The old script does not clear the IDLE flag.
So when the IDDMAEN(UCR4[6]) is enabled, the RX only receives few
bytes(such as 2 or 1 byte) per DMA operation.
The new script fixes it.
Signed-off-by: Huang Shijie <b32955@freescale.com>
The uart_to_mcu code in the ROM has bug.
The new fireware fixes it.
Add sdma support for mx6q.
add mx6 dependency for sdma, and add sdma mx6 firmware.
Note: firmware not release by owner, this version only for test.
Signed-off-by: Zeng Zhaoming <b32542@freescale.com>
- Added firmware/imx/epdc directory
- Added EPDC waveform firmware files
Signed-off-by: Danny Nold <dannynold@freescale.com>
Firmware build failed when add ihex format firmware.
This regression introduced by d21b2d2fb3a689193cae637d7195512ba8451a63,
which wrongly add 'bin-format' firmware.
Fix it by revert the wrong commit and convert sdma firmware to ihex.
Acked-by: Lily Zhang <r58066@freescale.com>
Linux kernel build failed when source and output object separate store.
Fix it by add srctree to prefix firmware.
Linux 2.6.38 kernel bootup slow, it stopped at sdma firmware
loading for about one minute.
It is caused by firmware store on rootfs lib/firmware directory,
while sdma initialization happens before rootfs mounted.
To fix it, we have to build firmware in kernel image.
Fix unusued return value compiler warnings due to unchecked write() calls.
[akpm@linux-foundation.org: correctly handle short writes]
Signed-off-by: Chris Ruffin <cmruffin@gmail.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Update MIPS firmware to 6.2.1, with improved small packet performance
in RSS mode, and iSCSI CID allocation bug fix on 5708.
Update driver version to 2.0.21.
Signed-off-by: Michael Chan <mchan@broadcom.com>
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
Includes FCoE releated fixes in FW flows
ihex firmwares can include a jump address for starting execution. Add a
-j option which will cause this to be written into the generated file as a
record with address zero and data consisting of the address to jump to,
allowing drivers to make use of this information.
This format is chosen because it most closely follows the original ihex
format, though it may make more sense to write a record with length zero
and the address stored as the address. The records are not omitted by
default since our ihex format does not include record type information and
so including additional records may lead to confusion.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
- Improved flow control and simplified interface
- Use hardware RSS indirection table instead of the slower firmware-
based table
- Lower latency interrupt on 5709
Reviewed-by: Benjamin Li <benli@broadcom.com>
57712 HW supported with same set of features as for 57710/57711
This is the new FW HSI blob and the relevant definitions without logic changes.
It also included code adaptation for new HSI. New features are not enabled.
New FW/HSI includes:
- Support for 57712 HW
- Future support for VF (not used)
- Improvements in FW interrupts scheme
- FW FCoE hooks (stubs for future usage)
New firmware files for all bnx2x devices
It doesn't like pattern and explicit rules to be on the same line,
and it seems to be more picky when matching file (or really directory)
names with different numbers of trailing slashes.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Andrew Benton <b3nton@gmail.com>
Cc: <stable@kernel.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits)
phy/marvell: add 88ec048 support
igb: Program MDICNFG register prior to PHY init
e1000e: correct MAC-PHY interconnect register offset for 82579
hso: Add new product ID
can: Add driver for esd CAN-USB/2 device
l2tp: fix export of header file for userspace
can-raw: Fix skb_orphan_try handling
Revert "net: remove zap_completion_queue"
net: cleanup inclusion
phy/marvell: add 88e1121 interface mode support
u32: negative offset fix
net: Fix a typo from "dev" to "ndev"
igb: Use irq_synchronize per vector when using MSI-X
ixgbevf: fix null pointer dereference due to filter being set for VLAN 0
e1000e: Fix irq_synchronize in MSI-X case
e1000e: register pm_qos request on hardware activation
ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice
net: Add getsockopt support for TCP thin-streams
cxgb4: update driver version
cxgb4: add new PCI IDs
Manually fix up conflicts in:
- drivers/net/e1000e/netdev.c: due to pm_qos registration
infrastructure changes
- drivers/net/phy/marvell.c: conflict between adding 88ec048 support
and cleaning up the IDs
- drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req
conflict (registration change vs marking it static)
Extract the microcode for the QLogic QLE7220 series IB HCA and use the
kernel microcode request facility to load the microcode. This
supports Debian Linux's requirements to separate microcode which
doesn't have open source code available from the device driver.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Update FW to 7.10
Signed-off-by: Divy Le Ray <divy@chelsio.com>
New firmware fixes a performance regression on small packets.
Removed FW 5.2.7.
Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com>
Switch to the new firmware version (5.2.13).
New firmware version (5.2.13).
- Increase FTQ depth to 256 to ehnabce performance.
- Fix RV2P context corruption on 5709 when flow control is enabled.
pcnet_cs,serial_cs:
add cis of KTI PE520 pcmcia network card,
and serial card(Sierra Wireless AC860).
Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp>
drivers/net/usb/cdc_ether.c
All CDC ethernet devices of type USB_CLASS_COMM need to use
'&mbm_info'.
pcnet_cs,serial_cs:
add cis of PreMax ethernet pcmcia card,
and some Sierra Wireless serial card(AC555, AC7xx, AC8xx).
use PROD_ID for AC7xx, because MANF_ID of AC7xx and AC8xx are the same.
Value of zero was used to disable the fairness mechanism. Though the code
(driver and FW) allowed changing the value at run time, it did not allow to do
that if the mechanism was disabled to begin with.
Fixed the FW to allow turning on and off the mechanism at run time. Fixed the
code to read the value from the chip at the right sequence.
Without this fix, if the initial value was set to zero, traffic could not run on
the interface.
pcnet_cs,serial_cs:
add cis of National Semicondoctor's lan&modem mulitifunction pcmcia card,
NE2K, tamarack ethernet card,
and some serial card(COMpad2, COMpad4).
Fix up -Wmissing-prototypes in compileable userspace code, mainly under
Documentation/.
Signed-off-by: Ladinu Chandrasinghe <ladinu.pub@gmail.com>
Signed-off-by: Trevor Keith <tsrk@tsrk.net>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (133 commits)
drm/vgaarb: add VGA arbitration support to the drm and kms.
drm/radeon: some r420s have a CP race with the DMA engine.
drm/radeon/r600/kms: rv670 is not DCE3
drm/radeon/kms: r420 idle after programming GA_ENHANCE
drm/radeon/kms: more fixes to rv770 suspend/resume path.
drm/radeon/kms: more alignment for rv770.c with r600.c
drm/radeon/kms: rv770 blit init called too late.
drm/radeon/kms: move around new init path code to avoid posting at init
drm/radeon/r600: fix some issues with suspend/resume.
drm/radeon/kms: disable VGA rendering engine before taking over VRAM
drm/radeon/kms: Move radeon_get_clock_info() call out of radeon_clocks_init().
drm/radeon/kms: add initial connector properties
drm/radeon/kms: Use surfaces for scanout / cursor byte swapping on big endian.
drm/radeon/kms: don't fail if we fail to init GPU acceleration
drm/r600/kms: fixup number of loops per blit calculation.
drm/radeon/kms: reprogram format in set base.
drm/radeon: avivo chips have no separate int bit for display
drm/radeon/r600: don't do interrupts
drm: fix _DRM_GEM addmap error message
drm: update crtc x/y when only fb changes
Fixed up trivial conflicts in firmware/Makefile due to network driver
(cxgb3) and drm (mga/r128/radeon) firmware being listed next to each
other.
pcnet_cs,serial_cs:
add cis of Linksys lan&modem mulitifunction pcmcia card
and some modem card(MT5634ZLX, RS-COM-2P).
Loosely based on a patch by
Jaswinder Singh Rajput <jaswinderlinux@gmail.com>.
KMS support by Dave Airlie <airlied@redhat.com>.
For Radeon 100- to 500-series, firmware blobs look like:
struct {
__be32 datah;
__be32 datal;
} cp_ucode[256];
For Radeon 600-series, there are two separate firmware blobs:
__be32 me_ucode[PM4_UCODE_SIZE * 3];
__be32 pfp_ucode[PFP_UCODE_SIZE];
For Radeon 700-series, likewise:
__be32 me_ucode[R700_PM4_UCODE_SIZE];
__be32 pfp_ucode[R700_PFP_UCODE_SIZE];
- Better small packet receive performance.
- Better handling of Flow control on 5709.
- Fixed iSCSI TMP ABORT TASK problem.
- Added iSCSI TCP timestamp option.
Firmware blob looks like this:
__be32 datah
__be32 datal
Image format is IHEX, one record for each pipe in order (record
addresses are ignored).
The new FW improves the packets per second rate. It required a lot of change in
the FW which implies many changes in the driver to support it. It is now also
possible for the driver to use a separate MSI-X vector for Rx and Tx - this also
add some to the complicity of this change.
All things said - after this patch, practically all performance matrixes show
improvement.
Though Vladislav Zolotarov is not signed on this patch, he did most of the job
and deserves credit for that.
use request_firmware() to load the phy's EDC programmation
Update FW to 7.4.
Bump up driver revision.
