path: root/fs/9p/vfs_dentry.c
2011-04-15fs/9p: Fix revalidate to return correct valueAneesh Kumar K.V
revalidate should return > 0 on success. Also return 0 on ENOENT to force do_revalidate to return NULL dentry; Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Add support for marking inode attribute invalidAneesh Kumar K.V
With cached mode some of the file system operation result in updating inode attributes (ctime). Add support for marking inode attribute invalid in such cases so that we fetch the updated inode attribute on dentry revalidation. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Clarify cached dentry delete operationAneesh Kumar K.V
Update the comment to indicate that we don't want to cache negative dentries. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-01-12switch 9pAl Viro
here we actually *want* ->d_op for root; setting it allows to get rid of kludge in v9fs_kill_super() since now we have proper ->d_release() for root and don't need to call it manually. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-03-27constify dentry_operations: 9pAl Viro
2008-12-199p: convert d_iname references to d_name.nameWu Fengguang
d_iname is rubbish for long file names. Use d_name.name in printks instead. Signed-off-by: Wu Fengguang <wfg@linux.intel.com> Acked-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-07-149p: Reorganization of 9p file system codeLatchesar Ionkov
This patchset moves non-filesystem interfaces of v9fs from fs/9p to net/9p. It moves the transport, packet marshalling and connection layers to net/9p leaving only the VFS related files in fs/9p. This work is being done in preparation for in-kernel 9p servers as well as alternate 9p clients (other than VFS). Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-189p: implement optional loose read cacheEric Van Hensbergen
While cacheing is generally frowned upon in the 9p world, it has its place -- particularly in situations where the remote file system is exclusive and/or read-only. The vacfs views of venti content addressable store are a real-world instance of such a situation. To facilitate higher performance for these workloads (and eventually use the fscache patches), we have enabled a "loose" cache mode which does not attempt to maintain any form of consistency on the page-cache or dcache. This results in over two orders of magnitude performance improvement for cacheable block reads in the Bonnie benchmark. The more aggressive use of the dcache also seems to improve metadata operational performance. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2006-03-25[PATCH] v9fs: update license boilerplateEric Van Hensbergen
Update license boilerplate to specify GPLv2 and remove the (at your option clause). This change was agreed to by all the copyright holders (approvals can be found on v9fs-developer mailing list). Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] v9fs: print 9p messagesLatchesar Ionkov
Print 9p messages. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] v9fs: simplify fid mappingEric Van Hensbergen
v9fs has been plagued by an over-complicated approach trying to map Linux dentry semantics to Plan 9 fid semantics. Our previous approach called for aggressive flushing of the dcache resulting in several problems (including wierd cwd behavior when running /bin/pwd). This patch dramatically simplifies our handling of this fid management. Fids will not be clunked as promptly, but the new approach is more functionally correct. We now clunk un-open fids only when their dentry ref_count reaches 0 (and d_delete is called). Another simplification is we no longer seek to match fids to the process-id or uid of the action initiator. The uid-matching will need to be revisited when we fix the security model. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: zero copy implementationLatchesar Ionkov
Performance enhancement reducing the number of copies in the data and stat paths. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: new multiplexer implementationLatchesar Ionkov
New multiplexer implementation. Decreases the number of kernel threads required. Better handling when the user process receives a signal. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] v9fs: fix races in fid allocationLatchesar Ionkov
Fid management cleanup. The patch attempts to fix the races in dentry's fid management. Dentries don't keep the opened fids anymore, they are moved to the file structs. Ideally there should be no more than one fid with fidcreate equal to zero in the dentry's list of fids. v9fs_fid_create initializes the important fields (fid, fidcreated) before v9fs_fid is added to the list. v9fs_fid_lookup returns only fids that are not created by v9fs_create. v9fs_fid_get_created returns the fid created by the same process by v9fs_create (if any) and removes it from dentry's list Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: VFS file, dentry, and directory operationsEric Van Hensbergen
This part of the patch contains the VFS file, dentry & directory interfaces. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
