path: root/fs/afs
2014-02-01afs: proc cells and rootcell are writeablePali Rohár
Both proc files are writeable and used for configuring cells. But there is missing correct mode flag for writeable files. Without this patch both proc files are read only. [ It turns out they aren't really read-only, since root can write to them even if the write bit isn't set due to CAP_DAC_OVERRIDE ] Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-25afs: get rid of junk in fs/afs/proc.cAl Viro
kill pointless method instances and don't bother with ->owner - it's ignored for procfs files anyway, make use of remove_proc_subtree() for removal, get rid of cell->proc_dir. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-10-28Merge branch 'fscache' of ↵Trond Myklebust
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into linux-next Pull fs-cache fixes from David Howells: Can you pull these commits to fix an issue with NFS whereby caching can be enabled on a file that is open for writing by subsequently opening it for reading. This can be made to crash by opening it for writing again if you're quick enough. The gist of the patchset is that the cookie should be acquired at inode creation only and subsequently enabled and disabled as appropriate (which dispenses with the backing objects when they're not needed). The extra synchronisation that NFS does can then be dispensed with as it is thenceforth managed by FS-Cache. Could you send these on to Linus? This likely will need fixing also in CIFS and 9P also once the FS-Cache changes are upstream. AFS and Ceph are probably safe. * 'fscache' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs: NFS: Use i_writecount to control whether to get an fscache cookie in nfs_open() FS-Cache: Provide the ability to enable/disable cookies FS-Cache: Add use/unuse/wake cookie wrappers
2013-09-29afs: dget_parent() can't return a negative dentryAl Viro
2013-09-27FS-Cache: Provide the ability to enable/disable cookiesDavid Howells
Provide the ability to enable and disable fscache cookies. A disabled cookie will reject or ignore further requests to: Acquire a child cookie Invalidate and update backing objects Check the consistency of a backing object Allocate storage for backing page Read backing pages Write to backing pages but still allows: Checks/waits on the completion of already in-progress objects Uncaching of pages Relinquishment of cookies Two new operations are provided: (1) Disable a cookie: void fscache_disable_cookie(struct fscache_cookie *cookie, bool invalidate); If the cookie is not already disabled, this locks the cookie against other dis/enablement ops, marks the cookie as being disabled, discards or invalidates any backing objects and waits for cessation of activity on any associated object. This is a wrapper around a chunk split out of fscache_relinquish_cookie(), but it reinitialises the cookie such that it can be reenabled. All possible failures are handled internally. The caller should consider calling fscache_uncache_all_inode_pages() afterwards to make sure all page markings are cleared up. (2) Enable a cookie: void fscache_enable_cookie(struct fscache_cookie *cookie, bool (*can_enable)(void *data), void *data) If the cookie is not already enabled, this locks the cookie against other dis/enablement ops, invokes can_enable() and, if the cookie is not an index cookie, will begin the procedure of acquiring backing objects. The optional can_enable() function is passed the data argument and returns a ruling as to whether or not enablement should actually be permitted to begin. All possible failures are handled internally. The cookie will only be marked as enabled if provisional backing objects are allocated. A later patch will introduce these to NFS. Cookie enablement during nfs_open() is then contingent on i_writecount <= 0. can_enable() checks for a race between open(O_RDONLY) and open(O_WRONLY/O_RDWR). This simplifies NFS's cookie handling and allows us to get rid of open(O_RDONLY) accidentally introducing caching to an inode that's open for writing already. One operation has its API modified: (3) Acquire a cookie. struct fscache_cookie *fscache_acquire_cookie( struct fscache_cookie *parent, const struct fscache_cookie_def *def, void *netfs_data, bool enable); This now has an additional argument that indicates whether the requested cookie should be enabled by default. It doesn't need the can_enable() function because the caller must prevent multiple calls for the same netfs object and it doesn't need to take the enablement lock because no one else can get at the cookie before this returns. Signed-off-by: David Howells <dhowells@redhat.com
2013-09-07afs: get rid of redundant ->d_name.len checksAl Viro
No dentry can get to directory modification methods without having passed either ->lookup() or ->atomic_open(); if name is rejected by those two (or by ->d_hash()) with an error, it won't be seen by anything else. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-05afs: use check_submounts_and_drop()Miklos Szeredi
Do have_submounts(), shrink_dcache_parent() and d_drop() atomically. check_submounts_and_drop() can deal with negative dentries as well. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second set of VFS changes from Al Viro: "Assorted f_pos race fixes, making do_splice_direct() safe to call with i_mutex on parent, O_TMPFILE support, Jeff's locks.c series, ->d_hash/->d_compare calling conventions changes from Linus, misc stuff all over the place." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) Document ->tmpfile() ext4: ->tmpfile() support vfs: export lseek_execute() to modules lseek_execute() doesn't need an inode passed to it block_dev: switch to fixed_size_llseek() cpqphp_sysfs: switch to fixed_size_llseek() tile-srom: switch to fixed_size_llseek() proc_powerpc: switch to fixed_size_llseek() ubi/cdev: switch to fixed_size_llseek() pci/proc: switch to fixed_size_llseek() isapnp: switch to fixed_size_llseek() lpfc: switch to fixed_size_llseek() locks: give the blocked_hash its own spinlock locks: add a new "lm_owner_key" lock operation locks: turn the blocked_list into a hashtable locks: convert fl_link to a hlist_node locks: avoid taking global lock if possible when waking up blocked waiters locks: protect most of the file_lock handling with i_lock locks: encapsulate the fl_link list handling locks: make "added" in __posix_lock_file a bool ...
2013-07-02Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 update from Ted Ts'o: "Lots of bug fixes, cleanups and optimizations. In the bug fixes category, of note is a fix for on-line resizing file systems where the block size is smaller than the page size (i.e., file systems 1k blocks on x86, or more interestingly file systems with 4k blocks on Power or ia64 systems.) In the cleanup category, the ext4's punch hole implementation was significantly improved by Lukas Czerner, and now supports bigalloc file systems. In addition, Jan Kara significantly cleaned up the write submission code path. We also improved error checking and added a few sanity checks. In the optimizations category, two major optimizations deserve mention. The first is that ext4_writepages() is now used for nodelalloc and ext3 compatibility mode. This allows writes to be submitted much more efficiently as a single bio request, instead of being sent as individual 4k writes into the block layer (which then relied on the elevator code to coalesce the requests in the block queue). Secondly, the extent cache shrink mechanism, which was introduce in 3.9, no longer has a scalability bottleneck caused by the i_es_lru spinlock. Other optimizations include some changes to reduce CPU usage and to avoid issuing empty commits unnecessarily." * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (86 commits) ext4: optimize starting extent in ext4_ext_rm_leaf() jbd2: invalidate handle if jbd2_journal_restart() fails ext4: translate flag bits to strings in tracepoints ext4: fix up error handling for mpage_map_and_submit_extent() jbd2: fix theoretical race in jbd2__journal_restart ext4: only zero partial blocks in ext4_zero_partial_blocks() ext4: check error return from ext4_write_inline_data_end() ext4: delete unnecessary C statements ext3,ext4: don't mess with dir_file->f_pos in htree_dirblock_to_tree() jbd2: move superblock checksum calculation to jbd2_write_superblock() ext4: pass inode pointer instead of file pointer to punch hole ext4: improve free space calculation for inline_data ext4: reduce object size when !CONFIG_PRINTK ext4: improve extent cache shrink mechanism to avoid to burn CPU time ext4: implement error handling of ext4_mb_new_preallocation() ext4: fix corruption when online resizing a fs with 1K block size ext4: delete unused variables ext4: return FIEMAP_EXTENT_UNKNOWN for delalloc extents jbd2: remove debug dependency on debug_fs and update Kconfig help text jbd2: use a single printk for jbd_debug() ...
2013-06-29locks: protect most of the file_lock handling with i_lockJeff Layton
Having a global lock that protects all of this code is a clear scalability problem. Instead of doing that, move most of the code to be protected by the i_lock instead. The exceptions are the global lists that the ->fl_link sits on, and the ->fl_block list. ->fl_link is what connects these structures to the global lists, so we must ensure that we hold those locks when iterating over or updating these lists. Furthermore, sound deadlock detection requires that we hold the blocked_list state steady while checking for loops. We also must ensure that the search and update to the list are atomic. For the checking and insertion side of the blocked_list, push the acquisition of the global lock into __posix_lock_file and ensure that checking and update of the blocked_list is done without dropping the lock in between. On the removal side, when waking up blocked lock waiters, take the global lock before walking the blocked list and dequeue the waiters from the global list prior to removal from the fl_block list. With this, deadlock detection should be race free while we minimize excessive file_lock_lock thrashing. Finally, in order to avoid a lock inversion problem when handling /proc/locks output we must ensure that manipulations of the fl_block list are also protected by the file_lock_lock. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29[readdir] convert afsAl Viro
2013-05-21mm: change invalidatepage prototype to accept lengthLukas Czerner
Currently there is no way to truncate partial page where the end truncate point is not at the end of the page. This is because it was not needed and the functionality was enough for file system truncate operation to work properly. However more file systems now support punch hole feature and it can benefit from mm supporting truncating page just up to the certain point. Specifically, with this functionality truncate_inode_pages_range() can be changed so it supports truncating partial page at the end of the range (currently it will BUG_ON() if 'end' is not at the end of the page). This commit changes the invalidatepage() address space operation prototype to accept range to be invalidated and update all the instances for it. We also change the block_invalidatepage() in the same way and actually make a use of the new length argument implementing range invalidation. Actual file system implementations will follow except the file systems where the changes are really simple and should not change the behaviour in any way .Implementation for truncate_page_range() which will be able to accept page unaligned ranges will follow as well. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com>
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace and namespace infrastructure changes from Eric W Biederman: "This set of changes starts with a few small enhnacements to the user namespace. reboot support, allowing more arbitrary mappings, and support for mounting devpts, ramfs, tmpfs, and mqueuefs as just the user namespace root. I do my best to document that if you care about limiting your unprivileged users that when you have the user namespace support enabled you will need to enable memory control groups. There is a minor bug fix to prevent overflowing the stack if someone creates way too many user namespaces. The bulk of the changes are a continuation of the kuid/kgid push down work through the filesystems. These changes make using uids and gids typesafe which ensures that these filesystems are safe to use when multiple user namespaces are in use. The filesystems converted for 3.9 are ceph, 9p, afs, ocfs2, gfs2, ncpfs, nfs, nfsd, and cifs. The changes for these filesystems were a little more involved so I split the changes into smaller hopefully obviously correct changes. XFS is the only filesystem that remains. I was hoping I could get that in this release so that user namespace support would be enabled with an allyesconfig or an allmodconfig but it looks like the xfs changes need another couple of days before it they are ready." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (93 commits) cifs: Enable building with user namespaces enabled. cifs: Convert struct cifs_ses to use a kuid_t and a kgid_t cifs: Convert struct cifs_sb_info to use kuids and kgids cifs: Modify struct smb_vol to use kuids and kgids cifs: Convert struct cifsFileInfo to use a kuid cifs: Convert struct cifs_fattr to use kuid and kgids cifs: Convert struct tcon_link to use a kuid. cifs: Modify struct cifs_unix_set_info_args to hold a kuid_t and a kgid_t cifs: Convert from a kuid before printing current_fsuid cifs: Use kuids and kgids SID to uid/gid mapping cifs: Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID to keyring_alloc cifs: Use BUILD_BUG_ON to validate uids and gids are the same size cifs: Override unmappable incoming uids and gids nfsd: Enable building with user namespaces enabled. nfsd: Properly compare and initialize kuids and kgids nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids nfsd: Modify nfsd4_cb_sec to use kuids and kgids nfsd: Handle kuids and kgids in the nfs4acl to posix_acl conversion nfsd: Convert nfsxdr to use kuids and kgids nfsd: Convert nfs3xdr to use kuids and kgids ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-13afs: Support interacting with multiple user namespacesEric W. Biederman
Modify struct afs_file_status to store owner as a kuid_t and group as a kgid_t. In xdr_decode_AFSFetchStatus as owner is now a kuid_t and group is now a kgid_t don't use the EXTRACT macro. Instead perform the work of the extract macro explicitly. Read the value with ntohl and convert it to the appropriate type with make_kuid or make_kgid. Test if the value is different from what is stored in status and update changed. Update the value in status. In xdr_encode_AFS_StoreStatus call from_kuid or from_kgid as we are computing the on the wire encoding. Initialize uids with GLOBAL_ROOT_UID instead of 0. Initialize gids with GLOBAL_ROOT_GID instead of 0. Cc: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2013-02-13afs: Only allow mounting afs in the intial network namespaceEric W. Biederman
rxrpc sockets only work in the initial network namespace so it isn't possible to support afs in any other network namespace. Cc: David Howells <dhowells@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-12afs: Remove unused structure afs_store_statusEric W. Biederman
While looking for kuid_t and kgid_t conversions I found this structure that has never been used since it was added to the kernel in 2007. The obvious for this structure to be used is in xdr_encode_AFS_StoreStatus and that function uses a small handful of local variables instead. So remove the unnecessary structure to prevent confusion. Cc: David Howells <dhowells@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-01-21fs/afs: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: David Howells <dhowells@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-08-13workqueue: use mod_delayed_work() instead of cancel + queueTejun Heo
Convert delayed_work users doing cancel_delayed_work() followed by queue_delayed_work() to mod_delayed_work(). Most conversions are straight-forward. Ones worth mentioning are, * drivers/edac/edac_mc.c: edac_mc_workq_setup() converted to always use mod_delayed_work() and cancel loop in edac_mc_reset_delay_period() is dropped. * drivers/platform/x86/thinkpad_acpi.c: No need to remember whether watchdog is active or not. @fan_watchdog_active and related code dropped. * drivers/power/charger-manager.c: Seemingly a lot of delayed_work_pending() abuse going on here. [delayed_]work_pending() are unsynchronized and racy when used like this. I converted one instance in fullbatt_handler(). Please conver the rest so that it invokes workqueue APIs for the intended target state rather than trying to game work item pending state transitions. e.g. if timer should be modified - call mod_delayed_work(), canceled - call cancel_delayed_work[_sync](). * drivers/thermal/thermal_sys.c: thermal_zone_device_set_polling() simplified. Note that round_jiffies() calls in this function are meaningless. round_jiffies() work on absolute jiffies not delta delay used by delayed_work. v2: Tomi pointed out that __cancel_delayed_work() users can't be safely converted to mod_delayed_work(). They could be calling it from irq context and if that happens while delayed_work_timer_fn() is running, it could deadlock. __cancel_delayed_work() users are dropped. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Doug Thompson <dougthompson@xmission.com> Cc: David Airlie <airlied@linux.ie> Cc: Roland Dreier <roland@kernel.org> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <len.brown@intel.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Johannes Berg <johannes@sipsolutions.net>
2012-07-14VFS: Pass mount flags to sget()David Howells
Pass mount flags to sget() so that it can use them in initialising a new superblock before the set function is called. They could also be passed to the compare function. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata * to ->d_revalidate()Al Viro
Just the lookup flags. Die, bastard, die... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2012-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "This is _not_ all; in particular, Miklos' and Jan's stuff is not there yet." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits) ext4: initialization of ext4_li_mtx needs to be done earlier debugfs-related mode_t whack-a-mole hfsplus: add an ioctl to bless files hfsplus: change finder_info to u32 hfsplus: initialise userflags qnx4: new helper - try_extent() qnx4: get rid of qnx4_bread/qnx4_getblk take removal of PF_FORKNOEXEC to flush_old_exec() trim includes in inode.c um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it um: embed ->stub_pages[] into mmu_context gadgetfs: list_for_each_safe() misuse ocfs2: fix leaks on failure exits in module_init ecryptfs: make register_filesystem() the last potential failure exit ntfs: forgets to unregister sysctls on register_filesystem() failure logfs: missing cleanup on register_filesystem() failure jfs: mising cleanup on register_filesystem() failure make configfs_pin_fs() return root dentry on success configfs: configfs_create_dir() has parent dentry in dentry->d_parent configfs: sanitize configfs_create() ...
2012-03-21Merge branch 'kmap_atomic' of git://github.com/congwang/linuxLinus Torvalds
Pull kmap_atomic cleanup from Cong Wang. It's been in -next for a long time, and it gets rid of the (no longer used) second argument to k[un]map_atomic(). Fix up a few trivial conflicts in various drivers, and do an "evil merge" to catch some new uses that have come in since Cong's tree. * 'kmap_atomic' of git://github.com/congwang/linux: (59 commits) feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename] drbd: remove the second argument of k[un]map_atomic() zcache: remove the second argument of k[un]map_atomic() gma500: remove the second argument of k[un]map_atomic() dm: remove the second argument of k[un]map_atomic() tomoyo: remove the second argument of k[un]map_atomic() sunrpc: remove the second argument of k[un]map_atomic() rds: remove the second argument of k[un]map_atomic() net: remove the second argument of k[un]map_atomic() mm: remove the second argument of k[un]map_atomic() lib: remove the second argument of k[un]map_atomic() power: remove the second argument of k[un]map_atomic() kdb: remove the second argument of k[un]map_atomic() udf: remove the second argument of k[un]map_atomic() ubifs: remove the second argument of k[un]map_atomic() squashfs: remove the second argument of k[un]map_atomic() reiserfs: remove the second argument of k[un]map_atomic() ocfs2: remove the second argument of k[un]map_atomic() ntfs: remove the second argument of k[un]map_atomic() ...
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-03-20AFS: checking wrong bit in afs_readpages()Dan Carpenter
We should be testing "if (vnode->flags & (1 << 4))" instead of "if (vnode->flags & 4) {". The current test checks if the data was modified instead of deleted. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-20afs: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-16afs: Remote abort can cause BUG in rxrpc codeAnton Blanchard
When writing files to afs I sometimes hit a BUG: kernel BUG at fs/afs/rxrpc.c:179! With a backtrace of: afs_free_call afs_make_call afs_fs_store_data afs_vnode_store_data afs_write_back_from_locked_page afs_writepages_region afs_writepages The cause is: ASSERT(skb_queue_empty(&call->rx_queue)); Looking at a tcpdump of the session the abort happens because we are exceeding our disk quota: rx abort fs reply store-data error diskquota exceeded (32) So the abort error is valid. We hit the BUG because we haven't freed all the resources for the call. By freeing any skbs in call->rx_queue before calling afs_free_call we avoid hitting leaking memory and avoid hitting the BUG. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David Howells <dhowells@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-16afs: Read of file returns EBADMSGAnton Blanchard
A read of a large file on an afs mount failed: # cat junk.file > /dev/null cat: junk.file: Bad message Looking at the trace, call->offset wrapped since it is only an unsigned short. In afs_extract_data: _enter("{%u},{%zu},%d,,%zu", call->offset, len, last, count); ... if (call->offset < count) { if (last) { _leave(" = -EBADMSG [%d < %zu]", call->offset, count); return -EBADMSG; } Which matches the trace: [cat ] ==> afs_extract_data({65132},{524},1,,65536) [cat ] <== afs_extract_data() = -EBADMSG [0 < 65536] call->offset went from 65132 to 0. Fix this by making call->offset an unsigned int. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David Howells <dhowells@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: fix the stupidity with i_dentry in inode destructorsAl Viro
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once(); the cost of taking it into inode_init_always() will be negligible for pipes and sockets and negative for everything else. Not to mention the removal of boilerplate code from ->destroy_inode() instances... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: kill ->mnt_devname use in afs printksAl Viro
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-07-20AFS: Fix silly characters in a commentDavid Howells
Fix silly characters in a comment in AFS code (some weird characters replaced the word 'flag' some point way back). Reported-by: viro@ZenIV.linux.org.uk Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->permission()Al Viro
not used by the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to generic_permission()Al Viro
redundant; all callers get it duplicated in mask & MAY_NOT_BLOCK and none of them removes that bit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20kill check_acl callback of generic_permission()Al Viro
its value depends only on inode and does not change; we might as well store it in ->i_op->check_acl and be done with that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-16AFS: Use i_generation not i_version for the vnode uniquifierDavid Howells
Store the AFS vnode uniquifier in the i_generation field, not the i_version field of the inode struct. i_version can then be given the AFS data version number. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-16AFS: Set s_id in the superblock to the volume nameDavid Howells
Set s_id in the superblock to the name of the AFS volume that this superblock corresponds to. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-16afs: afs_fill_page reads too much, or wrong dataAnton Blanchard
afs_fill_page should read the page that is about to be written but the current implementation has a number of issues. If we aren't extending the file we always read PAGE_CACHE_SIZE at offset 0. If we are extending the file we try to read the entire file. Change afs_fill_page to read PAGE_CACHE_SIZE at the right offset, clamped to i_size. While here, avoid calling afs_fill_page when we are doing a PAGE_CACHE_SIZE write. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
