. Clamp those attributes to (0, 127) degrees C for more predictable results. Cc: Axel Lin <axel.lin@ingics.com> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17hwmon: (emc2103) Clamp limits instead of bailing outGuenter Roeck
commit f6c2dd20108c35e30e2c1f3c6142d189451a626b upstream. It is customary to clamp limits instead of bailing out with an error if a configured limit is out of the range supported by the driver. This simplifies limit configuration, since the user will not typically know chip and/or driver specific limits. Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17hwmon: (amc6821) Fix permissions for temp2_inputAxel Lin
commit df86754b746e9a0ff6f863f690b1c01d408e3cdc upstream. temp2_input should not be writable, fix it. Reported-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17thermal: hwmon: Make the check for critical temp valid consistentAaron Lu
commit e8db5d6736a712a3e2280c0e31f4b301d85172d8 upstream. On 05/21/2014 04:22 PM, Aaron Lu wrote: > On 05/21/2014 01:57 PM, Kui Zhang wrote: >> Hello, >> >> I get following error when rmmod thermal. >> >> rmmod thermal >> Killed While dealing with this problem, I found another problem that also results in a kernel crash on thermal module removal: From: Aaron Lu <aaron.lu@intel.com> Date: Wed, 21 May 2014 16:05:38 +0800 Subject: thermal: hwmon: Make the check for critical temp valid consistent We used the tz->ops->get_crit_temp && !tz->ops->get_crit_temp(tz, temp) to decide if we need to create the temp_crit attribute file but we just check if tz->ops->get_crit_temp exists to decide if we need to remove that attribute file. Some ACPI thermal zone doesn't have a valid critical trip point and that would result in removing a non-existent device file on thermal module unload. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17i8k: Fix non-SMP operationGuenter Roeck
commit 6d827fbcc370ca259a2905309f64161ab7b10596 upstream. Commit f36fdb9f0266 (i8k: Force SMM to run on CPU 0) adds support for multi-core CPUs to the driver. Unfortunately, that causes it to fail loading if compiled without SMP support, at least on 32 bit kernels. Kernel log shows "i8k: unable to get SMM Dell signature", and function i8k_smm is found to return -EINVAL. Testing revealed that the culprit is the missing return value check of set_cpus_allowed_ptr. Fixes: f36fdb9f0266 (i8k: Force SMM to run on CPU 0) Reported-by: Jim Bos <jim876@xs4all.nl> Tested-by: Jim Bos <jim876@xs4all.nl> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Cc: Andreas Mohr <andi@lisas.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17iio: ti_am335x_adc: Fix: Use same step id at FIFOs both endsJan Kardell
commit baa3c65298c089a9014b4e523a14ec2885cca1bc upstream. Since AI lines could be selected at will (linux-3.11) the sending and receiving ends of the FIFO does not agree about what step is used for a line. It only works if the last lines are used, like 5,6,7, and fails if ie 2,4,6 is selected in DT. Signed-off-by: Jan Kardell <jan.kardell@telliq.com> Tested-by: Zubair Lutfullah <zubair.lutfullah@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17USB: serial: ftdi_sio: Add Infineon TriboardMichal Sojka
commit d8279a40e50ad55539780aa617a32a53d7f0953e upstream. This adds support for Infineon TriBoard TC1798 [1]. Only interface 1 is used as serial line (see [2], Figure 8-6). [1] http://www.infineon.com/cms/de/product/microcontroller/development-tools-software-and-kits/tricore-tm-development-tools-software-and-kits/starterkits-and-evaluation-boards/starter-kit-tc1798/channel.html?channel=db3a304333b8a7ca0133cfa3d73e4268 [2] http://www.infineon.com/dgdl/TriBoardManual-TC1798-V10.pdf?folderId=db3a304412b407950112b409ae7c0343&fileId=db3a304333b8a7ca0133cfae99fe426a Signed-off-by: Michal Sojka <sojkam1@fel.cvut.cz> Cc: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17USB: ftdi_sio: Add extra PID.Bert Vermeulen
commit 5a7fbe7e9ea0b1b9d7ffdba64db1faa3a259164c upstream. This patch adds PID 0x0003 to the VID 0x128d (Testo). At least the Testo 435-4 uses this, likely other gear as well. Signed-off-by: Bert Vermeulen <bert@biot.com> Cc: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17USB: cp210x: add support for Corsair usb dongleAndras Kovacs
commit b9326057a3d8447f5d2e74a7b521ccf21add2ec0 upstream. Corsair USB Dongles are shipped with Corsair AXi series PSUs. These are cp210x serial usb devices, so make driver detect these. I have a program, that can get information from these PSUs. Tested with 2 different dongles shipped with Corsair AX860i and AX1200i units. Signed-off-by: Andras Kovacs <andras@sth.sze.hu> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17usb: option: Add ID for Telewell TW-LTE 4G v2Bernd Wachter
commit 3d28bd840b2d3981cd28caf5fe1df38f1344dd60 upstream. Add ID of the Telewell 4G v2 hardware to option driver to get legacy serial interface working Signed-off-by: Bernd Wachter <bernd.wachter@jolla.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09sym53c8xx_2: Set DID_REQUEUE return code when aborting squeueMikulas Patocka
commit fd1232b214af43a973443aec6a2808f16ee5bf70 upstream. This patch fixes I/O errors with the sym53c8xx_2 driver when the disk returns QUEUE FULL status. When the controller encounters an error (including QUEUE FULL or BUSY status), it aborts all not yet submitted requests in the function sym_dequeue_from_squeue. This function aborts them with DID_SOFT_ERROR. If the disk has full tag queue, the request that caused the overflow is aborted with QUEUE FULL status (and the scsi midlayer properly retries it until it is accepted by the disk), but the sym53c8xx_2 driver aborts the following requests with DID_SOFT_ERROR --- for them, the midlayer does just a few retries and then signals the error up to sd. The result is that disk returning QUEUE FULL causes request failures. The error was reproduced on 53c895 with COMPAQ BD03685A24 disk (rebranded ST336607LC) with command queue 48 or 64 tags. The disk has 64 tags, but under some access patterns it return QUEUE FULL when there are less than 64 pending tags. The SCSI specification allows returning QUEUE FULL anytime and it is up to the host to retry. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09drivers/video/fbdev/fb-puv3.c: Add header files for function unifb_mmapZhichuang SUN
commit fbc6c4a13bbfb420eedfdb26a0a859f9c07e8a7b upstream. Function unifb_mmap calls functions which are defined in linux/mm.h and asm/pgtable.h The related error (for unicore32 with unicore32_defconfig): CC drivers/video/fbdev/fb-puv3.o drivers/video/fbdev/fb-puv3.c: In function 'unifb_mmap': drivers/video/fbdev/fb-puv3.c:646: error: implicit declaration of function 'vm_iomap_memory' drivers/video/fbdev/fb-puv3.c:646: error: implicit declaration of function 'pgprot_noncached' Signed-off-by: Zhichuang Sun <sunzc522@gmail.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Jingoo Han <jg1.han@samsung.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Joe Perches <joe@perches.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: linux-fbdev@vger.kernel.org Acked-by: Xuetao Guan <gxt@mprc.pku.edu.cn> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09drm/i915: fix display power sw state reportingImre Deak
commit b8c000d9bf23e7c1155ef421f595d1cbc25262da upstream. Atm, we refcount both power domains and power wells and intel_display_power_enabled_sw() returns the power domain refcount. What the callers are really interested in though is the sw state of the underlying power wells. Due to this we will report incorrectly that a given power domain is off if its power wells were enabled via another power domain, for example POWER_DOMAIN_INIT which enables all power wells. As a fix return instead the state based on the refcount of all power wells included in the passed in power domain. References: https://bugs.freedesktop.org/show_bug.cgi?id=79505 References: https://bugs.freedesktop.org/show_bug.cgi?id=79038 Reported-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Imre Deak <imre.deak@intel.com> Reviewed-by: Damien Lespiau <damien.lespiau@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09mmc: rtsx: add R1-no-CRC mmc command type handleMicky Ching
commit 5027251eced6e34315a52bd841279df957f627bb upstream. a27fbf2f067b0cd ("mmc: add ignorance case for CMD13 CRC error") produced a cmd.flags unhandled in realtek pci host driver. This will make MMC card fail to initialize, this patch is used to handle the new cmd.flags condition and MMC card can be used. Signed-off-by: Micky Ching <micky_ching@realsil.com.cn> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <chris@printf.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09brcmfmac: Fix brcmf_chip_ai_coredisable not applying reset bits to BCMA_IOCTLHans de Goede
commit ffa216bb5eecfce0f01b0b2a95d5c320dde90005 upstream. brcmfmac has been broken on my cubietruck with a BCM43362: brcmfmac: brcmf_chip_recognition: found AXI chip: BCM43362, rev=1 brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d since commit 53036261033: "brcmfmac: update core reset and disable routines". The problem is that since this commit brcmf_chip_ai_resetcore no longer sets BCMA_IOCTL itself before bringing the core out of reset, instead relying on brcmf_chip_ai_coredisable to do so. But brcmf_chip_ai_coredisable is a nop of the chip is already in reset. This patch modifies brcmf_chip_ai_coredisable to always set BCMA_IOCTL even if the core is already in reset. This fixes brcmfmac hanging in firmware loading on my board. Cc: stable@vger.kernel.org # v3.14 Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> [arend@broadcom.com: rebase patch on linux-3.14.y branch] Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09tty: Correct INPCK handlingPeter Hurley
commit 66528f90669691c85c73bea4f0c9f4a5857c4cab upstream. If INPCK is not set, input parity detection should be disabled. This means parity errors should not be received from the tty driver, and the data received should be treated normally. SUS v3, 11.2.2, General Terminal Interface - Input Modes, states: "If INPCK is set, input parity checking shall be enabled. If INPCK is not set, input parity checking shall be disabled, allowing output parity generation without input parity errors. Note that whether input parity checking is enabled or disabled is independent of whether parity detection is enabled or disabled (see Control Modes). If parity detection is enabled but input parity checking is disabled, the hardware to which the terminal is connected shall recognize the parity bit, but the terminal special file shall not check whether or not this bit is correctly set." Ignore parity errors reported by the tty driver when INPCK is not set, and handle the received data normally. Fixes: Bugzilla #71681, 'Improvement of n_tty_receive_parity_error from n_tty.c' Reported-by: Ivan <athlon_@mail.ru> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09serial: Fix IGNBRK handlingPeter Hurley
commit ef8b9ddcb45fa3b1e11acd72be2398001e807d14 upstream. If IGNBRK is set without either BRKINT or PARMRK set, some uart drivers send a 0x00 byte for BREAK without the TTYBREAK flag to the line discipline, when it should send either nothing or the TTYBREAK flag set. This happens because the read_status_mask masks out the BI condition, which uart_insert_char() then interprets as a normal 0x00 byte. SUS v3 is clear regarding the meaning of IGNBRK; Section 11.2.2, General Terminal Interface - Input Modes, states: "If IGNBRK is set, a break condition detected on input shall be ignored; that is, not put on the input queue and therefore not read by any process." Fix read_status_mask to include the BI bit if IGNBRK is set; the lsr status retains the BI bit if a BREAK is recv'd, which is subsequently ignored in uart_insert_char() when masked with the ignore_status_mask. Affected drivers: 8250 - all serial_txx9 mfd amba-pl010 amba-pl011 atmel_serial bfin_uart dz ip22zilog max310x mxs-auart netx-serial pnx8xxx_uart pxa sb1250-duart sccnxp serial_ks8695 sirfsoc_uart st-asc vr41xx_siu zs sunzilog fsl_lpuart sunsab ucc_uart bcm63xx_uart sunsu efm32-uart pmac_zilog mpsc msm_serial m32r_sio Unaffected drivers: omap-serial rp2 sa1100 imx icom Annotated for fixes: altera_uart mcf Drivers without break detection: 21285 xilinx-uartps altera_jtaguart apbuart arc-uart clps711x max3100 uartlite msm_serial_hs nwpserial lantiq vt8500_serial Unknown: samsung mpc52xx_uart bfin_sport_uart cpm_uart/core Fixes: Bugzilla #71651, '8250_core.c incorrectly handles IGNBRK flag' Reported-by: Ivan <athlon_@mail.ru> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09clk: qcom: Fix mmcc-8974's PLL configurationsStephen Boyd
commit 437ae6a1b8f2eedebfbf0f6572e19ca5c58a3f71 upstream. We forgot to add the status bit for the PLLs and we were using the wrong register and masks for configuration, leading to unexpected PLL configurations. Fix this. Fixes: d8b212014e69 (clk: qcom: Add support for MSM8974's multimedia clock controller (MMCC)) Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09clk: qcom: Fix clk_rcg2_is_enabled() checkStephen Boyd
commit aa014149ba002155a084ec1e9328e95b70167cbb upstream. If the bit is set the clock is off so we should be checking for a clear bit, not a set bit. Invert the logic. Fixes: bcd61c0f535a (clk: qcom: Add support for root clock generators (RCGs)) Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09mlx4_core: Fix incorrect FLAGS1 bitmap test in mlx4_QUERY_FUNC_CAPJack Morgenstein
commit bc82878baa10c2a6a4a6affaf52c152935112142 upstream. Commit eb17711bc1d6 ("net/mlx4_core: Introduce nic_info new flag in QUERY_FUNC_CAP") did: if (func_cap->flags1 & QUERY_FUNC_CAP_FLAGS1_OFFSET) { which should be: if (func_cap->flags1 & QUERY_FUNC_CAP_FLAGS1_FORCE_VLAN) { Fix that. Fixes: eb17711bc1d6 ("net/mlx4_core: Introduce nic_info new flag in QUERY_FUNC_CAP") Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
