path: root/firmware/WHENCE
2008-07-14firmware: convert sb16_csp driver to use firmware loader exclusivelyJaswinder Singh
Signed-off-by: Jaswinder Singh <jaswinder@infradead.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-14dsp56k: use request_firmwareJaswinder Singh
2008-07-14edgeport-ti: use request_firmware()Jaswinder Singh
Firmware blob looks like this... uint8_t MajorVersion uint8_t MinorVersion __le16 BuildNumber uint8_t data[] Signed-off-by: Jaswinder Singh <jaswinder@infradead.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-14edgeport: use request_firmware()Jaswinder Singh
Version number provided in first HEX record. Signed-off-by: Jaswinder Singh <jaswinder@infradead.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-14vicam: use request_firmware()Jaswinder Singh
Although it wasn't actually using ihex records before, we use the Intel HEX record format for this firmware -- because that gives us a simple way to split it into separate chunks internally as we need, without loading each part as a separate file. Signed-off-by: Jaswinder Singh <jaswinder@infradead.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-14dabusb: use request_firmware()David Woodhouse
2008-07-14cpia2: use request_firmware()David Woodhouse
Thanks for Jaswinder Singh for converting the firmware blob itself to ihex. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-10ip2: use request_firmware()David Woodhouse
Converted with help from Jaswinder Singh Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Alan Cox <alan@redhat.com>
2008-07-10whiteheat: use request_firmware()David Woodhouse
2008-07-10ti_usb_3410_5052: use request_firmware()David Woodhouse
2008-07-10emi62: use request_firmware()David Woodhouse
2008-07-10emi26: use request_firmware()David Woodhouse
2008-07-10keyspan_pda: use request_firmware()David Woodhouse
2008-07-10keyspan: use request_firmware()David Woodhouse
2008-07-10ttusb-budget: use request_firmware()David Woodhouse
Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-10kaweth: use request_firmware()David Woodhouse
2008-07-10smctr: use request_firmware()David Woodhouse
2008-07-10firmware: convert ymfpci driver to use firmware loader exclusivelyDavid Woodhouse
2008-07-10firmware: convert maestro3 driver to use firmware loader exclusivelyDavid Woodhouse
2008-07-10firmware: convert korg1212 driver to use firmware loader exclusivelyDavid Woodhouse
