path: root/fs/adfs
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-01-06vfs: switch ->show_options() to struct dentry *Al Viro
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-23fs/adfs/adfs.h: fix unsigned comparisonAndrew Morton
fs/adfs/adfs.h: In function 'append_filetype_suffix': fs/adfs/adfs.h:115: warning: comparison is always false due to limited range of data type Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Stuart Swales <stuart.swales.croftnuisk@gmail.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22adfs: add hexadecimal filetype suffix optionStuart Swales
ADFS (FileCore) storage complies with the RISC OS filetype specification (12 bits of file type information is stored in the file load address, rather than using a file extension). The existing driver largely ignores this information and does not present it to the end user. It is desirable that stored filetypes be made visible to the end user to facilitate a precise copy of data and metadata from a hard disc (or image thereof) into a RISC OS emulator (such as RPCEmu) or to a network share which can be accessed by real Acorn systems. This patch implements a per-mount filetype suffix option (use -o ftsuffix=1) to present any filetype as a ,xyz hexadecimal suffix on each file. This type suffix is compatible with that used by RISC OS systems that access network servers using NFS client software and by RPCemu's host filing system. Signed-off-by: Stuart Swales <stuart.swales.croftnuisk@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22adfs: improve timestamp precisionStuart Swales
ADFS (FileCore) storage complies with the RISC OS timestamp specification (40-bit centiseconds since 01 Jan 1900 00:00:00). It is desirable that stored timestamp precision be maintained to facilitate a precise copy of data and metadata from a hard disc (or image thereof) into a RISC OS emulator (such as RPCEmu). This patch implements a full-precision conversion from ADFS to Unix timestamp as the existing driver, for ease of calculation with old 32-bit compilers, uses the common trick of shifting the 40-bits representing centiseconds around into 32-bits representing seconds thereby losing precision. Signed-off-by: Stuart Swales<stuart.swales.croftnuisk@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22adfs: fix E+/F+ dir size > 2048 crashing kernelStuart Swales
Kernel crashes in fs/adfs module when accessing directories with a large number of objects on mounted Acorn ADFS E+/F+ format discs (or images) as the existing code writes off the end of the fixed array of struct buffer_head pointers. Additionally, each directory access that didn't crash would leak a buffer as nr_buffers was not adjusted correctly for E+/F+ discs (was always left as one less than required). The patch fixes this by allocating a dynamically-sized set of struct buffer_head pointers if necessary for the E+/F+ case (many directories still do in fact fit in 2048 bytes) and sets the correct nr_buffers so that all buffers are released. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=26072 Tested by tar'ing the contents of my RISC PC's E+ format 20Gb HDD which contains a number of large directories that previously crashed the kernel. Signed-off-by: Stuart Swales <stuart.swales.croftnuisk@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-02adfs: remove the big kernel lockArnd Bergmann
According to Russell King, adfs was written to not require the big kernel lock, and all inode updates are done under adfs_dir_lock. All other metadata in adfs is read-only and does not require locking. The use of the BKL is the result of various pushdowns from the VFS operations. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Stuart Swales <stuart.swales.croftnuisk@gmail.com>
2011-01-12switch adfsAl Viro
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_hash for rcu-walkNick Piggin
Change d_hash so it may be called from lock-free RCU lookups. See similar patch for d_compare for details. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_compare for rcu-walkNick Piggin
Change d_compare so it may be called from lock-free RCU lookups. This does put significant restrictions on what may be done from the callback, however there don't seem to have been any problems with in-tree fses. If some strange use case pops up that _really_ cannot cope with the rcu-walk rules, we can just add new rcu-unaware callbacks, which would cause name lookup to drop out of rcu-walk mode. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-22Merge branch 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: (30 commits) BKL: remove BKL from freevxfs BKL: remove BKL from qnx4 autofs4: Only declare function when CONFIG_COMPAT is defined autofs: Only declare function when CONFIG_COMPAT is defined ncpfs: Lock socket in ncpfs while setting its callbacks fs/locks.c: prepare for BKL removal BKL: Remove BKL from ncpfs BKL: Remove BKL from OCFS2 BKL: Remove BKL from squashfs BKL: Remove BKL from jffs2 BKL: Remove BKL from ecryptfs BKL: Remove BKL from afs BKL: Remove BKL from USB gadgetfs BKL: Remove BKL from autofs4 BKL: Remove BKL from isofs BKL: Remove BKL from fat BKL: Remove BKL from ext2 filesystem BKL: Remove BKL from do_new_mount() BKL: Remove BKL from cgroup BKL: Remove BKL from NTFS ...
2010-10-21BKL: introduce CONFIG_BKL.Arnd Bergmann
With all the patches we have queued in the BKL removal tree, only a few dozen modules are left that actually rely on the BKL, and even there are lots of low-hanging fruit. We need to decide what to do about them, this patch illustrates one of the options: Every user of the BKL is marked as 'depends on BKL' in Kconfig, and the CONFIG_BKL becomes a user-visible option. If it gets disabled, no BKL using module can be built any more and the BKL code itself is compiled out. The one exception is file locking, which is practically always enabled and does a 'select BKL' instead. This effectively forces CONFIG_BKL to be enabled until we have solved the fs/lockd mess and can apply the patch that removes the BKL from fs/locks.c. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-09check ATTR_SIZE contraints in inode_change_okChristoph Hellwig
Make sure we check the truncate constraints early on in ->setattr by adding those checks to inode_change_ok. Also clean up and document inode_change_ok to make this obvious. As a fallout we don't have to call inode_newsize_ok from simple_setsize and simplify it down to a truncate_setsize which doesn't return an error. This simplifies a lot of setattr implementations and means we use truncate_setsize almost everywhere. Get rid of fat_setsize now that it's trivial and mark ext2_setsize static to make the calling convention obvious. Keep the inode_newsize_ok in vmtruncate for now as all callers need an audit for its removal anyway. Note: setattr code in ecryptfs doesn't call inode_change_ok at all and needs a deeper audit, but that is left for later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of cont_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to cont_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27kill spurious reference to vmtruncatenpiggin@suse.de
Lots of filesystems calls vmtruncate despite not implementing the old ->truncate method. Switch them to use simple_setsize and add some comments about the truncate code where it seems fitting. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-24adfs: remove redundant test on unsignedRoel Kluin
unsigned block cannot be less than 0. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-17Cleanup of adfs headersAl Viro
2009-06-11Fix adfs GET_FRAG_ID() on big-endianAl Viro
Missing conversion to host-endian before doing shifts Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11repair adfs ->write_inode(), switch to simple_fsync()Al Viro
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-02fs/adfs: return f_fsid for statfs(2)Coly Li
Currently many file systems in Linux kernel do not return f_fsid in statfs info, the value is set as 0 in vfs layer. Anyway, in some conditions, f_fsid from statfs(2) is useful, especially being used as (f_fsid, ino) pair to uniquely identify a file. Basic idea of the patches is generating a unique fs ID by huge_encode_dev(sb->s_bdev->bd_dev) during file system mounting life time (no endian consistent issue). sb is a point of struct super_block of current mounted file system being accessed by statfs(2). This patch: Make adfs return f_fsid info for statfs(2), and do a little variable renaming in adfs_statfs(). Signed-off-by: Coly Li <coly.li@suse.de> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: "Sergey S. Kostyliov" <rathamahata@php4.ru> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Bob Copeland <me@bobcopeland.com> Cc: Anders Larsen <al@alarsen.net> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Jan Kara <jack@suse.cz> Cc: Andreas Dilger <adilger@sun.com> Cc: Jamie Lokier <jamie@shareable.org> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27constify dentry_operations: misc filesystemsAl Viro
2009-01-22fs/Kconfig: move adfs outAlexey Dobriyan
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-25[PATCH] fix ->llseek() for a bunch of directoriesAl Viro
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30fs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-29adfs: work around bogus sparse warningHarvey Harrison
fs/adfs/dir_f.c:126:4: warning: do-while statement is not a compound statement Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mount options: fix adfsMiklos Szeredi
Add a .show_options super operation to adfs. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fs: adfs convert to new aopsNick Piggin
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-01-05[PATCH] adfs: fix filename handlingJames Bursa
Fix filenames on adfs discs being terminated at the first character greater than 128 (adfs filenames are Latin 1). I saw this problem when using a loopback adfs image on a 2.6.17-rc5 x86_64 machine, and the patch fixed it there. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
