path: root/fs/affs/amigaffs.c
2011-01-07fs: dcache per-inode inode alias lockingNick Piggin
dcache_inode_lock can be replaced with per-inode locking. Use existing inode->i_lock for this. This is slightly non-trivial because we sometimes need to find the inode from the dentry, which requires d_inode to be stabilised (either with refcount or d_lock). Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove dcache_lockNick Piggin
dcache_lock no longer protects anything. remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: scale inode alias listNick Piggin
Add a new lock, dcache_inode_lock, to protect the inode's i_dentry list from concurrent modification. d_alias is also protected by d_lock. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2009-03-27affs: fix missing unlocks in affs_remove_linkChristoph Hellwig
In two error cases affs_remove_link doesn't call affs_unlock_dir to release the i_hash_lock semaphore. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-07iget: stop AFFS from using iget() and read_inode()David Howells
Stop the AFFS filesystem from using iget() and read_inode(). Replace affs_read_inode() with affs_iget(), and call that instead of iget(). affs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. affs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] fs/*: trivial vsnprintf() conversionAlexey Dobriyan
It would very lame to get buffer overflow via one of the following. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
