path: root/firmware
2011-03-31bnx2x: Update firmware to 6.2.9Dmitry Kravkov
To fix bugs when running offloaded FCoE/iSCSI traffic in multiple Class of Service environments. In some scenarios, traffic could stop on certain rings and eventually all traffic would stop. Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14bnx2: Update firmware and versionMichael Chan
Update 5709 mips firmware to 6.2.1a to fix iSCSI performance regression. There was an unnecessary context read in the fast path affecting performance. Update bnx2 to 2.1.6. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-13ihex: fix unused return value compiler warningChris Ruffin
Fix unusued return value compiler warnings due to unchecked write() calls. [akpm@linux-foundation.org: correctly handle short writes] Signed-off-by: Chris Ruffin <cmruffin@gmail.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-31bnx2: Update firmware and versionMichael Chan
Update MIPS firmware to 6.2.1, with improved small packet performance in RSS mode, and iSCSI CID allocation bug fix on 5708. Update driver version to 2.0.21. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-16bnx2x: remove old FW filesVladislav Zolotarov
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-16bnx2x: replace FW to 6.2.5Vladislav Zolotarov
Includes FCoE releated fixes in FW flows Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-16bnx2x: add FW 6.2.5 filesVladislav Zolotarov
2010-10-26ihex: add support for CS:IP/EIP recordsMark Brown
ihex firmwares can include a jump address for starting execution. Add a -j option which will cause this to be written into the generated file as a record with address zero and data consisting of the address to jump to, allowing drivers to make use of this information. This format is chosen because it most closely follows the original ihex format, though it may make more sense to write a record with length zero and the address stored as the address. The records are not omitted by default since our ihex format does not include record type information and so including additional records may lead to confusion. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-11bnx2: Update firmware to 6.0.x.Michael Chan
- Improved flow control and simplified interface - Use hardware RSS indirection table instead of the slower firmware- based table - Lower latency interrupt on 5709 Signed-off-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x: Add 57712 supportDmitry Kravkov
57712 HW supported with same set of features as for 57710/57711 Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x: remove old FW filesDmitry Kravkov
2010-10-06bnx2x, cnic, bnx2i: use new FW/HSIDmitry Kravkov
This is the new FW HSI blob and the relevant definitions without logic changes. It also included code adaptation for new HSI. New features are not enabled. New FW/HSI includes: - Support for 57712 HW - Future support for VF (not used) - Improvements in FW interrupts scheme - FW FCoE hooks (stubs for future usage) Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x: add 6.0.34 fw filesDmitry Kravkov
New firmware files for all bnx2x devices Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x: create folder for bnx2x firmware filesDmitry Kravkov
2010-08-20Merge commit 'v2.6.36-rc1' into kbuild/rc-fixesMichal Marek
2010-08-17fixes for using make 3.82Jan Beulich
It doesn't like pattern and explicit rules to be on the same line, and it seems to be more picky when matching file (or really directory) names with different numbers of trailing slashes. Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Andrew Benton <b3nton@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits) phy/marvell: add 88ec048 support igb: Program MDICNFG register prior to PHY init e1000e: correct MAC-PHY interconnect register offset for 82579 hso: Add new product ID can: Add driver for esd CAN-USB/2 device l2tp: fix export of header file for userspace can-raw: Fix skb_orphan_try handling Revert "net: remove zap_completion_queue" net: cleanup inclusion phy/marvell: add 88e1121 interface mode support u32: negative offset fix net: Fix a typo from "dev" to "ndev" igb: Use irq_synchronize per vector when using MSI-X ixgbevf: fix null pointer dereference due to filter being set for VLAN 0 e1000e: Fix irq_synchronize in MSI-X case e1000e: register pm_qos request on hardware activation ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice net: Add getsockopt support for TCP thin-streams cxgb4: update driver version cxgb4: add new PCI IDs ... Manually fix up conflicts in: - drivers/net/e1000e/netdev.c: due to pm_qos registration infrastructure changes - drivers/net/phy/marvell.c: conflict between adding 88ec048 support and cleaning up the IDs - drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req conflict (registration change vs marking it static)
2010-07-08IB/qib: Use request_firmware() to load SD7220 firmwareBen Hutchings
Extract the microcode for the QLogic QLE7220 series IB HCA and use the kernel microcode request facility to load the microcode. This supports Debian Linux's requirements to separate microcode which doesn't have open source code available from the device driver. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-06-25cxgb3: update FW to 7.10Divy Le Ray
Update FW to 7.10 Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17bnx2: Update 5709 MIPS firmware and version to 2.0.15.Michael Chan
New firmware fixes a performance regression on small packets. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-03bnx2x: Removed FW 5.2.7Vladislav Zolotarov
Removed FW 5.2.7. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17bnx2x: Use firmware 5.2.13Vladislav Zolotarov
Switch to the new firmware version (5.2.13). Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17bnx2x: FW 5.2.13Vladislav Zolotarov
New firmware version (5.2.13). Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16bnx2: Update firmwares and update version to 2.0.8.Michael Chan
- Increase FTQ depth to 256 to ehnabce performance. - Fix RV2P context corruption on 5709 when flow control is enabled. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06pcnet_cs: add cis of KTI PE520 pcmcia network cardKen Kawasaki
pcnet_cs,serial_cs: add cis of KTI PE520 pcmcia network card, and serial card(Sierra Wireless AC860). Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/cdc_ether.c All CDC ethernet devices of type USB_CLASS_COMM need to use '&mbm_info'. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29pcnet_cs: add cis of PreMax PE-200 ethernet pcmcia cardKen Kawasaki
pcnet_cs,serial_cs: add cis of PreMax ethernet pcmcia card, and some Sierra Wireless serial card(AC555, AC7xx, AC8xx). use PROD_ID for AC7xx, because MANF_ID of AC7xx and AC8xx are the same. Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Remove old FW filesEilon Greenstein
2009-10-15bnx2x: Allowing 0 as initial fairness valueEilon Greenstein
Value of zero was used to disable the fairness mechanism. Though the code (driver and FW) allowed changing the value at run time, it did not allow to do that if the mechanism was disabled to begin with. Fixed the FW to allow turning on and off the mechanism at run time. Fixed the code to read the value from the chip at the right sequence. Without this fix, if the initial value was set to zero, traffic could not run on the interface. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Add FW 5.2.7Eilon Greenstein
2009-10-05pcnet_cs: add cis of National Semicondoctor's multifunction pcmcia cardKen Kawasaki
pcnet_cs,serial_cs: add cis of National Semicondoctor's lan&modem mulitifunction pcmcia card, NE2K, tamarack ethernet card, and some serial card(COMpad2, COMpad4). Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-23Documentation/: fix warnings from -Wmissing-prototypes in HOSTCFLAGSLadinu Chandrasinghe
Fix up -Wmissing-prototypes in compileable userspace code, mainly under Documentation/. Signed-off-by: Ladinu Chandrasinghe <ladinu.pub@gmail.com> Signed-off-by: Trevor Keith <tsrk@tsrk.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (133 commits) drm/vgaarb: add VGA arbitration support to the drm and kms. drm/radeon: some r420s have a CP race with the DMA engine. drm/radeon/r600/kms: rv670 is not DCE3 drm/radeon/kms: r420 idle after programming GA_ENHANCE drm/radeon/kms: more fixes to rv770 suspend/resume path. drm/radeon/kms: more alignment for rv770.c with r600.c drm/radeon/kms: rv770 blit init called too late. drm/radeon/kms: move around new init path code to avoid posting at init drm/radeon/r600: fix some issues with suspend/resume. drm/radeon/kms: disable VGA rendering engine before taking over VRAM drm/radeon/kms: Move radeon_get_clock_info() call out of radeon_clocks_init(). drm/radeon/kms: add initial connector properties drm/radeon/kms: Use surfaces for scanout / cursor byte swapping on big endian. drm/radeon/kms: don't fail if we fail to init GPU acceleration drm/r600/kms: fixup number of loops per blit calculation. drm/radeon/kms: reprogram format in set base. drm/radeon: avivo chips have no separate int bit for display drm/radeon/r600: don't do interrupts drm: fix _DRM_GEM addmap error message drm: update crtc x/y when only fb changes ... Fixed up trivial conflicts in firmware/Makefile due to network driver (cxgb3) and drm (mga/r128/radeon) firmware being listed next to each other.
2009-09-15pcnet_cs: add cis of Linksys multifunction pcmcia cardKen Kawasaki
pcnet_cs,serial_cs: add cis of Linksys lan&modem mulitifunction pcmcia card and some modem card(MT5634ZLX, RS-COM-2P). Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-31radeon: Use request_firmware()Ben Hutchings
Loosely based on a patch by Jaswinder Singh Rajput <jaswinderlinux@gmail.com>. KMS support by Dave Airlie <airlied@redhat.com>. For Radeon 100- to 500-series, firmware blobs look like: struct { __be32 datah; __be32 datal; } cp_ucode[256]; For Radeon 600-series, there are two separate firmware blobs: __be32 me_ucode[PM4_UCODE_SIZE * 3]; __be32 pfp_ucode[PFP_UCODE_SIZE]; For Radeon 700-series, likewise: __be32 me_ucode[R700_PM4_UCODE_SIZE]; __be32 pfp_ucode[R700_PFP_UCODE_SIZE]; Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-29bnx2: Update firmware to 5.0.0.j3.Michael Chan
- Better small packet receive performance. - Better handling of Flow control on 5709. - Fixed iSCSI TMP ABORT TASK problem. - Added iSCSI TCP timestamp option. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-27drm/r128: Use request_firmware() to load CCE microcodeBen Hutchings
Firmware blob looks like this: __be32 datah __be32 datal Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-27drm/mga: Use request_firmware() to load microcodeBen Hutchings
Image format is IHEX, one record for each pipe in order (record addresses are ignored). Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-12bnx2x: Removing old FW filesEilon Greenstein
2009-08-12bnx2x: Using the new FWEilon Greenstein
The new FW improves the packets per second rate. It required a lot of change in the FW which implies many changes in the driver to support it. It is now also possible for the driver to use a separate MSI-X vector for Rx and Tx - this also add some to the complicity of this change. All things said - after this patch, practically all performance matrixes show improvement. Though Vladislav Zolotarov is not signed on this patch, he did most of the job and deserves credit for that. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12bnx2x: New FW filesEilon Greenstein
2009-07-08cxgb3: use request_firmware() for the EDC registers setupDivy Le Ray
use request_firmware() to load the phy's EDC programmation Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03cxgb3: Update FW to 7.4.0Divy Le Ray
Update FW to 7.4. Bump up driver revision. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/forcedeth.c
2009-05-29net/firmare: Ignore .cis filesMatt Kraai
Signed-off-by: Matt Kraai <kraai@ftbfs.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-013c589_cs: add cis(firmware) of 3Com multifunction pcmcia cardKen Kawasaki
3c589_cs,3c574_cs,serial_cs: (1)add cis(firmware) of 3Com lan&modem mulitifunction pcmcia card. (2)load correct configuration register for 3Com card Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27bnx2x: Separated FW from the source.Vladislav Zolotarov
>From now on FW will be downloaded from the binary file using request_firmware. There will be different files for every supported chip. Currently 57710 (e1) and 57711 (e1h). File names have the following format: bnx2x-<chip version>-<FW version>.fw. ihex versions of current FW files are submitted in the next patch. Each binary file has a header in the following format: struct bnx2x_fw_file_section { __be32 len; __be32 offset; } struct bnx2x_fw_file_hdr { struct bnx2x_fw_file_section init_ops; struct bnx2x_fw_file_section init_ops_offsets; struct bnx2x_fw_file_section init_data; struct bnx2x_fw_file_section tsem_int_table_data; struct bnx2x_fw_file_section tsem_pram_data; struct bnx2x_fw_file_section usem_int_table_data; struct bnx2x_fw_file_section usem_pram_data; struct bnx2x_fw_file_section csem_int_table_data; struct bnx2x_fw_file_section csem_pram_data; struct bnx2x_fw_file_section xsem_int_table_data; struct bnx2x_fw_file_section xsem_pram_data; struct bnx2x_fw_file_section fw_version; } Each bnx2x_fw_file_section contains the length and the offset of the appropriate section in the binary file. Values are stored in the big endian format. Data types of arrays: init_data __be32 init_ops_offsets __be16 XXsem_pram_data u8 XXsem_int_table_data u8 init_ops struct raw_op { u8 op; __be24 offset; __be32 data; } fw_version u8 >From now boundaries of a specific initialization stage are stored in init_ops_offsets array instead of being defined by separate macroes. The index in init_ops_offsets is calculated by BLOCK_OPS_IDX macro: #define BLOCK_OPS_IDX(block, stage, end) \ (2*(((block)*STAGE_IDX_MAX) + (stage)) + (end)) Security: In addition to sanity check of array boundaries bnx2x will check a FW version. Additional checks might be added in the future. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27bnx2x: FW 4.8.53.0Vladislav Zolotarov
