path: root/fs/aio.c
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-02-25aio: fix race between io_destroy() and io_submit()Jan Kara
A race can occur when io_submit() races with io_destroy(): CPU1 CPU2 io_submit() do_io_submit() ... ctx = lookup_ioctx(ctx_id); io_destroy() Now do_io_submit() holds the last reference to ctx. ... queue new AIO put_ioctx(ctx) - frees ctx with active AIOs We solve this issue by checking whether ctx is being destroyed in AIO submission path after adding new AIO to ctx. Then we are guaranteed that either io_destroy() waits for new AIO or we see that ctx is being destroyed and bail out. Cc: Nick Piggin <npiggin@kernel.dk> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25aio: fix rcu ioctx lookupNick Piggin
aio-dio-invalidate-failure GPFs in aio_put_req from io_submit. lookup_ioctx doesn't implement the rcu lookup pattern properly. rcu_read_lock does not prevent refcount going to zero, so we might take a refcount on a zero count ioctx. Fix the bug by atomically testing for zero refcount before incrementing. [jack@suse.cz: added comment into the code] Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-26fs/aio: aio_wq isn't used in memory reclaim pathTejun Heo
aio_wq isn't used during memory reclaim. Convert to alloc_workqueue() without WQ_MEM_RECLAIM. It's possible to use system_wq but given that the number of work items is determined from userland and the work item may block, enforcing strict concurrency limit would be a good idea. Also, move fput_work to system_wq so that aio_wq is used soley to throttle the max concurrency of aio work items and fput_work doesn't interact with other work items. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: linux-aio@kvack.org
2011-01-17aio: check return value of create_workqueue()Namhyung Kim
Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-13aio: remove unused aio_run_iocbs()Jeff Moyer
aio_run_iocbs() is not used at all, so get rid of it. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13aio: remove unnecessary checkNamhyung Kim
'nr >= min_nr >= 0' always satisfies 'nr >= 0' so the check is unnecesary. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25aio: bump i_count instead of using igrabChris Mason
The aio batching code is using igrab to get an extra reference on the inode so it can safely batch. igrab will go ahead and take the global inode spinlock, which can be a bottleneck on large machines doing lots of AIO. In this case, igrab isn't required because we already have a reference on the file handle. It is safe to just bump the i_count directly on the inode. Benchmarking shows this patch brings IOP/s on tons of flash up by about 2.5X. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-09-22aio: do not return ERESTARTSYS as a result of AIOJan Kara
OCFS2 can return ERESTARTSYS from its write function when the process is signalled while waiting for a cluster lock (and the filesystem is mounted with intr mount option). Generally, it seems reasonable to allow filesystems to return this error code from its IO functions. As we must not leak ERESTARTSYS (and similar error codes) to userspace as a result of an AIO operation, we have to properly convert it to EINTR inside AIO code (restarting the syscall isn't really an option because other AIO could have been already submitted by the same io_submit syscall). Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Zach Brown <zach.brown@oracle.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-14aio: check for multiplication overflow in do_io_submitJeff Moyer
Tavis Ormandy pointed out that do_io_submit does not do proper bounds checking on the passed-in iocb array:        if (unlikely(nr < 0))                return -EINVAL;        if (unlikely(!access_ok(VERIFY_READ, iocbpp, (nr*sizeof(iocbpp)))))                return -EFAULT;                      ^^^^^^^^^^^^^^^^^^ The attached patch checks for overflow, and if it is detected, the number of iocbs submitted is scaled down to a number that will fit in the long.  This is an ok thing to do, as sys_io_submit is documented as returning the number of iocbs submitted, so callers should handle a return value of less than the 'nr' argument passed in. Reported-by: Tavis Ormandy <taviso@cmpxchg8b.com> Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05aio: fix wrong subsystem commentsSatoru Takeuchi
- sys_io_destroy(): acutually return -EINVAL if the context pointed to is invalidIndex: linux-2.6.33-rc4/fs/aio.c - sys_io_getevents(): An argument specifying timeout is not `when', but `timeout'. - sys_io_getevents(): Should describe what is returned if this syscall succeeds. Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27get rid of the magic around f_count in aioAl Viro
__aio_put_req() plays sick games with file refcount. What it wants is fput() from atomic context; it's almost always done with f_count > 1, so they only have to deal with delayed work in rare cases when their reference happens to be the last one. Current code decrements f_count and if it hasn't hit 0, everything is fine. Otherwise it keeps a pointer to struct file (with zero f_count!) around and has delayed work do __fput() on it. Better way to do it: use atomic_long_add_unless( , -1, 1) instead of !atomic_long_dec_and_test(). IOW, decrement it only if it's not the last reference, leave refcount alone if it was. And use normal fput() in delayed work. I've made that atomic_long_add_unless call a new helper - fput_atomic(). Drops a reference to file if it's safe to do in atomic (i.e. if that's not the last one), tells if it had been able to do that. aio.c converted to it, __fput() use is gone. req->ki_file *always* contributes to refcount now. And __fput() became static. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27aio: fix the compat vectored operationsJeff Moyer
The aio compat code was not converting the struct iovecs from 32bit to 64bit pointers, causing either EINVAL to be returned from io_getevents, or EFAULT as the result of the I/O. This patch passes a compat flag to io_submit to signal that pointer conversion is necessary for a given iocb array. A variant of this was tested by Michael Tokarev. I have also updated the libaio test harness to exercise this code path with good success. Further, I grabbed a copy of ltp and ran the testcases/kernel/syscall/readv and writev tests there (compiled with -m32 on my 64bit system). All seems happy, but extra eyes on this would be welcome. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix CONFIG_COMPAT=n build] Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Reported-by: Michael Tokarev <mjt@tls.msk.ru> Cc: Zach Brown <zach.brown@oracle.com> Cc: <stable@kernel.org> [2.6.35.1] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16aio: remove unused fieldShaohua Li
Don't know the reason, but it appears ki_wait field of iocb never gets used. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29block: move bdi/address_space unplug functions to backing-dev.hJens Axboe
There's nothing block related about them, the backing device is used by things like NFS etc as well. This gets rid of the need to protect such calls by CONFIG_BLOCK. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-28aio: implement request batchingJeff Moyer
Hi, Some workloads issue batches of small I/O, and the performance is poor due to the call to blk_run_address_space for every single iocb. Nathan Roberts pointed this out, and suggested that by deferring this call until all I/Os in the iocb array are submitted to the block layer, we can realize some impressive performance gains (up to 30% for sequential 4k reads in batches of 16). Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-23aio.c: move EXPORT* macros to line after functionH Hartley Sweeten
As mentioned in Documentation/CodingStyle, move EXPORT* macro's to the line immediately after the closing function brace line. Also, move the __initcall() similarly. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: move use_mm/unuse_mm from aio.c to mm/Michael S. Tsirkin
Anyone who wants to do copy to/from user from a kernel thread, needs use_mm (like what fs/aio has). Move that into mm/, to make reusing and exporting easier down the line, and make aio use it. Next intended user, besides aio, will be vhost-net. Acked-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30eventfd: revised interface and cleanupsDavide Libenzi
Change the eventfd interface to de-couple the eventfd memory context, from the file pointer instance. Without such change, there is no clean way to racely free handle the POLLHUP event sent when the last instance of the file* goes away. Also, now the internal eventfd APIs are using the eventfd context instead of the file*. This patch is required by KVM's IRQfd code, which is still under development. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Gregory Haskins <ghaskins@novell.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Avi Kivity <avi@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-19aio: lookup_ioctx can return the wrong value when looking up a bogus contextJeff Moyer
The libaio test harness turned up a problem whereby lookup_ioctx on a bogus io context was returning the 1 valid io context from the list (harness/cases/3.p). Because of that, an extra put_iocontext was done, and when the process exited, it hit a BUG_ON in the put_iocontext macro called from exit_aio (since we expect a users count of 1 and instead get 0). The problem was introduced by "aio: make the lookup_ioctx() lockless" (commit abf137dd7712132ee56d5b3143c2ff61a72a5faa). Thanks to Zach for pointing out that hlist_for_each_entry_rcu will not return with a NULL tpos at the end of the loop, even if the entry was not found. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Zach Brown <zach.brown@oracle.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-19eventfd: remove fput() call from possible IRQ contextDavide Libenzi
Remove a source of fput() call from inside IRQ context. Myself, like Eric, wasn't able to reproduce an fput() call from IRQ context, but Jeff said he was able to, with the attached test program. Independently from this, the bug is conceptually there, so we might be better off fixing it. This patch adds an optimization similar to the one we already do on ->ki_filp, on ->ki_eventfd. Playing with ->f_count directly is not pretty in general, but the alternative here would be to add a brand new delayed fput() infrastructure, that I'm not sure is worth it. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 16Heiko Carstens
2008-12-29aio: make the lookup_ioctx() locklessJens Axboe
The mm->ioctx_list is currently protected by a reader-writer lock, so we always grab that lock on the read side for doing ioctx lookups. As the workload is extremely reader biased, turn this into an rcu hlist so we can make lookup_ioctx() lockless. Get rid of the rwlock and use a spinlock for providing update side exclusion. There's usually only 1 entry on this list, so it doesn't make sense to look into fancier data structures. Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-26[PATCH] f_count may wrap aroundAl Viro
make it atomic_long_t; while we are at it, get rid of useless checks in affs, hfs and hpfs - ->open() always has it equal to 1, ->release() - to 0. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-25kill PF_BORROWED_MM in favour of PF_KTHREADOleg Nesterov
Kill PF_BORROWED_MM. Change use_mm/unuse_mm to not play with ->flags, and do s/PF_BORROWED_MM/PF_KTHREAD/ for a couple of other users. No functional changes yet. But this allows us to do further fixes/cleanups. oom_kill/ptrace/etc often check "p->mm != NULL" to filter out the kthreads, this is wrong because of use_mm(). The problem with PF_BORROWED_MM is that we need task_lock() to avoid races. With this patch we can check PF_KTHREAD directly, or use a simple lockless helper: /* The result must not be dereferenced !!! */ struct mm_struct *__get_task_mm(struct task_struct *tsk) { if (tsk->flags & PF_KTHREAD) return NULL; return tsk->mm; } Note also ecard_task(). It runs with ->mm != NULL, but it's the kernel thread without PF_BORROWED_MM. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06uml: activate_mm: remove the dead PF_BORROWED_MM checktip-core-topology-2008-06-16_09.13_Montip-core-misc-2008-06-16_09.11_MonOleg Nesterov
use_mm() was changed to use switch_mm() instead of activate_mm(), since then nobody calls (and nobody should call) activate_mm() with PF_BORROWED_MM bit set. As Jeff Dike pointed out, we can also remove the "old != new" check, it is always true. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30debugobjects: add timer specific object debugging codeThomas Gleixner
Add calls to the generic object debugging infrastructure and provide fixup functions which allow to keep the system alive when recoverable problems have been detected by the object debugging core code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29aio: fix misleading commentsJeff Moyer
The FIXME comments are inaccurate. The locking comment over lookup_ioctx() is wrong. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Shen Feng <shen@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Remove duplicated unlikely() in IS_ERR()Hirofumi Nakagawa
Some drivers have duplicated unlikely() macros. IS_ERR() already has unlikely() in itself. This patch cleans up such pointless code. Signed-off-by: Hirofumi Nakagawa <hnakagawa@miraclelinux.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29fs/aio.c: make 3 functions staticAdrian Bunk
Make the following needlessly global functions static: - __put_ioctx() - lookup_ioctx() - io_submit_one() Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Zach Brown <zach.brown@oracle.com> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28aio: io_getevents() should return if io_destroy() is invokedJeff Moyer
This patch wakes up a thread waiting in io_getevents if another thread destroys the context. This was tested using a small program that spawns a thread to wait in io_getevents while the parent thread destroys the io context and then waits for the getevents thread to exit. Without this patch, the program hangs indefinitely. With the patch, the program exits as expected. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: Christopher Smith <x@xman.org> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11eventfd/kaio integration fixDavide Libenzi
Jeff Roberson discovered a race when using kaio eventfd based notifications. When it occurs it can lead tomissed wakeups and hung userspace. This patch fixes the race by moving the notification inside the spinlocked section of kaio. The operation is safe since eventfd spinlock and kaio one are unrelated. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Zach Brown <zach.brown@oracle.com> Cc: Jeff Roberson <jroberson@chesapeake.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-10asmlinkage_protect sys_io_geteventsRoland McGrath
Use asmlinkage_protect in sys_io_getevents, because GCC for i386 with CONFIG_FRAME_POINTER=n can decide to clobber an argument word on the stack, i.e. the user struct pt_regs. Here the problem is not a tail call, but just the compiler's use of the stack when it inlines and optimizes the body of the called function. This seems to avoid it. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19aio: bad AIO race in aio_complete() leads to process hangQuentin Barnes
My group ran into a AIO process hang on a 2.6.24 kernel with the process sleeping indefinitely in io_getevents(2) waiting for the last wakeup to come and it never would. We ran the tests on x86_64 SMP. The hang only occurred on a Xeon box ("Clovertown") but not a Core2Duo ("Conroe"). On the Xeon, the L2 cache isn't shared between all eight processors, but is L2 is shared between between all two processors on the Core2Duo we use. My analysis of the hang is if you go down to the second while-loop in read_events(), what happens on processor #1: 1) add_wait_queue_exclusive() adds thread to ctx->wait 2) aio_read_evt() to check tail 3) if aio_read_evt() returned 0, call [io_]schedule() and sleep In aio_complete() with processor #2: A) info->tail = tail; B) waitqueue_active(&ctx->wait) C) if waitqueue_active() returned non-0, call wake_up() The way the code is written, step 1 must be seen by all other processors before processor 1 checks for pending events in step 2 (that were recorded by step A) and step A by processor 2 must be seen by all other processors (checked in step 2) before step B is done. The race I believed I was seeing is that steps 1 and 2 were effectively swapped due to the __list_add() being delayed by the L2 cache not shared by some of the other processors. Imagine: proc 2: just before step A proc 1, step 1: adds to ctx->wait, but is not visible by other processors yet proc 1, step 2: checks tail and sees no pending events proc 2, step A: updates tail proc 1, step 3: calls [io_]schedule() and sleeps proc 2, step B: checks ctx->wait, but sees no one waiting, skips wakeup so proc 1 sleeps indefinitely My patch adds a memory barrier between steps A and B. It ensures that the update in step 1 gets seen on processor 2 before continuing. If processor 1 was just before step 1, the memory barrier makes sure that step A (update tail) gets seen by the time processor 1 makes it to step 2 (check tail). Before the patch our AIO process would hang virtually 100% of the time. After the patch, we have yet to see the process ever hang. Signed-off-by: Quentin Barnes <qbarnes+linux@yahoo-inc.com> Reviewed-by: Zach Brown <zach.brown@oracle.com> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: <stable@kernel.org> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ We should probably disallow that "if (waitqueue_active()) wake_up()" coding pattern, because it's so often buggy wrt memory ordering ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aio: negative offset should return -EINVALRusty Russell
An AIO read or write should return -EINVAL if the offset is negative. This check matches the one in pread and pwrite. This was found by the libaio test suite. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aio: partial write should not return error codeRusty Russell
When an AIO write gets an error after writing some data (eg. ENOSPC), it should return the amount written already, not the error. Just like write() is supposed to. This was found by the libaio test suite. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-By: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08fs: remove fastcall, it is always emptyHarvey Harrison
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30core: remove last users of empty FASTCALL macroHarvey Harrison
FASTCALL is always empty after the x86 removal. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-05aio: only account I/O wait time in read_events if there are active requestsJeff Moyer
On 2.6.24, top started showing 100% iowait on one CPU when a UML instance was running (but completely idle). The UML code sits in io_getevents waiting for an event to be submitted and completed. Fix this by checking ctx->reqs_active before scheduling to determine whether or not we are waiting for I/O. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Jeff Dike <jdike@addtoit.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Remove struct task_struct::io_waitAlexey Dobriyan
Hell knows what happened in commit 63b05203af57e7de4f3bb63b8b81d43bc196d32b during 2.6.9 development. Commit introduced io_wait field which remained write-only than and still remains write-only. Also garbage collect macros which "use" io_wait. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17aio: account I/O wait time properlyJeff Moyer
Some months back I proposed changing the schedule() call in read_events to an io_schedule(): http://osdir.com/ml/linux.kernel.aio.general/2006-10/msg00024.html This was rejected as there are AIO operations that do not initiate disk I/O. I've had another look at the problem, and the only AIO operation that will not initiate disk I/O is IOCB_CMD_NOOP. However, this command isn't even wired up! Given that it doesn't work, and hasn't for *years*, I'm going to suggest again that we do proper I/O accounting when using AIO. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Zach Brown <zach.brown@oracle.com> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Suparna Bhattacharya <suparna@in.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-08AIO: fix cleanup in io_submit_one(...)Yan Zheng
When IOCB_FLAG_RESFD flag is set and iocb->aio_resfd is incorrect, statement 'goto out_put_req' is executed. At label 'out_put_req', aio_put_req(..) is called, which requires 'req->ki_filp' set. Signed-off-by: Yan Zheng<yanzheng@21cn.com> Cc: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11signal/timer/event: KAIO eventfd support exampleDavide Libenzi
This is an example about how to add eventfd support to the current KAIO code, in order to enable KAIO to post readiness events to a pollable fd (hence compatible with POSIX select/poll). The KAIO code simply signals the eventfd fd when events are ready, and this triggers a POLLIN in the fd. This patch uses a reserved for future use member of the struct iocb to pass an eventfd file descriptor, that KAIO will use to post events every time a request completes. At that point, an aio_getevents() will return the completed result to a struct io_event. I made a quick test program to verify the patch, and it runs fine here: http://www.xmailserver.org/eventfd-aio-test.c The test program uses poll(2), but it'd, of course, work with select and epoll too. This can allow to schedule both block I/O and other poll-able devices requests, and wait for results using select/poll/epoll. In a typical scenario, an application would submit KAIO request using aio_submit(), and will also use epoll_ctl() on the whole other class of devices (that with the addition of signals, timers and user events, now it's pretty much complete), and then would: epoll_wait(...); for_each_event { if (curr_event_is_kaiofd) { aio_getevents(); dispatch_aio_events(); } else { dispatch_epoll_event(); } } Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09unify flush_work/flush_work_keventd and rename it to cancel_work_syncOleg Nesterov
flush_work(wq, work) doesn't need the first parameter, we can use cwq->wq (this was possible from the very beginnig, I missed this). So we can unify flush_work_keventd and flush_work. Also, rename flush_work() to cancel_work_sync() and fix all callers. Perhaps this is not the best name, but "flush_work" is really bad. (akpm: this is why the earlier patches bypassed maintainers) Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Tejun Heo <htejun@gmail.com> Cc: Auke Kok <auke-jan.h.kok@intel.com>, Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09aio: use flush_work()Andrew Morton
Migrate AIO over to use flush_work(). Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07KMEM_CACHE(): simplify slab cache creationChristoph Lameter
This patch provides a new macro KMEM_CACHE(<struct>, <flags>) to simplify slab creation. KMEM_CACHE creates a slab with the name of the struct, with the size of the struct and with the alignment of the struct. Additional slab flags may be specified if necessary. Example struct test_slab { int a,b,c; struct list_head; } __cacheline_aligned_in_smp; test_slab_cache = KMEM_CACHE(test_slab, SLAB_PANIC) will create a new slab named "test_slab" of the size sizeof(struct test_slab) and aligned to the alignment of test slab. If it fails then we panic. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-27[PATCH] aio: remove bare user-triggerable error printkZach Brown
The user can generate console output if they cause do_mmap() to fail during sys_io_setup(). This was seen in a regression test that does exactly that by spinning calling mmap() until it gets -ENOMEM before calling io_setup(). We don't need this printk at all, just remove it. Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Transform kmem_cache_alloc()+memset(0) -> kmem_cache_zalloc().Robert P. J. Day
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the corresponding "kmem_cache_zalloc()" call. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Roland McGrath <roland@redhat.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Acked-by: Joel Becker <Joel.Becker@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jan Kara <jack@ucw.cz> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Remove final references to deprecated "MAP_ANON" page protection flagRobert P. J. Day
Remove the last vestiges of the long-deprecated "MAP_ANON" page protection flag: use "MAP_ANONYMOUS" instead. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
