path: root/fs/afs/inode.c
2013-02-13afs: Support interacting with multiple user namespacesEric W. Biederman
Modify struct afs_file_status to store owner as a kuid_t and group as a kgid_t. In xdr_decode_AFSFetchStatus as owner is now a kuid_t and group is now a kgid_t don't use the EXTRACT macro. Instead perform the work of the extract macro explicitly. Read the value with ntohl and convert it to the appropriate type with make_kuid or make_kgid. Test if the value is different from what is stored in status and update changed. Update the value in status. In xdr_encode_AFS_StoreStatus call from_kuid or from_kgid as we are computing the on the wire encoding. Initialize uids with GLOBAL_ROOT_UID instead of 0. Initialize gids with GLOBAL_ROOT_GID instead of 0. Cc: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-06-16AFS: Use i_generation not i_version for the vnode uniquifierDavid Howells
Store the AFS vnode uniquifier in the i_generation field, not the i_version field of the inode struct. i_version can then be given the AFS data version number. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15AFS: Use d_automount() rather than abusing follow_link()David Howells
Make AFS use the new d_automount() dentry operation rather than abusing follow_link() on directories. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-11AFS: Implement an autocell mount capability [ver #2]wanglei
Implement the ability for the root directory of a mounted AFS filesystem to accept lookups of arbitrary directory names, to interpet the names as the names of cells, to look the cell names up in the DNS for AFSDB records and to mount the root.cell volume of the nominated cell on the pseudo-directory created by lookup. This facility is requested by passing: -o autocell to the mountpoint for which this is desired, usually the /afs mount. To use this facility, a DNS upcall program is required for AFSDB records. This can be obtained from: http://people.redhat.com/~dhowells/afs/dns.afsdb.c It should be compiled with -lresolv and -lkeyutils and installed as, say: /usr/sbin/dns.afsdb Then the following line needs to be added to /sbin/request-key.conf: create dns_resolver afsdb:* * /usr/sbin/dns.afsdb %k This can be tested by mounting AFS, say: insmod dns_resolver.ko insmod af-rxrpc.ko insmod kafs.ko rootcell=grand.central.org mount -t afs "#grand.central.org:root.cell." /afs -o autocell and doing: ls /afs/grand.central.org/ which should show: archive/ cvs/ doc/ local/ project/ service/ software/ user/ www/ if it works. Signed-off-by: Wang Lei <wang840925@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-09convert remaining ->clear_inode() to ->evict_inode()Al Viro
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-04-03FS-Cache: Make kAFS use FS-CacheDavid Howells
The attached patch makes the kAFS filesystem in fs/afs/ use FS-Cache, and through it any attached caches. The kAFS filesystem will use caching automatically if it's available. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2008-06-06Fix various old email addresses for dwmw2David Woodhouse
Although if people have questions about ARCnet, perhaps it's _better_ for them to be mailing dwmw2@cam.ac.uk about it... Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: use iget_failed() in AFSDavid Howells
Use iget_failed() in AFS to kill a failed inode. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28vfs: Add 64 bit i_version supportJean Noel Cordenner
The i_version field of the inode is changed to be a 64-bit counter that is set on every inode creation and that is incremented every time the inode data is modified (similarly to the "ctime" time-stamp). The aim is to fulfill a NFSv4 requirement for rfc3530. This first part concerns the vfs, it converts the 32-bit i_version in the generic inode to a 64-bit, a flag is added in the super block in order to check if the feature is enabled and the i_version is incremented in the vfs. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Jean Noel Cordenner <jean-noel.cordenner@bull.net> Signed-off-by: Kalpak Shah <kalpak@clusterfs.com>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11AFS: fix a couple of problems with unlinking AFS filesDavid Howells
Fix a couple of problems with unlinking AFS files. (1) The parent directory wasn't being updated properly between unlink() and the following lookup(). It seems that, for some reason, invalidate_remote_inode() wasn't discarding the directory contents correctly, so this patch calls invalidate_inode_pages2() instead on non-regular files. (2) afs_vnode_deleted_remotely() should handle vnodes that don't have a source server recorded without oopsing. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09AFS: implement basic file write supportDavid Howells
Implement support for writing to regular AFS files, including: (1) write (2) truncate (3) fsync, fdatasync (4) chmod, chown, chgrp, utime. AFS writeback attempts to batch writes into as chunks as large as it can manage up to the point that it writes back 65535 pages in one chunk or it meets a locked page. Furthermore, if a page has been written to using a particular key, then should another write to that page use some other key, the first write will be flushed before the second is allowed to take place. If the first write fails due to a security error, then the page will be scrapped and reread before the second write takes place. If a page is dirty and the callback on it is broken by the server, then the dirty data is not discarded (same behaviour as NFS). Shared-writable mappings are not supported by this patch. [akpm@linux-foundation.org: fix a bunch of warnings] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09AFS: AFS fixupsDavid Howells
Make some miscellaneous changes to the AFS filesystem: (1) Assert RCU barriers on module exit to make sure RCU has finished with callbacks in this module. (2) Correctly handle the AFS server returning a zero-length read. (3) Split out data zapping calls into one function (afs_zap_data). (4) Rename some afs_file_*() functions to afs_*() where they apply to non-regular files too. (5) Be consistent about the presentation of volume ID:vnode ID in debugging output. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-26[AFS]: Fix u64 printing in debug logging.David S. Miller
Need 'unsigned long long' casts to quiet warnings on 64-bit platforms when using %ll on a u64. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Add "directory write" support.David Howells
Add support for the create, link, symlink, unlink, mkdir, rmdir and rename VFS operations to the in-kernel AFS filesystem. Also: (1) Fix dentry and inode revalidation. d_revalidate should only look at state of the dentry. Revalidation of the contents of an inode pointed to by a dentry is now separate. (2) Fix afs_lookup() to hash negative dentries as well as positive ones. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Add security support.David Howells
Add security support to the AFS filesystem. Kerberos IV tickets are added as RxRPC keys are added to the session keyring with the klog program. open() and other VFS operations then find this ticket with request_key() and either use it immediately (eg: mkdir, unlink) or attach it to a file descriptor (open). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Make the in-kernel AFS filesystem use AF_RXRPC.David Howells
Make the in-kernel AFS filesystem use AF_RXRPC instead of the old RxRPC code. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Clean up the AFS sourcesDavid Howells
Clean up the AFS sources. Also remove references to AFS keys. RxRPC keys are used instead. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[PATCH] afs: use generic_ro_fopsChristoph Hellwig
afs actually had a write method that returned different errors depending on whether some flag was set - better return the standard EINVAL errno. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
