path: root/fs/9p/v9fs_vfs.h
2011-09-06fs/9p: Add OS dependent open flags in 9p protocolAneesh Kumar K.V
Some of the flags are OS/arch dependent we add a 9p protocol value which maps to asm-generic/fcntl.h values in Linux Based on the original patch from Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2011-09-06fs/9p: Don't update file type when updating file attributesAneesh Kumar K.V
We should only update attributes that we can change on stat2inode. Also do file type initialization in v9fs_init_inode. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-15fs/9p: Prevent multiple inclusion of same headerAneesh Kumar K.V
Add necessary #ifndef #endif blocks to avoid mulitple inclusion of same headers Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Add support for marking inode attribute invalidAneesh Kumar K.V
With cached mode some of the file system operation result in updating inode attributes (ctime). Add support for marking inode attribute invalid in such cases so that we fetch the updated inode attribute on dentry revalidation. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Add v9fs_inodeAneesh Kumar K.V
Switch to the fscache code to v9fs_inode. We will later use v9fs_inode in cache=loose mode to track the inode cache validity timeout. Ie if we find an inode in cache older that a specific jiffie range we will consider it stale Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Add inode hashingAneesh Kumar K.V
We didn't add the inode to inode hash in 9p. We need to do that to get sync to work, otherwise __mark_inode_dirty will not add the inode to super block's dirty list. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Add read write helper functionAneesh Kumar K.V
We add read write helper function here which will be used later by the mmap patch Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: set the cached file_operations struct during inode initAneesh Kumar K.V
With the old code we were not setting the file->f_op with cached file operations during creat. (format correction by jvrao@linux.vnet.ibm.com) Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-01-12switch 9pAl Viro
here we actually *want* ->d_op for root; setting it allows to get rid of kludge in v9fs_kill_super() since now we have proper ->d_release() for root and don't need to call it manually. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-289p: Add datasync to client side TFSYNC/RFSYNC for dotlVenkateswararao Jujjuri (JV)
SYNOPSIS size[4] Tfsync tag[2] fid[4] datasync[4] size[4] Rfsync tag[2] DESCRIPTION The Tfsync transaction transfers ("flushes") all modified in-core data of file identified by fid to the disk device (or other permanent storage device) where that file resides. If datasync flag is specified data will be fleshed but does not flush modified metadata unless that metadata is needed in order to allow a subsequent data retrieval to be correctly handled. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Implement TLOCKM. Mohan Kumar
Synopsis size[4] TLock tag[2] fid[4] flock[n] size[4] RLock tag[2] status[1] Description Tlock is used to acquire/release byte range posix locks on a file identified by given fid. The reply contains status of the lock request flock structure: type[1] - Type of lock: F_RDLCK, F_WRLCK, F_UNLCK flags[4] - Flags could be either of P9_LOCK_FLAGS_BLOCK - Blocked lock request, if there is a conflicting lock exists, wait for that lock to be released. P9_LOCK_FLAGS_RECLAIM - Reclaim lock request, used when client is trying to reclaim a lock after a server restrart (due to crash) start[8] - Starting offset for lock length[8] - Number of bytes to lock If length is 0, lock all bytes starting at the location 'start' through to the end of file pid[4] - PID of the process that wants to take lock client_id[4] - Unique client id status[1] - Status of the lock request, can be P9_LOCK_SUCCESS(0), P9_LOCK_BLOCKED(1), P9_LOCK_ERROR(2) or P9_LOCK_GRACE(3) P9_LOCK_SUCCESS - Request was successful P9_LOCK_BLOCKED - A conflicting lock is held by another process P9_LOCK_ERROR - Error while processing the lock request P9_LOCK_GRACE - Server is in grace period, it can't accept new lock requests in this period (except locks with P9_LOCK_FLAGS_RECLAIM flag set) Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28fs/9p: Implement setting posix aclAneesh Kumar K.V
This patch also update mode bits, as a normal file system. I am not sure wether we should do that, considering that a setxattr on the server will again update the ACL/mode value Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09convert remaining ->clear_inode() to ->evict_inode()Al Viro
2010-08-029p: getattr client implementation for 9P2000.L protocol.Sripathi Kodi
SYNOPSIS size[4] Tgetattr tag[2] fid[4] request_mask[8] size[4] Rgetattr tag[2] lstat[n] DESCRIPTION The getattr transaction inquires about the file identified by fid. request_mask is a bit mask that specifies which fields of the stat structure is the client interested in. The reply will contain a machine-independent directory entry, laid out as follows: st_result_mask[8] Bit mask that indicates which fields in the stat structure have been populated by the server qid.type[1] the type of the file (directory, etc.), represented as a bit vector corresponding to the high 8 bits of the file's mode word. qid.vers[4] version number for given path qid.path[8] the file server's unique identification for the file st_mode[4] Permission and flags st_uid[4] User id of owner st_gid[4] Group ID of owner st_nlink[8] Number of hard links st_rdev[8] Device ID (if special file) st_size[8] Size, in bytes st_blksize[8] Block size for file system IO st_blocks[8] Number of file system blocks allocated st_atime_sec[8] Time of last access, seconds st_atime_nsec[8] Time of last access, nanoseconds st_mtime_sec[8] Time of last modification, seconds st_mtime_nsec[8] Time of last modification, nanoseconds st_ctime_sec[8] Time of last status change, seconds st_ctime_nsec[8] Time of last status change, nanoseconds st_btime_sec[8] Time of creation (birth) of file, seconds st_btime_nsec[8] Time of creation (birth) of file, nanoseconds st_gen[8] Inode generation st_data_version[8] Data version number request_mask and result_mask bit masks contain the following bits #define P9_STATS_MODE 0x00000001ULL #define P9_STATS_NLINK 0x00000002ULL #define P9_STATS_UID 0x00000004ULL #define P9_STATS_GID 0x00000008ULL #define P9_STATS_RDEV 0x00000010ULL #define P9_STATS_ATIME 0x00000020ULL #define P9_STATS_MTIME 0x00000040ULL #define P9_STATS_CTIME 0x00000080ULL #define P9_STATS_INO 0x00000100ULL #define P9_STATS_SIZE 0x00000200ULL #define P9_STATS_BLOCKS 0x00000400ULL #define P9_STATS_BTIME 0x00000800ULL #define P9_STATS_GEN 0x00001000ULL #define P9_STATS_DATA_VERSION 0x00002000ULL #define P9_STATS_BASIC 0x000007ffULL #define P9_STATS_ALL 0x00003fffULL This patch implements the client side of getattr implementation for 9P2000.L. It introduces a new structure p9_stat_dotl for getting Linux stat information along with QID. The data layout is similar to stat structure in Linux user space with the following major differences: inode (st_ino) is not part of data. Instead qid is. device (st_dev) is not part of data because this doesn't make sense on the client. All time variables are 64 bit wide on the wire. The kernel seems to use 32 bit variables for these variables. However, some of the architectures have used 64 bit variables and glibc exposes 64 bit variables to user space on some architectures. Hence to be on the safer side we have made these 64 bit in the protocol. Refer to the comments in include/asm-generic/stat.h There are some additional fields: st_btime_sec, st_btime_nsec, st_gen, st_data_version apart from the bitmask, st_result_mask. The bit mask is filled by the server to indicate which stat fields have been populated by the server. Currently there is no clean way for the server to obtain these additional fields, so it sends back just the basic fields. Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com> Signed-off-by: Eric Van Hensbegren <ericvh@gmail.com>
2010-05-219p: VFS switches for 9p2000.L: VFS switchesSripathi Kodi
Implements VFS switches for 9p2000.L protocol. Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-02-089p: Include fsync support for 9p clientM. Mohan Kumar
Implement the fsync in the client side by marking stat field values to 'don't touch' so that server may interpret it as a request to guarantee that the contents of the associated file are committed to stable storage before the Rwstat message is returned. Without this patch, calling fsync on a 9p file results in "Invalid argument" error. Please check the attached C program. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Acked-by: Venkateswararao Jujjuri (JV) <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2009-09-239p: Add fscache support to 9pAbhishek Kulkarni
This patch adds a persistent, read-only caching facility for 9p clients using the FS-Cache caching backend. When the fscache facility is enabled, each inode is associated with a corresponding vcookie which is an index into the FS-Cache indexing tree. The FS-Cache indexing tree is indexed at 3 levels: - session object associated with each mount. - inode/vcookie - actual data (pages) A cache tag is chosen randomly for each session. These tags can be read off /sys/fs/9p/caches and can be passed as a mount-time parameter to re-attach to the specified caching session. Signed-off-by: Abhishek Kulkarni <adkulkar@umail.iu.edu> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2009-03-27constify dentry_operations: 9pAl Viro
2008-10-179p: rework client code to use new protocol support functionsEric Van Hensbergen
Now that the new protocol functions are in place, this patch switches the client code to using the new support code. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-10-179p: move readn meta-function from client to fs layerEric Van Hensbergen
There are a couple of methods in the client code which aren't actually wire operations. To keep things organized cleaner, these operations are being moved to the fs layer. This patch moves the readn meta-function (which executes multiple wire reads until a buffer is full) to the fs layer. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-07-039p: fix O_APPEND in legacy modeEric Van Hensbergen
The legacy protocol's open operation doesn't handle an append operation (it is expected that the client take care of it). We were incorrectly passing the extended protocol's flag through even in legacy mode. This was reported in bugzilla report #10689. This patch fixes the problem by disallowing extended protocol open modes from being passed in legacy mode and implemented append functionality on the client side by adding a seek after the open. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-07-149p: Reorganization of 9p file system codeLatchesar Ionkov
This patchset moves non-filesystem interfaces of v9fs from fs/9p to net/9p. It moves the transport, packet marshalling and connection layers to net/9p leaving only the VFS related files in fs/9p. This work is being done in preparation for in-kernel 9p servers as well as alternate 9p clients (other than VFS). Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-03-269p: make struct v9fs_cached_file_operations staticAdrian Bunk
This patch makes te needlessly global struct v9fs_cached_file_operations static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-02-189p: implement optional loose read cacheEric Van Hensbergen
While cacheing is generally frowned upon in the 9p world, it has its place -- particularly in situations where the remote file system is exclusive and/or read-only. The vacfs views of venti content addressable store are a real-world instance of such a situation. To facilitate higher performance for these workloads (and eventually use the fscache patches), we have enabled a "loose" cache mode which does not attempt to maintain any form of consistency on the page-cache or dcache. This results in over two orders of magnitude performance improvement for cacheable block reads in the Bonnie benchmark. The more aggressive use of the dcache also seems to improve metadata operational performance. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] v9fs: update license boilerplateEric Van Hensbergen
Update license boilerplate to specify GPLv2 and remove the (at your option clause). This change was agreed to by all the copyright holders (approvals can be found on v9fs-developer mailing list). Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] v9fs: fix atomic create openLatchesar Ionkov
In order to assure atomic create+open v9fs stores the open fid produced by v9fs_vfs_create in the dentry, from where v9fs_file_open retrieves it and associates it with the open file. This patch modifies v9fs to use nameidata.intent.open values to do the atomic create+open. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] v9fs: add readpage supportEric Van Hensbergen
v9fs mmap support was originally removed from v9fs at Al Viro's request, but recently there have been requests from folks who want readpage functionality (primarily to enable execution of files mounted via 9P). This patch adds readpage support (but not writepage which contained most of the objectionable code). It passes fsx-linux (and other regressions) so it should be relatively safe. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: zero copy implementationLatchesar Ionkov
Performance enhancement reducing the number of copies in the data and stat paths. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: VFS superblock operations and glueEric Van Hensbergen
This part of the patch contains VFS superblock and mapping code. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
