commit 21f8aaee0c62708654988ce092838aa7df4d25d8 upstream.
We check tid->sched without a lock taken on ath_tx_aggr_sleep(). That
is race condition which can result of doing list_del(&tid->list) twice
(second time with poisoned list node) and cause crash like shown below:
[424271.637220] BUG: unable to handle kernel paging request at 00100104
[424271.637328] IP: [<f90fc072>] ath_tx_aggr_sleep+0x62/0xe0 [ath9k]
[424271.639953] Call Trace:
[424271.639998] [<f90f6900>] ? ath9k_get_survey+0x110/0x110 [ath9k]
[424271.640083] [<f90f6942>] ath9k_sta_notify+0x42/0x50 [ath9k]
[424271.640177] [<f809cfef>] sta_ps_start+0x8f/0x1c0 [mac80211]
[424271.640258] [<c10f730e>] ? free_compound_page+0x2e/0x40
[424271.640346] [<f809e915>] ieee80211_rx_handlers+0x9d5/0x2340 [mac80211]
[424271.640437] [<c112f048>] ? kmem_cache_free+0x1d8/0x1f0
[424271.640510] [<c1345a84>] ? kfree_skbmem+0x34/0x90
[424271.640578] [<c10fc23c>] ? put_page+0x2c/0x40
[424271.640640] [<c1345a84>] ? kfree_skbmem+0x34/0x90
[424271.640706] [<c1345a84>] ? kfree_skbmem+0x34/0x90
[424271.640787] [<f809dde3>] ? ieee80211_rx_handlers_result+0x73/0x1d0 [mac80211]
[424271.640897] [<f80a07a0>] ieee80211_prepare_and_rx_handle+0x520/0xad0 [mac80211]
[424271.641009] [<f809e22d>] ? ieee80211_rx_handlers+0x2ed/0x2340 [mac80211]
[424271.641104] [<c13846ce>] ? ip_output+0x7e/0xd0
[424271.641182] [<f80a1057>] ieee80211_rx+0x307/0x7c0 [mac80211]
[424271.641266] [<f90fa6ee>] ath_rx_tasklet+0x88e/0xf70 [ath9k]
[424271.641358] [<f80a0f2c>] ? ieee80211_rx+0x1dc/0x7c0 [mac80211]
[424271.641445] [<f90f82db>] ath9k_tasklet+0xcb/0x130 [ath9k]
Bug report:
https://bugzilla.kernel.org/show_bug.cgi?id=70551
Reported-and-tested-by: Max Sydorenko <maxim.stargazer@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
[bwh: Backported to 3.2:
- Adjust context
- Use spin_unlock_bh() directly]
[gkh: backported to 3.4:
- adjust context
- back out bwh's spinlock change]
commit 8a55ade76551e3927b4e41ee9e7751875d18bc25 upstream.
Allocate a structure not a pointer to it !
Signed-off-by: Alan Cox <alan@linux.intel.com>
Cc: Yijing Wang <wangyijing@huawei.com>
Cc: Marc Dionne <marc.c.dionne@gmail.com>
commit d8dc3494f77a5cc3b274bae36f7e74e85cf8a407 upstream.
On a system with a logitech wireless keyboard/mouse and DMA-API debugging
enabled, this warning appears at boot:
kernel: WARNING: at lib/dma-debug.c:929 check_for_stack.part.12+0x70/0xa7()
kernel: Hardware name: MS-7593
kernel: uhci_hcd 0000:00:1d.1: DMA-API: device driver maps memory fromstack [addr=ffff8801b0079c29]
Make logi_dj_recv_query_paired_devices and logi_dj_recv_switch_to_dj_mode
use a structure allocated with kzalloc rather than a stack based one.
Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com>
commit a26d5ecb3201c11e03663a8f4a7dedc0c5f85c07 upstream.
Don't allocate and track PCIe ASPM state when "pcie_aspm=off" is specified
on the kernel command line.
Based-on-patch-from: Matthew Garrett <mjg59@srcf.ucam.org>
Signed-off-by: Joe Lawrence <joe.lawrence@stratus.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: David Bulkow <david.bulkow@stratus.com>
Acked-by: Myron Stowe <myron.stowe@redhat.com>
[wyj: Backported to 3.4: context adjust]
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
commit 9ecd1a75d977e2e8c48139c7d3efed183f898d94 upstream.
The maximum packet including header that can be handled by netfront / netback
wire format is 65535. Reduce gso_max_size accordingly.
Drop skb and print warning when skb->len > 65535. This can 1) save the effort
to send malformed packet to netback, 2) help spotting misconfiguration of
netfront in the future.
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
[bwh: Backported to 3.2: adjust context]
[hq: Backported to 3.4: adjust context]
Signed-off-by: Qiang Huang <h.huangqiang@huawei.com>
commit 2fea6cd303c0d0cd9067da31d873b6a6d5bd75e7 upstream.
This patch fixes the issue that the sja1000_interrupt() function may have
returned IRQ_NONE without processing the optional pre_irq() and post_irq()
function before. Further the irq processing counter 'n' is moved to the end of
the while statement to return correct IRQ_[NONE|HANDLED] values at error
conditions.
Reported-by: Wolfgang Grandegger <wg@grandegger.com>
Acked-by: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
[bwh: Backported to 3.2: s/SJA1000_IER/REG_IER/; s/SJA1000_IR/REG_IR/]
Cc: Qiang Huang <h.huangqiang@huawei.com>
commit ad5066d4c2b1d696749f8d7816357c23b648c4d3 upstream.
Make sure to honour gpio polarity also at remove so that the backlight is
actually disabled on boards with active-low enable pin.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Jingoo Han <jg1.han@samsung.com>
commit 778d226a1462572b51d6777cdb1d611543410cb4 upstream.
This patch fixes two memory errors:
1. During a probe failure (in mtd_device_parse_register?) the command
buffer would not be freed.
2. The command buffer's size is determined based on the 'fast_read'
boolean, but the assignment of fast_read is made after this
allocation. Thus, the buffer may be allocated "too small".
To fix the first, just switch to the devres version of kzalloc.
To fix the second, increase MAX_CMD_SIZE unconditionally. It's not worth
saving a byte to fiddle around with the conditions here.
This problem was reported by Yuhang Wang a while back.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Reported-by: Yuhang Wang <wangyuhang2014@gmail.com>
Reviewed-by: Sourav Poddar <sourav.poddar@ti.com>
commit 7e6d72c15ff4cc0c27573901bb05f9eddbd71ed4 upstream.
Booting a 64-vcpu KVM guest, with CONFIG_PREEMPT_VOLUNTARY,
can result in a soft lockup:
BUG: soft lockup - CPU#41 stuck for 67s! [setfont:1505]
RIP: 0010:[<ffffffff812c48da>]
[<ffffffff812c48da>] vgacon_do_font_op.clone.0+0x1ba/0x550
This is due to the 8192 (cmapsz) IO operations taking longer than expected
due to lock contention in QEMU.
Add conditional resched points in between writes allowing other tasks to
execute.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
[bwh: Backported to 3.2: add #include <linux/sched.h>, already present
upstream]
commit 693026ef2e751fd94d2e6c71028e68343cc875d5 upstream.
When b43 gets build into the kernel and it should use bcma we have to
ensure that bcma was also build into the kernel and not as a module.
In this patch this is also done for SSB, although you can not
build b43 without ssb support for now.
This fixes a build problem reported by Randy Dunlap in
5187EB95.2060605@infradead.org
Reported-By: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
commit b996ac90f595dda271cbd858b136b45557fc1a57 upstream.
To add AMD CZ SMBus controller device ID.
[bhelgaas: drop pci_ids.h update]
Signed-off-by: Shane Huang <shane.huang@amd.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
Reviewed-by: Jean Delvare <khali@linux-fr.org>
commit 10b3a32d292c21ea5b3ad5ca5975e88bb20b8d68 upstream.
Commit 902c098a3663 ("random: use lockless techniques in the interrupt
path") turned IRQ path from being spinlock protected into lockless
cmpxchg-retry update.
That commit removed r->lock serialization between crediting entropy bits
from IRQ context and accounting when extracting entropy on userspace
read path, but didn't turn the r->entropy_count reads/updates in
account() to use cmpxchg as well.
It has been observed, that under certain circumstances this leads to
read() on /dev/urandom to return 0 (EOF), as r->entropy_count gets
corrupted and becomes negative, which in turn results in propagating 0
all the way from account() to the actual read() call.
Convert the accounting code to be the proper lockless counterpart of
what has been partially done by 902c098a3663.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Greg KH <greg@kroah.com>
commit 94e0104bca7d6927e85119030b8e6e31fde88a7a upstream.
Commit 1619f441963e 'rapidio/tsi721: fix bug in MSI interrupt
handling' (commit 1ccc819da6fd upstream) makes the MSI handler disable
and re-enable interrupts. When re-enabling interrupts, we should set
the same flags as were originally set, but this changed in Linux 3.5 so
the flags are now inconsistent in 3.2. In fact, the extra flag isn't
even defined in 3.2. Remove the extra flag from the MSI handler.
Reported-by: Steve Conklin <steve.conklin@canonical.com>
commit 1ccc819da6fda9bee10ab8b72e9adbb5ad3e4959 upstream.
Fix bug in MSI interrupt handling which causes loss of event
notifications.
Typical indication of lost MSI interrupts are stalled message and
doorbell transfers between RapidIO endpoints. To avoid loss of MSI
interrupts all interrupts from the device must be disabled on entering
the interrupt handler routine and re-enabled when exiting it.
Re-enabling device interrupts will trigger new MSI message(s) if Tsi721
registered new events since entering interrupt handler routine.
This patch is applicable to kernel versions starting from v3.2.
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Matt Porter <mporter@kernel.crashing.org>
commit 51c94491c82c3d9029f6e87a1a153db321d88e35 upstream.
Fix memory leak - don't forget to kfree ACPI object when returning from
msi_wmi_notify() after suppressing key event.
Signed-off-by: Maxim Mikityanskiy <maxtram95@gmail.com>
Acked-by: Anisse Astier <anisse@astier.eu>
Signed-off-by: Lee, Chun-Yi <jlee@suse.com>
Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
commit f01fc1a82c2ee68726b400fadb156bd623b5f2f1 upstream.
ixgbe_notify_dca cannot be called before driver registration
because it expects driver's klist_devices to be allocated and
initialized. While on it make sure debugfs files are removed
when registration fails.
Signed-off-by: Jakub Kicinski <jakub.kicinski@intel.com>
Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com>
[bwh: Backported to 3.2: no debugfs support]
commit 132c803f7b70b17322579f6f4f3f65cf68e55135 upstream.
NVIDIA's Tegra SoC allows read/write of controller register only
if controller clock is enabled. System hangs if read/write happens
to registers without enabling clock.
clk_prepare_enable() can be fail due to unknown reason and hence
adding check for return value of this function. If this function
success then only access register otherwise return to caller with
error.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
- Adjust context
- Keep calling clk_enable() directly]
commit cfd757010691eae4e17acc246f74e7622c3a2f05 upstream.
Speech synthesis beginners need a low speech rate, and trained people
want a high speech rate. A medium speech rate is thus actually not a
good default for neither. Since trained people will typically know how
to change the rate, better default for a low speech rate, which
beginners can grasp and learn how to increase it afterwards
This was agreed with users on the speakup mailing list.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
commit 389cd784969e9148fedcde0608f15bd74d6b769e upstream.
This patch adds the IDE-mode SATA Device IDs for the Intel Lynx Point-LP PCH
Signed-off-by: James Ralston <james.d.ralston@intel.com>
commit 3399cfb5df9594495b876d1843a7165f77366b2b upstream.
Commit e7e034e18a0a ("drivers/rtc/rtc-pl031.c: fix the missing operation
on enable") accidentally broke the ST variants of PL031.
The bit that is being poked as "clockwatch" enable bit for the ST
variants does the work of bit 0 on this variant. Bit 0 is used for a
clock divider on the ST variants, and setting it to 1 will affect
timekeeping in a very bad way.
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Mian Yousaf KAUKAB <mian.yousaf.kaukab@stericsson.com>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
commit fd7b9270120ca7e53fbf0469febe0c68acf6a0a2 upstream.
D-Link DWA-125/B1 is a relatively new USB Wi-Fi adapter, using a
Ralink chipset supported by the rt2800usb driver. Currently, to work
around the problem (it's missing in all present kernel versions,
up to and including 3.7.x), I had to add this to /etc/rc.local:
echo 2001 3c1e >> /sys/bus/usb/drivers/rt2800usb/new_id
After that, the device works without problems. Been using it for over
a week with no bugs in sight.
The attached patch is trivial and simply adds the new USB ID to the
list of devices handled by rt2800usb.
Signed-off-by: Maia Kozheva <sikon@ubuntu.com>
commit 36f318bb124b231c01db6965a009f46d5731f012 upstream.
This patch adds detection for the Sweex LW323 USB wireless network card
in the rt2x00 driver (just one line in rt2800usb.c).
It applies to linux-3.7-rc3.
Signed-off-by: Jaume Delclòs <jaume@delclos.com>
commit 8f35f787b75e9b6435ea37dabcae2d40dc72d31c upstream.
put back 0x050d,0x7050 to rt73usb, same usb_id for two chips:
K7SF5D7050A ver 2xxx is rt2500
K7SF5D7050B ver 3xxx is rt73
<http://en-us-support.belkin.com/app/answers/detail/a_id/297/kw/K7SF5D7050>
Signed-off-by: Xose Vazquez Perez <xose.vazquez@gmail.com>
commit e7e034e18a0ab6bafb2425c3242cac311164f4d6 upstream.
The RTC control register should be enabled in the process of
initializing.
Without this patch, I failed to enable RTC in Hisilicon Hi3620 SoC. The
register mapping section in RTC is always read as zero. So I doubt that
ST guys may already enable this register in bootloader. So they won't
meet this issue.
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Cc: Linus Walleij <linus.walleij@linaro.org>
commit 6fab3febf6d949b0a12b1e4e73db38e4a177a79e upstream.
For r6xx+ asics. This mirrors the behavior of pre-r6xx
asics. We need to program the MC even if something
else in startup() fails. Failure to do so results in
an unusable GPU.
Based on a fix from: Mark Kettenis <kettenis@openbsd.org>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[wml: Backported to 3.4:
- adjust context
- drop changes to cik.c]
Signed-off-by: Weng Meiling <wengmeiling.weng@huawei.com>
commit dcb852905772416e322536ced5cb3c796d176af5 upstream.
These chips were previously skipped since they are
pre-R600.
- adjust context
- no !ASIC_IS_DCE3(rdev)]
commit 59c8e66378fb78adbcd05f0d09783dde6fef282b upstream.
Also check the busy placements before deciding to move a buffer object.
Failing to do this may result in a completely unneccessary move within a
single memory type.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
Cc: Weng Meiling <wengmeiling.weng@huawei.com>
commit 855f5f1d882a34e4e9dd27b299737cd3508a5624 upstream.
We were using the wrong set_properly callback so we always
ended up with Full scaling even if something else (Center or
Full aspect) was selected.
commit cac6a5ae0118832936eb162ec4cedb30f2422bcc upstream.
ACPI has _BCM and _BQC methods to set and query the backlight
brightness, respectively. The ACPI opregion has variables BCLP and CBLV
to hold the requested and current backlight brightness, respectively.
The BCLP variable has range 0..255 while the others have range
0..100. This means the _BCM method has to scale the brightness for BCLP,
and the gfx driver has to scale the requested value back for CBLV. If
the _BQC method uses the CBLV variable (apparently some implementations
do, some don't) for current backlight level reporting, there's room for
rounding errors.
Use DIV_ROUND_UP for scaling back to CBLV to get back to the same values
that were passed to _BCM, presuming the _BCM simply uses bclp = (in *
255) / 100 for scaling to BCLP.
Reference: https://gist.github.com/aaronlu/6314920
Reported-by: Aaron Lu <aaron.lu@intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Reviewed-by: Aaron Lu <aaron.lu@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
- Adjust context
- ASLE region is treated as normal memory rather than __iomem]
commit f7929f34fa0e0bb6736a2484fdc07d77a1653081 upstream.
got another card with "too bright" problem:
Sapphire Radeon VE 7000 DDR (VGA+S-Video)
lspci -vnn:
01:00.0 VGA compatible controller [0300]: Advanced Micro Devices [AMD] nee ATI RV100 QY [Radeon 7000/VE] [1002:5159] (prog-if 00 [VGA controller])
Subsystem: PC Partner Limited Sapphire Radeon VE 7000 DDR [174b:7c28]
The patch below fixes the problem for this card.
But I don't like the blacklist, couldn't some heuristic be used instead?
The interesting thing is that the manufacturer is the same as the other card
needing the same quirk. I wonder how many different types are broken this way.
The "wrong" ps2_pdac_adj value that comes from BIOS on this card is 0x300.
drm/radeon: Add primary dac adj quirk for Sapphire Radeon VE 7000 DDR
Values from BIOS are wrong, causing too bright colors.
Use default values instead.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
commit dc652f90e088798bfa31f496ba994ddadd5d5680 upstream.
Backlight cleanup in the eDP connector destroy callback caused the
backlight device to be removed on some systems that first initialized LVDS
and then attempted to initialize eDP. Prevent multiple backlight
initializations, and ensure backlight cleanup is only done once by moving
it to modeset cleanup.
A small wrinkle is the introduced asymmetry in backlight
setup/cleanup. This could be solved by adding refcounting, but it seems
overkill considering that there should only ever be one backlight device.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=55701
Tested-by: Peter Verthez <peter.verthez@skynet.be>
- Adjust context
- s/dev_priv->backlight\.device/dev_priv->backlight/]
commit 25ff1195f8a0b3724541ae7bbe331b4296de9c06 upstream.
In order to fully serialize access to the fenced region and the update
to the fence register we need to take extreme measures on SNB+, and
manually flush writes to memory prior to writing the fence register in
conjunction with the memory barriers placed around the register write.
Fixes i-g-t/gem_fence_thrash
v2: Bring a bigger gun
v3: Switch the bigger gun for heavier bullets (Arjan van de Ven)
v4: Remove changes for working generations.
v5: Reduce to a per-cpu wbinvd() call prior to updating the fences.
v6: Rewrite comments to ellide forgotten history.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=62191
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Jon Bloomfield <jon.bloomfield@intel.com>
Tested-by: Jon Bloomfield <jon.bloomfield@intel.com> (v2)
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
[bwh: Backported to 3.2: insert the cache flush in i915_gem_object_get_fence()]
commit 0cd9cb76ae26a19df21abc6f94f5fff141e689c7 upstream.
If we fail to map the mmio BAR, skip driver tear down
that requires mmio.
Should fix:
https://bugzilla.kernel.org/show_bug.cgi?id=56541
commit 411678288d61ba17afe1f8afed92200be6bbc65d upstream.
Monitors seem to prefer it. Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=37696
- Adjust context
- Add to pll->flags, not radeon_crtc->pll_flags]
commit 5f85f176c2f1c9d2a23f60ca0b99e4d0aa5a26a7 upstream.
NCR machines with LVDS panels using Intel chipsets need to have the
QUIRK_INVERT_BRIGHTNESS bit set.
Unfortunately NCR doesn't set a meaningful subvendor/subdevice ID,
therefore we add a DMI dependent quirk list.
Signed-off-by: Egbert Eich <eich@suse.de>
[danvet: fixup whitespace fail.]
Acked-by: Jani Nikula <jani.nikula@intel.com>
- Adjust context
- Add #include <linux/dmi.h>]
commit 5559ecadad5a73b27f863e92f4b4f369501dce6f upstream.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=44156
Reported-by: Alan Zimmerman <alan.zimm@gmail.com>
[wml: Backported to 3.4: Adjust context]
commit 01e3a8feb40e54b962a20fa7eb595c5efef5e109 upstream.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=31522#c35
[Note: There are more than one broken setups in the bug. This fixes one.]
Reported-by: Martins <andrissr@inbox.lv>
commit 1ffff60320879830e469e26062c18f75236822ba upstream.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=59628
Reported-by: Roland Gruber <post@rolandgruber.de>
commit 5a15ab5b93e4a3ebcd4fa6c76cf646a45e9cf806 upstream.
Mark the Acer Aspire 5734Z that this machines requires the module to
invert the panel backlight brightness value after reading from and prior
to writing to the PCI configuration space.
Signed-off-by: Carsten Emde <C.Emde@osadl.org>
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
commit 4dca20efb1a9c2efefc28ad2867e5d6c3f5e1955 upstream.
A machine may need to invert the panel backlight brightness value. This
patch adds the infrastructure for a quirk to do so.
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
- Adjust context
- one more flag QUIRK_NO_PCH_PWM_ENABLE]
commit 7bd90909bbf9ce7c40e1da3d72b97b93839c188a upstream.
Following the documentation of the Legacy Backlight Brightness (LBB)
Register in the configuration space of some Intel PCI graphics adapters,
setting the LBB register with the value 0x0 causes the backlight to be
turned off, and 0xFF causes the backlight to be set to 100% intensity
(http://download.intel.com/embedded/processors/Whitepaper/324567.pdf).
The Acer Aspire 5734Z, however, turns the backlight off at 0xFF and sets
it to maximum intensity at 0. In consequence, the screen of this systems
becomes dark at an early boot stage which makes it unusable. The same
inversion applies to the BLC_PWM_CTL I915 register. This problem was
introduced in kernel version 2.6.38 when the PCI device of this system
was first supported by the i915 KMS module.
This patch adds a parameter to the i915 module to enable inversion of
the brightness variable (i915.invert_brightness).
commit fdfa175d0a9cfa2082ce24e67e284e5acbba452a upstream.
Amending
commit 4518f611ba21ba165ea3714055938a8984a44ff9
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Wed Jan 23 16:16:35 2013 +0100
drm/i915: dump UTS_RELEASE into the error_state
commit 4518f611ba21ba165ea3714055938a8984a44ff9 upstream.
Useful for statistics or on overflowing bug reports to keep things all
lined up.
commit 93be8788e648817d62fda33e2998eb6ca6ebf3a3 upstream.
As along the error path we do not correct the user pin-count for the
failure, we may end up with userspace believing that it has a pinned
object at offset 0 (when interrupted by a signal for example).
commit e7d841ca03b7ab668620045cd7b428eda9f41601 upstream.
Before queuing the flip but crucially after attaching the unpin-work to
the crtc, we continue to setup the unpin-work. However, should the
hardware fire early, we see the connected unpin-work and queue the task.
The task then promptly runs and unpins the fb before we finish taking
the required references or even pinning it... Havoc.
To close the race, we use the flip-pending atomic to indicate when the
flip is finally setup and enqueued. So during the flip-done processing,
we can check more accurately whether the flip was expected.
v2: Add the appropriate mb() to ensure that the writes to the page-flip
worker are complete prior to marking it active and emitting the MI_FLIP.
On the read side, the mb should be enforced by the spinlocks.
Cc: stable@vger.kernel.org
[danvet: Review the barriers a bit, we need a write barrier both
before and after updating ->pending. Similarly we need a read barrier
in the interrupt handler both before and after reading ->pending. With
well-ordered irqs only one barrier in each place should be required,
but since this patch explicitly sets out to combat spurious interrupts
with is staged activation of the unpin work we need to go full-bore on
the barriers, too. Discussed with Chris Wilson on irc and changes
acked by him.]
[wml: Backported to 3.4: adjust context]
commit 695ddeb457584a602f2ba117d08ce37cf6ec1589 upstream.
Add missing index that may have led us to enabling
more crtcs than necessary.
May also fix:
https://bugs.freedesktop.org/show_bug.cgi?id=56139
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
commit eda85d6ad490923152544fba0473798b6cc0edf6 upstream.
Check that the AGP aperture can be mapped. This follows a similar change
done for Radeon (commit 365048ff, drm/radeon: AGP memory is only I/O if
the aperture can be mapped by the CPU.).
The patch fixes the following error seen on G5 iMac:
nouveau E[ DRM] failed to create kernel channel, -12
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=58806
Reviewed-by: Michel Dänzer <michel@daenzer.net>
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
commit cafa59b9011a7790be4ddd5979419259844a165d upstream.
Apple cards do not provide data tables in the vbios
so we have to hard code the connector parameters
in the driver.
Reported-by: Albrecht Dreß <albrecht.dress@arcor.de>
commit 6a556039e7823d27a0a7f7724d4d455053ea9253 upstream.
RV250 found on ppc embedded boards.
Cc: Hans Verkuil <hverkuil@xs4all.nl>
commit bd25f0783dc3fb72e1e2779c2b99b2d34b67fa8a upstream.
Set the proper number of tile pipe that should be a multiple of
pipe depending on the number of se engine.
Fix:
https://bugs.freedesktop.org/show_bug.cgi?id=56405
https://bugs.freedesktop.org/show_bug.cgi?id=56720
v2: Don't change sumo2
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
[bwh: Backported to 3.2: don't define/use *_GB_ADDR_CONFIG_GOLDEN]
