commit 3e7abe2556b583e87dabda3e0e6178a67b20d06f upstream.
When unbinding a device so that I could pass it through to a KVM VM, I
got the lockdep report below. It looks like a legitimate lock
ordering problem:
- domain_context_mapping_one() takes iommu->lock and calls
iommu_support_dev_iotlb(), which takes device_domain_lock (inside
iommu->lock).
- domain_remove_one_dev_info() starts by taking device_domain_lock
then takes iommu->lock inside it (near the end of the function).
So this is the classic AB-BA deadlock. It looks like a safe fix is to
simply release device_domain_lock a bit earlier, since as far as I can
tell, it doesn't protect any of the stuff accessed at the end of
domain_remove_one_dev_info() anyway.
BTW, the use of device_domain_lock looks a bit unsafe to me... it's
at least not obvious to me why we aren't vulnerable to the race below:
domain_remove_dev_info()
lock device_domain_lock
find info
unlock device_domain_lock
find same info
free_devinfo_mem(info)
do stuff with info after it's free
However I don't understand the locking here well enough to know if
this is a real problem, let alone what the best fix is.
Anyway here's the full lockdep output that prompted all of this:
[ INFO: possible circular locking dependency detected ]
2.6.39.1+ #1
bash/13954 is trying to acquire lock:
(&(&iommu->lock)->rlock){......}, at: [<ffffffff812f6421>] domain_remove_one_dev_info+0x121/0x230
but task is already holding lock:
(device_domain_lock){-.-...}, at: [<ffffffff812f6508>] domain_remove_one_dev_info+0x208/0x230
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (device_domain_lock){-.-...}:
[<ffffffff8109ca9d>] lock_acquire+0x9d/0x130
[<ffffffff81571475>] _raw_spin_lock_irqsave+0x55/0xa0
[<ffffffff812f8350>] domain_context_mapping_one+0x600/0x750
[<ffffffff812f84df>] domain_context_mapping+0x3f/0x120
[<ffffffff812f9175>] iommu_prepare_identity_map+0x1c5/0x1e0
[<ffffffff81ccf1ca>] intel_iommu_init+0x88e/0xb5e
[<ffffffff81cab204>] pci_iommu_init+0x16/0x41
[<ffffffff81002165>] do_one_initcall+0x45/0x190
[<ffffffff81ca3d3f>] kernel_init+0xe3/0x168
[<ffffffff8157ac24>] kernel_thread_helper+0x4/0x10
-> #0 (&(&iommu->lock)->rlock){......}:
[<ffffffff8109bf3e>] __lock_acquire+0x195e/0x1e10
[<ffffffff812f8b42>] device_notifier+0x72/0x90
[<ffffffff8157555c>] notifier_call_chain+0x8c/0xc0
[<ffffffff81089768>] __blocking_notifier_call_chain+0x78/0xb0
[<ffffffff810897b6>] blocking_notifier_call_chain+0x16/0x20
[<ffffffff81373a5c>] __device_release_driver+0xbc/0xe0
[<ffffffff81373ccf>] device_release_driver+0x2f/0x50
[<ffffffff81372ee3>] driver_unbind+0xa3/0xc0
[<ffffffff813724ac>] drv_attr_store+0x2c/0x30
[<ffffffff811e4506>] sysfs_write_file+0xe6/0x170
[<ffffffff8117569e>] vfs_write+0xce/0x190
[<ffffffff811759e4>] sys_write+0x54/0xa0
[<ffffffff81579a82>] system_call_fastpath+0x16/0x1b
6 locks held by bash/13954:
#0: (&buffer->mutex){+.+.+.}, at: [<ffffffff811e4464>] sysfs_write_file+0x44/0x170
#1: (s_active#3){++++.+}, at: [<ffffffff811e44ed>] sysfs_write_file+0xcd/0x170
#2: (&__lockdep_no_validate__){+.+.+.}, at: [<ffffffff81372edb>] driver_unbind+0x9b/0xc0
#3: (&__lockdep_no_validate__){+.+.+.}, at: [<ffffffff81373cc7>] device_release_driver+0x27/0x50
#4: (&(&priv->bus_notifier)->rwsem){.+.+.+}, at: [<ffffffff8108974f>] __blocking_notifier_call_chain+0x5f/0xb0
#5: (device_domain_lock){-.-...}, at: [<ffffffff812f6508>] domain_remove_one_dev_info+0x208/0x230
stack backtrace:
Pid: 13954, comm: bash Not tainted 2.6.39.1+ #1
Call Trace:
[<ffffffff810993a7>] print_circular_bug+0xf7/0x100
[<ffffffff810972bd>] ? trace_hardirqs_off+0xd/0x10
[<ffffffff8109d57d>] ? trace_hardirqs_on_caller+0x13d/0x180
[<ffffffff812f6421>] ? domain_remove_one_dev_info+0x121/0x230
Signed-off-by: Roland Dreier <roland@purestorage.com>
Fix warning about unused variable introduced by commit e681b66f2e19fa
("USB: mos7840: remove invalid disconnect handling") upstream.
A subsequent fix which removed the disconnect function got rid of the
warning but that one was only backported to v3.6.
Reported-by: Jiri Slaby <jslaby@suse.cz>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit b6e0e543f75729f207b9c72b0162ae61170635b2 upstream.
Like in the case of native hdmi, which is fixed already in
commit adf00b26d18e1b3570451296e03bcb20e4798cdd
Author: Paulo Zanoni <paulo.r.zanoni@intel.com>
Date: Tue Sep 25 13:23:34 2012 -0300
drm/i915: make sure we write all the DIP data bytes
we need to clear the entire sdvo buffer to avoid upsetting the
display.
Since infoframe buffer writing is now a bit more elaborate, extract it
into it's own function. This will be useful if we ever get around to
properly update the ELD for sdvo. Also #define proper names for the
two buffer indexes with fixed usage.
v2: Cite the right commit above, spotted by Paulo Zanoni.
v3: I'm too stupid to paste the right commit.
v4: Ben Hutchings noticed that I've failed to handle an underflow in
my loop logic, breaking it for i >= length + 8. Since I've just lost C
programmer license, use his solution. Also, make the frustrated 0-base
buffer size a notch more clear.
Reported-and-tested-by: Jürg Billeter <j@bitron.ch>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=25732
Cc: Paulo Zanoni <przanoni@gmail.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Reviewed-by: Rodrigo Vivi <rodrigo.vivi@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 81014b9d0b55fb0b48f26cd2a943359750d532db upstream.
At least the worst offenders:
- SDVO specifies that the encoder should compute the ecc. Testing also
shows that we must not send the ecc field, so copy the dip_infoframe
struct to a temporay place and avoid the ecc field. This way the avi
infoframe is exactly 17 bytes long, which agrees with what the spec
mandates as a minimal storage capacity (with the ecc field it would
be 18 bytes).
- Only 17 when sending the avi infoframe. The SDVO spec explicitly
says that sending more data than what the device announces results
in undefined behaviour.
- Add __attribute__((packed)) to the avi and spd infoframes, for
otherwise they're wrongly aligned. Noticed because the avi infoframe
ended up being 18 bytes large instead of 17. We haven't noticed this
yet because we don't use the uint16_t fields yet (which are the only
ones that would be wrongly aligned).
This regression has been introduce by
3c17fe4b8f40a112a85758a9ab2aebf772bdd647 is the first bad commit
commit 3c17fe4b8f40a112a85758a9ab2aebf772bdd647
Author: David Härdeman <david@hardeman.nu>
Date: Fri Sep 24 21:44:32 2010 +0200
i915: enable AVI infoframe for intel_hdmi.c [v4]
Patch tested on my g33 with a sdvo hdmi adaptor.
Tested-by: Peter Ross <pross@xvid.org> (G35 SDVO-HDMI)
Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 95e8f6a21996c4cc2c4574b231c6e858b749dce3 upstream.
The device would not reset properly when resuming from hibernation.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Brian Paul <brianp@vmware.com>
Reviewed-by: Dmitry Torokhov <dtor@vmware.com>
Cc: linux-graphics-maintainer@vmware.com
[ Upstream commit 39707c2a3ba5011038b363f84d37c8a98d2d9db1 ]
Driver anchors the tx urbs and defers the urb submission if
a transmit request comes when the interface is suspended.
Anchoring urb increments the urb reference count. These
deferred urbs are later accessed by calling usb_get_from_anchor()
for submission during interface resume. usb_get_from_anchor()
unanchors the urb but urb reference count remains same.
This causes the urb reference count to remain non-zero
after usb_free_urb() gets called and urb never gets freed.
Hence call usb_put_urb() after anchoring the urb to properly
balance the reference count for these deferred urbs. Also,
unanchor these deferred urbs during disconnect, to free them
up.
Signed-off-by: Hemant Kumar <hemantk@codeaurora.org>
Acked-by: Oliver Neukum <oneukum@suse.de>
commit 3300fb4f88688029fff8dfb9ec0734f6e4cba3e7 upstream.
Don't assume bank 0 is selected at device probe time. This may not be
the case. Force bank selection at first register access to guarantee
that we read the right registers upon driver loading.
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
commit 0f1cb1bd94a9c967cd4ad3de51cfdabe61eb5dcc upstream.
If drm_setup (called at first open) fails, the whole
open call has failed, so we should not keep the
open_count incremented.
Signed-off-by: Ilija Hadzic <ihadzic@research.bell-labs.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
commit 83325d072185899b706de2956170b246585aaec9 upstream.
An uninitialized variable led to broken load detection.
Signed-off-by: Egbert Eich <eich@suse.de>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 0d0f9dfb31e0a6c92063e235417b42df185b3275 upstream.
If the call to core_dev_release_virtual_lun0() fails, then nothing
sets ret to anything other than 0, so even though everything is
torn down and freed, target_core_init_configfs() will seem to succeed
and the module will be loaded. Fix this by passing the return value
on up the chain.
commit bf7e1abe434ba9e22e8dc04a4cba4ab504b788b8 upstream.
Some hardware has correct (!= 0xff) value of tssi_bounds[4] in the
EEPROM, but step is equal to 0xff. This results on ridiculous delta
calculations and completely broke TX power settings.
Reported-and-tested-by: Pavel Lucik <pavel.lucik@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
commit 8c6e30936a7893a85f6222084f0f26aceb81137a upstream.
bf->bf_next is only while buffers are chained as part of an A-MPDU
in the tx queue. When a tid queue is flushed (e.g. on tearing down
an aggregation session), frames can be enqueued again as normal
transmission, without bf_next being cleared. This can lead to the
old pointer being dereferenced again later.
This patch might fix crashes and "Failed to stop TX DMA!" messages.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit cee59f15a60cc6269a25e3f6fbf1a577d6ab8115 upstream.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit f6365201d8a21fb347260f89d6e9b3e718d63c70 upstream.
The X86_32-only disable_hlt/enable_hlt mechanism was used by the
32-bit floppy driver. Its effect was to replace the use of the
HLT instruction inside default_idle() with cpu_relax() - essentially
it turned off the use of HLT.
This workaround was commented in the code as:
"disable hlt during certain critical i/o operations"
"This halt magic was a workaround for ancient floppy DMA
wreckage. It should be safe to remove."
H. Peter Anvin additionally adds:
"To the best of my knowledge, no-hlt only existed because of
flaky power distributions on 386/486 systems which were sold to
run DOS. Since DOS did no power management of any kind,
including HLT, the power draw was fairly uniform; when exposed
to the much hhigher noise levels you got when Linux used HLT
caused some of these systems to fail.
They were by far in the minority even back then."
Alan Cox further says:
"Also for the Cyrix 5510 which tended to go castors up if a HLT
occurred during a DMA cycle and on a few other boxes HLT during
DMA tended to go astray.
Do we care ? I doubt it. The 5510 was pretty obscure, the 5520
fixed it, the 5530 is probably the oldest still in any kind of
use."
So, let's finally drop this.
Signed-off-by: Len Brown <len.brown@intel.com>
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Stephen Hemminger <shemminger@vyatta.com
Link: http://lkml.kernel.org/n/tip-3rhk9bzf0x9rljkv488tloib@git.kernel.org
[ If anyone cares then alternative instruction patching could be
used to replace HLT with a one-byte NOP instruction. Much simpler. ]
commit 238ab78469c6ab7845b43d5061cd3c92331b2452 upstream.
If blk_init_queue fails, we do not call put_disk on the current dr
(dr is decremented first in the error handling loop).
Reviewed-by: Ben Hutchings <ben@decadent.org.uk>
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
commit 9756fe38d10b2bf90c81dc4d2f17d5632e135364 upstream.
This box claims to have an LVDS interface but doesn't
actually have one.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
commit aaeb61a97b7159ebe30b18a422d04eeabfa8790b upstream.
`pc236_detach()` is called by the comedi core if it attempted to attach
a device and failed. `pc236_detach()` calls `pc236_intr_disable()` if
the comedi device private data pointer (`devpriv`) is non-null. This
test is insufficient as `pc236_intr_disable()` accesses hardware
registers and the attach routine may have failed before it has saved
their I/O base addresses.
Fix it by checking `dev->iobase` is non-zero before calling
`pc236_intr_disable()` as that means the I/O base addresses have been
saved and the hardware registers can be accessed. It also implies the
comedi device private data pointer is valid, so there is no need to
check it.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit e4df1cbcc1f329e53a1fff7450b2229e0addff20 upstream.
Commit 6889125b8b4e09c5e53e6ecab3433bed1ce198c9
(cpufreq/powernow-k8: workqueue user shouldn't migrate the kworker to another CPU)
causes powernow-k8 to trigger a preempt warning, e.g.:
BUG: using smp_processor_id() in preemptible [00000000] code: cpufreq/3776
caller is powernowk8_target+0x20/0x49
Pid: 3776, comm: cpufreq Not tainted 3.6.0 #9
Call Trace:
[<ffffffff8125b447>] debug_smp_processor_id+0xc7/0xe0
[<ffffffff814877e7>] powernowk8_target+0x20/0x49
[<ffffffff81482b02>] __cpufreq_driver_target+0x82/0x8a
[<ffffffff81484fc6>] cpufreq_governor_performance+0x4e/0x54
[<ffffffff81482c50>] __cpufreq_governor+0x8c/0xc9
[<ffffffff81482e6f>] __cpufreq_set_policy+0x1a9/0x21e
[<ffffffff814839af>] store_scaling_governor+0x16f/0x19b
[<ffffffff81484f16>] ? cpufreq_update_policy+0x124/0x124
[<ffffffff8162b4a5>] ? _raw_spin_unlock_irqrestore+0x2c/0x49
[<ffffffff81483640>] store+0x60/0x88
[<ffffffff811708c0>] sysfs_write_file+0xf4/0x130
[<ffffffff8111243b>] vfs_write+0xb5/0x151
[<ffffffff811126e0>] sys_write+0x4a/0x71
[<ffffffff816319a9>] system_call_fastpath+0x16/0x1b
Fix this by by always using work_on_cpu().
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
commit 1fffa905adffbf0d3767fc978ef09afb830275eb upstream.
When cores are unregistered, entries
need to be removed from cores list in a safe manner.
Reported-by: Stanislaw Gruszka <sgruszka@redhat.com>
Reviewed-by: Arend Van Spriel <arend@broadcom.com>
Signed-off-by: Piotr Haber <phaber@broadcom.com>
commit 910a578f7e9400a78a3b13aba0b4d2df16a2cb05 upstream.
We copy head count to a 16 bit field, this works by chance on LE but on
BE guest gets 0. Fix it up.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Alexander Graf <agraf@suse.de>
commit 43a09f7fb01fa1e091416a2aa49b6c666458c1ee upstream.
The command cancellation code doesn't check whether find_trb_seg()
couldn't find the segment that contains the TRB to be canceled. This
could cause a NULL pointer deference later in the function when next_trb
is called. It's unlikely to happen unless something is wrong with the
command ring pointers, so add some debugging in case it happens.
This patch should be backported to stable kernels as old as 3.0, that
contain the commit b63f4053cc8aa22a98e3f9a97845afe6c15d0a0d "xHCI:
handle command after aborting the command ring".
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit e681b66f2e19fadbe8a7e2a17900978cb6bc921f upstream.
Remove private zombie flag used to signal disconnect and to prevent
control urb from being submitted from interrupt urb completion handler.
The control urb will not be re-submitted as both the control urb and the
interrupt urb is killed on disconnect.
commit 28c3ae9a8cf45f439c9a0779ebd0256e2ae72813 upstream.
The private int_urb is never allocated so the submission from the
control completion handler will always fail. Remove this odd piece of
broken code.
commit 3eb55cc4ed88eee3b5230f66abcdbd2a91639eda upstream.
The driver set the usb-serial port pointers to NULL on errors in attach,
effectively preventing usb-serial core from decrementing the port ref
counters and releasing the port devices and associated data.
commit 65a4cdbb170e4ec1a7fa0e94936d47e24a17b0e8 upstream.
Make sure control urb is freed at release.
commit 084817d79399ab5ccab2f90a148b0369912a8369 upstream.
Move interface data allocation to attach so that it is deallocated on
errors in usb-serial probe.
commit 7e41f9bcdd2e813ea2a3c40db291d87ea06b559f upstream.
Make sure port private data is deallocated on errors in attach.
commit f7bc5051667b74c3861f79eed98c60d5c3b883f7 upstream.
I found a memory leak in sierra_release() (well sierra_probe() I guess)
that looses 8 bytes each time the driver releases a device.
Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca>
Acked-by: Johan Hovold <jhovold@gmail.com>
commit acbf0e5263de563e25f7c104868e4490b9e72b13 upstream.
Fix memory leak in write error path.
commit ea0dbebffe118724cd4df7d9b071ea8ee48d48f0 upstream.
Make sure to allocate the control-message buffer dynamically as some
platforms cannot do DMA from stack.
Note that only the first byte of the old buffer was used.
commit c129197c99550d356cf5f69b046994dd53cd1b9d upstream.
Make sure command buffer is deallocated in case of errors during attach.
Cc: <support@connecttech.com>
commit 3b6054da68f9b0d5ed6a7ed0f42a79e61904352c upstream.
There is a race condition in the USB hub code with regard to handling
TT clear requests that can get the HCD driver in a deadlock. Usually
when an TT clear request is scheduled it will be executed immediately:
<7>[ 6.077583] usb 2-1.3: unlink qh1-0e01/f4d4db00 start 0 [1/2 us]
<3>[ 6.078041] usb 2-1: clear tt buffer port 3, a3 ep2 t04048d82
<7>[ 6.078299] hub_tt_work:731
<7>[ 9.309089] usb 2-1.5: link qh1-0e01/f4d506c0 start 0 [1/2 us]
<7>[ 9.324526] ehci_hcd 0000:00:1d.0: reused qh f4d4db00 schedule
<7>[ 9.324539] usb 2-1.3: link qh1-0e01/f4d4db00 start 0 [1/2 us]
<7>[ 9.341530] usb 1-1.1: link qh4-0e01/f397aec0 start 2 [1/2 us]
<7>[ 10.116159] usb 2-1.3: unlink qh1-0e01/f4d4db00 start 0 [1/2 us]
<3>[ 10.116459] usb 2-1: clear tt buffer port 3, a3 ep2 t04048d82
<7>[ 10.116537] hub_tt_work:731
However, if a suspend operation is triggered before hub_tt_work is
scheduled, hub_quiesce will cancel the work without notifying the HCD
driver:
<3>[ 35.033941] usb 2-1: clear tt buffer port 3, a3 ep2 t04048d80
<5>[ 35.034022] sd 0:0:0:0: [sda] Stopping disk
<7>[ 35.034039] hub 2-1:1.0: hub_suspend
<7>[ 35.034067] usb 2-1: unlink qh256-0001/f3b1ab00 start 1 [1/0 us]
<7>[ 35.035085] hub 1-0:1.0: hub_suspend
<7>[ 35.035102] usb usb1: bus suspend, wakeup 0
<7>[ 35.035106] ehci_hcd 0000:00:1a.0: suspend root hub
<7>[ 35.035298] hub 2-0:1.0: hub_suspend
<7>[ 35.035313] usb usb2: bus suspend, wakeup 0
<7>[ 35.035315] ehci_hcd 0000:00:1d.0: suspend root hub
<6>[ 35.250017] PM: suspend of devices complete after 216.979 msecs
<6>[ 35.250822] PM: late suspend of devices complete after 0.799 msecs
<7>[ 35.252343] ehci_hcd 0000:00:1d.0: wakeup: 1
<7>[ 35.262923] ehci_hcd 0000:00:1d.0: --> PCI D3hot
<7>[ 35.263302] ehci_hcd 0000:00:1a.0: wakeup: 1
<7>[ 35.273912] ehci_hcd 0000:00:1a.0: --> PCI D3hot
<6>[ 35.274254] PM: noirq suspend of devices complete after 23.442 msecs
<6>[ 35.274975] ACPI: Preparing to enter system sleep state S3
<6>[ 35.292666] PM: Saving platform NVS memory
<7>[ 35.295030] Disabling non-boot CPUs ...
<6>[ 35.297351] CPU 1 is now offline
<6>[ 35.300345] CPU 2 is now offline
<6>[ 35.303929] CPU 3 is now offline
<7>[ 35.303931] lockdep: fixing up alternatives.
<6>[ 35.304825] Extended CMOS year: 2000
When the device will resume the EHCI driver will get stuck in
ehci_endpoint_disable waiting for the tt_clearing flag to reset:
<0>[ 47.610967] usb 2-1.3: **** DPM device timeout ****
<7>[ 47.610972] f2f11c60 00000092 f2f11c0c c10624a5 00000003 f4c6e880 c1c8a4c0 c1c8a4c0
<7>[ 47.610983] 15c55698 0000000b f56b34c0 f2a45b70 f4c6e880 00000082 f2a4602c f2f11c30
<7>[ 47.610993] c10787f8 f4cac000 f2a45b70 00000000 f4cac010 f2f11c58 00000046 00000001
<7>[ 47.611004] Call Trace:
<7>[ 47.611006] [<c10624a5>] ? sched_clock_cpu+0xf5/0x160
<7>[ 47.611019] [<c10787f8>] ? lock_release_holdtime.part.22+0x88/0xf0
<7>[ 47.611026] [<c103ed46>] ? lock_timer_base.isra.35+0x26/0x50
<7>[ 47.611034] [<c17592d3>] ? schedule_timeout+0x133/0x290
<7>[ 47.611044] [<c175b43e>] schedule+0x1e/0x50
<7>[ 47.611051] [<c17592d8>] schedule_timeout+0x138/0x290
<7>[ 47.611057] [<c10624a5>] ? sched_clock_cpu+0xf5/0x160
<7>[ 47.611063] [<c103e560>] ? usleep_range+0x40/0x40
<7>[ 47.611070] [<c1759445>] schedule_timeout_uninterruptible+0x15/0x20
<7>[ 47.611077] [<c14935f4>] ehci_endpoint_disable+0x64/0x160
<7>[ 47.611084] [<c147d1ee>] ? usb_hcd_flush_endpoint+0x10e/0x1d0
<7>[ 47.611092] [<c1165663>] ? sysfs_add_file+0x13/0x20
<7>[ 47.611100] [<c147d5a9>] usb_hcd_disable_endpoint+0x29/0x40
<7>[ 47.611107] [<c147fafc>] usb_disable_endpoint+0x5c/0x80
<7>[ 47.611111] [<c147fb57>] usb_disable_interface+0x37/0x50
<7>[ 47.611116] [<c1477650>] usb_reset_and_verify_device+0x4b0/0x640
<7>[ 47.611122] [<c1474665>] ? hub_port_status+0xb5/0x100
<7>[ 47.611129] [<c147a975>] usb_port_resume+0xd5/0x220
<7>[ 47.611136] [<c148877f>] generic_resume+0xf/0x30
<7>[ 47.611142] [<c14821a3>] usb_resume+0x133/0x180
<7>[ 47.611147] [<c1473b10>] ? usb_dev_thaw+0x10/0x10
<7>[ 47.611152] [<c1473b1d>] usb_dev_resume+0xd/0x10
<7>[ 47.611157] [<c13baa60>] dpm_run_callback+0x40/0xb0
<7>[ 47.611164] [<c13bdb03>] ? pm_runtime_enable+0x43/0x70
<7>[ 47.611171] [<c13bafc6>] device_resume+0x1a6/0x2c0
<7>[ 47.611177] [<c13ba940>] ? dpm_show_time+0xe0/0xe0
<7>[ 47.611183] [<c13bb0f9>] async_resume+0x19/0x40
<7>[ 47.611189] [<c10580c4>] async_run_entry_fn+0x64/0x160
<7>[ 47.611196] [<c104a244>] ? process_one_work+0x104/0x480
<7>[ 47.611203] [<c104a24c>] ? process_one_work+0x10c/0x480
<7>[ 47.611209] [<c104a2c0>] process_one_work+0x180/0x480
<7>[ 47.611215] [<c104a244>] ? process_one_work+0x104/0x480
<7>[ 47.611220] [<c1058060>] ? async_schedule+0x10/0x10
<7>[ 47.611226] [<c104c15c>] worker_thread+0x11c/0x2f0
<7>[ 47.611233] [<c104c040>] ? manage_workers.isra.27+0x1f0/0x1f0
<7>[ 47.611239] [<c10507f8>] kthread+0x78/0x80
<7>[ 47.611244] [<c1750000>] ? timer_cpu_notify+0xd6/0x20d
<7>[ 47.611253] [<c1050780>] ? __init_kthread_worker+0x60/0x60
<7>[ 47.611258] [<c176357e>] kernel_thread_helper+0x6/0xd
<7>[ 47.611283] ------------[ cut here ]------------
This patch changes hub_quiesce behavior to flush the TT clear work
instead of canceling it, to make sure that no TT clear request remains
uncompleted before suspend.
Signed-off-by: Octavian Purdila <octavian.purdila@intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit d7870af7e2e3a91b462075ec1ca669b482215187 upstream.
This commit sets removable subclass for Casio EX-N1 digital camera.
The patch has been tested within an ALT Linux kernel:
http://git.altlinux.org/people/led/packages/?p=kernel-image-3.0.git;a=commitdiff;h=c0fd891836e89fe0c93a4d536a59216d90e4e3e7
See also https://bugzilla.kernel.org/show_bug.cgi?id=49221
Signed-off-by: Oleksandr Chumachenko <ledest@gmail.com>
Signed-off-by: Michael Shigorin <mike@osdn.org.ua>
commit 8daf8b6086f9d575200cd0aa3797e26137255609 upstream.
Board name changed on another shipping Lucid tablet.
Signed-off-by: Anisse Astier <anisse@astier.eu>
commit c323dc023b9501e5d09582ec7efd1d40a9001d99 upstream.
BIOS vendors keep changing the BIOS versions. Only match the beginning
of the string to match all Lucid tablets with board name M11JB.
commit fee0de7791f967c2c5f0d43eb7b7261761b45e64 upstream.
Signed-off-by: Jan Luebbe <jlu@pengutronix.de>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Grant Likely <grant.likely@secretlab.ca>
Tested-by: Roland Stigge <stigge@antcom.de>
Cc: Sascha Hauer <kernel@pengutronix.de>
commit b63f4053cc8aa22a98e3f9a97845afe6c15d0a0d upstream.
According to xHCI spec section 4.6.1.1 and section 4.6.1.2,
after aborting a command on the command ring, xHC will
generate a command completion event with its completion
code set to Command Ring Stopped at least. If a command is
currently executing at the time of aborting a command, xHC
also generate a command completion event with its completion
code set to Command Abort. When the command ring is stopped,
software may remove, add, or rearrage Command Descriptors.
To cancel a command, software will initialize a command
descriptor for the cancel command, and add it into a
cancel_cmd_list of xhci. When the command ring is stopped,
software will find the command trbs described by command
descriptors in cancel_cmd_list and modify it to No Op
command. If software can't find the matched trbs, we can
think it had been finished.
This patch should be backported to kernels as old as 3.0, that contain
the commit 7ed603ecf8b68ab81f4c83097d3063d43ec73bb8 "xhci: Add an
assertion to check for virt_dev=0 bug." That commit papers over a NULL
pointer dereference, and this patch fixes the underlying issue that
caused the NULL pointer dereference.
Note from Sarah: The TRB_TYPE_LINK_LE32 macro is not in the 3.0 stable
kernel, so I added it to this patch.
Signed-off-by: Elric Fu <elricfu1@gmail.com>
Tested-by: Miroslav Sabljic <miroslav.sabljic@avl.com>
commit 6e4468b9a0793dfb53eb80d9fe52c739b13b27fd upstream.
The patch is used to cancel command when the command isn't
acknowledged and a timeout occurs.
commit b92cc66c047ff7cf587b318fe377061a353c120f upstream.
Software have to abort command ring and cancel command
when a command is failed or hang. Otherwise, the command
ring will hang up and can't handle the others. An example
of a command that may hang is the Address Device Command,
because waiting for a SET_ADDRESS request to be acknowledged
by a USB device is outside of the xHC's ability to control.
Sarah: Fixed missing newline on "Have the command ring been stopped?"
debugging statement.
commit c181bc5b5d5c79b71203cd10cef97f802fb6f9c1 upstream.
Adding cmd_ring_state for command ring. It helps to verify
the current command ring state for controlling the command
ring operations.
This patch should be backported to kernels as old as 3.0. The commit
7ed603ecf8b68ab81f4c83097d3063d43ec73bb8 "xhci: Add an assertion to
check for virt_dev=0 bug." papers over the NULL pointer dereference that
I now believe is related to a timed out Set Address command. This (and
the four patches that follow it) contain the real fix that also allows
VIA USB 3.0 hubs to consistently re-enumerate during the plug/unplug
stress tests.
[ Upstream commit a2af139ff1cd85df586690ff626619ab1ee88b0a ]
Marvell 88E8001 on an ASUS P5NSLI motherboard is unable to send/receive
packets on a system with >4gb ram unless a 32bit DMA mask is used.
This issue has been around for years and a fix was sent 3.5 years ago, but
there was some debate as to whether it should instead be fixed as a PCI quirk.
http://www.spinics.net/lists/netdev/msg88670.html
However, 18 months later a similar workaround was introduced for another
chipset exhibiting the same problem.
http://www.spinics.net/lists/netdev/msg142287.html
Signed-off-by: Graham Gower <graham.gower@gmail.com>
Signed-off-by: Jan Ceuleers <jan.ceuleers@computer.org>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
commit 3bcf603f6d5d18bd9d076dc280de71f48add4101 upstream.
On CougarPoint and PantherPoint PCH chips, the timing generator may fail
to start after DP training completes. This is due to a bug in the
FDI autotraining detect logic (which will stall the timing generator and
re-enable it once training completes), so disable it to avoid silent DP
mode setting failures.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Keith Packard <keithp@keithp.com>
Signed-off-by: Timo Aaltonen <timo.aaltonen@canonical.com>
causes BUG()
commit a595c1ce4c9d572cf53513570b9f1a263d7867f2 upstream.
We weren't checking whether the resource was in use before calling
res_free(), so applications which called STREAMOFF on a v4l2 device that
wasn't already streaming would cause a BUG() to be hit (MythTV).
Reported-by: Larry Finger <larry.finger@lwfinger.net>
Reported-by: Jay Harbeston <jharbestonus@gmail.com>
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
commit 168bfeef7bba3f9784f7540b053e4ac72b769ce9 upstream.
If none of the elements in scrubrates[] matches, this loop will cause
__amd64_set_scrub_rate() to incorrectly use the n+1th element.
As the function is designed to use the final scrubrates[] element in the
case of no match, we can fix this bug by simply terminating the array
search at the n-1th element.
Boris: this code is fragile anyway, see here why:
http://marc.info/?l=linux-kernel&m=135102834131236&w=2
It will be rewritten more robustly soonish.
Reported-by: Denis Kirjanov <kirjanov@gmail.com>
Cc: Doug Thompson <dougthompson@xmission.com>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
commit 4b35f1c52943851b310afb09047bfe991ac8f5ae upstream.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 1452df6f1b7e396d89c2a1fdbdc0e0e839f97671 upstream.
Based on information from the ZTE Windows drivers.
commit 301a29da6e891e7eb95c843af0ecdbe86d01f723 upstream.
The current code assumes that CSIZE is 0000060, which appears to be
wrong on some arches (such as powerpc).
Signed-off-by: Nicolas Boullis <nboullis@debian.org>
commit c5211187f7ff8e8dbff4ebf7c011ac4c0ffe319c upstream.
If the write endpoint is interrupt type, usb_sndintpipe() should
be passed to usb_fill_int_urb() instead of usb_sndbulkpipe().
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Cc: Oliver Neukum <oneukum@suse.de>
commit fdc858a466b738d35d3492bc7cf77b1dac98bf7c upstream.
The sharpsl_pcmcia_ops structure gets passed into
sa11xx_drv_pcmcia_probe, where it gets accessed at run-time,
unlike all other pcmcia drivers that pass their structures
into platform_device_add_data, which makes a copy.
This means the gcc warning is valid and the structure
must not be marked as __initdata.
Without this patch, building collie_defconfig results in:
drivers/pcmcia/pxa2xx_sharpsl.c:22:31: fatal error: mach-pxa/hardware.h: No such file or directory
compilation terminated.
make[3]: *** [drivers/pcmcia/pxa2xx_sharpsl.o] Error 1
make[2]: *** [drivers/pcmcia] Error 2
make[1]: *** [drivers] Error 2
make: *** [sub-make] Error 2
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Pavel Machek <pavel@suse.cz>
Cc: linux-pcmcia@lists.infradead.org
Cc: Jochen Friedrich <jochen@scram.de>
commit abce9ac292e13da367bbd22c1f7669f988d931ac upstream.
tpm_write calls tpm_transmit without checking the return value and
assigns the return value unconditionally to chip->pending_data, even if
it's an error value.
This causes three bugs.
So if we write to /dev/tpm0 with a tpm_param_size bigger than
TPM_BUFSIZE=0x1000 (e.g. 0x100a)
and a bufsize also bigger than TPM_BUFSIZE (e.g. 0x100a)
tpm_transmit returns -E2BIG which is assigned to chip->pending_data as
-7, but tpm_write returns that TPM_BUFSIZE bytes have been successfully
been written to the TPM, altough this is not true (bug #1).
As we did write more than than TPM_BUFSIZE bytes but tpm_write reports
that only TPM_BUFSIZE bytes have been written the vfs tries to write
the remaining bytes (in this case 10 bytes) to the tpm device driver via
tpm_write which then blocks at
/* cannot perform a write until the read has cleared
either via tpm_read or a user_read_timer timeout */
while (atomic_read(&chip->data_pending) != 0)
msleep(TPM_TIMEOUT);
for 60 seconds, since data_pending is -7 and nobody is able to
read it (since tpm_read luckily checks if data_pending is greater than
0) (#bug 2).
After that the remaining bytes are written to the TPM which are
interpreted by the tpm as a normal command. (bug #3)
So if the last bytes of the command stream happen to be a e.g.
tpm_force_clear this gets accidentally sent to the TPM.
This patch fixes all three bugs, by propagating the error code of
tpm_write and returning -E2BIG if the input buffer is too big,
since the response from the tpm for a truncated value is bogus anyway.
Moreover it returns -EBUSY to userspace if there is a response ready to be
read.
Signed-off-by: Peter Huewe <peter.huewe@infineon.com>
Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
