path: root/fs/9p/v9fs.h
2013-02-129p: Modify struct v9fs_session_info to use a kuids and kgidsEric W. Biederman
Change struct v9fs_session_info and the code that popluates it to use kuids and kgids. When parsing the 9p mount options convert the dfltuid, dflutgid, and the session uid from the current user namespace into kuids and kgids. Modify V9FS_DEFUID and V9FS_DEFGUID to be kuid and kgid values. Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@gmail.com> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-23fs/9p: Always ask new inode in createAneesh Kumar K.V
This make sure we don't end up reusing the unlinked inode object. The ideal way is to use inode i_generation. But i_generation is not available in userspace always. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: When doing inode lookup compare qid details and inode mode bits.Aneesh Kumar K.V
This make sure we don't use wrong inode from the inode hash. The inode number of the file deleted is reused by the next file system object created and if we only use inode number for inode hash lookup we could end up with wrong struct inode. Also compare inode generation number. Not all Linux file system provide st_gen in userspace. So it could be 0; Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-04-159p: revert tsyncfs related changesAneesh Kumar K.V
Now that we use write_inode to flush server cache related to fid, we don't need tsyncfs either fort dotl or dotu protocols. For dotu this helps to do a more efficient server flush. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-22fs/9p: Add v9fs_dentry2v9sesAneesh Kumar K.V
Add the new static inline and use the same Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-22fs/9p: Fix race in initializing writeback fidAneesh Kumar K.V
When two process open the same file we can end up with both of them allocating the writeback_fid. Add a new mutex which can be used for synchronizing v9fs_inode member values. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Prevent multiple inclusion of same headerAneesh Kumar K.V
Add necessary #ifndef #endif blocks to avoid mulitple inclusion of same headers Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Add support for marking inode attribute invalidAneesh Kumar K.V
With cached mode some of the file system operation result in updating inode attributes (ctime). Add support for marking inode attribute invalid in such cases so that we fetch the updated inode attribute on dentry revalidation. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Move writeback fid to v9fs_inodeAneesh Kumar K.V
2011-03-15fs/9p: Add v9fs_inodeAneesh Kumar K.V
Switch to the fscache code to v9fs_inode. We will later use v9fs_inode in cache=loose mode to track the inode cache validity timeout. Ie if we find an inode in cache older that a specific jiffie range we will consider it stale Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Implement syncfs call back for 9PfsAneesh Kumar K.V
FIXME!! what about dotu ? Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[fs/9P] Add posixacl mount optionVenkateswararao Jujjuri (JV)
The mount option access=client is overloaded as it assumes acl too. Adding posixacl option to enable POSIX ACLs makes it explicit and clear. Also it is convenient in the future to add other types of acls like richacls. Ideally, the access mode 'client' should be just like V9FS_ACCESS_USER except it underscores the location of access check. Traditional 9P protocol lets the server perform access checks but with this mode, all the access checks will be performed on the client itself. Server just follows the client's directive. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-01-11fs/9p: Move dotl inode operations into a seperate fileAneesh Kumar K.V
Source Code Reorganization Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Use V9FS_MAGIC in statfsM. Mohan Kumar
Use V9FS_MAGIC as the file system type while filling kernel statfs strucutre instead of using host file system magic number. Also move the definition of V9FS_MAGIC from v9fs.h to standard magic.h file. Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28fs/9p: Add access = client option to opt in acl evaluation.Aneesh Kumar K.V
2010-08-02fs/9p: Prevent parallel rename when doing fid_lookupAneesh Kumar K.V
During fid lookup we need to make sure that the dentry->d_parent doesn't change so that we can safely walk the parent dentries. To ensure that we need to prevent cross directory rename during fid_lookup. Add a per superblock rename_sem rw_semaphore to prevent parallel fid lookup and rename. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-04-229p: add bdi backing to mount sessionJens Axboe
This ensures that dirty data gets flushed properly. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-059p: Make sure we are able to clunk the cached fid on umountAneesh Kumar K.V
dcache prune happen on umount. So we cannot mark the client satus disconnect. That will prevent a 9p call to the server Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-03-139p: Change the name of new protocol from 9p2010.L to 9p2000.LSripathi Kodi
This patch changes the name of the new 9P protocol from 9p2010.L to 9p2000.u. This is because we learnt that the name 9p2010 is already being used by others. Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-03-059P2010.L handshake: Add VFS flagsSripathi Kodi
Add 9P2000.u and 9P2010.L protocol flags to V9FS VFS This patch adds 9P2000.u and 9P2010.L protocol flags into V9FS VFS side code and removes the single flag used for 'extended'. Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2009-09-239p: Add fscache support to 9pAbhishek Kulkarni
This patch adds a persistent, read-only caching facility for 9p clients using the FS-Cache caching backend. When the fscache facility is enabled, each inode is associated with a corresponding vcookie which is an index into the FS-Cache indexing tree. The FS-Cache indexing tree is indexed at 3 levels: - session object associated with each mount. - inode/vcookie - actual data (pages) A cache tag is chosen randomly for each session. These tags can be read off /sys/fs/9p/caches and can be passed as a mount-time parameter to re-attach to the specified caching session. Signed-off-by: Abhishek Kulkarni <adkulkar@umail.iu.edu> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2009-08-179p: remove unnecessary v9fses->options which duplicates the mount stringAbhishek Kulkarni
The mount options string is saved in sb->s_options. This patch removes the redundant duplicating of the mount options. Also, since we are not displaying anything special in show options, we replace v9fs_show_options with generic_show_options for now. Signed-off-by: Abhishek Kulkarni <adkulkar@umail.iu.edu> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-05-149p: Documentation updatesEric Van Hensbergen
The kernel-doc comments of much of the 9p system have been in disarray since reorganization. This patch fixes those problems, adds additional documentation and a template book which collects the 9p information. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-069p: transport API reorganizationEric Van Hensbergen
This merges the mux.c (including the connection interface) with trans_fd in preparation for transport API changes. Ultimately, trans_fd will need to be rewritten to clean it up and simplify the implementation, but this reorganization is viewed as the first step. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-10-179p: attach-per-userLatchesar Ionkov
The 9P2000 protocol requires the authentication and permission checks to be done in the file server. For that reason every user that accesses the file server tree has to authenticate and attach to the server separately. Multiple users can share the same connection to the server. Currently v9fs does a single attach and executes all I/O operations as a single user. This makes using v9fs in multiuser environment unsafe as it depends on the client doing the permission checking. This patch improves the 9P2000 support by allowing every user to attach separately. The patch defines three modes of access (new mount option 'access'): - attach-per-user (access=user) (default mode for 9P2000.u) If a user tries to access a file served by v9fs for the first time, v9fs sends an attach command to the server (Tattach) specifying the user. If the attach succeeds, the user can access the v9fs tree. As there is no uname->uid (string->integer) mapping yet, this mode works only with the 9P2000.u dialect. - allow only one user to access the tree (access=<uid>) Only the user with uid can access the v9fs tree. Other users that attempt to access it will get EPERM error. - do all operations as a single user (access=any) (default for 9P2000) V9fs does a single attach and all operations are done as a single user. If this mode is selected, the v9fs behavior is identical with the current one. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-10-179p: rename uid and gid parametersLatchesar Ionkov
Change the names of 'uid' and 'gid' parameters to the more appropriate 'dfltuid' and 'dfltgid'. This also sets the default uid/gid to -2 (aka nfsnobody) Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-10-179p: define session flagsLatchesar Ionkov
Create more general flags field in the v9fs_session_info struct and move the 'extended' flag as a bit in the flags. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-10-179p: Make transports dynamicEric Van Hensbergen
This patch abstracts out the interfaces to underlying transports so that new transports can be added as modules. This should also allow kernel configuration of transports without ifdef-hell. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-07-149p: Reorganization of 9p file system codeLatchesar Ionkov
This patchset moves non-filesystem interfaces of v9fs from fs/9p to net/9p. It moves the transport, packet marshalling and connection layers to net/9p leaving only the VFS related files in fs/9p. This work is being done in preparation for in-kernel 9p servers as well as alternate 9p clients (other than VFS). Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-02-189p: implement optional loose read cacheEric Van Hensbergen
While cacheing is generally frowned upon in the 9p world, it has its place -- particularly in situations where the remote file system is exclusive and/or read-only. The vacfs views of venti content addressable store are a real-world instance of such a situation. To facilitate higher performance for these workloads (and eventually use the fscache patches), we have enabled a "loose" cache mode which does not attempt to maintain any form of consistency on the page-cache or dcache. This results in over two orders of magnitude performance improvement for cacheable block reads in the Bonnie benchmark. The more aggressive use of the dcache also seems to improve metadata operational performance. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2006-03-25[PATCH] v9fs: update license boilerplateEric Van Hensbergen
Update license boilerplate to specify GPLv2 and remove the (at your option clause). This change was agreed to by all the copyright holders (approvals can be found on v9fs-developer mailing list). Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] v9fs: rename tids to tags to be consistent with Plan 9 documentationRuss Cox
The code talks about these things called tids, which I eventually figured out are tags. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: new multiplexer implementationLatchesar Ionkov
New multiplexer implementation. Decreases the number of kernel threads required. Better handling when the user process receives a signal. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: Support to force umountEric Van Hensbergen
Support for force umount Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: VFS superblock operations and glueEric Van Hensbergen
This part of the patch contains VFS superblock and mapping code. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
