path: root/fs/afs/main.c
2008-04-16AFS: Do not describe debug parameters with their valuePaul Bolle
Describe debug parameters with their names (and not their values). Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16AFS: implement file lockingDavid Howells
Implement file locking for AFS. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09AFS: AFS fixupsDavid Howells
Make some miscellaneous changes to the AFS filesystem: (1) Assert RCU barriers on module exit to make sure RCU has finished with callbacks in this module. (2) Correctly handle the AFS server returning a zero-length read. (3) Split out data zapping calls into one function (afs_zap_data). (4) Rename some afs_file_*() functions to afs_*() where they apply to non-regular files too. (5) Be consistent about the presentation of volume ID:vnode ID in debugging output. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-03[AFS]: Adjust the new netdevice scanning codeDavid Howells
Adjust the new netdevice scanning code provided by Patrick McHardy: (1) Restore the function banner comments that were dropped. (2) Rather than using an array size of 6 in some places and an array size of ETH_ALEN in others, pass a pointer instead and pass the array size through so that we can actually check it. (3) Do the buffer fill count check before checking the for_primary_ifa condition again. This permits us to skip that check should maxbufs be reached before we run out of interfaces. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Add support for the CB.GetCapabilities operation.David Howells
Add support for the CB.GetCapabilities operation with which the fileserver can ask the client for the following information: (1) The list of network interfaces it has available as IPv4 address + netmask plus the MTUs. (2) The client's UUID. (3) The extended capabilities of the client, for which the only current one is unified error mapping (abort code interpretation). To support this, the patch adds the following routines to AFS: (1) A function to iterate through all the network interfaces using RTNETLINK to extract IPv4 addresses and MTUs. (2) A function to iterate through all the network interfaces using RTNETLINK to pull out the MAC address of the lowest index interface to use in UUID construction. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Make the in-kernel AFS filesystem use AF_RXRPC.David Howells
Make the in-kernel AFS filesystem use AF_RXRPC instead of the old RxRPC code. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Clean up the AFS sourcesDavid Howells
Clean up the AFS sources. Also remove references to AFS keys. RxRPC keys are used instead. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
