commit 7644d63d1348ec044ccd8f775fefe5eb7cbcac69 upstream.
This patch fixes accumulating of the header in case packet was requeued
in the error path.
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 501aa061bd68169a5b54c123641f8dfa9ad31545 upstream.
Ensure that we do not set pcb->data.raw beyond its size, print an error message
and return false if we attempt to. A timout message was printed one too early.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
commit 5955c7a2cfb6a35429adea5dc480002b15ca8cfc upstream.
Signed-off-by: Zlatko Calusic <zlatko.calusic@iskon.hr>
commit 2f5899a39dcffb404c9a3d06ad438aff3e03bf04 upstream.
I am not sure what happened. It looks like we have always leaked
the q->queue that is allocated from the kfifo_init call. nab finally
noticed that we were leaking and this patch fixes it by adding a
kfree call to iscsi_pool_free. kfifo_free is not used per kfifo_init's
instructions to use kfree.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Jean Delvare <jdelvare@suse.de>
commit ca77fde8e62cecb2c0769052228d15b901367af8 upstream.
This is the cause of the DMA faults and disk corruption that people have
been seeing. Some chipsets neglect to report the RWBF "capability" --
the flag which says that we need to flush the chipset write-buffer when
changing the DMA page tables, to ensure that the change is visible to
the IOMMU.
Override that bit on the affected chipsets, and everything is happy
again.
Thanks to Chris and Bhavesh and others for helping to debug.
Tested-by: Chris Wright <chrisw@sous-sol.org>
Reviewed-by: Bhavesh Davda <bhavesh@vmware.com>
commit 7dac745b8e367c99175b8f0d014d996f0e5ed9e5 upstream.
Kernel bz#12176 reports that nf2 hardreset simply doesn't work. Give
up. Argh...
Cc: Robert Hancock <hancockr@shaw.ca>
Reported-by: Saro <saro_v@hotmail.it>
commit 12d60e28bed3f593aac5385acbdbb089eb8ae21e upstream.
bugzilla: #12363
commit 7cd5b08be3c489df11b559fef210b81133764ad4 added a second regression:
some Dell's and Compaq's lockup on boot. So we revert most of the code.
The ICH9 reboot issue remains in place and will need some more fixing... :-(
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
commit 9e772d0135a5b5f8355320be429efa339700d52d upstream.
This one fixes http://bugzilla.kernel.org/show_bug.cgi?id=12320.
Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
commit d89293abd95bfd7dd9229087d6c30c1464c5ac83 upstream.
The dev->pio_mode > XFER_PIO_0 test is there to avoid unnecessary
speed down warning messages but it accidentally disabled SATA link spd
down during configuration phase after reset where PIO mode is always
zero.
This patch fixes the problem by moving the test where it belongs.
This makes libata probing sequence behave better when the connection
is flaky at higher link speeds which isn't too uncommon for eSATA
devices.
Cc: Chuck Ebbert <cebbert@redhat.com>
commit 0fb21de0799a985d2da3da14ae5625d724256638 upstream.
Report descriptor fixup for MS 1028 receiver changes also values for
Keyboard and Consumer, which incorrectly trims the range, causing correct
events being thrown away before passing to userspace.
We need to keep the GenDesk usage fixup though, as it reports totally bogus
values about axis.
Reported-by: Lucas Gadani <lgadani@gmail.com>
[ Upstream commit e918085aaff34086e265f825dd469926b1aec4a4 ]
802.1Q expanded the maximum ethernet frame size by 4 bytes for the
VLAN tag. We're not taking this into account in virtio_net, which
means the buffers we provide to the backend in the virtqueue RX ring
aren't big enough to hold a full MTU VLAN packet. For QEMU/KVM,
this results in the backend exiting with a packet truncation error.
Signed-off-by: Alex Williamson <alex.williamson@hp.com>
Acked-by: Mark McLoughlin <markmc@redhat.com>
[ Upstream commit cfbf84fcbcda98bb91ada683a8dc8e6901a83ebd ]
Tap devices can make use of a small MAC filter set via the
TUNSETTXFILTER ioctl. The filter has a set of exact matches
plus a hash for imperfect filtering of additional multicast
addresses. The current code is unbalanced, adding unicast
addresses to the multicast hash, but only checking the hash
against multicast addresses. This results in the filter
dropping unicast addresses that overflow the exact filter.
The fix is simply to disable the filter by leaving count set
to zero if we find non-multicast addresses after the exact
match table is filled.
[ Upstream commit a11da890e4c9850411303efcf6514f048ca880ee ]
Printing anything over netconsole before hw is up and running is,
of course, not going to work.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
[ Upstream commit 71822faa3bc0af5dbf5e333a2d085f1ed7cd809f ]
In the lockup situation the driver seems to go off in an eternal storm
of interrupts right after calling request_irq(). It doesn't actually
do anything interesting in the interrupt handler. Since connecting the link
afterwards works, something later in initialization must fix this.
Looking at gem_do_start() and gem_open(), it seems that the only thing
done while opening the device after the request_irq(), is a call to
napi_enable().
I don't know what the ordering requirements are for the
initialization, but I boldly tried to move the napi_enable() call
inside gem_do_start() before the link state is checked and interrupts
subsequently enabled, and it seems to work for me. Doesn't even break
anything too obvious...
[ Upstream commit c25b9abbc2c2c0da88e180c3933d6e773245815a ]
Fix inverted logic
commit 3abdbf90a3ffb006108c831c56b092e35483b6ec upstream.
Since netmos 9835 with subids 0x1014(IBM):0x0299 is now bound with
serial/8250_pci, because it has no parallel ports and subdevice id isn't
in the expected form, return -ENODEV from probe function.
This is performed in netmos preinit_hook.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
commit efb43f4b2ccf8066abc3920a0e6858e4350a65c7 upstream.
Three people (Petr Mensik <pihhan@cipis.net>
["si" should be U+0161 U+00ED], Stephen Ho <stephenhoinhk@gmail.com>
on zd1211-devs and Ismael Ojeda Perez <iojedaperez@gmail.com>
on linux-wireless) reported success in getting TP-Link WN322G/WN422G
working by treating MAXIM_NEW_RF(0x08) as UW2453_RF(0x09) for rf
chip hardware initialization.
Signed-off-by: Hin-Tak Leung <htl10@users.sourceforge.net>
Tested-by: Petr Mensik <pihhan@cipis.net>
Tested-by: Stephen Ho <stephenhoinhk@gmail.com>
Tested-by: Ismael Ojeda Perez <iojedaperez@gmail.com>
commit 14990c69b5f51dd57b4e0e2373de50239ac861e2 upstream.
Christoph Biedl <sourceforge.bnwi@manchmal.in-ulm.de> reported success
in the sourceforge zd1211 mailing list on this addition. This product ID
was supported by the vendor driver ZD1211LnxDrv 2.22.0.0 (and possibly
earlier) and it probably should have been added earlier.
Tested-by: Christoph Biedl <sourceforge.bnwi@manchmal.in-ulm.de>
commit 507e2fbaaacb6f164b4125b87c5002f95143174b upstream.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=12646
When the temperature exceeds 32767 milli-degrees the temperature overflows
to -32768 millidegrees. These are bothe well within the -55 - +125 degree
range for the sensor.
Fix overflow in left-shift of a u8.
Signed-off-by: Ian Dall <ian@beware.dropbear.id.au>
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net>
commit 4d48a542b42747c36a5937447d9c3de7c897ea50 upstream.
Fix a problem that causes I/O to a disconnected (or partially initialized)
nbd device to hang indefinitely. To reproduce:
# ioctl NBD_SET_SIZE_BLOCKS /dev/nbd23 514048
# dd if=/dev/nbd23 of=/dev/null bs=4096 count=1
...hangs...
This can also occur when an nbd device loses its nbd-client/server
connection. Although we clear the queue of any outstanding I/Os after the
client/server connection fails, any additional I/Os that get queued later
will hang.
This bug may also be the problem reported in this bug report:
http://bugzilla.kernel.org/show_bug.cgi?id=12277
Testing would need to be performed to determine if the two issues are the
same.
This problem was introduced by the new request handling thread code ("NBD:
allow nbd to be used locally", 3/2008), which entered into mainline around
2.6.25.
The fix, which is fairly simple, is to restore the check for lo->sock
being NULL in do_nbd_request. This causes I/O to an uninitialized nbd to
immediately fail with an I/O error, as it did prior to the introduction of
this bug.
Signed-off-by: Paul Clements <paul.clements@steeleye.com>
Reported-by: Jon Nelson <jnelson-kernel-bugzilla@jamponi.net>
Acked-by: Pavel Machek <pavel@ucw.cz>
commit c91192d66d6cea7878b8542c9d9f1873971aba92 upstream.
Two nbd-clients at same time are bad idea, and cause WARN_ON from nbd in
2.6.28-rc7 from sysfs_add_one. This simply prevents that from happening.
To reproduce:
cat /dev/zero | head -c 10000000 > /tmp/delme.fstest.fs
nbd-server 9100 -l /anyone.can.connect > /tmp/delme.fstest.fs &
sleep 1
nbd-client localhost 9100 /dev/nd0 &
Signed-off-by: Pavel Machek <pavel@suse.cz>
Acked-by: Paul Clements <paul.clements@steeleye.com>
commit 6813952021a7820a505002de260bda36978671f7 upstream.
Signed-off-by: Joseph Chan <josephchan@via.com.tw>
commit 506e9469833c66ed6bb9acd902e208f7301b6adb upstream.
This patch (as1202) adds Pentax to usb-storage's list of bad vendors
whose devices always need the CAPACITY_HEURISTICS flag. This is in
addition to the existing entries: Nokia, Nikon, and Motorola.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Virgo Pärna <virgo.parna@mail.ee>
commit 97dcf0416e390fc5c997d4ea60e6f975c7b7a1c3 upstream.
This patch adds device IDs and balances the counts to make the
hot ID additioning mechanism work.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Cc: Chris Adams <cmadams@hiwaay.net>
commit 1a1fab513734b3a4fca1bee8229e5ff7e1cb873c upstream.
This adds a new device id
commit c200b9c9e8ec93cdd262cfa1699ad92e883d4876 upstream.
- New Novatel and Dell mobile broadband modem products added
- Dell pid variables used in stead of numerical PIDs for known
products
Signed-off-by: Dirk De Schepper <ddeschepper@nvtl.com>
Signed-off-by: Matthias Urlichs <matthias@urlichs.de>
commit 6b40c0057a7935bcf63a38a924094c7e61d4731f upstream.
Revert 8b6346ec899713a90890c9e832f7eff91ea73504 as these devices really
work just fine with the cdc-acm driver, as they follow the spec
properly.
Thanks to Chuck Ebbert for pointing out the problem here.
Cc: Dan Williams <dcbw@redhat.com>
commit 14a4dfe2ff8c353f59ae8324059ded1cfe22c7d9 upstream.
This patch fixes sporadic firmware restarts when scanning while associated.
The firmware will quietly cancel a scan (while associated) if the dwell time
for a channel to be scanned is larger than the time it may stay away from the
operating channel (because of DTIM catching). Unfortunately the driver is not
notified about the canceled scan and therefore the scan watchdog timeout will
be hit and the driver causes a firmware restart which results in
disassociation. This mainly happens on passive channels which use a dwell time
of 120 whereas a typical beacon interval is around 100.
The patch changes the dwell time for passive channels to be slightly smaller
than the actual beacon interval to work around the firmware issue. Furthermore
the number of allowed beacon misses is increased from one to three as otherwise
most scans (while associated) won't complete successfully.
However scanning while associated will still fail in corner cases such as a
beacon intervals below 30.
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
commit 935e5f290ec1eb0f1c15004421f5fd3154380fd5 upstream.
Section B.6.2 of ACPI 3.0b specification that defines _BCL method
doesn't require the brightness levels returned to be sorted.
At least ThinkPad SL300 (and probably all IdeaPads) returns the
array reversed (i.e. bightest levels have lowest indexes), which
causes the brightness management behave in completely reversed
manner on these machines (brightness increases when the laptop is
idle, while the display dims when used).
Sorting the array by brightness level values after reading the list
fixes the issue.
http://bugzilla.kernel.org/show_bug.cgi?id=12037
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Tested-by: Lubomir Rintel <lkundrak@v3.sk>
Signed-off-by: Len Brown <len.brown@intel.com>
Signed-off-by: Thomas Renninger <trenn@suse.de>
commit 78d70d48132ce4c678a95b771ffa1af4fb5a03ec upstream.
This Patch add the device information for the
MIC-3620 8-port RS-232 cPCI card from Advantech Co. Ltd.
Signed-off-by: Michael Bramer <grisu@deb-support.de>
Signed-off-by: Alan Cox <number6@the-village.bc.nu>
Dual 16950 Serial adapter
commit 39aced68d664291db3324d0fcf0985ab5626aac2 upstream.
The PCI-card identified as "Oxford Semiconductor Ltd EXSYS EX-41092 Dual
16950 Serial adapter" is only usable with other devices (i.e. not the same
card) after doing a "setserial /dev/ttyS<n> baud_base 115200". This
baud_base should be default for this card.
Signed-off-by: Niels de Vos <niels.devos@wincor-nixdorf.com>
Signed-off-by: Alan Cox <alan@redhat.com>
commit 97c44836cdec1ea713a15d84098a1a908157e68f upstream.
This patch makes the ROM reading code return an error to user space if
the size of the ROM read is equal to 0.
The patch also emits a warnings if the contents of the ROM are invalid,
and documents the effects of the "enable" file on ROM reading.
Signed-off-by: Timothy S. Nelson <wayland@wayland.id.au>
Acked-by: Alex Villacis-Lasso <a_villacis@palosanto.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 3419c75e15f82c3ab09bd944fddbde72c9e4b3ea upstream.
We only want to disable ASPM when the last function is removed from
the parent's device list. We determine this by checking to see if
the parent's device list is completely empty.
Unfortunately, we never hit that code because the parent is considered
an upstream port, and never had an ASPM link_state associated with it.
The early check for !link_state causes us to return early, we never
discover that our device list is empty, and thus we never remove the
downstream ports' link_state nodes.
Instead of checking to see if the parent's device list is empty, we can
check to see if we are the last device on the list, and if so, then we
know that we can clean up properly.
Cc: Shaohua Li <shaohua.li@intel.com>
Signed-off-by: Alex Chiang <achiang@hp.com>
commit 386e4a8358239f90275e1f93d5ad11cdc93c6453 upstream.
During early boot, ACPI RSDT/XSDT table entries are gathered into the
'initial_tables[]' array. This array is currently statically defined (see
./drivers/acpi/tables.c). When there are more table entries than can be
held in the 'initial_tables[]' array, the message "Truncating N table
entries!" is output. As currently implemented, this message will always
erroneously calculate N as 0.
This patch fixes the calculation that determines how many table entries
will be missing (truncated).
This modification may be used under either the GPL or the BSD-style
license used for Intel ACPI CA code.
Signed-off-by: Myron Stowe <myron.stowe@hp.com>
commit 9e3a9d1ed8cc8db93e5c53e9a5b09065bd95de8b upstream.
When ACPI is disabled in the BIOS of this VIA C3 box,
it invalidates the RSDP, which Linux notices:
ACPI Error (tbxfroot-0218): A valid RSDP was not found [20080926]
Bug Linux neglected to disable ACPI at that stage,
and later scribbled on smp_found_config:
ACPI: No APIC-table, disabling MPS
But this box doesn't run well in legacy PIC mode,
it needed IOAPIC mode to perform correctly:
http://lkml.org/lkml/2009/2/5/39
So exit ACPI mode cleanly when we first detect
that it is hopeless.
commit f3b39f1393d5cebe56f43a584ef47efbebd2702c upstream.
eliminate the duplicate the name of "VGA"
http://bugzilla.kernel.org/show_bug.cgi?id=12514
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
commit 0a3db1cec5d476804185114ff5d1845aed3936b3 upstream.
According to the Spec the first two elements in the _BCL package won't be
regarded as the available brightness level. The first is the brightness when
full power is connected to the box(It means that the AC adapter is plugged).
The second is the brightness level when the box is on battery.
If the first two elements are still used while finding the next brightness
level, it will fall back to the lowest level when keeping on pressing
hotkey. (On some boxes the brightness will be changed twice when hotkey is
pressed once. One is in the ACPI video driver. The other is changed by sys I/F.
In the ACPI video driver the first two elements will be used while changing
the brightness. But the first two elements is skipped while using sys I/F.
In such case there exists the inconsistency).
So he first two elements had better be skipped while showing the available
brightness or finding the next brightness level.
http://bugzilla.kernel.org/show_bug.cgi?id=12450
commit 2b190e76def5233c542f6025b4a133b1d4bd1a37 upstream.
Ensure pcc->keymap[ ARRAY_SIZE(pcc->keymap) ] does not occur.
commit 1021e2119eb33a990a2b9ff1410805dd9bdf7997 upstream.
Add R1F support
Signed-off-by: Corentin Chary <corentincj@iksaif.net>
commit b854b2ab959e8175d75e01cf8ed452ed2624d0c8 upstream.
Signed-off-by: Eric Anholt <eric@anholt.net>
Signed-off-by: Dave Airlie <airlied@linux.ie>
commit a50ccc6c6623ab0e64f2109881e07c176b2d876f upstream.
Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com>
commit 4d7155b932b8129c72e2f2714890e20b2a05e0b7 upstream.
On machine were no IO ports are assigned the call
to pci_enable_device() will fail, even if need_ioport
is false, we need to use pci_enable_device_mem() here.
Signed-off-by: Karsten Keil <kkeil@suse.de>
commit 15b2bee22a0390d951301b53e83df88d0350c499 upstream.
A nasty bug was found where an MTU change (or anything else that caused a
reset) could race with the interrupt code. The interrupt code was entered
by a shared interrupt during the MTU change.
This change prevents the interrupt code from running while the driver is in
the middle of its reset path.
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
commit b5f6f26550700445dcc125bbf75b9104e779d353 upstream.
Newer Eees have extra hotkeys above the function keys. This patch adds support
for sending them through the input layer.
eeepc-laptop init
commit 7695fb04aca62e2d8a7ca6ede50f6211e1d71e53 upstream.
I got the following oops while changing the backlight brightness during
startup. When it happens, it prevents use of the hotkeys, Fn-Fx, and the
lid button.
It's a clear use-before-init, as I verified by testing with an
appropriately-placed "else printk".
BUG: unable to handle kernel NULL pointer dereference at 00000000
*pde = 00000000
Oops: 0002 [#1] PREEMPT SMP
Pid: 160, comm: kacpi_notify Not tainted (2.6.28.1-eee901 #4) 901
EIP: 0060:[<c0264e68>] [<c0264e68>] eeepc_hotk_notify+26/da
EFLAGS: 00010246 CPU: 1
Using defaults from ksymoops -t elf32-i386 -a i386
EAX: 00000009 EBX: 00000000 ECX: 00000009 EDX: f70dbf64
ESI: 00000029 EDI: f7335188 EBP: c02112c9 ESP: f70dbf80
DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
f70731e0 f73acd50 c02164ac f7335180 f70aa040 c02112e6 f733518c c012b62f
f70aa044 f70aa040 c012bdba f70aa04c 00000000 c012be6e 00000000 f70bdf80
c012e198 f70dbfc4 f70dbfc4 f70aa040 c012bdba 00000000 c012e0c9 c012e091
Call Trace:
[<c02164ac>] ? acpi_ev_notify_dispatch+4c/55
[<c02112e6>] ? acpi_os_execute_deferred+1d/25
[<c012b62f>] ? run_workqueue+71/f1
[<c012bdba>] ? worker_thread+0/bf
[<c012be6e>] ? worker_thread+b4/bf
[<c012e198>] ? autoremove_wake_function+0/2b
[<c012e0c9>] ? kthread+38/5f
[<c012e091>] ? kthread+0/5f
[<c0103abf>] ? kernel_thread_helper+7/10
Code: 00 00 00 00 c3 83 3d 60 5c 50 c0 00 56 89 d6 53 0f 84 c4 00 00 00 8d 42
e0 83 f8 0f 77 0f 8b 1d 68 5c 50 c0 89 d8 e8 a9 fa ff ff <89> 03 8b 1d 60 5c
50 c0 89 f2 83 e2 7f 0f b7 4c 53 10 8d 41 01
Signed-off-by: Darren Salt <linux@youmustbejoking.demon.co.uk>
Commit 1448d7c6a2ff96d3b52ecae49e2d0f046a097fe0 upstream.
As per https://bugs.launchpad.net/bugs/294391. These got one sample of
each iPod generation going. However there still occurred I/O stalls
with the 3rd generation iPod which remain undiagnosed at the time of
this writing.
Acked-by: Jarod Wilson <jarod@redhat.com>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Commit c8c4707cf7ca8ff7dcc1653447e48cb3de0bf114 upstream.
According to https://bugs.launchpad.net/bugs/294391
- 3rd generation iPods need the "fix capacity" workaround after all
(apparently they crash after the last sector was accessed),
- 2nd generation iPods need the "128 kB maximum request size"
workaround.
Alas both iPod generations feature the same model ID in the config ROM,
hence we can only define a shared quirks list entry for them. Luckily
the fix capacity workaround did not show a negative effect in Jarod's
tests with 2nd gen. iPod.
A side note: Apple computers in target mode (or at least an x86 Mac
mini) don't have firmware_version and model_id, hence none of the iPod
quirks list entries is active for them.
Tested-by: Jarod Wilson <jarod@redhat.com>
Commit 5e2125677fd72d36396cc537466e07ffcbbd4b2b upstream.
Reported-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
who also provided a first version of the fix.
camcorders and others
Commit 8b7b6afaa84708d08139daa08538ca3e56c351f1 upstream.
Camcorders have a tendency to fail read requests to their config ROM and
write request to their FCP command register with ack_busy_X. This has
become a problem with newer kernels and especially Panasonic camcorders,
causing AV/C in dvgrab and kino to fail. Dvgrab for example frequently
logs "send oops"; kino reports loss of AV/C control. I suspect that
lower CPU scheduling latencies in newer kernels made this issue more
prominent now.
According to
https://sourceforge.net/tracker/?func=detail&atid=114103&aid=2492640&group_id=14103
this can be fixed by configuring the FireWire controller for more
hardware retries for request transmission; these retries are evidently
more successful than libavc1394's own retry loop (typically 3 tries on
top of hardware retries).
Presumably the same issue has been reported at
https://bugzilla.redhat.com/show_bug.cgi?id=449252 and
https://bugzilla.redhat.com/show_bug.cgi?id=477279 .
In a quick test with a JVC camcorder (which didn't malfunction like the
reported camcorders), this change decreased the number of ack_busy_X
from 16 in three runs of dvgrab to 4 in three runs of the same capture
duration.
Commit 64c634ef83991b390ec0503e61f16efb0ba3c60b upstream.
prominent now.
According to
Tested-by: Mathias Beilstein
