Some of the flags are OS/arch dependent we add a 9p
protocol value which maps to asm-generic/fcntl.h values in Linux
Based on the original patch from Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
We should only update attributes that we can change on stat2inode.
Also do file type initialization in v9fs_init_inode.
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
d_instantiate marks the dentry positive. So a parallel lookup and mkdir of
the directory can find dentry that doesn't have fid attached. This can result
in both the code path doing v9fs_fid_add which results in v9fs_dentry leak.
so we can pass &inode->i_mode to it
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
fs: take the ACL checks to common code
bury posix_acl_..._masq() variants
kill boilerplates around posix_acl_create_masq()
generic_acl: no need to clone acl just to push it to set_cached_acl()
kill boilerplate around posix_acl_chmod_masq()
reiserfs: cache negative ACLs for v1 stat format
xfs: cache negative ACLs if there is no attribute fork
9p: do no return 0 from ->check_acl without actually checking
vfs: move ACL cache lookup into generic code
CIFS: Fix oops while mounting with prefixpath
xfs: Fix wrong return value of xfs_file_aio_write
fix devtmpfs race
caam: don't pass bogus S_IFCHR to debugfs_create_...()
get rid of create_proc_entry() abuses - proc_mkdir() is there for purpose
asus-wmi: ->is_visible() can't return negative
fix jffs2 ACLs on big-endian with 16bit mode_t
9p: close ACL leaks
ocfs2_init_acl(): fix a leak
VFS : mount lock scalability for internal mounts
Replace the ->check_acl method with a ->get_acl method that simply reads an
ACL from disk after having a cache miss. This means we can replace the ACL
checking boilerplate code with a single implementation in namei.c.
This make sure we don't end up reusing the unlinked inode object.
The ideal way is to use inode i_generation. But i_generation is
not available in userspace always.
This make sure we don't use wrong inode from the inode hash. The inode number
of the file deleted is reused by the next file system object created
and if we only use inode number for inode hash lookup we could end up
with wrong struct inode.
Also compare inode generation number. Not all Linux file system provide
st_gen in userspace. So it could be 0;
... it will be set in nd->flag for all cases with non-NULL nd
(i.e. when called from do_last()).
->create() instances are much happier that way...
The dentry fid get clunked via the dput.
Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com>
Add the new static inline and use the same
We don't need writeback fid if we are only doing O_RDONLY open
convert vmtruncate usage to truncate_setsize. We also writeback
all dirty pages before doing 9p operations and on success call truncate_setsize.
This ensure that we continue sanely on failed truncate on the server. The
disadvantage is that we are now going to write back the content that get
thrown away later as a part of truncate.
When two process open the same file we can end up with both of them
allocating the writeback_fid. Add a new mutex which can be used
for synchronizing v9fs_inode member values.
change file attribute can result in making the file readonly.
So flush the dirty pages before that.
We need to call vmtruncate before 9p setattr operation, otherwise we
could write back some dirty pages between setattr with ATTR_SIZE and vmtruncate
causing some truncated pages to be written back to server
With caching enabled, we need to make sure we don't
update inode->i_size via stat2inode because we could
have dirty data which is not yet written to the server
One successfull directory operation we would have changed directory
inode attribute. So mark them invalid
rename, unlink and setattr can result in update of inode attribute.
So mark the cached copy invalid
With cached mode some of the file system operation result
in updating inode attributes (ctime). Add support for
marking inode attribute invalid in such cases so that
we fetch the updated inode attribute on dentry revalidation.
Switch to the fscache code to v9fs_inode. We will later use
v9fs_inode in cache=loose mode to track the inode cache
validity timeout. Ie if we find an inode in cache older
that a specific jiffie range we will consider it stale
simple_getattr does set stat.st_blocks to a value
derived from nrpages. That is not correct with 9p
We didn't add the inode to inode hash in 9p. We need to do that
to get sync to work, otherwise __mark_inode_dirty will not
add the inode to super block's dirty list.
The fid attached to inode will be opened O_RDWR mode and is used
for dirty page writeback only.
We need to ihold even in cached mode
We need to call v9fs_cache_inode_set_cookie in create
path also
We do set dentry->d_op in lookup even in case of EOENT entries.
That implies we should have dentry->d_op already set when
create/mkdir/mknod/link/symlink routines are called
introduced a typo somehow during a hand merge
Reported by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Remove v9fs_vfs_readlink_dotl function and use generic_readlink. Update
v9fs_vfs_follow_link_dotl function to accommodate this change
Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com>
Reported-by: Dr. David Alan Gilbert <linux@treblig.org>
Source Code Reorganization
