commit 0a73d0a204a4a04a1e110539c5a524ae51f91d6d upstream.
Pull vfs updates from Al Viro:
"Assorted stuff; the biggest pile here is Christoph's ACL series. Plus
assorted cleanups and fixes all over the place...
There will be another pile later this week"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (43 commits)
__dentry_path() fixes
vfs: Remove second variable named error in __dentry_path
vfs: Is mounted should be testing mnt_ns for NULL or error.
Fix race when checking i_size on direct i/o read
hfsplus: remove can_set_xattr
nfsd: use get_acl and ->set_acl
fs: remove generic_acl
nfs: use generic posix ACL infrastructure for v3 Posix ACLs
gfs2: use generic posix ACL infrastructure
jfs: use generic posix ACL infrastructure
xfs: use generic posix ACL infrastructure
reiserfs: use generic posix ACL infrastructure
ocfs2: use generic posix ACL infrastructure
jffs2: use generic posix ACL infrastructure
hfsplus: use generic posix ACL infrastructure
f2fs: use generic posix ACL infrastructure
ext2/3/4: use generic posix ACL infrastructure
btrfs: use generic posix ACL infrastructure
fs: make posix_acl_create more useful
fs: make posix_acl_chmod more useful
Rename the current posix_acl_created to __posix_acl_create and add
a fully featured helper to set up the ACLs on file creation that
uses get_acl().
Rename the current posix_acl_chmod to __posix_acl_chmod and add
a fully featured ACL chmod helper that uses the ->set_acl inode
operation.
- Add cache=mmap option
- Make mmap read-write while keeping it as synchronous as possible
- Build writeback fid on mmap creation if it is writable
Signed-off-by: Dominique Martinet <dominique.martinet@cea.fr>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
There is no use of 'name' pointer. Get rid of its useless assignment.
Signed-off-by: Geyslan G. Bem <geyslan@gmail.com>
In case of error in the p9_client_write, the function v9fs_fid_xattr_set
should return its negative value, what was never being done.
In case of success it only retuned 0. Now it returns the 'offset'
variable (write_count total).
There is no use of pointer 'v9ses'. Get rid of useless 'retval'
assignment.
There is no use of pointer 'fid' before the next assignment.
Get rid of the useless '*sb' variable.
Get rid of the useless 'err' variable, since the return is treated
farther down without the use of it.
Get rid of the useless '*fid' variable.
Get rid of the useless '*clnt' variable.
Rename simple_delete_dentry() to always_delete_dentry() and export it.
Export simple_dentry_operations, while we are at it, and get rid of
their duplicates
"All kinds of stuff this time around; some more notable parts:
- RCU'd vfsmounts handling
- new primitives for coredump handling
- files_lock is gone
- Bruce's delegations handling series
- exportfs fixes
plus misc stuff all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (101 commits)
ecryptfs: ->f_op is never NULL
locks: break delegations on any attribute modification
locks: break delegations on link
locks: break delegations on rename
locks: helper functions for delegation breaking
locks: break delegations on unlink
namei: minor vfs_unlink cleanup
locks: implement delegations
locks: introduce new FL_DELEG lock flag
vfs: take i_mutex on renamed file
vfs: rename I_MUTEX_QUOTA now that it's not used for quotas
vfs: don't use PARENT/CHILD lock classes for non-directories
vfs: pull ext4's double-i_mutex-locking into common code
exportfs: fix quadratic behavior in filehandle lookup
exportfs: better variable name
exportfs: move most of reconnect_path to helper function
exportfs: eliminate unused "noprogress" counter
exportfs: stop retrying once we race with rename/remove
exportfs: clear DISCONNECTED on all parents sooner
exportfs: more detailed comment for path_reconnect
Provide the ability to enable and disable fscache cookies. A disabled cookie
will reject or ignore further requests to:
Acquire a child cookie
Invalidate and update backing objects
Check the consistency of a backing object
Allocate storage for backing page
Read backing pages
Write to backing pages
but still allows:
Checks/waits on the completion of already in-progress objects
Uncaching of pages
Relinquishment of cookies
Two new operations are provided:
(1) Disable a cookie:
void fscache_disable_cookie(struct fscache_cookie *cookie,
bool invalidate);
If the cookie is not already disabled, this locks the cookie against other
dis/enablement ops, marks the cookie as being disabled, discards or
invalidates any backing objects and waits for cessation of activity on any
associated object.
This is a wrapper around a chunk split out of fscache_relinquish_cookie(),
but it reinitialises the cookie such that it can be reenabled.
All possible failures are handled internally. The caller should consider
calling fscache_uncache_all_inode_pages() afterwards to make sure all page
markings are cleared up.
(2) Enable a cookie:
void fscache_enable_cookie(struct fscache_cookie *cookie,
bool (*can_enable)(void *data),
void *data)
If the cookie is not already enabled, this locks the cookie against other
dis/enablement ops, invokes can_enable() and, if the cookie is not an
index cookie, will begin the procedure of acquiring backing objects.
The optional can_enable() function is passed the data argument and returns
a ruling as to whether or not enablement should actually be permitted to
begin.
All possible failures are handled internally. The cookie will only be
marked as enabled if provisional backing objects are allocated.
A later patch will introduce these to NFS. Cookie enablement during nfs_open()
is then contingent on i_writecount <= 0. can_enable() checks for a race
between open(O_RDONLY) and open(O_WRONLY/O_RDWR). This simplifies NFS's cookie
handling and allows us to get rid of open(O_RDONLY) accidentally introducing
caching to an inode that's open for writing already.
One operation has its API modified:
(3) Acquire a cookie.
struct fscache_cookie *fscache_acquire_cookie(
struct fscache_cookie *parent,
const struct fscache_cookie_def *def,
void *netfs_data,
bool enable);
This now has an additional argument that indicates whether the requested
cookie should be enabled by default. It doesn't need the can_enable()
function because the caller must prevent multiple calls for the same netfs
object and it doesn't need to take the enablement lock because no one else
can get at the cookie before this returns.
Signed-off-by: David Howells <dhowells@redhat.com
fs/namei.c
During trinity fuzzing in a kvmtool guest, I stumbled across the
following:
Unable to handle kernel NULL pointer dereference at virtual address 00000004
PC is at v9fs_file_do_lock+0xc8/0x1a0
LR is at v9fs_file_do_lock+0x48/0x1a0
[<c01e2ed0>] (v9fs_file_do_lock+0xc8/0x1a0) from [<c0119154>] (locks_remove_flock+0x8c/0x124)
[<c0119154>] (locks_remove_flock+0x8c/0x124) from [<c00d9bf0>] (__fput+0x58/0x1e4)
[<c00d9bf0>] (__fput+0x58/0x1e4) from [<c0044340>] (task_work_run+0xac/0xe8)
[<c0044340>] (task_work_run+0xac/0xe8) from [<c002e36c>] (do_exit+0x6bc/0x8d8)
[<c002e36c>] (do_exit+0x6bc/0x8d8) from [<c002e674>] (do_group_exit+0x3c/0xb0)
[<c002e674>] (do_group_exit+0x3c/0xb0) from [<c002e6f8>] (__wake_up_parent+0x0/0x18)
I believe this is due to an attempt to access utsname()->nodename, after
exit_task_namespaces() has been called, leaving current->nsproxy->uts_ns
as NULL and causing the above dereference.
A similar issue was fixed for lockd in 9a1b6bf818e7 ("LOCKD: Don't call
utsname()->nodename from nlmclnt_setlockargs"), so this patch attempts
something similar for 9pfs.
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
For 'NULL' terminated string, recommend always to be ended by zero.
Signed-off-by: Chen Gang <gang.chen@asianux.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
Pull second round of 9p patches from Eric Van Hensbergen:
"Several of these patches were rebased in order to correct style
issues. Only stylistic changes were made versus the patches which
were in linux-next for two weeks. The rebases have been in linux-next
for 3 days and have passed my regressions.
The bulk of these are RDMA fixes and improvements. There's also some
additions on the extended attributes front to support some additional
namespaces and a new option for TCP to force allocation of mount
requests from a priviledged port"
* tag 'for-linus-3.11-merge-window-part-2' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
fs/9p: Remove the unused variable "err" in v9fs_vfs_getattr()
9P: Add cancelled() to the transport functions.
9P/RDMA: count posted buffers without a pending request
9P/RDMA: Improve error handling in rdma_request
9P/RDMA: Do not free req->rc in error handling in rdma_request()
9P/RDMA: Use a semaphore to protect the RQ
9P/RDMA: Protect against duplicate replies
9P/RDMA: increase P9_RDMA_MAXSIZE to 1MB
9pnet: refactor struct p9_fcall alloc code
9P/RDMA: rdma_request() needs not allocate req->rc
9P: Fix fcall allocation for rdma
fs/9p: xattr: add trusted and security namespaces
net/9p: add privport option to 9p tcp transport
Delete the unused variable "err" in v9fs_vfs_getattr()
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Allow requests for security.* and trusted.* xattr name spaces
to pass through to server.
The new files are 99% cut and paste from fs/9p/xattr_user.c with the
namespaces changed. It has the intended effect in superficial testing.
I do not know much detail about how these namespaces are used, but passing
them through to the server, which can decide whether to handle them or not,
seems reasonable.
I want to support a use case where an ext4 file system is mounted via 9P,
then re-exported via samba to windows clients in a cluster. Windows wants
to store xattrs such as security.NTACL. This works when ext4 directly
backs samba, but not when 9P is inserted. This use case is documented here:
http://code.google.com/p/diod/issues/detail?id=95
Signed-off-by: Jim Garlick <garlick@llnl.gov>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 update from Ted Ts'o:
"Lots of bug fixes, cleanups and optimizations. In the bug fixes
category, of note is a fix for on-line resizing file systems where the
block size is smaller than the page size (i.e., file systems 1k blocks
on x86, or more interestingly file systems with 4k blocks on Power or
ia64 systems.)
In the cleanup category, the ext4's punch hole implementation was
significantly improved by Lukas Czerner, and now supports bigalloc
file systems. In addition, Jan Kara significantly cleaned up the
write submission code path. We also improved error checking and added
a few sanity checks.
In the optimizations category, two major optimizations deserve
mention. The first is that ext4_writepages() is now used for
nodelalloc and ext3 compatibility mode. This allows writes to be
submitted much more efficiently as a single bio request, instead of
being sent as individual 4k writes into the block layer (which then
relied on the elevator code to coalesce the requests in the block
queue). Secondly, the extent cache shrink mechanism, which was
introduce in 3.9, no longer has a scalability bottleneck caused by the
i_es_lru spinlock. Other optimizations include some changes to reduce
CPU usage and to avoid issuing empty commits unnecessarily."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (86 commits)
ext4: optimize starting extent in ext4_ext_rm_leaf()
jbd2: invalidate handle if jbd2_journal_restart() fails
ext4: translate flag bits to strings in tracepoints
ext4: fix up error handling for mpage_map_and_submit_extent()
jbd2: fix theoretical race in jbd2__journal_restart
ext4: only zero partial blocks in ext4_zero_partial_blocks()
ext4: check error return from ext4_write_inline_data_end()
ext4: delete unnecessary C statements
ext3,ext4: don't mess with dir_file->f_pos in htree_dirblock_to_tree()
jbd2: move superblock checksum calculation to jbd2_write_superblock()
ext4: pass inode pointer instead of file pointer to punch hole
ext4: improve free space calculation for inline_data
ext4: reduce object size when !CONFIG_PRINTK
ext4: improve extent cache shrink mechanism to avoid to burn CPU time
ext4: implement error handling of ext4_mb_new_preallocation()
ext4: fix corruption when online resizing a fs with 1K block size
ext4: delete unused variables
ext4: return FIEMAP_EXTENT_UNKNOWN for delalloc extents
jbd2: remove debug dependency on debug_fs and update Kconfig help text
jbd2: use a single printk for jbd_debug()
Currently there is no way to truncate partial page where the end
truncate point is not at the end of the page. This is because it was not
needed and the functionality was enough for file system truncate
operation to work properly. However more file systems now support punch
hole feature and it can benefit from mm supporting truncating page just
up to the certain point.
Specifically, with this functionality truncate_inode_pages_range() can
be changed so it supports truncating partial page at the end of the
range (currently it will BUG_ON() if 'end' is not at the end of the
page).
This commit changes the invalidatepage() address space operation
prototype to accept range to be invalidated and update all the instances
for it.
We also change the block_invalidatepage() in the same way and actually
make a use of the new length argument implementing range invalidation.
Actual file system implementations will follow except the file systems
where the changes are really simple and should not change the behaviour
in any way .Implementation for truncate_page_range() which will be able
to accept page unaligned ranges will follow as well.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
Modify the request_module to prefix the file system type with "fs-"
and add aliases to all of the filesystems that can be built as modules
to match.
A common practice is to build all of the kernel code and leave code
that is not commonly needed as modules, with the result that many
users are exposed to any bug anywhere in the kernel.
Looking for filesystems with a fs- prefix limits the pool of possible
modules that can be loaded by mount to just filesystems trivially
making things safer with no real cost.
Using aliases means user space can control the policy of which
filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf
with blacklist and alias directives. Allowing simple, safe,
well understood work-arounds to known problematic software.
This also addresses a rare but unfortunate problem where the filesystem
name is not the same as it's module name and module auto-loading
would not work. While writing this patch I saw a handful of such
cases. The most significant being autofs that lives in the module
autofs4.
This is relevant to user namespaces because we can reach the request
module in get_fs_type() without having any special permissions, and
people get uncomfortable when a user specified string (in this case
the filesystem type) goes all of the way to request_module.
After having looked at this issue I don't think there is any
particular reason to perform any filtering or permission checks beyond
making it clear in the module request that we want a filesystem
module. The common pattern in the kernel is to call request_module()
without regards to the users permissions. In general all a filesystem
module does once loaded is call register_filesystem() and go to sleep.
Which means there is not much attack surface exposed by loading a
filesytem module unless the filesystem is mounted. In a user
namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT,
which most filesystems do not set today.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Reported-by: Kees Cook <keescook@google.com>
Pull more VFS bits from Al Viro:
"Unfortunately, it looks like xattr series will have to wait until the
next cycle ;-/
This pile contains 9p cleanups and fixes (races in v9fs_fid_add()
etc), fixup for nommu breakage in shmem.c, several cleanups and a bit
more file_inode() work"
constify path_get/path_put and fs_struct.c stuff
fix nommu breakage in shmem.c
cache the value of file_inode() in struct file
9p: if v9fs_fid_lookup() gets to asking server, it'd better have hashed dentry
9p: make sure ->lookup() adds fid to the right dentry
9p: untangle ->lookup() a bit
9p: double iput() in ->lookup() if d_materialise_unique() fails
9p: v9fs_fid_add() can't fail now
v9fs: get rid of v9fs_dentry
9p: turn fid->dlist into hlist
9p: don't bother with private lock in ->d_fsdata; dentry->d_lock will do just fine
more file_inode() open-coded instances
selinux: opened file can't have NULL or negative ->f_path.dentry
(In the meantime, the hlist traversal macros have changed, so this
required a semantic conflict fixup for the newly hlistified fid->dlist)
... otherwise the path we'd built isn't worth much. Don't accept such fids
obtained from paths unless dentry is still alived by the end of the work.
d_materialise_unique() does iput() itself.
->d_fsdata can act as hlist_head...
just fine
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
The following set of operations on a NFS client and server will cause
server# mkdir a
client# cd a
server# mv a a.bak
client# sleep 30 # (or whatever the dir attrcache timeout is)
client# stat .
stat: cannot stat `.': Stale NFS file handle
Obviously, we should not be getting an ESTALE error back there since the
inode still exists on the server. The problem is that the lookup code
will call d_revalidate on the dentry that "." refers to, because NFS has
FS_REVAL_DOT set.
nfs_lookup_revalidate will see that the parent directory has changed and
will try to reverify the dentry by redoing a LOOKUP. That of course
fails, so the lookup code returns ESTALE.
The problem here is that d_revalidate is really a bad fit for this case.
What we really want to know at this point is whether the inode is still
good or not, but we don't really care what name it goes by or whether
the dcache is still valid.
Add a new d_op->d_weak_revalidate operation and have complete_walk call
that instead of d_revalidate. The intent there is to allow for a
"weaker" d_revalidate that just checks to see whether the inode is still
good. This is also gives us an opportunity to kill off the FS_REVAL_DOT
special casing.
[AV: changed method name, added note in porting, fixed confusion re
having it possibly called from RCU mode (it won't be)]
Cc: NeilBrown <neilb@suse.de>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
caller has both, might as well pass them explicitly.
... making v9fs_xattr_set() a wrapper for it.
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace and namespace infrastructure changes from Eric W Biederman:
"This set of changes starts with a few small enhnacements to the user
namespace. reboot support, allowing more arbitrary mappings, and
support for mounting devpts, ramfs, tmpfs, and mqueuefs as just the
user namespace root.
I do my best to document that if you care about limiting your
unprivileged users that when you have the user namespace support
enabled you will need to enable memory control groups.
There is a minor bug fix to prevent overflowing the stack if someone
creates way too many user namespaces.
The bulk of the changes are a continuation of the kuid/kgid push down
work through the filesystems. These changes make using uids and gids
typesafe which ensures that these filesystems are safe to use when
multiple user namespaces are in use. The filesystems converted for
3.9 are ceph, 9p, afs, ocfs2, gfs2, ncpfs, nfs, nfsd, and cifs. The
changes for these filesystems were a little more involved so I split
the changes into smaller hopefully obviously correct changes.
XFS is the only filesystem that remains. I was hoping I could get
that in this release so that user namespace support would be enabled
with an allyesconfig or an allmodconfig but it looks like the xfs
changes need another couple of days before it they are ready."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (93 commits)
cifs: Enable building with user namespaces enabled.
cifs: Convert struct cifs_ses to use a kuid_t and a kgid_t
cifs: Convert struct cifs_sb_info to use kuids and kgids
cifs: Modify struct smb_vol to use kuids and kgids
cifs: Convert struct cifsFileInfo to use a kuid
cifs: Convert struct cifs_fattr to use kuid and kgids
cifs: Convert struct tcon_link to use a kuid.
cifs: Modify struct cifs_unix_set_info_args to hold a kuid_t and a kgid_t
cifs: Convert from a kuid before printing current_fsuid
cifs: Use kuids and kgids SID to uid/gid mapping
cifs: Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID to keyring_alloc
cifs: Use BUILD_BUG_ON to validate uids and gids are the same size
cifs: Override unmappable incoming uids and gids
nfsd: Enable building with user namespaces enabled.
nfsd: Properly compare and initialize kuids and kgids
nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids
nfsd: Modify nfsd4_cb_sec to use kuids and kgids
nfsd: Handle kuids and kgids in the nfs4acl to posix_acl conversion
nfsd: Convert nfsxdr to use kuids and kgids
nfsd: Convert nfs3xdr to use kuids and kgids
Merge misc patches from Andrew Morton:
- Florian has vanished so I appear to have become fbdev maintainer
again :(
- Joel and Mark are distracted to welcome to the new OCFS2 maintainer
- The backlight queue
- Small core kernel changes
- lib/ updates
- The rtc queue
- Various random bits
* akpm: (164 commits)
rtc: rtc-davinci: use devm_*() functions
rtc: rtc-max8997: use devm_request_threaded_irq()
rtc: rtc-max8907: use devm_request_threaded_irq()
rtc: rtc-da9052: use devm_request_threaded_irq()
rtc: rtc-wm831x: use devm_request_threaded_irq()
rtc: rtc-tps80031: use devm_request_threaded_irq()
rtc: rtc-lp8788: use devm_request_threaded_irq()
rtc: rtc-coh901331: use devm_clk_get()
rtc: rtc-vt8500: use devm_*() functions
rtc: rtc-tps6586x: use devm_request_threaded_irq()
rtc: rtc-imxdi: use devm_clk_get()
rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug()
rtc: rtc-pcf8583: use dev_warn() instead of printk()
rtc: rtc-sun4v: use pr_warn() instead of printk()
rtc: rtc-vr41xx: use dev_info() instead of printk()
rtc: rtc-rs5c313: use pr_err() instead of printk()
rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug()
rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug()
rtc: rtc-ds2404: use dev_err() instead of printk()
rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk()
Fix up the ->page_mkwrite handler to provide stable page writes if necessary.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Steven Whitehouse <swhiteho@redhat.com>
