commit e3e84cda321703b123f36488f50700f371bc7230 upstream.
We can still see the error reported in
https://patchwork.kernel.org/patch/2338981/
when using fileio backed by a block device.
I'm assuming this will get us past that error (from sbc_parse_cdb),
and also assuming it's OK to have our max_sectors be larger than
the block's queue max hw sectors?
Reported-by: Eric Harney <eharney@redhat.com>
Signed-off-by: Andy Grover <agrover@redhat.com>
commit e9ced8e040ebe40e9953db90acbe7d0b58702ebb upstream.
When UMS was deprecated it removed support for nomodeset commandline
we really want this in distro land so we can debug stuff, everyone
should fallback to vesa correctly.
v2: oops -1 isn't used anymore, restore original behaviour
-1 is default, so we can boot with nomodeset on the command line,
then use radeon.modeset=1 to override it for debugging later.
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
commit fefaedcfb82d2e57c2320acf60604ab03b750cc0 upstream.
The "boxes" parameter points into userspace memory. It should be verified
like any other operation against user memory.
commit 6368087e851e697679af059b4247aca33a69cef3 upstream.
When a 32 bit version of ipmitool is used on a 64 bit kernel, the
ipmi_devintf code fails to correctly acquire ipmi_mutex. This results in
incomplete data being retrieved in some cases, or other possible failures.
Add a wrapper around compat_ipmi_ioctl() to take ipmi_mutex to fix this.
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
commit a5f2b3d6a738e7d4180012fe7b541172f8c8dcea upstream.
When calling memcpy, read_data and write_data need additional 2 bytes.
write_data:
for checking: "if (size > IPMI_MAX_MSG_LENGTH)"
for operating: "memcpy(bt->write_data + 3, data + 1, size - 1)"
read_data:
for checking: "if (msg_len < 3 || msg_len > IPMI_MAX_MSG_LENGTH)"
for operating: "memcpy(data + 2, bt->read_data + 4, msg_len - 2)"
Signed-off-by: Chen Gang <gang.chen@asianux.com>
commit 28fe5c825f8e15744d04c7c1b8df197950923ecd upstream.
The EC driver works abnormally with IBF flag always set.
IBF means "The host has written a byte of data to the command
or data port, but the embedded controller has not yet read it".
If IBF is set in the EC status and not cleared, this will cause
all subsequent EC requests to fail with a timeout error.
Change the EC driver so that it doesn't refuse to restart a
transaction if IBF is set in the status. Also increase the
number of transaction restarts to 5, as it turns out that 2
is not sufficient in some cases.
This bug happens on several different machines (Asus V1S,
Dell Latitude E6530, Samsung R719, Acer Aspire 5930G,
Sony Vaio SR19VN and others).
[rjw: Changelog]
References: https://bugzilla.kernel.org/show_bug.cgi?id=14733
References: https://bugzilla.kernel.org/show_bug.cgi?id=15560
References: https://bugzilla.kernel.org/show_bug.cgi?id=15946
References: https://bugzilla.kernel.org/show_bug.cgi?id=42945
References: https://bugzilla.kernel.org/show_bug.cgi?id=48221
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
commit d2bdbee0d91a5d3ba2e439ce889e20bfe6fd4f1b upstream.
This patch fixes a regression bug introduced in v3.9-rc1 where if the
underlying struct block_device for a IBLOCK backend is configured with
WCE=1 + DPOFUA=1 settings, the rw = WRITE assignment no longer occurs
in iblock_execute_rw(), and rw = 0 is passed to iblock_submit_bios()
in effect causing a READ bio operation to occur.
The offending commit is:
commit d0c8b259f8970d39354c1966853363345d401330
Author: Nicholas Bellinger <nab@linux-iscsi.org>
Date: Tue Jan 29 22:10:06 2013 -0800
target/iblock: Use backend REQ_FLUSH hint for WriteCacheEnabled status
Note the WCE=1 + DPOFUA=0, WCE=0 + DPOFUA=1, and WCE=0 + DPOFUA=0 cases
are not affected by this regression bug.
Reported-by: Chris Boot <bootc@bootc.net>
Tested-by: Chris Boot <bootc@bootc.net>
Reported-by: Hannes Reinecke <hare@suse.de>
commit ccf5ae83a6cf3d9cfe9a7038bfe7cd38ab03d5e1 upstream.
It is possible for one thread to to take se_sess->sess_cmd_lock in
core_tmr_abort_task() before taking a reference count on
se_cmd->cmd_kref, while another thread in target_put_sess_cmd() drops
se_cmd->cmd_kref before taking se_sess->sess_cmd_lock.
This introduces kref_put_spinlock_irqsave() and uses it in
target_put_sess_cmd() to close the race window.
Signed-off-by: Joern Engel <joern@logfs.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 3eccfdb01da58fbd0f789ae6ca61cee3769e26de upstream.
Fix two issues in OOO commands processing done at iscsit_attach_ooo_cmdsn.
Handle command serial numbers wrap around by using iscsi_sna_lt and not regular comparisson.
The routine iterates until it finds an entry whose serial number is greater than the serial number of
the new one, thus the new entry should be inserted before that entry and not after.
Signed-off-by: Shlomo Pongratz <shlomop@mellanox.com>
commit ca182aee389f8026401510f4c63841cb02c820e8 upstream.
The ffmpeg benchmark in the phoronix test suite has threads on
multiple cores that rely on the progress on of threads on other cores
and ping pong back and forth fast enough to make the core appear less
busy than it "should" be. If the core has been at minimum p-state for
a while bump the pstate up to kick the core to see if it is in this
ping pong state. If the core is truly idle the p-state will be
reduced at the next sample time. If the core makes more progress it
will send more work to the thread bringing both threads out of the
ping pong scenario and the p-state will be selected normally.
This fixes a performance regression of approximately 30%
Signed-off-by: Dirk Brandewie <dirk.j.brandewie@intel.com>
commit d8f469e9cff3bc4a6317d923e9506be046aa7bdc upstream.
There are two ways that the maximum p-state can be clamped, via a
policy change and via the sysfs file.
The acpi-thermal driver adjusts the p-state policy in response to
thermal events. These changes override the users settings at the
moment.
Use the lowest of the two requested values this ensures that we will
not exceed the requested pstate from either mechanism.
Reported-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
calculations
commit 1abc4b20b85b42e8573957e54b193385cf48b0d6 upstream.
Idle time is taken into account in the APERF/MPERF ratio calculation
there is no reason for the driver to track it seperately. This
reduces the work in the driver and makes the code more readable.
Removal of the tracking of sample duration removes the possibility of
the divide by zero exception when the duration is sub 1us
References: https://bugzilla.kernel.org/show_bug.cgi?id=56691
Reported-by: Mike Lothian <mike@fireburn.co.uk>
commit 35623715818dfa720cccf99cd280dcbb4b78da23 upstream.
Fix to return -ENODEV in the chip not found error handling
case instead of 0, as done elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Cc: Jingoo Han <jg1.han@samsung.com>
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
commit 7c689e63a847316c1b2500f86891b0a574ce7e69 upstream.
With an automatic after split-brain recovery policy of
"after-sb-1pri call-pri-lost-after-sb",
when trying to drbd_set_role() to R_SECONDARY,
we run into a deadlock.
This was first recognized and supposedly fixed by
2009-06-10 "Fixed a deadlock when using automatic split brain recovery when both nodes are"
replacing drbd_set_role() with drbd_change_state() in that code-path,
but the first hunk of that patch forgets to remove the drbd_set_role().
We apparently only ever tested the "two primaries" case.
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
commit 94ad0a101415978be04945b2787be1e8e8a874db upstream.
We forgot to free the disk_conf,
so for each attach/detach cycle we leaked 336 bytes.
commit ef57f9e6bb9278720c8a5278728f252ab85d7ac6 upstream.
commit 60403f7a4d9368d187f79cba5e4672d01df37574 upstream.
A race condition exists when registering the first watchdog device.
Sequence of events:
- watchdog_register_device calls watchdog_dev_register
- watchdog_dev_register creates the watchdog misc device by calling
misc_register.
At that time, the matching character device (/dev/watchdog0) does not yet
exist, and old_wdd is not set either.
- Userspace gets an event and opens /dev/watchdog
- watchdog_open is called and sets wdd = old_wdd, which is still NULL,
and tries to dereference it. This causes the kernel to panic.
Seen with systemd trying to open /dev/watchdog immediately after
it was created.
Reported-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
commit 5c1ef59168c485318e40ba485c1eba57d81d0faa upstream.
pdc_desc_get() is called from pd_prep_slave_sg, and the function is
called from interrupt context(e.g. Uart driver "pch_uart.c").
In fact, I saw kernel error message.
So, GFP_ATOMIC must be used not GFP_NOIO.
Signed-off-by: Tomoya MORINAGA <tomoya.rohm@gmail.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
[ Upstream commit 233c7df0821c4190e2d3f4be0f2ca0ab40a5ed8c ]
Currently, if macvlan in passthru mode is created and data are rxed and
you remove this device, following panic happens:
NULL pointer dereference at 0000000000000198
IP: [<ffffffffa0196058>] macvlan_handle_frame+0x153/0x1f7 [macvlan]
I'm using following script to trigger this:
<script>
while [ 1 ]
do
ip link add link e1 name macvtap0 type macvtap mode passthru
ip link set e1 up
ip link set macvtap0 up
IFINDEX=`ip link |grep macvtap0 | cut -f 1 -d ':'`
cat /dev/tap$IFINDEX >/dev/null &
ip link del dev macvtap0
done
</script>
I run this script while "ping -f" is running on another machine to send
packets to e1 rx.
Reason of the panic is that list_first_entry() is blindly called in
macvlan_handle_frame() even if the list was empty. vlan is set to
incorrect pointer which leads to the crash.
I'm fixing this by protecting port->vlans list by rcu and by preventing
from getting incorrect pointer in case the list is empty.
Introduced by: commit eb06acdc85585f2 "macvlan: Introduce 'passthru' mode to takeover the underlying device"
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 4b264a1676e70dc656ba53a8cac690f2d4b65f4e ]
The driver wrongly claimed I/O ports at an address returned by pci_iomap() --
even if it was passed an MMIO address. Fix this by claiming/releasing all PCI
resources in the PCI driver's probe()/remove() methods instead and get rid of
'must_free_region' flag weirdness (why would Cardbus claim anything for us?).
[ Upstream commit c81400be716aa4c76f6ebf339ba94358dbbf6da6 ]
When unloading the driver that drives an EISA board, a message similar to the
following one is displayed:
Trying to free nonexistent resource <0000000000013000-000000000001301f>
Then an user is unable to reload the driver because the resource it requested in
the previous load hasn't been freed. This happens most probably due to a typo in
vortex_eisa_remove() which calls release_region() with 'dev->base_addr' instead
of 'edev->base_addr'...
Reported-by: Matthew Whitehead <tedheadster@gmail.com>
Tested-by: Matthew Whitehead <tedheadster@gmail.com>
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit c5060cec6ba27ad3f0e7facfdf05d2f18e3e3010 ]
There is bug in the receive path of the asix driver at the time a
packet is received larger than MTU size and DF bit set:
BUG: unable to handle kernel paging request at 0000004000000001
IP: [<ffffffff8126f65b>] skb_release_head_state+0x2d/0xd2
Call Trace:
<IRQ>
[<ffffffff8126f86d>] ? skb_release_all+0x9/0x1e
[<ffffffff8126f8ad>] ? __kfree_skb+0x9/0x6f
[<ffffffffa00b4200>] ? asix_rx_fixup_internal+0xff/0x1ae [asix]
[<ffffffffa00fb3dc>] ? usbnet_bh+0x4f/0x226 [usbnet]
It is easily reproducable by setting an MTU of 512 e. g. and sending
something like
ping -s 1472 -c 1 -M do $SELF
from another box.
And this is because the rx->ax_skb is freed on error, but rx->ax_skb
is not reset, and the size is not reset to zero in this case.
And since the skb is added again to the usbnet->done skb queue it is
accessing already freed memory, resulting in the BUG when freeing a
2nd time. I therefore think the value 0x0000004000000001 show in the
trace is more or less random data.
Signed-off-by: Holger Eitzenberger <holger@eitzenberger.org>
[ Upstream commit 3b54912f9cd167641b91d4a697bd742f70e534fe ]
The venerable 3c509 driver only sets its device parent in one case, the ISAPnP one.
It does this with the SET_NETDEV_DEV function. It should register with the device
hierarchy in two additional cases: standard (non-PnP) ISA and EISA.
- Currently they appear here:
/sys/devices/virtual/net/eth0 (standard ISA)
/sys/devices/virtual/net/eth1 (EISA)
- Rather, they should instead be here:
/sys/devices/isa/3c509.0/net/eth0 (standard ISA)
/sys/devices/pci0000:00/0000:00:07.0/00:04/net/eth1 (EISA)
Tested on ISA and EISA boards.
Signed-off-by: Matthew Whitehead <tedheadster@gmail.com>
[ Upstream commit 3811ae76bc84e5dc1a670ae10695f046b310bee1 ]
We forget to release the reference of tun device in tun_recvmsg.
bug introduced in commit 54f968d6efdbf7dec36faa44fc11f01b0e4d1990
(tuntap: move socket to tun_file)
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Acked-by: Jason Wang <jasowang@redhat.com>
[ Upstream commit 89cc80a44b7c320e08599cb86f6aef0ead8986a1 ]
efx_mcdi_get_board_cfg() uses a buffer for the firmware response that
is only large enough to hold subtypes for the originally defined set
of NVRAM partitions. Longer responses are truncated, and we may read
off the end of the buffer when copying out subtypes for additional
partitions. In particular, this can result in the MTD partition for
an FPGA bitfile being named e.g. 'eth5 sfc_fpga:00' when it should be
'eth5 sfc_fpga:01'. This means the firmware update tool (sfupdate)
can't tell which bitfile should be written to the partition.
Correct the response buffer size.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
commit 1ffc5289bfcf7f4c4e4213240bb4be68c48ce603 upstream.
Similar to
commit 88afe715dd5469bc24ca7a19ac62dd3c241cab48
Author: Chris Wilson <chris@chris-wilson.co.uk>
Date: Sun Dec 16 12:15:41 2012 +0000
drm/i915: Clear the stolen fb before enabling
but on the resume path.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=57191
Reported-and-tested-by: Nikolay Amiantov <nikoamia@gmail.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit a9b054e8ab06504c2afa0e307ee78d3778993a1d upstream.
Since we know that locking is broken in that case and it's more
important to not flood the dmesg with random gunk.
Reported-and-tested-by: Borislav Petkov <bp@suse.de>
References: http://lkml.kernel.org/r/20130502000206.GH15623@pd.tnic
Cc: Dave Airlie <airlied@gmail.com>
commit 3a359f0b21ab218c1bf7a6a1b638b6fd143d0b99 upstream.
In
commit 9e8944ab564f2e3dde90a518cd32048c58918608
Date: Thu Nov 15 11:32:17 2012 +0000
drm: Introduce an iterator over holes in the drm_mm range manager
helpers and iterators for hole handling have been introduced with some
debug BUG_ONs sprinkled over. Unfortunately this broke the mm dumper
which unconditionally tried to compute the size of the very first
hole.
While at it unify the code a bit with the hole dumping in the loop.
v2: Extract a hole dump helper.
Reported-by: Christopher Harvey <charvey@matrox.com>
Cc: Christopher Harvey <charvey@matrox.com>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Acked-by: Dave Airlie <airlied@redhat.com>
commit 9f1d036648c1c5ed81b0e98d7a06d55df972701e upstream.
Higher bits of the base address of framebuffers weren't being
programmed properly. This caused framebuffers that didn't happen to be
allocated at a low enough address to not be displayed properly.
Signed-off-by: Christopher Harvey <charvey@matrox.com>
Signed-off-by: Mathieu Larouche <mathieu.larouche@matrox.com>
Acked-by: Julia Lemire <jlemire@matrox.com>
Tested-by: Julia Lemire <jlemire@matrox.com>
commit fb70a6690875315a3a1454e52fa339441ee7612b upstream.
The original line,
WREG_DAC(MGA1064_PIX_CLK_CTL_CLK_DIS, tmp);
wrote tmp into MGA1064_PIX_CLK_CTL_CLK_DIS, where
MGA1064_PIX_CLK_CTL_CLK_DIS is an offset into
MGA1064_PIX_CLK_CTL. Change the line to write properly into
MGA1064_PIX_CLK_CTL. There were other chunks of code nearby that use
the same pattern (but work correctly), so this patch updates them all
to use this new (slightly more efficient) write pattern. The WREG_DAC
macro was causing the DAC_INDEX register to be set to the same value
twice. WREG8(DAC_DATA, foo) takes advantage of the fact that DAC_INDEX
is already at the value we want.
Acked-by: Mathieu Larouche <mathieu.larouche@matrox.com>
commit dd9c46408fdc07098333655ff27edf8cac8d9fcf upstream.
Jake reported that since commit 1672c0e31917f49d31d30d79067103432bc20cc7
"mac80211: start auth/assoc timeout on frame status", he is unable to
connect to his AP, which is configured to use passive channel.
After switch to passive channel 4965 firmware drops any TX packet until
it receives beacon. Before commit 1672c0e3 we waited on channel and
retransmit packet after 200ms, that makes we receive beacon on the
meantime and association process succeed. New mac80211 behaviour cause
that any ASSOC frame fail immediately on iwl4965 and we can not
associate.
This patch restore old mac80211 behaviour for iwl4965, by removing
IEEE80211_HW_REPORTS_TX_ACK_STATUS feature. This feature will be
added again to iwl4965 driver, when different, more complex
workaround for this firmware issue, will be added to the driver.
Bisected-by: Jake Edge <jake@lwn.net>
Reported-and-tested-by: Jake Edge <jake@lwn.net>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 73b82bf0bfbf58e6ff328d3726934370585f6e78 upstream.
Add handling of rx descriptor underflow. This fixes a fault that could
happen on slow machines, where data is received faster than the CPU can
handle. In such a case the device will use up all rx descriptors and
refuse to send any more data before confirming that it is ok. This
patch enables necessary interrupt to discover such a situation and will
handle them by dropping everything in the ring buffer.
Reviewed-by: Michael Buesch <m@bues.ch>
Signed-off-by: Thommy Jakobsson <thommyj@gmail.com>
commit c539914dcd9a68c63305e055b14115a6a19578a8 upstream.
The Tilera hypervisor shipped in releases up through MDE 4.1 launches
the client operating system (i.e. Linux) at privilege level 1 (PL1).
Starting with MDE 4.2, as part of the work to enable KVM, the
Tilera hypervisor launches Linux at PL2 instead.
This commit makes the KERNEL_PL option default to 2 for tilegx, while
still saying at 1 for tilepro, which doesn't have an updated hypervisor.
It also explains how and when you might want to choose another value.
In addition, we change a small buglet in the on-chip Ethernet driver,
where we were failing to use the KERNEL_PL constant in an API call.
To make the transition cleaner, this change also provides the updated
hv_init() API for the new hypervisor that supports announcing Linux's
compiled-in PL, so the hypervisor can generate a suitable error in the
case of a mismatched hypervisor and Linux binary.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
commit ccd384b10420ac81ba3fb9b0a7d18272c7173552 upstream.
A small bug in this code was causing the ALLMULTI filter to be set
when in fact we were just wanting to program a selective multicast list
to the hardware.
Fix that bug and remove a redundant if condition in the code that
follows.
This fixes wakeup behaviour when multicast WOL is enabled. Previously,
all multicast packets would wake up the system. Now, only those that the
host intended to receive trigger wakeups.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Acked-by: Bing Zhao <bzhao@marvell.com>
commit f16fdc9d2dc1e5b270e9a08377587e831e0d36ac upstream.
After unregister_netdevice() call the request is queued and
reg_state is changed to NETREG_UNREGISTERING.
As we check for NETREG_UNREGISTERED state, free_netdev() never
gets executed causing memory leak.
Initialize "dev->destructor" to free_netdev() to free device
data after unregistration.
Reported-by: Daniel Drake <dsd@laptop.org>
Tested-by: Daniel Drake <dsd@laptop.org>
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
commit 48795424acff7215d5eac0b52793a2c1eb3a6283 upstream.
When the XO-4 with 8787 wireless is woken up due to wake-on-WLAN
mwifiex is often flooded with "not allowed while suspended" messages
and the interface is unusable.
[ 202.171609] int: sdio_ireg = 0x1
[ 202.180700] info: mwifiex_process_hs_config: auto cancelling host
sleep since there is interrupt from the firmware
[ 202.201880] event: wakeup device...
[ 202.211452] event: hs_deactivated
[ 202.514638] info: --- Rx: Data packet ---
[ 202.514753] data: 4294957544 BSS(0-0): Data <= kernel
[ 202.514825] PREP_CMD: device in suspended state
[ 202.514839] data: dequeuing the packet ec7248c0 ec4869c0
[ 202.514886] mwifiex_write_data_sync: not allowed while suspended
[ 202.514886] host_to_card, write iomem (1) failed: -1
[ 202.514917] mwifiex_write_data_sync: not allowed while suspended
[ 202.514936] host_to_card, write iomem (2) failed: -1
[ 202.514949] mwifiex_write_data_sync: not allowed while suspended
[ 202.514965] host_to_card, write iomem (3) failed: -1
[ 202.514976] mwifiex_write_data_async failed: 0xFFFFFFFF
This can be readily reproduced when putting the XO-4 in a loop where
it goes to sleep due to inactivity, but then wakes up due to an
incoming ping. The error is hit within an hour or two.
This issue happens when an interrupt comes in early while host sleep
is still activated. Driver handles this case by auto cancelling host
sleep. However is_suspended flag is still set which prevents any cmd
or data from being sent to firmware. Fix it by clearing is_suspended
flag in this path.
commit 4ef69d0394cba8caa9f75d3f2e53429bfb8b3045 upstream.
If no keycache slots are available, ath_key_config can return -ENOSPC.
If the key index is not checked for errors, it can lead to logspam that
looks like this: "ath: wiphy0: keyreset: keycache entry 228 out of range"
This can cause follow-up errors if the invalid keycache index gets
used for tx.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit b4f711ee03d28f776fd2324fd0bd999cc428e4d2 upstream.
Kay Sievers noted that the ALWAYS_USE_PERSISTENT_CLOCK config,
which enables some minor compile time optimization to avoid
uncessary code in mostly the suspend/resume path could cause
problems for userland.
In particular, the dependency for RTC_HCTOSYS on
!ALWAYS_USE_PERSISTENT_CLOCK, which avoids setting the time
twice and simplifies suspend/resume, has the side effect
of causing the /sys/class/rtc/rtcN/hctosys flag to always be
zero, and this flag is commonly used by udev to setup the
/dev/rtc symlink to /dev/rtcN, which can cause pain for
older applications.
While the udev rules could use some work to be less fragile,
breaking userland should strongly be avoided. Additionally
the compile time optimizations are fairly minor, and the code
being optimized is likely to be reworked in the future, so
lets revert this change.
Reported-by: Kay Sievers <kay@vrfy.org>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Cc: Feng Tang <feng.tang@intel.com>
Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Link: http://lkml.kernel.org/r/1366828376-18124-1-git-send-email-john.stultz@linaro.org
commit 39c60a0948cc06139e2fbfe084f83cb7e7deae3b upstream.
Some arrays synchronize their full non volatile cache when the sd driver sends
a SYNCHRONIZE CACHE command. Unfortunately, they can have Terrabytes of this
and we send a SYNCHRONIZE CACHE for every barrier if an array reports it has a
writeback cache. This leads to massive slowdowns on journalled filesystems.
The fix is to allow userspace to turn off the writeback cache setting as a
temporary measure (i.e. without doing the MODE SELECT to write it back to the
device), so even though the device reported it has a writeback cache, the
user, knowing that the cache is non volatile and all they care about is
filesystem correctness, can turn that bit off in the kernel and avoid the
performance ruinous (and safety irrelevant) SYNCHRONIZE CACHE commands.
The way you do this is add a 'temporary' prefix when performing the usual
cache setting operations, so
echo temporary write through > /sys/class/scsi_disk/<disk>/cache_type
Reported-by: Ric Wheeler <rwheeler@redhat.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 7783819920ca52fc582a2782f654fe6ed373f465 upstream.
The error in lis3lv02_poweron() is harmless in the resume path, so
we should ignore it. It is inline with the other usages of lis3lv02_poweron()
and matches the 3.0 code for this routine. This patch is in suse git and
might have missed making it into the mainline.
opensuse - commit id: 66ccdac87c322cf7af12bddba8c805af640b1cff
Signed-off-by: Shuah Khan <shuah.khan@hp.com>
Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
commit fa4d683af3693863bec761e2761a07e4c1351f86 upstream.
Return -ENOMEM if memory allocation fails in cache_create
instead of 0 (to avoid NULL pointer dereference).
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
commit 09e8b813897a0f85bb401435d009228644c81214 upstream.
Return -ENOMEM instead of success if unable to allocate pending
exception mempool in snapshot_ctr.
commit 502624bdad3dba45dfaacaf36b7d83e39e74b2d2 upstream.
This patch uses memalloc_noio_save to avoid a possible deadlock in
dm-bufio. (it could happen only with large block size, at most
PAGE_SIZE << MAX_ORDER (typically 8MiB).
__vmalloc doesn't fully respect gfp flags. The specified gfp flags are
used for allocation of requested pages, structures vmap_area, vmap_block
and vm_struct and the radix tree nodes.
However, the kernel pagetables are allocated always with GFP_KERNEL.
Thus the allocation of pagetables can recurse back to the I/O layer and
cause a deadlock.
This patch uses the function memalloc_noio_save to set per-process
PF_MEMALLOC_NOIO flag and the function memalloc_noio_restore to restore
it. When this flag is set, all allocations in the process are done with
implied GFP_NOIO flag, thus the deadlock can't happen.
This should be backported to stable kernels, but they don't have the
PF_MEMALLOC_NOIO flag and memalloc_noio_save/memalloc_noio_restore
functions. So, PF_MEMALLOC should be set and restored instead.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit d793e684277124d55c5d2444007e224635821346 upstream.
Fix a regression in the calculation of the stripe_width in the
dm stripe target which led to incorrect processing of device limits.
The stripe_width is the stripe device length divided by the number of
stripes. The group of commits in the range f14fa69 ("dm stripe: fix
size test") to eb850de ("dm stripe: support for non power of 2
chunksize") interfered with each other (a merging error) and led to the
stripe_width being set incorrectly to the stripe device length divided by
chunk_size * stripe_count.
For example, a stripe device's table with: 0 33553920 striped 3 512 ...
should result in a stripe_width of 11184640 (33553920 / 3), but due to
the bug it was getting set to 21845 (33553920 / (512 * 3)).
The impact of this bug is that device topologies that previously worked
fine with the stripe target are no longer considered valid. In
particular, there is a higher risk of seeing this issue if one of the
stripe devices has a 4K logical block size. Resulting in an error
message like this:
"device-mapper: table: 253:4: len=21845 not aligned to h/w logical block size 4096 of dm-1"
The fix is to swap the order of the divisions and to use a temporary
variable for the second one, so that width retains the intended
value.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit dc019b21fb92d620a3b52ccecc135ac968a7c7ec upstream.
If device_not_write_same_capable() returns true then the iterate_devices
loop in dm_table_supports_write_same() should return false.
Reported-by: Bharata B Rao <bharata.rao@gmail.com>
commit 9a188eb126aa7bf27077ee46fcb914898d6fc281 upstream.
In of_dma_controller_register() routine we are calling of_get_property() as an
parameter to be32_to_cpup(). In case the property doesn't exist we will get a
crash.
This patch changes this code to check if we got a valid property first and then
runs be32_to_cpup() on it.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Robert Richter <robert.richter@calxeda.com>
commit 61388f9e5d93053cf399a356414f31f9b4814c6d upstream.
Can only happen under these conditions: 1) The DSDT version is 1,
meaning integers are 32-bits. 2) The field is between 33 and 64
bits long.
It applies cleanly back to ACPICA 20100806+ (Linux v2.6.37+).
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
commit c1e0ac192b48b37f31801c17534ab3d2a9282d84 upstream.
It looks like the manual merge 0d69a3c731e120b05b7da9fb976830475a3fbc01 ("Merge
branches 'for-3.9/sony' and 'for-3.9/steelseries' into for-linus") accidentally
removed Sony RF receiver with USB product id 0x0374 from the "have special
driver" list, effectively nullifying a464918419f94a0043d2f549d6defb4c3f69f68a
("HID: add support for Sony RF receiver with USB product id 0x0374"). Add the
device back to the list.
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
commit 7fdb7846c9ca6fc06e380de0976a1228703b498a upstream.
A rebranded Novatel E371 for AT&T's LTE bands. qmi_wwan should drive this
device, while cdc_ether should ignore it. Even though the USB descriptors
are plain CDC-ETHER that USB interface is a QMI interface.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Acked-by: Bjørn Mork <bjorn@mork.no>
commit e253aaf0af51c1e4dc7dd3b26ea8e666bf9a2d8d upstream.
Commit 4f535093cf "PCI: Put pci_dev in device tree as early as possible"
moved final fixups from pci_bus_add_device() to pci_device_add(). But
pci_device_add() happens before resource assignment, so BARs may not be
valid yet.
Typical flow for hot-add:
pciehp_configure_device
pci_scan_slot
pci_scan_single_device
pci_device_add
pci_fixup_device(pci_fixup_final, dev) # previous location
# resource assignment happens here
pci_bus_add_devices
pci_bus_add_device
pci_fixup_device(pci_fixup_final, dev) # new location
[bhelgaas: changelog, move fixups to pci_bus_add_device()]
Reference: https://lkml.kernel.org/r/20130415182614.GB9224@xanatos
Reported-by: David Bulkow <David.Bulkow@stratus.com>
Tested-by: David Bulkow <David.Bulkow@stratus.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
