path: root/fs/affs
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-28affs: remove unnecessary dentry_unhash on rmdir, dir renameSage Weil
affs has no problems with references to unlinked directories. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-17fs: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. And change ntfs-objs to ntfs-y for cleaner conditional inclusion. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-12switch affsAl Viro
either d_op instance would work for root, actually... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: dcache per-inode inode alias lockingNick Piggin
dcache_inode_lock can be replaced with per-inode locking. Use existing inode->i_lock for this. This is slightly non-trivial because we sometimes need to find the inode from the dentry, which requires d_inode to be stabilised (either with refcount or d_lock). Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove dcache_lockNick Piggin
dcache_lock no longer protects anything. remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: scale inode alias listNick Piggin
Add a new lock, dcache_inode_lock, to protect the inode's i_dentry list from concurrent modification. d_alias is also protected by d_lock. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_hash for rcu-walkNick Piggin
Change d_hash so it may be called from lock-free RCU lookups. See similar patch for d_compare for details. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_compare for rcu-walkNick Piggin
Change d_compare so it may be called from lock-free RCU lookups. This does put significant restrictions on what may be done from the callback, however there don't seem to have been any problems with in-tree fses. If some strange use case pops up that _really_ cannot cope with the rcu-walk rules, we can just add new rcu-unaware callbacks, which would cause name lookup to drop out of rcu-walk mode. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25affs: testing the wrong variableDan Carpenter
The intent was to verify that bh = affs_bread_ino(...) returned a valid pointer. We checked "ext_bh" earlier in the function and it's valid here. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-22Merge branch 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: (30 commits) BKL: remove BKL from freevxfs BKL: remove BKL from qnx4 autofs4: Only declare function when CONFIG_COMPAT is defined autofs: Only declare function when CONFIG_COMPAT is defined ncpfs: Lock socket in ncpfs while setting its callbacks fs/locks.c: prepare for BKL removal BKL: Remove BKL from ncpfs BKL: Remove BKL from OCFS2 BKL: Remove BKL from squashfs BKL: Remove BKL from jffs2 BKL: Remove BKL from ecryptfs BKL: Remove BKL from afs BKL: Remove BKL from USB gadgetfs BKL: Remove BKL from autofs4 BKL: Remove BKL from isofs BKL: Remove BKL from fat BKL: Remove BKL from ext2 filesystem BKL: Remove BKL from do_new_mount() BKL: Remove BKL from cgroup BKL: Remove BKL from NTFS ...
2010-10-12affs: Use sema_init instead of init_MUTEXThomas Gleixner
Get rid of init_MUTE() and use sema_init() instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> LKML-Reference: <20100907125056.511395595@linutronix.de>
2010-10-04BKL: Remove BKL from Amiga FFSJan Blunck
The BKL is only used in put_super, fill_super and remount_fs that are all three protected by the superblocks s_umount rw_semaphore. Therefore it is safe to remove the BKL entirely. Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-09AFFS: wait for sb synchronization when neededArtem Bityutskiy
AFFS does not ever wait for superblock synchronization in ->put_super(), ->write_super, and ->sync_fs(). However, it should wait for synchronization in ->put_super() because it is about to be unmounted, in ->write_super() because this is periodic SB synchronization performed from a separate kernel thread, and in ->sync_fs() it should respect the 'wait' flag. This patch fixes the situation. Also, in ->put_super(), do not write the SB if it is not dirty. Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09AFFS: clean up dirty flag usageArtem Bityutskiy
In 'affs_write_super()': remove ancient and wrong commented code, remove unneeded 'clean' variable, so the function becomes a bit cleaner and simpler. In 'affs_remount(): remove unnecessary SB dirty flag changes. Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09switch affs to ->evict_inode()Al Viro
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of cont_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to cont_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2010-05-27fs/affs: use ERR_CASTJulia Lawall
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more clear what is the purpose of the operation, which otherwise looks like a no-op. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ type T; T x; identifier f; @@ T f (...) { <+... - ERR_PTR(PTR_ERR(x)) + x ...+> } @@ expression x; @@ - ERR_PTR(PTR_ERR(x)) + ERR_CAST(x) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-26fix affs parse_options()Al Viro
Error handling in that sucker got broken back in 2003. If function returns 0 on failure, it's not nice to add return -EINVAL into it. Adding return 1 on other failure exits is also not a good thing (and yes, original success exits with 1 and some of failure exits with 0 are still there; so's the original logics in callers). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-01-26Fix remount races with symlink handling in affsAl Viro
A couple of fields in affs_sb_info is used in follow_link() and symlink() for handling AFFS "absolute" symlinks. Need locking against affs_remount() updates. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-01-26Fix a leak in affs_fill_super()Al Viro
2009-06-11affs: add ->sync_fsChristoph Hellwig
Add a ->sync_fs method for data integrity syncs. Factor out common code between affs_put_super, affs_write_super and the new affs_sync_fs into a helper. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11sanitize ->fsync() for affsAl Viro
unfortunately, for affs (especially for affs directories) we have no real way to keep track of metadata ownership. So we have to do more or less what file_fsync() does, but we do *not* need to call write_super() there. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11Push BKL down into ->remount_fs()Alessio Igor Bogani
[xfs, btrfs, capifs, shmem don't need BKL, exempt] Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11->write_super lock_super pushdownChristoph Hellwig
Push down lock_super into ->write_super instances and remove it from the caller. Following filesystem don't need ->s_lock in ->write_super and are skipped: * bfs, nilfs2 - no other uses of s_lock and have internal locks in ->write_super * ext2 - uses BKL in ext2_write_super and has internal calls without s_lock * reiserfs - no other uses of s_lock as has reiserfs_write_lock (BKL) in ->write_super * xfs - no other uses of s_lock and uses internal lock (buffer lock on superblock buffer) to serialize ->write_super. Also xfs_fs_write_super is superflous and will go away in the next merge window Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09Fix races around the access to ->s_optionsAl Viro
Put generic_show_options read access to s_options under rcu_read_lock, split save_mount_options() into "we are setting it the first time" (uses in foo_fill_super()) and "we are relacing and freeing the old one", synchronize_rcu() before kfree() in the latter. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-02fs/affs: return f_fsid for statfs(2)Coly Li
Make affs return f_fsid info for statfs(2). Signed-off-by: Coly Li <coly.li@suse.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27constify dentry_operations: misc filesystemsAl Viro
2009-03-27affs: fix missing unlocks in affs_remove_linkChristoph Hellwig
In two error cases affs_remove_link doesn't call affs_unlock_dir to release the i_hash_lock semaphore. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-22fs/Kconfig: move affs outAlexey Dobriyan
2009-01-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: inotify: fix type errors in interfaces fix breakage in reiserfs_new_inode() fix the treatment of jfs special inodes vfs: remove duplicate code in get_fs_type() add a vfs_fsync helper sys_execve and sys_uselib do not call into fsnotify zero i_uid/i_gid on inode allocation inode->i_op is never NULL ntfs: don't NULL i_op isofs check for NULL ->i_op in root directory is dead code affs: do not zero ->i_op kill suid bit only for regular files vfs: lseek(fd, 0, SEEK_CUR) race condition
2009-01-05affs: do not zero ->i_opAl Viro
it is already set to empty table and should never be NULL Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04fs: symlink write_begin allocation context fixNick Piggin
With the write_begin/write_end aops, page_symlink was broken because it could no longer pass a GFP_NOFS type mask into the point where the allocations happened. They are done in write_begin, which would always assume that the filesystem can be entered from reclaim. This bug could cause filesystem deadlocks. The funny thing with having a gfp_t mask there is that it doesn't really allow the caller to arbitrarily tinker with the context in which it can be called. It couldn't ever be GFP_ATOMIC, for example, because it needs to take the page lock. The only thing any callers care about is __GFP_FS anyway, so turn that into a single flag. Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on this flag in their write_begin function. Change __grab_cache_page to accept a nofs argument as well, to honour that flag (while we're there, change the name to grab_cache_page_write_begin which is more instructive and does away with random leading underscores). This is really a more flexible way to go in the end anyway -- if a filesystem happens to want any extra allocations aside from the pagecache ones in ints write_begin function, it may now use GFP_KERNEL (rather than GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a random example). [kosaki.motohiro@jp.fujitsu.com: fix ubifs] [kosaki.motohiro@jp.fujitsu.com: fix fuse] Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <stable@kernel.org> [2.6.28.x] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Cleaned up the calling convention: just pass in the AOP flags untouched to the grab_cache_page_write_begin() function. That just simplifies everybody, and may even allow future expansion of the logic. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Wrap task credential accesses in the AFFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: James Morris <jmorris@namei.org>
