[ Upstream commit c87a37ebd40b889178664c2c09cc187334146292 ]
Currently on mmap cache policy, we always attach writeback_fid
whether mmap type is SHARED or PRIVATE. However, in the use case
of kata-container which combines 9p(Guest OS) with overlayfs(Host OS),
this behavior will trigger overlayfs' copy-up when excute command
inside container.
Link: http://lkml.kernel.org/r/20190820100325.10313-1-cgxu519@zoho.com.cn
Signed-off-by: Chengguang Xu <cgxu519@zoho.com.cn>
Signed-off-by: Dominique Martinet <dominique.martinet@cea.fr>
[ Upstream commit f053cbd4366051d7eb6ba1b8d529d20f719c2963 ]
Fix the callback 9p passes to read_cache_page to actually have the
proper type expected. Casting around function pointers can easily
hide typing bugs, and defeats control flow protection.
Link: http://lkml.kernel.org/r/20190520055731.24538-5-hch@lst.de
Cc: Sami Tolvanen <samitolvanen@google.com>
Cc: Nick Desaulniers <ndesaulniers@google.com>
[ Upstream commit e02a53d92e197706cad1627bd84705d4aa20a145 ]
iattr is passed to v9fs_vfs_setattr_dotl which does send various
values from iattr over the wire, even if it tells the server to
only look at iattr.ia_valid fields this could leak some stack data.
Link: http://lkml.kernel.org/r/1536339057-21974-2-git-send-email-asmadeus@codewreck.org
Addresses-Coverity-ID: 1195601 ("Uninitalized scalar variable")
[ Upstream commit 5e172f75e51e3de1b4274146d9b990f803cb5c2a ]
The default P9_LOCK_TIMEOUT can be too long for some users exporting
a local file system to a guest VM (30s), make this configurable at
mount time.
Link: http://lkml.kernel.org/r/1536295827-3181-1-git-send-email-asmadeus@codewreck.org
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=195727
Signed-off-by: Dinu-Razvan Chis-Serban <justcsdr@gmail.com>
[ Upstream commit 2803cf4379ed252894f046cb8812a48db35294e3 ]
v9fs_dir_readdir() could deadloop if a struct was sent with a size set
to -2
Link: http://lkml.kernel.org/r/1536134432-11997-1-git-send-email-asmadeus@codewreck.org
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=88021
Signed-off-by: Gertjan Halkes <gertjan@google.com>
commit 5e3cc1ee1405a7eb3487ed24f786dec01b4cbe1f upstream.
Use inode->i_lock to protect i_size_write(), else i_size_read() in
generic_fillattr() may loop infinitely in read_seqcount_begin() when
multiple processes invoke v9fs_vfs_getattr() or v9fs_vfs_getattr_dotl()
simultaneously under 32-bit SMP environment, and a soft lockup will be
triggered as show below:
watchdog: BUG: soft lockup - CPU#5 stuck for 22s! [stat:2217]
Modules linked in:
CPU: 5 PID: 2217 Comm: stat Not tainted 5.0.0-rc1-00005-g7f702faf5a9e #4
Hardware name: Generic DT based system
PC is at generic_fillattr+0x104/0x108
LR is at 0xec497f00
pc : [<802b8898>] lr : [<ec497f00>] psr: 200c0013
sp : ec497e20 ip : ed608030 fp : ec497e3c
r10: 00000000 r9 : ec497f00 r8 : ed608030
r7 : ec497ebc r6 : ec497f00 r5 : ee5c1550 r4 : ee005780
r3 : 0000052d r2 : 00000000 r1 : ec497f00 r0 : ed608030
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
Control: 10c5387d Table: ac48006a DAC: 00000051
Backtrace:
[<8010d974>] (dump_backtrace) from [<8010dc88>] (show_stack+0x20/0x24)
[<8010dc68>] (show_stack) from [<80a1d194>] (dump_stack+0xb0/0xdc)
[<80a1d0e4>] (dump_stack) from [<80109f34>] (show_regs+0x1c/0x20)
[<80109f18>] (show_regs) from [<801d0a80>] (watchdog_timer_fn+0x280/0x2f8)
[<801d0800>] (watchdog_timer_fn) from [<80198658>] (__hrtimer_run_queues+0x18c/0x380)
[<801984cc>] (__hrtimer_run_queues) from [<80198e60>] (hrtimer_run_queues+0xb8/0xf0)
[<80198da8>] (hrtimer_run_queues) from [<801973e8>] (run_local_timers+0x28/0x64)
[<801973c0>] (run_local_timers) from [<80197460>] (update_process_times+0x3c/0x6c)
[<80197424>] (update_process_times) from [<801ab2b8>] (tick_nohz_handler+0xe0/0x1bc)
[<801ab1d8>] (tick_nohz_handler) from [<80843050>] (arch_timer_handler_virt+0x38/0x48)
[<80843018>] (arch_timer_handler_virt) from [<80180a64>] (handle_percpu_devid_irq+0x8c/0x240)
[<801809d8>] (handle_percpu_devid_irq) from [<8017ac20>] (generic_handle_irq+0x34/0x44)
[<8017abec>] (generic_handle_irq) from [<8017b344>] (__handle_domain_irq+0x6c/0xc4)
[<8017b2d8>] (__handle_domain_irq) from [<801022e0>] (gic_handle_irq+0x4c/0x88)
[<80102294>] (gic_handle_irq) from [<80101a30>] (__irq_svc+0x70/0x98)
[<802b8794>] (generic_fillattr) from [<8056b284>] (v9fs_vfs_getattr_dotl+0x74/0xa4)
[<8056b210>] (v9fs_vfs_getattr_dotl) from [<802b8904>] (vfs_getattr_nosec+0x68/0x7c)
[<802b889c>] (vfs_getattr_nosec) from [<802b895c>] (vfs_getattr+0x44/0x48)
[<802b8918>] (vfs_getattr) from [<802b8a74>] (vfs_statx+0x9c/0xec)
[<802b89d8>] (vfs_statx) from [<802b9428>] (sys_lstat64+0x48/0x78)
[<802b93e0>] (sys_lstat64) from [<80101000>] (ret_fast_syscall+0x0/0x28)
[dominique.martinet@cea.fr: updated comment to not refer to a function
in another subsystem]
Link: http://lkml.kernel.org/r/20190124063514.8571-2-houtao1@huawei.com
Cc: stable@vger.kernel.org
Fixes: 7549ae3e81cc ("9p: Use the i_size_[read, write]() macros instead of using inode->i_size directly.")
Reported-by: Xing Gaopeng <xingaopeng@huawei.com>
Signed-off-by: Hou Tao <houtao1@huawei.com>
commit 81c99089bce693b94b775b6eb888115d2d540086 upstream.
p9stat_read will call p9stat_free on error, we should only free the
struct content on success.
There also is no need to "p9stat_init" st as the read function will
zero the whole struct for us anyway, so clean up the code a bit while
we are here.
Link: http://lkml.kernel.org/r/1535410108-20650-1-git-send-email-asmadeus@codewreck.org
Reported-by: syzbot+d4252148d198410b864f@syzkaller.appspotmail.com
[ Upstream commit b4dc44b3cac9e8327e0655f530ed0c46f2e6214c ]
the 9p client code overwrites our glock.client_id pointing to a static
buffer by an allocated string holding the network provided value which
we do not care about; free and reset the value as appropriate.
This is almost identical to the leak in v9fs_file_getlock() fixed by
Al Viro in commit ce85dd58ad5a6 ("9p: we are leaking glock.client_id
in v9fs_file_getlock()"), which was returned as an error by a coverity
false positive -- while we are here attempt to make the code slightly
more robust to future change of the net/9p/client code and hopefully
more clear to coverity that there is no problem.
Link: http://lkml.kernel.org/r/1536339057-21974-5-git-send-email-asmadeus@codewreck.org
commit 3111784bee81591ea2815011688d28b65df03627 upstream.
In my testing, v9fs_fid_xattr_set will return successfully even if the
backend ext4 filesystem has no space to store xattr key-value. That will
cause inconsistent behavior between front end and back end. The reason is
that lsetxattr will be triggered by p9_client_clunk, and unfortunately we
did not catch the error. This patch will catch the error to notify upper
caller.
p9_client_clunk (in 9p)
p9_client_rpc(clnt, P9_TCLUNK, "d", fid->fid);
v9fs_clunk (in qemu)
put_fid
free_fid
v9fs_xattr_fid_clunk
v9fs_co_lsetxattr
s->ops->lsetxattr
ext4_xattr_user_set (in host ext4 filesystem)
Link: http://lkml.kernel.org/r/5B57EACC.2060900@huawei.com
Signed-off-by: Jun Piao <piaojun@huawei.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
commit 8ee031631546cf2f7859cc69593bd60bbdd70b46 upstream.
Commit fd2421f54423 ("fs/9p: When doing inode lookup compare qid details
and inode mode bits.") transformed v9fs_qid_iget() to use iget5_locked()
instead of iget_locked(). However, the test() callback is not checking
fid.path at all, which means that a lookup in the inode cache can now
accidentally locate a completely wrong inode from the same inode hash
bucket if the other fields (qid.type and qid.version) match.
Fixes: fd2421f54423 ("fs/9p: When doing inode lookup compare qid details and inode mode bits.")
Reviewed-by: Latchesar Ionkov <lucho@ionkov.net>
commit b5c66bab72a6a65edb15beb60b90d3cb84c5763b upstream.
posix_acl_update_mode() could possibly clear 'acl', if so we leak the
memory pointed by 'acl'. Save this pointer before calling
posix_acl_update_mode() and release the memory if 'acl' really gets
cleared.
Link: http://lkml.kernel.org/r/1486678332-2430-1-git-send-email-xiyou.wangcong@gmail.com
Reported-by: Mark Salyzyn <salyzyn@android.com>
Reviewed-by: Greg Kurz <groug@kaod.org>
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
Pull vfs xattr updates from Al Viro:
"xattr stuff from Andreas
This completes the switch to xattr_handler ->get()/->set() from
->getxattr/->setxattr/->removexattr"
* 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
vfs: Remove {get,set,remove}xattr inode operations
xattr: Stop calling {get,set,remove}xattr inode operations
vfs: Check for the IOP_XATTR flag in listxattr
xattr: Add __vfs_{get,set,remove}xattr helpers
libfs: Use IOP_XATTR flag for empty directory handling
vfs: Use IOP_XATTR flag for bad-inode handling
vfs: Add IOP_XATTR inode operations flag
vfs: Move xattr_resolve_name to the front of fs/xattr.c
ecryptfs: Switch to generic xattr handlers
sockfs: Get rid of getxattr iop
sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names
kernfs: Switch to generic xattr handlers
hfs: Switch to generic xattr handlers
jffs2: Remove jffs2_{get,set,remove}xattr macros
xattr: Remove unnecessary NULL attribute name check
These inode operations are no longer used; remove them.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_time() instead.
CURRENT_TIME is also not y2038 safe.
This is also in preparation for the patch that transitions
vfs timestamps to use 64 bit time and hence make them
y2038 safe. As part of the effort current_time() will be
extended to do range checks. Hence, it is necessary for all
file system timestamps to use current_time(). Also,
current_time() will be transitioned along with vfs to be
y2038 safe.
Note that whenever a single call to current_time() is used
to change timestamps in different inodes, it is because they
share the same time granularity.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Felipe Balbi <balbi@kernel.org>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: David Sterba <dsterba@suse.com>
Generated patch:
sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2`
sed -i "s/\brename2\b/rename/g" `git grep -wl rename2`
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
This is trivial to do:
- add flags argument to foo_rename()
- check if flags is zero
- assign foo_rename() to .rename2 instead of .rename
This doesn't mean it's impossible to support RENAME_NOREPLACE for these
filesystems, but it is not trivial, like for local filesystems.
RENAME_NOREPLACE must guarantee atomicity (i.e. it shouldn't be possible
for a file to be created on one host while it is overwritten by rename on
another host).
Filesystems converted:
9p, afs, ceph, coda, ecryptfs, kernfs, lustre, ncpfs, nfs, ocfs2, orangefs.
After this, we can get rid of the duplicate interfaces for rename.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: David Howells <dhowells@redhat.com> [AFS]
Acked-by: Mike Marshall <hubcap@omnibond.com>
Cc: Ilya Dryomov <idryomov@gmail.com>
Cc: Jan Harkes <jaharkes@cs.cmu.edu>
Cc: Tyler Hicks <tyhicks@canonical.com>
Cc: Oleg Drokin <oleg.drokin@intel.com>
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
Cc: Mark Fasheh <mfasheh@suse.com>
inode_change_ok() will be resposible for clearing capabilities and IMA
extended attributes and as such will need dentry. Give it as an argument
to inode_change_ok() instead of an inode. Also rename inode_change_ok()
to setattr_prepare() to better relect that it does also some
modifications in addition to checks.
When file permissions are modified via chmod(2) and the user is not in
the owning group or capable of CAP_FSETID, the setgid bit is cleared in
inode_change_ok(). Setting a POSIX ACL via setxattr(2) sets the file
permissions as well as the new ACL, but doesn't clear the setgid bit in
a similar way; this allows to bypass the check in chmod(2). Fix that.
References: CVE-2016-7097
Reviewed-by: Jeff Layton <jlayton@redhat.com>
"Assorted cleanups and fixes.
In the "trivial API change" department - ->d_compare() losing 'parent'
argument"
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
cachefiles: Fix race between inactivating and culling a cache object
9p: use clone_fid()
9p: fix braino introduced in "9p: new helper - v9fs_parent_fid()"
vfs: make dentry_needs_remove_privs() internal
vfs: remove file_needs_remove_privs()
vfs: fix deadlock in file_remove_privs() on overlayfs
get rid of 'parent' argument of ->d_compare()
cifs, msdos, vfat, hfs+: don't bother with parent in ->d_compare()
affs ->d_compare(): don't bother with ->d_inode
fold _d_rehash() and __d_rehash() together
fold dentry_rcuwalk_invalidate() into its only remaining caller
in a bunch of places it cleans the things up
In v9fs_vfs_rename() we need to clone the parents' fids, not just
find them.
Spotted-by: Johannes Berg <johannes@sipsolutions.net>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull userns vfs updates from Eric Biederman:
"This tree contains some very long awaited work on generalizing the
user namespace support for mounting filesystems to include filesystems
with a backing store. The real world target is fuse but the goal is
to update the vfs to allow any filesystem to be supported. This
patchset is based on a lot of code review and testing to approach that
goal.
While looking at what is needed to support the fuse filesystem it
became clear that there were things like xattrs for security modules
that needed special treatment. That the resolution of those concerns
would not be fuse specific. That sorting out these general issues
made most sense at the generic level, where the right people could be
drawn into the conversation, and the issues could be solved for
everyone.
At a high level what this patchset does a couple of simple things:
- Add a user namespace owner (s_user_ns) to struct super_block.
- Teach the vfs to handle filesystem uids and gids not mapping into
to kuids and kgids and being reported as INVALID_UID and
INVALID_GID in vfs data structures.
By assigning a user namespace owner filesystems that are mounted with
only user namespace privilege can be detected. This allows security
modules and the like to know which mounts may not be trusted. This
also allows the set of uids and gids that are communicated to the
filesystem to be capped at the set of kuids and kgids that are in the
owning user namespace of the filesystem.
One of the crazier corner casees this handles is the case of inodes
whose i_uid or i_gid are not mapped into the vfs. Most of the code
simply doesn't care but it is easy to confuse the inode writeback path
so no operation that could cause an inode write-back is permitted for
such inodes (aka only reads are allowed).
This set of changes starts out by cleaning up the code paths involved
in user namespace permirted mounts. Then when things are clean enough
adds code that cleanly sets s_user_ns. Then additional restrictions
are added that are possible now that the filesystem superblock
contains owner information.
These changes should not affect anyone in practice, but there are some
parts of these restrictions that are changes in behavior.
- Andy's restriction on suid executables that does not honor the
suid bit when the path is from another mount namespace (think
/proc/[pid]/fd/) or when the filesystem was mounted by a less
privileged user.
- The replacement of the user namespace implicit setting of MNT_NODEV
with implicitly setting SB_I_NODEV on the filesystem superblock
instead.
Using SB_I_NODEV is a stronger form that happens to make this state
user invisible. The user visibility can be managed but it caused
problems when it was introduced from applications reasonably
expecting mount flags to be what they were set to.
There is a little bit of work remaining before it is safe to support
mounting filesystems with backing store in user namespaces, beyond
what is in this set of changes.
- Verifying the mounter has permission to read/write the block device
during mount.
- Teaching the integrity modules IMA and EVM to handle filesystems
mounted with only user namespace root and to reduce trust in their
security xattrs accordingly.
- Capturing the mounters credentials and using that for permission
checks in d_automount and the like. (Given that overlayfs already
does this, and we need the work in d_automount it make sense to
generalize this case).
Furthermore there are a few changes that are on the wishlist:
- Get all filesystems supporting posix acls using the generic posix
acls so that posix_acl_fix_xattr_from_user and
posix_acl_fix_xattr_to_user may be removed. [Maintainability]
- Reducing the permission checks in places such as remount to allow
the superblock owner to perform them.
- Allowing the superblock owner to chown files with unmapped uids and
gids to something that is mapped so the files may be treated
normally.
I am not considering even obvious relaxations of permission checks
until it is clear there are no more corner cases that need to be
locked down and handled generically.
Many thanks to Seth Forshee who kept this code alive, and putting up
with me rewriting substantial portions of what he did to handle more
corner cases, and for his diligent testing and reviewing of my
changes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (30 commits)
fs: Call d_automount with the filesystems creds
fs: Update i_[ug]id_(read|write) to translate relative to s_user_ns
evm: Translate user/group ids relative to s_user_ns when computing HMAC
dquot: For now explicitly don't support filesystems outside of init_user_ns
quota: Handle quota data stored in s_user_ns in quota_setxquota
quota: Ensure qids map to the filesystem
vfs: Don't create inodes with a uid or gid unknown to the vfs
vfs: Don't modify inodes with a uid or gid unknown to the vfs
cred: Reject inodes with invalid ids in set_create_file_as()
fs: Check for invalid i_uid in may_follow_link()
vfs: Verify acls are valid within superblock's s_user_ns.
userns: Handle -1 in k[ug]id_has_mapping when !CONFIG_USER_NS
fs: Refuse uid/gid changes which don't map into s_user_ns
selinux: Add support for unprivileged mounts from user namespaces
Smack: Handle labels consistently in untrusted mounts
Smack: Add support for unprivileged mounts from user namespaces
fs: Treat foreign mounts as nosuid
fs: Limit file caps to the user namespace of the super block
userns: Remove the now unnecessary FS_USERNS_DEV_MOUNT flag
userns: Remove implicit MNT_NODEV fragility.
Pull vfs updates from Al Viro:
Probably the most interesting part long-term is ->d_init() - that will
have a bunch of followups in (at least) ceph and lustre, but we'll
need to sort the barrier-related rules before it can get used for
really non-trivial stuff.
Another fun thing is the merge of ->d_iput() callers (dentry_iput()
and dentry_unlink_inode()) and a bunch of ->d_compare() ones (all
except the one in __d_lookup_lru())"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits)
fs/dcache.c: avoid soft-lockup in dput()
vfs: new d_init method
vfs: Update lookup_dcache() comment
bdev: get rid of ->bd_inodes
Remove last traces of ->sync_page
new helper: d_same_name()
dentry_cmp(): use lockless_dereference() instead of smp_read_barrier_depends()
vfs: clean up documentation
vfs: document ->d_real()
vfs: merge .d_select_inode() into .d_real()
unify dentry_iput() and dentry_unlink_inode()
binfmt_misc: ->s_root is not going anywhere
drop redundant ->owner initializations
ufs: get rid of redundant checks
orangefs: constify inode_operations
missed comment updates from ->direct_IO() prototype change
file_inode(f)->i_mapping is f->f_mapping
trim fsnotify hooks a bit
debugfs: ->d_parent is never NULL or negative
->atomic_open() can be given an in-lookup dentry *or* a negative one
found in dcache. Use d_in_lookup() to tell one from another, rather
than d_unhashed().
v9fs may be used as lower layer of overlayfs and accessing f_path.dentry
can lead to a crash. In this case it's a NULL pointer dereference in
p9_fid_create().
Fix by replacing direct access of file->f_path.dentry with the
file_dentry() accessor, which will always return a native object.
Reported-by: Alessio Igor Bogani <alessioigorbogani@gmail.com>
Tested-by: Alessio Igor Bogani <alessioigorbogani@gmail.com>
Fixes: 4bacc9c9234c ("overlayfs: Make f_path always point to the overlay and f_inode to the underlay")
Cc: <stable@vger.kernel.org>
Update posix_acl_valid to verify that an acl is within a user namespace.
Update the callers of posix_acl_valid to pass in an appropriate
user namespace. For posix_acl_xattr_set and v9fs_xattr_set_acl pass in
inode->i_sb->s_user_ns to posix_acl_valid. For md_unpack_acl pass in
&init_user_ns as no inode or superblock is in sight.
Acked-by: Seth Forshee <seth.forshee@canonical.com>
preparation for similar switch in ->setxattr() (see the next commit for
rationale).
Pull vfs cleanups from Al Viro:
"More cleanups from Christoph"
* 'work.preadv2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
nfsd: use RWF_SYNC
fs: add RWF_DSYNC aand RWF_SYNC
ceph: use generic_write_sync
fs: simplify the generic_write_sync prototype
fs: add IOCB_SYNC and IOCB_DSYNC
direct-io: remove the offset argument to dio_complete
direct-io: eliminate the offset argument to ->direct_IO
xfs: eliminate the pos variable in xfs_file_dio_aio_write
filemap: remove the pos argument to generic_file_direct_write
filemap: remove pos variables in generic_file_read_iter
The rest of work.xattr stuff isn't needed for this branch
Including blkdev_direct_IO and dax_do_io. It has to be ki_pos to actually
work, so eliminate the superflous argument.
... and do not assume they are already attached to each other
... and neither can ever be NULL
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
When get_acl() is called for an inode whose ACL is not cached yet, the
get_acl inode operation is called to fetch the ACL from the filesystem.
The inode operation is responsible for updating the cached acl with
set_cached_acl(). This is done without locking at the VFS level, so
another task can call set_cached_acl() or forget_cached_acl() before the
get_acl inode operation gets to calling set_cached_acl(), and then
get_acl's call to set_cached_acl() results in caching an outdate ACL.
Prevent this from happening by setting the cached ACL pointer to a
task-specific sentinel value before calling the get_acl inode operation.
Move the responsibility for updating the cached ACL from the get_acl
inode operations to get_acl(). There, only set the cached ACL if the
sentinel value hasn't changed.
The sentinel values are chosen to have odd values. Likewise, the value
of ACL_NOT_CACHED is odd. In contrast, ACL object pointers always have
an even value (ACLs are aligned in memory). This allows to distinguish
uncached ACLs values from ACL objects.
In addition, switch from guarding inode->i_acl and inode->i_default_acl
upates by the inode->i_lock spinlock to using xchg() and cmpxchg().
Filesystems that do not want ACLs returned from their get_acl inode
operations to be cached must call forget_cached_acl() to prevent the VFS
from doing so.
(Patch written by Al Viro and Andreas Gruenbacher.)
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
Mark those kmem allocations that are known to be easily triggered from
userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to
memcg. For the list, see below:
- threadinfo
- task_struct
- task_delay_info
- pid
- cred
- mm_struct
- vm_area_struct and vm_region (nommu)
- anon_vma and anon_vma_chain
- signal_struct
- sighand_struct
- fs_struct
- files_struct
- fdtable and fdtable->full_fds_bits
- dentry and external_name
- inode for all filesystems. This is the most tedious part, because
most filesystems overwrite the alloc_inode method.
The list is far from complete, so feel free to add more objects.
Nevertheless, it should be close to "account everything" approach and
keep most workloads within bounds. Malevolent users will be able to
breach the limit, but this was possible even with the former "account
everything" approach (simply because it did not account everything in
fact).
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Pull misc vfs updates from Al Viro:
"All kinds of stuff. That probably should've been 5 or 6 separate
branches, but by the time I'd realized how large and mixed that bag
had become it had been too close to -final to play with rebasing.
Some fs/namei.c cleanups there, memdup_user_nul() introduction and
switching open-coded instances, burying long-dead code, whack-a-mole
of various kinds, several new helpers for ->llseek(), assorted
cleanups and fixes from various people, etc.
One piece probably deserves special mention - Neil's
lookup_one_len_unlocked(). Similar to lookup_one_len(), but gets
called without ->i_mutex and tries to avoid ever taking it. That, of
course, means that it's not useful for any directory modifications,
but things like getting inode attributes in nfds readdirplus are fine
with that. I really should've asked for moratorium on lookup-related
changes this cycle, but since I hadn't done that early enough... I
*am* asking for that for the coming cycle, though - I'm going to try
and get conversion of i_mutex to rwsem with ->lookup() done under lock
taken shared.
There will be a patch closer to the end of the window, along the lines
of the one Linus had posted last May - mechanical conversion of
->i_mutex accesses to inode_lock()/inode_unlock()/inode_trylock()/
inode_is_locked()/inode_lock_nested(). To quote Linus back then:
| This is an automated patch using
| sed 's/mutex_lock(&\(.*\)->i_mutex)/inode_lock(\1)/'
| sed 's/mutex_unlock(&\(.*\)->i_mutex)/inode_unlock(\1)/'
| sed 's/mutex_lock_nested(&\(.*\)->i_mutex,[ ]*I_MUTEX_\([A-Z0-9_]*\))/inode_lock_nested(\1, I_MUTEX_\2)/'
| sed 's/mutex_is_locked(&\(.*\)->i_mutex)/inode_is_locked(\1)/'
| sed 's/mutex_trylock(&\(.*\)->i_mutex)/inode_trylock(\1)/'
| with a very few manual fixups
I'm going to send that once the ->i_mutex-affecting stuff in -next
gets mostly merged (or when Linus says he's about to stop taking
merges)"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
nfsd: don't hold i_mutex over userspace upcalls
fs:affs:Replace time_t with time64_t
fs/9p: use fscache mutex rather than spinlock
proc: add a reschedule point in proc_readfd_common()
logfs: constify logfs_block_ops structures
fcntl: allow to set O_DIRECT flag on pipe
fs: __generic_file_splice_read retry lookup on AOP_TRUNCATED_PAGE
fs: xattr: Use kvfree()
[s390] page_to_phys() always returns a multiple of PAGE_SIZE
nbd: use ->compat_ioctl()
fs: use block_device name vsprintf helper
lib/vsprintf: add %*pg format specifier
fs: use gendisk->disk_name where possible
poll: plug an unused argument to do_poll
amdkfd: don't open-code memdup_user()
cdrom: don't open-code memdup_user()
rsxx: don't open-code memdup_user()
mtip32xx: don't open-code memdup_user()
[um] mconsole: don't open-code memdup_user_nul()
[um] hostaudio: don't open-code memdup_user()
"Andreas' xattr cleanup series.
It's a followup to his xattr work that went in last cycle; -0.5KLoC"
xattr handlers: Simplify list operation
ocfs2: Replace list xattr handler operations
nfs: Move call to security_inode_listsecurity into nfs_listxattr
xfs: Change how listxattr generates synthetic attributes
tmpfs: listxattr should include POSIX ACL xattrs
tmpfs: Use xattr handler infrastructure
btrfs: Use xattr handler infrastructure
vfs: Distinguish between full xattr names and proper prefixes
posix acls: Remove duplicate xattr name definitions
gfs2: Remove gfs2_xattr_acl_chmod
vfs: Remove vfs_xattr_cmp
Pull vfs RCU symlink updates from Al Viro:
"Replacement of ->follow_link/->put_link, allowing to stay in RCU mode
even if the symlink is not an embedded one.
No changes since the mailbomb on Jan 1"
* 'work.symlinks' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
switch ->get_link() to delayed_call, kill ->put_link()
kill free_page_put_link()
teach nfs_get_link() to work in RCU mode
teach proc_self_get_link()/proc_thread_self_get_link() to work in RCU mode
teach shmem_get_link() to work in RCU mode
teach page_get_link() to work in RCU mode
replace ->follow_link() with new method that could stay in RCU mode
don't put symlink bodies in pagecache into highmem
namei: page_getlink() and page_follow_link_light() are the same thing
ufs: get rid of ->setattr() for symlinks
udf: don't duplicate page_symlink_inode_operations
logfs: don't duplicate page_symlink_inode_operations
switch befs long symlinks to page_symlink_operations
We may sleep inside a the lock, so use a mutex rather than spinlock.
new method: ->get_link(); replacement of ->follow_link(). The differences
are:
* inode and dentry are passed separately
* might be called both in RCU and non-RCU mode;
the former is indicated by passing it a NULL dentry.
* when called that way it isn't allowed to block
and should return ERR_PTR(-ECHILD) if it needs to be called
in non-RCU mode.
It's a flagday change - the old method is gone, all in-tree instances
converted. Conversion isn't hard; said that, so far very few instances
do not immediately bail out when called in RCU mode. That'll change
in the next commits.
For block devices the pagecache is associated with the inode
on bdevfs, not with the aliasing ones on the mountable filesystems.
The latter have its own ->i_data empty and ->i_mapping pointing
to the (unique per major/minor) bdevfs inode. That guarantees
cache coherence between all block device inodes with the same
device number.
Eviction of an alias inode has no business trying to evict the
pages belonging to bdevfs one; moreover, ->i_mapping is only
safe to access when the thing is opened. At the time of
->evict_inode() the victim is definitely *not* opened. We are
about to kill the address space embedded into struct inode
(inode->i_data) and that's what we need to empty of any pages.
9p instance tries to empty inode->i_mapping instead, which is
both unsafe and bogus - if we have several device nodes with
the same device number in different places, closing one of them
should not try to empty the (shared) page cache.
Fortunately, other instances in the tree are OK; they are
evicting from &inode->i_data instead, as 9p one should.
Cc: stable@vger.kernel.org # v2.6.32+, ones prior to 2.6.36 need only half of that
Reported-by: "Suzuki K. Poulose" <Suzuki.Poulose@arm.com>
Tested-by: "Suzuki K. Poulose" <Suzuki.Poulose@arm.com>
Add an additional "name" field to struct xattr_handler. When the name
is set, the handler matches attributes with exactly that name. When the
prefix is set instead, the handler matches attributes with the given
prefix and with a non-empty suffix.
This patch should avoid bugs like the one fixed in commit c361016a in
the future.
Reviewed-by: James Morris <james.l.morris@oracle.com>
