commit 7f54ab5ff52fb0b91569bc69c4a6bc5cac1b768d upstream.
This patch fixes a recent ABORT_TASK regression associated
with commit febe562c, where a left-over target_put_sess_cmd()
would still be called when __target_check_io_state() detected
a command has already been completed, and explicit ABORT must
be avoided.
Note commit febe562c dropped the local kref_get_unless_zero()
check in core_tmr_abort_task(), but did not drop this extra
corresponding target_put_sess_cmd() in the failure path.
So go ahead and drop this now bogus target_put_sess_cmd(),
and avoid this potential use-after-free.
Reported-by: Dan Lane <dracodan@gmail.com>
Cc: Quinn Tran <quinn.tran@qlogic.com>
Cc: Himanshu Madhani <himanshu.madhani@qlogic.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Andy Grover <agrover@redhat.com>
Cc: Mike Christie <mchristi@redhat.com>
commit d74e766e1916d0e09b86e4b5b9d0f819628fd546 upstream.
This reverts commit 39d4275058baf53e89203407bf3841ff2c74fa32.
This caused a regression on some older hardware.
bug:
https://bugzilla.kernel.org/show_bug.cgi?id=113891
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 1e1490a38504419e349caa1b7d55d5c141a9bccb upstream.
This is a port of the patch "drm/amdgpu: Fix error handling in amdgpu_flip_work_func."
to fix the following problem for radeon as well which was
reported against amdgpu:
The patch e1d09dc0ccc6: "drm/amdgpu: Don't hang in
amdgpu_flip_work_func on disabled crtc." from Feb 19, 2016, leads to
the following static checker warning, as reported by Dan Carpenter in
https://lists.freedesktop.org/archives/dri-devel/2016-February/101987.html
drivers/gpu/drm/amd/amdgpu/amdgpu_display.c:127 amdgpu_flip_work_func() warn: should this be 'repcnt == -1'
drivers/gpu/drm/amd/amdgpu/amdgpu_display.c:136 amdgpu_flip_work_func() error: double unlock 'spin_lock:&crtc->dev->event_lock'
drivers/gpu/drm/amd/amdgpu/amdgpu_display.c:136 amdgpu_flip_work_func() error: double unlock 'irqsave:flags'
This patch fixes both reported problems:
Change post-decrement of repcnt to pre-decrement, so
it can't underflow anymore, but still performs up to
three repetitions - three is the maximum one could
expect in practice.
Move the spin_unlock_irqrestore to where it actually
belongs.
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Mario Kleiner <mario.kleiner.de@gmail.com>
Cc: Michel Dänzer <michel.daenzer@amd.com>
Cc: Alex Deucher <alexander.deucher@amd.com>
commit 90e94b160c7f647ddffda707f5e3c0c66c170df8 upstream.
expect in practice.
belongs.
commit 256faedcfd646161477d47a1a78c32a562d2e845 upstream.
This reverts commit dbb17a21c131eca94eb31136eee9a7fe5aff00d9.
It turns out that commit can cause problems for systems with multiple
GPUs, and causes X to hang on at least a HP Pavilion dv7 with hybrid
graphics.
This got noticed originally in 4.4.4, where this patch had already
gotten back-ported, but 4.5-rc7 was verified to have the same problem.
Alexander Deucher says:
"It looks like you have a muxed system so I suspect what's happening is
that one of the display is being reported as connected for both the
IGP and the dGPU and then the desktop environment gets confused or
there some sort problem in the detect functions since the mux is not
switched to the dGPU. I don't see an easy fix unless Dave has any
ideas. I'd say just revert for now"
Reported-by: Jörg-Volker Peetz <jvpeetz@web.de>
Acked-by: Alexander Deucher <Alexander.Deucher@amd.com>
Cc: Dave Airlie <airlied@gmail.com>
commit 17e0521750399205f432966e602e125294879cdd upstream.
The port nodes are documented as optional, treat them accordingly.
Reported-by: Martin Fuzzey <mfuzzey@parkeon.com>
Reported-by: Chris Healy <Chris.Healy@zii.aero>
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Fixes: 304e6be652e2 ("gpu: ipu-v3: Assign of_node of child platform devices to corresponding ports")
commit fb896c44f88a75843a072cd6961b1615732f7811 upstream.
Until this patch, when TXing non-sta the pending_frames counter
wasn't increased, but it WAS decreased in
iwl_mvm_rx_tx_cmd_single(), what makes it negative in certain
conditions. This in turn caused much trouble when we need to
remove the station since we won't be waiting forever until
pending_frames gets 0. In certain cases, we were exhausting
the station table even in BSS mode, because we had a lot of
stale stations.
Increase the counter also in iwl_mvm_tx_skb_non_sta() after a
successful TX to avoid this outcome.
Signed-off-by: Liad Kaufman <liad.kaufman@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit e9a2d81b1761093386a0bb8a4f51642ac785ef63 upstream.
gs_destroy_candev() erroneously calls kfree() on a struct gs_can *, which is
allocated through alloc_candev() and should instead be freed using
free_candev() alone.
The inappropriate use of kfree() causes the kernel to hang when
gs_destroy_candev() is called.
Only the struct gs_usb * which is allocated through kzalloc() should be freed
using kfree() when the device is disconnected.
Signed-off-by: Maximilian Schneider <max@schneidersoft.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 25c5e9626ca4d40928dc9c44f009ce2ed0a739e7 upstream.
When computing the residue we need two pieces of information: the current
descriptor and the remaining data of the current descriptor. To get
that information, we need to read consecutively two registers but we
can't do it in an atomic way. For that reason, we have to check manually
that current descriptor has not changed.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Suggested-by: Cyrille Pitchen <cyrille.pitchen@atmel.com>
Reported-by: David Engraf <david.engraf@sysgo.com>
Tested-by: David Engraf <david.engraf@sysgo.com>
Fixes: e1f7c9eee707 ("dmaengine: at_xdmac: creation of the atmel
eXtended DMA Controller driver")
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit ce0c12b633846a47e103842149a5bac2e5d261ec upstream.
git commit 1ec2772e0c3c ("s390/diag: add a statistic for diagnose
calls") added function calls to gather diagnose statistics.
In case of the dasd diag driver the function call was added between a
register asm statement which initialized register r2 and the inline
assembly itself. The function call clobbers the contents of register
r2 and therefore the diag 0x250 call behaves in a more or less random
way.
Fix this by extracting the function call into a separate function like
we do everywhere else.
Fixes: 1ec2772e0c3c ("s390/diag: add a statistic for diagnose calls")
Reported-and-tested-by: Stefan Haberland <sth@linux.vnet.ibm.com>
commit 54c6e2dd00c313d0add58e5befe62fe6f286d03b upstream.
pci_create_root_bus() passes a "parent" pointer to
pci_bus_assign_domain_nr(). When CONFIG_PCI_DOMAINS_GENERIC is defined,
pci_bus_assign_domain_nr() dereferences that pointer. Many callers of
pci_create_root_bus() supply a NULL "parent" pointer, which leads to a NULL
pointer dereference error.
7c674700098c ("PCI: Move domain assignment from arm64 to generic code")
moved the "parent" dereference from arm64 to generic code. Only arm64 used
that code (because only arm64 defined CONFIG_PCI_DOMAINS_GENERIC), and it
always supplied a valid "parent" pointer. Other arches supplied NULL
"parent" pointers but didn't defined CONFIG_PCI_DOMAINS_GENERIC, so they
used a no-op version of pci_bus_assign_domain_nr().
8c7d14746abc ("ARM/PCI: Move to generic PCI domains") defined
CONFIG_PCI_DOMAINS_GENERIC on ARM, and many ARM platforms use
pci_common_init(), which supplies a NULL "parent" pointer.
These platforms (cns3xxx, dove, footbridge, iop13xx, etc.) crash
with a NULL pointer dereference like this while probing PCI:
Unable to handle kernel NULL pointer dereference at virtual address 000000a4
PC is at pci_bus_assign_domain_nr+0x10/0x84
LR is at pci_create_root_bus+0x48/0x2e4
Kernel panic - not syncing: Attempted to kill init!
[bhelgaas: changelog, add "Reported:" and "Fixes:" tags]
Reported: http://forum.doozan.com/read.php?2,17868,22070,quote=1
Fixes: 8c7d14746abc ("ARM/PCI: Move to generic PCI domains")
Fixes: 7c674700098c ("PCI: Move domain assignment from arm64 to generic code")
Signed-off-by: Krzysztof Hałasa <khalasa@piap.pl>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
When upstream commit 429c45deae6e57f1bb91bfb05b671063fb0cef60
was applied to 4.4 as d60703ca942e8d044d61360bc9792fcab54b95d0
it applied incorrectly to the tonga_ip_blocks array rather than
the topaz_ip_blocks array. Fix that up here.
Bug:
https://bugzilla.kernel.org/show_bug.cgi?id=113951
commit f2e305108faba0c85eb4ba4066599decb675117e upstream.
The test for the qemu q35 south bridge added by commit
"39bfcd52 drm/i915: more virtual south bridge detection"
also matches on real hardware. Having the check for
virtual systems last in the list is not enough to avoid
that ...
Refine the check by additionally verifying the pci
subsystem id to see whenever it *really* is qemu.
[ v2: fix subvendor tyops ]
Reported-and-tested-by: Bjørn Mork <bjorn@mork.no>
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
Tested-by: Bruno Wolff III <bruno@wolff.to>
Cc: drm-intel-fixes@lists.freedesktop.org
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1453719748-10944-1-git-send-email-kraxel@redhat.com
(cherry picked from commit 1e859111c128265f8d62b39ff322e42b1ddb5a20)
commit 39bfcd5235e07e95ad3e70eab8e0b85db181de9e upstream.
Commit "30c964a drm/i915: Detect virtual south bridge" detects and
handles the southbridge emulated by vmware esx. Add the ich9 south
bridge emulated by 'qemu -M q35'.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 9571e1d84042f5670df9fabdcbe7dd5da3abe43e upstream.
It can be big, depending on the VM address space size, which is tunable
via the vm_size module parameter.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=93721
Reviewed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
commit a53b8394ec3c67255928df6ee9cc99dd1cd452e3 upstream.
In __cpufreq_cooling_register() we allocate the arrays for time_in_idle
and time_in_idle_timestamp to be as big as the number of cpus in this
cpufreq device. However, in get_load() we access this array using the
cpu number as index, which can result in an out of bound access.
Index time_in_idle{,_timestamp} using the index in the cpufreq_device's
allowed_cpus mask, as we do for the load_cpu array in
cpufreq_get_requested_power()
Reported-by: Nicolas Boichat <drinkcat@chromium.org>
Cc: Amit Daniel Kachhap <amit.kachhap@gmail.com>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Eduardo Valentin <edubezval@gmail.com>
Tested-by: Nicolas Boichat <drinkcat@chromium.org>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Javi Merino <javi.merino@arm.com>
Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
commit 7314d22a2f5bd40468d57768be368c3d9b4bd726 upstream.
We want the size of the struct, not of a pointer to it. To be future
proof, just dereference the pointer to get the desired type.
Fixes: dd1aa2524bc5 ("i2c: brcmstb: Add Broadcom settop SoC i2c controller driver")
Acked-by: Gregory Fong <gregory.0xf0@gmail.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Reviewed-by: Kamal Dasu <kdasu.kdev@gmail.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit e4f6daac20332448529b11f09388f1d55ef2084c upstream.
ubi_start_leb_change() allocates too few bytes.
ubi_more_leb_change_data() will write up to req->upd_bytes +
ubi->min_io_size bytes.
Signed-off-by: Richard Weinberger <richard@nod.at>
Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com>
commit 923adb1646d5ba739d2a1e63ee20d60574d9da8e upstream.
The PSL timebase synchronization is seemingly failing for
configuration not including VIRT_CPU_ACCOUNTING_NATIVE. The driver
shows the following trace in dmesg:
PSL: Timebase sync: giving up!
The PSL timebase register is actually syncing correctly, but the cxl
driver is not detecting it. Fix is to use the proper timebase-to-time
conversion.
Signed-off-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
Acked-by: Michael Neuling <mikey@neuling.org>
Reviewed-by: Matthew R. Ochs <mrochs@linux.vnet.ibm.com>
Acked-by: Ian Munsie <imunsie@au1.ibm.com>
Reviewed-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
Reviewed-by: Vaibhav Jain <vaibhav@linux.vnet.ibm.com>
commit c0992d0f54847d0d1d85c60fcaa054f175ab1ccd upstream.
Add support for Quectel UC20 and blacklist the QMI interface.
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
[johan: amend commit message ]
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 5deef5551c77e488922cc4bf4bc76df63be650d0 upstream.
This patch adds support for 0x1045 PID of Telit LE922.
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
commit 04fdbc825ffc02fb098964b92de802fff44e73fd upstream.
The MC74xx and EM74xx modules use different IDs by default, according
to the Lenovo EM7455 driver for Windows.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 013dd239d6220a4e0dfdf0d45a82c34f1fd73deb upstream.
New revision of Dell Wireless 5809e Gobi 4G HSPA+ Mobile Broadband Card
has new idProduct.
Bus 002 Device 006: ID 413c:81b3 Dell Computer Corp.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x413c Dell Computer Corp.
idProduct 0x81b3
bcdDevice 0.06
iManufacturer 1 Sierra Wireless, Incorporated
iProduct 2 Dell Wireless 5809e Gobi™ 4G HSPA+ Mobile Broadband Card
iSerial 3
bNumConfigurations 2
Signed-off-by: Patrik Halfar <patrik_halfar@halfarit.cz>
commit 3c4c615d70c8cbdc8ba8c79ed702640930652a79 upstream.
The Parrot NMEA GPS Flight Recorder is a USB composite device
consisting of hub, flash storage, and cp210x usb to serial chip.
It is an accessory to the mass-produced Parrot AR Drone 2.
The device emits standard NMEA messages which make the it compatible
with NMEA compatible software. It was tested using gpsd version 3.11-3
as an NMEA interpreter and using the official Parrot Flight Recorder.
Signed-off-by: Vittorio Alfieri <vittorio88@gmail.com>
commit d144dfea8af7108f613139623e63952ed7e69c0c upstream.
If we use USB ID pin as wakeup source, and there is a USB block
device on this USB OTG (ID) cable, the system will be deadlock
after system resume.
The root cause for this problem is: the workqueue ci_otg may try
to remove hcd before the driver resume has finished, and hcd will
disconnect the device on it, then, it will call device_release_driver,
and holds the device lock "dev->mutex", but it is never unlocked since
it waits workqueue writeback to run to flush the block information, but
the workqueue writeback is freezable, it is not thawed before driver
resume has finished.
When the driver (device: sd 0:0:0:0:) resume goes to dpm_complete, it
tries to get its device lock "dev->mutex", but it can't get it forever,
then the deadlock occurs. Below call stacks show the situation.
So, in order to fix this problem, we need to change workqueue ci_otg
as freezable, then the work item in this workqueue will be run after
driver's resume, this workqueue will not be blocked forever like above
case since the workqueue writeback has been thawed too.
Tested at: i.mx6qdl-sabresd and i.mx6sx-sdb.
[ 555.178869] kworker/u2:13 D c07de74c 0 826 2 0x00000000
[ 555.185310] Workqueue: ci_otg ci_otg_work
[ 555.189353] Backtrace:
[ 555.191849] [<c07de4fc>] (__schedule) from [<c07dec6c>] (schedule+0x48/0xa0)
[ 555.198912] r10:ee471ba0 r9:00000000 r8:00000000 r7:00000002 r6:ee470000 r5:ee471ba4
[ 555.206867] r4:ee470000
[ 555.209453] [<c07dec24>] (schedule) from [<c07e2fc4>] (schedule_timeout+0x15c/0x1e0)
[ 555.217212] r4:7fffffff r3:edc2b000
[ 555.220862] [<c07e2e68>] (schedule_timeout) from [<c07df6c8>] (wait_for_common+0x94/0x144)
[ 555.229140] r8:00000000 r7:00000002 r6:ee470000 r5:ee471ba4 r4:7fffffff
[ 555.235980] [<c07df634>] (wait_for_common) from [<c07df790>] (wait_for_completion+0x18/0x1c)
[ 555.244430] r10:00000001 r9:c0b5563c r8:c0042e48 r7:ef086000 r6:eea4372c r5:ef131b00
[ 555.252383] r4:00000000
[ 555.254970] [<c07df778>] (wait_for_completion) from [<c0043cb8>] (flush_work+0x19c/0x234)
[ 555.263177] [<c0043b1c>] (flush_work) from [<c0043fac>] (flush_delayed_work+0x48/0x4c)
[ 555.271106] r8:ed5b5000 r7:c0b38a3c r6:eea439cc r5:eea4372c r4:eea4372c
[ 555.277958] [<c0043f64>] (flush_delayed_work) from [<c00eae18>] (bdi_unregister+0x84/0xec)
[ 555.286236] r4:eea43520 r3:20000153
[ 555.289885] [<c00ead94>] (bdi_unregister) from [<c02c2154>] (blk_cleanup_queue+0x180/0x29c)
[ 555.298250] r5:eea43808 r4:eea43400
[ 555.301909] [<c02c1fd4>] (blk_cleanup_queue) from [<c0417914>] (__scsi_remove_device+0x48/0xb8)
[ 555.310623] r7:00000000 r6:20000153 r5:ededa950 r4:ededa800
[ 555.316403] [<c04178cc>] (__scsi_remove_device) from [<c0415e90>] (scsi_forget_host+0x64/0x68)
[ 555.325028] r5:ededa800 r4:ed5b5000
[ 555.328689] [<c0415e2c>] (scsi_forget_host) from [<c0409828>] (scsi_remove_host+0x78/0x104)
[ 555.337054] r5:ed5b5068 r4:ed5b5000
[ 555.340709] [<c04097b0>] (scsi_remove_host) from [<c04cdfcc>] (usb_stor_disconnect+0x50/0xb4)
[ 555.349247] r6:ed5b56e4 r5:ed5b5818 r4:ed5b5690 r3:00000008
[ 555.355025] [<c04cdf7c>] (usb_stor_disconnect) from [<c04b3bc8>] (usb_unbind_interface+0x78/0x25c)
[ 555.363997] r8:c13919b4 r7:edd3c000 r6:edd3c020 r5:ee551c68 r4:ee551c00 r3:c04cdf7c
[ 555.371892] [<c04b3b50>] (usb_unbind_interface) from [<c03dc248>] (__device_release_driver+0x8c/0x118)
[ 555.381213] r10:00000001 r9:edd90c00 r8:c13919b4 r7:ee551c68 r6:c0b546e0 r5:c0b5563c
[ 555.389167] r4:edd3c020
[ 555.391752] [<c03dc1bc>] (__device_release_driver) from [<c03dc2fc>] (device_release_driver+0x28/0x34)
[ 555.401071] r5:edd3c020 r4:edd3c054
[ 555.404721] [<c03dc2d4>] (device_release_driver) from [<c03db304>] (bus_remove_device+0xe0/0x110)
[ 555.413607] r5:edd3c020 r4:ef17f04c
[ 555.417253] [<c03db224>] (bus_remove_device) from [<c03d8128>] (device_del+0x114/0x21c)
[ 555.425270] r6:edd3c028 r5:edd3c020 r4:ee551c00 r3:00000000
[ 555.431045] [<c03d8014>] (device_del) from [<c04b1560>] (usb_disable_device+0xa4/0x1e8)
[ 555.439061] r8:edd3c000 r7:eded8000 r6:00000000 r5:00000001 r4:ee551c00
[ 555.445906] [<c04b14bc>] (usb_disable_device) from [<c04a8e54>] (usb_disconnect+0x74/0x224)
[ 555.454271] r9:edd90c00 r8:ee551000 r7:ee551c68 r6:ee551c9c r5:ee551c00 r4:00000001
[ 555.462156] [<c04a8de0>] (usb_disconnect) from [<c04a8fb8>] (usb_disconnect+0x1d8/0x224)
[ 555.470259] r10:00000001 r9:edd90000 r8:ee471e2c r7:ee551468 r6:ee55149c r5:ee551400
[ 555.478213] r4:00000001
[ 555.480797] [<c04a8de0>] (usb_disconnect) from [<c04ae5ec>] (usb_remove_hcd+0xa0/0x1ac)
[ 555.488813] r10:00000001 r9:ee471eb0 r8:00000000 r7:ef3d9500 r6:eded810c r5:eded80b0
[ 555.496765] r4:eded8000
[ 555.499351] [<c04ae54c>] (usb_remove_hcd) from [<c04d4158>] (host_stop+0x28/0x64)
[ 555.506847] r6:eeb50010 r5:eded8000 r4:eeb51010
[ 555.511563] [<c04d4130>] (host_stop) from [<c04d09b8>] (ci_otg_work+0xc4/0x124)
[ 555.518885] r6:00000001 r5:eeb50010 r4:eeb502a0 r3:c04d4130
[ 555.524665] [<c04d08f4>] (ci_otg_work) from [<c00454f0>] (process_one_work+0x194/0x420)
[ 555.532682] r6:ef086000 r5:eeb502a0 r4:edc44480
[ 555.537393] [<c004535c>] (process_one_work) from [<c00457b0>] (worker_thread+0x34/0x514)
[ 555.545496] r10:edc44480 r9:ef086000 r8:c0b1a100 r7:ef086034 r6:00000088 r5:edc44498
[ 555.553450] r4:ef086000
[ 555.556032] [<c004577c>] (worker_thread) from [<c004bab4>] (kthread+0xdc/0xf8)
[ 555.563268] r10:00000000 r9:00000000 r8:00000000 r7:c004577c r6:edc44480 r5:eddc15c0
[ 555.571221] r4:00000000
[ 555.573804] [<c004b9d8>] (kthread) from [<c000fef0>] (ret_from_fork+0x14/0x24)
[ 555.581040] r7:00000000 r6:00000000 r5:c004b9d8 r4:eddc15c0
[ 553.429383] sh D c07de74c 0 694 691 0x00000000
[ 553.435801] Backtrace:
[ 553.438295] [<c07de4fc>] (__schedule) from [<c07dec6c>] (schedule+0x48/0xa0)
[ 553.445358] r10:edd3c054 r9:edd3c078 r8:edddbd50 r7:edcbbc00 r6:c1377c34 r5:60000153
[ 553.453313] r4:eddda000
[ 553.455896] [<c07dec24>] (schedule) from [<c07deff8>] (schedule_preempt_disabled+0x10/0x14)
[ 553.464261] r4:edd3c058 r3:0000000a
[ 553.467910] [<c07defe8>] (schedule_preempt_disabled) from [<c07e0bbc>] (mutex_lock_nested+0x1a0/0x3e8)
[ 553.477254] [<c07e0a1c>] (mutex_lock_nested) from [<c03e927c>] (dpm_complete+0xc0/0x1b0)
[ 553.485358] r10:00561408 r9:edd3c054 r8:c0b4863c r7:edddbd90 r6:c0b485d8 r5:edd3c020
[ 553.493313] r4:edd3c0d0
[ 553.495896] [<c03e91bc>] (dpm_complete) from [<c03e9388>] (dpm_resume_end+0x1c/0x20)
[ 553.503652] r9:00000000 r8:c0b1a9d0 r7:c1334ec0 r6:c1334edc r5:00000003 r4:00000010
[ 553.511544] [<c03e936c>] (dpm_resume_end) from [<c0079894>] (suspend_devices_and_enter+0x158/0x504)
[ 553.520604] r4:00000000 r3:c1334efc
[ 553.524250] [<c007973c>] (suspend_devices_and_enter) from [<c0079e74>] (pm_suspend+0x234/0x2cc)
[ 553.532961] r10:00561408 r9:ed6b7300 r8:00000004 r7:c1334eec r6:00000000 r5:c1334ee8
[ 553.540914] r4:00000003
[ 553.543493] [<c0079c40>] (pm_suspend) from [<c0078a6c>] (state_store+0x6c/0xc0)
[ 555.703684] 7 locks held by kworker/u2:13/826:
[ 555.708140] #0: ("%s""ci_otg"){++++.+}, at: [<c0045484>] process_one_work+0x128/0x420
[ 555.716277] #1: ((&ci->work)){+.+.+.}, at: [<c0045484>] process_one_work+0x128/0x420
[ 555.724317] #2: (usb_bus_list_lock){+.+.+.}, at: [<c04ae5e4>] usb_remove_hcd+0x98/0x1ac
[ 555.732626] #3: (&dev->mutex){......}, at: [<c04a8e28>] usb_disconnect+0x48/0x224
[ 555.740403] #4: (&dev->mutex){......}, at: [<c04a8e28>] usb_disconnect+0x48/0x224
[ 555.748179] #5: (&dev->mutex){......}, at: [<c03dc2f4>] device_release_driver+0x20/0x34
[ 555.756487] #6: (&shost->scan_mutex){+.+.+.}, at: [<c04097d0>] scsi_remove_host+0x20/0x104
Cc: Jun Li <jun.li@nxp.com>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
commit 0ba4581c84cfb39fd527f6b3457f1c97f6356c04 upstream.
The 5 volt detect functionality broke in 3.14: the code reads IO register 0x70
again after it has already been cleared. Instead it should use the cached
irq_reg_0x70 value and the io_write to 0x71 to clear 0x70 can be dropped since
this has already been done.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit f16921275cc3c2442d0b95225785a601603b990f upstream.
While testing audio with pxa2xx-ac97, underrun were happening while the
user application was correctly feeding the music. Debug proved that the
cyclic transfer is not cyclic, ie. the last descriptor did not loop on
the first.
Another issue is that the descriptor length was always set to 8192,
because of an trivial operator issue.
This was tested on a pxa27x platform.
Fixes: a57e16cf0333 ("dmaengine: pxa: add pxa dmaengine driver")
Reported-by: Vasily Khoruzhick <anarsoul@gmail.com>
Tested-by: Vasily Khoruzhick <anarsoul@gmail.com>
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit 018361767a21fb2d5ebd3ac182c04baf8a8b4e08 upstream.
The RB532 platform specific irq_to_gpio() implementation has been
removed with commit 832f5dacfa0b ("MIPS: Remove all the uses of
custom gpio.h"). Now the platform uses the generic stub which causes
the following error:
pata-rb532-cf pata-rb532-cf: no GPIO found for irq149
pata-rb532-cf: probe of pata-rb532-cf failed with error -2
Drop the irq_to_gpio() call and get the GPIO number from platform
data instead. After this change, the driver works again:
scsi host0: pata-rb532-cf
ata1: PATA max PIO4 irq 149
ata1.00: CFA: CF 1GB, 20080820, max MWDMA4
ata1.00: 1989792 sectors, multi 0: LBA
ata1.00: configured for PIO4
scsi 0:0:0:0: Direct-Access ATA CF 1GB 0820 PQ: 0\
ANSI: 5
sd 0:0:0:0: [sda] 1989792 512-byte logical blocks: (1.01 GB/971 MiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't\
support DPO or FUA
sda: sda1 sda2
sd 0:0:0:0: [sda] Attached SCSI disk
Fixes: 832f5dacfa0b ("MIPS: Remove all the uses of custom gpio.h")
Cc: Alban Bedel <albeu@free.fr>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
commit dc8b4afc4a04fac8ee55a19b59f2356a25e7e778 upstream.
The HPCP bit is set by bioses for on-board sata ports either because
they think sata is hotplug capable in general or to allow Windows
to display a "device eject" icon on ports which are routed to an
external connector bracket.
However in Redhat Bugzilla #1310682, users report that with kernel 4.4,
where this bit test first appeared, a lot of partitions on sata drives
are now mounted automatically.
This patch should fix redhat and a lot of other distros which
unconditionally automount all devices which have the "removable"
bit set.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
Fixes: 8a3e33cf92c7 ("ata: ahci: find eSATA ports and flag them as removable" changes userspace behavior)
Link: http://lkml.kernel.org/g/56CF35FA.1070500@redhat.com
commit f5bdd66c705484b4bc77eb914be15c1b7881fae7 upstream.
This patch complements the list of device IDs previously
added for lewisburg sata.
Signed-off-by: Alexandra Yates <alexandra.yates@linux.intel.com>
commit 287e6611ab1eac76c2c5ebf6e345e04c80ca9c61 upstream.
As reported by Soohoon Lee, the HDIO_GET_32BIT ioctl does not
work correctly in compat mode with libata.
I have investigated the issue further and found multiple problems
that all appeared with the same commit that originally introduced
HDIO_GET_32BIT handling in libata back in linux-2.6.8 and presumably
also linux-2.4, as the code uses "copy_to_user(arg, &val, 1)" to copy
a 'long' variable containing either 0 or 1 to user space.
The problems with this are:
* On big-endian machines, this will always write a zero because it
stores the wrong byte into user space.
* In compat mode, the upper three bytes of the variable are updated
by the compat_hdio_ioctl() function, but they now contain
uninitialized stack data.
* The hdparm tool calling this ioctl uses a 'static long' variable
to store the result. This means at least the upper bytes are
initialized to zero, but calling another ioctl like HDIO_GET_MULTCOUNT
would fill them with data that remains stale when the low byte
is overwritten. Fortunately libata doesn't implement any of the
affected ioctl commands, so this would only happen when we query
both an IDE and an ATA device in the same command such as
"hdparm -N -c /dev/hda /dev/sda"
* The libata code for unknown reasons started using ATA_IOC_GET_IO32
and ATA_IOC_SET_IO32 as aliases for HDIO_GET_32BIT and HDIO_SET_32BIT,
while the ioctl commands that were added later use the normal
HDIO_* names. This is harmless but rather confusing.
This addresses all four issues by changing the code to use put_user()
on an 'unsigned long' variable in HDIO_GET_32BIT, like the IDE subsystem
does, and by clarifying the names of the ioctl commands.
Reported-by: Soohoon Lee <Soohoon.Lee@f5.com>
Tested-by: Soohoon Lee <Soohoon.Lee@f5.com>
commit 0b39c531cfa12dad54eac238c2e303b994df1ef7 upstream.
In amdgpu_connector_hotplug(), we need to start DP link
training only after we have received DPCD. The function
amdgpu_atombios_dp_get_dpcd() returns non-zero value only
when an error condition is met, otherwise returns zero.
So in case the function encounters an error, we need to
skip rest of the code and return from amdgpu_connector_hotplug()
immediately. Only when we are successfull in reading DPCD
pin, we should carry on with turning-on the monitor.
Signed-off-by: Arindam Nath <arindam.nath@amd.com>
commit 9cac537332f5502c103415b25609548c276a09f8 upstream.
Select between me and pfp properly.
Signed-off-by: Chunming Zhou <David1.Zhou@amd.com>
commit feebe91aa9a9d99d9ec157612a614fadb79beb99 upstream.
We never ported that back to CIK, so we could run into VM faults here.
Signed-off-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
commit eda1d1cf8d18383f19cd2b752f786120efa4768f upstream.
On CI, we need to see if the number of crtcs changes to determine
whether or not we need to upload the mclk table again. In practice
we don't currently upload the mclk table again after the initial load.
The only reason you would would be to add new states, e.g., for
arbitrary mclk setting which is not currently supported.
Acked-by: Jordan Lazare <Jordan.Lazare@amd.com>
Acked-by: Christian König <christian.koenig@amd.com>
commit 5e031d9fe8b0741f11d49667dfc3ebf5454121fd upstream.
commit 2d02b8bdba322b527c5f5168ce1ca10c2d982a78 upstream.
During DRAM initialization on certain ASpeed devices, an incorrect
bit (bit 10) was checked in the "SDRAM Bus Width Status" register
to determine DRAM width.
Query bit 6 instead in accordance with the Aspeed AST2050 datasheet v1.05.
Signed-off-by: Timothy Pearson <tpearson@raptorengineeringinc.com>
commit 8a9ebe717a133ba7bc90b06047f43cc6b8bcb8b3 upstream.
In a couple places we are not converting to/from the Linux
block layer 512 bytes sectors.
1.
The request queue values and what we do are a mismatch of
things:
max_discard_sectors - This is in linux block layer 512 byte
sectors. We are just copying this to max_unmap_lba_count.
discard_granularity - This is in bytes. We are converting it
to Linux block layer 512 byte sectors.
discard_alignment - This is in bytes. We are just copying
this over.
The problem is that the core LIO code exports these values in
spc_emulate_evpd_b0 and we use them to test request arguments
in sbc_execute_unmap, but we never convert to the block size
we export to the initiator. If we are not using 512 byte sectors
then we are exporting the wrong values or are checks are off.
And, for the discard_alignment/bytes case we are just plain messed
up.
2.
blkdev_issue_discard's start and number of sector arguments
are supposed to be in linux block layer 512 byte sectors. We are
currently passing in the values we get from the initiator which
might be based on some other sector size.
There is a similar problem in iblock_execute_write_same where
the bio functions want values in 512 byte sectors but we are
passing in what we got from the initiator.
Signed-off-by: Mike Christie <mchristi@redhat.com>
[ kamal: backport to 4.4-stable: no unmap_zeroes_data ]
Signed-off-by: Kamal Mostafa <kamal@canonical.com>
commit e6a8c9b337eed56eb481e1b4dd2180c25a1e5310 upstream.
In the PCI hotplug path of the Intel IOMMU driver, replace
the usage of the BUS_NOTIFY_DEL_DEVICE notifier, which is
executed before the driver is unbound from the device, with
BUS_NOTIFY_REMOVED_DEVICE, which runs after that.
This fixes a kernel BUG being triggered in the VT-d code
when the device driver tries to unmap DMA buffers and the
VT-d driver already destroyed all mappings.
Reported-by: Stefani Seibold <stefani@seibold.net>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit 38e45d02ea9f194b89d6bf41e52ccafc8e2c2b47 upstream.
The setup code for the performance counters in the AMD IOMMU driver
tests whether the counters can be written. It tests to setup a counter
for device 00:00.0, which fails on systems where this particular device
is not covered by the IOMMU.
Fix this by not relying on device 00:00.0 but only on the IOMMU being
present.
Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com>
commit 358875fd52ab8f00f66328cbf1a1d2486f265829 upstream.
The AMD Family 15h Models 30h-3Fh (Kaveri) BIOS and Kernel Developer's
Guide omitted part of the BIOS IOMMU L2 register setup specification.
Without this setup the IOMMU L2 does not fully respect write permissions
when handling an ATS translation request.
The IOMMU L2 will set PTE dirty bit when handling an ATS translation with
write permission request, even when PTE RW bit is clear. This may occur by
direct translation (which would cause a PPR) or by prefetch request from
the ATC.
This is observed in practice when the IOMMU L2 modifies a PTE which maps a
pagecache page. The ext4 filesystem driver BUGs when asked to writeback
these (non-modified) pages.
Enable ATS write permission check in the Kaveri IOMMU L2 if BIOS has not.
Signed-off-by: Jay Cornwall <jay@jcornwall.me>
commit 8160c4e455820d5008a1116d2dca35f0363bb062 upstream.
Calling return copy_to_user(...) in an ioctl will not
do the right thing if there's a pagefault:
copy_to_user returns the number of bytes not copied
in this case.
Fix up vfio to do
return copy_to_user(...)) ?
-EFAULT : 0;
everywhere.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
commit a1e533ec07d583d01349ef13c0c965b8633e1b91 upstream.
Since commit 27a4c827c34ac4256a190cc9d24607f953c1c459
fbcon: use the cursor blink interval provided by vt
two attempts have been made at fixing a possible hang caused by
cursor_timer_handler. That function registers a timer to be triggered at
"jiffies + fbcon_ops.cur_blink_jiffies".
A new case had been encountered during initialisation of clcd-pl11x:
fbcon_fb_registered
do_fbcon_takeover
-> do_register_con_driver
fbcon_startup
(A) add_cursor_timer (with cur_blink_jiffies = 0)
-> do_bind_con_driver
visual_init
fbcon_init
(B) cur_blink_jiffies = msecs_to_jiffies(vc->vc_cur_blink_ms);
If we take an softirq anywhere between A and B (and we do),
cursor_timer_handler executes indefinitely.
Instead of patching all possible paths that lead to this case one at a
time, fix the issue at the source and initialise cur_blink_jiffies to
200ms when allocating fbcon_ops. This was its default value before
aforesaid commit. fbcon_cursor or fbcon_init will refine this value
downstream.
Signed-off-by: Jean-Philippe Brucker <jean-philippe.brucker@arm.com>
Tested-by: Scot Doyle <lkml14@scotdoyle.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
commit 79e3f4a853ed161cd4c06d84b50beebf961a47c6 upstream.
Commit cbce7900598c ("PCI: designware: Make driver arch-agnostic") changed
the host bridge sysdata pointer from the ARM pci_sys_data to the DesignWare
pcie_port structure, and changed pcie-designware.c to reflect that. But it
did not change the corresponding code in pci-keystone-dw.c, so it caused
crashes on Keystone:
Unable to handle kernel NULL pointer dereference at virtual address 00000030
pgd = c0003000
[00000030] *pgd=80000800004003, *pmd=00000000
Internal error: Oops: 206 [#1] PREEMPT SMP ARM
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.2-00139-gb74f926 #2
Hardware name: Keystone
PC is at ks_dw_pcie_msi_irq_unmask+0x24/0x58
Change pci-keystone-dw.c to expect sysdata to be the struct pcie_port
pointer.
[bhelgaas: changelog]
Fixes: cbce7900598c ("PCI: designware: Make driver arch-agnostic")
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
CC: Zhou Wang <wangzhou1@hisilicon.com>
commit a187f17f0e15a046aa5d7263b35df55230d92779 upstream.
Signed-off-by: Oded Gabbay <oded.gabbay@gmail.com>
commit 0378ba4899d5fbd8494ed6580cbc81d7b44dbac6 upstream.
CONFIG_ARCH_SHMOBILE is not only enabled for Renesas ARM platforms
(which are DT based and multi-platform), but also on a select set of
Renesas SuperH platforms (SH7722/SH7723/SH7724/SH7343/SH7366). Hence
since commit 0ba58de231066e47 ("drivers: sh: Get rid of
CONFIG_ARCH_SHMOBILE_MULTI"), the legacy clock domain is no longer
installed on these SuperH platforms, and module clocks may not be
enabled when needed, leading to driver failures.
To fix this, add an additional check for CONFIG_OF.
Fixes: 0ba58de231066e47 ("drivers: sh: Get rid of CONFIG_ARCH_SHMOBILE_MULTI").
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
commit 5e56276e7555b34550d51459a801ff75eca8b907 upstream.
The firmware can perform a scheduled scan with not matchsets passed,
but it can't send notification that results were found. Since the
userspace then cannot know when we got new results and the firmware
wouldn't trigger a wake in case we are sleeping, it's better not to
allow scans without matchsets.
This fixes https://bugzilla.kernel.org/show_bug.cgi?id=110831
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
commit 006bda75d81fd27a583a3b310e9444fea2aa6ef2 upstream.
Update and fix some 7265 PCI IDs entries.
Signed-off-by: Oren Givon <oren.givon@intel.com>
commit 62d7476d958ce06d7a10b02bdb30006870286fe2 upstream.
8000 device family has a new debug engine that needs to be
configured differently than 7000's.
The debug engine's DMA works in chunks of memory and the
size of the buffer really means the start of the last
chunk. Since one chunk is 256-byte long, we should
configure the device to write to buffer_size - 256.
This fixes a situation were the device would write to
memory it is not allowed to access.
commit a1cdb1c59c8c203de2731fc6910598ed19c97e41 upstream.
My commit below introduced a mutex in the transport to
prevent concurrent operations. To do so, it added a flag
(is_down) to make sure the transport is in the right state.
This uncoverred an bug that didn't cause any harm until
now: iwldvm calls stop_device and then starts the firmware
without calling start_hw in between. While this flow is
fine from the device configuration point of view (register,
etc...), it is now forbidden by the new is_down flag.
This led to this error to appear:
iwlwifi 0000:05:00.0: Can't start_fw since the HW hasn't been started
and the suspend would fail.
This fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=109591
Reported-by: Bogdan Bogush <bogdan.s.bogush@gmail.com>
Fixes=fa9f3281cbb1 ("iwlwifi: pcie: lock start_hw / start_fw / stop_device")
