path: root/fs/afs
2010-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits) split invalidate_inodes() fs: skip I_FREEING inodes in writeback_sb_inodes fs: fold invalidate_list into invalidate_inodes fs: do not drop inode_lock in dispose_list fs: inode split IO and LRU lists fs: switch bdev inode bdi's correctly fs: fix buffer invalidation in invalidate_list fsnotify: use dget_parent smbfs: use dget_parent exportfs: use dget_parent fs: use RCU read side protection in d_validate fs: clean up dentry lru modification fs: split __shrink_dcache_sb fs: improve DCACHE_REFERENCED usage fs: use percpu counter for nr_dentry and nr_dentry_unused fs: simplify __d_free fs: take dcache_lock inside __d_path fs: do not assign default i_ino in new_inode fs: introduce a per-cpu last_ino allocator new helper: ihold() ...
2010-10-26writeback: remove nonblocking/encountered_congestion referencesWu Fengguang
This removes more dead code that was somehow missed by commit 0d99519efef (writeback: remove unused nonblocking and congestion checks). There are no behavior change except for the removal of two entries from one of the ext4 tracing interface. The nonblocking checks in ->writepages are no longer used because the flusher now prefer to block on get_request_wait() than to skip inodes on IO congestion. The latter will lead to more seeky IO. The nonblocking checks in ->writepage are no longer used because it's redundant with the WB_SYNC_NONE check. We no long set ->nonblocking in VM page out and page migration, because a) it's effectively redundant with WB_SYNC_NONE in current code b) it's old semantic of "Don't get stuck on request queues" is mis-behavior: that would skip some dirty inodes on congestion and page out others, which is unfair in terms of LRU age. Inspired by Christoph Hellwig. Thanks! Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: David Howells <dhowells@redhat.com> Cc: Sage Weil <sage@newdream.net> Cc: Steve French <sfrench@samba.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-05fs/locks.c: prepare for BKL removalArnd Bergmann
This prepares the removal of the big kernel lock from the file locking code. We still use the BKL as long as fs/lockd uses it and ceph might sleep, but we can flip the definition to a private spinlock as soon as that's done. All users outside of fs/lockd get converted to use lock_flocks() instead of lock_kernel() where appropriate. Based on an earlier patch to use a spinlock from Matthew Wilcox, who has attempted this a few times before, the earliest patch from over 10 years ago turned it into a semaphore, which ended up being slower than the BKL and was subsequently reverted. Someone should do some serious performance testing when this becomes a spinlock, since this has caused problems before. Using a spinlock should be at least as good as the BKL in theory, but who knows... Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Matthew Wilcox <willy@linux.intel.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Miklos Szeredi <mszeredi@suse.cz> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: John Kacur <jkacur@redhat.com> Cc: Sage Weil <sage@newdream.net> Cc: linux-kernel@vger.kernel.org Cc: linux-fsdevel@vger.kernel.org
2010-10-04BKL: Remove BKL from afsArnd Bergmann
The BKL is only used in put_super and fill_super, which are both protected by the superblocks s_umount rw_semaphore. Therefore it is safe to remove the BKL entirely. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: linux-afs@lists.infradead.org Cc: David Howells <dhowells@redhat.com>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [NFS] Set CONFIG_KEYS when CONFIG_NFS_USE_KERNEL_DNS is set AFS: Implement an autocell mount capability [ver #2] DNS: If the DNS server returns an error, allow that to be cached [ver #2] NFS: Use kernel DNS resolver [ver #2] cifs: update README to include details about 'fsc' option
2010-08-12Add a dummy printk function for the maintenance of unused printksDavid Howells
Add a dummy printk function for the maintenance of unused printks through gcc format checking, and also so that side-effect checking is maintained too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11AFS: Implement an autocell mount capability [ver #2]wanglei
Implement the ability for the root directory of a mounted AFS filesystem to accept lookups of arbitrary directory names, to interpet the names as the names of cells, to look the cell names up in the DNS for AFSDB records and to mount the root.cell volume of the nominated cell on the pseudo-directory created by lookup. This facility is requested by passing: -o autocell to the mountpoint for which this is desired, usually the /afs mount. To use this facility, a DNS upcall program is required for AFSDB records. This can be obtained from: http://people.redhat.com/~dhowells/afs/dns.afsdb.c It should be compiled with -lresolv and -lkeyutils and installed as, say: /usr/sbin/dns.afsdb Then the following line needs to be added to /sbin/request-key.conf: create dns_resolver afsdb:* * /usr/sbin/dns.afsdb %k This can be tested by mounting AFS, say: insmod dns_resolver.ko insmod af-rxrpc.ko insmod kafs.ko rootcell=grand.central.org mount -t afs "#grand.central.org:root.cell." /afs -o autocell and doing: ls /afs/grand.central.org/ which should show: archive/ cvs/ doc/ local/ project/ service/ software/ user/ www/ if it works. Signed-off-by: Wang Lei <wang840925@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-11DNS: If the DNS server returns an error, allow that to be cached [ver #2]Wang Lei
If the DNS server returns an error, allow that to be cached in the DNS resolver key in lieu of a value. Userspace passes the desired error number as an option in the payload: "#dnserror=<number>" Userspace must map h_errno from the name resolution routines to an appropriate Linux error before passing it up. Something like the following mapping is recommended: [HOST_NOT_FOUND] = ENODATA, [TRY_AGAIN] = EAGAIN, [NO_RECOVERY] = ECONNREFUSED, [NO_DATA] = ENODATA, in lieu of Linux errors specifically for representing name service errors. The filesystem must map these errors appropropriately before passing them to userspace. AFS is made to map ENODATA and EAGAIN to EDESTADDRREQ for the return to userspace; ECONNREFUSED is allowed to stand as is. The error can be seen in /proc/keys as a negative number after the description of the key. Compare, for example, the following key entries: 2f97238c I--Q-- 1 53s 3f010000 0 0 dns_resol afsdb:grand.centrall.org: -61 338bfbbe I--Q-- 1 59m 3f010000 0 0 dns_resol afsdb:grand.central.org: 37 If the error option is supplied in the payload, the main part of the payload is discarded. The key should have an expiry time set by userspace. Signed-off-by: Wang Lei <wang840925@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-11afs: destroy work queue on init failureDan Carpenter
We can clean up the work queue on this error path. This function is called from afs_init(). Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09convert remaining ->clear_inode() to ->evict_inode()Al Viro
2010-08-07AFS: Fix the module init error handlingDavid Howells
Fix the module init error handling. There are a bunch of goto labels for aborting the init procedure at different points and just undoing what needs undoing - they aren't all in the right places, however. This can lead to an oops like the following: BUG: unable to handle kernel NULL pointer dereference at 0000000000000020 IP: [<ffffffff81042a31>] destroy_workqueue+0x17/0xc0 ... Modules linked in: kafs(+) dns_resolver rxkad af_rxrpc fscache Pid: 2171, comm: insmod Not tainted 2.6.35-cachefs+ #319 DG965RY/ ... Process insmod (pid: 2171, threadinfo ffff88003ca6a000, task ffff88003dcc3050) ... Call Trace: [<ffffffffa0055994>] afs_callback_update_kill+0x10/0x12 [kafs] [<ffffffffa007d1c5>] afs_init+0x190/0x1ce [kafs] [<ffffffffa007d035>] ? afs_init+0x0/0x1ce [kafs] [<ffffffff810001ef>] do_one_initcall+0x59/0x14e [<ffffffff8105f7ee>] sys_init_module+0x9c/0x1de [<ffffffff81001eab>] system_call_fastpath+0x16/0x1b Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05DNS: Make AFS go to the DNS for AFSDB records for unknown cellsWang Lei
Add DNS query support for AFS so that it can get the IP addresses of Volume Location servers from the DNS using an AFSDB record. This requires userspace support. /etc/request-key.conf must be configured to invoke a helper for dns_resolver type keys with a subtype of "afsdb:" in the description. Signed-off-by: Wang Lei <wang840925@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-07-06writeback: remove writeback_inodes_wbcChristoph Hellwig
This was just an odd wrapper around writeback_inodes_wb. Removing this also allows to get rid of the bdi member of struct writeback_control which was rather out of place there. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-01AFS: Fix possible null pointer dereference in afs_alloc_server()Denis Kirjanov
Fix a possible null pointer dereference in afs_alloc_server(): the server pointer is NULL if there was an allocation failure, and under such a condition, we can't dereference it in the _leave() statement. Signed-off-by: Denis Kirjanov <dkirjanov@kernel.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21AFS: Don't put struct file on the stackAl Viro
Don't put struct file on the stack as it takes up quite a lot of space and violates lifetime rules for struct file. Rather than calling afs_readpage() indirectly from the directory routines by way of read_mapping_page(), split afs_readpage() to have afs_page_filler() that's given a key instead of a file and call read_cache_page(), specifying the new function directly. Use it in afs_readpages() as well. Also make use of this in afs_mntpt_check_symlink() too for the same reason. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com>
2010-04-28Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: coda: move backing-dev.h kernel include inside __KERNEL__ mtd: ensure that bdi entries are properly initialized and registered Move mtd_bdi_*mappable to mtdcore.c btrfs: convert to using bdi_setup_and_register() Catch filesystems lacking s_bdi drbd: Terminate a connection early if sending the protocol fails drbd: fix memory leak Fix JFFS2 sync silent failure smbfs: add bdi backing to mount session ncpfs: add bdi backing to mount session exofs: add bdi backing to mount session ecryptfs: add bdi backing to mount session coda: add bdi backing to mount session cifs: add bdi backing to mount session afs: add bdi backing to mount session. 9p: add bdi backing to mount session bdi: add helper function for doing init and register of a bdi for a file system block: ensure jiffies wrap is handled correctly in blk_rq_timed_out_timer
2010-04-22afs: add bdi backing to mount session.Jens Axboe
This ensures that dirty data gets flushed properly. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-21AFS: Don't pass error value to page_cache_release() in error handlingDavid Howells
In the error handling in afs_mntpt_do_automount(), we pass an error pointer to page_cache_release() if read_mapping_page() failed. Instead, we should extend the gotos around the error handling we don't need. Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-22AFS: Potential null dereferenceDan Carpenter
It seems clear from the surrounding code that xpermits is allowed to be NULL here. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-05make sure data is on disk before calling ->write_inodeChristoph Hellwig
Similar to the fsync issue fixed a while ago in commit 2daea67e966dc0c42067ebea015ddac6834cef88 we need to write for data to actually hit the disk before writing out the metadata to guarantee data integrity for filesystems that modify the inode in the data I/O completion path. Currently XFS and NFS handle this manually, and AFS has a write_inode method that does nothing but waiting for data, while others are possibly missing out on this. Fortunately this change has a lot less impact than the fsync change as none of the write_inode methods starts data writeout of any form by itself. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-10afs: remove manual O_SYNC handlingChristoph Hellwig
generic_file_aio_write already calls into ->fsync to handle O_SYNC/O_DSYNC. Remove the duplicate manual invocation. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-10vfs: Implement proper O_SYNC semanticsChristoph Hellwig
While Linux provided an O_SYNC flag basically since day 1, it took until Linux 2.4.0-test12pre2 to actually get it implemented for filesystems, since that day we had generic_osync_around with only minor changes and the great "For now, when the user asks for O_SYNC, we'll actually give O_DSYNC" comment. This patch intends to actually give us real O_SYNC semantics in addition to the O_DSYNC semantics. After Jan's O_SYNC patches which are required before this patch it's actually surprisingly simple, we just need to figure out when to set the datasync flag to vfs_fsync_range and when not. This patch renames the existing O_SYNC flag to O_DSYNC while keeping it's numerical value to keep binary compatibility, and adds a new real O_SYNC flag. To guarantee backwards compatiblity it is defined as expanding to both the O_DSYNC and the new additional binary flag (__O_SYNC) to make sure we are backwards-compatible when compiled against the new headers. This also means that all places that don't care about the differences can just check O_DSYNC and get the right behaviour for O_SYNC, too - only places that actuall care need to check __O_SYNC in addition. Drivers and network filesystems have been updated in a fail safe way to always do the full sync magic if O_DSYNC is set. The few places setting O_SYNC for lower layers are kept that way for now to stay failsafe. We enforce that O_DSYNC is set when __O_SYNC is set early in the open path to make sure we always get these sane options. Note that parisc really screwed up their headers as they already define a O_DSYNC that has always been a no-op. We try to repair it by using it for the new O_DSYNC and redefinining O_SYNC to send both the traditional O_SYNC numerical value _and_ the O_DSYNC one. Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jan Kara <jack@suse.cz>
2009-11-19FS-Cache: Handle pages pending storage that get evicted under OOM conditionsDavid Howells
Handle netfs pages that the vmscan algorithm wants to evict from the pagecache under OOM conditions, but that are waiting for write to the cache. Under these conditions, vmscan calls the releasepage() function of the netfs, asking if a page can be discarded. The problem is typified by the following trace of a stuck process: kslowd005 D 0000000000000000 0 4253 2 0x00000080 ffff88001b14f370 0000000000000046 ffff880020d0d000 0000000000000007 0000000000000006 0000000000000001 ffff88001b14ffd8 ffff880020d0d2a8 000000000000ddf0 00000000000118c0 00000000000118c0 ffff880020d0d2a8 Call Trace: [<ffffffffa00782d8>] __fscache_wait_on_page_write+0x8b/0xa7 [fscache] [<ffffffff8104c0f1>] ? autoremove_wake_function+0x0/0x34 [<ffffffffa0078240>] ? __fscache_check_page_write+0x63/0x70 [fscache] [<ffffffffa00b671d>] nfs_fscache_release_page+0x4e/0xc4 [nfs] [<ffffffffa00927f0>] nfs_release_page+0x3c/0x41 [nfs] [<ffffffff810885d3>] try_to_release_page+0x32/0x3b [<ffffffff81093203>] shrink_page_list+0x316/0x4ac [<ffffffff8109372b>] shrink_inactive_list+0x392/0x67c [<ffffffff813532fa>] ? __mutex_unlock_slowpath+0x100/0x10b [<ffffffff81058df0>] ? trace_hardirqs_on_caller+0x10c/0x130 [<ffffffff8135330e>] ? mutex_unlock+0x9/0xb [<ffffffff81093aa2>] shrink_list+0x8d/0x8f [<ffffffff81093d1c>] shrink_zone+0x278/0x33c [<ffffffff81052d6c>] ? ktime_get_ts+0xad/0xba [<ffffffff81094b13>] try_to_free_pages+0x22e/0x392 [<ffffffff81091e24>] ? isolate_pages_global+0x0/0x212 [<ffffffff8108e743>] __alloc_pages_nodemask+0x3dc/0x5cf [<ffffffff81089529>] grab_cache_page_write_begin+0x65/0xaa [<ffffffff8110f8c0>] ext3_write_begin+0x78/0x1eb [<ffffffff81089ec5>] generic_file_buffered_write+0x109/0x28c [<ffffffff8103cb69>] ? current_fs_time+0x22/0x29 [<ffffffff8108a509>] __generic_file_aio_write+0x350/0x385 [<ffffffff8108a588>] ? generic_file_aio_write+0x4a/0xae [<ffffffff8108a59e>] generic_file_aio_write+0x60/0xae [<ffffffff810b2e82>] do_sync_write+0xe3/0x120 [<ffffffff8104c0f1>] ? autoremove_wake_function+0x0/0x34 [<ffffffff810b18e1>] ? __dentry_open+0x1a5/0x2b8 [<ffffffff810b1a76>] ? dentry_open+0x82/0x89 [<ffffffffa00e693c>] cachefiles_write_page+0x298/0x335 [cachefiles] [<ffffffffa0077147>] fscache_write_op+0x178/0x2c2 [fscache] [<ffffffffa0075656>] fscache_op_execute+0x7a/0xd1 [fscache] [<ffffffff81082093>] slow_work_execute+0x18f/0x2d1 [<ffffffff8108239a>] slow_work_thread+0x1c5/0x308 [<ffffffff8104c0f1>] ? autoremove_wake_function+0x0/0x34 [<ffffffff810821d5>] ? slow_work_thread+0x0/0x308 [<ffffffff8104be91>] kthread+0x7a/0x82 [<ffffffff8100beda>] child_rip+0xa/0x20 [<ffffffff8100b87c>] ? restore_args+0x0/0x30 [<ffffffff8102ef83>] ? tg_shares_up+0x171/0x227 [<ffffffff8104be17>] ? kthread+0x0/0x82 [<ffffffff8100bed0>] ? child_rip+0x0/0x20 In the above backtrace, the following is happening: (1) A page storage operation is being executed by a slow-work thread (fscache_write_op()). (2) FS-Cache farms the operation out to the cache to perform (cachefiles_write_page()). (3) CacheFiles is then calling Ext3 to perform the actual write, using Ext3's standard write (do_sync_write()) under KERNEL_DS directly from the netfs page. (4) However, for Ext3 to perform the write, it must allocate some memory, in particular, it must allocate at least one page cache page into which it can copy the data from the netfs page. (5) Under OOM conditions, the memory allocator can't immediately come up with a page, so it uses vmscan to find something to discard (try_to_free_pages()). (6) vmscan finds a clean netfs page it might be able to discard (possibly the one it's trying to write out). (7) The netfs is called to throw the page away (nfs_release_page()) - but it's called with __GFP_WAIT, so the netfs decides to wait for the store to complete (__fscache_wait_on_page_write()). (8) This blocks a slow-work processing thread - possibly against itself. The system ends up stuck because it can't write out any netfs pages to the cache without allocating more memory. To avoid this, we make FS-Cache cancel some writes that aren't in the middle of actually being performed. This means that some data won't make it into the cache this time. To support this, a new FS-Cache function is added fscache_maybe_release_page() that replaces what the netfs releasepage() functions used to do with respect to the cache. The decisions fscache_maybe_release_page() makes are counted and displayed through /proc/fs/fscache/stats on a line labelled "VmScan". There are four counters provided: "nos=N" - pages that weren't pending storage; "gon=N" - pages that were pending storage when we first looked, but weren't by the time we got the object lock; "bsy=N" - pages that we ignored as they were actively being written when we looked; and "can=N" - pages that we cancelled the storage of. What I'd really like to do is alter the behaviour of the cancellation heuristics, depending on how necessary it is to expel pages. If there are plenty of other pages that aren't waiting to be written to the cache that could be ejected first, then it would be nice to hold up on immediate cancellation of cache writes - but I don't see a way of doing that. Signed-off-by: David Howells <dhowells@redhat.com>
2009-10-01afs: remove cache.hChristoph Hellwig
It's just a wrapper for <linux/fscache.h>, so remove it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: make file_lock_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16writeback: get rid of wbc->for_writepagesJens Axboe
It's only set, it's never checked. Kill it. Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-08-27AFS: Stop readlink() on AFS crashing due to NULL 'file' ptrDavid Howells
kAFS crashes when asked to read a symbolic link because page_getlink() passes a NULL file pointer to read_mapping_page(), but afs_readpage() expects a file pointer from which to extract a key. Modify afs_readpage() to request the appropriate key from the calling process's keyrings if a file struct is not supplied with one attached. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Anton Blanchard <anton@samba.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12AFS: Fix compilation warningArtem Bityutskiy
Fix the following warning: fs/afs/dir.c: In function 'afs_d_revalidate': fs/afs/dir.c:567: warning: 'fid.vnode' may be used uninitialized in this function fs/afs/dir.c:567: warning: 'fid.unique' may be used uninitialized in this function by marking the 'fid' variable as an uninitialized_var. The problem is that gcc doesn't always manage to work out that fid is always set on the path through the function that uses it. Cc: linux-afs@lists.infradead.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-08headers: mnt_namespace.h reduxAlexey Dobriyan
Fix various silly problems wrt mnt_namespace.h: - exit_mnt_ns() isn't used, remove it - done that, sched.h and nsproxy.h inclusions aren't needed - mount.h inclusion was need for vfsmount_lock, but no longer - remove mnt_namespace.h inclusion from files which don't use anything from mnt_namespace.h Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30AFS: Fix lock imbalanceJiri Slaby
Don't unlock on vfs_rejected_lock path in afs_do_setlk, since the lock is unlocked after abort_attempt label. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16AFS: Correctly translate auth error aborts and don't failover in such casesDavid Howells
Authentication error abort codes should be translated to appropriate Linux error codes, rather than all being translated to EREMOTEIO - which indicates that the server had internal problems. Additionally, a server shouldn't be marked unavailable and the next server tried if an authentication error occurs. This will quickly make all the servers unavailable to the client. Instead the error should be returned straight to the user. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11switch follow_down()Al Viro
2009-05-09Fix races around the access to ->s_optionsAl Viro
Put generic_show_options read access to s_options under rcu_read_lock, split save_mount_options() into "we are setting it the first time" (uses in foo_fill_super()) and "we are relacing and freeing the old one", synchronize_rcu() before kfree() in the latter. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09Convert obvious places to deactivate_locked_super()Al Viro
2009-04-17AFS: Guard afs_file_readpage_read_complete() definition with CONFIG_AFS_FSCACHEMatt Kraai
If CONFIG_AFS_FSCACHE is not defined, the following warning is displayed when fs/afs/file.c is compiled: fs/afs/file.c:111: warning: ‘afs_file_readpage_read_complete’ defined but not used This occurs because all calls to this function are guarded by CONFIG_AFS_FSCACHE. Thus, guard its definition as well. Signed-off-by: Matt Kraai <kraai@ftbfs.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-09afs: BUG to BUG_ON changesStoyan Gaydarov
Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03FS-Cache: Make kAFS use FS-CacheDavid Howells
The attached patch makes the kAFS filesystem in fs/afs/ use FS-Cache, and through it any attached caches. The kAFS filesystem will use caching automatically if it's available. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-27constify dentry_operations: AFSAl Viro
2009-01-22fs/Kconfig: move afs outAlexey Dobriyan
