path: root/firmware
2012-07-30ENGR00218013-6 SDMA:Add HDMI script in SDMA firmwareChen Liangjun
Add support for hdmi-sdma script content in sdma firmware. Signed-off-by: Chen Liangjun <b36089@freescale.com>
2012-07-20ENGR00211678 - SPDC : update Sipix AUO panel firmwareFugang Duan
- The original waveform mode4 refresh action is not expected, and the waveform file resolve the issue. Signed-off-by: Fugang Duan <B38611@freescale.com>
2012-07-20ENGR00210075-5 - SPDC: Add waveform file for AUO paper panelFugang Duan
- Add waveform firmware file for AUO paper panel Signed-off-by: Fugang Duan <B38611@freescale.com>
2012-07-20ENGR00179498-1 SDMA: fix p2p sdma script errorChen Liangjun
The p2p script in SDMA binary file is invalid. The ESAI call ASRC can't work properly with this firmware. Update the firmware and script address. Signed-off-by: Chen Liangjun <b36089@freescale.com>
2012-07-20ENGR00174886-2 - EPDC fb: Don't register EPDC unless "epdc" kernel option setDanny Nold
- EPDC firmware build was breaking due to binary build pre-empting the conversion from .fw.ihex->.fw. Resolve this by forcing firmware objects to be built in order. Signed-off-by: Danny Nold <dannynold@freescale.com>
2012-07-20ENGR00174106-2 - EPDC fb: Add waveform file for E Ink Pearl panelDanny Nold
- Added waveform firmware file for E Ink Pearl panel Signed-off-by: Danny Nold <dannynold@freescale.com>
2012-07-20ENGR00170465-1 MX6Q/SDMA : update the SDMA script for UART RXHuang Shijie
The old script does not clear the IDLE flag. So when the IDDMAEN(UCR4[6]) is enabled, the RX only receives few bytes(such as 2 or 1 byte) per DMA operation. The new script fixes it. Signed-off-by: Huang Shijie <b32955@freescale.com>
2012-07-20ENGR00163603-4 MX6Q SDMA firmware : fix a bug in the UART receiving.Huang Shijie
The uart_to_mcu code in the ROM has bug. The new fireware fixes it. Signed-off-by: Huang Shijie <b32955@freescale.com>
2012-07-20ENGR00152287-2 SDMA: Add SDMA support for MX6QZeng Zhaoming
Add sdma support for mx6q. add mx6 dependency for sdma, and add sdma mx6 firmware. Note: firmware not release by owner, this version only for test. Signed-off-by: Zeng Zhaoming <b32542@freescale.com>
2012-07-20ENGR00142950-7 - EPDC firmware: Port to 2.6.38Danny Nold
- Added firmware/imx/epdc directory - Added EPDC waveform firmware files Signed-off-by: Danny Nold <dannynold@freescale.com>
2012-07-20ENGR00143074 Firmware: Fix firmware build failed in 2.6.38 kernelZeng Zhaoming
Firmware build failed when add ihex format firmware. This regression introduced by d21b2d2fb3a689193cae637d7195512ba8451a63, which wrongly add 'bin-format' firmware. Fix it by revert the wrong commit and convert sdma firmware to ihex. Signed-off-by: Zeng Zhaoming <b32542@freescale.com> Acked-by: Lily Zhang <r58066@freescale.com>
2012-07-20ENGR00141859 Firmware: Fix Kernel build failed with firmware not find errorsZeng Zhaoming
Linux kernel build failed when source and output object separate store. Fix it by add srctree to prefix firmware. Signed-off-by: Zeng Zhaoming <b32542@freescale.com>
2012-07-20ENGR00141732 SDMA: Fix bootup stop at sdma firmware loadingZeng Zhaoming
Linux 2.6.38 kernel bootup slow, it stopped at sdma firmware loading for about one minute. It is caused by firmware store on rootfs lib/firmware directory, while sdma initialization happens before rootfs mounted. To fix it, we have to build firmware in kernel image. Signed-off-by: Zeng Zhaoming <b32542@freescale.com>
2011-07-03isci: Added support for C0 to SCU DriverAdam Gruchala
C0 silicon updates the pci revision id and requires new AFE parameters for phy signal integrity. Support for previous silicon revisions is deprecated (it's also broken for the theoretical case of multiple controllers at different silicon revisions, all the more reason to get it removed as soon as possible) Signed-off-by: Adam Gruchala <adam.gruchala@intel.com> [fixed up deprecated silicon support] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: fix oem parameter header definitionDan Williams
The element_length is 2 bytes. Reported-by: Yinghai Lu <yinghai.lu@oracle.com> Acked-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: fix apc mode definitionDan Williams
The original apc mode definition is the correct one, the fix from commit 4711ba10 "isci: fix oem parameter initialization and mode detection" was based on a typo from a specification update. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: fix oem parameter initialization and mode detectionDan Williams
1/ Since commit 858d4aa7 "isci: Move firmware loading to per PCI device" we have been silently falling back to built-in defaults for the parameter settings by skipping the call to scic_oem_parameters_set(). 2/ The afe parameters from the firmware were not being honored 3/ The latest oem parameter definition flips the mode_type values which are now 0: for APC 1: for MPC. For APC we need to make sure all the phys default to the same address otherwise strict_wide_ports will cause duplicate domains. 4/ Fix up the driver announcement to indicate the source of the parameters. 5/ Fix up the sas addresses to be unique per controller (in the fallback case) Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: add support for 2 more oem parmetersHenryk Dembkowski
1/ add OEM paramater support for mode_type (MPC vs APC) 2/ add OEM parameter support for max_number_concurrent_device_spin_up 3/ cleanup scic_sds_controller_start_next_phy todo: hook up the amp control afe parameters into the afe init code Signed-off-by: Henryk Dembkowski <henryk.dembkowski@intel.com> Signed-off-by: Jacek Danecki <Jacek.Danecki@intel.com> [cleaned up scic_sds_controller_start_next_phy] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: Add support for probing OROM for OEM paramsDan Williams
We need to scan the OROM for signature and grab the OEM parameters. We also need to do the same for EFI. If all fails then we resort to user binary blob, and if that fails then we go to the defaults. Share the format with the create_fw utility so that all possible sources of the parameters are in-sync. Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-02isci: Intel(R) C600 Series Chipset Storage Control Unit DriverDan Williams
Support for the up to 2x4-port 6Gb/s SAS controllers embedded in the chipset. This is a snapshot of the first publicly available version of the driver, commit 4c1db2d0 in the 'historical' branch. git://git.kernel.org/pub/scm/linux/kernel/git/djbw/isci.git historical Signed-off-by: Maciej Trela <maciej.trela@intel.com> Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Edmund Nadolski <edmund.nadolski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-31bnx2x: Update firmware to 6.2.9Dmitry Kravkov
To fix bugs when running offloaded FCoE/iSCSI traffic in multiple Class of Service environments. In some scenarios, traffic could stop on certain rings and eventually all traffic would stop. Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14bnx2: Update firmware and versionMichael Chan
Update 5709 mips firmware to 6.2.1a to fix iSCSI performance regression. There was an unnecessary context read in the fast path affecting performance. Update bnx2 to 2.1.6. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-13ihex: fix unused return value compiler warningChris Ruffin
Fix unusued return value compiler warnings due to unchecked write() calls. [akpm@linux-foundation.org: correctly handle short writes] Signed-off-by: Chris Ruffin <cmruffin@gmail.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-31bnx2: Update firmware and versionMichael Chan
Update MIPS firmware to 6.2.1, with improved small packet performance in RSS mode, and iSCSI CID allocation bug fix on 5708. Update driver version to 2.0.21. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-16bnx2x: remove old FW filesVladislav Zolotarov
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-16bnx2x: replace FW to 6.2.5Vladislav Zolotarov
Includes FCoE releated fixes in FW flows Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-16bnx2x: add FW 6.2.5 filesVladislav Zolotarov
2010-10-26ihex: add support for CS:IP/EIP recordsMark Brown
ihex firmwares can include a jump address for starting execution. Add a -j option which will cause this to be written into the generated file as a record with address zero and data consisting of the address to jump to, allowing drivers to make use of this information. This format is chosen because it most closely follows the original ihex format, though it may make more sense to write a record with length zero and the address stored as the address. The records are not omitted by default since our ihex format does not include record type information and so including additional records may lead to confusion. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-11bnx2: Update firmware to 6.0.x.Michael Chan
- Improved flow control and simplified interface - Use hardware RSS indirection table instead of the slower firmware- based table - Lower latency interrupt on 5709 Signed-off-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x: Add 57712 supportDmitry Kravkov
57712 HW supported with same set of features as for 57710/57711 Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x: remove old FW filesDmitry Kravkov
2010-10-06bnx2x, cnic, bnx2i: use new FW/HSIDmitry Kravkov
This is the new FW HSI blob and the relevant definitions without logic changes. It also included code adaptation for new HSI. New features are not enabled. New FW/HSI includes: - Support for 57712 HW - Future support for VF (not used) - Improvements in FW interrupts scheme - FW FCoE hooks (stubs for future usage) Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x: add 6.0.34 fw filesDmitry Kravkov
New firmware files for all bnx2x devices Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x: create folder for bnx2x firmware filesDmitry Kravkov
2010-08-20Merge commit 'v2.6.36-rc1' into kbuild/rc-fixesMichal Marek
2010-08-17fixes for using make 3.82Jan Beulich
It doesn't like pattern and explicit rules to be on the same line, and it seems to be more picky when matching file (or really directory) names with different numbers of trailing slashes. Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Andrew Benton <b3nton@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits) phy/marvell: add 88ec048 support igb: Program MDICNFG register prior to PHY init e1000e: correct MAC-PHY interconnect register offset for 82579 hso: Add new product ID can: Add driver for esd CAN-USB/2 device l2tp: fix export of header file for userspace can-raw: Fix skb_orphan_try handling Revert "net: remove zap_completion_queue" net: cleanup inclusion phy/marvell: add 88e1121 interface mode support u32: negative offset fix net: Fix a typo from "dev" to "ndev" igb: Use irq_synchronize per vector when using MSI-X ixgbevf: fix null pointer dereference due to filter being set for VLAN 0 e1000e: Fix irq_synchronize in MSI-X case e1000e: register pm_qos request on hardware activation ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice net: Add getsockopt support for TCP thin-streams cxgb4: update driver version cxgb4: add new PCI IDs ... Manually fix up conflicts in: - drivers/net/e1000e/netdev.c: due to pm_qos registration infrastructure changes - drivers/net/phy/marvell.c: conflict between adding 88ec048 support and cleaning up the IDs - drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req conflict (registration change vs marking it static)
2010-07-08IB/qib: Use request_firmware() to load SD7220 firmwareBen Hutchings
Extract the microcode for the QLogic QLE7220 series IB HCA and use the kernel microcode request facility to load the microcode. This supports Debian Linux's requirements to separate microcode which doesn't have open source code available from the device driver. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-06-25cxgb3: update FW to 7.10Divy Le Ray
Update FW to 7.10 Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17bnx2: Update 5709 MIPS firmware and version to 2.0.15.Michael Chan
New firmware fixes a performance regression on small packets. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-03bnx2x: Removed FW 5.2.7Vladislav Zolotarov
Removed FW 5.2.7. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17bnx2x: Use firmware 5.2.13Vladislav Zolotarov
Switch to the new firmware version (5.2.13). Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17bnx2x: FW 5.2.13Vladislav Zolotarov
New firmware version (5.2.13). Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16bnx2: Update firmwares and update version to 2.0.8.Michael Chan
- Increase FTQ depth to 256 to ehnabce performance. - Fix RV2P context corruption on 5709 when flow control is enabled. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06pcnet_cs: add cis of KTI PE520 pcmcia network cardKen Kawasaki
pcnet_cs,serial_cs: add cis of KTI PE520 pcmcia network card, and serial card(Sierra Wireless AC860). Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/cdc_ether.c All CDC ethernet devices of type USB_CLASS_COMM need to use '&mbm_info'. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29pcnet_cs: add cis of PreMax PE-200 ethernet pcmcia cardKen Kawasaki
pcnet_cs,serial_cs: add cis of PreMax ethernet pcmcia card, and some Sierra Wireless serial card(AC555, AC7xx, AC8xx). use PROD_ID for AC7xx, because MANF_ID of AC7xx and AC8xx are the same. Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Remove old FW filesEilon Greenstein
