path: root/drivers
2006-03-11[PATCH] 3c509: bus registration fixAndrew Morton
- Don't call eisa_driver_unregister() if eisa_driver_register() failed. - Properly propagate error values. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-11[PATCH] de620: fix section mismatch warningSam Ravnborg
In latest -mm de620 gave following warning: WARNING: drivers/net/de620.o - Section mismatch: reference to \ .init.text:de620_probe from .text between 'init_module' (at offset \ 0x1682) and 'cleanup_module' init_module() call de620_probe() which is declared __init. Fix is to declare init_module() __init too. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-11[PATCH] NE2000 Kconfig help entry improvementJesper Juhl
Improve reference to PCI NE2K support in ISA NE2K documentation. Original 2.4 patch From: Ged Haywood <ged@jubileegroup.co.uk> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-11[PATCH] dl2k: DMA freeing errorJon Mason
This patch fixes an error in the dl2k driver's DMA mapping/unmapping. The adapter uses the upper 16bits of the DMA address for the buffer size. However, this is not masked off when referencing the DMA address, and can lead to errors by trying to free a DMA address out of range. Thanks, Jon Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-11[PATCH] Wrong return value corrupts free object in e1000 driverDavid S. Miller
For some reason, E1000's ->hard_start_xmit() routine returns -EFAULT instead of one of the NETDEV_TX_* error codes. In fact, it frees up the SKB before returning this. This makes the queueing layer think the packet should be requeued and subsequently we corrupt a freed object. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-11Merge branch 'for-jeff' of ↵Jeff Garzik
git://electric-eye.fr.zoreil.com/home/romieu/linux-2.6
2006-03-11[PATCH] radeonfb: Fix static array overrunAntonino A. Daplas
radeonfb_parse_monitor_layout() will produce an array overrun if passed with a substring of length higher than 4 (ie, "XXXXX,YYYYYY"). Coverity Bug 494 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] aty128fb: Fix array overrunAntonino A. Daplas
Fix static array overrun Coverity Bug 556 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] tdfxfb: Fix buffer overrunAntonino A. Daplas
The pseudo_palette has room only for 16 entries, but tdfxfb_setcolreg may attempt to write more. Coverity Bug 557 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] intelfb: Fix buffer overrunAntonino A. Daplas
The pseudo_palette has room only for 16 entries, but intelfb_setcolreg will attempt to write more. Coverity Bug 558 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] savagefb: Fix kfree before useAntonino A. Daplas
par->edid is kfree'd before using in fb_edid_to_monspecs() Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] imsttfb: Fix resource leakAntonino A. Daplas
The struct info and device resource may not be released in the driver's error path. Fix. Coverity Bug 671 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] s1d13xxxfb: Fix resource leakAntonino A. Daplas
struct info may not be released in the driver's error path. Coverity Bug 672 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] arcfb: Fix dereference before NULL checkAntonino A. Daplas
info->par is dereferenced before info is checked for NULL. Fix. Coverity Bug 833 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] kyrofb: Fix uninitialized valueAntonino A. Daplas
Initialize Variable 'count' in DisableVGA to zero. Coverity Bug 874 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] arcfb: Fix uninitialized valueAntonino A. Daplas
Remove insignificant and uninitialized variable "count" from arcfb_lcd_update_page. Coverity Bug 894 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] neofb: Fix uninitialized valueAntonino A. Daplas
Remove insignificant and unitialized variable "waitcycles" from neo2200_sync. Coverity Bug 895 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] Altix: small ioc4 oversightPat Gefre
Get rid of the local 'flip' variable and no need to 'trim' the buffer. Signed-off-by: Patrick Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] edac: disable a few sysfs files to avoid them becoming an ABIArjan van de Ven
Disable (via ugly #if 0's) the 3 sysfs files that I think by now we all agree are very much wrong. These files shouldn't become part of the ABI by the 2.6.16 release, so I rather have this minimal patch merged to disable them for now, the real fix can then come during the 2.6.17 devel window. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-10[PATCH] Input: psmouse - disable autoresyncDmitry Torokhov
Automatic resynchronization in psmouse driver causes problems on some hardware so disable it by default for now. People with KVM switches that require resync can still enable it via module parameter or sysfs attribute. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-10[PATCH] fix pcmcia_device_probe oopsHugh Dickins
Fix pcmcia_device_probe NULL pointer dereference at startup. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-09[PATCH] s390: dasd proc interface typoHorst Hummel
This fixes a typo introduced with 90f0094dc607abe384a412bfb7199fb667ab0735. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-09[PATCH] edac: mark as experimentalTim Small
EDAC is still causing a few problems and the code is relatively green. Mark it as experimental until thing settle down. Also, provide some documentation pointers in Kconfig help. Signed-off-by: Tim Small <tim@buttersideup.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-09[PATCH] ibmasm: use after free fixMax Asbock
The kobject_put() can free the memory at *cmd, but cmd->lock points to a persistent lock that is not freed with cmd. Signed-off-by: Max Asbock <masbock@us.ibm.com> Cc: Vernon Mauery <vernux@us.ibm.com> Cc: Srihari Vijayaraghavan <sriharivijayaraghavan@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-09[PATCH] md: Fix several raid1 bugs which cause a memory leakNeilBrown
- wrong test for 'is this a BARRIER bio' - not freeing on all possible paths. - using r1_bio after freeing it. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-09[PATCH] Fix error handling in backlight driversJean Delvare
ERR_PTR() is supposed to be passed a negative value. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-09[PATCH] dcdbas: dcdbas_pdev referenced after platform_device_unregister on exitDoug Warzecha
smi_data_buf_free() references dcdbas_pdev when calling dma_free_coherent(). In dcdbas_exit(), smi_data_buf_free() is called after platform_device_unregister(dcdbas_pdev). This patch moves platform_device_unregister(dcdbas_pdev) after smi_data_buf_free() in dcdbas_exit(). Signed-off-by: Doug Warzecha <Douglas_Warzecha@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-09sky2: truncate oversize packetsStephen Hemminger
Turn on truncation to prevent getting choked by frames larger than expected. Without this fix, driver hangs after receiving an oversize packet. Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-03-09sky2: force early transmit interruptsStephen Hemminger
Avoid premature transmit ring full conditions. Force a transmit status interrupt if transmit ring gets nearly full and after a TSO send. Allow more entries in transmit ring to be used if dma_addr is 32 bits Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-03-09sky2: not random enoughStephen Hemminger
Don't use sky2 to seed random pool beacause the network packet arrival time will not be truly random due to NAPI and interrupt mitigation. Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-03-09de2104x: fix the TX watchdogFrancois Romieu
Insert de_init_rings() to reinit the rings before de_init_hw() tries to access them again. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-03-09de2104x: prevent interrupt before the interrupt handler is registeredFrancois Romieu
de_init_hw enables the irq thus it must be issued after request_irq. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-03-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-mergeLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-merge: powerpc: Fix various syscall/signal/swapcontext bugs [PATCH] powerpc: incorrect rmo_top handling in prom_init [PATCH] powerpc: Fix incorrect pud_ERROR() message [PATCH] powerpc: Expose SMT and L1 icache snoop userland features [PATCH] powerpc: Fix windfarm_pm112 not starting all control loops [PATCH] powerpc: Fix old g5 issues with windfarm powerpc32: Fix timebase synchronization on 32-bit powermacs powerpc: Turn off verbose debug output in powermac platform functions powerpc: Fix might-sleep warning in program check exception handler
2006-03-08Merge master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: Merge branch 'work-fixes' V4L/DVB (3413): Typos grab bag of the month V4L/DVB (3403): Workaround to fix initialization for Nexus CA Merge branch 'work-fixes' V4L/DVB (3395): Fixed Pinnacle 300i DVB-T support V4L/DVB (3399): ELSA EX-VISION 500TV: fix incorrect PCI subsystem ID V4L/DVB (3382): Fix stv0297 for qam128 on tt c1500 (saa7146) V4L/DVB (3300a): Removing personal email from DVB maintainers V4L/DVB (3385): Dvb: fix __init/__exit section references in av7110 driver V4L/DVB (3378): Restore power on defaults of tda9887 after tda8290 probe V4L/DVB (3354): Fix maximum for the saturation and contrast controls. V4L/DVB (3352): Cxusb: fix lgdt3303 naming V4L/DVB (3348): Fixed saa7134 ALSA initialization with multiple cards V4L/DVB (3347): Pinnacle PCTV 40i: add filtered Composite2 input V4L/DVB (3341): Upstream sync - make 2 structs static V4L/DVB (3340): Make a struct static V4L/DVB (3337): Drivers/media/dvb/frontends/mt312.c: cleanups V4L/DVB (3336): Bt8xx documentation authors fix
2006-03-08[PATCH] dac960: add disk entropy in request completionsMatt Mackall
Signed-off-by: Matt Mackall <mpm@selenic.com> Tested-by: Anders K. Pedersen <akp@cohaesio.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-08[PATCH] s390: dasd partition detectionHorst Hummel
DASD allows to open a device as soon as gendisk is registered, which means the device is a fake device (capacity=0) and we do know nothing about blocksize and partitions at that point of time. In case the device is opened by someone, the bdev and inode creation is done with the fake device info and the following partition detection code is just using the wrong data. To avoid this modify the DASD state machine to make sure that the open is rejected until the device analysis is either finished or an unformatted device was detected. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-08[PATCH] s390: iucv message limit for smsgMartin Schwidefsky
The message limit on the iucv connect call for the smsg module is too low. Therefore increase the smsg message limit to 255. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-08[PATCH] serial core: work around sub-driver bugsPavel Machek
We're presently getting oopses because Bluetooth (and possibly other) drivers are calling core functions after things have been shut down. So rather than oopsing, let's drop a warning then take avoiding action, so the machine survives. Once all the sub-drivers are fixed up we can remove the take-avoiding-action part. Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-08Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] mca recovery return value when no bus check [IA64] SGI SN drivers: don't report !sn2 hardware as an error [IA64] don't report !sn2 or !summit hardware as an error [IA64] gensparse_defconfig: turn on PNPACPI [IA64] Increase severity of MCA recovery messages
2006-03-08Merge branch 'work-fixes'Mauro Carvalho Chehab
2006-03-08V4L/DVB (3413): Typos grab bag of the monthAlexey Dobriyan
Typos grab bag of the month. Eyeballed by jmc@ in OpenBSD. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-08V4L/DVB (3403): Workaround to fix initialization for Nexus CAMarco Schluessler
Workaround for Nexus CA: Debi test fails unless first debi write is repeated. Signed-off-by: Marco Schluessler <marco@lordzodiac.de> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-07Merge master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-serial: [SERIAL] ip22zilog: Fix oops on runlevel change with serial console [SERIAL] Fix two bugs in parport_serial
2006-03-07[IA64] SGI SN drivers: don't report !sn2 hardware as an errorBjorn Helgaas
This stuff is all in the generic ia64 kernel, and the new initcall error reporting complains about them. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-07[SERIAL] ip22zilog: Fix oops on runlevel change with serial consoleMartin Michlmayr
Incorrect uart_write_wakeup() calls cause reference to a NULL tty pointer. This has been fixed in the sunsab and sunzilog serial drivers in October 2005. Update the ip22zilog, which is based on sunzilog, accordingly. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk
2006-03-06[TG3]: Add DMA address workaroundMichael Chan
Add DMA workaround for chips that do not support full 64-bit DMA addresses. 5714, 5715, and 5780 chips only support DMA addresses less than 40 bits. On 64-bit systems with IOMMU, set the dma_mask to 40-bit so that pci_map_xxx() calls will map the DMA address below 40 bits if necessary. On 64-bit systems without IOMMU, set the dma_mask to 64-bit and check for DMA addresses exceeding the limit in tg3_start_xmit(). 5788 only supports 32-bit DMA so need to set the mask appropriately also. Thanks to Chris Elmquist at SGI for reporting and helping to debug the problem on 5714. Thanks to David Miller for explaining the HIGHMEM and DMA stuff. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-06Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: IB/srp: Don't send task management commands after target removal
2006-03-06[PATCH] s390: improve response code handling in chsc_enable_facility()Cornelia Huck
Rather than checking for some known failures, check positively for the success response code 0x0001 and return -EIO for unrecognized failure response codes. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Greg Smith <gsmith@nc.rr.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-06[PATCH] windfarm license fixBenjamin Herrenschmidt
The Windfarm PID module lacks a licence, it should be GPL, here it is Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-06[PATCH] i4l: fix compatiblity issue with big endian systemsKarsten Keil
This patch fix some compatiblity issues with big endian systems Signed-off-by: Martin Bachem <info@colognechip.com> Signed-off-by: Karsten Keil <kkeil@suse.de> Cc: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
