path: root/fs/9p
2011-09-06fs/9p: Use protocol-defined value for lock/getlock 'type' field.Jim Garlick
Signed-off-by: Jim Garlick <garlick@llnl.gov> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2011-09-06fs/9p: Always ask new inode in lookup for cache mode disabledAneesh Kumar K.V
This make sure we don't end up reusing the unlinked inode object. The ideal way is to use inode i_generation. But i_generation is not available in userspace always. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2011-09-06fs/9p: Add OS dependent open flags in 9p protocolAneesh Kumar K.V
Some of the flags are OS/arch dependent we add a 9p protocol value which maps to asm-generic/fcntl.h values in Linux Based on the original patch from Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2011-09-06fs/9p: Don't update file type when updating file attributesAneesh Kumar K.V
We should only update attributes that we can change on stat2inode. Also do file type initialization in v9fs_init_inode. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-09-06fs/9p: Add fid before dentry instantiationAneesh Kumar K.V
d_instantiate marks the dentry positive. So a parallel lookup and mkdir of the directory can find dentry that doesn't have fid attached. This can result in both the code path doing v9fs_fid_add which results in v9fs_dentry leak. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-08-01switch posix_acl_equiv_mode() to umode_t *Al Viro
... so that &inode->i_mode could be passed to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01switch posix_acl_create() to umode_t *Al Viro
so we can pass &inode->i_mode to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25p9: avoid unused variable warningLinus Torvalds
Commit 4e34e719e457 ("fs: take the ACL checks to common code") removed the use of the 'acl' variable in v9fs_iop_get_acl(), but left the variable definition around. Remove it to get rid of the warning: fs/9p/acl.c: In function ‘v9fs_iop_get_acl’: fs/9p/acl.c:101:20: warning: unused variable ‘acl’ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fs: take the ACL checks to common code bury posix_acl_..._masq() variants kill boilerplates around posix_acl_create_masq() generic_acl: no need to clone acl just to push it to set_cached_acl() kill boilerplate around posix_acl_chmod_masq() reiserfs: cache negative ACLs for v1 stat format xfs: cache negative ACLs if there is no attribute fork 9p: do no return 0 from ->check_acl without actually checking vfs: move ACL cache lookup into generic code CIFS: Fix oops while mounting with prefixpath xfs: Fix wrong return value of xfs_file_aio_write fix devtmpfs race caam: don't pass bogus S_IFCHR to debugfs_create_...() get rid of create_proc_entry() abuses - proc_mkdir() is there for purpose asus-wmi: ->is_visible() can't return negative fix jffs2 ACLs on big-endian with 16bit mode_t 9p: close ACL leaks ocfs2_init_acl(): fix a leak VFS : mount lock scalability for internal mounts
2011-07-25fs: take the ACL checks to common codeChristoph Hellwig
Replace the ->check_acl method with a ->get_acl method that simply reads an ACL from disk after having a cache miss. This means we can replace the ACL checking boilerplate code with a single implementation in namei.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplates around posix_acl_create_masq()Al Viro
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with modified clone, on failure releases acl and replaces with NULL. Returns 0 or -ve on error. All callers of posix_acl_create_masq() switched. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplate around posix_acl_chmod_masq()Al Viro
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified clone or with NULL if that has failed; returns 0 or -ve on error. All callers of posix_acl_chmod_masq() switched to that - they'd been doing exactly the same thing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-259p: do no return 0 from ->check_acl without actually checkingChristoph Hellwig
If we do not want to use ACLs we at least need to perform normal Unix permission checks. From the comment I'm not quite sure that's what is intended, but if 0p wants to do permission checks entirely on the server it needs to do so in ->permission, not in ->check_acl. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25vfs: move ACL cache lookup into generic codeLinus Torvalds
This moves logic for checking the cached ACL values from low-level filesystems into generic code. The end result is a streamlined ACL check that doesn't need to load the inode->i_op->check_acl pointer at all for the common cached case. The filesystems also don't need to check for a non-blocking RCU walk case in their acl_check() functions, because that is all handled at a VFS layer. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-249p: close ACL leaksAl Viro
2011-07-23fs/9p: add 9P2000.L unlinkat operationAneesh Kumar K.V
unlinkat - Remove a directory entry size[4] Tunlinkat tag[2] dirfid[4] name[s] flag[4] size[4] Runlinkat tag[2] older Tremove have the below request format size[4] Tremove tag[2] fid[4] The remove message is used to remove a directory entry either file or directory The remove opreation is actually a directory opertation and should ideally have dirfid, if not we cannot represent the fid on server with anything other than name. We will have to derive the directory name from fid in the Tremove request. NOTE: The operation doesn't clunk the unlink fid. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: add 9P2000.L renameat operationAneesh Kumar K.V
renameat - change name of file or directory size[4] Trenameat tag[2] olddirfid[4] oldname[s] newdirfid[4] newname[s] size[4] Rrenameat tag[2] older Trename have the below request format size[4] Trename tag[2] fid[4] newdirfid[4] name[s] The rename message is used to change the name of a file, possibly moving it to a new directory. The rename opreation is actually a directory opertation and should ideally have olddirfid, if not we cannot represent the fid on server with anything other than name. We will have to derive the old directory name from fid in the Trename request. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: Always ask new inode in createAneesh Kumar K.V
This make sure we don't end up reusing the unlinked inode object. The ideal way is to use inode i_generation. But i_generation is not available in userspace always. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: Fix invalid mount options/argsPrem Karat
Without this fix, if any invalid mount options/args are passed while mouting the 9p fs, no error (-EINVAL) is returned and default arg value is assigned. This fix returns -EINVAL when an invalid arguement is found while parsing mount options. Signed-off-by: Prem Karat <prem.karat@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: When doing inode lookup compare qid details and inode mode bits.Aneesh Kumar K.V
This make sure we don't use wrong inode from the inode hash. The inode number of the file deleted is reused by the next file system object created and if we only use inode number for inode hash lookup we could end up with wrong struct inode. Also compare inode generation number. Not all Linux file system provide st_gen in userspace. So it could be 0; Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: remove rename work around in 9pAneesh Kumar K.V
Now that VFS does the right thing remove the work around. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20no need to check for LOOKUP_OPEN in ->create() instancesAl Viro
... it will be set in nd->flag for all cases with non-NULL nd (i.e. when called from do_last()). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20don't transliterate lower bits of ->intent.open.flags to FMODE_...Al Viro
->create() instances are much happier that way... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->check_acl()Al Viro
not used in the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: pass MAY_NOT_BLOCK to ->check_acl()Al Viro
2011-05-289p: remove unnecessary dentry_unhash on rmdir, dir renameSage Weil
9p has no problems with references to unlinked directories. CC: Eric Van Hensbergen <ericvh@gmail.com> CC: Ron Minnich <rminnich@sandia.gov> CC: Latchesar Ionkov <lucho@ionkov.net> CC: v9fs-developer@lists.sourceforge.net Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (25 commits) cifs: remove unnecessary dentry_unhash on rmdir/rename_dir ocfs2: remove unnecessary dentry_unhash on rmdir/rename_dir exofs: remove unnecessary dentry_unhash on rmdir/rename_dir nfs: remove unnecessary dentry_unhash on rmdir/rename_dir ext2: remove unnecessary dentry_unhash on rmdir/rename_dir ext3: remove unnecessary dentry_unhash on rmdir/rename_dir ext4: remove unnecessary dentry_unhash on rmdir/rename_dir btrfs: remove unnecessary dentry_unhash in rmdir/rename_dir ceph: remove unnecessary dentry_unhash calls vfs: clean up vfs_rename_other vfs: clean up vfs_rename_dir vfs: clean up vfs_rmdir vfs: fix vfs_rename_dir for FS_RENAME_DOES_D_MOVE filesystems libfs: drop unneeded dentry_unhash vfs: update dentry_unhash() comment vfs: push dentry_unhash on rename_dir into file systems vfs: push dentry_unhash on rmdir into file systems vfs: remove dget() from dentry_unhash() vfs: dentry_unhash immediately prior to rmdir vfs: Block mmapped writes while the fs is frozen ...
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-25fs/9p: Don't clunk dentry fid when we fail to get a writeback inodeAneesh Kumar K.V
The dentry fid get clunked via the dput. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-05-259p: remove experimental tag from tested configurationsEric Van Hensbergen
The 9p client is currently undergoing regular regresssion and stress testing as a by-product of the virtfs work. I think its finally time to take off the experimental tags from the well-tested code paths. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-04-15fs/9p: Fix error reported by coccicheckAneesh Kumar K.V
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-04-159p: revert tsyncfs related changesAneesh Kumar K.V
Now that we use write_inode to flush server cache related to fid, we don't need tsyncfs either fort dotl or dotu protocols. For dotu this helps to do a more efficient server flush. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-04-15fs/9p: Use write_inode for data sync on serverAneesh Kumar K.V
2011-04-15fs/9p: Fix revalidate to return correct valueAneesh Kumar K.V
revalidate should return > 0 on success. Also return 0 on ENOENT to force do_revalidate to return NULL dentry; Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-229p: use the updated offset given by generic_write_checksM. Mohan Kumar
Without this fix, even if a file is opened in O_APPEND mode, data will be written at current file position instead of end of file. Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-22fs/9p: Add v9fs_dentry2v9sesAneesh Kumar K.V
Add the new static inline and use the same Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-22fs/9p: Attach writeback_fid on first open with WR flagAneesh Kumar K.V
We don't need writeback fid if we are only doing O_RDONLY open Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-22fs/9p: Open writeback fid in O_SYNC modeAneesh Kumar K.V
Older version of protocol don't support tsyncfs operation. So for them force a O_SYNC flag on the server Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-22fs/9p: Use truncate_setsize instead of vmtruncateAneesh Kumar K.V
convert vmtruncate usage to truncate_setsize. We also writeback all dirty pages before doing 9p operations and on success call truncate_setsize. This ensure that we continue sanely on failed truncate on the server. The disadvantage is that we are now going to write back the content that get thrown away later as a part of truncate. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-22fs/9p: Fix race in initializing writeback fidAneesh Kumar K.V
When two process open the same file we can end up with both of them allocating the writeback_fid. Add a new mutex which can be used for synchronizing v9fs_inode member values. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Make the writeback_fid owned by rootAneesh Kumar K.V
Changes to make sure writeback fid is owned by root Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Writeback dirty data before setattrAneesh Kumar K.V
change file attribute can result in making the file readonly. So flush the dirty pages before that. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: call vmtruncate before setattr 9p opeationAneesh Kumar K.V
We need to call vmtruncate before 9p setattr operation, otherwise we could write back some dirty pages between setattr with ATTR_SIZE and vmtruncate causing some truncated pages to be written back to server Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Properly update inode attributes on linkAneesh Kumar K.V
With caching enabled, we need to make sure we don't update inode->i_size via stat2inode because we could have dirty data which is not yet written to the server Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Prevent multiple inclusion of same headerAneesh Kumar K.V
Add necessary #ifndef #endif blocks to avoid mulitple inclusion of same headers Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Workaround vfs rename rehash bugAneesh Kumar K.V
This is similar to what ceph, ocfs2 and nfs does http://kerneltrap.org/mailarchive/linux-fsdevel/2008/4/18/1498534 May be we should get vfs fixed Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15fs/9p: Mark directory inode invalid for many directory inode operationsAneesh Kumar K.V
One successfull directory operation we would have changed directory inode attribute. So mark them invalid Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
