path: root/fs/9p/vfs_dir.c
2006-03-17[PATCH] v9fs: fix overzealous dropping of dentry which breaks dcacheEric Van Hensbergen
There is a d_drop in dir_release which caused problems as it invalidates dcache entries too soon. This was likely a part of the wierd cwd behavior folks were seeing. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: zero copy implementationLatchesar Ionkov
Performance enhancement reducing the number of copies in the data and stat paths. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: new multiplexer implementationLatchesar Ionkov
New multiplexer implementation. Decreases the number of kernel threads required. Better handling when the user process receives a signal. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Fix and add EXPORT_SYMBOL(filemap_write_and_wait)OGAWA Hirofumi
This patch add EXPORT_SYMBOL(filemap_write_and_wait) and use it. See mm/filemap.c: And changes the filemap_write_and_wait() and filemap_write_and_wait_range(). Current filemap_write_and_wait() doesn't wait if filemap_fdatawrite() returns error. However, even if filemap_fdatawrite() returned an error, it may have submitted the partially data pages to the device. (e.g. in the case of -ENOSPC) <quotation> Andrew Morton writes, If filemap_fdatawrite() returns an error, this might be due to some I/O problem: dead disk, unplugged cable, etc. Given the generally crappy quality of the kernel's handling of such exceptions, there's a good chance that the filemap_fdatawait() will get stuck in D state forever. </quotation> So, this patch doesn't wait if filemap_fdatawrite() returns the -EIO. Trond, could you please review the nfs part? Especially I'm not sure, nfs must use the "filemap_fdatawrite(inode->i_mapping) == 0", or not. Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] v9fs: fix races in fid allocationLatchesar Ionkov
Fid management cleanup. The patch attempts to fix the races in dentry's fid management. Dentries don't keep the opened fids anymore, they are moved to the file structs. Ideally there should be no more than one fid with fidcreate equal to zero in the dentry's list of fids. v9fs_fid_create initializes the important fields (fid, fidcreated) before v9fs_fid is added to the list. v9fs_fid_lookup returns only fids that are not created by v9fs_create. v9fs_fid_get_created returns the fid created by the same process by v9fs_create (if any) and removes it from dentry's list Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: VFS file, dentry, and directory operationsEric Van Hensbergen
This part of the patch contains the VFS file, dentry & directory interfaces. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
