path: root/firmware
2009-07-08cxgb3: use request_firmware() for the EDC registers setupDivy Le Ray
use request_firmware() to load the phy's EDC programmation Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03cxgb3: Update FW to 7.4.0Divy Le Ray
Update FW to 7.4. Bump up driver revision. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/forcedeth.c
2009-05-29net/firmare: Ignore .cis filesMatt Kraai
Signed-off-by: Matt Kraai <kraai@ftbfs.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-013c589_cs: add cis(firmware) of 3Com multifunction pcmcia cardKen Kawasaki
3c589_cs,3c574_cs,serial_cs: (1)add cis(firmware) of 3Com lan&modem mulitifunction pcmcia card. (2)load correct configuration register for 3Com card Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27bnx2x: Separated FW from the source.Vladislav Zolotarov
>From now on FW will be downloaded from the binary file using request_firmware. There will be different files for every supported chip. Currently 57710 (e1) and 57711 (e1h). File names have the following format: bnx2x-<chip version>-<FW version>.fw. ihex versions of current FW files are submitted in the next patch. Each binary file has a header in the following format: struct bnx2x_fw_file_section { __be32 len; __be32 offset; } struct bnx2x_fw_file_hdr { struct bnx2x_fw_file_section init_ops; struct bnx2x_fw_file_section init_ops_offsets; struct bnx2x_fw_file_section init_data; struct bnx2x_fw_file_section tsem_int_table_data; struct bnx2x_fw_file_section tsem_pram_data; struct bnx2x_fw_file_section usem_int_table_data; struct bnx2x_fw_file_section usem_pram_data; struct bnx2x_fw_file_section csem_int_table_data; struct bnx2x_fw_file_section csem_pram_data; struct bnx2x_fw_file_section xsem_int_table_data; struct bnx2x_fw_file_section xsem_pram_data; struct bnx2x_fw_file_section fw_version; } Each bnx2x_fw_file_section contains the length and the offset of the appropriate section in the binary file. Values are stored in the big endian format. Data types of arrays: init_data __be32 init_ops_offsets __be16 XXsem_pram_data u8 XXsem_int_table_data u8 init_ops struct raw_op { u8 op; __be24 offset; __be32 data; } fw_version u8 >From now boundaries of a specific initialization stage are stored in init_ops_offsets array instead of being defined by separate macroes. The index in init_ops_offsets is calculated by BLOCK_OPS_IDX macro: #define BLOCK_OPS_IDX(block, stage, end) \ (2*(((block)*STAGE_IDX_MAX) + (stage)) + (end)) Security: In addition to sanity check of array boundaries bnx2x will check a FW version. Additional checks might be added in the future. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27bnx2x: FW 4.8.53.0Vladislav Zolotarov
2009-04-21pcnet_cs: add cis(firmware) of the Allied Telesis LA-PCMKen Kawasaki
pcnet_cs: add cis(firmware) of the Allied Telesis LA-PCM Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-10Merge git://git.infradead.org/~dwmw2/firmware-2.6Linus Torvalds
* git://git.infradead.org/~dwmw2/firmware-2.6: qla1280: Fix off-by-some error in firmware loading. Add README.AddingFirmware file. Basically telling people not to. firmware: Remove newly-added slicoss and sxg firmware images firmware/WHENCE: Add missing origin information for Ambassador atmsar11.fw ALSA: wavefront - Always use request_firmware() Remove fdump tool for av7110 firmware firmware: convert av7110 driver to request_firmware() Partially revert "V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card" Revert "fix modules_install via NFS" Add-add conflicts in firmware/WHENCE fixed manually
2009-04-06Add README.AddingFirmware file. Basically telling people not to.David Woodhouse
2009-04-06firmware: Remove newly-added slicoss and sxg firmware imagesDavid Woodhouse
These are available elsewhere (for example in the linux-firmware.git repository); they have no business being added to the kernel source tree. We are only putting stuff in the firmware/ directory of the kernel source when it's extracted from long-standing drivers which used to include it directly. We didn't intend to open the floodgates to including megabytes of new firmware which was previously being distributed separately. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: b44: Use kernel DMA addresses for the kernel DMA API forcedeth: Fix resume from hibernation regression. xfrm: fix fragmentation on inter family tunnels ibm_newemac: Fix dangerous struct assumption gigaset: documentation update gigaset: in file ops, check for device disconnect before anything else bas_gigaset: use tasklet_hi_schedule for timing critical tasklets net/802/fddi.c: add MODULE_LICENSE smsc911x: remove unused #include <linux/version.h> axnet_cs: fix phy_id detection for bogus Asix chip. bnx2: Use request_firmware() b44: Fix sizes passed to b44_sync_dma_desc_for_{device,cpu}() socket: use percpu_add() while updating sockets_in_use virtio_net: Set the mac config only when VIRITO_NET_F_MAC myri_sbus: use request_firmware e1000: fix loss of multicast packets vxge: should include tcp.h Conflict in firmware/WHENCE (SCSI vs net firmware)
2009-04-06firmware/WHENCE: Add missing origin information for Ambassador atmsar11.fwDavid Woodhouse
Looks like we forgot to update WHENCE when we converted this driver. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06ALSA: wavefront - Always use request_firmware()Takashi Iwai
Always use request_firmware() for loading yss225_registers image. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06firmware: convert av7110 driver to request_firmware()Jaswinder Singh
Signed-off-by: Jaswinder Singh <jaswinder@infradead.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06Partially revert "V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 ↵David Woodhouse
DVB-S PCI card" This reverts a hunk of commit 4b29631db33292d416dc395c56122ea865e7635c which seems to have been an accident, and which re-introduced a previously fixed bug. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06Revert "fix modules_install via NFS"David Woodhouse
This reverts commit 8b249b6856f16f09b0e5b79ce5f4d435e439b9d6. This 'fix' is not necessary; we just need to undo the damage caused accidentally by Igor/Mauro in 4b29631db33292d416dc395c56122ea865e7635c ("V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card") Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (74 commits) [SCSI] sg: fix q->queue_lock on scsi_error_handler path [SCSI] replace __inline with inline [SCSI] a2091: make 2 functions static [SCSI] a3000: make 2 functions static [SCSI] ses: #if 0 the unused ses_match_host() [SCSI] use kmem_cache_zalloc instead of kmem_cache_alloc/memset [SCSI] sg: fix iovec bugs introduced by the block layer conversion [SCSI] qlogicpti: use request_firmware [SCSI] advansys: use request_firmware [SCSI] qla1280: use request_firmware [SCSI] libiscsi: fix iscsi pool error path [SCSI] cxgb3i: call ddp release function directly [SCSI] cxgb3i: merge cxgb3i_ddp into cxgb3i module [SCSI] cxgb3i: close all tcp connections upon chip reset [SCSI] cxgb3i: re-read ddp settings information after chip reset [SCSI] cxgb3i: re-initialize ddp settings after chip reset [SCSI] cxgb3i: subscribe to error notification from cxgb3 driver [SCSI] aacraid driver update [SCSI] mptsas: remove unneeded check [SCSI] config: Make need for SCSI_CDROM clearer ...
2009-04-04bnx2: Use request_firmware()Michael Chan
Based on original patch by Ben Hutchings <ben@decadent.org.uk> and Bastian Blank <waldi@debian.org>, with the following main changes: Separated the mips firmware and rv2p firmware into different files to make it easier to update them separately. Added some code to fixup the rv2p code with run-time information such as PAGE_SIZE. Update version to 2.0.0. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-04myri_sbus: use request_firmwareJaswinder Singh Rajput
Firmware blob looks like this... __be16 lanai4_data_size unsigned char lanai4_code[] Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-03Staging: sxg: slicoss: Specify the license for Sahara SXG and Slicoss driversMithlesh Thukral
Specify a license for the Alacritech Sahara (10Gbe) and SLICOSS (1GBE) firmware files. Signed-off-by: Christopher Harrer <charrer@alacritech.com> Signed-off-by: Mithlesh Thukral <mithlesh@linsyssoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-03Staging: sxg: Add support to download the firmware using request_firmware()Mithlesh Thukral
Add support for downloading the firmware using kernel-builtin mechanism. This will remove the need for the firmware files in the driver source code. Signed-off-by: Christopher Harrer <charrer@alacritech.com> Signed-off-by: Mithlesh Thukral <mithlesh@linsyssoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-03Staging: slicoss: add binary firmware to firmware directoryLior Dotan
Adds the firmware to the firmware directory in ihex format so it can be installed when doing make firmware_install. Also update the firmware location in the driver code so it can locate the files in the right place. This should conclude the move to request_firmware(). Signed-off-by: Lior Dotan <liodot@gmail.com> Cc: Christopher Harrer <charrer@alacritech.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-03[SCSI] qlogicpti: use request_firmwareJaswinder Singh Rajput
Firmware blob is little endian Thanks to Stephen Rothwell for fixing typos Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] advansys: use request_firmwareJaswinder Singh Rajput
Firmware blob looks like this... __le32 checksum unsigned char data[] Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] qla1280: use request_firmwareJaswinder Singh Rajput
Firmware blob is little endian looks like this... unsigned char Version1 unsigned char Version2 unsigned char Version3 unsigned char Padding unsigned short start_address unsigned short data Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-30smc91c92_cs: use request_firmwareJaswinder Singh Rajput
Added osi_load_firmware() instead of copying same thing twice Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2009-03-303C359: use request_firmwareJaswinder Singh Rajput
2009-03-30yam: use request_firmwareJaswinder Singh Rajput
Added predef variable in add_mcs() to support predefined mcs data Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2009-03-13cxgb3: update FWDivy Le Ray
Update FW to 7.1 Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26typhoon: Use request_firmware()Ben Hutchings
Based on a patch by Jaswinder Singh <jaswinder@infradead.org>. Compile-tested only. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26tehuti: Use request_firmware()Ben Hutchings
Firmware blob is little endian. Compile-tested only. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12ti_usb_3410_5052: add Multi-Tech firmwareChris Adams
Add the Multi-Tech cellular modem firmware to the TI USB serial driver. This firmware was extracted from: ftp://ftp.multitech.com/wireless/wireless_linux.zip Firmware licence: "all firmware components are redistributable in binary form" per support@multitech.com Copyright (C) 2005 Multi-Tech Systems, Inc. Signed-off-by: Chris Adams <cmadams@hiwaay.net> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2009-01-07firmware: convert e100 driver to request_firmware()Jaswinder Singh Rajput
Thanks to David Woodhouse for help. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-07fix modules_install via NFSSam Ravnborg
Rafael reported: I get the following error from 'make modules_install' on my test boxes: HOSTCC firmware/ihex2fw /home/rafael/src/linux-2.6/firmware/ihex2fw.c:268: fatal error: opening dependency file firmware/.ihex2fw.d: Read-only file system compilation terminated. make[3]: *** [firmware/ihex2fw] Error 1 make[2]: *** [_modinst_post] Error 2 make[1]: *** [sub-make] Error 2 make: *** [all] Error 2 where the configuration is that the kernel is compiled on a build box with 'make O=<destdir> -j5' and then <destdir> is mounted over NFS read-only by each test box (full path to this directory is the same on the build box and on the test boxes). Then, I cd into <destdir>, run 'make modules_install' and get the error above. The issue turns out to be that we when we install firmware pick up the list of firmware blobs from firmware/Makefile. And this triggers the Makefile rules to update ihex2fw. There were two solutions for this issue: 1) Move the list of firmware blobs to a separate file 2) Avoid ihex2fw rebuild by moving it to scripts As I seriously beleive that the list of firmware blobs should be done in a fundamental different way solution 2) was selected. Reported-and-tested-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: David Woodhouse <dwmw2@infradead.org>
2009-01-06make firmware/dsp56k/bootstrap.asm buildable on a56Robert Millan
Make firmware/dsp56k/bootstrap.asm buildable on a56, the free Motorola DSP56001 assembler (http://www.zdomain.com/a56.html). Summary of changes: - Remove '<' and '>' candy (they specify explicit addressing modes, which a56 don't grok, but uses implicitly anyway). - Replace 'move' with 'movem' when accessing program memory. - Rename a few labels to avoid duplicates (which a56 can't handle). Signed-off-by: Robert Millan <rmh@aybabtu.com> Cc: Jaswinder Singh <jaswinder@infradead.org> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (44 commits) qlge: Fix sparse warnings for tx ring indexes. qlge: Fix sparse warning regarding rx buffer queues. qlge: Fix sparse endian warning in ql_hw_csum_setup(). qlge: Fix sparse endian warning for inbound packet control block flags. qlge: Fix sparse warnings for byte swapping in qlge_ethool.c myri10ge: print MAC and serial number on probe failure pkt_sched: cls_u32: Fix locking in u32_change() iucv: fix cpu hotplug af_iucv: Free iucv path/socket in path_pending callback af_iucv: avoid left over IUCV connections from failing connects af_iucv: New error return codes for connect() net/ehea: bitops work on unsigned longs Revert "net: Fix for initial link state in 2.6.28" tcp: Kill extraneous SPLICE_F_NONBLOCK checks. tcp: don't mask EOF and socket errors on nonblocking splice receive dccp: Integrate the TFRC library with DCCP dccp: Clean up ccid.c after integration of CCID plugins dccp: Lockless integration of CCID congestion-control plugins qeth: get rid of extra argument after printk to dev_* conversion qeth: No large send using EDDP for HiperSockets. ...
2009-01-04starfire: use request_firmware()Jaswinder Singh Rajput
Firmware blob is big endian Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-04firmware: convert tg3 driver to request_firmware()Jaswinder Singh Rajput
Firmware blob looks like this... u8 firmware_major u8 firmware_minor u8 firmware_fix u8 pad __be32 start_address __be32 length (total, including BSS sections to be zeroed) data... (in __be32 words, which is native for the firmware) Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-04firmware: convert acenic driver to request_firmware()Jaswinder Singh
We store the firmware in its native big-endian form now, so the loop in ace_copy() is modified to use be32_to_cpup() when writing it out. We can forget the BSS,SBSS sections of the firmware, since we were clearing all the device's RAM anyway. And the text,rodata,data sections can all be loaded as a single chunk since they're contiguous (give or take a few dozen bytes in between). Signed-off-by: Jaswinder Singh <jaswinder@infradead.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Jes Sorensen <jes@sgi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-29V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI cardIgor M. Liplianin
The card based on stv0299 or stv0288 demodulators. Signed-off-by: Igor M. Liplianin <liplianin@me.by> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-26cxgb3: integrate FW and protocol engines in the kernelDivy Le Ray
Include firmware and protocol images in the kernel image if requested Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22cassini: use request_firmwareJaswinder Singh
Firmware blob looks like this... __le16 load_address unsigned char data[] [akpm@linux-foundation.org: include vmalloc.h] Signed-off-by: Jaswinder Singh <jaswinder@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-02Fix modules_install on RO nfs-exported trees.David Woodhouse
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=11355 by avoiding a needless rebuild of the firmware/ihex2fw tool. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-02Fix IHEX firmware generation/loadingMarc Zyngier
Fix both the IHEX firmware generation (len field always null, and EOF marker a byte too short) and loading (struct ihex_binrec needs to be packed to reflect the on-disk structure). Signed-off-by: Marc Zyngier <maz@misterjones.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-16Fix 'make clean' and .gitignore for firmware/ directory.David Woodhouse
Provide a .gitignore file, and fix a typo which prevented some of the generated binary files from being removed on 'make clean'. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Reported-and-tested-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14Fix accidental reference to tg3 firmwareDavid Woodhouse
We're not updating the tg3 driver to use request_firmware() yet, but a reference to its firmware accidentally slipped in as part of commit c4667746 ("dabusb: use request_firmware()"). Remove it again. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Reported-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14firmware: Correct dependency on CONFIG_EXTRA_FIRMWARE_DIRDavid Woodhouse
When CONFIG_EXTRA_FIRMWARE_DIR gets changed, the filename in the .S file (which uses .incbin to include the binary) needs to change. When we renamed the BUILTIN_FIRMWARE_DIR option to EXTRA_FIRMWARE_DIR, we forgot to update the manual dependency in firmware/Makefile, so it was depending on a non-existent file in include/config/ Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14firmware: convert sb16_csp driver to use firmware loader exclusivelyJaswinder Singh
